[OSGeo-Conf] FOSS4G Cookbook writing guide
Cameron Shorter
cameron.shorter at gmail.com
Fri Sep 7 14:53:19 PDT 2012
I have written suggestions for our "Update Process" [1] and a "Template
Section" [2], and would like to hear suggestions on whether I'm on the
right track:
Editing this document
Draft, awaiting review
This FOSS4G Cookbook aims to be concise, so that it is easy to read and
follow. We also aim to collaboratively edit and continuously build this
document based upon our collective experience running conferences. As
such, we will need to continuously update and delete old text as new
ideas come to hand.
The process to follow in updating this wiki is:
Feel free to make trivial tweaks to grammar and syntax.
If you would like to introduce a new idea, maybe add a new section,
or improve an old section:
Raise your suggestion on the OSGeo Conference email list.
Once a rough consensus has been reached on the list, you may
then update the Cookbook with the collective wisdom of the list.
If writing a new section, consider starting the section with:
After updating your text, notify the list again to give others
the opportunity to review and tweak.
Section Writing Guide
The first sentence(s) of a section should describe the meaning of the
heading. Eg, if this section is on "Birds of a Feather", then the first
sentence should start with: Birds of a Feather sessions refer to
semi-formal gatherings of like minded delegates to discuss a topic of
interest.
Following paragraphs provide specific details. They might hyperlink to
more details from an external Lessons Learned type doc. It will likely
cover some of the following topics:
Key success factors
Things that can go wrong, with optional brief examples
List of considerations and why choose one consideration over another
List of steps to follow
Organisations or people to contact to coordinate with
Links to external documents, such as a Google Docs spreadsheet
See Also
Where relevant, finish with a list of links to web pages for
further reading. E.g.
FOSS4G 2009 Birds of Feather Lessons Learned
[1] http://wiki.osgeo.org/wiki/FOSS4G_Cookbook#Section_Writing_Guide
[2] http://wiki.osgeo.org/wiki/FOSS4G_Cookbook#Section_Writing_Guide
Cameron Shorter
Geospatial Solutions Manager
Tel: +61 (0)2 8570 5050
Mob: +61 (0)419 142 254
Think Globally, Fix Locally
Geospatial Solutions enhanced with Open Standards and Open Source
http://www.lisasoft.com
More information about the Conference_dev
