[OSGeo-Edu] Education brochure
Ned Horning
horning at amnh.org
Fri Jun 9 11:55:15 EDT 2006
Tyler,
Thanks for your work on this. The flyer looks good but I have a few comments
that others can comment on and you can deal with as you see fit.
In the third paragraph I would change "We hope to accomplish this by. "We
will accomplish this by.".
Under Activities "Goal" should be changed to "Goals" when more than one goal
is listed. I would delete all of the "Methods" text. This doesn't really add
anything to what is mentioned under Goal(s). If something under "Methods" is
important enough I'd move it up to goals. For example, I would move "Work
with developers to identify research needs" up to "Goals".
Lastly, I would change "Geospatial Free Open Source Software" to "open
source geospatial software which echos the name of the Foundation (a good
thing). For what it's worth I have a problem with the use of "Free" in this
context. If this is intended for general consumption "free" is usually
interpreted as "no cost" not "freedom" as it was/is interpreted in OS
circles. I realize including "free" is supposed to be profound but from my
perspective it's a bit silly and confusing especially since it effectively
repeats the meaning of "open source".
All the best,
Ned
> -----Original Message-----
> From: Tyler Mitchell [mailto:tylermitchell at shaw.ca]
> Sent: Friday, June 09, 2006 2:20 AM
> To: discuss at edu.osgeo.org
> Subject: [OSGeo-Edu] Education brochure
> Hi all,
> I've got a draft of the Education brochure for Where 2.0, see attached.
> I can't handle a lot of changes right now, but please review the text
> - I touched it up a bit. And I definitely can't handle layout
> changes, as I'm using a standard template for all the other 9
> brochures that I'm pulling together (yes, I am busy :).
> Please give me feedback... I leave Saturday for California but will
> try to respond to any comments.
More information about the Edu_discuss
