[OSGeo-Discuss] Documenting GIS Data Models (Again): Using DXF
Landon Blake lblake at ksninc.com
Wed Sep 9 16:36:15 EDT 2009
Craig,
Because I am working with simple features, the entities I'm modeling are
more like tables in a database than they are objects from
object-oriented software architecture.
My basic set-up is looking something like this:
A "sheet" for each simple feature type in the data model. This sheet
contains the following elements:
-          A table describing the features attributes.
-          A table describing limitations or restrictions on the
attribute values.
-          A table describing any attribute value domains used in the
simple feature.
-          A brief description of the simple feature type.
-          Notes explaining the creation/extraction, modification, and
destruction policies for the simple feature type.
I'm thinking there may be two (2) additional sheets for each simple
feature type. One of these sheets will contain:
-          Topology restrictions for this simple feature type.
-          Data on the spatial relationships this simple feature type
participates in.
-          Data on the temporal relationships this simple feature type
participates in.
-          Data on the relationship with non-spatial entities (tables)
that this simple feature type participates in.
The second sheet will contain the metadata policy and information on
dataset-level and feature-level metadata that should be created and
maintained for the simple feature type.
I believe there will be similar sheets for the temporal events and
non-spatial features in the GIS data model.
Some of this is still taking shape in my head. In the end, it is
probably going to look and function like a set of civil engineering
plans. :]
I've just started work on the first sheet I described in this message,
which documents the attributes for a simple feature type.
Landon
Office Phone Number: (209) 946-0268
Cell Phone Number: (209) 992-0658
[mailto:discuss-bounces at lists.osgeo.org] On Behalf Of Craig Miller
Sent: Wednesday, September 09, 2009 12:58 PM
To: 'OSGeo Discussions'
Subject: RE: [OSGeo-Discuss] Documenting GIS Data Models (Again): Using
DXF
Landon,
I missed your previous post.  I'm not sure if you are modeling GIS
Objects or a relational database but am guessing you are modeling GIS
objects.  Since I missed the earlier post(s)... Is there a reason why
traditional OO diagrams such as UML Class diagrams won't work for the
GIS data you are modeling?
Craig
[mailto:discuss-bounces at lists.osgeo.org] On Behalf Of Landon Blake
Sent: Wednesday, September 09, 2009 12:48 PM
To: OSGeo Discussions
Subject: [OSGeo-Discuss] Documenting GIS Data Models (Again): Using DXF
I posted a few weeks back I posted about possible ways to document and
share GIS data models. I decided to move forward with a graphical
approach.
I started building diagrams to document my GIS data model for the Public
Land Survey System in the United States. I am drawing these diagrams in
a CAD program. When I get things ironed out I hope to release the
following items to the GIS community:
-       My completed GIS data model in DXF format that can be used as an
example or template for other models.
-       A set of CAD "blocks" that can be used to build similar
diagrams.
If I like how things come together with the diagrams, I might try
converting the diagrams to SVG. The diagrams would be much prettier in
SVG, but I am quicker with CAD than I am with Inkscape, and I want to
get a prototype completed quickly.
This will make a lot more sense when you get to see the example
diagrams.
I welcome any collaboration on this effort. If there is interest, I
could move this discussion to the Standards mailing list. It would be
great to get input from interested parties now, while the diagrams are
still taking shape.
Landon
Warning:
Information provided via electronic media is not guaranteed against
defects including translation and transmission errors. If the reader is
not the intended recipient, you are hereby notified that any
dissemination, distribution or copying of this communication is strictly
prohibited. If you have received this information in error, please
notify the sender immediately.
URL: http://lists.osgeo.org/pipermail/discuss/attachments/20090909/bbbf2cd8/attachment-0001.html
More information about the Discuss mailing list
