[OSGeo-Conf] FOSS4G2006 Web Site
Claude Philipona
claude.philipona at camptocamp.com
Fri May 11 15:44:07 EDT 2007
The domain was reserved by Daniel Rappo from the university of applied
sciences heig-vd more than 2 years ago. All the email addresses for the
heig-vd changed last year (the former one were canceled) so Daniel did
not receive any reminder to renew the domain.
Daniel is now going thru the manual procedure with proof of identity and
everything to renew the domain, the site should be up again soon.
As I told Jeff, there is a feature in Indico to make a static version of
the site in plain proper html which is then easy to host anywhere.
Claude
Allan Doyle wrote:
> On May 11, 2007, at 13:16, Paul Ramsey wrote:
>> Jeff McKenna wrote:
>>> I have also asked them if we could host it on
>>> http://www.osgeo.org/conference/. And
>> The simplest thing might just be to run wget over the whole thing so
>> you can have a static archive of the content for all time, rather than
>> trying to actually host the environment. I've done that for the '07
>> bid site, so we have it for historical purposes
>> (http://www.foss4g2007.org/bid_site).
> +1 on that. There's no need to have the archives be "active". A
> permalink to each abstract and talk is a pretty desirable thing.
> --Allan Doyle
> +1.781.433.2695
> adoyle at eogeo.org
> Conference_dev mailing list
> Conference_dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/conference_dev
More information about the Conference_dev
