[Aust-NZ] Fw: BlueNet MEST Version 1.1
Bruce.Bannerman at dpi.vic.gov.au
Sun Jun 15 19:48:03 EDT 2008
Simon,
Congratulations on getting the production version of Bluenet Mest out!
Bruce
Bruce Bannerman
IT Solutions Architect
Information Development Branch
Minerals and Petroleum Division
Department of Primary Industries - Victoria
Australia
----- Forwarded by Bruce Bannerman/DPI/VICGOV1 on 16/06/2008 09:42 AM
Simon Pigot <sppigot at utas.edu.au>
Sent by: owner-anzlicmet-l at postoffice.utas.edu.au
15/06/2008 07:21 PM
Please respond to
Simon.Pigot at utas.edu.au
To
anzlicmet-l at listserv.its.utas.edu.au,
bluenet-mestdrg at postoffice.utas.edu.au
cc
Subject
Hi Everyone,
The production version of the BlueNet MEST is available (or has been
available since 11/06/08) for download from
http://anzlicmet.bluenet.utas.edu.au
Note this version is basically beta5 plus bug fixes. The trac site (same
as download site above) is still active and up to date for bug reporting
and we are currently working with the geonetwork community to get the
modifications and fixes into the trunk - some progress on this should
result from the OSGeo Hacking Workshop in Bolsena this week.
The source code is now in a project area of its own (known as a sandbox)
in the subversion repository used by the geonetwork trunk - go to
http://geonetwork.svn.sourceforge.net/viewvc/geonetwork/sandbox/ to
browse and follow the instructions on
http://sourceforge.net/projects/geonetwork/ for more details on how to
download.
We hope to reach the situation fairly quickly where national profiles
like ANZLIC, Australian Marine Community Profile etc will be available
as an optional install pack that you can select when you install the
trunk and then later progress to having profiles as plugins. When
profiles can be selectively installed and changes accepted by the
community have been merged with the trunk, then focus will switch from
the BlueNetMEST to the trunk.
As always, the success of the whole GeoNetwork tree depends upon
community support ie. you :-), so I hope that you will (continue to) use
the BlueNetMEST sandbox and release as a way of "ratcheting up" your
involvement in GeoNetwork and that testing/feedback/interest will
continue.
Cheers and thanks,
Simon
anzlicmet-l - discussion of the anzlic metadata entry tool (met)
to find out how to subscribe/unsubscribe etc send a blank email to
anzlicmet-l-request at listserv.its.utas.edu.au
to post send your email to anzlicmet-l at listserv.its.utas.edu.au
Notice:
This email and any attachments may contain information that is personal,
confidential, legally privileged and/or copyright.No part of it should be reproduced,
adapted or communicated without the prior written consent of the copyright owner.
It is the responsibility of the recipient to check for and remove viruses.
If you have received this email in error, please notify the sender by return email, delete
it from your system and destroy any copies. You are not authorised to use, communicate or rely on the information
contained in this email.
Please consider the environment before printing this email.
URL: http://lists.osgeo.org/pipermail/aust-nz/attachments/20080616/c623273c/attachment.html
More information about the Aust-NZ
