[OSGeo-Conf] FOSS4G 2027 Bristol
Luca Delucchi lucadeluge at gmail.com
Fri Jan 2 09:49:15 PST 2026
On Fri, 2 Jan 2026, 18:36 Dennis Bauszus, <dbauszus at gmail.com> wrote:
> Hello Jeroen;
> We have options for workshops but not for the conference proper and would
> prefer to have the workshops and talks at the same venue. Our aim is to
> allow comfortably for 800 delegates with the option to expand to 1000+ if
> the demand exceeds our expectations. We researched alternative locations in
> the Bristol area. However these venues were either too remote (i.e.
> Newport), too small, or both. We are in communication with the venue team
> at the University of Bristol and I will check whether a manual reservation
> prior to the system calendar opening up dates for late August/September
> 2027 is possible.
Thanks a lot for your tentative. In the worst case could you reserve the
last week of July?
This should reduce the distance with the 2028 edition.
> Best,
> Dennis
Best
Luca
URL: <http://lists.osgeo.org/pipermail/conference_dev/attachments/20260102/46027652/attachment.htm>
More information about the Conference_dev mailing list
