[OSGeo-Discuss] Problems to install ms4w in windows7 (64bit)
Jody Garnett jody.garnett at gmail.com
Wed Jan 4 16:10:36 PST 2012
You will want to ask on the MS4W email list :-)
For details: http://www.maptools.org/ms4w/index.phtml?page=mailinglist.html
We tend to use this discuss at osgeo.org email list for OSGeo Foundation discussion and collaboration; leaving technical issues to individual projects.
Jody Garnett
On Wednesday, 4 January 2012 at 8:24 PM, Jan Tappenbeck wrote:
> Hi !
> i try to install ms4w in windows7 64bit and there are many problems....
> the source is [1] rel. 3.0.3
> to install the software i try to run osgeo4w.bat - but the PATH-Variable
> will not add automaticlly - so i try manuell.
> in the next line there sould be run some bat-files in the folder -
> %OSGEO4W%\etc\ini -> the folder etc exists; but ini not - there only is
> a folder setup with non-bat-files !!!!
> at last i try to run setenv.bat manuell - but sorry the PATH will not
> added. in my opion i am missing the drive-letter ...?
> set
> PATH=\ms4w\Apache\cgi-bin;\ms4w\tools\gdal-ogr;\ms4w\tools\mapserv;\ms4w\tools\shapelib;\ms4w\proj\bin;\ms4w\tools\shp2tile;\ms4w\tools\shpdiff;\ms4w\tools\avce00;\ms4w\python\gdal;%PATH%
> next there will be added some other Variables like GDAL_DATA - here i am
> missing drive-letters agains and then i try a test by following command:
> echo %GDAL_DATA% - but no value will show.
> can anyone help me ?
> regards Jan :-)
> [1] http://www.maptools.org/dl/ms4w/ms4w_3.0.3.zip
> regards Jan :-)
> Discuss mailing list
> Discuss at lists.osgeo.org (mailto:Discuss at lists.osgeo.org)
> http://lists.osgeo.org/mailman/listinfo/discuss
URL: <http://lists.osgeo.org/pipermail/discuss/attachments/20120105/7d98bfa7/attachment-0002.html>
More information about the Discuss mailing list
