[OSGeo-Conf] FOSS4G Auckland 2025 Proposal
María Arias de Reyna
delawen at gmail.com
Thu May 16 11:36:59 PDT 2024
Dear Simon,
I just did a first read of your document and I want to congratulate you and
your LOC for such a beautiful proposal.
I see that you consider numbers that I feel are a bit low for attendance
(base 550, better 650, best 750). I like that you are conservative and that
the budget stays strong with a low number, but I think that we should be
prepared for the upper number to be at least 1000, considering the
historial data[1]. Is there a reason why 750 is the higher you planned?
Because even if it is very far away from me (Spain), I see it is very close
to some of the most vibrant communities out there. I know you mention you
can expand to more rooms if needed and that you can have a bigger plenary
room, I am just curious if I'm missing some reason behind the numbers.
I like the childcare services. As a suggestion: are you also considering
offering some tourist package for partners?
Sometimes the codesprint is not of interest for the majority of the
audience for several reasons (considered too technical, people are tired at
the last day and decide to just do some tourism,...). Do you have any ideas
on how to encourage participation?
Cheers!
María.
[1]
https://docs.google.com/spreadsheets/d/1ux_hFq-C165140ZD48RRImPTHSpXj42OG3nBr9cyZYo/edit#gid=1782600951
On Sun, May 12, 2024 at 10:36 PM Simon Nitz via Conference_dev <
conference_dev at lists.osgeo.org> wrote:
> Dear FOSS4G Conference Committee,
> On behalf of OSGeo Oceania and the Auckland Local Organizing Committee it
> gives me great pleasure to submit our proposal to host FOSS4G 2025 in
> Auckland, New Zealand.
> Please find our Proposal document attached to this email.
> Additional documents including budget have been sent to Luca to
> disseminate to the committee privately.
> Simon Nitz
> Co-Chair for FOSS4G 2025 Auckland Local Organizing Committee
> *Simon Nitz | GIS Lead*
> P: +64 349 3052 | M: +64
> www.whanganui.govt.nz
> *Whanganui District Council | | | Whanganui *
> [image: Antenno] <https://www.whanganui.govt.nz/Online-Services/Antenno>
> * Like Us on Facebook*
> <https://www.facebook.com/whanganuidistrictcouncil/>
> Please consider the environment before printing this email
> CAUTION: This correspondence is confidential and intended for the named
> recipient(s) only. If you are not the named recipient and receive this
> correspondence in error, you must not copy, distribute or take an action in
> reliance on it and you should delete it from your system and notify the
> sender immediately. Unless otherwise stated, any views or opinions
> expressed are solely those of the author, and do not represent those of the
> organisation.
> Conference_dev mailing list
> Conference_dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/conference_dev
URL: <http://lists.osgeo.org/pipermail/conference_dev/attachments/20240516/da77db15/attachment.htm>
More information about the Conference_dev
