[Workshops] Machine setup
Jeff McKenna jmckenna at gatewaygeomatics.com
Mon Sep 28 22:08:36 EDT 2009
For the MapServer workshop we'll be using MS4W with it's own Apache
installed, which in all of the past workshops ran on port 80.  Is this ok?
-jeff
Mark Leslie wrote:
> Apache running on port 80 shouldn't be a problem, but having it running
> depends on what else needs the port, and whether we need different,
> conflicting configurations.
> Is anyone else planning on binding something non-Apache to port 80, or
> mapping the mentioned paths?
> Mark
> Tim Schaub wrote:
>> Sorry if this is asking the obvious, but does Apache get 80 (and will
>> it be running)?
>> I understand the desire to limit what workshops install and run as
>> services, but I think it also makes sense to limit the number of
>> things that every participant has to click through.
>> I was planning on writing up instructions for configuring Apache to
>> proxy GeoServer on port 80 and set up an alias for the root of the
>> workshop folder.
>> All the OpenLayers material assumes this (http://localhost/geoserver
>> and http://localhost/ol_workshop).
>> I had been planning on walking participants through starting
>> GeoServer.   And I had been assuming we'd have an http server running
>> on 80 that could get to the workshop folder.
>> Tim
>> Etienne Dube wrote:
>>> Yep it'll be running on 8080, but the tomcat instance will be
>>> manually started during the workshop (it won't be installed as a
>>> service, only launched from a batch file). Like Mark said in this
>>> thread, I think it's a good idea to have nothing installed as an
>>> automatic service, to avoid any port conflict.
>>> Justin Deoliveira a écrit :
>>>> Cool. Just to ensure there are no conflicts i will set up GeoServer
>>>> to run on a different port than 8080. Assuming that Tomcat will be
>>>> indeed running on 8080?
>>>> Etienne Dube wrote:
>>>>> Hi Justin,
>>>>> Good, it's fine for us too. I'll put JDK 6u16 in the software to be
>>>>> installed. JAVA_HOME can point to it and our Tomcat instance will
>>>>> be happy.
>>>>> Etienne
>>>>>> Hi Etienne,
>>>>>> We require a JDK (not just a JRE) for GeoServer to run. Version 6
>>>>>> will be fine for us.
>>>>>> -Justin
>>>>>> Etienne Dube wrote:
>>>>>>> Hi,
>>>>>>> Is there any other workshop that requires a Java JRE? We'll be
>>>>>>> using the Java 6 Update 16 JRE in workshop_01 (Geospatial BI with
>>>>>>> FOSS). Everything else is self-contained in a directory under
>>>>>>> C:\. Could Java be pre-installed on the machines? Any possible
>>>>>>> version conflicts (i.e. if anyone requires a Java 5 JRE)?
>>>>>>> Thanks,
>>>>>>> Etienne
>>>>>>> Mark Leslie a écrit :
>>>>>>>> Damnit, this one slipped past me last week.
>>>>>>>> All we've got going so far is
>>>>>>>> http://wiki.osgeo.org/wiki/FOSS4G_2009_Workshop_Computer_Setup,
>>>>>>>> which really isn't up to this task, and is already incomplete.
>>>>>>>> As a general rule, I would prefer to have nothing installed as
>>>>>>>> an automatic service.  We can setup links to load
>>>>>>>> applications/services as needed, but it seems easiest to not
>>>>>>>> have everything running by default.  That way port conflicts
>>>>>>>> shouldn't be a hugh issue (optimism?).
>>>>>>>> It will still cause collisions on install directories, in
>>>>>>>> particular for workshops that involve an installation step, and
>>>>>>>> service names.
>>>>>>>> Mark
>>>>>>>> Justin Deoliveira wrote:
>>>>>>>>> Hi folks,
>>>>>>>>> Apologies if this has been covered already but is there a wiki
>>>>>>>>> page up that lists all the software that is going to be
>>>>>>>>> installed on all the workshop machines? I know last year we set
>>>>>>>>> this up and it was quite useful in order to resolve any version
>>>>>>>>> conflicts, and more importantly any port conflicts between
>>>>>>>>> running services.
>>>>>>>>> -Justin
>>>>>>>> _______________________________________________
>>>>>>>> Conference-workshops mailing list
>>>>>>>> Conference-workshops at lists.osgeo.org
>>>>>>>> http://lists.osgeo.org/mailman/listinfo/conference-workshops
Jeff McKenna
FOSS4G Consulting and Training Services
http://www.gatewaygeomatics.com/
More information about the Conference-workshops mailing list
