[OSGeo-Discuss] PostGIS 3.6.0 Released
Sandro Santilli
strk at kbt.io
Tue Sep 9 02:26:46 PDT 2025
The PostGIS Team is pleased to announce the release of PostGIS 3.6.0.
[ 2025/09/01 ]
Download: https://download.osgeo.org/postgis/source/postgis-3.6.0.tar.gz
MD5: 469182b48dddf39c8d26da2e3cca9781
Online announcement: https://postgis.net/2025/09/PostGIS-3.6.0/
* Breaking Changes *
- #5799, make ST_TileEnvelope clips envelopes to tile plane extent (Paul Ramsey)
- #5829, remove constraint checking from geometry_columns view (Paul Ramsey)
- #3373, GT-255, [topology] Support for upgrading domains (Ayo Adesugba, U.S. Census Bureau)
- GT-252, ST_NumGeometries/ST_GeometryN treat TIN and PolyhedralSurface as unitary geometries, use ST_NumPatches/ST_PatchN for patch access (Loïc Bartoletti)
- #3110, GT-242 [topology] Support for bigint (Ayo Adesugba, U.S. Census Bureau)
- #5359, #5897, GT-260 [tiger_geocoder] Use @extschema:extension@ for PG >= 16 to schema qualify dependent extensions, switch to use typmod for tiger tables (Regina Obe)
* Deprecated / Removed signatures *
- #3110, GT-242, [topology] numerous topology functions that accepted integer replaced with bigint versions to support both integer and bigint inputs (Ayo Adesugba, U.S. Census Bureau)
- #5498 Drop st_approxquantile(raster, double precision), wasn't usable as it triggered is not unique error when used (Regina Obe)
* New Features *
- GH-803, [sfcgal] ADD CG_Simplify function (Loïc Bartoletti)
- GH-805, [sfcgal] Add M support for SFCGAL >= 1.5.0 (Loïc Bartoletti)
- GH-801, [sfcgal] ADD CG_3DAlphaWrapping function (Jean Felder)
- #5894, [topology] TotalTopologySize (Sandro Santilli)
- #5890, [topology] ValidateTopologyPrecision, MakeTopologyPrecise (Sandro Santilli)
- #5861, [topology] Add --drop-topology switch to pgtopo_import (Sandro Santilli)
- #1247, [raster] ST_AsRasterAgg (Sandro Santilli)
- #5784, GT-223 Export circ_tree_distance_tree_internal for mobilitydb use (Maxime Schoemans)
- GT-228, [sfcgal] Add new functions (Scale, Translate, Rotate, Buffer 3D and Straight Skeleton Partition) from SFCGAL 2 (Loïc Bartoletti)
- [raster] New GUC postgis.gdal_cpl_debug, enables GDAL debugging messages and routes them into the PostgreSQL logging system. (Paul Ramsey)
- #5841, Change interrupt handling to remove use of pqsignal to support PG 18 (Paul Ramsey)
- Add ST_CoverageClean to edge match and gap remove polygonal coverages (Paul Ramsey) from GEOS 3.14 (Martin Davis)
- [raster] Add ST_ReclassExact to quickly remap values in raster (Paul Ramsey)
- #5963, [raster] add ST_IntersectionFractions - Requires GEOS 3.14 (Paul Ramsey)
- #5971, Option to build --without-tiger (Regina Obe)
Notes:
This version requires PostgreSQL 12-18beta3, GEOS 3.8 or higher, and Proj 6.1+.
To take advantage of all features, GEOS 3.14+ is needed.
To take advantage of all SFCGAL features, SFCGAL 2.2+ is needed.
Many thanks to our translation teams, in particular:
Teramoto Ikuhiro (Japanese Team)
Daniel Nylander (Swedish Team)
Dapeng Wang, Zuo Chenwei from HighGo (Chinese Team)
Denys Kovshun (Ukrainian Team)
--strk;
Libre GIS consultant/developer 🎺
https://strk.kbt.io/services.html
Desc: not available
URL: <http://lists.osgeo.org/pipermail/discuss/attachments/20250909/66681e90/attachment.sig>
More information about the Discuss
