[OSGeo-Discuss] Batch geocoding
JP Glutting jpglutting at gmail.com
Mon Feb 7 14:05:30 PST 2011
Thanks Wladimir. I will probably call them up and see if they will let me
explain my project to them.
I'm not even sure it would be a better option, though. Frankly, how good is
their geocoder? I have slimmed my dataset down to 50,000 addresses, but they
are written in a sort of shorthand ("CARRER GV CORTS CATALANES, 56, 08000
España") which is giving even Google fits - that one coded in Bermuda.
Several show up in Las Canarias and Andalucia.
I am spending a lot of time cleaning up and formatting the addresses, but I
am not convinced their geocoder can handle the volume or the format (I have
my doubts about the Google results).
I read that thread on Geoinquiets - very interesting. Frankly, it doesn't
surprise me all that much, but it is a shame. Maybe I will add something,
but it seemed to get very wrapped up in the server configuration, and I
don't have a lot to say about that.
Cheers,
JP
On Mon, Feb 7, 2011 at 9:34 AM, Wladimir Szczerban <bolosig at gmail.com>wrote:
> Hi JP,
> I work in the IDEC (Spatial Data Infrastructure of Catalonia).
> You can contact the ICC (www.icc.cat) and explain that you need to codify
> some directions for a thesis. Maybe give you some access to their geocoder,
> though they are quite closed to that topic.
> In the list of geoinquiets was treated this subject in a post titled "la
> importancia de les dades obertes" of January 21, 2011. See the thread that you
> might get something that works for you.
> Cheers,
> 2011/2/6 JP Glutting <jpglutting at gmail.com>
> FYI: Fusion Tables does not provide access to unlimited geocoding. There is
>> a daily limit (not sure what it is, but I assume it is the same as the API)
>> http://www.google.com/support/fusiontables/bin/answer.py?hl=en&answer=1012281
>> The interface is nice for geocoding, though, because it has some nice
>> features for adjusting the geocoding location on the fly. I have about 100
>> pages of addresses to check, but I am really only checking one or two per
>> street name, since not finding a street seems to be the biggest problem for
>> Google.
>> When geocoding fails, it tends to assign a location to the centroid of the
>> postal code in the address. It would be nice to be able to see these cases
>> and fix them, but I can't figure out how to do this through the interface
>> (if anyone knows, please let me know). i am going to look into the API.
>> The only way I can think to do it would be to export the KML file
>> (Postgis, etc), search for addresses that start with a postal code, and
>> create a new file of bad addresses to upload back to Fusion to fix them by
>> hand.
>> Cheers,
>> JP
>> On Sun, Feb 6, 2011 at 12:35 AM, JP Glutting <jpglutting at gmail.com>wrote:
>>> HJ,
>>> Is it the "partial_match" field in the results? If so, I am not sure if
>>> that helps much. for example, these two addresses return
>>> "partial_match":True
>>> CARRERO DE LES CAROLINES, 25, 08012, Spain
>>> which returns the formatted address
>>> Carreró de les Carolines, 25, 08012 Barcelona, Spain
>>> and
>>> TURO DE LA PEIRA, 31, 08031 Barcelona, Spain
>>> returns
>>> Turó de la Peira, Passeig de Fabra i Puig, 396, 08031 Barcelona, Spain
>>> While the former is probably fine, the latter is probably not.
>>> Oh well, I'm just going to keep working on cleaning the addresses and
>>> formatting the fields better. Running queries from the python prompt make it
>>> clear that little things make a huge difference. A few stray letters at the
>>> start of an address can send google off into a whole different city.
>>> Cheers,
>>> JP
>>> On Sat, Feb 5, 2011 at 10:53 PM, JP Glutting <jpglutting at gmail.com>wrote:
>>>> Hi HJ,
>>>> That is the part I missed when I read the Google geocoding API. I don't
>>>> see it on the geocoding API page [
>>>> http://code.google.com/apis/maps/documentation/geocoding/]. Am I
>>>> looking in the wrong place?
>>>> Actually, now that I re-read it, it says that you can only use Google
>>>> Geocoding with a Google map:
>>>>  Usage Limits
>>>> Use of the Google Geocoding API is subject to a query limit of 2,500
>>>> geolocation requests per day. (User of Google Maps API Premier may perform
>>>> up to 100,000 requests per day.) This limit is enforced to prevent abuse
>>>> and/or repurposing of the Geocoding API, and this limit may be changed in
>>>> the future without notice. Additionally, we enforce a request rate limit to
>>>> prevent abuse of the service. If you exceed the 24-hour limit or otherwise
>>>> abuse the service, the Geocoding API may stop working for you temporarily.
>>>> If you continue to exceed this limit, your access to the Geocoding API may
>>>> be blocked.
>>>> *Note: the Geocoding API may only be used in conjunction with a Google
>>>> map; geocoding results without displaying them on a map is prohibited. For
>>>> complete details on allowed usage, consult the Maps API Terms of
>>>> Service License Restrictions<http://code.google.com/apis/maps/terms.html#section_10_12>
>>>> Whoops!
>>>> Would you mind sending me the code you are using? I was using geopy to
>>>> avoid having to spend time writing or learning about a JSON parser, but the
>>>> example on the google page works for me. Is the geocoding quality part of
>>>> the JSON results object? I don't see it.
>>>> Cheers,
>>>> JP
>>>> On Sat, Feb 5, 2011 at 9:11 PM, Stark Hans-Jörg <
>>>> hansjoerg.stark at fhnw.ch> wrote:
>>>>> the mapping APIs provide indormation on the geocoding quality - this
>>>>> will help you use only addresses with good geocoding quality.
>>>>> --hj
>>>>> Am 05.02.2011 um 20:26 schrieb "JP Glutting" <jpglutting at gmail.com>:
>>>>> Hi Hans-Jörg,
>>>>> That is a good point about the dataset. I am not sure how good it is in
>>>>> Spain. I might try comparing Yahoo and Google (or at least it should be
>>>>> possible to use my data for that), but I don't really have a "gold standard"
>>>>> to compare them too.
>>>>> For my project, the accuracy of the locations are not as important for
>>>>> interpolation (which would be based on 2-3 weather stations around
>>>>> Barcelona, at best), but I also want to use satellite thermal IR images to
>>>>> take a look at the temperature as well. Landsat 7 has a 60m resolution, but
>>>>> there are methods for getting that down to 10m, and it could be very
>>>>> important. My thesis advisor hasn't approved the TIR part of the project (he
>>>>> might think it is too much), but I think I can do it. There are several
>>>>> similar studies published, so the methods are not a mystery.
>>>>> I have enough addresses that I would be happy discarding the ones that
>>>>> are erroneous and not trying to fix them all, but I am not sure how to
>>>>> figure out which ones are poorly geolocated. Right now I know there are a
>>>>> number that are bad, because the Fusion map shows them all over Spain, not
>>>>> in Barcelona itself, but the accuracy of the points within the city itself
>>>>> is a mystery. I might try to check on a sample, but I am afraid of what I
>>>>> might find.
>>>>> Cheers,
>>>>> JP
>>>>> Public Health - GIS - Bioinformatics
>>>>> <http://www.bmeisis.com/>http://www.bmeisis.com
>>>>>  <http://www.bmeisis.com/> <http://www.jpglutting.com>
>>>>> On Sat, Feb 5, 2011 at 8:00 PM, Stark Hans-Jörg <<hansjoerg.stark at fhnw.ch>
>>>>>> mind you: Google licensed a high-quality dataset in Switzerland - in
>>>>>> other words: I doubt that GM provides as good spatial accuracy in other
>>>>>> countries per se.
>>>>>> I'll checkmout the mentioned table (have currently no access). Your
>>>>>> task sounds interesting - I would like to read your thesis / follow your
>>>>>> work. But we could also continue on this via personal mail and not this
>>>>>> list.
>>>>>> cheers, hj
>>>>>> Am 05.02.2011 um 18:28 schrieb "JP Glutting" < <jpglutting at gmail.com>
>>>>>> Brilliant! I will take a closer look at the PDF after I finish some
>>>>>> things I need to take care of. The python code would be nice, but the truth
>>>>>> is that this geocoding is a small part of the project (it is my UNIGIS
>>>>>> Master's thesis as well :-), and if I can get decent geocoding through
>>>>>> Google, then I would prefer not to get too caught up in that. I am looking
>>>>>> at heat and mortality in Barcelona, and I need to generate a lot of
>>>>>> interpolated temperature maps, so I would like to spend more time on that.
>>>>>> From the images in the paper (figure 35) it looks like Google is
>>>>>> better at locating the position of the address, but then in Table 12 it
>>>>>> shows that Google's positional accuracy was slightly worse than Bing's. Do
>>>>>> you know why that is?
>>>>>> I'm geocoding addresses of people who died, so positional accuracy is
>>>>>> important with regard to heat exposure. Which would you recommend?
>>>>>> Actually, after reading some of that, maybe I should take a look at
>>>>>> your code. It looks like I am going to need to do more to make sure these
>>>>>> are correct. The difficult thing is that the addresses I have are
>>>>>> abbreviated (like "CL/ LLEO, 12" which is really "Carrer del Lleó 12"), so
>>>>>> it will be hard to check accuracy automatically.
>>>>>> i am definitely citing your paper.
>>>>>> Cheers,
>>>>>> JP
>>>>>> On Sat, Feb 5, 2011 at 5:53 PM, Stark Hans-Jörg <<hansjoerg.stark at fhnw.ch><hansjoerg.stark at fhnw.ch>
>>>>>>> Hi JP
>>>>>>> Hope this helps:
>>>>>>> http://www.unigis.ac.at/club/bibliothek/pdf/40138.pdf
>>>>>>> In OA we are currently running a test-phase where we check all
>>>>>>> user-digitised addresses versus open Geocoding engines like Bing, Google and
>>>>>>> Yahoo. The comparison results shall then be an indicator of the quality of
>>>>>>> the user entered address. Cf.
>>>>>>> http://geolin01.cti.ac.at/openaddresses/ (to digitise) and
>>>>>>> http://geolin01.cti.ac.at/openaddresses/qa/qareport to get the
>>>>>>> report (and http://code.google.com/p/openaddresses/wiki/qa for a
>>>>>>> description).
>>>>>>> I run the yahoo geocoding in python. If you want to see the code I
>>>>>>> could provide it (it is not yet in the wiki) and perhaps you can take parts
>>>>>>> of it for your purpose to avoid starting from scratch.
>>>>>>> Best,
>>>>>>> hj
>>>>>>> *Von:* <discuss-bounces at lists.osgeo.org><discuss-bounces at lists.osgeo.org>
>>>>>>> discuss-bounces at lists.osgeo.org [mailto:<discuss-bounces at lists.osgeo.org><discuss-bounces at lists.osgeo.org>
>>>>>>> discuss-bounces at lists.osgeo.org] *Im Auftrag von *JP Glutting
>>>>>>> *Gesendet:* Samstag, 5. Februar 2011 17:42
>>>>>>> *An:* OSGeo Discussions
>>>>>>> *Betreff:* Re: [OSGeo-Discuss] Batch geocoding
>>>>>>> Hi HJ,
>>>>>>> Yes, thanks, it is relevant. I was going to go looking for a
>>>>>>> reference just like that. It looks excellent. Is there a PDF available? From
>>>>>>> the image, it looks like Google is much better, but I can't read the table
>>>>>>> online (and I don't seem to get GeoInformatics in the mail anymore, not sure
>>>>>>> why).
>>>>>>> At this point, I am not sure I have much choice in the matter. I can
>>>>>>> geocode the addresses in Google using fusion tables, but Yahoo seems to
>>>>>>> start returning errors after a few thousand lookups per day via geopy.
>>>>>>> After spending some time fixing geocoding errors in fusion tables, I
>>>>>>> think I am going to go back and edit the addresses in the source table and
>>>>>>> re-export them to Fusion. It is putting addresses like "CL/ LLEO, 12,
>>>>>>> Barcelona, Spain" in León. Adjusting that to "Carrer del Lleó, 12,
>>>>>>> Barcelona, Spain" does a much better job, so I am going to go back and make
>>>>>>> abbreviations like "CL/", "PA/", "RBLA", etc. explicit and try the geocoding
>>>>>>> again. On the whole, it did a very good job, but there are a lot of
>>>>>>> addresses that I need to fix. It would probably work better if I could
>>>>>>> specify fields for City and Country (some of the addresses were encoded in
>>>>>>> Bermuda, despite all having "Barcelona, Spain" appended to them).
>>>>>>> Cheers,
>>>>>>> JP
>>>>>>> On Sat, Feb 5, 2011 at 4:54 PM, Stark Hans-Jörg <<hansjoerg.stark at fhnw.ch><hansjoerg.stark at fhnw.ch>
>>>>>>> BTW: the geocoding engines of Yahoo and Google provide different
>>>>>>> spatial accuracy (cf.
>>>>>>> http://www.geoinformatics.com/blog/in-the-spotlight/quality-assessment-of-volunteered-geographic-information-vgi)
>>>>>>> But I do not know whether that is relevant for your task.
>>>>>>> Cheers,
>>>>>>> hj
>>>>>>> *Gesendet:* Samstag, 5. Februar 2011 16:37
>>>>>>> For anyone who is considering using Fusion Tables, it has a very nice
>>>>>>> feature that allows you to select a point that has been badly geocoded, and
>>>>>>> find the right location searching in a small pop-up map, and then select
>>>>>>> from a set of alternate locations. Your choice modifies the coordinates of
>>>>>>> the geocoding, but not the address itself. A very nice and quite easy way to
>>>>>>> fix problems.
>>>>>>> Cheers,
>>>>>>> JP
>>>>>>> On Sat, Feb 5, 2011 at 12:37 AM, JP Glutting <<jpglutting at gmail.com><jpglutting at gmail.com>
>>>>>>> jpglutting at gmail.com> wrote:
>>>>>>> It is pretty slick, but I just started using it about an hour ago, so
>>>>>>> I haven't thought much about what to do with it. I did see a comment where
>>>>>>> someone from Google said that reverse geocoding is not possible yet.
>>>>>>> I am going to have to get up to speed with PostGIS, but this is a
>>>>>>> pretty simple operation. I didn't number the addresses, but each event has a
>>>>>>> real address and a "cleaned" address column in a table. The CSV that I
>>>>>>> uploaded to Fusion was just a "select distinct..." of the cleaned addresses,
>>>>>>> so it will serve as a lookup table for all the addresses in the original
>>>>>>> table. I'm not sure how I am going to reorganize the tables afterward, but I
>>>>>>> want to interpolate temperatures for each data point based on other data
>>>>>>> that I have, and I think PostGIS only does simpler operations right now, so
>>>>>>> I might  have to export the points into shapefiles for each day an event
>>>>>>> occurs and do splines in another package, then copy the interpolated values
>>>>>>> back into the database. I am sure there is a more elegant way to do that, I
>>>>>>> really need to think about it some more.
>>>>>>> (Oh, hey, I just saw that you can compile R into Postgres. That is
>>>>>>> pretty crazy, but potentially totally awesome: <http://postgis.refractions.net/pipermail/postgis-users/2009-March/022894.html><http://postgis.refractions.net/pipermail/postgis-users/2009-March/022894.html>
>>>>>>> Cheers,
>>>>>>> JP
>>>>>>> On Sat, Feb 5, 2011 at 12:17 AM, Dan Putler <<dan.putler at sauder.ubc.ca><dan.putler at sauder.ubc.ca>
>>>>>>> dan.putler at sauder.ubc.ca> wrote:
>>>>>>> Glad to be of help, I'm just curious about what the licensing / terms
>>>>>>> of use on the KML files that come out of fusion tables. Plus I want to know
>>>>>>> if it will reverse geocode. It is very slick, but I can imagine violating
>>>>>>> the terms of use almost instantly.
>>>>>>> In terms of your next problem (which seems like one for the PostGIS
>>>>>>> user list), did you create a unique address ID? if you did, can't you put it
>>>>>>> in the data you created the fusion table from and then just do the
>>>>>>> appropriate table join in Postgres/PostGIS?
>>>>>>> Dan
>>>>>>> On 02/04/2011 03:08 PM, JP Glutting wrote:
>>>>>>> That is a nice trick, I will remember that. I really just need the
>>>>>>> coordinates, since each coordinate needs to go back into a database in a
>>>>>>> register of a location-time that needs more data added later. These are the
>>>>>>> "generic" addresses, with the apartment numbers stripped, so each address
>>>>>>> will provide coordinates for multiples DB entries on different dates, and I
>>>>>>> won't really be using them on the same layer. But I am sure I can figure out
>>>>>>> a way to get the data back out with PostGIS (the original data is in
>>>>>>> Postgres anyway).
>>>>>>> Cheers,
>>>>>>> JP
>>>>>>> On Fri, Feb 4, 2011 at 11:59 PM, Dan Putler <<dan.putler at sauder.ubc.ca><dan.putler at sauder.ubc.ca>
>>>>>>> dan.putler at sauder.ubc.ca <mailto: <dan.putler at sauder.ubc.ca><dan.putler at sauder.ubc.ca>
>>>>>>> dan.putler at sauder.ubc.ca>> wrote:
>>>>>>>    JP,
>>>>>>>    If you export the KML, and then feed it into QGIS you can then
>>>>>>>    save the resulting layer as a shapefile, which is probably what
>>>>>>>    you are really hoping to have since you can then easily feed it to
>>>>>>>    R, PostGIS, or a number of other tools to pull the coordinates.
>>>>>>>    Dan
>>>>>>>    On 02/04/2011 02:20 PM, JP Glutting wrote:
>>>>>>>        Hi Bernie,
>>>>>>>        You can't actually get the lat-lng back out of a Fusion table.
>>>>>>>        It will geocode all the addresses, but you can't get the
>>>>>>>        numbers back, you can just make a map or layer or something.
>>>>>>>        <http://groups.google.com/group/fusion-tables-users-group/browse_thread/thread/91c43c73107164eb><http://groups.google.com/group/fusion-tables-users-group/browse_thread/thread/91c43c73107164eb>
>>>>>>>        Unless I export it to KML and pull it back out of there?
>>>>>>>        That seems like a lot of work. But it sure geocodes like
>>>>>>>        gangbusters.
>>>>>>>        Cheers,
>>>>>>>        JP
>>>>>>>         <http://www.bmeisis.com> <http://www.bmeisis.com>
>>>>>>> http://www.bmeisis.com < <http://www.bmeisis.com/><http://www.bmeisis.com/>
>>>>>>>         <http://www.jpglutting.com> <http://www.jpglutting.com>
>>>>>>>        On Fri, Feb 4, 2011 at 7:42 PM, Connors, Bernie (SNB)
>>>>>>>        < <Bernie.Connors at snb.ca> <Bernie.Connors at snb.ca>
>>>>>>> Bernie.Connors at snb.ca <mailto: <Bernie.Connors at snb.ca><Bernie.Connors at snb.ca>
>>>>>>>        <mailto: <Bernie.Connors at snb.ca> <Bernie.Connors at snb.ca>
>>>>>>> Bernie.Connors at snb.ca>>>
>>>>>>>        wrote:
>>>>>>>           Try Google Fusion Tables.  All you have to do is put all of
>>>>>>> the
>>>>>>>           address components in one field and it should be recognized
>>>>>>> and
>>>>>>>           geocoded.
>>>>>>>           *Bernie Connors, P.Eng*
>>>>>>>           Service New Brunswick
>>>>>>>           (506) 444-2077
>>>>>>>           45°56'25.21"N, 66°38'53.65"W
>>>>>>>         <http://www.snb.ca/geonb/> <http://www.snb.ca/geonb/>
>>>>>>> www.snb.ca/geonb/ < <http://www.snb.ca/geonb/><http://www.snb.ca/geonb/>
>>>>>>>        < <http://www.snb.ca/geonb/> <http://www.snb.ca/geonb/>
>>>>>>>           *From:* <discuss-bounces at lists.osgeo.org><discuss-bounces at lists.osgeo.org>
>>>>>>>        <mailto: <discuss-bounces at lists.osgeo.org><discuss-bounces at lists.osgeo.org>
>>>>>>> discuss-bounces at lists.osgeo.org>>
>>>>>>>           [mailto: <discuss-bounces at lists.osgeo.org><discuss-bounces at lists.osgeo.org>
>>>>>>> discuss-bounces at lists.osgeo.org>>] *On Behalf Of *JP
>>>>>>>        Glutting
>>>>>>>           *Sent:* Friday, 2011-02-04 09:34
>>>>>>>           *To:* <discuss at lists.osgeo.org> <discuss at lists.osgeo.org>
>>>>>>>        <mailto: <discuss at lists.osgeo.org> <discuss at lists.osgeo.org>
>>>>>>> discuss at lists.osgeo.org <mailto: <discuss at lists.osgeo.org><discuss at lists.osgeo.org>
>>>>>>> discuss at lists.osgeo.org>>
>>>>>>>           *Subject:* [OSGeo-Discuss] Batch geocoding
>>>>>>>           Hello,
>>>>>>>           I have a large set of addresses (around 150k) that I need
>>>>>>> to
>>>>>>>           geocode for a study (my Masters thesis on heat-related
>>>>>>>        mortality).
>>>>>>>           I am looking into different solutions, but I can't find
>>>>>>>        anything
>>>>>>>           that seems like it would work properly.
>>>>>>>           I could script a solution using Google's map API, but there
>>>>>>>        is a
>>>>>>>           limit of 2,500 addreses per day (I can get around them with
>>>>>>> a
>>>>>>>           little patience).
>>>>>>>           Right now the best solution I am looking at geopy for
>>>>>>> geocoding
>>>>>>>           addresses ( <http://code.google.com/p/geopy/><http://code.google.com/p/geopy/>
>>>>>>> http://code.google.com/p/geopy/). It seems like
>>>>>>>        a good
>>>>>>>           system, I think I can use it to pull addresses out of my
>>>>>>>        database
>>>>>>>           and write back coordinates. There is one thing that I am
>>>>>>>        not sure,
>>>>>>>           about, though, is whether I am actually allowed to use the
>>>>>>>        Google
>>>>>>>           API without my use being liked to a specific web page. The
>>>>>>>        terms
>>>>>>>           of service and form for getting a Google API key require a
>>>>>>> URL
>>>>>>>           linked to a Google account. In fact, it looks like the API
>>>>>>> can
>>>>>>>           only be used through a web site:
>>>>>>>               "5.2 _Account Key_. After supplying Google with your
>>>>>>>        account
>>>>>>>               information and the URL of your Maps API
>>>>>>>        Implementation, and
>>>>>>>               accepting the Terms, you will be issued an alphanumeric
>>>>>>> key
>>>>>>>               assigned to you by Google that is uniquely associated
>>>>>>> with
>>>>>>>               your Google Account and the URL of your Maps API
>>>>>>>               Implementation. Your Maps API Implementation must
>>>>>>>        import the
>>>>>>>               Google Maps APIs using this key as described in the
>>>>>>>        Maps APIs
>>>>>>>               Documentation
>>>>>>>        < <http://code.google.com/apis/maps/documentation/><http://code.google.com/apis/maps/documentation/>
>>>>>>> http://code.google.com/apis/maps/documentation/>, and Google
>>>>>>>               will block requests with an invalid key or invalid URL.
>>>>>>> You
>>>>>>>               may only obtain and use a key in accordance with these
>>>>>>>        Terms
>>>>>>>               and the Maps APIs Documentation
>>>>>>> http://code.google.com/apis/maps/documentation/>."
>>>>>>>           So it looks like I can't even get it to work without a URL.
>>>>>>>           I can always write a script that loops through results
>>>>>>>        extracted
>>>>>>>           from the database, creates URLs and parses the XML results
>>>>>>>        one at
>>>>>>>           a time, but that seems like a fairly inelegant solution.
>>>>>>>           Does anyone have any good ideas about how to geocode a few
>>>>>>>           thousand addresses?
>>>>>>>           Many thanks,
>>>>>>>           JP
>>>>>>>           _______________________________________________
>>>>>>>           Discuss mailing list
>>>>>>>         <Discuss at lists.osgeo.org> <Discuss at lists.osgeo.org>
>>>>>>> Discuss at lists.osgeo.org <mailto: <Discuss at lists.osgeo.org><Discuss at lists.osgeo.org>
>>>>>>>        <mailto: <Discuss at lists.osgeo.org> <Discuss at lists.osgeo.org>
>>>>>>> Discuss at lists.osgeo.org>>
>>>>>>>         <http://lists.osgeo.org/mailman/listinfo/discuss><http://lists.osgeo.org/mailman/listinfo/discuss>
>>>>>> <ATT00001..c>
>>>>>>  <Discuss at lists.osgeo.org>Discuss at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/discuss/attachments/20110207/70ad957a/attachment-0002.html>
More information about the Discuss mailing list
