[OSGeo-Discuss] mxd to other format (i.e. shapefile)
Noli Sicad nsicad at gmail.com
Mon Aug 2 19:41:33 PDT 2010
Maning,
Reading again the post.
I think my reply is wrong.
Can SLD format can be convert to PostGIS then to shapefile?
Noli
On 8/3/10, Noli Sicad <nsicad at gmail.com> wrote:
> Hi Maning,
> You can try ArcMap2SLD. It convert *.mxd to SLD.
> Download it here.
> http://wald.intevation.org/frs/?group_id=32&release_id=213
> http://www.cadmaps.com/gisblog/?p=75
> Regards, Noli
> On 8/3/10, maning sambale <emmanuel.sambale at gmail.com> wrote:
>> No luck so far looking for a converter.
>> Basically, I want to export geometry and attributes without the
>> styling from an Arc's mxd format to shapefile.
>> Any workaround here (other then looking for an ArcGIS installed machine)?
>> cheers,
>> maning
>> "Freedom is still the most radical idea of all" -N.Branden
>> wiki: http://esambale.wikispaces.com/
>> blog: http://epsg4253.wordpress.com/
>> Discuss mailing list
>> Discuss at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/discuss
More information about the Discuss mailing list
