[OSGeo-Discuss] Concurrency problems, please help
Martin Dobias wonder.sk at gmail.com
Wed Sep 23 00:31:28 PDT 2020
Hi Pierre
While I don't have concrete advice for your implementation, I would
like to suggest having a look at Entwine [1] and/or PotreeConverter
[2] projects and maybe reuse their code. Both of them have only a
single task - to build an octree from potentially massive amounts of
point cloud data.
I will start working on point cloud visualization in QGIS in the
coming months and I plan to use code from one of the projects to build
octrees for efficient visualization (more details here [3]).
Regards
Martin
[1] https://github.com/connormanning/entwine
[2] https://github.com/potree/PotreeConverter
[3] https://github.com/qgis/QGIS-Enhancement-Proposals/issues/194
On Wed, Sep 23, 2020 at 3:11 AM Pierre Abbat <phma at bezitopo.org> wrote:
> https://github.com/phma/wolkenbase
> I just published the repo. I've been racking my brains on this problem for
> months. Wolkenbase reads a point cloud and makes an octree, in order to
> classify points. The basic algorithm of building the octree is sound, but
> slow, so I'm trying to multithread it.
> Wolkenbase has to handle point clouds that are too big to fit in RAM, so it
> allocates block buffers until RAM gets low, then swaps blocks out to files. So
> that it can continue putting points in the octree while writing blocks to
> files, it uses more files than there are threads.
> I'm testing it with a small point cloud of 250024 points, so that it doesn't
> have to write to disk while it constructs the octree, but still it loses
> points. I've found and fixed bugs in the splitting routine. I currently have it
> checking after each point it inserts to make sure that it's in there. I've
> found, and I think I fixed, a bug where one thread checked a point while
> another thread was splitting the block where the point was inserted, so it
> didn't find it. Now it fails to find a point, but the point is not in the block
> being split. It may fail to find 24 points while it's building the octree, but
> when it's finished they're all there, or it's missing one or three of them.
> I have a huge point cloud (19 files, 3.5 GB total) which I've tried Wolkenbase
> on, but it complains that the point is already in the octree. This turned out
> to be points scattered through the cloud that have been "deleted" by
> overwriting with all zeros. (0,0,0) is offset to somewhere within the cube, and
> is equal to (0,0,0), so I can't rely on the point count in the dump file.
> I cut it down to one thread; it works perfectly. With two threads, it works
> fine, but with three, it loses points. Usually two threads are sufficient to
> allow a concurrency bug to happen.
> Can someone look at the program and suggest how to make it work?
> Pierre
> li ze te'a ci vu'u ci bi'e te'a mu du
> li ci su'i ze te'a mu bi'e vu'u ci
> Discuss mailing list
> Discuss at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/discuss
More information about the Discuss mailing list
