[Aust-NZ] Fwd: Consultation on Open Source Policy for NZ Govt
Cameron Shorter cameron.shorter at gmail.com
Mon Apr 18 01:37:32 PDT 2016
Hi NZ folks on this list.
If you are not already aware, you might want to have a look at policy on
Open Source license selection.
Warm regards, Cameron
-------- Forwarded Message --------
Subject: 	Consultation on Open Source Policy for NZ Govt
Date: 	Mon, 18 Apr 2016 15:52:07 +1000
To: 	Cameron Shorter <cameron.shorter at gmail.com>
HI Cameron,
New from across the ditch - the NZ Govt are currently consulting on
their Open Source Policy.
You can look over the policy draft that was released earlier this month
at:
https://www.ict.govt.nz/assets/Uploads/Documents/NZGOAL-Software-Extension-DRAFT-February-2016.pdf
They are already underway with discussions and consensus building on
improvements to the initial draft over at:
https://www.loomio.org/g/NohQxyr9/nzgoal-software-extension-discussion-of-draft
It would also be great if you could share that this process is under way
among any of your tech industry friends in NZ and other contacts that
might have an interest. I'm aiming to ensure we get the best
representation of perspectives. Feel free to post the above links
anywhere relevant too.
Amelia
*Amelia Loye *
Engagement Specialist
+ 61 411960585
Amelia at engage2.com.au <x-msg://515/amelia@engage2.com.au>
www.engage2.com.au <x-msg://515/www.engage2.com.au>
@Emotivate <https://twitter.com/Emotivate>
URL: <http://lists.osgeo.org/pipermail/aust-nz/attachments/20160418/af9df1b7/attachment.html>
Name: not available
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/aust-nz/attachments/20160418/af9df1b7/attachment.png>
More information about the Aust-NZ mailing list
