[Aust-NZ] Best approach to adding vector layer to NZTopo TMS [SEC=UNCLASSIFIED]
Bruce Bannerman B.Bannerman at bom.gov.au
Tue Feb 22 23:51:11 EST 2011
Hi Peter,
Our thoughts are with you guys.
I'd recommend serving your data via WMS and WFS for now. Don't worry about tiling until you have the time to put it together.
This will open up your data to the greatest number of people, including those using Google Earth.
One of the findings of OGC OWS7 that was held during the Haiti earthquake was that this was a good way of providing timely access to data.
Google Earth users will be able to add:
WMS: via Tools>Add Image Overlay menu item.      See [1].
WFS (via KML using GeoServer):   the Tools>Add Network Link menu item. There is even a facility to update the data on a time basis or when a particular area is revisited. See [2] and [3].
An example of a URL to use to display WFS (via KML) data coming out of GeoServer is:
http://<server-name>/geoserver/ows?service=WMS&version=1.1.0&request=GetMap&layers=wml:<namespace>&styles=&bbox=-4340053.435,-1.0330423859E7,6514765.77,-331935.533&width=512&height=471&srs=EPSG:3112&format=kml
URL, EPSG, namespace and extent will of course need to be revised for your situation.
I hope this helps.
Bruce
[1] http://earth.google.com/support/bin/static.py?page=guide.cs&guide=22373&topic=22376&answer=148100#wms
[2] http://earth.google.com/support/bin/static.py?page=guide.cs&guide=22369&topic=27830#networklinks
[3] http://earth.google.com/support/bin/static.py?page=guide.cs&guide=22369&topic=27830#creatingnetwork
On 23/02/11 5:16 AM, "Peter" <webwiz at pl.net> wrote:
I am working with Gavin from topomap.co.nz (a topomap viewer targeted at outdoor users) to migrate the site to openlayers using NZTM, baselayer tiles from the topo50 etc geotiffs.
Thus far the thinking is that the baselayer is a TMS layer, because it changes about once per blue moon, and is fast to deliver and render. However we are working on adding a political layer, which comprises among other things TLA and region boundarys, doc estate, doc facilitys and similar that either doesnt appear in the baselayer or is more dynamic in nature. User maintained hut listings and public right of way entrance points are likely.
My question is what is the best approach to serve this layer? My as yet limited knowledge sees these choices:
a. make a second TMS layer, redone manually from time to time
b. same as above but using tools like mapnik.
c. create a mapserver WMS with tile caching to make updates easier.
d. simplify the polygons and deliver as a ajax strategiedvector layer to openlayers.
Wed appreciate any advice about the pros and cons of these methods?
Theres a qgis screenshot of the draft layer here:
http://www.zoneblue.org/files/political-concept.png
And an openlayers proof of concept here:
http://www.zoneblue.org/map/openlayers.html
Regards
Peter Scott
Aust-NZ mailing list
Aust-NZ at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/aust-nz
URL: http://lists.osgeo.org/pipermail/aust-nz/attachments/20110223/9f5bf9ea/attachment.html
More information about the Aust-NZ mailing list
