[cat-interop] Call for public review of GeoDCAT-AP
ana.fernandez.de.soria.risco at be.pwc.com
Mon Jul 13 06:47:17 PDT 2015
Dear Sir or Madam,
You are kindly invited to review the working group draft of the GeoDCAT
Application Profile, an extension of the DCAT application profile
(DCAT-AP) for describing geospatial datasets, dataset series, and
services.
GeoDCAT-AP provides an RDF syntax binding for the union of metadata
elements defined in the core profile of ISO 19115:2003 and those defined
in the framework of the INSPIRE Directive.
The GeoDCAT-AP specification can be downloaded from:
https://joinup.ec.europa.eu/node/139283#Distributions
The specification is accompanied by an XSLT script, which allows the
automated conversion of ISO 19139 metadata records into GeoDCAT-AP format
https://webgate.ec.europa.eu/CITnet/stash/projects/ODCKAN/repos/iso-19139-to-dcat-ap/
The public review period will last until 30 August 2015.
Please submit your feedback by sending comments and suggestions to the
GeoDCAT-AP mailing list: dcat_application_profile-geo at joinup.ec.europa.eu.
The feedback received will be discussed by the GeoDCAT-AP Working Group in
early September. Final publication of application profile is foreseen for
October 2015.
The full text of the call is available from Joinup:
https://joinup.ec.europa.eu/node/144506/
The intended use case of GeoDCAT-AP is to make spatial datasets, data
series, and services searchable on general data portals, thereby making
geospatial information better searchable across borders and sectors. This
can be achieved by the exchange of descriptions of data sets among data
portals using a common exchange format.
GeoDCAT-AP has been developed in the context of Action 1.1 ? Improving
semantic interoperability in European eGovernment systems of the European
Commission?s Interoperability Solutions for European Public
Administrations (ISA) programme. The DCAT-AP is a joint initiative of four
Directorates-General of the European Commission: the Joint Research
Centre, DG DIGIT (ISA Programme), DG CONNECT and the Publications Office
of the EU.
Looking forward to receiving your feedback.
Ana Fernández de Soria
- On behalf of the ISA Programme
*be_pwc_b*
______________________________________________________________________
This e-mail is intended only for the person to whom it is addressed.
If an addressing or transmission error has misdirected this e-mail,
please notify the author by replying to this e-mail. If you are not
the intended recipient you must not use, disclose, copy, print or
rely on this e-mail.
PwC may monitor outgoing and incoming e-mails and
other telecommunications on its e-mail and telecommunications systems.
URL: <http://lists.osgeo.org/pipermail/cat-interop/attachments/20150713/1ed45721/attachment.html>
More information about the cat-interop
