[OSGeo-Discuss] uDig 1.2.0 Released
Jody Garnett jody.garnett at gmail.com
Tue Aug 17 07:16:20 PDT 2010
The uDig 1.2 release process is complete and we are pleased to offer uDig 1.2.0 for download.
This release is made in conjunction with GeoTools 2.6.5.
The uDig 1.2.0 release is available from the main download page.
INSTALLATION
Download the package appropriate to your platform, unzip and run:
Windows
Linux
Mac
SDK: For use with SDK Quickstart instructions
Windows and Linux packages includes a Java Runtime so you really can unzip and run without making any configuration changes to your Machine. On Mac OSX uDig is able to check for Java Advanced Imaging and install if needed. There is also a windows installer.
To get started with uDig:
Help Menu provides a Quickstart
Walkthrough 1
Walkthrough 2
ABOUT UDIG 1.2 SERIES
The uDig 1.2 series highlights a lot really great ideas the developer community has been working on. We have migrated to a modern version of the GeoTools library - bringing in five years of new developments in standard support, and a host of new raster and vector formats. An exciting addition is the use of the ImageIO-ext project allowing the use of raster formats supported by GDAL.
New and capabilities of uDig 1.2 include:
ImageIO-EXT rendering enabling additional raster formats and working with images larger then memory
On select platforms MRSID and ECW raster support
Tiled rendering (as an option in preferences) with a new flicker free panning tool.
Support for GeoWebCache and TileCache via WMS-C
WFS 1.1.0 support (read-only)
Greatly improved ArcSDE support; multithreaded and faster
Advanced Symbology including Hatches and True Type Font support
ABOUT UDIG 1.2.0
Features and capabilities of this release:
Access to GeoTools DataStores via a generic wizard allowing users to connect to many additional data formats and access all connection parameters.
One long standing difficulty with using large datasets is uDig wanting to know the bounds of the data (so it can efficiently search, zoom). For common spatial file formats this data is known and available; for large databases such as DB2 and PostgreSQL this can take some time to calculate. For the generic GeoTools DataStore wizard above we are experimenting with using bounds based simply on the valid area for coordinate reference system provided by the data.
The valid area of the coordinate reference system is also used when "clipping" WFS requests resolving some long standing issues when editing WFS services that do not update their Capabilities document.
Advanced: Control what features are requested for a layer using a Common Query Language (CQL) expression. The expression builder offers command completion with the full GeoTools function list available as you type
Advanced: Cache support added allowing you to cache Raster layers in memory (please be working with large datasets as this is the first time uDig is allowing users to cache information in memory). Please note that raster file formats on disk are optimised and in may cases perform better than caching in memory. Caching in memory is recommended for formats such as jpeg (where the entire image must be loaded to display even a small section) and when working with data from a slow device such as the network or DVD.
Experimental: Cache support added allowing you to cache WFS layers in memory for increased performance (please be careful when working with large datasets as this is the first time uDig is allowing users to cache data in memory)
Enhanced Vector Editing
Revamped printing support, standard paper sizes are supported when printing
Import multiple layers into the catalog at once
switch between common map scales
Improved Drag and Drop support allowing multiple layers to be manipulated at once
Drag and Drop treats URL as a distinct content type across browser implementations
Notes and documentation for developers:
Service and GeoResource Interceptors Docs
Interceptors Docs
Review of the dependencies used by the uDig SDK with license and build advice
We have transitioned to a modern version of GeoTools allowing for a more productive relationship with the larger community
Support for the "JDBC-NG" rewrite of GeoTools Database access
Uses the latest Eclipse 3.6.0 "Helios" release for an industrial strength plug-in system
Uses the latest "Babel" project translations
RELEASE NOTES
The following release notes are applicable to this release:
UDIG 1.2.0 Release Notes, August 9, 2010 (23 Issues)
UDIG 1.2.RC3 Release Notes, May 17th, 2010 (25 Issues)
UDIG 1.2.RC2 Release Notes, March 21, 2010 (7 Issues)
UDIG 1.2.RC1 Release Notes, March 10, 2010 (4 issues)
UDIG 1.2.M9 Release Notes, January 8, 2010 (2 issues)
UDIG 1.2.M8 Release Notes, December 8, 2009 (1 issue)
UDIG 1.2.M7 Release Notes, September 9, 2009 (13 issues)
UDIG 1.2.M6 Release Notes, August 5, 2009 (53 issues)
UDIG 1.2.M5 Release Notes, June 10, 2009 (4 issues)
UDIG 1.2.M4 Release Notes, May 23, 2009 (12 Issues)
UDIG 1.2.M3 Release Notes, March 30, 2009 (74 Issues)
UDIG 1.2.M2 Release Notes, February 5, 2009 (14 Issues)
UDIG 1.2.M1 Release Notes, December 18, 2008 (10 Issues)
UDIG 1.2.M0 Release Notes, August 19, 2008 (19 Issues)
KNOWN PROBLEMS:
The mac release is unable to support the full range of ImageIO-EXT formats. Please contact udig-devel if you are able to build GDAL on Mac OSX.
URL: <http://lists.osgeo.org/pipermail/discuss/attachments/20100818/bdfac07a/attachment-0002.html>
More information about the Discuss mailing list
