[OSGeo-Edu] ACM SIGSPATIAL contest
Suchith Anand Suchith.Anand at nottingham.ac.uk
Fri Feb 21 05:08:22 PST 2014
Hi Stefan,
Thanks for this info. There is also a QGIS Schematization Plugin that was proposed by  Luciene Delazari along with Mark Ware and myself for this year's Google Summer of Code. Details below:
In the current version there are few tools for generalization (Dedicated to line simplification). It would be a great improvement to have some functions to create schematic maps, for example:
   #   Simplify lines - input data will typically contain redundant vertices. These are removed by application of a suitable line simplification algorithm (in our case the Douglas-Peucker algorithm). For example building on the QGIS generalize plugin
   #   topology - ensures that original map and derived schematic map are topologically consistent i.e yopology of the network is preserved during the schematization process.
   #   angular - if possible, edges should lie in horizontal, vertical or diagonal direction.
    minimum edge length - if possible, all edges should have length greater than some minimum length.
In future, we can add more functionalities by adding constraints on Rotation, Clearance, Displacement etc.
http://hub.qgis.org/wiki/quantum-gis/Google_Summer_of_Code_2014
It will be good opportunity if we can implement this as plugin in QGIS.
Suchith
-----Original Message-----
From: edu_discuss-bounces at lists.osgeo.org [mailto:edu_discuss-bounces at lists.osgeo.org] On Behalf Of Stefan Steiniger
Sent: 20 February 2014 14:26
To: edu_discuss at lists.osgeo.org
Subject: [OSGeo-Edu] ACM SIGSPATIAL contest
Hi all,
the ACM SIGSPATIAL contest this year is about a map generalization task.
If someone has interest or interested students, please forward:
http://mypages.iit.edu/~xzhang22/GISCUP2014/
would be interesting to see also how standard FOS desktop GIS perform on this.
cheers,
stefan
Edu_discuss mailing list
Edu_discuss at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/edu_discuss
This message and any attachment are intended solely for the addressee and may contain confidential information. If you have received this message in error, please send it back to me, and immediately delete it.   Please do not use, copy or disclose the information contained in this message or in any attachment.  Any views or opinions expressed by the author of this email do not necessarily reflect the views of the University of Nottingham.
This message has been checked for viruses but the contents of an attachment
may still contain software viruses which could damage your computer system, you are advised to perform your own checks. Email communications with the University of Nottingham may be monitored as permitted by UK legislation.
More information about the Edu_discuss mailing list
