[OSGeo-Discuss] Qgis network plugins (Nathan D)
Reg Nelson reg at corvusspatial.ca
Fri Sep 25 07:38:07 PDT 2020
Nathan, I would consider using pgrouting <https://pgrouting.org/> for
network analysis problems. It requires setting up an instance of Postgresql
database and adding PostGIS, so there is significant work involved and a
steep learning curve. If you have a single problem to solve this may be too
much, but if you're interested in network analysis in general and
anticipate tackling other network problems then this is a good open source
solution. You can use QGIS with Postgresql/PostGIS/pgrouting, and there is
an active community with tutorials, documentation, etc.
Reg
URL: <http://lists.osgeo.org/pipermail/discuss/attachments/20200925/6004c769/attachment.html>
More information about the Discuss mailing list
