[OSGeo-Discuss] Research For Shared Java CRS Library
Landon Blake lblake at ksninc.com
Mon May 5 16:37:51 EDT 2008
Thanks for the input Justin.
I agree simplicity (and the broad adoption that results from simplicity)
is a primary goal. We shouldn't let GeoAPI stand in the way of that.
Does anyone know how much of the existing GeoTools code is actually
based on the CRS interfaces in GeoAPI? Is anyone besides GeoTools using
the GeoAPI interfaces for a CRS library implementation in Java?
Landon
-----Original Message-----
[mailto:discuss-bounces at lists.osgeo.org] On Behalf Of Justin Deoliveira
Sent: Monday, May 05, 2008 1:20 PM
To: OSGeo Discussions
Subject: Re: [OSGeo-Discuss] Research For Shared Java CRS Library
> I know some of you want to know why we aren't just going to use the
> GeoAPI interfaces. I don't know enough about the GeoAPI code to say
that
> it won't be used. I think that will need to be part of our research
> process. It would make sense to use GeoAPI as a home for common
> interfaces if this is possible. I don't want to reinvent any existing
> technology.
Just to chime in about GeoAPI. From someone who has had to implement a
number of its interfaces here are my thoughts.
1) Its a great way to talk about standards in the context of java
interfaces
2) Its not a good way to promote interoperability
Now this is just my opinion of course so take it with a grain of salt.
But anyone who has looked at the geoapi interfaces can tell you they are
not simple. Which creates a large entry barrier for someone wanting to
implement them, which defeats the entire purpose.
I would think by definition a library which is intended to be used as a
base for other projects needs to be as simple as possible. Look at proj
for instance, i am by no means an expert on the code base but from what
I have seen there are no unnecessary abstractions. Which I would think
is a large part of the reason it has been utilized so effectively by
most of the other projects in the C and python community.
My 2c.
-Justin
> Landon
> P.S. - I have subscribed to the MetaCRS mailing list. I will post
> messages there about any decisions made on sharing
> "programming-language-independent" (PLI) resources like CRS
definitions
> or test cases.
> *Warning:
> *Information provided via electronic media is not guaranteed against
> defects including translation and transmission errors. If the reader
is
> not the intended recipient, you are hereby notified that any
> dissemination, distribution or copying of this communication is
strictly
> prohibited.  If you have received this information in error, please
> notify the sender immediately. !DSPAM:4007,481f601c109671628642973!
> Discuss mailing list
> Discuss at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/discuss
Justin Deoliveira
The Open Planning Project
jdeolive at openplans.org
Warning:
Information provided via electronic media is not guaranteed against defects including translation and transmission errors. If the reader is not the intended recipient, you are hereby notified that any dissemination, distribution or copying of this communication is strictly prohibited. If you have received this information in error, please notify the sender immediately.
More information about the Discuss mailing list
