[OSGeo-Discuss] OSGeo booth at state of the map
Jeff McKenna
jmckenna at gatewaygeomatics.com
Thu Sep 15 05:56:33 PDT 2016
Hi Johan,
Thank you for helping promote OSGeo at SotM next week.
Regarding booth materials, I know when I was in your same situation for
FOSS4G Seoul I checked out the marketing sources with a command like:
svn co https://svn.osgeo.org/osgeo/marketing/ marketing-svn
and then found an old version source, of a poster or 'popup', edited it
to make sure it was uptodate, and then committed those changes back into
the svn repository (use your OSGeo ID, which you can find or reset
through http://www.osgeo.org/osgeo_userid). If your user ID needs write
access to that marketing repository please let me know and I will add you.
For example, for the Seoul booth I used my marketing hat and edited the
'popups' at https://svn.osgeo.org/osgeo/marketing/exhibitionpack/ to add
in missing projects etc. It looks like that is the last change made, so
you might have to check to verify the info is still correct, for 2016.
I will also later today check that too.
-jeff
Jeff McKenna
President Emeritus, OSGeo
http://wiki.osgeo.org/wiki/Jeff_McKenna
On 2016-09-15 5:46 AM, Johan Van de Wauw wrote:
> Hi all,
> Next week (23 - 25 september) there will be the yearly open streetmap
> conference (state of the map) in Brussels. OSGeo (technically speaking
> OSGeo.be) will have a booth there.
> If you are planning to join the conference and would like to staff our
> booth, please let us know, by mailing me or updating our wiki page: [1]
> We could also still use some marketing material (stickers/flyers/...).
> Anyone around who can send or bring those?
> Kind Regards,
> Johan
> See you at maptember: https://wiki.osgeo.org/wiki/Belgium/Booth_SOTM2016
> [1]: https://wiki.osgeo.org/wiki/Belgium/Booth_SOTM2016
More information about the Discuss
