[OSGeo-Conf] Proposed text for an OSGeo Code of Conduct
Bart van den Eijnden
bartvde at osgis.nl
Tue Feb 3 12:16:51 PST 2015
Interesting, MapZen will only sponsor events which have a strong COC in place:
https://mapzen.com/blog/mapzen-code-of-conduct <https://mapzen.com/blog/mapzen-code-of-conduct>
Best regards,
Bart
> On 25 Jan 2015, at 22:10, Cameron Shorter <cameron.shorter at gmail.com> wrote:
> Thanks Eli,
> I like your list of characteristics. I'd add:
> * Have a CoC in the first place, which breaks down to:
> ** Ensure conferences remember / realise that a CoC should be in place. (Add it to our cookbook [1] and bid process)
> ** Make it easy to apply a CoC by referencing an existing document. (Complete this discussion and provide a best practice document that can be referenced).
> I acknowledge your point re over-doing sexualized images discussion.
> I like the qgis CoC, and suggest that if we can make adding a CoC easy (by providing generic text), then we should add having a CoC a requirement for OSGeo graduation. I've added a placemarker into the proposed text for the next OSGeo Project Graduation Checklist. [2]
> [1] http://wiki.osgeo.org/wiki/FOSS4G_Handbook
> [2] http://wiki.osgeo.org/wiki/Project_Graduation_Checklist#processes.4
> On 26/01/2015 5:53 am, Eli Adam wrote:
>> Code of Conduct specific wording is less important than these characteristics:
>> * Being present (i.e. not implied but clearly stated)
>> * Appearing sincere
>> * Being sincere
>> * Having reasonable people implementing it
>> In that regard, the similar texts you listed were all fine.
>> Generally, I think that we are spending too much time and emphasis on
>> sexualized images. We are in the open source geospatial software,
>> geospatial standards, open data, education, and related fields; 95%+
>> of all presentations and other content can be done entirely
>> successfully without images of people at all. For the 5% of cases
>> that images of people substantively contribute to the presentation,
>> err on the side of caution, "If in doubt, leave it out".
>> I like the idea of the conference committee starting with a CoC for
>> conferences and the Board possibly modifying and expanding it to other
>> areas of OSGeo or projects establishing their own (see QGIS,
>> http://qgis.org/en/site/getinvolved/governance/codeofconduct/codeofconduct.html)
>> I don't think that 2015 FOSS4G needs any input, they already seem to
>> have it under control, http://2015.foss4g.org/about/codeofconduct/,
>> and there was nothing about a CoC in the bid. We should be focusing
>> 2016 and beyond.
>> Thanks for working on guiding this process Cameron.
>> Best regards, Eli
>> On Sat, Jan 24, 2015 at 3:12 AM, Cameron Shorter
>>> Hi David,
>>> Thanks for starting this discussion. When you opened the discussion, you
>>> very kindly offered to help set a Code of Conduct in place. How do you
>>> suggest we move toward concluding the discussion and getting a Code of
>>> Conduct in place?
>>> Do you have a timeframe in mind for this? I assume we should try to make a
>>> CoC available for FOSS4G 2015 if they wish to make use of one?
>>> Peter, thanks for you comments on proposed text.
>>> Is there anyone else with an interest in influencing the final text? If so,
>>> please speak up.
>>> Which is the better version of a CoC?
>>> 1. Prior foss4g: https://2015.foss4g-na.org/code-conduct
>>> 2. OReilly: http://www.oreilly.com/conferences/code-of-conduct.html (copied
>>> below)
>>> 3. My revised version (copied below)
>>> 4. Something else
>>> On 19/01/2015 9:16 am, Cameron Shorter wrote:
>>> Hi David,
>>> I'm happy to move proposed CoC text across to a wiki. If requested, I'll
>>> copy across now (within 48 hours), or can wait till there has been further
>>> discussion.
>>> Also happy to expand the discussion to other lists, although I expect the
>>> conference committee is probably the logical primary point for discussion,
>>> as a CoC is most applicable to conferences. The board would need to sign off
>>> on a CoC and should be invited to comment.
>>> Re identifying what should be in a code of conduct. I've attempted to start
>>> on that in the list of items I've attempted to address, listed below.
>>> I have presented the draft CoC (below), as I find it is often easier to
>>> start with a "straw man" which can be picked apart, rather than talking
>>> vaguely in conceptual levels. However, I'm not wedded to the text, and hope
>>> to see constructive criticism of the ideas, text and structure.
>>> On 19/01/2015 3:46 am, David William Bitner wrote:
>>> I really want to thank everyone here for engaging in this issue. I do
>>> appreciate all the different voices that have contributed to this
>>> conversation -- they all certainly speak to the diversity of thoughts and
>>> experiences that we already have in this community.
>>> Cameron -- thank you very much for putting forward a first draft of a
>>> potential CoC for us to use. Before drafting and wordsmithing a CoC I want
>>> to step back and make sure we answer a few questions that would certainly
>>> impact how a CoC gets written. When we get to the point of drafting, we
>>> should certainly do so on the wiki (or other trackable collaborative medium)
>>> rather than in an email thread.
>>> With some of the wording in this draft as well as seeing the discussion from
>>> the last Board Meeting, is the conference committee the correct venue for
>>> this discussion or should this be at the Board level so that this applies to
>>> all OSGeo activities (mailing lists, events, etc)? I am certain that many of
>>> the same people would remain engaged in helping draft a Code of Conduct
>>> either for the foundation as a whole or just for our events, but this
>>> certainly impacts the scope and wording required in a draft.
>>> Many of the comments that I read as against having a CoC seem to stem from
>>> people wondering what does a CoC solve. Sadly, having a CoC does not "solve"
>>> anything. There will still be issues. A CoC simply provides one tool for us
>>> to help resolve those issues when they come up as well as providing a
>>> proactive statement that we aim to be a welcoming and diverse community to
>>> hopefully prevent some of those issues in the first place. A CoC is not the
>>> end point of diversity initiatives, but it is a very low hanging fruit to
>>> start with. Other initiatives that I know have been tried that we should
>>> continue to look at their effectiveness include author blind public program
>>> review, scholarship initiatives, proactively seeking out diversity in key
>>> notes, and many more things that we haven't tried.
>>> On 18/01/2015 2:33 pm, Cameron Shorter wrote:
>>> Following on from this email thread, I've drafted a proposed Code of
>>> Conduct, where I've aimed to address:
>>> * Be concise (concise words get read more)
>>> * Cover key messages
>>> * Include an escalation process for dealing with both minor and major issues
>>> * Ensure key terms are understood (in particular reference to definition of
>>> sexualised images)
>>> * Couch in positive language
>>> Tickbox version:
>>> * I agree to act respectfully toward others in line with the OSGeo Code of
>>> Conduct.
>>> OSGeo Code of Conduct:
>>> This Code of Conduct collates the collective values adopted by our OSGeo
>>> community which baselines the behaviour we do and don’t support to ensure
>>> OSGeo is a safe and productive environment for all.
>>> We invite everyone to be respectful to all, regardless of race, gender, age,
>>> sexual orientation, disability, physical appearance, national origin,
>>> ethnicity, religion, or ideas. We do not tolerate harassment of others in
>>> any form. Examples of harassment include offensive comments, verbal threats
>>> or demands, sexualized images in public spaces, intimidation, stalking,
>>> harassing photography or recording, sustained disruption of events, and
>>> unwelcome physical contact or sexual attention. [1]
>>> We expect all participants to follow the Code of Conduct when involved in
>>> OSGeo activities. This includes conferences, related social events, and
>>> online forums. Participants violating this Code of Conduct will be asked to
>>> desist and/or make amends. For gross or continual violations, offenders may
>>> be expelled from the event or forum without a refund, and/or banned from
>>> future events or other forums.
>>> Participants are encouraged to bring any concerns to the attention of event
>>> staff, the forum, forum leader, or OSGeo Board. We thank all for helping
>>> keep OSGeo welcoming, respectful, and friendly for all.
>>> [1] Examples of inappropriate sexualised environments are described here:
>>> https://www.humanrights.gov.au/publications/sexual-harassment-code-practice-what-sexual-harassment
>>> On 10/01/2015 9:59 pm, Cameron Shorter wrote:
>>> Looking around at various Conference "Codes of Conduct", I found the
>>> O'Reilly definition to be eloquently worded, and less threatening to
>>> potential attendees. (Although I still can't find a clear definition of
>>> "sexual images".)
>>> Code of Conduct
>>> At O'Reilly, we assume that most people are intelligent and well-intended,
>>> and we're not inclined to tell people what to do. However, we want every
>>> O'Reilly conference to be a safe and productive environment for everyone. To
>>> that end, this code of conduct spells out the behavior we support and don't
>>> support at conferences. The core of our approach is this:
>>> We don't condone harassment or offensive behavior, at our conference venues
>>> or anywhere. It's counter to our company values. More importantly, it's
>>> counter to our values as human beings.
>>> We're voicing our strong, unequivocal support of appropriate behavior by all
>>> participants at technical events, including all O'Reilly conferences. We
>>> invite you to help us make each O'Reilly conference a place that is
>>> welcoming and respectful to all participants, regardless of race, gender,
>>> age, sexual orientation, disability, physical appearance, national origin,
>>> ethnicity, or religion. So that everyone can focus on the conference itself,
>>> and the great networking and community richness that happens when we get
>>> together in person, we will not tolerate harassment of conference
>>> participants in any form—in person or online.
>>> Examples of harassment include offensive comments, verbal threats or
>>> harassing photography or recording, sustained disruption of sessions or
>>> events, and unwelcome physical contact or sexual attention.
>>> We expect all participants—attendees, speakers, sponsors, and volunteers—to
>>> follow the Code of Conduct during the conference. This includes
>>> conference-related social events at off-site locations, and in related
>>> online communities and social media. Participants asked to stop any
>>> harassing behavior are expected to comply immediately. Conference
>>> participants violating this Code of Conduct may be expelled from the
>>> conference without a refund, and/or banned from future O'Reilly events, at
>>> the discretion of O'Reilly Media.
>>> Please bring any concerns to the immediate attention of the event staff, or
>>> contact our VP of Conferences, Gina Blaber at gina at oreilly.com. We thank our
>>> participants for your help in keeping the event welcoming, respectful, and
>>> friendly to all participants.
>>> Read the blog post by Tim O'Reilly that is the basis of our functional code
>>> of conduct for all O'Reilly conferences.
>>> Thanks to the Lean Startup folks and the jsconf.us folks, whose Codes of
>>> Conduct inspired some changes to our own.
>>> Cameron Shorter,
>>> Software and Data Solutions Manager
>>> LISAsoft
>>> Suite 112, Jones Bay Wharf,
>>> 26 - 32 Pirrama Rd, Pyrmont NSW 2009
>>> P +61 2 9009 5000, W www.lisasoft.com, F +61 2 9009 5099
>>> Cameron Shorter,
>>> LISAsoft
>>> Cameron Shorter,
>>> LISAsoft
>>> Conference_dev mailing list
>>> Conference_dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/conference_dev
> Cameron Shorter,
> LISAsoft
URL: <http://lists.osgeo.org/pipermail/conference_dev/attachments/20150203/d9877c9f/attachment-0001.html>
More information about the Conference_dev
