[OSGeo-Conf] Portland LOC bid
    Darrell Fuhriman
    darrell at garnix.org
    Sun Jun 30 16:56:40 PDT 2013
Thanks to everyone who helped on our bid!
Attached is our proposal. One quick note, the spreadsheet was drawn up in Numbers, which I realize not everyone may have access to, hence there is also an Excel version attached. However, I strongly suggest using the numbers version if you are capable – it's much easier to work with.
We look forward to seeing you all in Portland next year!
Darrell
Name: PDX FOSS4g 2013 Bid.pdf
Type: application/pdf
Desc: not available
URL: <http://lists.osgeo.org/pipermail/conference_dev/attachments/20130630/3810781a/attachment-0002.pdf>
Name: PDX FOSS4g 2014 Budget.numbers
Type: application/octet-stream
Desc: not available
URL: <http://lists.osgeo.org/pipermail/conference_dev/attachments/20130630/3810781a/attachment-0002.obj>
Name: PDX FOSS4g 2014 Budget.pdf
Desc: not available
URL: <http://lists.osgeo.org/pipermail/conference_dev/attachments/20130630/3810781a/attachment-0003.pdf>
Name: PDX FOSS4g 2014 Budget.xls
Desc: not available
URL: <http://lists.osgeo.org/pipermail/conference_dev/attachments/20130630/3810781a/attachment-0003.obj>
More information about the Conference_dev
