[Aust-NZ] NSW Government Procurement actively discourages use of Open Source
Cameron Shorter cameron.shorter at gmail.com
Tue Nov 18 11:53:52 PST 2014
OSGeo Aust-NZ,
During a recent NSW tendering process (for a spatial software system),
we have discovered that NSW Government purchasing guidelines actively
discourage use of Open Source Software.
I propose that the following email is sent on behalf of OSGeo Aust/NZ.
Any comments, votes for or against?
Vote from me: +1 Cameron Shorter
From: President of the Open Source Geospatial Foundation -
Australian/New Zealand Chapter
To: nswbuy at finance.nsw.gov.au
CC: Aust-NZ at lists.osgeo.org
To NSW Procurement Team,
We, the Australian and New Zealand chapter of the Open Source Geospatial
Foundation, are concerned that NSW Procurement guidelines about Open
Source Software should be changed.
The guidelines:
* Inaccurately imply Proprietary Software is less risky than Open Source
[1],
* Unfairly discriminate against Australian Open Source Software
solutions and businesses [1],
* Conflict with Australian government policy which directly mandate that
Open Source and Proprietary Software should be considered equally. [2]
* Increases the cost of NSW Government IT purchases by actively
discouraging use of Open Source.
Could the NSW Procurement Team please review the current Open Source
statement, assess the appropriateness of updating to Australian
Government Policy statements related to Open Source, and respond with
your assessment.
*Reference 1:*
The NSW IT procurement framework (version 3.1) specifically discourses
use of Open Source software with Major Project System Integration Services.
/23 Open Source Software //
//23.1 The Contractor must ensure that: //
//(a) none of the Deliverables comprise Open Source Software; and //
//(b) it does not insert any Open Source Software into the Customer
Environment, except to the extent otherwise approved by the Customer in
writing. //
//23.2 Where the Customer gives its approval in relation to the use of
any Open Source Software //
//under clause 23.1: //
//(a) the Contractor must ensure that the use of that Open Source
Software will not result in an obligation to disclose, license or
otherwise make available any part of the Customer Environment or any of
the Customer'sConfidential Information to any third party; and //
//(b) the use of that Open Source Software will not in any way diminish
the Contractor's obligations under the Contract, including without
limitation in relation to any warranties, indemnities or any provisions
dealing with the licensing or assignment of Intellectual Property. /
https://www.procurepoint.nsw.gov.au/before-you-supply/standard-procurement-contract-templates/procure-it-framework-version-31
See:  Module 13A Major project systems integration services
*Reference 2:*
Australian Government Policy on Open Source Software:
/Principle 1: Australian Government ICT procurement processes must
actively and fairly consider all types of available software.//
//Australian Government agencies must actively and fairly consider all
types of available software (including but not limited to open source
software and proprietary software) through their ICT procurement
processes. It is recognised there may be areas where open source
software is not yet available for consideration. Procurement decisions
must be made based on value for money. Procurement decisions should take
into account //
//whole-of-life costs, capability, security, scalability,
transferability, support and manageability requirements.//
//For a covered procurement (over $80K), agencies are required to
include in their procurement plan that open source software will be
considered equally alongside proprietary software. Agencies will be
required to insert a statement into any Request for Tender that they
will consider open source software equally alongside proprietary
software. Tender responses will be evaluated under the normal
requirements of the Commonwealth Procurement Guidelines. For a
non-covered procurement (below $80K), agencies are required to document
all key decisions, as required by the Commonwealth Procurement
Guidelines. This includes how they considered open source software
suppliers when selecting suppliers to respond to the Select Tender or
Request for Quotation.//
Australian Government Policy on Open Source Software,
http://www.finance.gov.au/policy-guides-procurement/open-source-software/
Cameron Shorter,
Software and Data Solutions Manager
LISAsoft
Suite 112, Jones Bay Wharf,
26 - 32 Pirrama Rd, Pyrmont NSW 2009
P +61 2 9009 5000,  W www.lisasoft.com,  F +61 2 9009 5099
URL: <http://lists.osgeo.org/pipermail/aust-nz/attachments/20141119/d21ddbc4/attachment.html>
More information about the Aust-NZ mailing list
