[OSGeo-Discuss] Research For Shared Java CRS Library
Justin Deoliveira
jdeolive at openplans.org
Mon May 5 14:57:11 PDT 2008
Pretty much all client code of the referencing/crs subsystem in GeoTools
goes through GeoAPI. When the switch occurred a few years back the
maintainers were aggressive about removing direct references to the
GeoTools implementation classes.
Also, both GeoServer and uDig make extensive use of these interfaces as
well.
-Justin
Landon Blake wrote:
> Thanks for the input Justin.
> I agree simplicity (and the broad adoption that results from simplicity)
> is a primary goal. We shouldn't let GeoAPI stand in the way of that.
> Does anyone know how much of the existing GeoTools code is actually
> based on the CRS interfaces in GeoAPI? Is anyone besides GeoTools using
> the GeoAPI interfaces for a CRS library implementation in Java?
> Landon
> -----Original Message-----
> From: discuss-bounces at lists.osgeo.org
> [mailto:discuss-bounces at lists.osgeo.org] On Behalf Of Justin Deoliveira
> Sent: Monday, May 05, 2008 1:20 PM
> To: OSGeo Discussions
> Subject: Re: [OSGeo-Discuss] Research For Shared Java CRS Library
>> I know some of you want to know why we aren't just going to use the
>> GeoAPI interfaces. I don't know enough about the GeoAPI code to say
> that
>> it won't be used. I think that will need to be part of our research
>> process. It would make sense to use GeoAPI as a home for common
>> interfaces if this is possible. I don't want to reinvent any existing
>> technology.
> Just to chime in about GeoAPI. From someone who has had to implement a
> number of its interfaces here are my thoughts.
> 1) Its a great way to talk about standards in the context of java
> interfaces
> 2) Its not a good way to promote interoperability
> Now this is just my opinion of course so take it with a grain of salt.
> But anyone who has looked at the geoapi interfaces can tell you they are
> not simple. Which creates a large entry barrier for someone wanting to
> implement them, which defeats the entire purpose.
> I would think by definition a library which is intended to be used as a
> base for other projects needs to be as simple as possible. Look at proj
> for instance, i am by no means an expert on the code base but from what
> I have seen there are no unnecessary abstractions. Which I would think
> is a large part of the reason it has been utilized so effectively by
> most of the other projects in the C and python community.
> My 2c.
> -Justin
>> Landon
>> P.S. - I have subscribed to the MetaCRS mailing list. I will post
>> messages there about any decisions made on sharing
>> "programming-language-independent" (PLI) resources like CRS
> definitions
>> or test cases.
>> *Warning:
>> *Information provided via electronic media is not guaranteed against
>> defects including translation and transmission errors. If the reader
> is
>> not the intended recipient, you are hereby notified that any
>> dissemination, distribution or copying of this communication is
> strictly
>> prohibited. If you have received this information in error, please
>> notify the sender immediately.
>> Discuss mailing list
>> Discuss at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/discuss
>> !DSPAM:4007,481f601c109671628642973!
Justin Deoliveira
The Open Planning Project
More information about the Discuss
