[OSGeo-Discuss] Is there an Open Source software application
thatwill draw a graticule on a map?
Brent Fraser
bfraser at geoanalytic.com
Fri Sep 7 11:51:49 EDT 2007
Markus,
Many thanks for the info. What I'm looking for is a
relatively simple GUI mapping application I can recommend to
casual cartographers (in this case geologists), and I think
Grass may be too big in this case.
I see that the development of the [more native] Windows
port of Grass 6.3 is moving along; I'll have to keep my eye
on that...
Thanks!
Brent Fraser
GeoAnalytic Inc.
Calgary, Alberta
----- Original Message -----
From: "Markus Neteler" <neteler.osgeo at gmail.com>
To: "OSGeo Discussions" <discuss at lists.osgeo.org>
Sent: Thursday, September 06, 2007 11:23 PM
Subject: Re: [OSGeo-Discuss] Is there an Open Source
software application that will draw a graticule on a map?
> Hi Brent,
> with GRASS' ps.map you can do that rather easily:
> - define the raster and vector map names
> - define (optionally) legend stuff
> - activate "geogrid" to overlay a geographic grid onto the
output map
> - define paper size
> It generated a Postscript file (use ps2pdf to make PDF)
which
> can be printed then.
> See
> http://grass.itc.it/gdp/html_grass63/ps.map.html
> Example screenshot (a bit low-res, sorry):
> http://www.gdf-hannover.de/lit_html/grass60_v1.2/img35.png
> Code for that map:
http://www.gdf-hannover.de/lit_html/grass60_v1.2_en/node78.html
> Markus
> On 9/6/07, Brent Fraser <bfraser at geoanalytic.com> wrote:
> > Hi all,
> > I've been looking for an Open Source desktop
application
> > that will:
> > 1. Combine raster and vector spatial data, and
(re)project
> > them
> > 2. Render a graticule (lines and labels showing latitude
and
> > longitude) (and no, I don't want to create a shapefile
to do
> > that)
> > 3. Print to a large format plotter (paper 24 inches wide
or
> > greater)
> > So far I've looked at uDig, Quantum GIS, and gvSig. As
far
> > as I can tell, none of them can do Step 2, and only
gvSig
> > does Step 3 successfully.
> > Any pointers would be appreciated!
> > Brent Fraser
> > GeoAnalytic Inc.
> > Calgary, Alberta
> > Discuss mailing list
> > Discuss at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/discuss
> Open Source Geospatial Foundation
> http://www.osgeo.org/
> http://osgeo.org/grass
More information about the Discuss
