[OSGeo-Discuss] Computing area using different Spatial Refences
Eduardo Patto Kanegae
eduardo.kanegae at inflor.com.br
Thu May 31 10:13:11 EDT 2007
Thanks Steve. I forgot to THINK before writing. :-)
With this error sizing for a milion of hectares, just 6 hectares will be
the difference.
best
Eduardo
Stephen Woodbridge wrote:
> Wouldn't you want to use an equiarea projection to calculate the area?
> or are these small enough that is does not matter. I would expect some
> numerical rounding error, does this difference fall into that?
> All questions, no answers today :)
> -Steve W
> Eduardo Patto Kanegae wrote:
>> Hi folks,
>> A cartographic doubt:
>> We have a WGS 84 dataset ( EPSG:4326 ) and the need to to calculate
>> (in hectares) the area of each polygon. To do this, we are currently
>> transforming
>> these objects for our local common UTM spatial reference ( SAD69,
>> EPSG:29183 ) .
>> But, I was thinking if maybe the most correct procedure is to
>> transform objects
>> to UTM WGS84 and then calculate area.
>> Is this right? Does "GCS-WGS84 to UTM-WGS84" provides LESS distortion
>> than "GCS-WGS84 to UTM-SAD69" ?
>> For a given geometry(described at the end of message), we calculated
>> values using "to UTM WGS84" and "to UTM SAD69"
>> and have different values.
>> - Hectares using Transform(...,29183) = 30,9977784638335
>> - Hectares using Transform(...,32723) = 30,997559727974
>> Note: I made this test using MsSqlSpatial (
>> http://www.codeplex.com/MsSqlSpatial )
>> which implements Transform functions using NTS engine( a C# GEOS fork)
>> best regards
> Discuss mailing list
> Discuss at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/discuss
INFLOR Consultoria e Sistemas Ltda
http://www.inflor.com.br
More information about the Discuss
