[OSGeo-Discuss] presentation template for coding training?
Jody Garnett
jody.garnett at gmail.com
Mon May 2 04:19:10 PDT 2011
Hey Jody
> S5 is a slide show format based on XHTML, CSS, and JavaScript [0].
> It integrates very well with reST as a command line utility for
> converting reST to S5 is provided within docutils, give a look at this [1]
> link.
> Even if you don't want to use S5, you can still use reST and convert
> the slides to pdf, via the rst2pdf [2] (included in docutils too). I
> had very good results with it.
> BTW: It would be very nice to have an OSGeo template for reST, if you
> have one it would be nice if you could share ;)
I made one for my course materials for foss4g 2009 (for geotools); it has since been tossed in the bit bucket as no projects
are using osgeo branding :(
It was used for the first cut of the osgeo live documentation and you can retrieve it from their svn repository.
Thanks for the tips on s5 it sounds interesting.
> [0] http://meyerweb.com/eric/tools/s5/
> [1] http://docutils.sourceforge.net/docs/user/slide-shows.html
> [2] http://docutils.sourceforge.net/sandbox/rst2pdf/README.html
> Paolo Corti
> Geospatial software developer
> web: http://www.paolocorti.net
> twitter: @capooti
> Discuss mailing list
> Discuss at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/discuss
URL: <http://lists.osgeo.org/pipermail/discuss/attachments/20110502/5fb33954/attachment-0002.html>
More information about the Discuss
