[OSGeo-Discuss] Computing area using different Spatial Refences
Stephen Woodbridge
woodbri at swoodbridge.com
Thu May 31 06:50:14 PDT 2007
Wouldn't you want to use an equiarea projection to calculate the area?
or are these small enough that is does not matter. I would expect some
numerical rounding error, does this difference fall into that?
All questions, no answers today :)
-Steve W
Eduardo Patto Kanegae wrote:
> Hi folks,
> A cartographic doubt:
> We have a WGS 84 dataset ( EPSG:4326 ) and the need to to calculate
> (in hectares) the area of each polygon. To do this, we are currently
> transforming
> these objects for our local common UTM spatial reference ( SAD69,
> EPSG:29183 ) .
> But, I was thinking if maybe the most correct procedure is to transform
> objects
> to UTM WGS84 and then calculate area.
> Is this right? Does "GCS-WGS84 to UTM-WGS84" provides LESS distortion
> than "GCS-WGS84 to UTM-SAD69" ?
> For a given geometry(described at the end of message), we calculated
> values using "to UTM WGS84" and "to UTM SAD69"
> and have different values.
> - Hectares using Transform(...,29183) = 30,9977784638335
> - Hectares using Transform(...,32723) = 30,997559727974
> Note: I made this test using MsSqlSpatial (
> http://www.codeplex.com/MsSqlSpatial )
> which implements Transform functions using NTS engine( a C# GEOS fork)
> best regards
More information about the Discuss
