[OSGeo-Discuss] Research For Shared Java CRS Library
Jody Garnett
jgarnett at refractions.net
Mon May 5 21:15:24 EDT 2008
Landon Blake wrote:
> I know some of you want to know why we aren’t just going to use the
> GeoAPI interfaces. I don’t know enough about the GeoAPI code to say
> that it won’t be used. I think that will need to be part of our
> research process. It would make sense to use GeoAPI as a home for
> common interfaces if this is possible. I don’t want to reinvent any
> existing technology.
Landon that sentence there *is* the definition of the GeoAPI project;
originally started for Deegree and GeoTools to work together :-) Let's
have a look and see if it meets those goals...
> P.S. – I have subscribed to the MetaCRS mailing list. I will post
> messages there about any decisions made on sharing
> “programming-language-independent” (PLI) resources like CRS
> definitions or test cases.
So would you like us to join the MetaCRS mailing list? And continue the
discussion there? Or is this a good osgeo-discussions topic?
Cheers,
Jody
More information about the Discuss
