[OSGeo-Discuss] Confirm subscription to geoserver-devel. sent from SourceForge.net?
Mateusz Loskot mateusz at loskot.net
Sun Sep 17 11:49:35 PDT 2017
I've received confusing e-mail with confirmation of subscription
to geoserver-devel sent from SF.net to lists.osgeo.org.
I'm not subscribed to geoserver-devel.
I've not attempted to subscribe to geoserver-devel.
Any ideas why the confirmation?
Regards,
Mateusz
Delivered-To: mateusz at loskot.net
Received: by 10.176.81.212 with SMTP id h20csp2665003uaa;
        Sun, 17 Sep 2017 10:39:14 -0700 (PDT)
X-Google-Smtp-Source:
ADKCNb5NSiGRdcmQo7SR838yVXdVwDGRpNpyNGfc5uIRvEkaj++zy0TZHWGQHhmzjEotoks81oL1
X-Received: by 10.101.83.4 with SMTP id m4mr22371363pgq.266.1505669954060;
ARC-Seal: i=1; a=rsa-sha256; t=1505669954; cv=none;
        d=google.com; s=arc-20160816;
        b=Ffw2uRP1fPABJJHVcjvWjOMfE1NpXsHnMRexX5zTK3E0Ch0zjUhzyRWFseFveuW6XZ
         GZxc+129ssKsSLRDBCKUi6oL9PXYFlxdF6lZS2ONMJUEtKs3KUswf7bk/D4ZhFtxKki7
         jN6CoTewS2n5FM/Esvx7z5mNoL3n9RhK6L2ny0UxP5RiZHS7DnuMOx9xMjV/3gN6ZHB8
         7DMdLiJVUQPkU0mAsFS+BzNCRfvmtcCd+o/PwN43VLzzRlICDKA2Z0aOFfzBKENEyN34
         1By53H2zMBwmFlTF6dOCtXHDCx1A2HNQGoXtH21ET6S3ZVHZH0aIjpbGITAfqKxnk+OW
         s/NA==
ARC-Message-Signature: i=1; a=rsa-sha256; c=relaxed/relaxed;
        h=reply-to:date:message-id:to:from:subject:mime-version
         :dkim-signature:delivered-to:arc-authentication-results;
        bh=gT/6YI+CqAR3f7iK4FGtp4iOYH+yEYCuaWBMcStLlzI=;
        b=nuYITQP5xX8qcC1XTtAq1+hssAjhU3gPQPdEnhNrKjIOa6AihkL1O9U7UOoAKOrCDg
         WpDdtsUwgxEJrHavnWlCtJM8m+HXGh314a0Dy0FmFhSheR7KggHRxan9sH4I0KnFth1L
         wR7VDjelxaGmv3z1PM4NIg+MiJBzY4bIfw2c5PwpwMBypHxJH9zj330WGhHYOV+I8r/K
         lEpdtzKiAfnbelRxVvQFi4TS9ONvY+GQsBIFq+45Yp0dvRiikNzFZDuSgK/5nW6L02UP
         kuQIpso0XlVQyALxpCUUJbykE+KreG6y7Uc1VxPguKHh7FPHJj/QJMZtt4yJe77U5arl
         VAJg==
ARC-Authentication-Results: i=1; mx.google.com;
       dkim=fail (test mode) header.i=@sourceforge.com header.s=x
header.b=IxTumoSI;
       spf=fail (google.com: domain of noreply at sourceforge.net does
not designate 140.211.15.3 as permitted sender)
smtp.mailfrom=noreply at sourceforge.net;
       dmarc=fail (p=QUARANTINE sp=NONE dis=NONE) header.from=sourceforge.net
Return-Path: <noreply at sourceforge.net>
Received: from lists.osgeo.org (osgeo6.osgeo.osuosl.org. [140.211.15.3])
        by mx.google.com with ESMTPS id z15si3461277pfk.30.2017.09.17.10.39.13
        for <mateusz at loskot.net>
        (version=TLS1_2 cipher=ECDHE-RSA-AES128-GCM-SHA256 bits=128/128);
        Sun, 17 Sep 2017 10:39:13 -0700 (PDT)
Received-SPF: fail (google.com: domain of noreply at sourceforge.net does
client-ip=140.211.15.3;
Authentication-Results: mx.google.com;
header.b=IxTumoSI;
Received: by lists.osgeo.org (Postfix) id 813706146817; Sun, 17 Sep
Delivered-To: nabble at osgeo.org
Received: from n6.nabble.com (n6.nabble.com [162.255.23.37]) by
lists.osgeo.org (Postfix) with ESMTP id 645C46146810 for
<nabble at osgeo.org>; Sun, 17 Sep 2017 10:39:13 -0700 (PDT)
Received: from n6.nabble.com (localhost [127.0.0.1]) by n6.nabble.com
(Postfix) with ESMTP id 3A68F1BE5919 for <nabble at osgeo.org>; Sun, 17
Sep 2017 10:39:12 -0700 (MST)
Received: from compute4.internal (compute4.nyi.internal [10.202.2.44])
by sloti25t09 (Cyrus fastmail-fmjessie44918-15375-git-fastmail-15375)
with LMTPA;
Sun, 17 Sep 2017 13:39:03 -0400
X-Cyrus-Session-Id: sloti25t09-2704098-1505669943-2-9954565599429992181
X-Sieve: CMU Sieve 3.0
X-Spam-known-sender: no
X-Spam-score: 0.0
X-Spam-hits: BAYES_00 -1.9, HTML_FONT_LOW_CONTRAST 0.001, HTML_MESSAGE 0.001,
  RCVD_IN_DNSWL_MED -2.3, RP_MATCHES_RCVD -0.001, SPF_PASS -0.001,
  LANGUAGES en, BAYES_USED global, SA_VERSION 3.4.0
X-Spam-source: IP='216.34.181.60', Host='ch3.sourceforge.net', Country='US',
  FromHeader='net', MailFrom='net'
X-Spam-charsets: plain='utf-8', html='utf-8'
X-Resolved-to: lists+1326929063815-3819232 at n6.nabble.com
X-Delivered-to: lists+1326929063815-3819232 at n6.nabble.com
X-Mail-from: noreply at sourceforge.net
Received: from mx2 ([10.202.2.201])
  by compute4.internal (LMTPProxy); Sun, 17 Sep 2017 13:39:03 -0400
Received: from mx2.messagingengine.com (localhost [127.0.0.1]) by
mailmx.nyi.internal (Postfix) with ESMTP id CCA0AD8990 for
<lists+1326929063815-3819232 at n6.nabble.com>; Sun, 17 Sep 2017 13:39:01
-0400 (EDT)
    by mx2.messagingengine.com (Authentication Milter) with ESMTP
    id 0DEC626A852;
    Sun, 17 Sep 2017 13:39:01 -0400
Authentication-Results: mx2.messagingengine.com;
    dkim=pass (1024-bit rsa key sha256) header.d=sourceforge.com
header.i=@sourceforge.com header.b=IxTumoSI;
    dmarc=pass header.from=sourceforge.net;
    iprev=pass policy.iprev=216.34.181.60 (ch3.sourceforge.net);
    spf=pass smtp.mailfrom=noreply at sourceforge.net
smtp.helo=smtp.ch3.sourceforge.com;
    x-ptr=fail x-ptr-helo=smtp.ch3.sourceforge.com
x-ptr-lookup=ch3.sourceforge.net;
    x-tls=pass version=TLSv1.2 cipher=ECDHE-RSA-AES256-GCM-SHA384 bits=256/256
Received-SPF: pass
    (sourceforge.net ... _spf.sourceforge.net: 216.34.181.60 is
authorized to use 'noreply at sourceforge.net' in 'mfrom' identity
(mechanism 'ip4:216.34.181.0/24' matched))
    receiver=mx2.messagingengine.com;
    identity=mailfrom;
    envelope-from="noreply at sourceforge.net";
    client-ip=216.34.181.60
Received: from smtp.ch3.sourceforge.com (ch3.sourceforge.net
[216.34.181.60]) (using TLSv1.2 with cipher
ECDHE-RSA-AES256-GCM-SHA384 (256/256 bits)) (No client certificate
requested) by mx2.messagingengine.com (Postfix) with ESMTPS for
-0400 (EDT)
DKIM-Signature: v=1; a=rsa-sha256; q=dns/txt; c=relaxed/relaxed;
d=sourceforge.com; s=x;
h=Date:Message-ID:To:From:Subject:MIME-Version:
Content-Type:Sender:Reply-To:Cc:Content-Transfer-Encoding:Content-ID:
Content-Description:Resent-Date:Resent-From:Resent-Sender:Resent-To:Resent-Cc
:Resent-Message-ID:In-Reply-To:References:List-Id:List-Help:List-Unsubscribe:
List-Subscribe:List-Post:List-Owner:List-Archive;
b=IxTumoSIpy3UFl+nWu5QqjYl3U
R6IqR5qb9VCplkOrVVA2m91ycHMIJWYuZnfpYebkKMm6IvCYxNqEs37Ksfu6Ed0uECEqh1bucQgEE
4JVqmmv/TC4DSgkLGxRPZLtid2RUcn/2HB4iRZwC4pJirvQKXDej1Wq5G5pck7YvxEnM=;
Received: from localhost ([127.0.0.1]
helo=sfs-consume-2.v29.ch3.sourceforge.com) by
sfs-consume-2.v29.ch3.sourceforge.com with esmtp (Exim 4.89)
(envelope-from <noreply at sourceforge.net>) id 1dtdX1-0003Lu-So for
lists+1326929063815-3819232 at n6.nabble.com; Sun, 17 Sep 2017 17:38:59
+0000
Content-Type: multipart/alternative;
boundary="===============6422380634963448771=="
MIME-Version: 1.0
Subject: Project Mailing List Confirmation Required
From: "SourceForge.net" <noreply at sourceforge.net>
To: lists+1326929063815-3819232 at n6.nabble.com
Message-ID: <481539195.18003.1505669952236.JavaMail.administrator at n6.nabble.com>
Date: Sun, 17 Sep 2017 17:38:59 +0000
Reply-To: fwd+lists~2B1326929063815-3819232~40n6.nabble.com+noreply~40sourceforge.net+457910485 at n6.nabble.com
Mateusz Loskot, http://mateusz.loskot.net
More information about the Discuss mailing list
