[OSGeo-Edu] New Ominiverdi Live-DVD available
Alex Mandel tech_dev at wildintellect.com
Wed Sep 10 03:26:19 EDT 2008
Hmm, looking around the web this seems to be a bug that comes up in
custom LiveCDs every once in a while.
If I switch to Ctrl-Alt-F1 I get a " user not known to the underlying
authentication module"
In particular I'm testing this on VMware Server 2 Beta.
I did a disk check which came out ok and tried to boot into Single User
mode without success. I'll try a different live CD and see what happens
and maybe poke around the VMware bug tracker.
Thanks,
Alex
Luca Casagrande wrote:
> You don't need a username and a password to log in, because it should be
> automatic.  If you see the log-in manager, can be some troubles with
> the graphic server..
> Try with ubuntu as username and leave empty the password field.
> Let me know if it works.
> Bye
> Luca
> 2008/9/10 Alex Mandel <tech_dev at wildintellect.com>:
>> Anyone know the username and password for this Disc I can't seem to
>> figure it out.
>> I've tried all sorts of combos of:
>> ominiverdi
>> ubuntu
>> osgeo
>> xubuntu
>> Thanks,
>> Alex
>> Moritz Lennert wrote:
>>> Hello,
>>> Luca Casagrande, whose internet connection is intermittent, has asked me
>>> to announce the availability of the new Ominiverdi Live-DVD [1]. For
>>> more info about the project see [2].
>>> The DVD is a Xubuntu system containing recent versions of
>>> GRASS
>>> QGIS
>>> PostgreSQL+PostGIS
>>> GDAL
>>> R
>>> Openoffice
>>> etc...
>>> It also contains the new North Carolina GRASS demo data set, next to the
>>> old Spearfish data set.
>>> On the DVD, there is also a special win/ folder with the following
>>> windows installers:
>>> - FWTools221.exe
>>> - QGIS-0.11.0-1-Setup.exe
>>> - WinGRASS-6.3.0-4-Setup.exe
>>> - gvSIG-1_1_1-windows-i586-withjre.exe
>>> - ms4w-2.2.8-setup.exe
>>> Many thanks for Luca for the great work !
>>> Moritz
>>> [1] http://www.thebighouse.biz/livecd-1108.iso
>>> (Size: 1210691584, Md5sum: d5b47e81d19045cabcad8e0b5cc655dc
>>> [2] : http://www.ominiverdi.org/index.php/livecd/Free%20GIS%20liveCD
>> Edu_discuss mailing list
>> Edu_discuss at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/edu_discuss
More information about the Edu_discuss mailing list
