[OSGeo-Discuss] Re: [Board] Open Source and Open Standards White Paper
Adrian Custer acuster at gmail.com
Fri Apr 15 05:24:19 PDT 2011
Hey Seven,
you two are working on a position paper which is hard to write well! So
please take the critique below as encouragement and ideas, if you have
time, to perhaps help you improve the structure of what you are trying
to write.
On 04/14/2011 08:55 PM, Seven (aka Arnulf) wrote:
> Folks,
> please be so kind and give this paper a moment of your attention:
> http://wiki.osgeo.org/wiki/Talk:Open_Source_and_Open_Standards
In discussing the 'open standards', your point 3 related to OGC
standards is actually *not* a policy of the OGC. OGC policies would
allow patent encumbered standards requiring license fees; it is only by
luck(?) that no OGC standard has yet been that way. Similarly, point 5
is not true. WMS requires a document returned in XML which follows a
particular schema. We currently are working on a new approach which
would allow flexibility in 'data storage model{s} or format{s}' but we
are not there yet and regardless we will probably always require a
finite number of such formats---their standardization is part of our
mandate. Point 6 is something I am not yet convinced of: recently a
standard has been approved which is wholly controlled by a single
organization (a single person really); it is not clear yet how this
process will evolve and if control will be distributed from that person
to a community of some kind. So perhaps you can change the lead it from
'standards which are' to 'standards which aim to be' or you might revise
the list of points.
In introducing 'Open Source' you discuss, appropriately, the aspects of
freedom important to some software that labels itself with that moniker.
However, you never relate that back to the openness of the source---it
might be worth mentioning that freedom implies access to the source (to
read, to rebuild, to modify), thereby explaining the label 'open
source'. The second paragraph, the typical clarification of 'free' in
'free software', does not make so much sense here since you have adopted
the label 'Open Source' rather than 'Free software.' The list of
freedoms is also problematic since they are germaine to 'free software'
but not necessaryly to 'open source' software. Probably, it would be
better to list the 10 requirements of 'open source' software you mention
in the third paragraph, rather than the four requirements of 'free
software'. As Cameron mentioned, you then launch into the variety of
production styles in 'Open source' projects but really you probably want
to go from the list of requirements to a list of advantages: both of the
artifacts (can audit the source) and of the projects which produce them.
'release early/often' is not a good in itself, indeed it forces users to
vet the software they acquire---you have to talk about the benefits that
such an approach can bring. Finally you end the section with 'real Open
Source software' which is starting to be a mess; if there is 'real' and
'fake' then that will need to be front and center not a passing
reference at the end of the section.
In discussing 'open data' I disagree with your 'The most prominent open
geospatial data project is OpenStreeMap.' By far the open data which has
had the biggest impact on GIS these past four decades in my opinion has
been the longstanding tradition of the US government that its data,
funded by the people taxed by the US government, has already been paid
for and therefore is part of the public domain. Colaborative data
acquisitions efforts are fascinating and full of potential but are not
necessarily 'most prominent' outside of our circle and build on existing
traditions which have been going on for a while (e.g. the national bird
survey in the UK) which have massive communities (never underestimate
the birders). So perhaps you could talk about the real holdings of 'open
data' to which we have access today: the various geoids, the STRM and
global bathymetry hodlings, the MODIS archives, the global
self-consistent hierarchial shoreline database, and others. That can be
contrasted with the massive holdings which exist but are limited in use
in one way or another, i.e. 'dark data' or 'closed data'. Finally, you
can certainly talk about the more recent, community driven efforts to
accumulate 'mass market' data like the road networks but note that those
collection efforts are focused on particular kinds of data. In other
words, this section, if you are going to include it, needs love.
On the OGC position towards open source software, you probably have to
distinguish between the official position (agnostic), the position of
the members of the consortium (globally for the existance of such
implementations) and the de facto position (the OGC could but does not
allow free certification of open source implementations). The change of
person in the sentence starting 'Our goal ...', paragraph 2, is out of
place with the rest of the document (we don't know without work that
'our' is 'the OGC').
"OSGeo encourages project developers to adopt open standards." How does
this 'encouragement' happen? I have never seen this expressed anywhere.
Indeed, OSGeo seems to have a rich tradition of encouraging 'roll your
own' innovation rather than of adopting existing standards. There is
even active hostility towards ISO standards because one has to pay for
the documents. So to my mind this reads less as reality than as what we
might want; the reality is more ambivalent. It is true that a massive
amount of work at the OSGeo uses existing standards but perhaps,
ironically enough, not so much the open geospatial standards.
The conclusion starts with some reference to "ICT" whatever that may be;
it seems weak.
Overall, I suspect readers are more interested in 'what it does for me'
than in 'what it claims to be.' Therefore, I would encourage you to
relate how open standards and open source software help build large,
distributed, robust, sustainable spatial data infrastructures (SDIs) and
how they help organizations of different kinds participate in those SDIs
(by coding their own software that follows the standard, by using
existing software that follows the standards, or by building on the
standards to provide new functionality). The paper currently reads more
like a definition than like an explanation of 'how they can help the
reader'. On the standards side it might be worth mentioning there are
standards for semantics (the abstract series), for services, and for
data formats which have different uses to different publics. On the
OSGeo side it would be worth talking about the disparity of the efforts
to mention the hetergenity of the relationships with standards.
Sorry for the missive; I subject you to it because it would take me much
more time to distill it to its essentials than it will take you to read
through this mail.
ciao,
   ~adrian
More information about the Discuss mailing list
