[OSGeo-Discuss] RE: Harvesting from a Geoportal Extension 9.3.1
jforne jforne at linz.govt.nz
Tue Feb 1 12:23:59 PST 2011
Thanks Heikki - much appreciated!
Sorry for the slow reply... I'm new to using GeoNetwork and have been trying to work out what's happening.
Anyhow, as suggested, I'll re-send my question to GeoNetwork users mailing list.
In addition, I gather that Geoportal Extensions use the CSW 2.0.1 (http://www.opengeospatial.org/resource/products/compliant).
By "unsuccessfully" I mean that after I "add" (refer original screen dump), select the OGC Web service to be harvested and then click "run" I get an error message (see attached to current email).
Thanks again,
John
John Forne
New Zealand Geospatial Office |
DDI: +64 4 496 5404
www.geospatial.govt.nz<http://www.geospatial.govt.nz/>
Land Information New Zealand  l  Toitu te whenua
Lambton House  l  160 Lambton Quay  l  PO Box 5501  l  Wellington 6145  l  New Zealand | Fax +64 4 498 3519
From: Heikki Doeleman [via OSGeo.org] [mailto:ml-node+5969604-260365052-288785 at n2.nabble.com]
Sent: Saturday, January 29, 2011 1:02 AM
To: John Forne
Subject: Re: Harvesting from a Geoportal Extension 9.3.1
hello John,
I think it is best if you'd repeat sending your message to the GeoNetwork users mailing list, see https://lists.sourceforge.net/lists/listinfo/geonetwork-users.
That being said, I've looked at your screenshot and it looks fine to me, assuming Geoportal Extensions uses the CSW 2.0.2 protocol.
When you say "unsuccessfully" what do you mean by that exactly ? Do you get any errors in GeoNetwork's output when running the harvester ? Do you see any indication of an error in the page listing all configured harvesters ?
Kind regards
Heikki Doeleman
On Fri, Jan 28, 2011 at 4:21 AM, jforne <[hidden email]</user/SendEmail.jtp?type=node&node=5969604&i=0>> wrote:
Hi there
I'm having trouble adding Geoportal Extensions as nodes to be harvested by
my GeoNetwork node. Could somebody please guide me through what I need to do
to add Geoportal Extensions (presumably under Harvesting Management)? Please
see below for a screen dump of how I tried (unsucessfully) to configure...
http://osgeo-org.1803224.n2.nabble.com/file/n5968645/Screen_dump_re_harvesting_geoportal.doc<http://osgeo-org.1803224.n2.nabble.com/file/n5968645/Screen_dump_re_harvesting_geoportal.doc?by-user=t>
Note: we are developing a GeoNetwork catalogue for datasets and other
resources in New Zealand. I am trying to configure our GeoNetwork node so
that our node is able to harvest metadata from other web-based catalogues -
both GeoNetwork based and others.
Many thanks in anticipation,
John
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Harvesting-from-a-Geoportal-Extension-9-3-1-tp5968645p5968645.html<http://osgeo-org.1803224.n2.nabble.com/Harvesting-from-a-Geoportal-Extension-9-3-1-tp5968645p5968645.html?by-user=t>
Sent from the OSGeo Discuss mailing list archive at Nabble.com.
[hidden email]</user/SendEmail.jtp?type=node&node=5969604&i=1>
http://lists.osgeo.org/mailman/listinfo/discuss
[hidden email]</user/SendEmail.jtp?type=node&node=5969604&i=2>
If you reply to this email, your message will be added to the discussion below:
http://osgeo-org.1803224.n2.nabble.com/Harvesting-from-a-Geoportal-Extension-9-3-1-tp5968645p5969604.html
To unsubscribe from Harvesting from a Geoportal Extension 9.3.1, click here<http://osgeo-org.1803224.n2.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=5968645&code=amZvcm5lQGxpbnouZ292dC5uenw1OTY4NjQ1fC0zOTI0ODQ0NQ==>.
______________________________________________________________________________________________________
This message contains information, which is confidential and may be subject to legal privilege.
If you are not the intended recipient, you must not peruse, use, disseminate, distribute or copy this message.
If you have received this message in error, please notify us immediately (Phone 0800 665 463 or info at linz.govt.nz) and destroy the original message.
LINZ accepts no responsibility for changes to this email, or for any attachments, after its transmission from LINZ.
Thank you.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Harvesting-from-a-Geoportal-Extension-9-3-1-tp5968645p5982495.html
URL: <http://lists.osgeo.org/pipermail/discuss/attachments/20110201/cc67bd3c/attachment-0002.html>
More information about the Discuss mailing list
