[OSGeo-Discuss] Searching proper schema constructs in layered GML application schema
Raj Singh
raj at rajsingh.org
Thu Nov 12 12:32:05 PST 2009
OGC's GML discussion forum is probably the best place to ask this.
http://feature.opengeospatial.org/forumbb/viewforum.php?f=9
Staff monitors the board and tries to make sure posted questions get
looked at by topic experts within the membership.
Raj
On Nov 12, at 6:21 AM, Krzysztof FF wrote:
> Hi there,
> I'm trying to define GML 3.2.1. based application schema for FM-
> related
> software.
> The concept is to create some intermediate base-level schema common
> to basic
> software tools (e.g. universal XSLT processing), completed with
> specific
> application-level schemas presenting actual application structure.
>> From "GML Best Practices Guide"
> (http://www.ogcnetwork.net/system/files/
> GML_Best_Practices_Guide.pdf) it is
> advised not to use "type" attribute:
> quote starts
> If you wish to denote distinct semantic types such as river and
> road, it is
> INVALID GML to use a type attribute as shown in the following
> examples.
> Example of Invalid GML Using a Type Attribute
> <app:GenericFeature gml:id = "p2" type = "Canal">
> <app:material>water</app:material>
> <app:age>90</app:age>
> <gml:centerLineOf> … </app:centerLineOf>
> </app:GenericFeature>
> You can "narrow" the type denoted by the feature type name element
> (<app:
> GenericFeature>) by using qualifying properties, as shown in the
> following
> example.
> <app:GenericFeature gml:id = "p2">
> <app:type>Canal</app:type>
> <gml:centerLineOf> ... </app:centerLineOf>
> quote ends
> But from the other hand, from "XML Schema W3C Recommendation"
> (http://www.w3.org/TR/xmlschema-0/#abstract) it results that using
> abstract
> types makes constructs with "type" attribute perfectly legal:
> quote starts
> Declaring a type as abstract simply requires the use of a type
> derived from
> it (and identified by the xsi:type attribute) in the instance
> document.
> <schema xmlns="http://www.w3.org/2001/XMLSchema"
> targetNamespace="http://cars.example.com/schema"
> xmlns:target="http://cars.example.com/schema">
> <complexType name="Vehicle" abstract="true"/>
> <complexType name="Car">
> <complexContent>
> <extension base="target:Vehicle"/>
> </complexContent>
> </complexType>
> <element name="transport" type="target:Vehicle"/>
> </schema>
> The transport element is not abstract, therefore it can appear in
> instance
> documents. However, because its type definition is abstract, it may
> never
> appear in an instance document without an xsi:type attribute that
> refers to
> a derived type. That means the following is not schema-valid:
> <transport xmlns="http://cars.example.com/schema"/>
> because the transport element's type is abstract. However, the
> following is
> schema-valid:
> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
> xsi:type="Car"/>
> because it uses a non-abstract type that is substitutable for Vehicle.
> quote ends
> It results that using Galdos recommendation with <app:type> element is
> somehow artificial and naive, disallowing for application-specific
> specialization of concrete GenericFeatures.
> On the other hand, W3C recommended xsi:type attribute is perfectly
> legal,
> and allows using in the same time generic schema to describe specific
> features.
> Of course it requires further generalization by defining generic
> properties
> for features in base-level schema with their concrete definitions in
> application-level schema.
> I wonder what is opinion of GML-gurus about proper constructs for
> layering
> of GML-application schemas.
> Regards,
> Krzysztof
> View this message in context: http://n2.nabble.com/Searching-proper-schema-constructs-in-layered-GML-application-schema-tp3992089p3992089.html
> Sent from the OSGeo Discuss mailing list archive at Nabble.com.
> Discuss at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/discuss
More information about the Discuss
