[OSGeo-Discuss] Open Source Library For ECW Conversion
Simone Giannecchini simone.giannecchini at geo-solutions.it
Wed May 13 07:52:10 PDT 2009
You can use geotools with the gdal plugin, see:
http://docs.codehaus.org/display/GEOTDOC/ImageIO-EXT+GDAL+Plugin
http://docs.codehaus.org/display/GEOTOOLS/ImageIO-EXT+GDAL
Simone.
Ing. Simone Giannecchini
GeoSolutions S.A.S.
Owner - Software Engineer
Via Carignoni 51
55041  Camaiore (LU)
Italy
phone: +39 0584983027
fax:      +39 0584983027
mob:    +39 333 8128928
http://www.geo-solutions.it
http://simboss.blogspot.com/
http://www.linkedin.com/in/simonegiannecchini
On Wed, May 13, 2009 at 4:41 PM, Landon Blake <lblake at ksninc.com> wrote:
> I’m looking for an open source library that will allow me to convert ECW
> images into a more common format like JPG or TIFF. I’d love it if there were
> something in Java, but I’m not running across anything via search engine
> query so far.
> I could probably work with a library written in Python, and as a last
> resort, something written in C.
> I will be trying to write a program that will convert the image files in a
> batch.
> Any suggestions?
> Thanks,
> Landon
> Warning:
> Information provided via electronic media is not guaranteed against defects
> including translation and transmission errors. If the reader is not the
> intended recipient, you are hereby notified that any dissemination,
> distribution or copying of this communication is strictly prohibited. If you
> have received this information in error, please notify the sender
> immediately.
> Discuss mailing list
> Discuss at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/discuss
More information about the Discuss mailing list
