[OSGeo-Discuss] [Board] OSGeo and LocationTech
Andrew Ross andrew.ross at eclipse.org
Mon Sep 10 15:34:34 PDT 2012
Hi Cameron, Michael, All
Yes that makes good sense, will likely yield tangible benefits. I'm in.
I note that Jody Garnett is chair of the incubation Committee and also
on the Project Management Committee (PMC) @ LocationTech. (added to /cc)
Andrew
On 09/10/2012 04:26 PM, Cameron Shorter wrote:
> Andrew,
> I suggest that the next steps would be to do a gap analysis between
> OSGeo incubation processes and LT incubation processes.
> This gap analysis will likely lead to:
> * Merging of both OSGeo and LT processes to pick up the best points of
> each.
> * Identification of the differences, followed by a process describing
> the migration path from one to the other.
> Andrew, is this something you are interested to pursue, possibly in
> conjunction with the incubation committee?
> On 11/09/2012 12:51 AM, Michael P. Gerlek wrote:
>> Cameron:
>> There's no reason a project can't play in both LT and OSGeo spheres,
>> and indeed proposed a motion to that effect some months ago now.
>> However, it proved very controversial among some members of our
>> community and I didn't feel it worth fighting at the time. Perhaps
>> more pragmatic heads will prevail as LT gets further along.
>> -mpg
>> On Sep 10, 2012, at 8:42 AM, Andrew Ross <andrew.ross at eclipse.org>
>> wrote:
>>> On 09/08/2012 04:38 PM, Cameron Shorter wrote:
>>>> Andrew, I'm moving this conversation over to OSGeo Discuss list so
>>>> that it has the opportunity for wider discussion.
>>> Thank you Cameron. And hello everyone.
>>>> Extracting from a conversation on the board email list ...
>>>> On 09/09/12 00:25, Andrew Ross wrote:
>>>>> If there is a close relationship between OSGeo & LocationTech, say
>>>>> where there is a natural progression of projects into OSGeo and
>>>>> then to LocationTech as they mature and look for corporate
>>>>> adoption & contributions, the Steering Committee may see good
>>>>> value in financial support. We are creating a program modelled
>>>>> after Friends of Eclipse which enables individual sponsorship for
>>>>> a modest amount. This program is designed to raise funds
>>>>> explicitly for the community. A close relationship with OSGeo
>>>>> helping to direct those funds might make a lot of sense.
>>>>> These are things going on at LocationTech in any case. Maybe they
>>>>> make sense to get involved with or perhaps not. I'm glad to
>>>>> discuss if there's potential.
>>>> Andrew, I'd like to suggest extending your thought to suggest that
>>>> projects can be members of "OSGeo" AND "LocationTech" rather than
>>>> OSGeo OR LocationTech. Any reason why that wouldn't work?
>>> Yes, at this point it looks like this can work fine.
>>> A project needs to comply with governance/requirements be it those
>>> of OSGeo or LocationTech. There is much overlap in this regard. In
>>> terms of difference, LocationTech appears to have more rigour in
>>> terms of code provenance, digging through prerequisites to detect
>>> potentially undesirable licensing issues, trademark search, and
>>> such. The bill of good health that results is seen as desirable by
>>> many companies when considering reuse & investment in the project.
>>> Andrew
More information about the Discuss mailing list
