[Aust-NZ] Aust-NZ Digest, Vol 85, Issue 1
Neil Crisp
neilgcrisp at optusnet.com.au
Thu Dec 11 12:16:17 PST 2014
Well done, Cameron!
This is a good result.
Cheers,
Neil.
On Thu, 2014-12-11 at 12:00 -0800, aust-nz-request at lists.osgeo.org
wrote:
> Send Aust-NZ mailing list submissions to
> aust-nz at lists.osgeo.org
> To subscribe or unsubscribe via the World Wide Web, visit
> http://lists.osgeo.org/mailman/listinfo/aust-nz
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
> aust-nz-owner at lists.osgeo.org
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of Aust-NZ digest..."
> Today's Topics:
> 1. Re: Please update NSW Procurement guidelines to align with
> Australian Open Source Policies (Cameron Shorter)
> Message: 1
> Date: Thu, 11 Dec 2014 15:34:50 +1100
> From: Cameron Shorter <cameron.shorter at gmail.com>
> To: aust-nz at lists.osgeo.org, osia-members-request at osia.com.au
> Subject: Re: [Aust-NZ] Please update NSW Procurement guidelines to
> align with Australian Open Source Policies
> Message-ID: <54891EEA.7030801 at gmail.com>
> Content-Type: text/plain; charset="iso-8859-1"; Format="flowed"
> OSIA and OSGeo Aust-NZ lists,
> I've received a positive response from NSW ICT Procurement
> regarding"Anti-Open Source" purchasing guidelines.
> In particular they mentioned that they do not want to discourage the use
> of open source software and the upcoming Procure IT 3.1 [1] has many
> measures with respect to open source software that facilitate its use.
> They asked that we review the remainder of Procure IT 3.1, and would be
> happy to receive our comments.
> I'd like to actually forward the email I received, but the person I
> received it from was not in a position to make a public statement on
> behalf of NSW Government.
> Regards,
> Cameron Shorter
> [1]
> https://www.procurepoint.nsw.gov.au/before-you-supply/standard-procurement-contract-templates/procure-it-framework-version-31
> On 20/11/2014 8:41 PM, Cameron Shorter wrote:
> > To the NSW Procurement Team,
> > We, the Australian and New Zealand chapter of the Open Source
> > Geospatial Foundation, are concerned that NSW Procurement guidelines
> > about Open Source Software are dated and need to be changed.
> > The guidelines:
> > * Inaccurately imply Proprietary Software is less risky than Open
> > Source [1],
> > * Unfairly discriminate against Open Source Software solutions and
> > Australian Open Source businesses [1],
> > * Conflict with Australian government policy which directly mandate
> > that Open Source and Proprietary Software should be considered
> > equally. [2]
> > * Increases the cost and reduce the value of NSW Government IT
> > purchases by actively discouraging use of Open Source.
> > Could the NSW Procurement Team please review the current Open Source
> > statement, assess the appropriateness of updating to Australian
> > Government Policy statements related to Open Source, and reply
> > describing how you plan to address this issue.
> > *Reference 1:*
> > The NSW IT procurement framework (version 3.1) specifically discourses
> > use of Open Source software with Major Project System Integration
> > Services.
> > /23 Open Source Software //
> > //23.1 The Contractor must ensure that: //
> > //(a) none of the Deliverables comprise Open Source Software; and //
> > //(b) it does not insert any Open Source Software into the Customer
> > Environment, except to the extent otherwise approved by the Customer
> > in writing. //
> > //23.2 Where the Customer gives its approval in relation to the use of
> > any Open Source Software //
> > //under clause 23.1: //
> > //(a) the Contractor must ensure that the use of that Open Source
> > Software will not result in an obligation to disclose, license or
> > otherwise make available any part of the Customer Environment or any
> > of the Customer'sConfidential Information to any third party; and //
> > //(b) the use of that Open Source Software will not in any way
> > diminish the Contractor's obligations under the Contract, including
> > without limitation in relation to any warranties, indemnities or any
> > provisions dealing with the licensing or assignment of Intellectual
> > Property. /
> > See: Module 13A Major project systems integration services
> > *Reference 2:*
> > Australian Government Policy on Open Source Software:
> > /Principle 1: Australian Government ICT procurement processes must
> > actively and fairly consider all types of available software.//
> > //Australian Government agencies must actively and fairly consider all
> > types of available software (including but not limited to open source
> > software and proprietary software) through their ICT procurement
> > processes. It is recognised there may be areas where open source
> > software is not yet available for consideration. Procurement decisions
> > must be made based on value for money. Procurement decisions should
> > take into account //
> > //whole-of-life costs, capability, security, scalability,
> > transferability, support and manageability requirements.//
> > //For a covered procurement (over $80K), agencies are required to
> > include in their procurement plan that open source software will be
> > considered equally alongside proprietary software. Agencies will be
> > required to insert a statement into any Request for Tender that they
> > will consider open source software equally alongside proprietary
> > software. Tender responses will be evaluated under the normal
> > requirements of the Commonwealth Procurement Guidelines. For a
> > non-covered procurement (below $80K), agencies are required to
> > document all key decisions, as required by the Commonwealth
> > Procurement Guidelines. This includes how they considered open source
> > software suppliers when selecting suppliers to respond to the Select
> > Tender or Request for Quotation.//
> > Australian Government Policy on Open Source Software,
> > http://www.finance.gov.au/policy-guides-procurement/open-source-software/
> > Cameron Shorter,
> > President of the Australian Chapter of the Open Source Geospatial Foundation,
> > Software and Data Solutions Manager, LISAsoft
> > Suite 112, Jones Bay Wharf,
> > 26 - 32 Pirrama Rd, Pyrmont NSW 2009
> > P +61 2 9009 5000, Wwww.lisasoft.com, F +61 2 9009 5099
> > The contents of this email are confidential and may be subject to
> > legal or professional privilege and copyright. No representation is
> > made that this email is free of viruses or other defects. If you have
> > received this communication in error, you may not copy or distribute
> > any part of it or otherwise disclose its contents to anyone. Please
> > advise the sender of your incorrect receipt of this correspondence.
> > Aust-NZ at lists.osgeo.org
More information about the Aust-NZ
