[OSGeo-Discuss] Re: Sign the Hague declaration
P Kishor punk.kish at gmail.com
Thu May 15 09:23:01 EDT 2008
On 5/15/08, Chris Puttick <chris.puttick at thehumanjourney.net> wrote:
>  ----- "P Kishor" <punk.kish at gmail.com> wrote:
>  > >  But disagree there. Switching from M$ documents to 'real' open
>  > source
>  > > documents and dropping licensed graphical data in favour of OSM and
>  > other
>  > > free map data opens the door to 'Standardising' on something that we
>  > can all
>  > > cooperate on.
>  > It still is not clear what the "something" is... are you advocating a
>  > standard for a license or a standard for a format? Are you talking
>  > about standards in office-productivity applications (word-processing,
>  > spreadsheet, presentation software) or in databases (should we
>  > boycott
>  > everyone who uses Oracle and Ingres?) or remote sensing (does IDL go
>  > out the window?) or medical imaging or audio or video or ... you get
>  > the picture. Let me repeat my question.
>  > Standard for what?
> Standards for everything that matters.
Chris,
You are conflating a whole boatload of things here, and "everything
that matters" is about the biggest boatload there can be.
>  A physical example: in the UK we have a standard for electrical plugs and sockets and for the supply. This means that I can buy a lamp or a fridge I can be sure it will be able to plug in to my electrical socket and just work and I don't risk death by using it.
And, when I travel from the US to the UK, I am sol unless I carry a
"driver" or a "translator" that allows me to connect my appliance to
the UK grid.
What was the standard here? I didn't force UK to change to 110 v and
to flat pins. I just went to the market and bought a translator.
>  It is my choice to have switched sockets or unswitched. The plug can be black or white or chrome (hopefully not chrome...); it can be rubberised and curvy or hard plastic and square. The sockets can be sunk into the wall or surface mounted or in trunking and also any colour/material (mine are black nickel, which is nice without being too much, but I digress...). It doesn't matter i.e. these factors are not part of standard, because what matters is that the socket has 3 specifically sized rectangular pins, positioned just so, with the right pin "live" and fused appropriately, the left pin neutral and the top pin earth. The socket needs to have the equivalent sized and placed holes and wired appropriately and if switched the switch needs to meet certain specifications. The UK electrical supply is legally required to be 50Hz AC at 230V +/- 10%
>  That's it. That's the bits that need to be standardised. And not only are supply and sockets and plugs standardised but mandated to be so. This means I can buy my sockets from whomever made by whomever and my plugs are sourced by the manufacturers of my electrical equipment from whomever. Bring it all together with my power supply from yet another supplier and it all works fine.
>  SQL already is a standard (the openness of it let's debate another day). A well-behaved (R/O)DBMS responds more or less the same way to an SQL query as the others. This has been a useful evolution of databases, reflecting their relative age. But we do not have standards in many areas of digital life where it would be important, or where the standards exist, they are not being mandated and therefore are not being adopted.
SQL is not a data storage format. SQL is a query standard, and a
fairly malleable one.
Are you talking about data storage formats or about query standards?
>  So the shortish answer to your question: standards for the digital plugs and sockets and standards for the digital power supply. The plugs and sockets are the APIs and the protocols; lots of that is already sorted. The digital power supply is the information that flows, the stuff that is important in this information age we are entering. It is there we are short of standards. I don't want to dictate to anyone what software they should use. I do think I should be able to demand that they provide information in a standardised format and this not be an issue because they don't have a specific software package. Where there are no available standards we have to be pragmatic initially, but we must move, with some urgency, towards a position where there are standards for those interchanges i.e. develop them either from existing formats or by starting clean.
My shortish reply is that there is no shortish reply. I am with you
with regards to the sentiment. But I am convinced that the
digistan/"Hague declaration" is not the way to go about doing so.
We've had a lot of discussion about standards on OSGeo lists as well
as on Geowanking lists. Some of that discussion merits re-reading.
Some are born standards (Shapefiles, by virtue of first-entry as well
as subsequent ubiquity), some achieve standards (OGC-type standards by
discussion and committee), and others have standards thrust upon them
(big agencies using MS-Word or ArcGIS).
In the end, the most useful and easy to implement format and query
interchange method approaches the level of a standard.
>  It's not about control or restrictions, its about real choice. You get to choose which applications you use for which jobs and do so without concerns about operating systems or the applications being used by your client or other stakeholders, because the information will flow as a standard all can read without issue.
>  As to why governments first? Another long answer for another time...
>  Chris
>  Files attached to this email may be in ISO 26300 format (OASIS Open Document Format). If you have difficulty opening them, please visit http://iso26300.info for more information.
I found this end-tag to your email quite humorous unintentionally --
thankfully no file was attached, but if it had been, and if I had had
difficulty opening it, seems like it would have been my responsibility
to figure out how to open it. Thankfully, my life didn't depend on it.
Some "standards" have a long way to go before they become a standard.
More information about the Discuss mailing list
