[OSGeo-Discuss] Batch geocoding
JP Glutting
jpglutting at gmail.com
Fri Feb 4 17:20:08 EST 2011
Hi Bernie,
You can't actually get the lat-lng back out of a Fusion table. It will
geocode all the addresses, but you can't get the numbers back, you can just
make a map or layer or something.
http://groups.google.com/group/fusion-tables-users-group/browse_thread/thread/91c43c73107164eb
Unless I export it to KML and pull it back out of there?
That seems like a lot of work. But it sure geocodes like gangbusters.
Cheers,
JP
Public Health - GIS - Bioinformatics
http://www.bmeisis.com
<http://www.bmeisis.com/>http://www.jpglutting.com
On Fri, Feb 4, 2011 at 7:42 PM, Connors, Bernie (SNB) <Bernie.Connors at snb.ca
> wrote:
> Try Google Fusion Tables. All you have to do is put all of the address
> components in one field and it should be recognized and geocoded.
> *Bernie Connors, P.Eng*
> Service New Brunswick
> (506) 444-2077
> 45°56'25.21"N, 66°38'53.65"W
> www.snb.ca/geonb/
> *From:* discuss-bounces at lists.osgeo.org [mailto:
> discuss-bounces at lists.osgeo.org] *On Behalf Of *JP Glutting
> *Sent:* Friday, 2011-02-04 09:34
> *To:* discuss at lists.osgeo.org
> *Subject:* [OSGeo-Discuss] Batch geocoding
> Hello,
> I have a large set of addresses (around 150k) that I need to geocode for a
> study (my Masters thesis on heat-related mortality). I am looking into
> different solutions, but I can't find anything that seems like it would work
> properly.
> I could script a solution using Google's map API, but there is a limit of
> 2,500 addreses per day (I can get around them with a little patience).
> Right now the best solution I am looking at geopy for geocoding addresses (
> http://code.google.com/p/geopy/). It seems like a good system, I think I
> can use it to pull addresses out of my database and write back coordinates.
> There is one thing that I am not sure, about, though, is whether I am
> actually allowed to use the Google API without my use being liked to a
> specific web page. The terms of service and form for getting a Google API
> key require a URL linked to a Google account. In fact, it looks like the API
> can only be used through a web site:
> "5.2 *Account Key*. After supplying Google with your account information
> and the URL of your Maps API Implementation, and accepting the Terms, you
> will be issued an alphanumeric key assigned to you by Google that is
> uniquely associated with your Google Account and the URL of your Maps API
> Implementation. Your Maps API Implementation must import the Google Maps
> APIs using this key as described in the Maps APIs Documentation<http://code.google.com/apis/maps/documentation/>,
> and Google will block requests with an invalid key or invalid URL. You may
> only obtain and use a key in accordance with these Terms and the Maps APIs
> Documentation <http://code.google.com/apis/maps/documentation/>."
> So it looks like I can't even get it to work without a URL.
> I can always write a script that loops through results extracted from the
> database, creates URLs and parses the XML results one at a time, but that
> seems like a fairly inelegant solution.
> Does anyone have any good ideas about how to geocode a few thousand
> addresses?
> Many thanks,
> JP
> Discuss mailing list
> Discuss at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/discuss
URL: http://lists.osgeo.org/pipermail/discuss/attachments/20110204/83254300/attachment.html
More information about the Discuss
