[OSGeo-Discuss] GIS_Libraries
Picavet Vincent Vincent.Picavet at mediapost.fr
Tue May 5 09:40:36 PDT 2009
Some more precision.
> Let's say ShapeLib is published under GPL (I don't know
> whether or not it is; this is only for illustration purpose).
> Let's say, MapServer utilizes ShapeLib, but doesn't modify
> ShapeLib, but uses ShapeLib as is. Let's say, MapServer's
> creator decides to make millions off of MapServer, Inc. He is
> under no obligation to release the source code of MapServer,
> but he is obligated to release the source code of ShapeLib,
> which is no big deal, because the source code of ShapeLib is
> already available to anyone.
> On the other hand, let's say, ShapeLib is modified to perform
> better, or differently, for MapServer. Now, there is an
> obligation to release the source code to the modified version
> of ShapeLib no matter what the value of that value-added
> might be. That is what the GPL obligates.
> MapServer itself is still governed by whatever license that
> its creator decides to apply.
It depends what you call <utilizes>. If Mapserver links with the
ShapeLib library, the latter being under GPL licence, then its source
code has to be released. This is the <contaminating> part of GPL.
The situation you describe is true if ShapeLib is under LGPL. If it is
under GPL, everything linked to it must be under a GPL-compliant
licence.
As Daniel says, GPL code can not be embedded in or linked to a closed
source application. Period.
Please also note that the GPL licence does not prevent any commercial
usage of the software.
Hopes this helps to clarify things.
Vincent
> > Also take into consideration development platform/language.
> > My group (MapWindow project) has a number of people using
> our GIS SDK
> > for commercial applications in the .NET platform. MapWindow is
> > licensed under MPL 1.1 which supports commercial usage.
> > Dan
> > On Tue, May 5, 2009 at 7:07 AM, Nenad Milasinovic
> > <nenad.milasinovic at zesium.com> wrote:
> >> Hello,
> >> I am interested is there any reliable open source, LGPL
> licensed GIS
> >> SDK or library suited for building commercial, platform
> independent
> >> GIS application on top of it.
> >> I am also interested for commercial solutions but only as
> SDK or library.
> >> I will appreciate any help.
> >> Best regards.
> >> Nenad Milasinovic
> >> Software Development and Testing
> >> "ZESIUM mobile" d.o.o.
> >> Valentina Vodnika 8/9
> >> 21000 Novi Sad
> >> Serbia
> >> Tel: +381 (0)21 472 15 48
> >> Fax: +381 (0)21 472 15 49
> >> Mob: +381 (0)61 231 41 20
> >> E-mail: nenad.milasinovic at zesium.com
> >> _______________________________________________
> >> Discuss mailing list
> >> Discuss at lists.osgeo.org
> >> http://lists.osgeo.org/mailman/listinfo/discuss
> Puneet Kishor http://www.punkish.org/
> Carbon Model http://carbonmodel.org/
> Charter Member, Open Source Geospatial Foundation
> http://www.osgeo.org/ Science Commons Fellow, Geospatial Data
> http://sciencecommons.org Nelson Institute, UW-Madison
> http://www.nelson.wisc.edu/
> collaborate, communicate, compete
> Sent from Madison, WI, United States
More information about the Discuss mailing list
