[OSGeo-Discuss] presentation template for coding training?
Jody Garnett
jody.garnett at gmail.com
Mon May 2 07:20:21 EDT 2011
I found it in an old branch of geotools for you:
- http://svn.osgeo.org/geotools/branches/2.7.x/docs/themes/geotools-tutorial/
Give it whirl; it matches the layout of the open office docs (giving more width to code examples etc...).
Jody
Jody Garnett
On Monday, 2 May 2011 at 9:19 PM, Jody Garnett wrote:
> Hey Jody
> > S5 is a slide show format based on XHTML, CSS, and JavaScript [0].
> > It integrates very well with reST as a command line utility for
> > converting reST to S5 is provided within docutils, give a look at this [1]
> > link.
> > Even if you don't want to use S5, you can still use reST and convert
> > the slides to pdf, via the rst2pdf [2] (included in docutils too). I
> > had very good results with it.
> > BTW: It would be very nice to have an OSGeo template for reST, if you
> > have one it would be nice if you could share ;)
> I made one for my course materials for foss4g 2009 (for geotools); it has since been tossed in the bit bucket as no projects
> are using osgeo branding :(
> It was used for the first cut of the osgeo live documentation and you can retrieve it from their svn repository.
> Thanks for the tips on s5 it sounds interesting.
> > [0] http://meyerweb.com/eric/tools/s5/
> > [1] http://docutils.sourceforge.net/docs/user/slide-shows.html
> > [2] http://docutils.sourceforge.net/sandbox/rst2pdf/README.html
> > Paolo Corti
> > Geospatial software developer
> > web: http://www.paolocorti.net
> > twitter: @capooti
> > Discuss mailing list
> > Discuss at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/discuss
URL: http://lists.osgeo.org/pipermail/discuss/attachments/20110502/f93f79f7/attachment-0001.html
More information about the Discuss
