[OSGeo-Discuss] code of conduct: another real case
Peter Baumann p.baumann at jacobs-university.de
Fri Sep 18 09:40:33 PDT 2015
so first OSGeo steals a project identity and then just says "go cure yourself"?
That won't fly.
-Peter
On 2015-09-18 17:30, Markus Neteler wrote:
> On Fri, Sep 18, 2015 at 5:02 PM, Stephen Woodbridge
> <woodbri at swoodbridge.com> wrote:
>> Ok, maybe I don't understand, but why doesn't somebody just fix this issue.
>> It seems everyone agrees the listing is wrong on the site. Somebody should
> ... just check the page itself:
> https://www.openhub.net/p/rasdaman
> "About Basics
>  The project name will be shown in Open Hub search results, as well as
> in search engines. This name must be unique across all of Open Hub.
> Please Contact us if you believe your preferred project name is
> incorrectly assigned to another project. Please use as short a name as
> possible.
> --> Please Contact us = http://blog.openhub.net/support-2/
> Very easy to do that.
> But: the manager of that openhub page is here:
> rasdaman
> -  Settings |  Report Duplicate
>    - Settings : Managers
>      - pebau
>        https://www.openhub.net/accounts/pebau
>        "Principal Architect of rasdaman."
> Peter, probably you can edit the page right away after login?
> Otherwise "Support" above.
> (I agree that there are too many links on the openhub pages)
> cheers,
> Markus
Dr. Peter Baumann
 - Professor of Computer Science, Jacobs University Bremen
   www.faculty.jacobs-university.de/pbaumann
   mail: p.baumann at jacobs-university.de
   tel: +49-421-200-3178, fax: +49-421-200-493178
 - Executive Director, rasdaman GmbH Bremen (HRB 26793)
   www.rasdaman.com, mail: baumann at rasdaman.com
   tel: 0800-rasdaman, fax: 0800-rasdafax, mobile: +49-173-5837882
"Si forte in alienas manus oberraverit hec peregrina epistola incertis ventis dimissa, sed Deo commendata, precamur ut ei reddatur cui soli destinata, nec preripiat quisquam non sibi parata." (mail disclaimer, AD 1083)
More information about the Discuss mailing list
