[OSGeo-Discuss] Batch geocoding
JP Glutting jpglutting at gmail.com
Sun Feb 6 07:13:09 PST 2011
FYI: Fusion Tables does not provide access to unlimited geocoding. There is
a daily limit (not sure what it is, but I assume it is the same as the API)
http://www.google.com/support/fusiontables/bin/answer.py?hl=en&answer=1012281
The interface is nice for geocoding, though, because it has some nice
features for adjusting the geocoding location on the fly. I have about 100
pages of addresses to check, but I am really only checking one or two per
street name, since not finding a street seems to be the biggest problem for
Google.
When geocoding fails, it tends to assign a location to the centroid of the
postal code in the address. It would be nice to be able to see these cases
and fix them, but I can't figure out how to do this through the interface
(if anyone knows, please let me know). i am going to look into the API.
The only way I can think to do it would be to export the KML file (Postgis,
etc), search for addresses that start with a postal code, and create a new
file of bad addresses to upload back to Fusion to fix them by hand.
Cheers,
JP
On Sun, Feb 6, 2011 at 12:35 AM, JP Glutting <jpglutting at gmail.com> wrote:
> HJ,
> Is it the "partial_match" field in the results? If so, I am not sure if
> that helps much. for example, these two addresses return
> "partial_match":True
> CARRERO DE LES CAROLINES, 25, 08012, Spain
> which returns the formatted address
> Carreró de les Carolines, 25, 08012 Barcelona, Spain
> and
> TURO DE LA PEIRA, 31, 08031 Barcelona, Spain
> returns
> Turó de la Peira, Passeig de Fabra i Puig, 396, 08031 Barcelona, Spain
> While the former is probably fine, the latter is probably not.
> Oh well, I'm just going to keep working on cleaning the addresses and
> formatting the fields better. Running queries from the python prompt make it
> clear that little things make a huge difference. A few stray letters at the
> start of an address can send google off into a whole different city.
> Cheers,
> JP
> On Sat, Feb 5, 2011 at 10:53 PM, JP Glutting <jpglutting at gmail.com> wrote:
>> Hi HJ,
>> That is the part I missed when I read the Google geocoding API. I don't
>> see it on the geocoding API page [
>> http://code.google.com/apis/maps/documentation/geocoding/]. Am I looking
>> in the wrong place?
>> Actually, now that I re-read it, it says that you can only use Google
>> Geocoding with a Google map:
>>  Usage Limits
>> Use of the Google Geocoding API is subject to a query limit of 2,500
>> geolocation requests per day. (User of Google Maps API Premier may perform
>> up to 100,000 requests per day.) This limit is enforced to prevent abuse
>> and/or repurposing of the Geocoding API, and this limit may be changed in
>> the future without notice. Additionally, we enforce a request rate limit to
>> prevent abuse of the service. If you exceed the 24-hour limit or otherwise
>> abuse the service, the Geocoding API may stop working for you temporarily.
>> If you continue to exceed this limit, your access to the Geocoding API may
>> be blocked.
>> *Note: the Geocoding API may only be used in conjunction with a Google
>> map; geocoding results without displaying them on a map is prohibited. For
>> complete details on allowed usage, consult the Maps API Terms of Service
>> License Restrictions<http://code.google.com/apis/maps/terms.html#section_10_12>
>> Whoops!
>> Would you mind sending me the code you are using? I was using geopy to
>> avoid having to spend time writing or learning about a JSON parser, but the
>> example on the google page works for me. Is the geocoding quality part of
>> the JSON results object? I don't see it.
>> Cheers,
>> JP
>> On Sat, Feb 5, 2011 at 9:11 PM, Stark Hans-Jörg <hansjoerg.stark at fhnw.ch>wrote:
>>> the mapping APIs provide indormation on the geocoding quality - this will
>>> help you use only addresses with good geocoding quality.
>>> --hj
>>> Am 05.02.2011 um 20:26 schrieb "JP Glutting" <jpglutting at gmail.com>:
>>> Hi Hans-Jörg,
>>> That is a good point about the dataset. I am not sure how good it is in
>>> Spain. I might try comparing Yahoo and Google (or at least it should be
>>> possible to use my data for that), but I don't really have a "gold standard"
>>> to compare them too.
>>> For my project, the accuracy of the locations are not as important for
>>> interpolation (which would be based on 2-3 weather stations around
>>> Barcelona, at best), but I also want to use satellite thermal IR images to
>>> take a look at the temperature as well. Landsat 7 has a 60m resolution, but
>>> there are methods for getting that down to 10m, and it could be very
>>> important. My thesis advisor hasn't approved the TIR part of the project (he
>>> might think it is too much), but I think I can do it. There are several
>>> similar studies published, so the methods are not a mystery.
>>> I have enough addresses that I would be happy discarding the ones that
>>> are erroneous and not trying to fix them all, but I am not sure how to
>>> figure out which ones are poorly geolocated. Right now I know there are a
>>> number that are bad, because the Fusion map shows them all over Spain, not
>>> in Barcelona itself, but the accuracy of the points within the city itself
>>> is a mystery. I might try to check on a sample, but I am afraid of what I
>>> might find.
>>> Cheers,
>>> JP
>>> Public Health - GIS - Bioinformatics
>>> <http://www.bmeisis.com/>http://www.bmeisis.com
>>>  <http://www.bmeisis.com/> <http://www.jpglutting.com>
>>> On Sat, Feb 5, 2011 at 8:00 PM, Stark Hans-Jörg <<hansjoerg.stark at fhnw.ch>
>>> hansjoerg.stark at fhnw.ch> wrote:
>>>> mind you: Google licensed a high-quality dataset in Switzerland - in
>>>> other words: I doubt that GM provides as good spatial accuracy in other
>>>> countries per se.
>>>> I'll checkmout the mentioned table (have currently no access). Your task
>>>> sounds interesting - I would like to read your thesis / follow your work.
>>>> But we could also continue on this via personal mail and not this list.
>>>> cheers, hj
>>>> Am 05.02.2011 um 18:28 schrieb "JP Glutting" < <jpglutting at gmail.com>
>>>> Brilliant! I will take a closer look at the PDF after I finish some
>>>> things I need to take care of. The python code would be nice, but the truth
>>>> is that this geocoding is a small part of the project (it is my UNIGIS
>>>> Master's thesis as well :-), and if I can get decent geocoding through
>>>> Google, then I would prefer not to get too caught up in that. I am looking
>>>> at heat and mortality in Barcelona, and I need to generate a lot of
>>>> interpolated temperature maps, so I would like to spend more time on that.
>>>> From the images in the paper (figure 35) it looks like Google is better
>>>> at locating the position of the address, but then in Table 12 it shows that
>>>> Google's positional accuracy was slightly worse than Bing's. Do you know why
>>>> that is?
>>>> I'm geocoding addresses of people who died, so positional accuracy is
>>>> important with regard to heat exposure. Which would you recommend?
>>>> Actually, after reading some of that, maybe I should take a look at your
>>>> code. It looks like I am going to need to do more to make sure these are
>>>> correct. The difficult thing is that the addresses I have are abbreviated
>>>> (like "CL/ LLEO, 12" which is really "Carrer del Lleó 12"), so it will be
>>>> hard to check accuracy automatically.
>>>> i am definitely citing your paper.
>>>> Cheers,
>>>> JP
>>>> On Sat, Feb 5, 2011 at 5:53 PM, Stark Hans-Jörg <<hansjoerg.stark at fhnw.ch><hansjoerg.stark at fhnw.ch>
>>>>> Hi JP
>>>>> Hope this helps: http://www.unigis.ac.at/club/bibliothek/pdf/40138.pdf
>>>>> In OA we are currently running a test-phase where we check all
>>>>> user-digitised addresses versus open Geocoding engines like Bing, Google and
>>>>> Yahoo. The comparison results shall then be an indicator of the quality of
>>>>> the user entered address. Cf. http://geolin01.cti.ac.at/openaddresses/(to digitise) and
>>>>> http://geolin01.cti.ac.at/openaddresses/qa/qareport to get the report
>>>>> (and http://code.google.com/p/openaddresses/wiki/qa for a
>>>>> description).
>>>>> I run the yahoo geocoding in python. If you want to see the code I
>>>>> could provide it (it is not yet in the wiki) and perhaps you can take parts
>>>>> of it for your purpose to avoid starting from scratch.
>>>>> Best,
>>>>> hj
>>>>> *Von:* <discuss-bounces at lists.osgeo.org><discuss-bounces at lists.osgeo.org>
>>>>> discuss-bounces at lists.osgeo.org [mailto:<discuss-bounces at lists.osgeo.org><discuss-bounces at lists.osgeo.org>
>>>>> discuss-bounces at lists.osgeo.org] *Im Auftrag von *JP Glutting
>>>>> *Gesendet:* Samstag, 5. Februar 2011 17:42
>>>>> *An:* OSGeo Discussions
>>>>> *Betreff:* Re: [OSGeo-Discuss] Batch geocoding
>>>>> Hi HJ,
>>>>> Yes, thanks, it is relevant. I was going to go looking for a reference
>>>>> just like that. It looks excellent. Is there a PDF available? From the
>>>>> image, it looks like Google is much better, but I can't read the table
>>>>> online (and I don't seem to get GeoInformatics in the mail anymore, not sure
>>>>> why).
>>>>> At this point, I am not sure I have much choice in the matter. I can
>>>>> geocode the addresses in Google using fusion tables, but Yahoo seems to
>>>>> start returning errors after a few thousand lookups per day via geopy.
>>>>> After spending some time fixing geocoding errors in fusion tables, I
>>>>> think I am going to go back and edit the addresses in the source table and
>>>>> re-export them to Fusion. It is putting addresses like "CL/ LLEO, 12,
>>>>> Barcelona, Spain" in León. Adjusting that to "Carrer del Lleó, 12,
>>>>> Barcelona, Spain" does a much better job, so I am going to go back and make
>>>>> abbreviations like "CL/", "PA/", "RBLA", etc. explicit and try the geocoding
>>>>> again. On the whole, it did a very good job, but there are a lot of
>>>>> addresses that I need to fix. It would probably work better if I could
>>>>> specify fields for City and Country (some of the addresses were encoded in
>>>>> Bermuda, despite all having "Barcelona, Spain" appended to them).
>>>>> Cheers,
>>>>> JP
>>>>> On Sat, Feb 5, 2011 at 4:54 PM, Stark Hans-Jörg <<hansjoerg.stark at fhnw.ch><hansjoerg.stark at fhnw.ch>
>>>>> BTW: the geocoding engines of Yahoo and Google provide different
>>>>> spatial accuracy (cf.
>>>>> http://www.geoinformatics.com/blog/in-the-spotlight/quality-assessment-of-volunteered-geographic-information-vgi)
>>>>> But I do not know whether that is relevant for your task.
>>>>> Cheers,
>>>>> hj
>>>>> *Gesendet:* Samstag, 5. Februar 2011 16:37
>>>>> For anyone who is considering using Fusion Tables, it has a very nice
>>>>> feature that allows you to select a point that has been badly geocoded, and
>>>>> find the right location searching in a small pop-up map, and then select
>>>>> from a set of alternate locations. Your choice modifies the coordinates of
>>>>> the geocoding, but not the address itself. A very nice and quite easy way to
>>>>> fix problems.
>>>>> Cheers,
>>>>> JP
>>>>> On Sat, Feb 5, 2011 at 12:37 AM, JP Glutting < <jpglutting at gmail.com><jpglutting at gmail.com>
>>>>> It is pretty slick, but I just started using it about an hour ago, so I
>>>>> haven't thought much about what to do with it. I did see a comment where
>>>>> someone from Google said that reverse geocoding is not possible yet.
>>>>> I am going to have to get up to speed with PostGIS, but this is a
>>>>> pretty simple operation. I didn't number the addresses, but each event has a
>>>>> real address and a "cleaned" address column in a table. The CSV that I
>>>>> uploaded to Fusion was just a "select distinct..." of the cleaned addresses,
>>>>> so it will serve as a lookup table for all the addresses in the original
>>>>> table. I'm not sure how I am going to reorganize the tables afterward, but I
>>>>> want to interpolate temperatures for each data point based on other data
>>>>> that I have, and I think PostGIS only does simpler operations right now, so
>>>>> I might  have to export the points into shapefiles for each day an event
>>>>> occurs and do splines in another package, then copy the interpolated values
>>>>> back into the database. I am sure there is a more elegant way to do that, I
>>>>> really need to think about it some more.
>>>>> (Oh, hey, I just saw that you can compile R into Postgres. That is
>>>>> pretty crazy, but potentially totally awesome: <http://postgis.refractions.net/pipermail/postgis-users/2009-March/022894.html><http://postgis.refractions.net/pipermail/postgis-users/2009-March/022894.html>
>>>>> Cheers,
>>>>> JP
>>>>> On Sat, Feb 5, 2011 at 12:17 AM, Dan Putler <<dan.putler at sauder.ubc.ca><dan.putler at sauder.ubc.ca>
>>>>> dan.putler at sauder.ubc.ca> wrote:
>>>>> Glad to be of help, I'm just curious about what the licensing / terms
>>>>> of use on the KML files that come out of fusion tables. Plus I want to know
>>>>> if it will reverse geocode. It is very slick, but I can imagine violating
>>>>> the terms of use almost instantly.
>>>>> In terms of your next problem (which seems like one for the PostGIS
>>>>> user list), did you create a unique address ID? if you did, can't you put it
>>>>> in the data you created the fusion table from and then just do the
>>>>> appropriate table join in Postgres/PostGIS?
>>>>> Dan
>>>>> On 02/04/2011 03:08 PM, JP Glutting wrote:
>>>>> That is a nice trick, I will remember that. I really just need the
>>>>> coordinates, since each coordinate needs to go back into a database in a
>>>>> register of a location-time that needs more data added later. These are the
>>>>> "generic" addresses, with the apartment numbers stripped, so each address
>>>>> will provide coordinates for multiples DB entries on different dates, and I
>>>>> won't really be using them on the same layer. But I am sure I can figure out
>>>>> a way to get the data back out with PostGIS (the original data is in
>>>>> Postgres anyway).
>>>>> Cheers,
>>>>> JP
>>>>> On Fri, Feb 4, 2011 at 11:59 PM, Dan Putler <<dan.putler at sauder.ubc.ca><dan.putler at sauder.ubc.ca>
>>>>> dan.putler at sauder.ubc.ca <mailto: <dan.putler at sauder.ubc.ca><dan.putler at sauder.ubc.ca>
>>>>> dan.putler at sauder.ubc.ca>> wrote:
>>>>>    JP,
>>>>>    If you export the KML, and then feed it into QGIS you can then
>>>>>    save the resulting layer as a shapefile, which is probably what
>>>>>    you are really hoping to have since you can then easily feed it to
>>>>>    R, PostGIS, or a number of other tools to pull the coordinates.
>>>>>    Dan
>>>>>    On 02/04/2011 02:20 PM, JP Glutting wrote:
>>>>>        Hi Bernie,
>>>>>        You can't actually get the lat-lng back out of a Fusion table.
>>>>>        It will geocode all the addresses, but you can't get the
>>>>>        numbers back, you can just make a map or layer or something.
>>>>>        <http://groups.google.com/group/fusion-tables-users-group/browse_thread/thread/91c43c73107164eb><http://groups.google.com/group/fusion-tables-users-group/browse_thread/thread/91c43c73107164eb>
>>>>>        Unless I export it to KML and pull it back out of there?
>>>>>        That seems like a lot of work. But it sure geocodes like
>>>>>        gangbusters.
>>>>>        Cheers,
>>>>>        JP
>>>>>         <http://www.bmeisis.com> <http://www.bmeisis.com>
>>>>> http://www.bmeisis.com < <http://www.bmeisis.com/><http://www.bmeisis.com/>
>>>>>         <http://www.jpglutting.com> <http://www.jpglutting.com>
>>>>>        On Fri, Feb 4, 2011 at 7:42 PM, Connors, Bernie (SNB)
>>>>>        < <Bernie.Connors at snb.ca> <Bernie.Connors at snb.ca>
>>>>> Bernie.Connors at snb.ca <mailto: <Bernie.Connors at snb.ca><Bernie.Connors at snb.ca>
>>>>>        <mailto: <Bernie.Connors at snb.ca> <Bernie.Connors at snb.ca>
>>>>> Bernie.Connors at snb.ca>>>
>>>>>        wrote:
>>>>>           Try Google Fusion Tables.  All you have to do is put all of
>>>>> the
>>>>>           address components in one field and it should be recognized
>>>>> and
>>>>>           geocoded.
>>>>>           *Bernie Connors, P.Eng*
>>>>>           Service New Brunswick
>>>>>           (506) 444-2077
>>>>>           45°56'25.21"N, 66°38'53.65"W
>>>>>         <http://www.snb.ca/geonb/> <http://www.snb.ca/geonb/>
>>>>> www.snb.ca/geonb/ < <http://www.snb.ca/geonb/><http://www.snb.ca/geonb/>
>>>>>        < <http://www.snb.ca/geonb/> <http://www.snb.ca/geonb/>
>>>>>           *From:* <discuss-bounces at lists.osgeo.org><discuss-bounces at lists.osgeo.org>
>>>>>        <mailto: <discuss-bounces at lists.osgeo.org><discuss-bounces at lists.osgeo.org>
>>>>> discuss-bounces at lists.osgeo.org>>
>>>>>           [mailto: <discuss-bounces at lists.osgeo.org><discuss-bounces at lists.osgeo.org>
>>>>> discuss-bounces at lists.osgeo.org>>] *On Behalf Of *JP
>>>>>        Glutting
>>>>>           *Sent:* Friday, 2011-02-04 09:34
>>>>>           *To:* <discuss at lists.osgeo.org> <discuss at lists.osgeo.org>
>>>>>        <mailto: <discuss at lists.osgeo.org> <discuss at lists.osgeo.org>
>>>>> discuss at lists.osgeo.org <mailto: <discuss at lists.osgeo.org><discuss at lists.osgeo.org>
>>>>> discuss at lists.osgeo.org>>
>>>>>           *Subject:* [OSGeo-Discuss] Batch geocoding
>>>>>           Hello,
>>>>>           I have a large set of addresses (around 150k) that I need to
>>>>>           geocode for a study (my Masters thesis on heat-related
>>>>>        mortality).
>>>>>           I am looking into different solutions, but I can't find
>>>>>        anything
>>>>>           that seems like it would work properly.
>>>>>           I could script a solution using Google's map API, but there
>>>>>        is a
>>>>>           limit of 2,500 addreses per day (I can get around them with a
>>>>>           little patience).
>>>>>           Right now the best solution I am looking at geopy for
>>>>> geocoding
>>>>>           addresses ( <http://code.google.com/p/geopy/><http://code.google.com/p/geopy/>
>>>>> http://code.google.com/p/geopy/). It seems like
>>>>>        a good
>>>>>           system, I think I can use it to pull addresses out of my
>>>>>        database
>>>>>           and write back coordinates. There is one thing that I am
>>>>>        not sure,
>>>>>           about, though, is whether I am actually allowed to use the
>>>>>        Google
>>>>>           API without my use being liked to a specific web page. The
>>>>>        terms
>>>>>           of service and form for getting a Google API key require a
>>>>> URL
>>>>>           linked to a Google account. In fact, it looks like the API
>>>>> can
>>>>>           only be used through a web site:
>>>>>               "5.2 _Account Key_. After supplying Google with your
>>>>>        account
>>>>>               information and the URL of your Maps API
>>>>>        Implementation, and
>>>>>               accepting the Terms, you will be issued an alphanumeric
>>>>> key
>>>>>               assigned to you by Google that is uniquely associated
>>>>> with
>>>>>               your Google Account and the URL of your Maps API
>>>>>               Implementation. Your Maps API Implementation must
>>>>>        import the
>>>>>               Google Maps APIs using this key as described in the
>>>>>        Maps APIs
>>>>>               Documentation
>>>>>        < <http://code.google.com/apis/maps/documentation/><http://code.google.com/apis/maps/documentation/>
>>>>> http://code.google.com/apis/maps/documentation/>, and Google
>>>>>               will block requests with an invalid key or invalid URL.
>>>>> You
>>>>>               may only obtain and use a key in accordance with these
>>>>>        Terms
>>>>>               and the Maps APIs Documentation
>>>>> http://code.google.com/apis/maps/documentation/>."
>>>>>           So it looks like I can't even get it to work without a URL.
>>>>>           I can always write a script that loops through results
>>>>>        extracted
>>>>>           from the database, creates URLs and parses the XML results
>>>>>        one at
>>>>>           a time, but that seems like a fairly inelegant solution.
>>>>>           Does anyone have any good ideas about how to geocode a few
>>>>>           thousand addresses?
>>>>>           Many thanks,
>>>>>           JP
>>>>>           _______________________________________________
>>>>>           Discuss mailing list
>>>>>         <Discuss at lists.osgeo.org> <Discuss at lists.osgeo.org>
>>>>> Discuss at lists.osgeo.org <mailto: <Discuss at lists.osgeo.org><Discuss at lists.osgeo.org>
>>>>>        <mailto: <Discuss at lists.osgeo.org> <Discuss at lists.osgeo.org>
>>>>> Discuss at lists.osgeo.org>>
>>>>>         <http://lists.osgeo.org/mailman/listinfo/discuss><http://lists.osgeo.org/mailman/listinfo/discuss>
>>>> <ATT00001..c>
>>>>  <Discuss at lists.osgeo.org>Discuss at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/discuss/attachments/20110206/60e66f01/attachment-0002.html>
More information about the Discuss mailing list
