[OSGeo-Discuss] repo.osgeo.org contains empty files
Jody Garnett jody.garnett at gmail.com
Thu Sep 7 15:59:15 PDT 2023
 Question:
Are you building against repo osgeo "release" directly in your maven build?
If so you should indeed be fixed 🙂
Or have you setup a mirror or nexus repository of your own that caches repo
osgeo "releases"?
In this case you may need to clear your cache (to get rid of any zero sized
jars).
I am curious how many folks are running downstream caches or mirrors and
may be affected ...
Jody Garnett
On Sep 7, 2023 at 12:42:09 PM, "Brogli, Alexander" <Alexander.Brogli at ebp.ch>
wrote:
> Hello
> Thanks for creating the ticket. I haven't created one, since I don't have
> a osgeo ID and am still waiting for a reply to my mantra request. I've
> checked, it seems we can regularly pull from repo.osgeo.org again, so I
> can confirm the problem seems to be resolved for us, thanks a lot!
> Regards, Alex
> *Von:* Jody Garnett <jody.garnett at gmail.com>
> *Gesendet:* Donnerstag, 7. September 2023 21:04
> *An:* fgdrf at users.sourceforge.net <fgdrf at users.sourceforge.net>
> *Cc:* Brogli, Alexander <Alexander.Brogli at ebp.ch>; discuss at lists.osgeo.org
> <discuss at lists.osgeo.org>
> *Betreff:* Re: [OSGeo-Discuss] repo.osgeo.org contains empty files
> *[EXTERNE E-MAIL]* Klicke nicht auf Links und öffne keine angehängten
> Dateien, wenn du die Absenderin oder den Absender nicht kennst.
> I have gone ahead and created a ticket there:
> https://trac.osgeo.org/osgeo/ticket/2978
> I did not see you report the ticket yet, and it is capturing feedback on
> multiple channels.
> I have found the problem with geonetwork-cache being setup to cache files
> stored in a GitHub repository by geonetwork 2.x series.
> GitHub must of turned off access in this manner yesterday, resulting in a
> lot of time-outs and zero sized files being saved.
> The geonetwork-cache has been removed from release configuration; and I
> hope normal service has been restored? Please CONFIRM 🙂
> Notes:
>    - There is a risk that other repositories have saved these zero sized
>    files and will need to clear their cache of OSGeo, and lazily rebuild it
>    again.
>    - Normal maven builds do not have any way to select what jar to
>    retrieve from different repositories. Indeed they attempt to contact each
>    repository in turn, checking for every jar.
>    So it is expect that repo.osgeo.org releases would field requests for
>    all manner of content as we have seen. This is one case where gradle offers
>    better control ...
>    - I will reach out to the core-geonetwork project and determine how
>    their build can be restored also.
> Jody Garnett
> Jody Garnett
> On Sep 7, 2023 at 7:39:38 AM, Frank Gasdorf <fgdrf at users.sourceforge.net>
> wrote:
> Hi folks,
> I recently stumble about this problem to and my investigation is as
> follows:
> * you a company uses a repository manager and has osger repo as a proxy
> repo configured AND
> * and internal artefact has been request but is not avaliable in internal
> repositories, that a http get is set to osgeo repo as well
> * this leads to enties like that with size 0 for each artefact
> IMHO it seems to be an issue in nexus configuration and I investigate how
> to configure filter for proxe repositories in Nexus.
> Once you have a trac issue id, let us know
> Frank
> Am Do., 7. Sept. 2023 um 15:22 Uhr schrieb Jody Garnett via Discuss <
> discuss at lists.osgeo.org>:
> This should be reported to the trac issues tracker, for the system admin
> committee.
> I help manage the repo a bit, I wonder where the size zero files come
> from? We may be able to check if they were uploaded or fetched from a cache
> of an external repo.
> On Thu, Sep 7, 2023 at 5:54 AM Brogli, Alexander via Discuss <
> discuss at lists.osgeo.org> wrote:
> Hi all
> We're thankful consumers of osgeo's maven repository, though this morning
> we noticed that empty files are pulled. Inspecting certain cases, we saw
> that since this morning files with size 0 seem to be in the repo, e.g. the
> files here
> https://repo.osgeo.org/service/rest/repository/browse/release/org/jboss/jboss-parent/36/
> Do you know if there's a better place / mailing list to post this inquiry,
> or if the responsible persons are aware of the issue?
> Thanks & regards
> Alex
> Discuss mailing list
> Discuss at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/discuss
URL: <http://lists.osgeo.org/pipermail/discuss/attachments/20230907/e41e4bbd/attachment.htm>
More information about the Discuss mailing list
