svn commit: r94 - trunk/www/docs/ODBC
gregboone at osgeo.org
Fri Dec 1 15:39:08 EST 2006
Author: gregboone
Date: 2006-12-01 20:39:06+0000
New Revision: 94
Added:
trunk/www/docs/ODBC/_odbc_ov_8h-source.html (contents, props changed)
trunk/www/docs/ODBC/_odbc_ov_8h.html (contents, props changed)
trunk/www/docs/ODBC/_odbc_ov_8h_91b15f0fd565be7c245bbe8e5247fbdc.html (contents, props changed)
trunk/www/docs/ODBC/_odbc_ov_8h__dep__incl.map (contents, props changed)
trunk/www/docs/ODBC/_odbc_ov_8h__dep__incl.md5 (contents, props changed)
trunk/www/docs/ODBC/_odbc_ov_8h__dep__incl.png (contents, props changed)
trunk/www/docs/ODBC/_odbc_ov_class_collection_8h-source.html (contents, props changed)
trunk/www/docs/ODBC/_odbc_ov_class_collection_8h.html (contents, props changed)
trunk/www/docs/ODBC/_odbc_ov_class_collection_8h_45dc2dbdb78cdf026c7aa3e26d67bd29.html (contents, props changed)
trunk/www/docs/ODBC/_odbc_ov_class_collection_8h__dep__incl.map (contents, props changed)
trunk/www/docs/ODBC/_odbc_ov_class_collection_8h__dep__incl.md5 (contents, props changed)
trunk/www/docs/ODBC/_odbc_ov_class_collection_8h__dep__incl.png (contents, props changed)
trunk/www/docs/ODBC/_odbc_ov_class_collection_8h__incl.map (contents, props changed)
trunk/www/docs/ODBC/_odbc_ov_class_collection_8h__incl.md5 (contents, props changed)
trunk/www/docs/ODBC/_odbc_ov_class_collection_8h__incl.png (contents, props changed)
trunk/www/docs/ODBC/_odbc_ov_class_definition_8h-source.html (contents, props changed)
trunk/www/docs/ODBC/_odbc_ov_class_definition_8h.html (contents, props changed)
trunk/www/docs/ODBC/_odbc_ov_class_definition_8h_70719915c7660c6a63636304351c73c9.html (contents, props changed)
trunk/www/docs/ODBC/_odbc_ov_class_definition_8h__dep__incl.map (contents, props changed)
trunk/www/docs/ODBC/_odbc_ov_class_definition_8h__dep__incl.md5 (contents, props changed)
trunk/www/docs/ODBC/_odbc_ov_class_definition_8h__dep__incl.png (contents, props changed)
trunk/www/docs/ODBC/_odbc_ov_class_definition_8h__incl.map (contents, props changed)
trunk/www/docs/ODBC/_odbc_ov_class_definition_8h__incl.md5 (contents, props changed)
trunk/www/docs/ODBC/_odbc_ov_class_definition_8h__incl.png (contents, props changed)
trunk/www/docs/ODBC/_odbc_ov_column_8h-source.html (contents, props changed)
trunk/www/docs/ODBC/_odbc_ov_column_8h.html (contents, props changed)
trunk/www/docs/ODBC/_odbc_ov_column_8h__dep__incl.map (contents, props changed)
trunk/www/docs/ODBC/_odbc_ov_column_8h__dep__incl.md5 (contents, props changed)
trunk/www/docs/ODBC/_odbc_ov_column_8h__dep__incl.png (contents, props changed)
trunk/www/docs/ODBC/_odbc_ov_column_8h__incl.map (contents, props changed)
trunk/www/docs/ODBC/_odbc_ov_column_8h__incl.md5 (contents, props changed)
trunk/www/docs/ODBC/_odbc_ov_column_8h__incl.png (contents, props changed)
trunk/www/docs/ODBC/_odbc_ov_column_8h_fb1cb53c58d91f79354479c12b7127bc.html (contents, props changed)
trunk/www/docs/ODBC/_odbc_ov_data_property_definition_8h-source.html (contents, props changed)
trunk/www/docs/ODBC/_odbc_ov_data_property_definition_8h.html (contents, props changed)
trunk/www/docs/ODBC/_odbc_ov_data_property_definition_8h_1594f236136919ad7bf4b57af8928e09.html (contents, props changed)
trunk/www/docs/ODBC/_odbc_ov_data_property_definition_8h__dep__incl.map (contents, props changed)
trunk/www/docs/ODBC/_odbc_ov_data_property_definition_8h__dep__incl.md5 (contents, props changed)
trunk/www/docs/ODBC/_odbc_ov_data_property_definition_8h__dep__incl.png (contents, props changed)
trunk/www/docs/ODBC/_odbc_ov_data_property_definition_8h__incl.map (contents, props changed)
trunk/www/docs/ODBC/_odbc_ov_data_property_definition_8h__incl.md5 (contents, props changed)
trunk/www/docs/ODBC/_odbc_ov_data_property_definition_8h__incl.png (contents, props changed)
trunk/www/docs/ODBC/_odbc_ov_geometric_property_definition_8h-source.html (contents, props changed)
trunk/www/docs/ODBC/_odbc_ov_geometric_property_definition_8h.html (contents, props changed)
trunk/www/docs/ODBC/_odbc_ov_geometric_property_definition_8h_04c59f42eaac4b45a0cf577ba2946da3.html (contents, props changed)
trunk/www/docs/ODBC/_odbc_ov_geometric_property_definition_8h__dep__incl.map (contents, props changed)
trunk/www/docs/ODBC/_odbc_ov_geometric_property_definition_8h__dep__incl.md5 (contents, props changed)
trunk/www/docs/ODBC/_odbc_ov_geometric_property_definition_8h__dep__incl.png (contents, props changed)
trunk/www/docs/ODBC/_odbc_ov_geometric_property_definition_8h__incl.map (contents, props changed)
trunk/www/docs/ODBC/_odbc_ov_geometric_property_definition_8h__incl.md5 (contents, props changed)
trunk/www/docs/ODBC/_odbc_ov_geometric_property_definition_8h__incl.png (contents, props changed)
trunk/www/docs/ODBC/_odbc_ov_physical_schema_mapping_8h-source.html (contents, props changed)
trunk/www/docs/ODBC/_odbc_ov_physical_schema_mapping_8h.html (contents, props changed)
trunk/www/docs/ODBC/_odbc_ov_physical_schema_mapping_8h_16e671a2edec1595ecd12c49caee7f95.html (contents, props changed)
trunk/www/docs/ODBC/_odbc_ov_physical_schema_mapping_8h__incl.map (contents, props changed)
trunk/www/docs/ODBC/_odbc_ov_physical_schema_mapping_8h__incl.md5 (contents, props changed)
trunk/www/docs/ODBC/_odbc_ov_physical_schema_mapping_8h__incl.png (contents, props changed)
trunk/www/docs/ODBC/_odbc_ov_property_definition_8h-source.html (contents, props changed)
trunk/www/docs/ODBC/_odbc_ov_property_definition_8h.html (contents, props changed)
trunk/www/docs/ODBC/_odbc_ov_property_definition_8h_7b052f5fa1f33d3d0016cf2ff0282b03.html (contents, props changed)
trunk/www/docs/ODBC/_odbc_ov_property_definition_8h__dep__incl.map (contents, props changed)
trunk/www/docs/ODBC/_odbc_ov_property_definition_8h__dep__incl.md5 (contents, props changed)
trunk/www/docs/ODBC/_odbc_ov_property_definition_8h__dep__incl.png (contents, props changed)
trunk/www/docs/ODBC/_odbc_ov_property_definition_8h__incl.map (contents, props changed)
trunk/www/docs/ODBC/_odbc_ov_property_definition_8h__incl.md5 (contents, props changed)
trunk/www/docs/ODBC/_odbc_ov_property_definition_8h__incl.png (contents, props changed)
trunk/www/docs/ODBC/_odbc_ov_property_definition_collection_8h-source.html (contents, props changed)
trunk/www/docs/ODBC/_odbc_ov_property_definition_collection_8h.html (contents, props changed)
trunk/www/docs/ODBC/_odbc_ov_property_definition_collection_8h__dep__incl.map (contents, props changed)
trunk/www/docs/ODBC/_odbc_ov_property_definition_collection_8h__dep__incl.md5 (contents, props changed)
trunk/www/docs/ODBC/_odbc_ov_property_definition_collection_8h__dep__incl.png (contents, props changed)
trunk/www/docs/ODBC/_odbc_ov_property_definition_collection_8h__incl.map (contents, props changed)
trunk/www/docs/ODBC/_odbc_ov_property_definition_collection_8h__incl.md5 (contents, props changed)
trunk/www/docs/ODBC/_odbc_ov_property_definition_collection_8h__incl.png (contents, props changed)
trunk/www/docs/ODBC/_odbc_ov_property_definition_collection_8h_da3ba8c7ff9ce10201957d8e68f55300.html (contents, props changed)
trunk/www/docs/ODBC/_odbc_ov_table_8h-source.html (contents, props changed)
trunk/www/docs/ODBC/_odbc_ov_table_8h.html (contents, props changed)
trunk/www/docs/ODBC/_odbc_ov_table_8h_073b61edcaf447b7d0a9b9b17cea198b.html (contents, props changed)
trunk/www/docs/ODBC/_odbc_ov_table_8h__dep__incl.map (contents, props changed)
trunk/www/docs/ODBC/_odbc_ov_table_8h__dep__incl.md5 (contents, props changed)
trunk/www/docs/ODBC/_odbc_ov_table_8h__dep__incl.png (contents, props changed)
trunk/www/docs/ODBC/_odbc_ov_table_8h__incl.map (contents, props changed)
trunk/www/docs/ODBC/_odbc_ov_table_8h__incl.md5 (contents, props changed)
trunk/www/docs/ODBC/_odbc_ov_table_8h__incl.png (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_8h-source.html (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_8h.html (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_8h__dep__incl.map (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_8h__dep__incl.md5 (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_8h__dep__incl.png (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_association_property_definition_8h-source.html (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_association_property_definition_8h.html (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_association_property_definition_8h__incl.map (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_association_property_definition_8h__incl.md5 (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_association_property_definition_8h__incl.png (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_class_collection_8h-source.html (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_class_collection_8h.html (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_class_collection_8h_26ee985d3d48ae9904b2d8f4528b6b9c.html (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_class_collection_8h__dep__incl.map (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_class_collection_8h__dep__incl.md5 (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_class_collection_8h__dep__incl.png (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_class_collection_8h__incl.map (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_class_collection_8h__incl.md5 (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_class_collection_8h__incl.png (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_class_collection_8h_f361019b6db0e19fbf2265c24420ba09.html (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_class_definition_8h-source.html (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_class_definition_8h.html (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_class_definition_8h_95c424bcc48087ac80719d81150c51c5.html (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_class_definition_8h__dep__incl.map (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_class_definition_8h__dep__incl.md5 (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_class_definition_8h__dep__incl.png (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_class_definition_8h__incl.map (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_class_definition_8h__incl.md5 (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_class_definition_8h__incl.png (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_column_8h-source.html (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_column_8h.html (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_column_8h__dep__incl.map (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_column_8h__dep__incl.md5 (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_column_8h__dep__incl.png (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_column_8h__incl.map (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_column_8h__incl.md5 (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_column_8h__incl.png (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_column_8h_be8c4edc8774e74cb12d266f13e76f07.html (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_data_property_definition_8h-source.html (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_data_property_definition_8h.html (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_data_property_definition_8h__dep__incl.map (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_data_property_definition_8h__dep__incl.md5 (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_data_property_definition_8h__dep__incl.png (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_data_property_definition_8h__incl.map (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_data_property_definition_8h__incl.md5 (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_data_property_definition_8h__incl.png (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_data_property_definition_8h_fb7f707266f7220c654ef63b0248531c.html (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_geometric_column_8h-source.html (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_geometric_column_8h.html (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_geometric_column_8h_6041d0e4455167520365a3628c75f7c1.html (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_geometric_column_8h__dep__incl.map (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_geometric_column_8h__dep__incl.md5 (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_geometric_column_8h__dep__incl.png (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_geometric_column_8h__incl.map (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_geometric_column_8h__incl.md5 (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_geometric_column_8h__incl.png (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_geometric_property_definition_8h-source.html (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_geometric_property_definition_8h.html (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_geometric_property_definition_8h__dep__incl.map (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_geometric_property_definition_8h__dep__incl.md5 (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_geometric_property_definition_8h__dep__incl.png (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_geometric_property_definition_8h__incl.map (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_geometric_property_definition_8h__incl.md5 (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_geometric_property_definition_8h__incl.png (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_geometric_property_definition_8h_b9378490b3e08ad09a80d49a6a8aff7d.html (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_object_property_definition_8h-source.html (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_object_property_definition_8h.html (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_object_property_definition_8h_82a4996cf07e521712d6b26ac2aa96de.html (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_object_property_definition_8h__dep__incl.map (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_object_property_definition_8h__dep__incl.md5 (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_object_property_definition_8h__dep__incl.png (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_object_property_definition_8h__incl.map (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_object_property_definition_8h__incl.md5 (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_object_property_definition_8h__incl.png (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_physical_schema_mapping_8h-source.html (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_physical_schema_mapping_8h.html (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_physical_schema_mapping_8h_02cd08b9000105a1137aa76047cbd783.html (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_physical_schema_mapping_8h__dep__incl.map (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_physical_schema_mapping_8h__dep__incl.md5 (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_physical_schema_mapping_8h__dep__incl.png (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_physical_schema_mapping_8h__incl.map (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_physical_schema_mapping_8h__incl.md5 (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_physical_schema_mapping_8h__incl.png (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_property_definition_8h-source.html (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_property_definition_8h.html (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_property_definition_8h_24fedbc49697b547f171502e79aa9797.html (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_property_definition_8h__dep__incl.map (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_property_definition_8h__dep__incl.md5 (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_property_definition_8h__dep__incl.png (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_property_definition_8h__incl.map (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_property_definition_8h__incl.md5 (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_property_definition_8h__incl.png (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_property_definition_collection_8h-source.html (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_property_definition_collection_8h.html (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_property_definition_collection_8h_28f0f2c56e33f94a7d96751ec866475a.html (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_property_definition_collection_8h_8a7a02562b4dcd8bbbf507c92753c27c.html (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_property_definition_collection_8h__dep__incl.map (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_property_definition_collection_8h__dep__incl.md5 (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_property_definition_collection_8h__dep__incl.png (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_property_definition_collection_8h__incl.map (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_property_definition_collection_8h__incl.md5 (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_property_definition_collection_8h__incl.png (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_property_mapping_class_8h-source.html (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_property_mapping_class_8h.html (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_property_mapping_class_8h_87b56c23456a68ff05d9b74e4dd72dc2.html (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_property_mapping_class_8h__dep__incl.map (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_property_mapping_class_8h__dep__incl.md5 (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_property_mapping_class_8h__dep__incl.png (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_property_mapping_class_8h__incl.map (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_property_mapping_class_8h__incl.md5 (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_property_mapping_class_8h__incl.png (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_property_mapping_concrete_8h-source.html (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_property_mapping_concrete_8h.html (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_property_mapping_concrete_8h_5dd5fae46254c872392b8b0aa0552f92.html (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_property_mapping_concrete_8h__dep__incl.map (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_property_mapping_concrete_8h__dep__incl.md5 (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_property_mapping_concrete_8h__dep__incl.png (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_property_mapping_concrete_8h__incl.map (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_property_mapping_concrete_8h__incl.md5 (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_property_mapping_concrete_8h__incl.png (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_property_mapping_definition_8h-source.html (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_property_mapping_definition_8h.html (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_property_mapping_definition_8h__dep__incl.map (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_property_mapping_definition_8h__dep__incl.md5 (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_property_mapping_definition_8h__dep__incl.png (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_property_mapping_definition_8h__incl.map (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_property_mapping_definition_8h__incl.md5 (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_property_mapping_definition_8h__incl.png (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_property_mapping_definition_8h_c13fe6b320fc1f174d6079b9651cd759.html (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_property_mapping_relation_8h-source.html (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_property_mapping_relation_8h.html (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_property_mapping_relation_8h__dep__incl.map (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_property_mapping_relation_8h__dep__incl.md5 (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_property_mapping_relation_8h__dep__incl.png (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_property_mapping_relation_8h__incl.map (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_property_mapping_relation_8h__incl.md5 (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_property_mapping_relation_8h__incl.png (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_property_mapping_relation_8h_b3f57932c53a39a0aa8aa9928ff972eb.html (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_property_mapping_single_8h-source.html (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_property_mapping_single_8h.html (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_property_mapping_single_8h__dep__incl.map (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_property_mapping_single_8h__dep__incl.md5 (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_property_mapping_single_8h__dep__incl.png (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_property_mapping_single_8h__incl.map (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_property_mapping_single_8h__incl.md5 (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_property_mapping_single_8h__incl.png (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_property_mapping_single_8h_d486b981d11220f25c37a429705aea57.html (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_schema_auto_generation_8h-source.html (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_schema_auto_generation_8h.html (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_schema_auto_generation_8h_499cf448778c4955e4e0f6776244c105.html (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_schema_auto_generation_8h__dep__incl.map (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_schema_auto_generation_8h__dep__incl.md5 (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_schema_auto_generation_8h__dep__incl.png (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_schema_auto_generation_8h__incl.map (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_schema_auto_generation_8h__incl.md5 (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_schema_auto_generation_8h__incl.png (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_table_8h-source.html (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_table_8h.html (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_table_8h_612b061ebc8babde7d8d0ef0943742cb.html (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_table_8h__dep__incl.map (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_table_8h__dep__incl.md5 (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_table_8h__dep__incl.png (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_table_8h__incl.map (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_table_8h__incl.md5 (contents, props changed)
trunk/www/docs/ODBC/_rdbms_ov_table_8h__incl.png (contents, props changed)
trunk/www/docs/ODBC/annotated.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_odbc_ov_class_collection-members.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_odbc_ov_class_collection.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_odbc_ov_class_collection_352fb410434a2623f70ec357ad0f83a4.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_odbc_ov_class_collection_45aff3b8f9120525cef83de34b8c4e86.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_odbc_ov_class_collection_53a1361f8930b13a0bd99cc2f852a3c9.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_odbc_ov_class_collection_85228f4f3d85f61af7e0c7790b9f6adc.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_odbc_ov_class_collection_a5fb329c0358c77bb11ba905de514500.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_odbc_ov_class_collection_a9c29116c9e09ebd9644533ffce2bdad.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_odbc_ov_class_collection_ae8eb3969cc3870d6b5b57b2c3196d51.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_odbc_ov_class_definition-members.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_odbc_ov_class_definition.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_odbc_ov_class_definition_00157c4391485a3ecd13e67be92da9ec.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_odbc_ov_class_definition_21342b4a7fdbcf4744e09bc73a64c9c3.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_odbc_ov_class_definition_3e0b0a6270eb712b771b0c105ac66c81.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_odbc_ov_class_definition_461c57fb77cb2c090a6bddab1455688a.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_odbc_ov_class_definition_4f9806910e6d083e4c8b7fb5ba8f40a8.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_odbc_ov_class_definition_5a591790d6e74e348d2227618fc99d78.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_odbc_ov_class_definition_728ebb53c3deb7c9703d69548df686ef.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_odbc_ov_class_definition_87a4c8fe37b18475aa03c3b17eb0d94a.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_odbc_ov_class_definition_8b39782d6a8f8c2d4a483771ced7df8e.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_odbc_ov_class_definition_903d6c0adf72890f2c1eb8a9e58fa078.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_odbc_ov_class_definition__inherit__graph.map (contents, props changed)
trunk/www/docs/ODBC/class_fdo_odbc_ov_class_definition__inherit__graph.md5 (contents, props changed)
trunk/www/docs/ODBC/class_fdo_odbc_ov_class_definition__inherit__graph.png (contents, props changed)
trunk/www/docs/ODBC/class_fdo_odbc_ov_class_definition_c1136439caf25e740e49d3195acbad8e.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_odbc_ov_class_definition_c881f0b09a83e8c2ddd7085597ab9b7c.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_odbc_ov_class_definition_ea3d32bfdcd6b87864bbacb927afc35a.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_odbc_ov_class_definition_f9dabe9332019053a8cd66b382623fdf.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_odbc_ov_column-members.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_odbc_ov_column.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_odbc_ov_column_077cfd6bd88f07e1341926f290bac1b8.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_odbc_ov_column_17b534d92991db28c97af211be630cc5.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_odbc_ov_column_1f28b6527c37a821a97768f0745198d2.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_odbc_ov_column_238bf6fbd015cd69495f0a50d64423cc.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_odbc_ov_column_2e706ada31d133a7ee1022ebf90d0fde.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_odbc_ov_column__inherit__graph.map (contents, props changed)
trunk/www/docs/ODBC/class_fdo_odbc_ov_column__inherit__graph.md5 (contents, props changed)
trunk/www/docs/ODBC/class_fdo_odbc_ov_column__inherit__graph.png (contents, props changed)
trunk/www/docs/ODBC/class_fdo_odbc_ov_column_a25dc7f0d606e09b0f7205e78f926da4.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_odbc_ov_column_a6fa4d2750344c449bffaa13be91f29d.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_odbc_ov_data_property_definition-members.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_odbc_ov_data_property_definition.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_odbc_ov_data_property_definition_0127527b281657c675e2f075b5a5381e.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_odbc_ov_data_property_definition_264b0c72c7493d4544b9ef3b23460a87.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_odbc_ov_data_property_definition_41e3b2773aaa5560dc3b8b8fa28782dc.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_odbc_ov_data_property_definition_6c89a8425d98e274f4c5b14f612ea027.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_odbc_ov_data_property_definition_86dd56d85e59ecaa71de82c2488cb2cb.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_odbc_ov_data_property_definition_978bea6673bc58a481a9a725e5508ce0.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_odbc_ov_data_property_definition__inherit__graph.map (contents, props changed)
trunk/www/docs/ODBC/class_fdo_odbc_ov_data_property_definition__inherit__graph.md5 (contents, props changed)
trunk/www/docs/ODBC/class_fdo_odbc_ov_data_property_definition__inherit__graph.png (contents, props changed)
trunk/www/docs/ODBC/class_fdo_odbc_ov_data_property_definition_b4f1391f2b6707ac76dc58ec5d6d5874.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_odbc_ov_data_property_definition_d016120b71b712a59cbc06f30045a08c.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_odbc_ov_geometric_property_definition-members.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_odbc_ov_geometric_property_definition.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_odbc_ov_geometric_property_definition_283648a2daeb09ebb34806e7a9b960f3.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_odbc_ov_geometric_property_definition__inherit__graph.map (contents, props changed)
trunk/www/docs/ODBC/class_fdo_odbc_ov_geometric_property_definition__inherit__graph.md5 (contents, props changed)
trunk/www/docs/ODBC/class_fdo_odbc_ov_geometric_property_definition__inherit__graph.png (contents, props changed)
trunk/www/docs/ODBC/class_fdo_odbc_ov_geometric_property_definition_cd67333f0e52cb45aa1e2428ae1587a6.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_odbc_ov_physical_schema_mapping-members.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_odbc_ov_physical_schema_mapping.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_odbc_ov_physical_schema_mapping_01f1189649d6a5f324cd066012e5fad0.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_odbc_ov_physical_schema_mapping_0e512fcbe78b6c3258bcd822988fdfa2.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_odbc_ov_physical_schema_mapping_13bd733f5dda9dfb5c082c5f747a7b4d.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_odbc_ov_physical_schema_mapping_1462526e1fd744995659a18d31253bcf.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_odbc_ov_physical_schema_mapping_1c0a7ecf79c3a25d76abaca1bc99e5c2.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_odbc_ov_physical_schema_mapping_1cca5fdb1b40bbe2efa466db2c9f27a2.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_odbc_ov_physical_schema_mapping_26ecb8ceedcbddcf00e3e697538ce01c.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_odbc_ov_physical_schema_mapping_74f6fe4a4266b1a72b63f3b0875246b0.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_odbc_ov_physical_schema_mapping_8bf14a911b6fc5754ff741f3fa4d9456.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_odbc_ov_physical_schema_mapping__inherit__graph.map (contents, props changed)
trunk/www/docs/ODBC/class_fdo_odbc_ov_physical_schema_mapping__inherit__graph.md5 (contents, props changed)
trunk/www/docs/ODBC/class_fdo_odbc_ov_physical_schema_mapping__inherit__graph.png (contents, props changed)
trunk/www/docs/ODBC/class_fdo_odbc_ov_physical_schema_mapping_aac5477e38a2e83d61113cd03d50710e.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_odbc_ov_physical_schema_mapping_d5025f56de7a427a5c9356974370c5ee.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_odbc_ov_property_definition-members.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_odbc_ov_property_definition.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_odbc_ov_property_definition_24a908a2541982ff60a17e6b819f365d.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_odbc_ov_property_definition_55cd087e142f097d0a9dae6fd63489fc.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_odbc_ov_property_definition_6b4a0d61ef13d1c1271b58ec47eea75c.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_odbc_ov_property_definition_6fc812d7505d71d1fd82a54cded73119.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_odbc_ov_property_definition__inherit__graph.map (contents, props changed)
trunk/www/docs/ODBC/class_fdo_odbc_ov_property_definition__inherit__graph.md5 (contents, props changed)
trunk/www/docs/ODBC/class_fdo_odbc_ov_property_definition__inherit__graph.png (contents, props changed)
trunk/www/docs/ODBC/class_fdo_odbc_ov_property_definition_collection-members.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_odbc_ov_property_definition_collection.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_odbc_ov_property_definition_collection_47b59ec3253b234e92764a0eab625aaf.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_odbc_ov_property_definition_collection_4f891687e268fe821988c4957c1da2fd.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_odbc_ov_property_definition_collection_5704d820b51c74f06ae2055a476ebc92.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_odbc_ov_property_definition_collection_83508e8306545e4d2f160ccf37c110bd.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_odbc_ov_property_definition_collection_98c588a89787bccc711970c9d1dcc4f4.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_odbc_ov_property_definition_collection_b482b0206f4cefb72ca99592cbccf12e.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_odbc_ov_property_definition_collection_d8a740d445aa7746c49809e86cf67fa7.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_odbc_ov_property_definition_e54002ef0bb97c94a554bf22a28d4fc0.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_odbc_ov_table-members.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_odbc_ov_table.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_odbc_ov_table_2009c866e6875cd10648a1778d310850.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_odbc_ov_table_5176dca2d64619cb88a8d10cac7faf17.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_odbc_ov_table_5f8ebb1fc58222ab31eea159fe718d96.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_odbc_ov_table__inherit__graph.map (contents, props changed)
trunk/www/docs/ODBC/class_fdo_odbc_ov_table__inherit__graph.md5 (contents, props changed)
trunk/www/docs/ODBC/class_fdo_odbc_ov_table__inherit__graph.png (contents, props changed)
trunk/www/docs/ODBC/class_fdo_odbc_ov_table_e4cb40081e9a8c67fcc63ae2b23c2a88.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_odbc_ov_table_f59cdd955a259cd5b05f4acdc03b232c.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_odbc_ov_table_faead8b2ea534e1e12ac8dda2efd087b.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_association_property_definition-members.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_association_property_definition.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_association_property_definition_2825a113f289eceadbb57f51c963c6a7.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_association_property_definition_35daee263dadfc1e35ef63cc08409d82.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_association_property_definition_387c25774cbaeae9a745a888e0c20e62.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_association_property_definition_74dc114c67d46fbe5bccf6215dfc1b0a.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_association_property_definition__inherit__graph.map (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_association_property_definition__inherit__graph.md5 (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_association_property_definition__inherit__graph.png (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_association_property_definition_f02db222ef7cf482901f3828f99d5d9d.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_class_collection-members.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_class_collection.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_class_collection_1be601498d10586902435a82cf602417.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_class_collection_33b7ad497be3d84ea74dafcd3d227cc8.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_class_collection_3c926b10a44e3704bbca871194c4822e.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_class_collection_425cfaabd885fbcd5118512afee1cc3e.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_class_collection_61efa167a392917361e7f552507cef6b.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_class_collection_cc2c194d085a6b28d2b921746ef2dbd4.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_class_definition-members.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_class_definition.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_class_definition_13055d78afb38b416bfa382b53b1d52c.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_class_definition_14dd2ceb64c6717fce9e0c4b42453c38.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_class_definition_1964e0fff0115e528f7aa328c19cc7fd.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_class_definition_1d3f4570f3a7eb4c89367dc8be9327e4.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_class_definition_1f7f96e74f1fd02b5e674ffc00fafca1.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_class_definition_4600f7daf28d8e3301f768bcce460fd1.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_class_definition_4ff68496a1501f813642d416cf239d48.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_class_definition_55ba186d10bdc2d88c18659edc0722c9.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_class_definition_67aeba1b9893aba90139cb89f0e99d79.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_class_definition_865da921ba083d63cb9c34c3e8bd5808.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_class_definition_930aa466b8b22426b1091171d5875a39.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_class_definition_94c652ae4389ad6115f3ff0d3266e09d.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_class_definition_98af5a6fe61d7e563bc26fe0cd4bd9e8.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_class_definition_9a8be90a92df7487cec1224259e99833.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_class_definition__inherit__graph.map (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_class_definition__inherit__graph.md5 (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_class_definition__inherit__graph.png (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_class_definition_a25300e89cd1535e9b7b2f4605c0e413.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_class_definition_b9305a7abd05993ed4122ed92518584a.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_class_definition_e08591d4b92b0e41a9f5dfac8a71c48a.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_class_definition_e3b45851d6a9559b5ec696ff011275a5.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_class_definition_e400bdb98dda4fd85ede3f356df30148.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_class_definition_f8fbb294ca3859e5f5411f118131568a.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_class_definition_f9ed063657db3faadeeee7514de9cd4c.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_class_definition_fab708882de4a26ffd667ebeffd6901a.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_column-members.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_column.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_column_495202f59e8ec336cc6d5bc66384243f.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_column_77942ff6294b9fc20de8dcf5d37cbef7.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_column_799c09fe92f7297b6d9c6090513c0fed.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_column_9d822ac4ab67ca84c513507701c83fdf.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_column__inherit__graph.map (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_column__inherit__graph.md5 (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_column__inherit__graph.png (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_column_bde6620b08ab40c64ab8cff0c42087fa.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_column_ca382d01afaa99a48748a1aa4a507ca5.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_column_f0fe1927d526a04b0f2443b40e6a467b.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_column_ff4bd29c7e2627a70fb3b494cb316c0b.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_data_property_definition-members.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_data_property_definition.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_data_property_definition_181918f49709e7f5eb3fc15f8ce54b6a.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_data_property_definition_6c9bae4b23c707051c437d37fdaf5724.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_data_property_definition_956e7c893d7604567bee59fea598372e.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_data_property_definition__inherit__graph.map (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_data_property_definition__inherit__graph.md5 (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_data_property_definition__inherit__graph.png (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_data_property_definition_afa52c3c68762992a3a4c884b539fc36.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_data_property_definition_c331d9f501c089659f9772cf163b44b5.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_data_property_definition_f28f70532d721f4d8a7ec630b7c4bc18.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_geometric_column-members.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_geometric_column.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_geometric_column_0595676c1527c814e21c579d4e2a7bae.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_geometric_column_0b34b873e3a81534cefc3c5babc28579.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_geometric_column_10322c8c00d86b3e8b70aa61b39918f3.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_geometric_column_2ce5767658a73331eb5830a67f7b9cc7.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_geometric_column_894893cf60f212d0e956464549d0840c.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_geometric_column_aee998c9f9b97f772cb42b2ad6b90394.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_geometric_column_f905ae8553efaf4e8372635c5bfbc349.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_geometric_property_definition-members.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_geometric_property_definition.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_geometric_property_definition_0552d4c0287eb3f319ba6145e6e4e4b9.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_geometric_property_definition_4a942aa2e6b040ad0459d9bbf77316e5.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_geometric_property_definition_501f1bda658ff2fdd96013fa802fe716.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_geometric_property_definition_56c93e984644b106b6b9982cdc36429f.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_geometric_property_definition_77c26ccaadb05667df585711de57378f.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_geometric_property_definition_79b5f004b660853ab200775f23cb1bb8.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_geometric_property_definition_8227d146d4046be94740cc87f8a5a226.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_geometric_property_definition_839d3e58dc3a1cc5bd2db3e0e9c4587d.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_geometric_property_definition_8f68c8fb8c8a92c5e83b40e719dc6b37.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_geometric_property_definition_9039c8e9ceb849fd1edd847d2e39123e.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_geometric_property_definition_93edf55b34051a41079774e2beae1c2b.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_geometric_property_definition_9738cb21bb8933cbc597542ae7d12f50.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_geometric_property_definition_977e611393a45777ce3d90519e8871db.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_geometric_property_definition__inherit__graph.map (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_geometric_property_definition__inherit__graph.md5 (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_geometric_property_definition__inherit__graph.png (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_geometric_property_definition_a032fcec7424bf16e302bc86734a425b.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_geometric_property_definition_c3f9df50411d16e812630411b53a6a68.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_geometric_property_definition_c9c1de76e395eeecfa8bc0a46cb9a1d1.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_geometric_property_definition_d1e5d00fb0c70ea8d50c1171e27add9f.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_geometric_property_definition_ede8ec5d7f8dc2194be0c8472a8126ec.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_object_property_definition-members.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_object_property_definition.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_object_property_definition_03b019db58670b70b177331490de5db1.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_object_property_definition_1ab9fa891708a2986856f9f4aae7c8f4.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_object_property_definition_2643f55b32de68af05517e3679951f8c.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_object_property_definition_503d029a3d71167c08ed63c6c6970944.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_object_property_definition_55c9b086f2585c674b94e1f360a289d8.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_object_property_definition_83e55405dcaa9c75d31855e2e4cd9d85.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_object_property_definition_97a69b3eadb6dfa059ba803654348101.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_object_property_definition__inherit__graph.map (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_object_property_definition__inherit__graph.md5 (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_object_property_definition__inherit__graph.png (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_object_property_definition_eba244316cb1d22359f6a9d05e794514.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_object_property_definition_ed9566f0edf068a505dc8960399b9336.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_object_property_definition_f596496de1a0727160e669da1ad0bba0.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_physical_schema_mapping-members.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_physical_schema_mapping.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_physical_schema_mapping_04862ecbeba0b0f033f788eef3bc8afa.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_physical_schema_mapping_052d29b735fbe5300b6220ed14e5b69c.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_physical_schema_mapping_06c7286190a76e961adfa3fda7e9859b.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_physical_schema_mapping_0709948feb750e1ab594e7e7128a3242.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_physical_schema_mapping_0754e6d7807cd92a2b6cd1e3b3baa91d.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_physical_schema_mapping_11557baeabbdcc1a1fcc72dbf45d4552.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_physical_schema_mapping_17b84ebbae4f6b661f3d116e4b3b6311.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_physical_schema_mapping_1c5c4049eb5666870d94658cc6d81c35.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_physical_schema_mapping_3346828609c0761c0f9a35ce1da88cab.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_physical_schema_mapping_4548da0330caee9645a487b476ccaca8.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_physical_schema_mapping_4cc2d72e5cc5cc4ec3d542b175c93f9d.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_physical_schema_mapping_4e67fff5dc13e27ade8d86c10078d450.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_physical_schema_mapping_50943de96e62f86ca5d7a9446d907acd.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_physical_schema_mapping_58a9289ebd2279e26f4cbea8986b944c.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_physical_schema_mapping_645f9e612eb208b50977253407fb25ff.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_physical_schema_mapping_653d1d44a2788211776eb485a5e559d1.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_physical_schema_mapping__inherit__graph.map (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_physical_schema_mapping__inherit__graph.md5 (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_physical_schema_mapping__inherit__graph.png (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_physical_schema_mapping_b0626ba328793b256547581795c7800c.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_physical_schema_mapping_c4bef3220580bf67d9a8cf5adc1b3a7b.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_physical_schema_mapping_d70b968a3c44bb2c0eff6beebf4bae17.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_physical_schema_mapping_d7d73849b4f9326288e88ba27c0fc45f.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_physical_schema_mapping_ec2811d5d0786b98114b418d82b73743.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_property_definition-members.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_property_definition.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_property_definition_104a397f5939e3065086f2d68d239f28.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_property_definition_823cd2ad36c41c015df90b31ae19750f.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_property_definition_86f4ba556a337a842a3cc733a2224da9.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_property_definition__inherit__graph.map (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_property_definition__inherit__graph.md5 (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_property_definition__inherit__graph.png (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_property_definition_a394465c946ccaa44822e0ca5c5ef7a6.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_property_definition_bd6d7567bee9cc782c1cbba4389cda93.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_property_definition_cc9a4992e82b491746578b2373159765.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_property_definition_collection-members.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_property_definition_collection.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_property_definition_collection_5e8cd1eb4ef957615a8dd13619c5529f.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_property_definition_collection_83e134c7680f3ac1852b9a8df6425f20.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_property_definition_collection_a0126b8a5d732915e4fd81bc3402b840.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_property_definition_collection_c1b7fccc469533409689a1606683fde0.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_property_definition_collection_dd8070b745a257212667fe17c0b197f0.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_property_definition_collection_ffbf059f678c27fd89119c764b1ef421.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_property_mapping_class-members.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_property_mapping_class.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_property_mapping_class_11df41f413f9fddc8c8c38ee5c9f57f1.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_property_mapping_class_2810b377bdf9fe163c79025830050031.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_property_mapping_class_6c0ceb2307027764dc492ee5a8ac015c.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_property_mapping_class__inherit__graph.map (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_property_mapping_class__inherit__graph.md5 (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_property_mapping_class__inherit__graph.png (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_property_mapping_class_be09a24c031113087f0f394e68edd78e.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_property_mapping_class_c0ef144c3f8043866b707e2f23eef679.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_property_mapping_concrete-members.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_property_mapping_concrete.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_property_mapping_concrete_2acece23c9aa45246c2bbbee429b125d.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_property_mapping_concrete_48435a417f70333a2842a6ce86a8549b.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_property_mapping_concrete_644c838b9f4e37a19527c10a6d0011e6.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_property_mapping_concrete__inherit__graph.map (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_property_mapping_concrete__inherit__graph.md5 (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_property_mapping_concrete__inherit__graph.png (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_property_mapping_concrete_cda5ea045747502d5eecf8e128d9e7c1.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_property_mapping_concrete_e60c778281acc929d697bd460fcf8586.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_property_mapping_definition-members.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_property_mapping_definition.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_property_mapping_definition_03db45b676deef2a9e820e534e4ed02d.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_property_mapping_definition_3ae359b6b7e658824cf186b2d3c9ad3f.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_property_mapping_definition_618997b863b2a1ea642f2f0864830af9.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_property_mapping_definition_641cc7da4e8e0696744a5ca8dbf70cb0.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_property_mapping_definition__inherit__graph.map (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_property_mapping_definition__inherit__graph.md5 (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_property_mapping_definition__inherit__graph.png (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_property_mapping_definition_b100a514d000b4ebb6a95be24740b0ad.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_property_mapping_relation-members.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_property_mapping_relation.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_property_mapping_relation_0356f294429f9f0a4f0e980c0309e239.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_property_mapping_relation_1d0a1c240408b951d053f580cc4e10f8.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_property_mapping_relation_3bcb1a60ae2ab9b8868a022b32624e0d.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_property_mapping_relation_4c64aa5b06cd639b6f599ea0a3776589.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_property_mapping_relation_5e75bb8248eeb703d6d8c47493247ff6.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_property_mapping_relation_8ff17d9dc1c74beefcfdeb5c166dd40d.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_property_mapping_relation_9ec78dd558383c1fbd77f0f611222932.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_property_mapping_relation__inherit__graph.map (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_property_mapping_relation__inherit__graph.md5 (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_property_mapping_relation__inherit__graph.png (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_property_mapping_relation_e8a263e8c6dc2b9351f6e7f0101c88e5.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_property_mapping_single-members.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_property_mapping_single.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_property_mapping_single_1a5d483c26b31cabd3871a10be45a90c.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_property_mapping_single_39313f76df020263766b8c10479ad257.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_property_mapping_single_4432ebee838b92bc50276c016b50734f.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_property_mapping_single_7bb0d36e5fc78a8d91adb1ea79f77c1e.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_property_mapping_single_7be8a29544577d9bfaa883ca263ddad7.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_property_mapping_single_8e0e30c1088348915153f06684c83ca1.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_property_mapping_single__inherit__graph.map (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_property_mapping_single__inherit__graph.md5 (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_property_mapping_single__inherit__graph.png (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_property_mapping_single_b17c06ea2effe39282f1deddac722526.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_read_only_class_collection-members.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_read_only_class_collection.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_read_only_class_collection_08debf30e474b0e45b6c1c64ebc3d13e.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_read_only_class_collection_0b569963edfde52995939099ad755e54.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_read_only_class_collection_355f8ada79ff99509fa43a0de42c1ebb.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_read_only_class_collection_7b0936cb7438c96e8c6e9a60316ad577.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_read_only_class_collection_9bc9718b6cfa52075840f833be5fd246.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_read_only_class_collection_e1d2342cb65b1e7c92db9369dd1c9aed.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_read_only_property_definition_collection-members.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_read_only_property_definition_collection.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_read_only_property_definition_collection_4a95a07128e96e901e0eef4a30ce0f83.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_read_only_property_definition_collection_547f138c8fcd72288a76c152b1da3293.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_read_only_property_definition_collection_855bf7fdd382ba6cb4300990f34539fe.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_read_only_property_definition_collection_8a2c64bd01420a039115c009cbf81caf.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_read_only_property_definition_collection_99924ae0952f8540ef3650200b45987d.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_read_only_property_definition_collection_9a8ccc6c0b95faf0ae058bd72c055f32.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_schema_auto_generation-members.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_schema_auto_generation.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_schema_auto_generation_10607168b4dc6988da728924b9bf3a85.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_schema_auto_generation_172f90d8d0c7c0ce3a046186a70fa4b3.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_schema_auto_generation_1d003bbe339a1b983e450a9d3fe7f165.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_schema_auto_generation_1d8bc2acd02130612b4604abaf46b081.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_schema_auto_generation_4286f512b8811f479e47daa867b5ad20.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_schema_auto_generation_4ca740f68b29d8d40e9a817145d6dcff.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_schema_auto_generation_5366adde2b202582dc29ada8b0776b51.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_schema_auto_generation_894de2f28577f3309b384e23f269b4f3.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_schema_auto_generation_95910d04bc6fcf61cd88e4247c25e8b9.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_schema_auto_generation_a08327e0743427ccb6233ce25c0354e2.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_schema_auto_generation_b4a99aa44de049ec3363cb355ef0f05b.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_schema_auto_generation_bcccc6acca278bb74ecf48f848643763.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_schema_auto_generation_ddf56629e27d25b1f5e5457c807a1c5c.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_schema_auto_generation_fce5f95403f431707747d2bf0248ebd5.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_table-members.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_table.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_table_0e03dc3742dacf897c7f00dd19064882.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_table_209299ef102d4b5ee2b92763be873289.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_table_22cd99f83948f56058e375600c0690d5.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_table_2b3477c363a06d4c499e1a10691bea50.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_table_36b365e957e8aaadce79998310a89597.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_table_7c5c89a5bc08fe0c439bdc416bd39b7b.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_table_851524a620c0f7bd5668ea19d56dd718.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_table__inherit__graph.map (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_table__inherit__graph.md5 (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_table__inherit__graph.png (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_table_b002904d6ee0bd1c82ccb2da78277d60.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_table_dacd6e8b43927ba107a406a903ec380e.html (contents, props changed)
trunk/www/docs/ODBC/class_fdo_rdbms_ov_table_e678441f64a8c2efbaa724fefe79b302.html (contents, props changed)
trunk/www/docs/ODBC/classes.html (contents, props changed)
trunk/www/docs/ODBC/custom.css (contents, props changed)
trunk/www/docs/ODBC/define__pages_8h-source.html (contents, props changed)
trunk/www/docs/ODBC/define__pages_8h.html (contents, props changed)
trunk/www/docs/ODBC/doxygen.png (contents, props changed)
trunk/www/docs/ODBC/files.html (contents, props changed)
trunk/www/docs/ODBC/ftv2blank.png (contents, props changed)
trunk/www/docs/ODBC/ftv2doc.png (contents, props changed)
trunk/www/docs/ODBC/ftv2folderclosed.png (contents, props changed)
trunk/www/docs/ODBC/ftv2folderopen.png (contents, props changed)
trunk/www/docs/ODBC/ftv2lastnode.png (contents, props changed)
trunk/www/docs/ODBC/ftv2link.png (contents, props changed)
trunk/www/docs/ODBC/ftv2mlastnode.png (contents, props changed)
trunk/www/docs/ODBC/ftv2mnode.png (contents, props changed)
trunk/www/docs/ODBC/ftv2node.png (contents, props changed)
trunk/www/docs/ODBC/ftv2plastnode.png (contents, props changed)
trunk/www/docs/ODBC/ftv2pnode.png (contents, props changed)
trunk/www/docs/ODBC/ftv2vertline.png (contents, props changed)
trunk/www/docs/ODBC/functions.html (contents, props changed)
trunk/www/docs/ODBC/functions_func.html (contents, props changed)
trunk/www/docs/ODBC/functions_rela.html (contents, props changed)
trunk/www/docs/ODBC/globals.html (contents, props changed)
trunk/www/docs/ODBC/globals_defs.html (contents, props changed)
trunk/www/docs/ODBC/globals_type.html (contents, props changed)
trunk/www/docs/ODBC/graph_legend.dot (contents, props changed)
trunk/www/docs/ODBC/graph_legend.html (contents, props changed)
trunk/www/docs/ODBC/graph_legend.png (contents, props changed)
trunk/www/docs/ODBC/hierarchy.html (contents, props changed)
trunk/www/docs/ODBC/index.hhc (contents, props changed)
trunk/www/docs/ODBC/index.hhk (contents, props changed)
trunk/www/docs/ODBC/index.hhp (contents, props changed)
trunk/www/docs/ODBC/index.html (contents, props changed)
trunk/www/docs/ODBC/inherit__graph__0.map (contents, props changed)
trunk/www/docs/ODBC/inherit__graph__0.md5 (contents, props changed)
trunk/www/docs/ODBC/inherit__graph__0.png (contents, props changed)
trunk/www/docs/ODBC/inherit__graph__1.map (contents, props changed)
trunk/www/docs/ODBC/inherit__graph__1.md5 (contents, props changed)
trunk/www/docs/ODBC/inherit__graph__1.png (contents, props changed)
trunk/www/docs/ODBC/inherit__graph__10.map (contents, props changed)
trunk/www/docs/ODBC/inherit__graph__10.md5 (contents, props changed)
trunk/www/docs/ODBC/inherit__graph__10.png (contents, props changed)
trunk/www/docs/ODBC/inherit__graph__11.map (contents, props changed)
trunk/www/docs/ODBC/inherit__graph__11.md5 (contents, props changed)
trunk/www/docs/ODBC/inherit__graph__11.png (contents, props changed)
trunk/www/docs/ODBC/inherit__graph__12.map (contents, props changed)
trunk/www/docs/ODBC/inherit__graph__12.md5 (contents, props changed)
trunk/www/docs/ODBC/inherit__graph__12.png (contents, props changed)
trunk/www/docs/ODBC/inherit__graph__13.map (contents, props changed)
trunk/www/docs/ODBC/inherit__graph__13.md5 (contents, props changed)
trunk/www/docs/ODBC/inherit__graph__13.png (contents, props changed)
trunk/www/docs/ODBC/inherit__graph__2.map (contents, props changed)
trunk/www/docs/ODBC/inherit__graph__2.md5 (contents, props changed)
trunk/www/docs/ODBC/inherit__graph__2.png (contents, props changed)
trunk/www/docs/ODBC/inherit__graph__3.map (contents, props changed)
trunk/www/docs/ODBC/inherit__graph__3.md5 (contents, props changed)
trunk/www/docs/ODBC/inherit__graph__3.png (contents, props changed)
trunk/www/docs/ODBC/inherit__graph__4.map (contents, props changed)
trunk/www/docs/ODBC/inherit__graph__4.md5 (contents, props changed)
trunk/www/docs/ODBC/inherit__graph__4.png (contents, props changed)
trunk/www/docs/ODBC/inherit__graph__5.map (contents, props changed)
trunk/www/docs/ODBC/inherit__graph__5.md5 (contents, props changed)
trunk/www/docs/ODBC/inherit__graph__5.png (contents, props changed)
trunk/www/docs/ODBC/inherit__graph__6.map (contents, props changed)
trunk/www/docs/ODBC/inherit__graph__6.md5 (contents, props changed)
trunk/www/docs/ODBC/inherit__graph__6.png (contents, props changed)
trunk/www/docs/ODBC/inherit__graph__7.map (contents, props changed)
trunk/www/docs/ODBC/inherit__graph__7.md5 (contents, props changed)
trunk/www/docs/ODBC/inherit__graph__7.png (contents, props changed)
trunk/www/docs/ODBC/inherit__graph__8.map (contents, props changed)
trunk/www/docs/ODBC/inherit__graph__8.md5 (contents, props changed)
trunk/www/docs/ODBC/inherit__graph__8.png (contents, props changed)
trunk/www/docs/ODBC/inherit__graph__9.map (contents, props changed)
trunk/www/docs/ODBC/inherit__graph__9.md5 (contents, props changed)
trunk/www/docs/ODBC/inherit__graph__9.png (contents, props changed)
trunk/www/docs/ODBC/inherits.html (contents, props changed)
trunk/www/docs/ODBC/main.html (contents, props changed)
trunk/www/docs/ODBC/tab_b.gif (contents, props changed)
trunk/www/docs/ODBC/tab_l.gif (contents, props changed)
trunk/www/docs/ODBC/tab_r.gif (contents, props changed)
trunk/www/docs/ODBC/tabs.css (contents, props changed)
trunk/www/docs/ODBC/tree.html (contents, props changed)
FDO111: Update FDO Web Documentation (3.2.0)
Added: trunk/www/docs/ODBC/_odbc_ov_8h-source.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_odbc_ov_8h-source.html?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_odbc_ov_8h-source.html 2006-12-01 20:39:06+0000
@@ -0,0 +1,81 @@
+<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN" "http://www.w3.org/TR/html4/loose.dtd">
+<html>
+ <head>
+ <meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
+ <title>OSGeo FDO Provider for ODBC API Reference</title>
+ <link href="custom.css" rel="stylesheet" type="text/css">
+ <link href="tabs.css" rel="stylesheet" type="text/css">
+ </head>
+ <body bgcolor="#FFFFFF">
+ <table width="100%" border="0">
+ <tr>
+ <td><b>API Reference<b></td>
+ <td align="right"><b>OSGeo FDO Provider for ODBC<b></td>
+ </tr>
+ </table>
+<!-- End of: header.html -->
+<!-- Generated by Doxygen 1.4.6-NO -->
+<div class="tabs">
+ <ul>
+ <li><a href="main.html"><span>Main Page</span></a></li>
+ <li><a href="classes.html"><span>Classes</span></a></li>
+ <li id="current"><a href="files.html"><span>Files</span></a></li>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ <li><a href="files.html"><span>File List</span></a></li>
+ <li><a href="globals.html"><span>File Members</span></a></li>
+ </ul></div>
+<h1>OdbcOv.h</h1><a href="_odbc_ov_8h.html">Go to the documentation of this file.</a><div class="fragment"><pre class="fragment"><a name="l00001"></a>00001 <span class="comment">//</span>
+<a name="l00002"></a>00002 <span class="comment">// Copyright (C) 2004-2006 Autodesk, Inc.</span>
+<a name="l00003"></a>00003 <span class="comment">// </span>
+<a name="l00004"></a>00004 <span class="comment">// This library is free software; you can redistribute it and/or</span>
+<a name="l00005"></a>00005 <span class="comment">// modify it under the terms of version 2.1 of the GNU Lesser</span>
+<a name="l00006"></a>00006 <span class="comment">// General Public License as published by the Free Software Foundation.</span>
+<a name="l00007"></a>00007 <span class="comment">// </span>
+<a name="l00008"></a>00008 <span class="comment">// This library is distributed in the hope that it will be useful,</span>
+<a name="l00009"></a>00009 <span class="comment">// but WITHOUT ANY WARRANTY; without even the implied warranty of</span>
+<a name="l00010"></a>00010 <span class="comment">// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU</span>
+<a name="l00011"></a>00011 <span class="comment">// Lesser General Public License for more details.</span>
+<a name="l00012"></a>00012 <span class="comment">// </span>
+<a name="l00013"></a>00013 <span class="comment">// You should have received a copy of the GNU Lesser General Public</span>
+<a name="l00014"></a>00014 <span class="comment">// License along with this library; if not, write to the Free Software</span>
+<a name="l00015"></a>00015 <span class="comment">// Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA</span>
+<a name="l00016"></a>00016 <span class="comment">//</span>
+<a name="l00017"></a>00017
+<a name="l00018"></a>00018 <span class="preprocessor">#ifndef FDOODBC_OV_H</span>
+<a name="l00019"></a>00019 <span class="preprocessor"></span><span class="preprocessor">#define FDOODBC_OV_H</span>
+<a name="l00020"></a>00020 <span class="preprocessor"></span><span class="preprocessor">#ifdef _WIN32</span>
+<a name="l00021"></a>00021 <span class="preprocessor"></span><span class="preprocessor">#pragma once</span>
+<a name="l00022"></a>00022 <span class="preprocessor"></span><span class="preprocessor">#endif</span>
+<a name="l00023"></a>00023 <span class="preprocessor"></span>
+<a name="l00024"></a>00024 <span class="comment">// The following ifdef block is the standard way of creating macros which make exporting</span>
+<a name="l00025"></a>00025 <span class="comment">// from a DLL simpler. All files within this DLL are compiled with the FDOODBC_OV_EXPORTS</span>
+<a name="l00026"></a>00026 <span class="comment">// symbol defined. The FDO_EXPORTS symbol should not be defined on any project</span>
+<a name="l00027"></a>00027 <span class="comment">// that uses this DLL. This way any other project whose source files include this file see</span>
+<a name="l00028"></a>00028 <span class="comment">// FDOODBC_OV_API functions as being imported from a DLL, whereas this DLL sees symbols</span>
+<a name="l00029"></a>00029 <span class="comment">// defined with this macro as being exported.</span>
+<a name="l00030"></a>00030 <span class="preprocessor">#ifdef _WIN32</span>
+<a name="l00031"></a>00031 <span class="preprocessor"></span><span class="preprocessor">#ifdef FDOODBC_OV_EXPORTS</span>
+<a name="l00032"></a>00032 <span class="preprocessor"></span><span class="preprocessor">#define FDOODBC_OV_API __declspec(dllexport)</span>
+<a name="l00033"></a>00033 <span class="preprocessor"></span><span class="preprocessor">#else</span>
+<a name="l00034"></a>00034 <span class="preprocessor"></span><span class="preprocessor">#define FDOODBC_OV_API __declspec(dllimport)</span>
+<a name="l00035"></a>00035 <span class="preprocessor"></span><span class="preprocessor">#endif</span>
+<a name="l00036"></a>00036 <span class="preprocessor"></span><span class="preprocessor">#else</span>
+<a name="l00037"></a><a class="code" href="_odbc_ov_8h_91b15f0fd565be7c245bbe8e5247fbdc.html#91b15f0fd565be7c245bbe8e5247fbdc">00037</a> <span class="preprocessor"></span><span class="preprocessor">#define FDOODBC_OV_API</span>
+<a name="l00038"></a>00038 <span class="preprocessor"></span><span class="preprocessor">#endif</span>
+<a name="l00039"></a>00039 <span class="preprocessor"></span>
+<a name="l00040"></a>00040 <span class="preprocessor">#endif // FDOODBC_OV_H</span>
+<a name="l00041"></a>00041 <span class="preprocessor"></span>
+<a name="l00042"></a>00042
+</pre></div><!-- footer.html -->
+ <hr>
+ <tr>
+ <td align="right"><font size="-2"><a href="mailto:isd.docs at autodesk.com&subject=FDO%20Provider%20for%20ODBC%20API%20documentation">Comments?</a></font></td>
+ <!-- The logo can go in another cell, when we get one -->
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/ODBC/_odbc_ov_8h.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_odbc_ov_8h.html?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_odbc_ov_8h.html 2006-12-01 20:39:06+0000
@@ -0,0 +1,63 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<h1>OdbcOv.h File Reference</h1>
+<p>
+<p>
+This graph shows which files directly or indirectly include this file:<p><center><img src="_odbc_ov_8h__dep__incl.png" border="0" usemap="#OdbcOv.hdep_map" alt=""></center>
+<map name="OdbcOv.hdep_map">
+<area href="_odbc_ov_class_collection_8h.html" shape="rect" coords="900,95,1076,122" alt="">
+<area href="_odbc_ov_physical_schema_mapping_8h.html" shape="rect" coords="1125,70,1357,96" alt="">
+<area href="_odbc_ov_class_definition_8h.html" shape="rect" coords="679,222,852,248" alt="">
+<area href="_odbc_ov_column_8h.html" shape="rect" coords="169,450,297,476" alt="">
+<area href="_odbc_ov_data_property_definition_8h.html" shape="rect" coords="395,374,613,400" alt="">
+<area href="_odbc_ov_geometric_property_definition_8h.html" shape="rect" coords="377,247,631,274" alt="">
+<area href="_odbc_ov_property_definition_8h.html" shape="rect" coords="139,298,328,324" alt="">
+<area href="_odbc_ov_property_definition_collection_8h.html" shape="rect" coords="380,298,628,324" alt="">
+<area href="_odbc_ov_table_8h.html" shape="rect" coords="176,146,291,172" alt="">
+</map>
+<p>
+<a href="_odbc_ov_8h-source.html">Go to the source code of this file.</a><table border="0" cellpadding="0" cellspacing="0">
+<tr><td></td></tr>
+<tr><td colspan="2"><br><h2>Defines</h2></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">#define </td><td class="memItemRight" valign="bottom"><a class="el" href="_odbc_ov_8h_91b15f0fd565be7c245bbe8e5247fbdc.html#91b15f0fd565be7c245bbe8e5247fbdc">FDOODBC_OV_API</a></td></tr>
+</table>
+<!-- footer.html -->
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/ODBC/_odbc_ov_8h_91b15f0fd565be7c245bbe8e5247fbdc.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_odbc_ov_8h_91b15f0fd565be7c245bbe8e5247fbdc.html?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_odbc_ov_8h_91b15f0fd565be7c245bbe8e5247fbdc.html 2006-12-01 20:39:06+0000
@@ -0,0 +1,74 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ <li><a href="files.html"><span>Files</span></a></li>
+ </ul></div>
+<div class="nav">
+<a class="el" href="_odbc_ov_8h.html">OdbcOv.h</a></div>
+<table cellspacing="0" cellpadding="0" border="0">
+ <tr>
+ <td valign="top">
+ <div class="navtab">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="_odbc_ov_8h_91b15f0fd565be7c245bbe8e5247fbdc.html#91b15f0fd565be7c245bbe8e5247fbdc">FDOODBC_OV_API</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="91b15f0fd565be7c245bbe8e5247fbdc"></a><!-- doxytag: member="OdbcOv.h::FDOODBC_OV_API" ref="91b15f0fd565be7c245bbe8e5247fbdc" args="" --><p>
+<table class="mdTable" cellpadding="2" cellspacing="0">
+ <tr>
+ <td class="mdRow">
+ <table cellpadding="0" cellspacing="0" border="0">
+ <tr>
+ <td class="md" nowrap valign="top">#define FDOODBC_OV_API </td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+<table cellspacing="5" cellpadding="0" border="0">
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+<p>
+Definition at line <a class="el" href="_odbc_ov_8h-source.html#l00037">37</a> of file <a class="el" href="_odbc_ov_8h-source.html">OdbcOv.h</a>. </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/ODBC/_odbc_ov_8h__dep__incl.map
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_odbc_ov_8h__dep__incl.map?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_odbc_ov_8h__dep__incl.map 2006-12-01 20:39:06+0000
@@ -0,0 +1,10 @@
+base referer
+rect $_odbc_ov_class_collection_8h.html 900,95 1076,122
+rect $_odbc_ov_physical_schema_mapping_8h.html 1125,70 1357,96
+rect $_odbc_ov_class_definition_8h.html 679,222 852,248
+rect $_odbc_ov_column_8h.html 169,450 297,476
+rect $_odbc_ov_data_property_definition_8h.html 395,374 613,400
+rect $_odbc_ov_geometric_property_definition_8h.html 377,247 631,274
+rect $_odbc_ov_property_definition_8h.html 139,298 328,324
+rect $_odbc_ov_property_definition_collection_8h.html 380,298 628,324
+rect $_odbc_ov_table_8h.html 176,146 291,172
Added: trunk/www/docs/ODBC/_odbc_ov_8h__dep__incl.md5
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_odbc_ov_8h__dep__incl.md5?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_odbc_ov_8h__dep__incl.md5 2006-12-01 20:39:06+0000
@@ -0,0 +1 @@
+682d97feddea3401d4050e5152f68b7c
\ No newline at end of file
Added: trunk/www/docs/ODBC/_odbc_ov_8h__dep__incl.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_odbc_ov_8h__dep__incl.png?view=auto&rev=94
Binary file. No diff available.
Added: trunk/www/docs/ODBC/_odbc_ov_class_collection_8h-source.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_odbc_ov_class_collection_8h-source.html?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_odbc_ov_class_collection_8h-source.html 2006-12-01 20:39:06+0000
@@ -0,0 +1,106 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<h1>OdbcOvClassCollection.h</h1><a href="_odbc_ov_class_collection_8h.html">Go to the documentation of this file.</a><div class="fragment"><pre class="fragment"><a name="l00001"></a>00001 <span class="preprocessor">#ifndef FDO_OdbcOVCLASSCOLLECTION_H</span>
+<a name="l00002"></a>00002 <span class="preprocessor"></span><span class="preprocessor">#define FDO_OdbcOVCLASSCOLLECTION_H</span>
+<a name="l00003"></a>00003 <span class="preprocessor"></span><span class="comment">//</span>
+<a name="l00004"></a>00004 <span class="comment">//</span>
+<a name="l00005"></a>00005 <span class="comment">// Copyright (C) 2004-2006 Autodesk, Inc.</span>
+<a name="l00006"></a>00006 <span class="comment">// </span>
+<a name="l00007"></a>00007 <span class="comment">// This library is free software; you can redistribute it and/or</span>
+<a name="l00008"></a>00008 <span class="comment">// modify it under the terms of version 2.1 of the GNU Lesser</span>
+<a name="l00009"></a>00009 <span class="comment">// General Public License as published by the Free Software Foundation.</span>
+<a name="l00010"></a>00010 <span class="comment">// </span>
+<a name="l00011"></a>00011 <span class="comment">// This library is distributed in the hope that it will be useful,</span>
+<a name="l00012"></a>00012 <span class="comment">// but WITHOUT ANY WARRANTY; without even the implied warranty of</span>
+<a name="l00013"></a>00013 <span class="comment">// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU</span>
+<a name="l00014"></a>00014 <span class="comment">// Lesser General Public License for more details.</span>
+<a name="l00015"></a>00015 <span class="comment">// </span>
+<a name="l00016"></a>00016 <span class="comment">// You should have received a copy of the GNU Lesser General Public</span>
+<a name="l00017"></a>00017 <span class="comment">// License along with this library; if not, write to the Free Software</span>
+<a name="l00018"></a>00018 <span class="comment">// Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA</span>
+<a name="l00019"></a>00019 <span class="comment">//</span>
+<a name="l00020"></a>00020 <span class="preprocessor">#include <<a class="code" href="_odbc_ov_8h.html">Rdbms/Override/ODBC/OdbcOv.h</a>></span>
+<a name="l00021"></a>00021 <span class="preprocessor">#include <<a class="code" href="_odbc_ov_class_definition_8h.html">Rdbms/Override/ODBC/OdbcOvClassDefinition.h</a>></span>
+<a name="l00022"></a>00022 <span class="preprocessor">#include <<a class="code" href="_rdbms_ov_class_collection_8h.html">Rdbms/Override/RdbmsOvClassCollection.h</a>></span>
+<a name="l00023"></a>00023 <span class="preprocessor">#include <Fdo/Commands/Schema/PhysicalElementMappingCollection.h></span>
+<a name="l00024"></a>00024 <span class="comment"></span>
+<a name="l00025"></a>00025 <span class="comment">/// \brief</span>
+<a name="l00026"></a>00026 <span class="comment">/// Concrete class defining physical schema overrides for a collection of classes.</span>
+<a name="l00027"></a><a class="code" href="class_fdo_odbc_ov_class_collection.html">00027</a> <span class="comment"></span><span class="keyword">class </span><a class="code" href="class_fdo_odbc_ov_class_collection.html">FdoOdbcOvClassCollection</a> : <span class="keyword">public</span> FdoRestrictedNamedCollection<FdoRdbmsOvClassDefinition,FdoOdbcOvClassDefinition,FdoRdbmsOvClassCollection>
+<a name="l00028"></a>00028 {
+<a name="l00029"></a>00029 <span class="keyword">public</span>:<span class="comment"></span>
+<a name="l00030"></a>00030 <span class="comment"> /// \brief</span>
+<a name="l00031"></a>00031 <span class="comment"> /// Constructs a default of an FdoOdbcOvClassCollection</span>
+<a name="l00032"></a>00032 <span class="comment"> /// </span>
+<a name="l00033"></a>00033 <span class="comment"> /// \return</span>
+<a name="l00034"></a>00034 <span class="comment"> /// Returns FdoOdbcOvClassCollection</span>
+<a name="l00035"></a>00035 <span class="comment"> /// </span>
+<a name="l00036"></a>00036 <span class="comment"></span> <a class="code" href="_odbc_ov_8h_91b15f0fd565be7c245bbe8e5247fbdc.html#91b15f0fd565be7c245bbe8e5247fbdc">FDOODBC_OV_API</a> <span class="keyword">static</span> <a class="code" href="class_fdo_odbc_ov_class_collection.html">FdoOdbcOvClassCollection</a>* <a class="code" href="class_fdo_odbc_ov_class_collection_85228f4f3d85f61af7e0c7790b9f6adc.html#85228f4f3d85f61af7e0c7790b9f6adc">Create</a>();
+<a name="l00037"></a>00037 <span class="comment"></span>
+<a name="l00038"></a>00038 <span class="comment"> /// \brief</span>
+<a name="l00039"></a>00039 <span class="comment"> /// Constructs an instance of an FdoOdbcOvClassCollection using the specified arguments</span>
+<a name="l00040"></a>00040 <span class="comment"> /// </span>
+<a name="l00041"></a>00041 <span class="comment"> /// \param parent </span>
+<a name="l00042"></a>00042 <span class="comment"> /// Input parent</span>
+<a name="l00043"></a>00043 <span class="comment"> /// </span>
+<a name="l00044"></a>00044 <span class="comment"> /// \return</span>
+<a name="l00045"></a>00045 <span class="comment"> /// Returns FdoOdbcOvClassCollection</span>
+<a name="l00046"></a>00046 <span class="comment"> /// </span>
+<a name="l00047"></a>00047 <span class="comment"></span> <a class="code" href="_odbc_ov_8h_91b15f0fd565be7c245bbe8e5247fbdc.html#91b15f0fd565be7c245bbe8e5247fbdc">FDOODBC_OV_API</a> <span class="keyword">static</span> <a class="code" href="class_fdo_odbc_ov_class_collection.html">FdoOdbcOvClassCollection</a>* <a class="code" href="class_fdo_odbc_ov_class_collection_85228f4f3d85f61af7e0c7790b9f6adc.html#85228f4f3d85f61af7e0c7790b9f6adc">Create</a>(<a class="code" href="class_fdo_rdbms_ov_class_collection.html">FdoRdbmsOvClassCollection</a>* baseCollection);
+<a name="l00048"></a>00048
+<a name="l00049"></a>00049 <span class="keyword">protected</span>:
+<a name="l00050"></a>00050 <a class="code" href="class_fdo_odbc_ov_class_collection_352fb410434a2623f70ec357ad0f83a4.html#352fb410434a2623f70ec357ad0f83a4">FdoOdbcOvClassCollection</a>();
+<a name="l00051"></a>00051 <a class="code" href="class_fdo_odbc_ov_class_collection_352fb410434a2623f70ec357ad0f83a4.html#352fb410434a2623f70ec357ad0f83a4">FdoOdbcOvClassCollection</a>(<a class="code" href="class_fdo_rdbms_ov_class_collection.html">FdoRdbmsOvClassCollection</a>* baseCollection);
+<a name="l00052"></a>00052 <span class="keyword">virtual</span> <a class="code" href="class_fdo_odbc_ov_class_collection_45aff3b8f9120525cef83de34b8c4e86.html#45aff3b8f9120525cef83de34b8c4e86">~FdoOdbcOvClassCollection</a>();
+<a name="l00053"></a>00053 <span class="keyword">virtual</span> <span class="keywordtype">void</span> <a class="code" href="class_fdo_odbc_ov_class_collection_ae8eb3969cc3870d6b5b57b2c3196d51.html#ae8eb3969cc3870d6b5b57b2c3196d51">Dispose</a>();
+<a name="l00054"></a>00054
+<a name="l00055"></a>00055 <span class="keyword">virtual</span> <a class="code" href="class_fdo_odbc_ov_class_definition.html">FdoOdbcOvClassDefinition</a>* <a class="code" href="class_fdo_odbc_ov_class_collection_a5fb329c0358c77bb11ba905de514500.html#a5fb329c0358c77bb11ba905de514500">DownCast</a>( <a class="code" href="class_fdo_rdbms_ov_class_definition.html">FdoRdbmsOvClassDefinition</a>* value ) <span class="keyword">const</span>;
+<a name="l00056"></a>00056
+<a name="l00057"></a>00057 <span class="keyword">private</span>:
+<a name="l00058"></a>00058
+<a name="l00059"></a>00059 };
+<a name="l00060"></a>00060 <span class="comment"></span>
+<a name="l00061"></a>00061 <span class="comment">/// \brief</span>
+<a name="l00062"></a>00062 <span class="comment">/// FdoOdbcOvClassesP is a FdoPtr on FdoOdbcOvClassCollection, provided for convenience.</span>
+<a name="l00063"></a><a class="code" href="_odbc_ov_class_collection_8h_45dc2dbdb78cdf026c7aa3e26d67bd29.html#45dc2dbdb78cdf026c7aa3e26d67bd29">00063</a> <span class="comment"></span><span class="keyword">typedef</span> FdoPtr<FdoOdbcOvClassCollection> <a class="code" href="_odbc_ov_class_collection_8h_45dc2dbdb78cdf026c7aa3e26d67bd29.html#45dc2dbdb78cdf026c7aa3e26d67bd29">FdoOdbcOvClassesP</a>;
+<a name="l00064"></a>00064
+<a name="l00065"></a>00065 <span class="preprocessor">#endif</span>
+<a name="l00066"></a>00066 <span class="preprocessor"></span>
+<a name="l00067"></a>00067
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/ODBC/_odbc_ov_class_collection_8h.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_odbc_ov_class_collection_8h.html?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_odbc_ov_class_collection_8h.html 2006-12-01 20:39:06+0000
@@ -0,0 +1,72 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<h1>OdbcOvClassCollection.h File Reference</h1>
+<p>
+<code>#include <<a class="el" href="_odbc_ov_8h-source.html">Rdbms/Override/ODBC/OdbcOv.h</a>></code><br>
+<code>#include <<a class="el" href="_odbc_ov_class_definition_8h-source.html">Rdbms/Override/ODBC/OdbcOvClassDefinition.h</a>></code><br>
+<code>#include <<a class="el" href="_rdbms_ov_class_collection_8h-source.html">Rdbms/Override/RdbmsOvClassCollection.h</a>></code><br>
+<code>#include <Fdo/Commands/Schema/PhysicalElementMappingCollection.h></code><br>
+<p>
+Include dependency graph for OdbcOvClassCollection.h:<p><center><img src="_odbc_ov_class_collection_8h__incl.png" border="0" usemap="#OdbcOvClassCollection.h_map" alt=""></center>
+<map name="OdbcOvClassCollection.h_map">
+<area href="_odbc_ov_8h.html" shape="rect" coords="681,45,908,72" alt="">
+<area href="_odbc_ov_class_definition_8h.html" shape="rect" coords="231,57,548,84" alt="">
+<area href="_rdbms_ov_class_collection_8h.html" shape="rect" coords="245,108,533,135" alt="">
+</map>
+<p>
+This graph shows which files directly or indirectly include this file:<p><center><img src="_odbc_ov_class_collection_8h__dep__incl.png" border="0" usemap="#OdbcOvClassCollection.hdep_map" alt=""></center>
+<map name="OdbcOvClassCollection.hdep_map">
+<area href="_odbc_ov_physical_schema_mapping_8h.html" shape="rect" coords="232,7,464,33" alt="">
+</map>
+<p>
+<a href="_odbc_ov_class_collection_8h-source.html">Go to the source code of this file.</a><table border="0" cellpadding="0" cellspacing="0">
+<tr><td></td></tr>
+<tr><td colspan="2"><br><h2>Classes</h2></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">class </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_odbc_ov_class_collection.html">FdoOdbcOvClassCollection</a></td></tr>
+<tr><td class="mdescLeft"> </td><td class="mdescRight">Concrete class defining physical schema overrides for a collection of classes. <a href="class_fdo_odbc_ov_class_collection.html#_details">More...</a><br></td></tr>
+<tr><td colspan="2"><br><h2>Typedefs</h2></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">typedef FdoPtr< <a class="el" href="class_fdo_odbc_ov_class_collection.html">FdoOdbcOvClassCollection</a> > </td><td class="memItemRight" valign="bottom"><a class="el" href="_odbc_ov_class_collection_8h_45dc2dbdb78cdf026c7aa3e26d67bd29.html#45dc2dbdb78cdf026c7aa3e26d67bd29">FdoOdbcOvClassesP</a></td></tr>
+<tr><td class="mdescLeft"> </td><td class="mdescRight">FdoOdbcOvClassesP is a FdoPtr on <a class="el" href="class_fdo_odbc_ov_class_collection.html">FdoOdbcOvClassCollection</a>, provided for convenience. <a href="#45dc2dbdb78cdf026c7aa3e26d67bd29"></a><br></td></tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/ODBC/_odbc_ov_class_collection_8h_45dc2dbdb78cdf026c7aa3e26d67bd29.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_odbc_ov_class_collection_8h_45dc2dbdb78cdf026c7aa3e26d67bd29.html?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_odbc_ov_class_collection_8h_45dc2dbdb78cdf026c7aa3e26d67bd29.html 2006-12-01 20:39:06+0000
@@ -0,0 +1,76 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="nav">
+<a class="el" href="_odbc_ov_class_collection_8h.html">OdbcOvClassCollection.h</a></div>
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="_odbc_ov_class_collection_8h_45dc2dbdb78cdf026c7aa3e26d67bd29.html#45dc2dbdb78cdf026c7aa3e26d67bd29">FdoOdbcOvClassesP</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="45dc2dbdb78cdf026c7aa3e26d67bd29"></a><!-- doxytag: member="OdbcOvClassCollection.h::FdoOdbcOvClassesP" ref="45dc2dbdb78cdf026c7aa3e26d67bd29" args="" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">typedef FdoPtr<<a class="el" href="class_fdo_odbc_ov_class_collection.html">FdoOdbcOvClassCollection</a>> <a class="el" href="_odbc_ov_class_collection_8h_45dc2dbdb78cdf026c7aa3e26d67bd29.html#45dc2dbdb78cdf026c7aa3e26d67bd29">FdoOdbcOvClassesP</a> </td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+FdoOdbcOvClassesP is a FdoPtr on <a class="el" href="class_fdo_odbc_ov_class_collection.html">FdoOdbcOvClassCollection</a>, provided for convenience.
+<p>
+<p>
+Definition at line <a class="el" href="_odbc_ov_class_collection_8h-source.html#l00063">63</a> of file <a class="el" href="_odbc_ov_class_collection_8h-source.html">OdbcOvClassCollection.h</a>. </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/ODBC/_odbc_ov_class_collection_8h__dep__incl.map
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_odbc_ov_class_collection_8h__dep__incl.map?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_odbc_ov_class_collection_8h__dep__incl.map 2006-12-01 20:39:06+0000
@@ -0,0 +1,2 @@
+base referer
+rect $_odbc_ov_physical_schema_mapping_8h.html 232,7 464,33
Added: trunk/www/docs/ODBC/_odbc_ov_class_collection_8h__dep__incl.md5
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_odbc_ov_class_collection_8h__dep__incl.md5?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_odbc_ov_class_collection_8h__dep__incl.md5 2006-12-01 20:39:06+0000
@@ -0,0 +1 @@
+da579ab012b0ee5429bc3bffb4a5b538
Added: trunk/www/docs/ODBC/_odbc_ov_class_collection_8h__dep__incl.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_odbc_ov_class_collection_8h__dep__incl.png?view=auto&rev=94
Added: trunk/www/docs/ODBC/_odbc_ov_class_collection_8h__incl.map
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_odbc_ov_class_collection_8h__incl.map?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_odbc_ov_class_collection_8h__incl.map 2006-12-01 20:39:06+0000
@@ -0,0 +1,4 @@
+base referer
+rect $_odbc_ov_8h.html 681,45 908,72
+rect $_odbc_ov_class_definition_8h.html 231,57 548,84
+rect $_rdbms_ov_class_collection_8h.html 245,108 533,135
Added: trunk/www/docs/ODBC/_odbc_ov_class_collection_8h__incl.md5
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_odbc_ov_class_collection_8h__incl.md5?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_odbc_ov_class_collection_8h__incl.md5 2006-12-01 20:39:06+0000
@@ -0,0 +1 @@
+9419eda4b5fdf49bb24cc615517f0123
Added: trunk/www/docs/ODBC/_odbc_ov_class_collection_8h__incl.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_odbc_ov_class_collection_8h__incl.png?view=auto&rev=94
Added: trunk/www/docs/ODBC/_odbc_ov_class_definition_8h-source.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_odbc_ov_class_definition_8h-source.html?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_odbc_ov_class_definition_8h-source.html 2006-12-01 20:39:06+0000
@@ -0,0 +1,176 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<h1>OdbcOvClassDefinition.h</h1><a href="_odbc_ov_class_definition_8h.html">Go to the documentation of this file.</a><div class="fragment"><pre class="fragment"><a name="l00001"></a>00001 <span class="preprocessor">#ifndef FDO_ODBCOVCLASSDEFINITION_H</span>
+<a name="l00002"></a>00002 <span class="preprocessor"></span><span class="preprocessor">#define FDO_ODBCOVCLASSDEFINITION_H</span>
+<a name="l00020"></a>00020 <span class="preprocessor">#include <<a class="code" href="_rdbms_ov_class_definition_8h.html">Rdbms/Override/RdbmsOvClassDefinition.h</a>></span>
+<a name="l00021"></a>00021 <span class="preprocessor">#include <<a class="code" href="_odbc_ov_8h.html">Rdbms/Override/ODBC/OdbcOv.h</a>></span>
+<a name="l00022"></a>00022 <span class="preprocessor">#include <<a class="code" href="_odbc_ov_data_property_definition_8h.html">Rdbms/Override/ODBC/OdbcOvDataPropertyDefinition.h</a>></span>
+<a name="l00023"></a>00023 <span class="preprocessor">#include <<a class="code" href="_odbc_ov_geometric_property_definition_8h.html">Rdbms/Override/ODBC/OdbcOvGeometricPropertyDefinition.h</a>></span>
+<a name="l00024"></a>00024 <span class="preprocessor">#include <<a class="code" href="_odbc_ov_property_definition_collection_8h.html">Rdbms/Override/ODBC/OdbcOvPropertyDefinitionCollection.h</a>></span>
+<a name="l00025"></a>00025 <span class="preprocessor">#include <<a class="code" href="_odbc_ov_table_8h.html">Rdbms/Override/ODBC/OdbcOvTable.h</a>></span>
+<a name="l00026"></a>00026 <span class="comment"></span>
+<a name="l00027"></a>00027 <span class="comment">/// \brief</span>
+<a name="l00028"></a>00028 <span class="comment">/// Concrete class defining physical schema overrides for a class definition.</span>
+<a name="l00029"></a><a class="code" href="class_fdo_odbc_ov_class_definition.html">00029</a> <span class="comment"></span><span class="keyword">class </span><a class="code" href="class_fdo_odbc_ov_class_definition.html">FdoOdbcOvClassDefinition</a> : <span class="keyword">public</span> <a class="code" href="class_fdo_rdbms_ov_class_definition.html">FdoRdbmsOvClassDefinition</a>
+<a name="l00030"></a>00030 {
+<a name="l00032"></a>00032 <span class="keyword">public</span>:<span class="comment"></span>
+<a name="l00033"></a>00033 <span class="comment"> /// \brief</span>
+<a name="l00034"></a>00034 <span class="comment"> /// Constructs a default of an FdoOdbcOvClassDefinition</span>
+<a name="l00036"></a>00036 <span class="comment"> /// \return</span>
+<a name="l00037"></a>00037 <span class="comment"> /// Returns FdoOdbcOvClassDefinition</span>
+<a name="l00038"></a>00038 <span class="comment"> /// </span>
+<a name="l00039"></a>00039 <span class="comment"></span> <a class="code" href="_odbc_ov_8h_91b15f0fd565be7c245bbe8e5247fbdc.html#91b15f0fd565be7c245bbe8e5247fbdc">FDOODBC_OV_API</a> <span class="keyword">static</span> <a class="code" href="class_fdo_odbc_ov_class_definition.html">FdoOdbcOvClassDefinition</a>* <a class="code" href="class_fdo_odbc_ov_class_definition_c1136439caf25e740e49d3195acbad8e.html#c1136439caf25e740e49d3195acbad8e">Create</a>();
+<a name="l00040"></a>00040 <span class="comment"></span>
+<a name="l00041"></a>00041 <span class="comment"> /// \brief</span>
+<a name="l00042"></a>00042 <span class="comment"> /// Constructs an instance of an FdoOdbcOvClassDefinition using the specified arguments</span>
+<a name="l00044"></a>00044 <span class="comment"> /// \param name </span>
+<a name="l00045"></a>00045 <span class="comment"> /// Input name</span>
+<a name="l00047"></a>00047 <span class="comment"> /// \return</span>
+<a name="l00048"></a>00048 <span class="comment"> /// Returns FdoOdbcOvClassDefinition</span>
+<a name="l00049"></a>00049 <span class="comment"> /// </span>
+<a name="l00050"></a>00050 <span class="comment"></span> <a class="code" href="_odbc_ov_8h_91b15f0fd565be7c245bbe8e5247fbdc.html#91b15f0fd565be7c245bbe8e5247fbdc">FDOODBC_OV_API</a> <span class="keyword">static</span> <a class="code" href="class_fdo_odbc_ov_class_definition.html">FdoOdbcOvClassDefinition</a>* <a class="code" href="class_fdo_odbc_ov_class_definition_c1136439caf25e740e49d3195acbad8e.html#c1136439caf25e740e49d3195acbad8e">Create</a>(FdoString* name);
+<a name="l00051"></a>00051 <span class="comment"></span>
+<a name="l00052"></a>00052 <span class="comment"> /// \brief</span>
+<a name="l00053"></a>00053 <span class="comment"> /// Gets a collection of Odbc property overrides</span>
+<a name="l00054"></a>00054 <span class="comment"> /// </span>
+<a name="l00055"></a>00055 <span class="comment"> /// \return</span>
+<a name="l00056"></a>00056 <span class="comment"> /// Returns the collection of Odbc property overrides</span>
+<a name="l00057"></a>00057 <span class="comment"> /// </span>
+<a name="l00058"></a>00058 <span class="comment"></span> <a class="code" href="_odbc_ov_8h_91b15f0fd565be7c245bbe8e5247fbdc.html#91b15f0fd565be7c245bbe8e5247fbdc">FDOODBC_OV_API</a> <a class="code" href="class_fdo_odbc_ov_property_definition_collection.html">FdoOdbcOvPropertyDefinitionCollection</a>* <a class="code" href="class_fdo_odbc_ov_class_definition_8b39782d6a8f8c2d4a483771ced7df8e.html#8b39782d6a8f8c2d4a483771ced7df8e">GetProperties</a>();
+<a name="l00059"></a>00059 <span class="comment"></span>
+<a name="l00060"></a>00060 <span class="comment"> /// \brief</span>
+<a name="l00061"></a>00061 <span class="comment"> /// Gets the Odbc table override for this class override</span>
+<a name="l00062"></a>00062 <span class="comment"> /// </span>
+<a name="l00063"></a>00063 <span class="comment"> /// \return</span>
+<a name="l00064"></a>00064 <span class="comment"> /// Returns FdoOdbcOvTable</span>
+<a name="l00065"></a>00065 <span class="comment"> /// </span>
+<a name="l00066"></a>00066 <span class="comment"></span> <a class="code" href="_odbc_ov_8h_91b15f0fd565be7c245bbe8e5247fbdc.html#91b15f0fd565be7c245bbe8e5247fbdc">FDOODBC_OV_API</a> <a class="code" href="class_fdo_odbc_ov_table.html">FdoOdbcOvTable</a>* <a class="code" href="class_fdo_odbc_ov_class_definition_21342b4a7fdbcf4744e09bc73a64c9c3.html#21342b4a7fdbcf4744e09bc73a64c9c3">GetTable</a>();
+<a name="l00067"></a>00067 <span class="comment"></span>
+<a name="l00068"></a>00068 <span class="comment"> /// \brief</span>
+<a name="l00069"></a>00069 <span class="comment"> /// Sets the Odbc table override for this class override</span>
+<a name="l00070"></a>00070 <span class="comment"> /// </span>
+<a name="l00071"></a>00071 <span class="comment"> /// \param name </span>
+<a name="l00072"></a>00072 <span class="comment"> /// Input Odbc table override</span>
+<a name="l00073"></a>00073 <span class="comment"> /// </span>
+<a name="l00074"></a>00074 <span class="comment"> /// \return</span>
+<a name="l00075"></a>00075 <span class="comment"> /// Returns nothing</span>
+<a name="l00076"></a>00076 <span class="comment"> /// </span>
+<a name="l00077"></a>00077 <span class="comment"></span> <a class="code" href="_odbc_ov_8h_91b15f0fd565be7c245bbe8e5247fbdc.html#91b15f0fd565be7c245bbe8e5247fbdc">FDOODBC_OV_API</a> <span class="keywordtype">void</span> <a class="code" href="class_fdo_odbc_ov_class_definition_ea3d32bfdcd6b87864bbacb927afc35a.html#ea3d32bfdcd6b87864bbacb927afc35a">SetTable</a>(<a class="code" href="class_fdo_odbc_ov_table.html">FdoOdbcOvTable</a>* table);
+<a name="l00078"></a>00078
+<a name="l00079"></a>00079 <span class="comment"></span>
+<a name="l00080"></a>00080 <span class="comment">/// \cond DOXYGEN-IGNORE</span>
+<a name="l00081"></a>00081 <span class="comment"></span><span class="comment"></span>
+<a name="l00082"></a>00082 <span class="comment"> /// Sets the parent of this object. Not part of the API.</span>
+<a name="l00083"></a>00083 <span class="comment"></span> <span class="keywordtype">void</span> <a class="code" href="class_fdo_rdbms_ov_class_definition_b9305a7abd05993ed4122ed92518584a.html#b9305a7abd05993ed4122ed92518584a">SetParent</a>(FdoPhysicalElementMapping* value);
+<a name="l00084"></a>00084 <span class="comment"></span>
+<a name="l00085"></a>00085 <span class="comment"> /// Initialize this element from its XML attributes</span>
+<a name="l00086"></a>00086 <span class="comment"></span> <span class="keyword">virtual</span> <span class="keywordtype">void</span> <a class="code" href="class_fdo_rdbms_ov_class_definition_67aeba1b9893aba90139cb89f0e99d79.html#67aeba1b9893aba90139cb89f0e99d79">InitFromXml</a>(FdoXmlSaxContext* pContext, FdoXmlAttributeCollection* attrs);
+<a name="l00087"></a>00087 <span class="comment"></span>
+<a name="l00088"></a>00088 <span class="comment"> /// Serialize the XML attributes of this class:</span>
+<a name="l00089"></a>00089 <span class="comment"></span> <span class="keyword">virtual</span> <span class="keywordtype">void</span> <a class="code" href="class_fdo_rdbms_ov_class_definition_4ff68496a1501f813642d416cf239d48.html#4ff68496a1501f813642d416cf239d48">_writeXmlAttributes</a>(FdoXmlWriter* xmlWriter, <span class="keyword">const</span> FdoXmlFlags* flags);
+<a name="l00090"></a>00090 <span class="comment"></span>
+<a name="l00091"></a>00091 <span class="comment">/// \endcond</span>
+<a name="l00092"></a>00092 <span class="comment"></span>
+<a name="l00093"></a>00093 <span class="keyword">protected</span>:
+<a name="l00094"></a>00094 <a class="code" href="class_fdo_odbc_ov_class_definition_903d6c0adf72890f2c1eb8a9e58fa078.html#903d6c0adf72890f2c1eb8a9e58fa078">FdoOdbcOvClassDefinition</a>();
+<a name="l00095"></a>00095 <a class="code" href="class_fdo_odbc_ov_class_definition_903d6c0adf72890f2c1eb8a9e58fa078.html#903d6c0adf72890f2c1eb8a9e58fa078">FdoOdbcOvClassDefinition</a>(FdoString *name);
+<a name="l00096"></a>00096
+<a name="l00097"></a>00097 <span class="keyword">virtual</span> <a class="code" href="class_fdo_odbc_ov_class_definition_00157c4391485a3ecd13e67be92da9ec.html#00157c4391485a3ecd13e67be92da9ec">~FdoOdbcOvClassDefinition</a>();
+<a name="l00098"></a>00098 <span class="keywordtype">void</span> <a class="code" href="class_fdo_odbc_ov_class_definition_f9dabe9332019053a8cd66b382623fdf.html#f9dabe9332019053a8cd66b382623fdf">Init</a>();
+<a name="l00099"></a>00099 <span class="keyword">virtual</span> <span class="keywordtype">void</span> <a class="code" href="class_fdo_odbc_ov_class_definition_3e0b0a6270eb712b771b0c105ac66c81.html#3e0b0a6270eb712b771b0c105ac66c81">Dispose</a>();
+<a name="l00100"></a>00100 <span class="comment"></span>
+<a name="l00101"></a>00101 <span class="comment"> /// Create table override from XML attributes</span>
+<a name="l00102"></a>00102 <span class="comment"></span> <span class="keyword">virtual</span> <span class="keywordtype">void</span> <a class="code" href="class_fdo_odbc_ov_class_definition_ea3d32bfdcd6b87864bbacb927afc35a.html#ea3d32bfdcd6b87864bbacb927afc35a">SetTable</a>(
+<a name="l00103"></a>00103 FdoXmlSaxContext* context,
+<a name="l00104"></a>00104 FdoXmlAttributeCollection* atts
+<a name="l00105"></a>00105 );
+<a name="l00106"></a>00106 <span class="comment"></span>
+<a name="l00107"></a>00107 <span class="comment"> /// Create data property override from XML attributes</span>
+<a name="l00108"></a>00108 <span class="comment"></span> <span class="keyword">virtual</span> <a class="code" href="class_fdo_rdbms_ov_data_property_definition.html">FdoRdbmsOvDataPropertyDefinition</a>* <a class="code" href="class_fdo_odbc_ov_class_definition_c881f0b09a83e8c2ddd7085597ab9b7c.html#c881f0b09a83e8c2ddd7085597ab9b7c">CreateDataProperty</a>(
+<a name="l00109"></a>00109 FdoXmlSaxContext* context,
+<a name="l00110"></a>00110 FdoXmlAttributeCollection* propAtts,
+<a name="l00111"></a>00111 FdoXmlAttributeCollection* colAtts
+<a name="l00112"></a>00112 );
+<a name="l00113"></a>00113 <span class="comment"></span>
+<a name="l00114"></a>00114 <span class="comment"> /// Create geometric property override from XML attributes</span>
+<a name="l00115"></a>00115 <span class="comment"></span> <span class="keyword">virtual</span> <a class="code" href="class_fdo_rdbms_ov_geometric_property_definition.html">FdoRdbmsOvGeometricPropertyDefinition</a>* <a class="code" href="class_fdo_odbc_ov_class_definition_728ebb53c3deb7c9703d69548df686ef.html#728ebb53c3deb7c9703d69548df686ef">CreateGeometricProperty</a>(
+<a name="l00116"></a>00116 FdoXmlSaxContext* context,
+<a name="l00117"></a>00117 FdoXmlAttributeCollection* propAtts,
+<a name="l00118"></a>00118 FdoXmlAttributeCollection* colAtts
+<a name="l00119"></a>00119 );
+<a name="l00120"></a>00120 <span class="comment"></span>
+<a name="l00121"></a>00121 <span class="comment"> /// Add the given property override to this class override</span>
+<a name="l00122"></a>00122 <span class="comment"></span> <span class="keyword">virtual</span> <span class="keywordtype">void</span> <a class="code" href="class_fdo_odbc_ov_class_definition_4f9806910e6d083e4c8b7fb5ba8f40a8.html#4f9806910e6d083e4c8b7fb5ba8f40a8">AddProperty</a>(
+<a name="l00123"></a>00123 <a class="code" href="class_fdo_rdbms_ov_property_definition.html">FdoRdbmsOvPropertyDefinition</a>* pProp
+<a name="l00124"></a>00124 );
+<a name="l00125"></a>00125
+<a name="l00126"></a>00126 <span class="keyword">private</span>:
+<a name="l00127"></a>00127 <a class="code" href="_odbc_ov_property_definition_collection_8h_da3ba8c7ff9ce10201957d8e68f55300.html#da3ba8c7ff9ce10201957d8e68f55300">FdoOdbcOvPropertiesP</a> mPropertyDefinitions;
+<a name="l00128"></a>00128 };
+<a name="l00129"></a>00129
+<a name="l00130"></a>00130 <span class="comment"></span>
+<a name="l00131"></a>00131 <span class="comment">/// \brief</span>
+<a name="l00132"></a>00132 <span class="comment">/// FdoOdbcOvClassP is a FdoPtr on FdoOdbcOvClassDefinition, provided for convenience.</span>
+<a name="l00133"></a><a class="code" href="_odbc_ov_class_definition_8h_70719915c7660c6a63636304351c73c9.html#70719915c7660c6a63636304351c73c9">00133</a> <span class="comment"></span><span class="keyword">typedef</span> FdoPtr<FdoOdbcOvClassDefinition> <a class="code" href="_odbc_ov_class_definition_8h_70719915c7660c6a63636304351c73c9.html#70719915c7660c6a63636304351c73c9">FdoOdbcOvClassP</a>;
+<a name="l00134"></a>00134
+<a name="l00135"></a>00135 <span class="preprocessor">#endif</span>
+<a name="l00136"></a>00136 <span class="preprocessor"></span>
+<a name="l00137"></a>00137
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/ODBC/_odbc_ov_class_definition_8h.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_odbc_ov_class_definition_8h.html?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_odbc_ov_class_definition_8h.html 2006-12-01 20:39:06+0000
@@ -0,0 +1,78 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<h1>OdbcOvClassDefinition.h File Reference</h1>
+<p>
+<code>#include <<a class="el" href="_rdbms_ov_class_definition_8h-source.html">Rdbms/Override/RdbmsOvClassDefinition.h</a>></code><br>
+<code>#include <<a class="el" href="_odbc_ov_data_property_definition_8h-source.html">Rdbms/Override/ODBC/OdbcOvDataPropertyDefinition.h</a>></code><br>
+<code>#include <<a class="el" href="_odbc_ov_geometric_property_definition_8h-source.html">Rdbms/Override/ODBC/OdbcOvGeometricPropertyDefinition.h</a>></code><br>
+<code>#include <<a class="el" href="_odbc_ov_property_definition_collection_8h-source.html">Rdbms/Override/ODBC/OdbcOvPropertyDefinitionCollection.h</a>></code><br>
+<code>#include <<a class="el" href="_odbc_ov_table_8h-source.html">Rdbms/Override/ODBC/OdbcOvTable.h</a>></code><br>
+<p>
+Include dependency graph for OdbcOvClassDefinition.h:<p><center><img src="_odbc_ov_class_definition_8h__incl.png" border="0" usemap="#OdbcOvClassDefinition.h_map" alt=""></center>
+<map name="OdbcOvClassDefinition.h_map">
+<area href="_rdbms_ov_class_definition_8h.html" shape="rect" coords="284,7,570,33" alt="">
+<area href="_odbc_ov_8h.html" shape="rect" coords="674,159,900,185" alt="">
+<area href="_odbc_ov_data_property_definition_8h.html" shape="rect" coords="246,108,608,135" alt="">
+<area href="_odbc_ov_geometric_property_definition_8h.html" shape="rect" coords="228,159,626,185" alt="">
+<area href="_odbc_ov_property_definition_collection_8h.html" shape="rect" coords="230,209,624,236" alt="">
+<area href="_odbc_ov_table_8h.html" shape="rect" coords="298,260,556,287" alt="">
+</map>
+<p>
+This graph shows which files directly or indirectly include this file:<p><center><img src="_odbc_ov_class_definition_8h__dep__incl.png" border="0" usemap="#OdbcOvClassDefinition.hdep_map" alt=""></center>
+<map name="OdbcOvClassDefinition.hdep_map">
+<area href="_odbc_ov_class_collection_8h.html" shape="rect" coords="228,7,404,33" alt="">
+<area href="_odbc_ov_physical_schema_mapping_8h.html" shape="rect" coords="453,7,685,33" alt="">
+</map>
+<p>
+<a href="_odbc_ov_class_definition_8h-source.html">Go to the source code of this file.</a><table border="0" cellpadding="0" cellspacing="0">
+<tr><td></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">class </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_odbc_ov_class_definition.html">FdoOdbcOvClassDefinition</a></td></tr>
+<tr><td class="mdescLeft"> </td><td class="mdescRight">Concrete class defining physical schema overrides for a class definition. <a href="class_fdo_odbc_ov_class_definition.html#_details">More...</a><br></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">typedef FdoPtr< <a class="el" href="class_fdo_odbc_ov_class_definition.html">FdoOdbcOvClassDefinition</a> > </td><td class="memItemRight" valign="bottom"><a class="el" href="_odbc_ov_class_definition_8h_70719915c7660c6a63636304351c73c9.html#70719915c7660c6a63636304351c73c9">FdoOdbcOvClassP</a></td></tr>
+<tr><td class="mdescLeft"> </td><td class="mdescRight">FdoOdbcOvClassP is a FdoPtr on <a class="el" href="class_fdo_odbc_ov_class_definition.html">FdoOdbcOvClassDefinition</a>, provided for convenience. <a href="#70719915c7660c6a63636304351c73c9"></a><br></td></tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/ODBC/_odbc_ov_class_definition_8h_70719915c7660c6a63636304351c73c9.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_odbc_ov_class_definition_8h_70719915c7660c6a63636304351c73c9.html?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_odbc_ov_class_definition_8h_70719915c7660c6a63636304351c73c9.html 2006-12-01 20:39:06+0000
@@ -0,0 +1,76 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="nav">
+<a class="el" href="_odbc_ov_class_definition_8h.html">OdbcOvClassDefinition.h</a></div>
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="_odbc_ov_class_definition_8h_70719915c7660c6a63636304351c73c9.html#70719915c7660c6a63636304351c73c9">FdoOdbcOvClassP</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="70719915c7660c6a63636304351c73c9"></a><!-- doxytag: member="OdbcOvClassDefinition.h::FdoOdbcOvClassP" ref="70719915c7660c6a63636304351c73c9" args="" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">typedef FdoPtr<<a class="el" href="class_fdo_odbc_ov_class_definition.html">FdoOdbcOvClassDefinition</a>> <a class="el" href="_odbc_ov_class_definition_8h_70719915c7660c6a63636304351c73c9.html#70719915c7660c6a63636304351c73c9">FdoOdbcOvClassP</a> </td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+FdoOdbcOvClassP is a FdoPtr on <a class="el" href="class_fdo_odbc_ov_class_definition.html">FdoOdbcOvClassDefinition</a>, provided for convenience.
+<p>
+<p>
+Definition at line <a class="el" href="_odbc_ov_class_definition_8h-source.html#l00133">133</a> of file <a class="el" href="_odbc_ov_class_definition_8h-source.html">OdbcOvClassDefinition.h</a>. </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/ODBC/_odbc_ov_class_definition_8h__dep__incl.map
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_odbc_ov_class_definition_8h__dep__incl.map?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_odbc_ov_class_definition_8h__dep__incl.map 2006-12-01 20:39:06+0000
@@ -0,0 +1,3 @@
+base referer
+rect $_odbc_ov_class_collection_8h.html 228,7 404,33
+rect $_odbc_ov_physical_schema_mapping_8h.html 453,7 685,33
Added: trunk/www/docs/ODBC/_odbc_ov_class_definition_8h__dep__incl.md5
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_odbc_ov_class_definition_8h__dep__incl.md5?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_odbc_ov_class_definition_8h__dep__incl.md5 2006-12-01 20:39:06+0000
@@ -0,0 +1 @@
+2be567330bee03c7e979a9750ab69e52
Added: trunk/www/docs/ODBC/_odbc_ov_class_definition_8h__dep__incl.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_odbc_ov_class_definition_8h__dep__incl.png?view=auto&rev=94
Added: trunk/www/docs/ODBC/_odbc_ov_class_definition_8h__incl.map
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_odbc_ov_class_definition_8h__incl.map?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_odbc_ov_class_definition_8h__incl.map 2006-12-01 20:39:06+0000
@@ -0,0 +1,7 @@
+base referer
+rect $_rdbms_ov_class_definition_8h.html 284,7 570,33
+rect $_odbc_ov_8h.html 674,159 900,185
+rect $_odbc_ov_data_property_definition_8h.html 246,108 608,135
+rect $_odbc_ov_geometric_property_definition_8h.html 228,159 626,185
+rect $_odbc_ov_property_definition_collection_8h.html 230,209 624,236
+rect $_odbc_ov_table_8h.html 298,260 556,287
Added: trunk/www/docs/ODBC/_odbc_ov_class_definition_8h__incl.md5
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_odbc_ov_class_definition_8h__incl.md5?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_odbc_ov_class_definition_8h__incl.md5 2006-12-01 20:39:06+0000
@@ -0,0 +1 @@
+a322e93da0eb762d4bcbbb6c862f94f9
Added: trunk/www/docs/ODBC/_odbc_ov_class_definition_8h__incl.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_odbc_ov_class_definition_8h__incl.png?view=auto&rev=94
Added: trunk/www/docs/ODBC/_odbc_ov_column_8h-source.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_odbc_ov_column_8h-source.html?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_odbc_ov_column_8h-source.html 2006-12-01 20:39:06+0000
@@ -0,0 +1,116 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<h1>OdbcOvColumn.h</h1><a href="_odbc_ov_column_8h.html">Go to the documentation of this file.</a><div class="fragment"><pre class="fragment"><a name="l00001"></a>00001 <span class="preprocessor">#ifndef FDO_OdbcOvColumn_H</span>
+<a name="l00002"></a>00002 <span class="preprocessor"></span><span class="preprocessor">#define FDO_OdbcOvColumn_H</span>
+<a name="l00005"></a>00005 <span class="comment">//</span>
+<a name="l00006"></a>00006 <span class="comment">// Copyright (C) 2004-2006 Autodesk, Inc.</span>
+<a name="l00008"></a>00008 <span class="comment">// This library is free software; you can redistribute it and/or</span>
+<a name="l00009"></a>00009 <span class="comment">// modify it under the terms of version 2.1 of the GNU Lesser</span>
+<a name="l00010"></a>00010 <span class="comment">// General Public License as published by the Free Software Foundation.</span>
+<a name="l00011"></a>00011 <span class="comment">// </span>
+<a name="l00012"></a>00012 <span class="comment">// This library is distributed in the hope that it will be useful,</span>
+<a name="l00013"></a>00013 <span class="comment">// but WITHOUT ANY WARRANTY; without even the implied warranty of</span>
+<a name="l00014"></a>00014 <span class="comment">// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU</span>
+<a name="l00015"></a>00015 <span class="comment">// Lesser General Public License for more details.</span>
+<a name="l00016"></a>00016 <span class="comment">// </span>
+<a name="l00017"></a>00017 <span class="comment">// You should have received a copy of the GNU Lesser General Public</span>
+<a name="l00018"></a>00018 <span class="comment">// License along with this library; if not, write to the Free Software</span>
+<a name="l00019"></a>00019 <span class="comment">// Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA</span>
+<a name="l00020"></a>00020 <span class="comment">//</span>
+<a name="l00022"></a>00022 <span class="preprocessor">#include <<a class="code" href="_rdbms_ov_column_8h.html">Rdbms/Override/RdbmsOvColumn.h</a>></span>
+<a name="l00023"></a>00023 <span class="comment"></span>
+<a name="l00024"></a>00024 <span class="comment">/// \brief</span>
+<a name="l00025"></a>00025 <span class="comment">/// Concrete class defining physical schema overrides for a column.</span>
+<a name="l00026"></a><a class="code" href="class_fdo_odbc_ov_column.html">00026</a> <span class="comment"></span><span class="keyword">class </span><a class="code" href="class_fdo_odbc_ov_column.html">FdoOdbcOvColumn</a> : <span class="keyword">public</span> <a class="code" href="class_fdo_rdbms_ov_column.html">FdoRdbmsOvColumn</a>
+<a name="l00027"></a>00027 {
+<a name="l00031"></a>00031 <span class="comment"> /// Constructs a default of an FdoOdbcOvColumn</span>
+<a name="l00034"></a>00034 <span class="comment"> /// Returns FdoOdbcOvColumn</span>
+<a name="l00036"></a>00036 <span class="comment"></span> <a class="code" href="_odbc_ov_8h_91b15f0fd565be7c245bbe8e5247fbdc.html#91b15f0fd565be7c245bbe8e5247fbdc">FDOODBC_OV_API</a> <span class="keyword">static</span> <a class="code" href="class_fdo_odbc_ov_column.html">FdoOdbcOvColumn</a>* <a class="code" href="class_fdo_odbc_ov_column_238bf6fbd015cd69495f0a50d64423cc.html#238bf6fbd015cd69495f0a50d64423cc">Create</a>();
+<a name="l00039"></a>00039 <span class="comment"> /// Constructs an instance of an FdoOdbcOvColumn using the specified arguments</span>
+<a name="l00041"></a>00041 <span class="comment"> /// \param name </span>
+<a name="l00042"></a>00042 <span class="comment"> /// Input name</span>
+<a name="l00045"></a>00045 <span class="comment"> /// Returns FdoOdbcOvColumn</span>
+<a name="l00047"></a>00047 <span class="comment"></span> <a class="code" href="_odbc_ov_8h_91b15f0fd565be7c245bbe8e5247fbdc.html#91b15f0fd565be7c245bbe8e5247fbdc">FDOODBC_OV_API</a> <span class="keyword">static</span> <a class="code" href="class_fdo_odbc_ov_column.html">FdoOdbcOvColumn</a>* <a class="code" href="class_fdo_odbc_ov_column_238bf6fbd015cd69495f0a50d64423cc.html#238bf6fbd015cd69495f0a50d64423cc">Create</a>(FdoString* name);
+<a name="l00049"></a>00049 <span class="comment"></span>
+<a name="l00050"></a>00050 <span class="comment">/// \cond DOXYGEN-IGNORE</span>
+<a name="l00051"></a>00051 <span class="comment"></span><span class="comment"></span>
+<a name="l00052"></a>00052 <span class="comment"> /// XML serialization functions, not part of the API.</span>
+<a name="l00053"></a>00053 <span class="comment"></span><span class="comment"></span>
+<a name="l00054"></a>00054 <span class="comment"> /// Initialize this element from its XML attributes</span>
+<a name="l00055"></a>00055 <span class="comment"></span> <span class="keyword">virtual</span> <span class="keywordtype">void</span> <a class="code" href="class_fdo_rdbms_ov_column_9d822ac4ab67ca84c513507701c83fdf.html#9d822ac4ab67ca84c513507701c83fdf">InitFromXml</a>(FdoXmlSaxContext* pContext, FdoXmlAttributeCollection* attrs);
+<a name="l00056"></a>00056 <span class="comment"></span>
+<a name="l00057"></a>00057 <span class="comment">/// \endcond</span>
+<a name="l00059"></a>00059 <span class="keyword">protected</span>:
+<a name="l00060"></a>00060 <a class="code" href="class_fdo_odbc_ov_column_1f28b6527c37a821a97768f0745198d2.html#1f28b6527c37a821a97768f0745198d2">FdoOdbcOvColumn</a>();
+<a name="l00061"></a>00061 <a class="code" href="class_fdo_odbc_ov_column_1f28b6527c37a821a97768f0745198d2.html#1f28b6527c37a821a97768f0745198d2">FdoOdbcOvColumn</a>(FdoString* name);
+<a name="l00062"></a>00062 <span class="keyword">virtual</span> <a class="code" href="class_fdo_odbc_ov_column_077cfd6bd88f07e1341926f290bac1b8.html#077cfd6bd88f07e1341926f290bac1b8">~FdoOdbcOvColumn</a>();
+<a name="l00063"></a>00063 <span class="keyword">virtual</span> <span class="keywordtype">void</span> <a class="code" href="class_fdo_odbc_ov_column_2e706ada31d133a7ee1022ebf90d0fde.html#2e706ada31d133a7ee1022ebf90d0fde">Dispose</a>();
+<a name="l00064"></a>00064 <span class="comment"></span>
+<a name="l00065"></a>00065 <span class="comment"> /// Serialize this property to XML.</span>
+<a name="l00066"></a>00066 <span class="comment"></span> <span class="keyword">virtual</span> <span class="keywordtype">void</span> <a class="code" href="class_fdo_odbc_ov_column_a6fa4d2750344c449bffaa13be91f29d.html#a6fa4d2750344c449bffaa13be91f29d">_writeXmlContents</a>(FdoXmlWriter* xmlWriter, <span class="keyword">const</span> FdoXmlFlags* flags);
+<a name="l00068"></a>00068 <span class="keyword">private</span>:
+<a name="l00069"></a>00069 };
+<a name="l00070"></a>00070 <span class="comment"></span>
+<a name="l00071"></a>00071 <span class="comment">/// \brief</span>
+<a name="l00072"></a>00072 <span class="comment">/// FdoOdbcOvColumnP is a FdoPtr on FdoOdbcOvColumn, provided for convenience.</span>
+<a name="l00073"></a><a class="code" href="_odbc_ov_column_8h_fb1cb53c58d91f79354479c12b7127bc.html#fb1cb53c58d91f79354479c12b7127bc">00073</a> <span class="comment"></span><span class="keyword">typedef</span> FdoPtr<FdoOdbcOvColumn> <a class="code" href="_odbc_ov_column_8h_fb1cb53c58d91f79354479c12b7127bc.html#fb1cb53c58d91f79354479c12b7127bc">FdoOdbcOvColumnP</a>;
+<a name="l00075"></a>00075 <span class="preprocessor">#endif</span>
+<a name="l00076"></a>00076 <span class="preprocessor"></span>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/ODBC/_odbc_ov_column_8h.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_odbc_ov_column_8h.html?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_odbc_ov_column_8h.html 2006-12-01 20:39:06+0000
@@ -0,0 +1,72 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<h1>OdbcOvColumn.h File Reference</h1>
+<p>
+<code>#include <<a class="el" href="_rdbms_ov_column_8h-source.html">Rdbms/Override/RdbmsOvColumn.h</a>></code><br>
+<p>
+Include dependency graph for OdbcOvColumn.h:<p><center><img src="_odbc_ov_column_8h__incl.png" border="0" usemap="#OdbcOvColumn.h_map" alt=""></center>
+<map name="OdbcOvColumn.h_map">
+<area href="_odbc_ov_8h.html" shape="rect" coords="194,7,420,33" alt="">
+<area href="_rdbms_ov_column_8h.html" shape="rect" coords="186,57,428,84" alt="">
+<area href="_rdbms_ov_8h.html" shape="rect" coords="547,108,742,135" alt="">
+</map>
+<p>
+This graph shows which files directly or indirectly include this file:<p><center><img src="_odbc_ov_column_8h__dep__incl.png" border="0" usemap="#OdbcOvColumn.hdep_map" alt=""></center>
+<map name="OdbcOvColumn.hdep_map">
+<area href="_odbc_ov_data_property_definition_8h.html" shape="rect" coords="185,7,404,33" alt="">
+<area href="_odbc_ov_class_definition_8h.html" shape="rect" coords="452,7,625,33" alt="">
+<area href="_odbc_ov_class_collection_8h.html" shape="rect" coords="673,7,849,33" alt="">
+</map>
+<p>
+<a href="_odbc_ov_column_8h-source.html">Go to the source code of this file.</a><table border="0" cellpadding="0" cellspacing="0">
+<tr><td></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">class </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_odbc_ov_column.html">FdoOdbcOvColumn</a></td></tr>
+<tr><td class="mdescLeft"> </td><td class="mdescRight">Concrete class defining physical schema overrides for a column. <a href="class_fdo_odbc_ov_column.html#_details">More...</a><br></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">typedef FdoPtr< <a class="el" href="class_fdo_odbc_ov_column.html">FdoOdbcOvColumn</a> > </td><td class="memItemRight" valign="bottom"><a class="el" href="_odbc_ov_column_8h_fb1cb53c58d91f79354479c12b7127bc.html#fb1cb53c58d91f79354479c12b7127bc">FdoOdbcOvColumnP</a></td></tr>
+<tr><td class="mdescLeft"> </td><td class="mdescRight">FdoOdbcOvColumnP is a FdoPtr on <a class="el" href="class_fdo_odbc_ov_column.html">FdoOdbcOvColumn</a>, provided for convenience. <a href="#fb1cb53c58d91f79354479c12b7127bc"></a><br></td></tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/ODBC/_odbc_ov_column_8h__dep__incl.map
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_odbc_ov_column_8h__dep__incl.map?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_odbc_ov_column_8h__dep__incl.map 2006-12-01 20:39:06+0000
@@ -0,0 +1,4 @@
+base referer
+rect $_odbc_ov_data_property_definition_8h.html 185,7 404,33
+rect $_odbc_ov_class_definition_8h.html 452,7 625,33
+rect $_odbc_ov_class_collection_8h.html 673,7 849,33
Added: trunk/www/docs/ODBC/_odbc_ov_column_8h__dep__incl.md5
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_odbc_ov_column_8h__dep__incl.md5?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_odbc_ov_column_8h__dep__incl.md5 2006-12-01 20:39:06+0000
@@ -0,0 +1 @@
+97322604c6985ec994838835ab57ae5f
Added: trunk/www/docs/ODBC/_odbc_ov_column_8h__dep__incl.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_odbc_ov_column_8h__dep__incl.png?view=auto&rev=94
Added: trunk/www/docs/ODBC/_odbc_ov_column_8h__incl.map
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_odbc_ov_column_8h__incl.map?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_odbc_ov_column_8h__incl.map 2006-12-01 20:39:06+0000
@@ -0,0 +1,4 @@
+base referer
+rect $_odbc_ov_8h.html 194,7 420,33
+rect $_rdbms_ov_column_8h.html 186,57 428,84
+rect $_rdbms_ov_8h.html 547,108 742,135
Added: trunk/www/docs/ODBC/_odbc_ov_column_8h__incl.md5
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_odbc_ov_column_8h__incl.md5?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_odbc_ov_column_8h__incl.md5 2006-12-01 20:39:06+0000
@@ -0,0 +1 @@
+19a1e0975f3f1ac668ec0f7766a57957
Added: trunk/www/docs/ODBC/_odbc_ov_column_8h__incl.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_odbc_ov_column_8h__incl.png?view=auto&rev=94
Added: trunk/www/docs/ODBC/_odbc_ov_column_8h_fb1cb53c58d91f79354479c12b7127bc.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_odbc_ov_column_8h_fb1cb53c58d91f79354479c12b7127bc.html?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_odbc_ov_column_8h_fb1cb53c58d91f79354479c12b7127bc.html 2006-12-01 20:39:06+0000
@@ -0,0 +1,76 @@
+<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN" "http://www.w3.org/TR/html4/loose.dtd">
+<html>
+ <head>
+ <meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
+ <title>OSGeo FDO Provider for ODBC API Reference</title>
+ <link href="custom.css" rel="stylesheet" type="text/css">
+ <link href="tabs.css" rel="stylesheet" type="text/css">
+ </head>
+ <body bgcolor="#FFFFFF">
+ <table width="100%" border="0">
+ <tr>
+ <td><b>API Reference<b></td>
+ <td align="right"><b>OSGeo FDO Provider for ODBC<b></td>
+ </tr>
+ </table>
+<!-- End of: header.html -->
+<!-- Generated by Doxygen 1.4.6-NO -->
+<div class="tabs">
+ <ul>
+ <li><a href="main.html"><span>Main Page</span></a></li>
+ <li><a href="classes.html"><span>Classes</span></a></li>
+ </ul></div>
+<div class="nav">
+<a class="el" href="_odbc_ov_column_8h.html">OdbcOvColumn.h</a></div>
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="_odbc_ov_column_8h_fb1cb53c58d91f79354479c12b7127bc.html#fb1cb53c58d91f79354479c12b7127bc">FdoOdbcOvColumnP</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="fb1cb53c58d91f79354479c12b7127bc"></a><!-- doxytag: member="OdbcOvColumn.h::FdoOdbcOvColumnP" ref="fb1cb53c58d91f79354479c12b7127bc" args="" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">typedef FdoPtr<<a class="el" href="class_fdo_odbc_ov_column.html">FdoOdbcOvColumn</a>> <a class="el" href="_odbc_ov_column_8h_fb1cb53c58d91f79354479c12b7127bc.html#fb1cb53c58d91f79354479c12b7127bc">FdoOdbcOvColumnP</a> </td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+FdoOdbcOvColumnP is a FdoPtr on <a class="el" href="class_fdo_odbc_ov_column.html">FdoOdbcOvColumn</a>, provided for convenience.
+<p>
+<p>
+Definition at line <a class="el" href="_odbc_ov_column_8h-source.html#l00073">73</a> of file <a class="el" href="_odbc_ov_column_8h-source.html">OdbcOvColumn.h</a>. </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/ODBC/_odbc_ov_data_property_definition_8h-source.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_odbc_ov_data_property_definition_8h-source.html?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_odbc_ov_data_property_definition_8h-source.html 2006-12-01 20:39:06+0000
@@ -0,0 +1,126 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ <li id="current"><a href="files.html"><span>Files</span></a></li>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ <li><a href="files.html"><span>File List</span></a></li>
+ <li><a href="globals.html"><span>File Members</span></a></li>
+ </ul></div>
+<h1>OdbcOvDataPropertyDefinition.h</h1><a href="_odbc_ov_data_property_definition_8h.html">Go to the documentation of this file.</a><div class="fragment"><pre class="fragment"><a name="l00001"></a>00001 <span class="preprocessor">#ifndef FDO_OdbcOVDATAPROPERTYDEFINITION_H</span>
+<a name="l00002"></a>00002 <span class="preprocessor"></span><span class="preprocessor">#define FDO_OdbcOVDATAPROPERTYDEFINITION_H</span>
+<a name="l00007"></a>00007 <span class="comment">// </span>
+<a name="l00021"></a>00021 <span class="preprocessor">#include <FdoCommon.h></span>
+<a name="l00022"></a>00022 <span class="preprocessor">#include <<a class="code" href="_rdbms_ov_data_property_definition_8h.html">Rdbms/Override/RdbmsOvDataPropertyDefinition.h</a>></span>
+<a name="l00023"></a>00023 <span class="preprocessor">#include <<a class="code" href="_odbc_ov_8h.html">Rdbms/Override/ODBC/OdbcOv.h</a>></span>
+<a name="l00024"></a>00024 <span class="preprocessor">#include <<a class="code" href="_odbc_ov_column_8h.html">Rdbms/Override/ODBC/OdbcOvColumn.h</a>></span>
+<a name="l00025"></a>00025 <span class="preprocessor">#include <<a class="code" href="_odbc_ov_property_definition_8h.html">Rdbms/Override/ODBC/OdbcOvPropertyDefinition.h</a>></span>
+<a name="l00028"></a>00028 <span class="comment">/// Concrete class defining physical schema overrides for a data property definition.</span>
+<a name="l00029"></a><a class="code" href="class_fdo_odbc_ov_data_property_definition.html">00029</a> <span class="comment"></span><span class="keyword">class </span><a class="code" href="class_fdo_odbc_ov_data_property_definition.html">FdoOdbcOvDataPropertyDefinition</a> : <span class="keyword">public</span> <a class="code" href="class_fdo_rdbms_ov_data_property_definition.html">FdoRdbmsOvDataPropertyDefinition</a>, <span class="keyword">public</span> <a class="code" href="class_fdo_odbc_ov_property_definition.html">FdoOdbcOvPropertyDefinition</a>
+<a name="l00031"></a>00031 <span class="keyword">public</span>:<span class="comment"></span>
+<a name="l00032"></a>00032 <span class="comment"> /// \brief</span>
+<a name="l00033"></a>00033 <span class="comment"> /// Constructs a default of an FdoOdbcOvDataPropertyDefinition</span>
+<a name="l00034"></a>00034 <span class="comment"> /// </span>
+<a name="l00035"></a>00035 <span class="comment"> /// \return</span>
+<a name="l00036"></a>00036 <span class="comment"> /// Returns FdoOdbcOvDataPropertyDefinition</span>
+<a name="l00037"></a>00037 <span class="comment"> /// </span>
+<a name="l00038"></a>00038 <span class="comment"></span> <a class="code" href="_odbc_ov_8h_91b15f0fd565be7c245bbe8e5247fbdc.html#91b15f0fd565be7c245bbe8e5247fbdc">FDOODBC_OV_API</a> <span class="keyword">static</span> <a class="code" href="class_fdo_odbc_ov_data_property_definition.html">FdoOdbcOvDataPropertyDefinition</a>* <a class="code" href="class_fdo_odbc_ov_data_property_definition_b4f1391f2b6707ac76dc58ec5d6d5874.html#b4f1391f2b6707ac76dc58ec5d6d5874">Create</a>();
+<a name="l00040"></a>00040 <span class="comment"> /// \brief</span>
+<a name="l00041"></a>00041 <span class="comment"> /// Constructs an instance of an FdoOdbcOvDataPropertyDefinition using the specified arguments</span>
+<a name="l00042"></a>00042 <span class="comment"> /// </span>
+<a name="l00043"></a>00043 <span class="comment"> /// \param name </span>
+<a name="l00044"></a>00044 <span class="comment"> /// Input name</span>
+<a name="l00045"></a>00045 <span class="comment"> /// </span>
+<a name="l00046"></a>00046 <span class="comment"> /// \return</span>
+<a name="l00047"></a>00047 <span class="comment"> /// Returns FdoOdbcOvDataPropertyDefinition</span>
+<a name="l00048"></a>00048 <span class="comment"> /// </span>
+<a name="l00049"></a>00049 <span class="comment"></span> <a class="code" href="_odbc_ov_8h_91b15f0fd565be7c245bbe8e5247fbdc.html#91b15f0fd565be7c245bbe8e5247fbdc">FDOODBC_OV_API</a> <span class="keyword">static</span> <a class="code" href="class_fdo_odbc_ov_data_property_definition.html">FdoOdbcOvDataPropertyDefinition</a>* <a class="code" href="class_fdo_odbc_ov_data_property_definition_b4f1391f2b6707ac76dc58ec5d6d5874.html#b4f1391f2b6707ac76dc58ec5d6d5874">Create</a>(FdoString* name);
+<a name="l00051"></a>00051 <span class="comment"> /// \brief</span>
+<a name="l00052"></a>00052 <span class="comment"> /// Gets the Odbc column</span>
+<a name="l00053"></a>00053 <span class="comment"> /// </span>
+<a name="l00054"></a>00054 <span class="comment"> /// \return</span>
+<a name="l00055"></a>00055 <span class="comment"> /// Returns the Odbc column</span>
+<a name="l00056"></a>00056 <span class="comment"> /// </span>
+<a name="l00057"></a>00057 <span class="comment"></span> <a class="code" href="_odbc_ov_8h_91b15f0fd565be7c245bbe8e5247fbdc.html#91b15f0fd565be7c245bbe8e5247fbdc">FDOODBC_OV_API</a> <a class="code" href="class_fdo_odbc_ov_column.html">FdoOdbcOvColumn</a>* <a class="code" href="class_fdo_odbc_ov_data_property_definition_41e3b2773aaa5560dc3b8b8fa28782dc.html#41e3b2773aaa5560dc3b8b8fa28782dc">GetColumn</a>();
+<a name="l00059"></a>00059 <span class="comment"> /// \brief</span>
+<a name="l00060"></a>00060 <span class="comment"> /// Sets the Odbc column</span>
+<a name="l00061"></a>00061 <span class="comment"> /// </span>
+<a name="l00062"></a>00062 <span class="comment"> /// \return</span>
+<a name="l00063"></a>00063 <span class="comment"> /// Returns nothing</span>
+<a name="l00064"></a>00064 <span class="comment"> /// </span>
+<a name="l00065"></a>00065 <span class="comment"></span> <a class="code" href="_odbc_ov_8h_91b15f0fd565be7c245bbe8e5247fbdc.html#91b15f0fd565be7c245bbe8e5247fbdc">FDOODBC_OV_API</a> <span class="keywordtype">void</span> <a class="code" href="class_fdo_odbc_ov_data_property_definition_978bea6673bc58a481a9a725e5508ce0.html#978bea6673bc58a481a9a725e5508ce0">SetColumn</a>(<a class="code" href="class_fdo_odbc_ov_column.html">FdoOdbcOvColumn</a> *column);
+<a name="l00067"></a>00067 <span class="comment">/// \cond DOXYGEN-IGNORE</span>
+<a name="l00068"></a>00068 <span class="comment"></span><span class="comment"></span>
+<a name="l00069"></a>00069 <span class="comment">/// \endcond</span>
+<a name="l00071"></a>00071 <span class="keyword">protected</span>:
+<a name="l00072"></a>00072 <a class="code" href="class_fdo_odbc_ov_data_property_definition_0127527b281657c675e2f075b5a5381e.html#0127527b281657c675e2f075b5a5381e">FdoOdbcOvDataPropertyDefinition</a>();
+<a name="l00073"></a>00073 <a class="code" href="class_fdo_odbc_ov_data_property_definition_0127527b281657c675e2f075b5a5381e.html#0127527b281657c675e2f075b5a5381e">FdoOdbcOvDataPropertyDefinition</a>(FdoString* name);
+<a name="l00074"></a>00074 <span class="keyword">virtual</span> <a class="code" href="class_fdo_odbc_ov_data_property_definition_86dd56d85e59ecaa71de82c2488cb2cb.html#86dd56d85e59ecaa71de82c2488cb2cb">~FdoOdbcOvDataPropertyDefinition</a>();
+<a name="l00075"></a>00075 <span class="keyword">virtual</span> <span class="keywordtype">void</span> <a class="code" href="class_fdo_odbc_ov_data_property_definition_264b0c72c7493d4544b9ef3b23460a87.html#264b0c72c7493d4544b9ef3b23460a87">Dispose</a>();
+<a name="l00077"></a>00077 <span class="keyword">private</span>:
+<a name="l00078"></a>00078 };
+<a name="l00080"></a>00080 <span class="comment"></span>
+<a name="l00081"></a>00081 <span class="comment">/// \brief</span>
+<a name="l00082"></a>00082 <span class="comment">/// FdoOdbcOvDataPropertyP is a FdoPtr on FdoOdbcOvDataPropertyDefinition, provided for convenience.</span>
+<a name="l00083"></a><a class="code" href="_odbc_ov_data_property_definition_8h_1594f236136919ad7bf4b57af8928e09.html#1594f236136919ad7bf4b57af8928e09">00083</a> <span class="comment"></span><span class="keyword">typedef</span> FdoPtr<FdoOdbcOvDataPropertyDefinition> <a class="code" href="_odbc_ov_data_property_definition_8h_1594f236136919ad7bf4b57af8928e09.html#1594f236136919ad7bf4b57af8928e09">FdoOdbcOvDataPropertyP</a>;
+<a name="l00085"></a>00085 <span class="preprocessor">#endif</span>
+<a name="l00086"></a>00086 <span class="preprocessor"></span>
+</pre></div><!-- footer.html -->
+ <hr>
+ <tr>
+ <td align="right"><font size="-2"><a href="mailto:isd.docs at autodesk.com&subject=FDO%20Provider%20for%20ODBC%20API%20documentation">Comments?</a></font></td>
+ <!-- The logo can go in another cell, when we get one -->
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/ODBC/_odbc_ov_data_property_definition_8h.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_odbc_ov_data_property_definition_8h.html?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_odbc_ov_data_property_definition_8h.html 2006-12-01 20:39:06+0000
@@ -0,0 +1,76 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<h1>OdbcOvDataPropertyDefinition.h File Reference</h1>
+<p>
+<code>#include <FdoCommon.h></code><br>
+<code>#include <<a class="el" href="_rdbms_ov_data_property_definition_8h-source.html">Rdbms/Override/RdbmsOvDataPropertyDefinition.h</a>></code><br>
+<code>#include <<a class="el" href="_odbc_ov_column_8h-source.html">Rdbms/Override/ODBC/OdbcOvColumn.h</a>></code><br>
+<code>#include <<a class="el" href="_odbc_ov_property_definition_8h-source.html">Rdbms/Override/ODBC/OdbcOvPropertyDefinition.h</a>></code><br>
+<p>
+Include dependency graph for OdbcOvDataPropertyDefinition.h:<p><center><img src="_odbc_ov_data_property_definition_8h__incl.png" border="0" usemap="#OdbcOvDataPropertyDefinition.h_map" alt=""></center>
+<map name="OdbcOvDataPropertyDefinition.h_map">
+<area href="_rdbms_ov_data_property_definition_8h.html" shape="rect" coords="276,58,607,84" alt="">
+<area href="_odbc_ov_8h.html" shape="rect" coords="658,159,884,186" alt="">
+<area href="_odbc_ov_column_8h.html" shape="rect" coords="304,159,579,186" alt="">
+<area href="_odbc_ov_property_definition_8h.html" shape="rect" coords="275,210,608,236" alt="">
+</map>
+<p>
+This graph shows which files directly or indirectly include this file:<p><center><img src="_odbc_ov_data_property_definition_8h__dep__incl.png" border="0" usemap="#OdbcOvDataPropertyDefinition.hdep_map" alt=""></center>
+<map name="OdbcOvDataPropertyDefinition.hdep_map">
+<area href="_odbc_ov_class_definition_8h.html" shape="rect" coords="273,7,447,33" alt="">
+<area href="_odbc_ov_class_collection_8h.html" shape="rect" coords="495,7,671,33" alt="">
+<area href="_odbc_ov_physical_schema_mapping_8h.html" shape="rect" coords="720,7,952,33" alt="">
+</map>
+<p>
+<a href="_odbc_ov_data_property_definition_8h-source.html">Go to the source code of this file.</a><table border="0" cellpadding="0" cellspacing="0">
+<tr><td></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">class </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_odbc_ov_data_property_definition.html">FdoOdbcOvDataPropertyDefinition</a></td></tr>
+<tr><td class="mdescLeft"> </td><td class="mdescRight">Concrete class defining physical schema overrides for a data property definition. <a href="class_fdo_odbc_ov_data_property_definition.html#_details">More...</a><br></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">typedef FdoPtr< <a class="el" href="class_fdo_odbc_ov_data_property_definition.html">FdoOdbcOvDataPropertyDefinition</a> > </td><td class="memItemRight" valign="bottom"><a class="el" href="_odbc_ov_data_property_definition_8h_1594f236136919ad7bf4b57af8928e09.html#1594f236136919ad7bf4b57af8928e09">FdoOdbcOvDataPropertyP</a></td></tr>
+<tr><td class="mdescLeft"> </td><td class="mdescRight">FdoOdbcOvDataPropertyP is a FdoPtr on <a class="el" href="class_fdo_odbc_ov_data_property_definition.html">FdoOdbcOvDataPropertyDefinition</a>, provided for convenience. <a href="#1594f236136919ad7bf4b57af8928e09"></a><br></td></tr>
+</table>
+<!-- footer.html -->
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/ODBC/_odbc_ov_data_property_definition_8h_1594f236136919ad7bf4b57af8928e09.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_odbc_ov_data_property_definition_8h_1594f236136919ad7bf4b57af8928e09.html?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_odbc_ov_data_property_definition_8h_1594f236136919ad7bf4b57af8928e09.html 2006-12-01 20:39:06+0000
@@ -0,0 +1,76 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ <li><a href="files.html"><span>Files</span></a></li>
+ </ul></div>
+<div class="nav">
+<a class="el" href="_odbc_ov_data_property_definition_8h.html">OdbcOvDataPropertyDefinition.h</a></div>
+<table cellspacing="0" cellpadding="0" border="0">
+ <tr>
+ <td valign="top">
+ <div class="navtab">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="_odbc_ov_data_property_definition_8h_1594f236136919ad7bf4b57af8928e09.html#1594f236136919ad7bf4b57af8928e09">FdoOdbcOvDataPropertyP</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="1594f236136919ad7bf4b57af8928e09"></a><!-- doxytag: member="OdbcOvDataPropertyDefinition.h::FdoOdbcOvDataPropertyP" ref="1594f236136919ad7bf4b57af8928e09" args="" --><p>
+<table class="mdTable" cellpadding="2" cellspacing="0">
+ <tr>
+ <td class="mdRow">
+ <table cellpadding="0" cellspacing="0" border="0">
+ <tr>
+ <td class="md" nowrap valign="top">typedef FdoPtr<<a class="el" href="class_fdo_odbc_ov_data_property_definition.html">FdoOdbcOvDataPropertyDefinition</a>> <a class="el" href="_odbc_ov_data_property_definition_8h_1594f236136919ad7bf4b57af8928e09.html#1594f236136919ad7bf4b57af8928e09">FdoOdbcOvDataPropertyP</a> </td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+<table cellspacing="5" cellpadding="0" border="0">
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+FdoOdbcOvDataPropertyP is a FdoPtr on <a class="el" href="class_fdo_odbc_ov_data_property_definition.html">FdoOdbcOvDataPropertyDefinition</a>, provided for convenience.
+<p>
+<p>
+Definition at line <a class="el" href="_odbc_ov_data_property_definition_8h-source.html#l00083">83</a> of file <a class="el" href="_odbc_ov_data_property_definition_8h-source.html">OdbcOvDataPropertyDefinition.h</a>. </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/ODBC/_odbc_ov_data_property_definition_8h__dep__incl.map
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_odbc_ov_data_property_definition_8h__dep__incl.map?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_odbc_ov_data_property_definition_8h__dep__incl.map 2006-12-01 20:39:06+0000
@@ -0,0 +1,4 @@
+base referer
+rect $_odbc_ov_class_definition_8h.html 273,7 447,33
+rect $_odbc_ov_class_collection_8h.html 495,7 671,33
+rect $_odbc_ov_physical_schema_mapping_8h.html 720,7 952,33
Added: trunk/www/docs/ODBC/_odbc_ov_data_property_definition_8h__dep__incl.md5
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_odbc_ov_data_property_definition_8h__dep__incl.md5?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_odbc_ov_data_property_definition_8h__dep__incl.md5 2006-12-01 20:39:06+0000
@@ -0,0 +1 @@
+c6661238abfbd0c0ca1abe96ac1300e3
\ No newline at end of file
Added: trunk/www/docs/ODBC/_odbc_ov_data_property_definition_8h__dep__incl.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_odbc_ov_data_property_definition_8h__dep__incl.png?view=auto&rev=94
Binary file. No diff available.
Added: trunk/www/docs/ODBC/_odbc_ov_data_property_definition_8h__incl.map
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_odbc_ov_data_property_definition_8h__incl.map?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_odbc_ov_data_property_definition_8h__incl.map 2006-12-01 20:39:06+0000
@@ -0,0 +1,5 @@
+base referer
+rect $_rdbms_ov_data_property_definition_8h.html 276,58 607,84
+rect $_odbc_ov_8h.html 658,159 884,186
+rect $_odbc_ov_column_8h.html 304,159 579,186
+rect $_odbc_ov_property_definition_8h.html 275,210 608,236
Added: trunk/www/docs/ODBC/_odbc_ov_data_property_definition_8h__incl.md5
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_odbc_ov_data_property_definition_8h__incl.md5?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_odbc_ov_data_property_definition_8h__incl.md5 2006-12-01 20:39:06+0000
@@ -0,0 +1 @@
+b5cb78b673a2772e43686ec50615cdd9
Added: trunk/www/docs/ODBC/_odbc_ov_data_property_definition_8h__incl.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_odbc_ov_data_property_definition_8h__incl.png?view=auto&rev=94
Added: trunk/www/docs/ODBC/_odbc_ov_geometric_property_definition_8h-source.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_odbc_ov_geometric_property_definition_8h-source.html?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_odbc_ov_geometric_property_definition_8h-source.html 2006-12-01 20:39:06+0000
@@ -0,0 +1,105 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<h1>OdbcOvGeometricPropertyDefinition.h</h1><a href="_odbc_ov_geometric_property_definition_8h.html">Go to the documentation of this file.</a><div class="fragment"><pre class="fragment"><a name="l00001"></a>00001 <span class="preprocessor">#ifndef FDO_OdbcOVGEOMETRICPROPERTYDEFINITION_H</span>
+<a name="l00002"></a>00002 <span class="preprocessor"></span><span class="preprocessor">#define FDO_OdbcOVGEOMETRICPROPERTYDEFINITION_H</span>
+<a name="l00003"></a>00003 <span class="preprocessor"></span><span class="comment">//</span>
+<a name="l00004"></a>00004 <span class="comment">//</span>
+<a name="l00005"></a>00005 <span class="comment">// Copyright (C) 2004-2006 Autodesk, Inc.</span>
+<a name="l00006"></a>00006 <span class="comment">// </span>
+<a name="l00007"></a>00007 <span class="comment">// This library is free software; you can redistribute it and/or</span>
+<a name="l00008"></a>00008 <span class="comment">// modify it under the terms of version 2.1 of the GNU Lesser</span>
+<a name="l00009"></a>00009 <span class="comment">// General Public License as published by the Free Software Foundation.</span>
+<a name="l00010"></a>00010 <span class="comment">// </span>
+<a name="l00011"></a>00011 <span class="comment">// This library is distributed in the hope that it will be useful,</span>
+<a name="l00012"></a>00012 <span class="comment">// but WITHOUT ANY WARRANTY; without even the implied warranty of</span>
+<a name="l00013"></a>00013 <span class="comment">// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU</span>
+<a name="l00014"></a>00014 <span class="comment">// Lesser General Public License for more details.</span>
+<a name="l00015"></a>00015 <span class="comment">// </span>
+<a name="l00016"></a>00016 <span class="comment">// You should have received a copy of the GNU Lesser General Public</span>
+<a name="l00017"></a>00017 <span class="comment">// License along with this library; if not, write to the Free Software</span>
+<a name="l00018"></a>00018 <span class="comment">// Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA</span>
+<a name="l00019"></a>00019 <span class="comment">//</span>
+<a name="l00020"></a>00020 <span class="preprocessor">#include <<a class="code" href="_rdbms_ov_geometric_property_definition_8h.html">Rdbms/Override/RdbmsOvGeometricPropertyDefinition.h</a>></span>
+<a name="l00022"></a>00022 <span class="preprocessor">#include <<a class="code" href="_odbc_ov_property_definition_8h.html">Rdbms/Override/ODBC/OdbcOvPropertyDefinition.h</a>></span>
+<a name="l00025"></a>00025 <span class="comment">/// Concrete class defining physical schema overrides for a geometric property definition.</span>
+<a name="l00026"></a><a class="code" href="class_fdo_odbc_ov_geometric_property_definition.html">00026</a> <span class="comment"></span><span class="keyword">class </span><a class="code" href="class_fdo_odbc_ov_geometric_property_definition.html">FdoOdbcOvGeometricPropertyDefinition</a> : <span class="keyword">public</span> <a class="code" href="class_fdo_rdbms_ov_geometric_property_definition.html">FdoRdbmsOvGeometricPropertyDefinition</a>, <span class="keyword">public</span> <a class="code" href="class_fdo_odbc_ov_property_definition.html">FdoOdbcOvPropertyDefinition</a>
+<a name="l00028"></a>00028 <span class="keyword">public</span>:<span class="comment"></span>
+<a name="l00029"></a>00029 <span class="comment"> /// \brief</span>
+<a name="l00030"></a>00030 <span class="comment"> /// Constructs a default of an FdoOdbcOvGeometricPropertyDefinition</span>
+<a name="l00031"></a>00031 <span class="comment"> /// </span>
+<a name="l00032"></a>00032 <span class="comment"> /// \return</span>
+<a name="l00033"></a>00033 <span class="comment"> /// Returns FdoOdbcOvGeometricPropertyDefinition</span>
+<a name="l00035"></a>00035 <span class="comment"></span> <a class="code" href="_odbc_ov_8h_91b15f0fd565be7c245bbe8e5247fbdc.html#91b15f0fd565be7c245bbe8e5247fbdc">FDOODBC_OV_API</a> <span class="keyword">static</span> <a class="code" href="class_fdo_odbc_ov_geometric_property_definition.html">FdoOdbcOvGeometricPropertyDefinition</a>* <a class="code" href="class_fdo_odbc_ov_geometric_property_definition_cd67333f0e52cb45aa1e2428ae1587a6.html#cd67333f0e52cb45aa1e2428ae1587a6">Create</a>();
+<a name="l00037"></a>00037 <span class="comment"> /// \brief</span>
+<a name="l00038"></a>00038 <span class="comment"> /// Constructs an instance of an FdoOdbcOvGeometricPropertyDefinition using the specified arguments</span>
+<a name="l00039"></a>00039 <span class="comment"> /// </span>
+<a name="l00040"></a>00040 <span class="comment"> /// \param name </span>
+<a name="l00041"></a>00041 <span class="comment"> /// Input name</span>
+<a name="l00043"></a>00043 <span class="comment"> /// \return</span>
+<a name="l00044"></a>00044 <span class="comment"> /// Returns FdoOdbcOvGeometricPropertyDefinition</span>
+<a name="l00046"></a>00046 <span class="comment"></span> <a class="code" href="_odbc_ov_8h_91b15f0fd565be7c245bbe8e5247fbdc.html#91b15f0fd565be7c245bbe8e5247fbdc">FDOODBC_OV_API</a> <span class="keyword">static</span> <a class="code" href="class_fdo_odbc_ov_geometric_property_definition.html">FdoOdbcOvGeometricPropertyDefinition</a>* <a class="code" href="class_fdo_odbc_ov_geometric_property_definition_cd67333f0e52cb45aa1e2428ae1587a6.html#cd67333f0e52cb45aa1e2428ae1587a6">Create</a>(FdoString* name);
+<a name="l00048"></a>00048 <span class="keyword">protected</span>:<span class="comment"></span>
+<a name="l00049"></a>00049 <span class="comment">/// \cond DOXYGEN-IGNORE</span>
+<a name="l00051"></a>00051 <a class="code" href="class_fdo_odbc_ov_geometric_property_definition.html">FdoOdbcOvGeometricPropertyDefinition</a>();
+<a name="l00052"></a>00052 <a class="code" href="class_fdo_odbc_ov_geometric_property_definition.html">FdoOdbcOvGeometricPropertyDefinition</a>(FdoString* name);
+<a name="l00053"></a>00053 <span class="keyword">virtual</span> ~<a class="code" href="class_fdo_odbc_ov_geometric_property_definition.html">FdoOdbcOvGeometricPropertyDefinition</a>();
+<a name="l00054"></a>00054 <span class="keyword">virtual</span> <span class="keywordtype">void</span> <a class="code" href="class_fdo_odbc_ov_property_definition_55cd087e142f097d0a9dae6fd63489fc.html#55cd087e142f097d0a9dae6fd63489fc">Dispose</a>();<span class="comment"></span>
+<a name="l00055"></a>00055 <span class="comment">/// \endcond</span>
+<a name="l00057"></a>00057 <span class="keyword">private</span>:
+<a name="l00058"></a>00058 };
+<a name="l00060"></a>00060 <span class="comment">/// \brief</span>
+<a name="l00061"></a>00061 <span class="comment">/// FdoOdbcOvGeometricPropertyP is a FdoPtr on FdoOdbcOvGeometricPropertyDefinition, provided for convenience.</span>
+<a name="l00062"></a><a class="code" href="_odbc_ov_geometric_property_definition_8h_04c59f42eaac4b45a0cf577ba2946da3.html#04c59f42eaac4b45a0cf577ba2946da3">00062</a> <span class="comment"></span><span class="keyword">typedef</span> FdoPtr<FdoOdbcOvGeometricPropertyDefinition> <a class="code" href="_odbc_ov_geometric_property_definition_8h_04c59f42eaac4b45a0cf577ba2946da3.html#04c59f42eaac4b45a0cf577ba2946da3">FdoOdbcOvGeometricPropertyP</a>;
+<a name="l00064"></a>00064 <span class="preprocessor">#endif</span>
+<a name="l00065"></a>00065 <span class="preprocessor"></span>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/ODBC/_odbc_ov_geometric_property_definition_8h.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_odbc_ov_geometric_property_definition_8h.html?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_odbc_ov_geometric_property_definition_8h.html 2006-12-01 20:39:06+0000
@@ -0,0 +1,73 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<h1>OdbcOvGeometricPropertyDefinition.h File Reference</h1>
+<p>
+<code>#include <<a class="el" href="_rdbms_ov_geometric_property_definition_8h-source.html">Rdbms/Override/RdbmsOvGeometricPropertyDefinition.h</a>></code><br>
+<code>#include <<a class="el" href="_odbc_ov_8h-source.html">Rdbms/Override/ODBC/OdbcOv.h</a>></code><br>
+<p>
+Include dependency graph for OdbcOvGeometricPropertyDefinition.h:<p><center><img src="_odbc_ov_geometric_property_definition_8h__incl.png" border="0" usemap="#OdbcOvGeometricPropertyDefinition.h_map" alt=""></center>
+<map name="OdbcOvGeometricPropertyDefinition.h_map">
+<area href="_rdbms_ov_geometric_property_definition_8h.html" shape="rect" coords="308,7,674,33" alt="">
+<area href="_odbc_ov_8h.html" shape="rect" coords="722,83,948,109" alt="">
+<area href="_odbc_ov_property_definition_8h.html" shape="rect" coords="324,108,658,135" alt="">
+</map>
+<p>
+This graph shows which files directly or indirectly include this file:<p><center><img src="_odbc_ov_geometric_property_definition_8h__dep__incl.png" border="0" usemap="#OdbcOvGeometricPropertyDefinition.hdep_map" alt=""></center>
+<map name="OdbcOvGeometricPropertyDefinition.hdep_map">
+<area href="_odbc_ov_class_definition_8h.html" shape="rect" coords="308,7,482,33" alt="">
+<area href="_odbc_ov_class_collection_8h.html" shape="rect" coords="530,7,706,33" alt="">
+<area href="_odbc_ov_physical_schema_mapping_8h.html" shape="rect" coords="755,7,987,33" alt="">
+</map>
+<p>
+<a href="_odbc_ov_geometric_property_definition_8h-source.html">Go to the source code of this file.</a><table border="0" cellpadding="0" cellspacing="0">
+<tr><td></td></tr>
+<tr><td colspan="2"><br><h2>Classes</h2></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">class </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_odbc_ov_geometric_property_definition.html">FdoOdbcOvGeometricPropertyDefinition</a></td></tr>
+<tr><td class="mdescLeft"> </td><td class="mdescRight">Concrete class defining physical schema overrides for a geometric property definition. <a href="class_fdo_odbc_ov_geometric_property_definition.html#_details">More...</a><br></td></tr>
+<tr><td colspan="2"><br><h2>Typedefs</h2></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">typedef FdoPtr< <a class="el" href="class_fdo_odbc_ov_geometric_property_definition.html">FdoOdbcOvGeometricPropertyDefinition</a> > </td><td class="memItemRight" valign="bottom"><a class="el" href="_odbc_ov_geometric_property_definition_8h_04c59f42eaac4b45a0cf577ba2946da3.html#04c59f42eaac4b45a0cf577ba2946da3">FdoOdbcOvGeometricPropertyP</a></td></tr>
+<tr><td class="mdescLeft"> </td><td class="mdescRight">FdoOdbcOvGeometricPropertyP is a FdoPtr on <a class="el" href="class_fdo_odbc_ov_geometric_property_definition.html">FdoOdbcOvGeometricPropertyDefinition</a>, provided for convenience. <a href="#04c59f42eaac4b45a0cf577ba2946da3"></a><br></td></tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/ODBC/_odbc_ov_geometric_property_definition_8h_04c59f42eaac4b45a0cf577ba2946da3.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_odbc_ov_geometric_property_definition_8h_04c59f42eaac4b45a0cf577ba2946da3.html?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_odbc_ov_geometric_property_definition_8h_04c59f42eaac4b45a0cf577ba2946da3.html 2006-12-01 20:39:06+0000
@@ -0,0 +1,76 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="nav">
+<a class="el" href="_odbc_ov_geometric_property_definition_8h.html">OdbcOvGeometricPropertyDefinition.h</a></div>
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="_odbc_ov_geometric_property_definition_8h_04c59f42eaac4b45a0cf577ba2946da3.html#04c59f42eaac4b45a0cf577ba2946da3">FdoOdbcOvGeometricPropertyP</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="04c59f42eaac4b45a0cf577ba2946da3"></a><!-- doxytag: member="OdbcOvGeometricPropertyDefinition.h::FdoOdbcOvGeometricPropertyP" ref="04c59f42eaac4b45a0cf577ba2946da3" args="" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">typedef FdoPtr<<a class="el" href="class_fdo_odbc_ov_geometric_property_definition.html">FdoOdbcOvGeometricPropertyDefinition</a>> <a class="el" href="_odbc_ov_geometric_property_definition_8h_04c59f42eaac4b45a0cf577ba2946da3.html#04c59f42eaac4b45a0cf577ba2946da3">FdoOdbcOvGeometricPropertyP</a> </td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+FdoOdbcOvGeometricPropertyP is a FdoPtr on <a class="el" href="class_fdo_odbc_ov_geometric_property_definition.html">FdoOdbcOvGeometricPropertyDefinition</a>, provided for convenience.
+<p>
+<p>
+Definition at line <a class="el" href="_odbc_ov_geometric_property_definition_8h-source.html#l00062">62</a> of file <a class="el" href="_odbc_ov_geometric_property_definition_8h-source.html">OdbcOvGeometricPropertyDefinition.h</a>. </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/ODBC/_odbc_ov_geometric_property_definition_8h__dep__incl.map
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_odbc_ov_geometric_property_definition_8h__dep__incl.map?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_odbc_ov_geometric_property_definition_8h__dep__incl.map 2006-12-01 20:39:06+0000
@@ -0,0 +1,4 @@
+base referer
+rect $_odbc_ov_class_definition_8h.html 308,7 482,33
+rect $_odbc_ov_class_collection_8h.html 530,7 706,33
+rect $_odbc_ov_physical_schema_mapping_8h.html 755,7 987,33
Added: trunk/www/docs/ODBC/_odbc_ov_geometric_property_definition_8h__dep__incl.md5
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_odbc_ov_geometric_property_definition_8h__dep__incl.md5?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_odbc_ov_geometric_property_definition_8h__dep__incl.md5 2006-12-01 20:39:06+0000
@@ -0,0 +1 @@
+7bdb22e825ddd7d7f877eb488dbdab0c
Added: trunk/www/docs/ODBC/_odbc_ov_geometric_property_definition_8h__dep__incl.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_odbc_ov_geometric_property_definition_8h__dep__incl.png?view=auto&rev=94
Added: trunk/www/docs/ODBC/_odbc_ov_geometric_property_definition_8h__incl.map
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_odbc_ov_geometric_property_definition_8h__incl.map?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_odbc_ov_geometric_property_definition_8h__incl.map 2006-12-01 20:39:06+0000
@@ -0,0 +1,4 @@
+base referer
+rect $_rdbms_ov_geometric_property_definition_8h.html 308,7 674,33
+rect $_odbc_ov_8h.html 722,83 948,109
+rect $_odbc_ov_property_definition_8h.html 324,108 658,135
Added: trunk/www/docs/ODBC/_odbc_ov_geometric_property_definition_8h__incl.md5
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_odbc_ov_geometric_property_definition_8h__incl.md5?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_odbc_ov_geometric_property_definition_8h__incl.md5 2006-12-01 20:39:06+0000
@@ -0,0 +1 @@
+7135fd05659826f56ba59757371b9a98
Added: trunk/www/docs/ODBC/_odbc_ov_geometric_property_definition_8h__incl.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_odbc_ov_geometric_property_definition_8h__incl.png?view=auto&rev=94
Added: trunk/www/docs/ODBC/_odbc_ov_physical_schema_mapping_8h-source.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_odbc_ov_physical_schema_mapping_8h-source.html?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_odbc_ov_physical_schema_mapping_8h-source.html 2006-12-01 20:39:06+0000
@@ -0,0 +1,148 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<h1>OdbcOvPhysicalSchemaMapping.h</h1><a href="_odbc_ov_physical_schema_mapping_8h.html">Go to the documentation of this file.</a><div class="fragment"><pre class="fragment"><a name="l00001"></a>00001 <span class="preprocessor">#ifndef FDO_ODBCOVPHYSICALSCHEMAMAPPING_H</span>
+<a name="l00002"></a>00002 <span class="preprocessor"></span><span class="preprocessor">#define FDO_ODBCOVPHYSICALSCHEMAMAPPING_H</span>
+<a name="l00020"></a>00020 <span class="preprocessor">#include <<a class="code" href="_rdbms_ov_physical_schema_mapping_8h.html">Rdbms/Override/RdbmsOvPhysicalSchemaMapping.h</a>></span>
+<a name="l00021"></a>00021 <span class="preprocessor">#include <<a class="code" href="_odbc_ov_8h.html">Rdbms/Override/ODBC/OdbcOv.h</a>></span>
+<a name="l00022"></a>00022 <span class="preprocessor">#include <<a class="code" href="_odbc_ov_class_collection_8h.html">Rdbms/Override/ODBC/OdbcOvClassCollection.h</a>></span>
+<a name="l00025"></a>00025 <span class="comment">/// Concrete class offering schema overrides for</span>
+<a name="l00026"></a>00026 <span class="comment">/// the Odbc Provider.</span>
+<a name="l00027"></a><a class="code" href="class_fdo_odbc_ov_physical_schema_mapping.html">00027</a> <span class="comment"></span><span class="keyword">class </span><a class="code" href="class_fdo_odbc_ov_physical_schema_mapping.html">FdoOdbcOvPhysicalSchemaMapping</a> : <span class="keyword">public</span> <a class="code" href="class_fdo_rdbms_ov_physical_schema_mapping.html">FdoRdbmsOvPhysicalSchemaMapping</a>
+<a name="l00028"></a>00028 {
+<a name="l00030"></a>00030 <span class="keyword">public</span>:
+<a name="l00031"></a>00031 <span class="comment"></span>
+<a name="l00033"></a>00033 <span class="comment"> /// Constructs a default of an FdoOdbcOvPhysicalSchemaMapping</span>
+<a name="l00036"></a>00036 <span class="comment"> /// Returns FdoOdbcOvPhysicalSchemaMapping</span>
+<a name="l00038"></a>00038 <span class="comment"></span> <a class="code" href="_odbc_ov_8h_91b15f0fd565be7c245bbe8e5247fbdc.html#91b15f0fd565be7c245bbe8e5247fbdc">FDOODBC_OV_API</a> <span class="keyword">static</span> <a class="code" href="class_fdo_odbc_ov_physical_schema_mapping.html">FdoOdbcOvPhysicalSchemaMapping</a>* <a class="code" href="class_fdo_odbc_ov_physical_schema_mapping_74f6fe4a4266b1a72b63f3b0875246b0.html#74f6fe4a4266b1a72b63f3b0875246b0">Create</a>();
+<a name="l00039"></a>00039 <span class="comment"></span>
+<a name="l00041"></a>00041 <span class="comment"> /// Constructs an instance of an FdoOdbcOvPhysicalSchemaMapping using the specified arguments</span>
+<a name="l00047"></a>00047 <span class="comment"> /// Returns FdoOdbcOvPhysicalSchemaMapping</span>
+<a name="l00049"></a>00049 <span class="comment"></span> <a class="code" href="_odbc_ov_8h_91b15f0fd565be7c245bbe8e5247fbdc.html#91b15f0fd565be7c245bbe8e5247fbdc">FDOODBC_OV_API</a> <span class="keyword">static</span> <a class="code" href="class_fdo_odbc_ov_physical_schema_mapping.html">FdoOdbcOvPhysicalSchemaMapping</a>* <a class="code" href="class_fdo_odbc_ov_physical_schema_mapping_74f6fe4a4266b1a72b63f3b0875246b0.html#74f6fe4a4266b1a72b63f3b0875246b0">Create</a>(FdoString* name);
+<a name="l00050"></a>00050 <span class="comment"></span>
+<a name="l00052"></a>00052 <span class="comment"> /// Gets the classes</span>
+<a name="l00055"></a>00055 <span class="comment"> /// Returns the classes</span>
+<a name="l00057"></a>00057 <span class="comment"></span> <a class="code" href="_odbc_ov_8h_91b15f0fd565be7c245bbe8e5247fbdc.html#91b15f0fd565be7c245bbe8e5247fbdc">FDOODBC_OV_API</a> <a class="code" href="class_fdo_odbc_ov_class_collection.html">FdoOdbcOvClassCollection</a>* <a class="code" href="class_fdo_odbc_ov_physical_schema_mapping_1462526e1fd744995659a18d31253bcf.html#1462526e1fd744995659a18d31253bcf">GetClasses</a>();
+<a name="l00058"></a>00058 <span class="comment"></span>
+<a name="l00060"></a>00060 <span class="comment"> /// Gets the provider name</span>
+<a name="l00063"></a>00063 <span class="comment"> /// Returns the provider name</span>
+<a name="l00065"></a>00065 <span class="comment"></span> <a class="code" href="_odbc_ov_8h_91b15f0fd565be7c245bbe8e5247fbdc.html#91b15f0fd565be7c245bbe8e5247fbdc">FDOODBC_OV_API</a> <span class="keyword">virtual</span> FdoString *<a class="code" href="class_fdo_odbc_ov_physical_schema_mapping_1cca5fdb1b40bbe2efa466db2c9f27a2.html#1cca5fdb1b40bbe2efa466db2c9f27a2">GetProvider</a>(<span class="keywordtype">void</span>);
+<a name="l00069"></a>00069 <span class="comment"> /// XML Serialization functions, not part of API.</span>
+<a name="l00070"></a>00070 <span class="comment"></span><span class="comment"></span>
+<a name="l00071"></a>00071 <span class="comment"> /// Serialize this property to XML.</span>
+<a name="l00072"></a>00072 <span class="comment"></span> <span class="keyword">virtual</span> <span class="keywordtype">void</span> <a class="code" href="class_fdo_rdbms_ov_physical_schema_mapping_0754e6d7807cd92a2b6cd1e3b3baa91d.html#0754e6d7807cd92a2b6cd1e3b3baa91d">_writeXmlAttributes</a>(FdoXmlWriter* xmlWriter, <span class="keyword">const</span> FdoXmlFlags* flags);
+<a name="l00073"></a>00073 <span class="comment"></span>
+<a name="l00074"></a>00074 <span class="comment"> /// Initialize this element from its XML attributes</span>
+<a name="l00075"></a>00075 <span class="comment"></span> <span class="keyword">virtual</span> <span class="keywordtype">void</span> <a class="code" href="class_fdo_rdbms_ov_physical_schema_mapping_3346828609c0761c0f9a35ce1da88cab.html#3346828609c0761c0f9a35ce1da88cab">InitFromXml</a>(FdoXmlSaxContext* pContext, FdoXmlAttributeCollection* attrs);
+<a name="l00076"></a>00076 <span class="comment"></span>
+<a name="l00077"></a>00077 <span class="comment">/// \endcond</span>
+<a name="l00078"></a>00078 <span class="comment"></span>
+<a name="l00079"></a>00079 <span class="keyword">protected</span>:
+<a name="l00080"></a>00080 <a class="code" href="class_fdo_odbc_ov_physical_schema_mapping_1c0a7ecf79c3a25d76abaca1bc99e5c2.html#1c0a7ecf79c3a25d76abaca1bc99e5c2">FdoOdbcOvPhysicalSchemaMapping</a>();
+<a name="l00081"></a>00081 <a class="code" href="class_fdo_odbc_ov_physical_schema_mapping_1c0a7ecf79c3a25d76abaca1bc99e5c2.html#1c0a7ecf79c3a25d76abaca1bc99e5c2">FdoOdbcOvPhysicalSchemaMapping</a>(FdoString* name);
+<a name="l00082"></a>00082 <span class="keyword">virtual</span> <a class="code" href="class_fdo_odbc_ov_physical_schema_mapping_d5025f56de7a427a5c9356974370c5ee.html#d5025f56de7a427a5c9356974370c5ee">~FdoOdbcOvPhysicalSchemaMapping</a>();
+<a name="l00083"></a>00083 <span class="keyword">virtual</span> <span class="keywordtype">void</span> <a class="code" href="class_fdo_odbc_ov_physical_schema_mapping_26ecb8ceedcbddcf00e3e697538ce01c.html#26ecb8ceedcbddcf00e3e697538ce01c">Dispose</a>();
+<a name="l00084"></a>00084 <span class="comment"></span>
+<a name="l00085"></a>00085 <span class="comment"> /// Create a class override from XML attributes</span>
+<a name="l00086"></a>00086 <span class="comment"></span> <span class="keyword">virtual</span> <a class="code" href="class_fdo_rdbms_ov_class_definition.html">FdoRdbmsOvClassDefinition</a>* <a class="code" href="class_fdo_odbc_ov_physical_schema_mapping_13bd733f5dda9dfb5c082c5f747a7b4d.html#13bd733f5dda9dfb5c082c5f747a7b4d">CreateClass</a>(
+<a name="l00087"></a>00087 FdoXmlSaxContext* context,
+<a name="l00088"></a>00088 FdoXmlAttributeCollection* atts
+<a name="l00089"></a>00089 );
+<a name="l00090"></a>00090 <span class="comment"></span>
+<a name="l00091"></a>00091 <span class="comment"> /// Add the given class override to this schema override set</span>
+<a name="l00092"></a>00092 <span class="comment"></span> <span class="keyword">virtual</span> <span class="keywordtype">void</span> <a class="code" href="class_fdo_odbc_ov_physical_schema_mapping_0e512fcbe78b6c3258bcd822988fdfa2.html#0e512fcbe78b6c3258bcd822988fdfa2">AddClass</a>(
+<a name="l00093"></a>00093 <a class="code" href="class_fdo_rdbms_ov_class_definition.html">FdoRdbmsOvClassDefinition</a>* pClass
+<a name="l00094"></a>00094 );
+<a name="l00095"></a>00095 <span class="comment"></span>
+<a name="l00096"></a>00096 <span class="comment"> /// Common initializer for all constructors:</span>
+<a name="l00097"></a>00097 <span class="comment"></span> <span class="keywordtype">void</span> <a class="code" href="class_fdo_odbc_ov_physical_schema_mapping_8bf14a911b6fc5754ff741f3fa4d9456.html#8bf14a911b6fc5754ff741f3fa4d9456">Init</a>();
+<a name="l00098"></a>00098
+<a name="l00099"></a>00099 <span class="keyword">private</span>:
+<a name="l00100"></a>00100 <a class="code" href="_odbc_ov_class_collection_8h_45dc2dbdb78cdf026c7aa3e26d67bd29.html#45dc2dbdb78cdf026c7aa3e26d67bd29">FdoOdbcOvClassesP</a> mClasses;
+<a name="l00101"></a>00101 };
+<a name="l00102"></a>00102 <span class="comment"></span>
+<a name="l00103"></a>00103 <span class="comment">/// \brief</span>
+<a name="l00104"></a>00104 <span class="comment">/// FdoOdbcOvSchemaMappingP is a FdoPtr on FdoOdbcOvPhysicalSchemaMapping, provided for convenience.</span>
+<a name="l00105"></a><a class="code" href="_odbc_ov_physical_schema_mapping_8h_16e671a2edec1595ecd12c49caee7f95.html#16e671a2edec1595ecd12c49caee7f95">00105</a> <span class="comment"></span><span class="keyword">typedef</span> FdoPtr<FdoOdbcOvPhysicalSchemaMapping> <a class="code" href="_odbc_ov_physical_schema_mapping_8h_16e671a2edec1595ecd12c49caee7f95.html#16e671a2edec1595ecd12c49caee7f95">FdoOdbcOvSchemaMappingP</a>;
+<a name="l00106"></a>00106
+<a name="l00107"></a>00107 <span class="preprocessor">#endif</span>
+<a name="l00108"></a>00108 <span class="preprocessor"></span>
+<a name="l00109"></a>00109
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/ODBC/_odbc_ov_physical_schema_mapping_8h.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_odbc_ov_physical_schema_mapping_8h.html?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_odbc_ov_physical_schema_mapping_8h.html 2006-12-01 20:39:06+0000
@@ -0,0 +1,65 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<h1>OdbcOvPhysicalSchemaMapping.h File Reference</h1>
+<p>
+<code>#include <<a class="el" href="_rdbms_ov_physical_schema_mapping_8h-source.html">Rdbms/Override/RdbmsOvPhysicalSchemaMapping.h</a>></code><br>
+<code>#include <<a class="el" href="_odbc_ov_class_collection_8h-source.html">Rdbms/Override/ODBC/OdbcOvClassCollection.h</a>></code><br>
+<p>
+Include dependency graph for OdbcOvPhysicalSchemaMapping.h:<p><center><img src="_odbc_ov_physical_schema_mapping_8h__incl.png" border="0" usemap="#OdbcOvPhysicalSchemaMapping.h_map" alt=""></center>
+<map name="OdbcOvPhysicalSchemaMapping.h_map">
+<area href="_rdbms_ov_physical_schema_mapping_8h.html" shape="rect" coords="289,7,636,33" alt="">
+<area href="_odbc_ov_8h.html" shape="rect" coords="684,83,911,109" alt="">
+<area href="_odbc_ov_class_collection_8h.html" shape="rect" coords="303,108,623,135" alt="">
+</map>
+<p>
+<a href="_odbc_ov_physical_schema_mapping_8h-source.html">Go to the source code of this file.</a><table border="0" cellpadding="0" cellspacing="0">
+<tr><td></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">class </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_odbc_ov_physical_schema_mapping.html">FdoOdbcOvPhysicalSchemaMapping</a></td></tr>
+<tr><td class="mdescLeft"> </td><td class="mdescRight">Concrete class offering schema overrides for the Odbc Provider. <a href="class_fdo_odbc_ov_physical_schema_mapping.html#_details">More...</a><br></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">typedef FdoPtr< <a class="el" href="class_fdo_odbc_ov_physical_schema_mapping.html">FdoOdbcOvPhysicalSchemaMapping</a> > </td><td class="memItemRight" valign="bottom"><a class="el" href="_odbc_ov_physical_schema_mapping_8h_16e671a2edec1595ecd12c49caee7f95.html#16e671a2edec1595ecd12c49caee7f95">FdoOdbcOvSchemaMappingP</a></td></tr>
+<tr><td class="mdescLeft"> </td><td class="mdescRight">FdoOdbcOvSchemaMappingP is a FdoPtr on <a class="el" href="class_fdo_odbc_ov_physical_schema_mapping.html">FdoOdbcOvPhysicalSchemaMapping</a>, provided for convenience. <a href="#16e671a2edec1595ecd12c49caee7f95"></a><br></td></tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/ODBC/_odbc_ov_physical_schema_mapping_8h_16e671a2edec1595ecd12c49caee7f95.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_odbc_ov_physical_schema_mapping_8h_16e671a2edec1595ecd12c49caee7f95.html?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_odbc_ov_physical_schema_mapping_8h_16e671a2edec1595ecd12c49caee7f95.html 2006-12-01 20:39:06+0000
@@ -0,0 +1,76 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="nav">
+<a class="el" href="_odbc_ov_physical_schema_mapping_8h.html">OdbcOvPhysicalSchemaMapping.h</a></div>
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="_odbc_ov_physical_schema_mapping_8h_16e671a2edec1595ecd12c49caee7f95.html#16e671a2edec1595ecd12c49caee7f95">FdoOdbcOvSchemaMappingP</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="16e671a2edec1595ecd12c49caee7f95"></a><!-- doxytag: member="OdbcOvPhysicalSchemaMapping.h::FdoOdbcOvSchemaMappingP" ref="16e671a2edec1595ecd12c49caee7f95" args="" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">typedef FdoPtr<<a class="el" href="class_fdo_odbc_ov_physical_schema_mapping.html">FdoOdbcOvPhysicalSchemaMapping</a>> <a class="el" href="_odbc_ov_physical_schema_mapping_8h_16e671a2edec1595ecd12c49caee7f95.html#16e671a2edec1595ecd12c49caee7f95">FdoOdbcOvSchemaMappingP</a> </td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+FdoOdbcOvSchemaMappingP is a FdoPtr on <a class="el" href="class_fdo_odbc_ov_physical_schema_mapping.html">FdoOdbcOvPhysicalSchemaMapping</a>, provided for convenience.
+<p>
+<p>
+Definition at line <a class="el" href="_odbc_ov_physical_schema_mapping_8h-source.html#l00105">105</a> of file <a class="el" href="_odbc_ov_physical_schema_mapping_8h-source.html">OdbcOvPhysicalSchemaMapping.h</a>. </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/ODBC/_odbc_ov_physical_schema_mapping_8h__incl.map
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_odbc_ov_physical_schema_mapping_8h__incl.map?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_odbc_ov_physical_schema_mapping_8h__incl.map 2006-12-01 20:39:06+0000
@@ -0,0 +1,4 @@
+base referer
+rect $_rdbms_ov_physical_schema_mapping_8h.html 289,7 636,33
+rect $_odbc_ov_8h.html 684,83 911,109
+rect $_odbc_ov_class_collection_8h.html 303,108 623,135
Added: trunk/www/docs/ODBC/_odbc_ov_physical_schema_mapping_8h__incl.md5
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_odbc_ov_physical_schema_mapping_8h__incl.md5?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_odbc_ov_physical_schema_mapping_8h__incl.md5 2006-12-01 20:39:06+0000
@@ -0,0 +1 @@
+c3d8127f288e6bb47c52fce1be9f1ed6
Added: trunk/www/docs/ODBC/_odbc_ov_physical_schema_mapping_8h__incl.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_odbc_ov_physical_schema_mapping_8h__incl.png?view=auto&rev=94
Added: trunk/www/docs/ODBC/_odbc_ov_property_definition_8h-source.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_odbc_ov_property_definition_8h-source.html?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_odbc_ov_property_definition_8h-source.html 2006-12-01 20:39:06+0000
@@ -0,0 +1,81 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<h1>OdbcOvPropertyDefinition.h</h1><a href="_odbc_ov_property_definition_8h.html">Go to the documentation of this file.</a><div class="fragment"><pre class="fragment"><a name="l00001"></a>00001 <span class="preprocessor">#ifndef FDO_OdbcOVPROPERTYDEFINITION_H</span>
+<a name="l00002"></a>00002 <span class="preprocessor"></span><span class="preprocessor">#define FDO_OdbcOVPROPERTYDEFINITION_H</span>
+<a name="l00020"></a>00020 <span class="preprocessor">#include <<a class="code" href="_rdbms_ov_property_definition_8h.html">Rdbms/Override/RdbmsOvPropertyDefinition.h</a>></span>
+<a name="l00022"></a>00022 <span class="comment"></span>
+<a name="l00023"></a>00023 <span class="comment">/// \brief</span>
+<a name="l00024"></a>00024 <span class="comment">/// Abstract class defining physical schema overrides for a property definition.</span>
+<a name="l00025"></a><a class="code" href="class_fdo_odbc_ov_property_definition.html">00025</a> <span class="comment"></span><span class="keyword">class </span><a class="code" href="class_fdo_odbc_ov_property_definition.html">FdoOdbcOvPropertyDefinition</a> : <span class="keyword">public</span> <span class="keyword">virtual</span> <a class="code" href="class_fdo_rdbms_ov_property_definition.html">FdoRdbmsOvPropertyDefinition</a>
+<a name="l00026"></a>00026 {
+<a name="l00027"></a><a class="code" href="class_fdo_odbc_ov_property_definition_6b4a0d61ef13d1c1271b58ec47eea75c.html#6b4a0d61ef13d1c1271b58ec47eea75c">00027</a> <span class="keyword">friend</span> <span class="keyword">class </span><a class="code" href="class_fdo_odbc_ov_class_definition.html">FdoOdbcOvClassDefinition</a>;
+<a name="l00028"></a>00028 <span class="keyword">protected</span>:
+<a name="l00029"></a>00029 <a class="code" href="class_fdo_odbc_ov_property_definition_6fc812d7505d71d1fd82a54cded73119.html#6fc812d7505d71d1fd82a54cded73119">FdoOdbcOvPropertyDefinition</a>();
+<a name="l00030"></a>00030 <a class="code" href="class_fdo_odbc_ov_property_definition_6fc812d7505d71d1fd82a54cded73119.html#6fc812d7505d71d1fd82a54cded73119">FdoOdbcOvPropertyDefinition</a>(FdoString* name);
+<a name="l00031"></a>00031 <span class="keyword">virtual</span> <a class="code" href="class_fdo_odbc_ov_property_definition_24a908a2541982ff60a17e6b819f365d.html#24a908a2541982ff60a17e6b819f365d">~FdoOdbcOvPropertyDefinition</a>();
+<a name="l00032"></a>00032 <span class="keyword">virtual</span> <span class="keywordtype">void</span> <a class="code" href="class_fdo_odbc_ov_property_definition_55cd087e142f097d0a9dae6fd63489fc.html#55cd087e142f097d0a9dae6fd63489fc">Dispose</a>();
+<a name="l00034"></a>00034 };
+<a name="l00036"></a>00036 <span class="comment">/// \brief</span>
+<a name="l00037"></a>00037 <span class="comment">/// FdoOdbcOvPropertyP is a FdoPtr on FdoOdbcOvPropertyDefinition, provided for convenience.</span>
+<a name="l00038"></a><a class="code" href="_odbc_ov_property_definition_8h_7b052f5fa1f33d3d0016cf2ff0282b03.html#7b052f5fa1f33d3d0016cf2ff0282b03">00038</a> <span class="comment"></span><span class="keyword">typedef</span> FdoPtr<FdoOdbcOvPropertyDefinition> <a class="code" href="_odbc_ov_property_definition_8h_7b052f5fa1f33d3d0016cf2ff0282b03.html#7b052f5fa1f33d3d0016cf2ff0282b03">FdoOdbcOvPropertyP</a>;
+<a name="l00040"></a>00040 <span class="preprocessor">#endif</span>
+<a name="l00041"></a>00041 <span class="preprocessor"></span>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/ODBC/_odbc_ov_property_definition_8h.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_odbc_ov_property_definition_8h.html?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_odbc_ov_property_definition_8h.html 2006-12-01 20:39:06+0000
@@ -0,0 +1,74 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<h1>OdbcOvPropertyDefinition.h File Reference</h1>
+<p>
+<code>#include <<a class="el" href="_rdbms_ov_property_definition_8h-source.html">Rdbms/Override/RdbmsOvPropertyDefinition.h</a>></code><br>
+<p>
+Include dependency graph for OdbcOvPropertyDefinition.h:<p><center><img src="_odbc_ov_property_definition_8h__incl.png" border="0" usemap="#OdbcOvPropertyDefinition.h_map" alt=""></center>
+<map name="OdbcOvPropertyDefinition.h_map">
+<area href="_rdbms_ov_property_definition_8h.html" shape="rect" coords="248,32,549,59" alt="">
+<area href="_odbc_ov_8h.html" shape="rect" coords="285,83,512,109" alt="">
+<area href="_rdbms_ov_8h.html" shape="rect" coords="671,57,865,84" alt="">
+</map>
+<p>
+This graph shows which files directly or indirectly include this file:<p><center><img src="_odbc_ov_property_definition_8h__dep__incl.png" border="0" usemap="#OdbcOvPropertyDefinition.hdep_map" alt=""></center>
+<map name="OdbcOvPropertyDefinition.hdep_map">
+<area href="_odbc_ov_data_property_definition_8h.html" shape="rect" coords="264,7,483,33" alt="">
+<area href="_odbc_ov_geometric_property_definition_8h.html" shape="rect" coords="247,57,500,84" alt="">
+<area href="_odbc_ov_property_definition_collection_8h.html" shape="rect" coords="249,108,497,135" alt="">
+<area href="_odbc_ov_class_definition_8h.html" shape="rect" coords="548,57,721,84" alt="">
+<area href="_odbc_ov_class_collection_8h.html" shape="rect" coords="769,57,945,84" alt="">
+</map>
+<p>
+<a href="_odbc_ov_property_definition_8h-source.html">Go to the source code of this file.</a><table border="0" cellpadding="0" cellspacing="0">
+<tr><td></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">class </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_odbc_ov_property_definition.html">FdoOdbcOvPropertyDefinition</a></td></tr>
+<tr><td class="mdescLeft"> </td><td class="mdescRight">Abstract class defining physical schema overrides for a property definition. <a href="class_fdo_odbc_ov_property_definition.html#_details">More...</a><br></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">typedef FdoPtr< <a class="el" href="class_fdo_odbc_ov_property_definition.html">FdoOdbcOvPropertyDefinition</a> > </td><td class="memItemRight" valign="bottom"><a class="el" href="_odbc_ov_property_definition_8h_7b052f5fa1f33d3d0016cf2ff0282b03.html#7b052f5fa1f33d3d0016cf2ff0282b03">FdoOdbcOvPropertyP</a></td></tr>
+<tr><td class="mdescLeft"> </td><td class="mdescRight">FdoOdbcOvPropertyP is a FdoPtr on <a class="el" href="class_fdo_odbc_ov_property_definition.html">FdoOdbcOvPropertyDefinition</a>, provided for convenience. <a href="#7b052f5fa1f33d3d0016cf2ff0282b03"></a><br></td></tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/ODBC/_odbc_ov_property_definition_8h_7b052f5fa1f33d3d0016cf2ff0282b03.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_odbc_ov_property_definition_8h_7b052f5fa1f33d3d0016cf2ff0282b03.html?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_odbc_ov_property_definition_8h_7b052f5fa1f33d3d0016cf2ff0282b03.html 2006-12-01 20:39:06+0000
@@ -0,0 +1,76 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="nav">
+<a class="el" href="_odbc_ov_property_definition_8h.html">OdbcOvPropertyDefinition.h</a></div>
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="_odbc_ov_property_definition_8h_7b052f5fa1f33d3d0016cf2ff0282b03.html#7b052f5fa1f33d3d0016cf2ff0282b03">FdoOdbcOvPropertyP</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="7b052f5fa1f33d3d0016cf2ff0282b03"></a><!-- doxytag: member="OdbcOvPropertyDefinition.h::FdoOdbcOvPropertyP" ref="7b052f5fa1f33d3d0016cf2ff0282b03" args="" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">typedef FdoPtr<<a class="el" href="class_fdo_odbc_ov_property_definition.html">FdoOdbcOvPropertyDefinition</a>> <a class="el" href="_odbc_ov_property_definition_8h_7b052f5fa1f33d3d0016cf2ff0282b03.html#7b052f5fa1f33d3d0016cf2ff0282b03">FdoOdbcOvPropertyP</a> </td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+FdoOdbcOvPropertyP is a FdoPtr on <a class="el" href="class_fdo_odbc_ov_property_definition.html">FdoOdbcOvPropertyDefinition</a>, provided for convenience.
+<p>
+<p>
+Definition at line <a class="el" href="_odbc_ov_property_definition_8h-source.html#l00038">38</a> of file <a class="el" href="_odbc_ov_property_definition_8h-source.html">OdbcOvPropertyDefinition.h</a>. </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/ODBC/_odbc_ov_property_definition_8h__dep__incl.map
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_odbc_ov_property_definition_8h__dep__incl.map?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_odbc_ov_property_definition_8h__dep__incl.map 2006-12-01 20:39:06+0000
@@ -0,0 +1,6 @@
+base referer
+rect $_odbc_ov_data_property_definition_8h.html 264,7 483,33
+rect $_odbc_ov_geometric_property_definition_8h.html 247,57 500,84
+rect $_odbc_ov_property_definition_collection_8h.html 249,108 497,135
+rect $_odbc_ov_class_definition_8h.html 548,57 721,84
+rect $_odbc_ov_class_collection_8h.html 769,57 945,84
Added: trunk/www/docs/ODBC/_odbc_ov_property_definition_8h__dep__incl.md5
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_odbc_ov_property_definition_8h__dep__incl.md5?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_odbc_ov_property_definition_8h__dep__incl.md5 2006-12-01 20:39:06+0000
@@ -0,0 +1 @@
+a92098d57bd8213a807438ca0a534c74
Added: trunk/www/docs/ODBC/_odbc_ov_property_definition_8h__dep__incl.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_odbc_ov_property_definition_8h__dep__incl.png?view=auto&rev=94
Added: trunk/www/docs/ODBC/_odbc_ov_property_definition_8h__incl.map
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_odbc_ov_property_definition_8h__incl.map?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_odbc_ov_property_definition_8h__incl.map 2006-12-01 20:39:06+0000
@@ -0,0 +1,4 @@
+base referer
+rect $_rdbms_ov_property_definition_8h.html 248,32 549,59
+rect $_odbc_ov_8h.html 285,83 512,109
+rect $_rdbms_ov_8h.html 671,57 865,84
Added: trunk/www/docs/ODBC/_odbc_ov_property_definition_8h__incl.md5
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_odbc_ov_property_definition_8h__incl.md5?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_odbc_ov_property_definition_8h__incl.md5 2006-12-01 20:39:06+0000
@@ -0,0 +1 @@
+f33ce311cf27e6256510841bcee11b13
Added: trunk/www/docs/ODBC/_odbc_ov_property_definition_8h__incl.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_odbc_ov_property_definition_8h__incl.png?view=auto&rev=94
Added: trunk/www/docs/ODBC/_odbc_ov_property_definition_collection_8h-source.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_odbc_ov_property_definition_collection_8h-source.html?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_odbc_ov_property_definition_collection_8h-source.html 2006-12-01 20:39:06+0000
@@ -0,0 +1,105 @@
+<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN" "http://www.w3.org/TR/html4/loose.dtd">
+<html>
+ <head>
+ <meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
+ <title>OSGeo FDO Provider for ODBC API Reference</title>
+ <link href="custom.css" rel="stylesheet" type="text/css">
+ <link href="tabs.css" rel="stylesheet" type="text/css">
+ </head>
+ <body bgcolor="#FFFFFF">
+ <table width="100%" border="0">
+ <tr>
+ <td><b>API Reference<b></td>
+ <td align="right"><b>OSGeo FDO Provider for ODBC<b></td>
+ </tr>
+ </table>
+<!-- End of: header.html -->
+<!-- Generated by Doxygen 1.4.6-NO -->
+<div class="tabs">
+ <ul>
+ <li><a href="main.html"><span>Main Page</span></a></li>
+ <li><a href="classes.html"><span>Classes</span></a></li>
+ <li id="current"><a href="files.html"><span>Files</span></a></li>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ <li><a href="files.html"><span>File List</span></a></li>
+ <li><a href="globals.html"><span>File Members</span></a></li>
+ </ul></div>
+<h1>OdbcOvPropertyDefinitionCollection.h</h1><a href="_odbc_ov_property_definition_collection_8h.html">Go to the documentation of this file.</a><div class="fragment"><pre class="fragment"><a name="l00001"></a>00001 <span class="preprocessor">#ifndef FDO_OdbcOVPROPERTYDEFINITIONCOLLECTION_H</span>
+<a name="l00002"></a>00002 <span class="preprocessor"></span><span class="preprocessor">#define FDO_OdbcOVPROPERTYDEFINITIONCOLLECTION_H</span>
+<a name="l00020"></a>00020 <span class="preprocessor">#include <<a class="code" href="_odbc_ov_8h.html">Rdbms/Override/ODBC/OdbcOv.h</a>></span>
+<a name="l00021"></a>00021 <span class="preprocessor">#include <<a class="code" href="_odbc_ov_property_definition_8h.html">Rdbms/Override/ODBC/OdbcOvPropertyDefinition.h</a>></span>
+<a name="l00022"></a>00022 <span class="preprocessor">#include <<a class="code" href="_rdbms_ov_property_definition_collection_8h.html">Rdbms/Override/RdbmsOvPropertyDefinitionCollection.h</a>></span>
+<a name="l00023"></a>00023 <span class="preprocessor">#include <Fdo/Commands/Schema/PhysicalElementMappingCollection.h></span>
+<a name="l00024"></a>00024 <span class="comment"></span>
+<a name="l00025"></a>00025 <span class="comment">/// \brief</span>
+<a name="l00026"></a>00026 <span class="comment">/// Concrete class defining physical schema overrides for a collection of property</span>
+<a name="l00027"></a>00027 <span class="comment">/// definitions.</span>
+<a name="l00028"></a><a class="code" href="class_fdo_odbc_ov_property_definition_collection.html">00028</a> <span class="comment"></span><span class="keyword">class </span><a class="code" href="class_fdo_odbc_ov_property_definition_collection.html">FdoOdbcOvPropertyDefinitionCollection</a> : <span class="keyword">public</span> FdoRestrictedNamedCollection<FdoRdbmsOvPropertyDefinition,FdoOdbcOvPropertyDefinition,FdoRdbmsOvPropertyDefinitionCollection>
+<a name="l00029"></a>00029 {
+<a name="l00030"></a>00030 <span class="keyword">public</span>:<span class="comment"></span>
+<a name="l00031"></a>00031 <span class="comment"> /// \brief</span>
+<a name="l00032"></a>00032 <span class="comment"> /// Constructs a default of an FdoOdbcOvPropertyDefinitionCollection</span>
+<a name="l00033"></a>00033 <span class="comment"> /// </span>
+<a name="l00034"></a>00034 <span class="comment"> /// \return</span>
+<a name="l00035"></a>00035 <span class="comment"> /// Returns FdoOdbcOvPropertyDefinitionCollection</span>
+<a name="l00036"></a>00036 <span class="comment"> /// </span>
+<a name="l00037"></a>00037 <span class="comment"></span> <a class="code" href="_odbc_ov_8h_91b15f0fd565be7c245bbe8e5247fbdc.html#91b15f0fd565be7c245bbe8e5247fbdc">FDOODBC_OV_API</a> <span class="keyword">static</span> <a class="code" href="class_fdo_odbc_ov_property_definition_collection.html">FdoOdbcOvPropertyDefinitionCollection</a>* <a class="code" href="class_fdo_odbc_ov_property_definition_collection_b482b0206f4cefb72ca99592cbccf12e.html#b482b0206f4cefb72ca99592cbccf12e">Create</a>();
+<a name="l00039"></a>00039 <span class="comment"> /// \brief</span>
+<a name="l00040"></a>00040 <span class="comment"> /// Constructs an instance of an FdoOdbcOvPropertyDefinitionCollection using the specified arguments</span>
+<a name="l00041"></a>00041 <span class="comment"> /// </span>
+<a name="l00042"></a>00042 <span class="comment"> /// \param parent </span>
+<a name="l00043"></a>00043 <span class="comment"> /// Input parent</span>
+<a name="l00044"></a>00044 <span class="comment"> /// </span>
+<a name="l00045"></a>00045 <span class="comment"> /// \return</span>
+<a name="l00046"></a>00046 <span class="comment"> /// Returns FdoOdbcOvPropertyDefinitionCollection</span>
+<a name="l00047"></a>00047 <span class="comment"> /// </span>
+<a name="l00048"></a>00048 <span class="comment"></span> <a class="code" href="_odbc_ov_8h_91b15f0fd565be7c245bbe8e5247fbdc.html#91b15f0fd565be7c245bbe8e5247fbdc">FDOODBC_OV_API</a> <span class="keyword">static</span> <a class="code" href="class_fdo_odbc_ov_property_definition_collection.html">FdoOdbcOvPropertyDefinitionCollection</a>* <a class="code" href="class_fdo_odbc_ov_property_definition_collection_b482b0206f4cefb72ca99592cbccf12e.html#b482b0206f4cefb72ca99592cbccf12e">Create</a>(<a class="code" href="class_fdo_rdbms_ov_property_definition_collection.html">FdoRdbmsOvPropertyDefinitionCollection</a>* baseCollection );
+<a name="l00050"></a>00050 <span class="keyword">protected</span>:
+<a name="l00051"></a>00051 <a class="code" href="class_fdo_odbc_ov_property_definition_collection_d8a740d445aa7746c49809e86cf67fa7.html#d8a740d445aa7746c49809e86cf67fa7">FdoOdbcOvPropertyDefinitionCollection</a>();
+<a name="l00052"></a>00052 <a class="code" href="class_fdo_odbc_ov_property_definition_collection_d8a740d445aa7746c49809e86cf67fa7.html#d8a740d445aa7746c49809e86cf67fa7">FdoOdbcOvPropertyDefinitionCollection</a>(<a class="code" href="class_fdo_rdbms_ov_property_definition_collection.html">FdoRdbmsOvPropertyDefinitionCollection</a>* baseCollection);
+<a name="l00053"></a>00053 <span class="keyword">virtual</span> <a class="code" href="class_fdo_odbc_ov_property_definition_collection_83508e8306545e4d2f160ccf37c110bd.html#83508e8306545e4d2f160ccf37c110bd">~FdoOdbcOvPropertyDefinitionCollection</a>();
+<a name="l00054"></a>00054 <span class="keyword">virtual</span> <span class="keywordtype">void</span> <a class="code" href="class_fdo_odbc_ov_property_definition_collection_4f891687e268fe821988c4957c1da2fd.html#4f891687e268fe821988c4957c1da2fd">Dispose</a>();
+<a name="l00056"></a>00056 <span class="keyword">virtual</span> <a class="code" href="class_fdo_odbc_ov_property_definition.html">FdoOdbcOvPropertyDefinition</a>* <a class="code" href="class_fdo_odbc_ov_property_definition_collection_5704d820b51c74f06ae2055a476ebc92.html#5704d820b51c74f06ae2055a476ebc92">DownCast</a>( <a class="code" href="class_fdo_rdbms_ov_property_definition.html">FdoRdbmsOvPropertyDefinition</a>* value ) <span class="keyword">const</span>;
+<a name="l00057"></a>00057 };
+<a name="l00059"></a>00059 <span class="comment">/// \brief</span>
+<a name="l00060"></a>00060 <span class="comment">/// FdoOdbcOvPropertiesP is a FdoPtr on FdoOdbcOvPropertyDefinitionCollection, provided for convenience.</span>
+<a name="l00061"></a><a class="code" href="_odbc_ov_property_definition_collection_8h_da3ba8c7ff9ce10201957d8e68f55300.html#da3ba8c7ff9ce10201957d8e68f55300">00061</a> <span class="comment"></span><span class="keyword">typedef</span> FdoPtr<FdoOdbcOvPropertyDefinitionCollection> <a class="code" href="_odbc_ov_property_definition_collection_8h_da3ba8c7ff9ce10201957d8e68f55300.html#da3ba8c7ff9ce10201957d8e68f55300">FdoOdbcOvPropertiesP</a>;
+<a name="l00062"></a>00062
+<a name="l00066"></a>00066
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/ODBC/_odbc_ov_property_definition_collection_8h.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_odbc_ov_property_definition_collection_8h.html?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_odbc_ov_property_definition_collection_8h.html 2006-12-01 20:39:06+0000
@@ -0,0 +1,74 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<h1>OdbcOvPropertyDefinitionCollection.h File Reference</h1>
+<p>
+<code>#include <<a class="el" href="_rdbms_ov_property_definition_collection_8h-source.html">Rdbms/Override/RdbmsOvPropertyDefinitionCollection.h</a>></code><br>
+<code>#include <Fdo/Commands/Schema/PhysicalElementMappingCollection.h></code><br>
+<p>
+Include dependency graph for OdbcOvPropertyDefinitionCollection.h:<p><center><img src="_odbc_ov_property_definition_collection_8h__incl.png" border="0" usemap="#OdbcOvPropertyDefinitionCollection.h_map" alt=""></center>
+<map name="OdbcOvPropertyDefinitionCollection.h_map">
+<area href="_odbc_ov_8h.html" shape="rect" coords="801,45,1028,72" alt="">
+<area href="_odbc_ov_property_definition_8h.html" shape="rect" coords="320,57,653,84" alt="">
+<area href="_rdbms_ov_property_definition_collection_8h.html" shape="rect" coords="305,108,668,135" alt="">
+</map>
+<p>
+This graph shows which files directly or indirectly include this file:<p><center><img src="_odbc_ov_property_definition_collection_8h__dep__incl.png" border="0" usemap="#OdbcOvPropertyDefinitionCollection.hdep_map" alt=""></center>
+<map name="OdbcOvPropertyDefinitionCollection.hdep_map">
+<area href="_odbc_ov_class_definition_8h.html" shape="rect" coords="305,7,479,33" alt="">
+<area href="_odbc_ov_class_collection_8h.html" shape="rect" coords="527,7,703,33" alt="">
+<area href="_odbc_ov_physical_schema_mapping_8h.html" shape="rect" coords="752,7,984,33" alt="">
+</map>
+<p>
+<a href="_odbc_ov_property_definition_collection_8h-source.html">Go to the source code of this file.</a><table border="0" cellpadding="0" cellspacing="0">
+<tr><td></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">class </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_odbc_ov_property_definition_collection.html">FdoOdbcOvPropertyDefinitionCollection</a></td></tr>
+<tr><td class="mdescLeft"> </td><td class="mdescRight">Concrete class defining physical schema overrides for a collection of property definitions. <a href="class_fdo_odbc_ov_property_definition_collection.html#_details">More...</a><br></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">typedef FdoPtr< <a class="el" href="class_fdo_odbc_ov_property_definition_collection.html">FdoOdbcOvPropertyDefinitionCollection</a> > </td><td class="memItemRight" valign="bottom"><a class="el" href="_odbc_ov_property_definition_collection_8h_da3ba8c7ff9ce10201957d8e68f55300.html#da3ba8c7ff9ce10201957d8e68f55300">FdoOdbcOvPropertiesP</a></td></tr>
+<tr><td class="mdescLeft"> </td><td class="mdescRight">FdoOdbcOvPropertiesP is a FdoPtr on <a class="el" href="class_fdo_odbc_ov_property_definition_collection.html">FdoOdbcOvPropertyDefinitionCollection</a>, provided for convenience. <a href="#da3ba8c7ff9ce10201957d8e68f55300"></a><br></td></tr>
+</table>
+ <hr>
+ <tr>
+ <td align="right"><font size="-2"><a href="mailto:isd.docs at autodesk.com&subject=FDO%20Provider%20for%20ODBC%20API%20documentation">Comments?</a></font></td>
+ <!-- The logo can go in another cell, when we get one -->
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/ODBC/_odbc_ov_property_definition_collection_8h__dep__incl.map
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_odbc_ov_property_definition_collection_8h__dep__incl.map?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_odbc_ov_property_definition_collection_8h__dep__incl.map 2006-12-01 20:39:06+0000
@@ -0,0 +1,4 @@
+base referer
+rect $_odbc_ov_class_definition_8h.html 305,7 479,33
+rect $_odbc_ov_class_collection_8h.html 527,7 703,33
+rect $_odbc_ov_physical_schema_mapping_8h.html 752,7 984,33
Added: trunk/www/docs/ODBC/_odbc_ov_property_definition_collection_8h__dep__incl.md5
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_odbc_ov_property_definition_collection_8h__dep__incl.md5?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_odbc_ov_property_definition_collection_8h__dep__incl.md5 2006-12-01 20:39:06+0000
@@ -0,0 +1 @@
+c464a5fc3080a70fe28f082ddb9eda5d
Added: trunk/www/docs/ODBC/_odbc_ov_property_definition_collection_8h__dep__incl.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_odbc_ov_property_definition_collection_8h__dep__incl.png?view=auto&rev=94
Added: trunk/www/docs/ODBC/_odbc_ov_property_definition_collection_8h__incl.map
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_odbc_ov_property_definition_collection_8h__incl.map?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_odbc_ov_property_definition_collection_8h__incl.map 2006-12-01 20:39:06+0000
@@ -0,0 +1,4 @@
+base referer
+rect $_odbc_ov_8h.html 801,45 1028,72
+rect $_odbc_ov_property_definition_8h.html 320,57 653,84
+rect $_rdbms_ov_property_definition_collection_8h.html 305,108 668,135
Added: trunk/www/docs/ODBC/_odbc_ov_property_definition_collection_8h__incl.md5
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_odbc_ov_property_definition_collection_8h__incl.md5?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_odbc_ov_property_definition_collection_8h__incl.md5 2006-12-01 20:39:06+0000
@@ -0,0 +1 @@
+31f6444c1d2637bce3c06d89d8489ab7
Added: trunk/www/docs/ODBC/_odbc_ov_property_definition_collection_8h__incl.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_odbc_ov_property_definition_collection_8h__incl.png?view=auto&rev=94
Added: trunk/www/docs/ODBC/_odbc_ov_property_definition_collection_8h_da3ba8c7ff9ce10201957d8e68f55300.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_odbc_ov_property_definition_collection_8h_da3ba8c7ff9ce10201957d8e68f55300.html?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_odbc_ov_property_definition_collection_8h_da3ba8c7ff9ce10201957d8e68f55300.html 2006-12-01 20:39:06+0000
@@ -0,0 +1,76 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ <li><a href="files.html"><span>Files</span></a></li>
+ </ul></div>
+<div class="nav">
+<a class="el" href="_odbc_ov_property_definition_collection_8h.html">OdbcOvPropertyDefinitionCollection.h</a></div>
+<table cellspacing="0" cellpadding="0" border="0">
+ <tr>
+ <td valign="top">
+ <div class="navtab">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="_odbc_ov_property_definition_collection_8h_da3ba8c7ff9ce10201957d8e68f55300.html#da3ba8c7ff9ce10201957d8e68f55300">FdoOdbcOvPropertiesP</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="da3ba8c7ff9ce10201957d8e68f55300"></a><!-- doxytag: member="OdbcOvPropertyDefinitionCollection.h::FdoOdbcOvPropertiesP" ref="da3ba8c7ff9ce10201957d8e68f55300" args="" --><p>
+<table class="mdTable" cellpadding="2" cellspacing="0">
+ <tr>
+ <td class="mdRow">
+ <table cellpadding="0" cellspacing="0" border="0">
+ <tr>
+ <td class="md" nowrap valign="top">typedef FdoPtr<<a class="el" href="class_fdo_odbc_ov_property_definition_collection.html">FdoOdbcOvPropertyDefinitionCollection</a>> <a class="el" href="_odbc_ov_property_definition_collection_8h_da3ba8c7ff9ce10201957d8e68f55300.html#da3ba8c7ff9ce10201957d8e68f55300">FdoOdbcOvPropertiesP</a> </td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+<table cellspacing="5" cellpadding="0" border="0">
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+FdoOdbcOvPropertiesP is a FdoPtr on <a class="el" href="class_fdo_odbc_ov_property_definition_collection.html">FdoOdbcOvPropertyDefinitionCollection</a>, provided for convenience.
+<p>
+<p>
+Definition at line <a class="el" href="_odbc_ov_property_definition_collection_8h-source.html#l00061">61</a> of file <a class="el" href="_odbc_ov_property_definition_collection_8h-source.html">OdbcOvPropertyDefinitionCollection.h</a>. </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+<!-- footer.html -->
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/ODBC/_odbc_ov_table_8h-source.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_odbc_ov_table_8h-source.html?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_odbc_ov_table_8h-source.html 2006-12-01 20:39:06+0000
@@ -0,0 +1,122 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<h1>OdbcOvTable.h</h1><a href="_odbc_ov_table_8h.html">Go to the documentation of this file.</a><div class="fragment"><pre class="fragment"><a name="l00001"></a>00001 <span class="preprocessor">#ifndef FDO_OdbcOVTABLE_H</span>
+<a name="l00002"></a>00002 <span class="preprocessor"></span><span class="preprocessor">#define FDO_OdbcOVTABLE_H</span>
+<a name="l00020"></a>00020 <span class="preprocessor">#include <<a class="code" href="_rdbms_ov_table_8h.html">Rdbms/Override/RdbmsOvTable.h</a>></span>
+<a name="l00023"></a>00023 <span class="comment"></span>
+<a name="l00024"></a>00024 <span class="comment">/// \brief</span>
+<a name="l00025"></a>00025 <span class="comment">/// Concrete class defining physical schema overrides for a table.</span>
+<a name="l00026"></a><a class="code" href="class_fdo_odbc_ov_table.html">00026</a> <span class="comment"></span><span class="keyword">class </span><a class="code" href="class_fdo_odbc_ov_table.html">FdoOdbcOvTable</a> : <span class="keyword">public</span> <a class="code" href="class_fdo_rdbms_ov_table.html">FdoRdbmsOvTable</a>
+<a name="l00027"></a>00027 {
+<a name="l00029"></a>00029 <span class="keyword">public</span>:<span class="comment"></span>
+<a name="l00030"></a>00030 <span class="comment"> /// \brief</span>
+<a name="l00031"></a>00031 <span class="comment"> /// Constructs a default of an FdoOdbcOvTable</span>
+<a name="l00032"></a>00032 <span class="comment"> /// </span>
+<a name="l00033"></a>00033 <span class="comment"> /// \return</span>
+<a name="l00034"></a>00034 <span class="comment"> /// Returns FdoOdbcOvTable</span>
+<a name="l00035"></a>00035 <span class="comment"> /// </span>
+<a name="l00036"></a>00036 <span class="comment"></span> <a class="code" href="_odbc_ov_8h_91b15f0fd565be7c245bbe8e5247fbdc.html#91b15f0fd565be7c245bbe8e5247fbdc">FDOODBC_OV_API</a> <span class="keyword">static</span> <a class="code" href="class_fdo_odbc_ov_table.html">FdoOdbcOvTable</a>* <a class="code" href="class_fdo_odbc_ov_table_2009c866e6875cd10648a1778d310850.html#2009c866e6875cd10648a1778d310850">Create</a>();
+<a name="l00038"></a>00038 <span class="comment"> /// \brief</span>
+<a name="l00039"></a>00039 <span class="comment"> /// Constructs an instance of an FdoOdbcOvTable using the specified arguments</span>
+<a name="l00040"></a>00040 <span class="comment"> /// </span>
+<a name="l00041"></a>00041 <span class="comment"> /// \param name </span>
+<a name="l00042"></a>00042 <span class="comment"> /// Input name</span>
+<a name="l00043"></a>00043 <span class="comment"> /// </span>
+<a name="l00044"></a>00044 <span class="comment"> /// \return</span>
+<a name="l00045"></a>00045 <span class="comment"> /// Returns FdoOdbcOvTable</span>
+<a name="l00046"></a>00046 <span class="comment"> /// </span>
+<a name="l00047"></a>00047 <span class="comment"></span> <a class="code" href="_odbc_ov_8h_91b15f0fd565be7c245bbe8e5247fbdc.html#91b15f0fd565be7c245bbe8e5247fbdc">FDOODBC_OV_API</a> <span class="keyword">static</span> <a class="code" href="class_fdo_odbc_ov_table.html">FdoOdbcOvTable</a>* <a class="code" href="class_fdo_odbc_ov_table_2009c866e6875cd10648a1778d310850.html#2009c866e6875cd10648a1778d310850">Create</a>(FdoString *name);
+<a name="l00050"></a>00050 <span class="comment">/// \cond DOXYGEN-IGNORE</span>
+<a name="l00051"></a>00051 <span class="comment"></span><span class="comment"></span>
+<a name="l00052"></a>00052 <span class="comment"> /// XML Serialization functions, not part of the API.</span>
+<a name="l00053"></a>00053 <span class="comment"></span><span class="comment"></span>
+<a name="l00054"></a>00054 <span class="comment"> /// Serialize this property to XML.</span>
+<a name="l00055"></a>00055 <span class="comment"></span> <span class="keyword">virtual</span> <span class="keywordtype">void</span> <a class="code" href="class_fdo_rdbms_ov_table_209299ef102d4b5ee2b92763be873289.html#209299ef102d4b5ee2b92763be873289">_writeXmlContents</a>(FdoXmlWriter* xmlWriter, <span class="keyword">const</span> FdoXmlFlags* flags);
+<a name="l00056"></a>00056 <span class="comment"></span>
+<a name="l00057"></a>00057 <span class="comment"> /// Initialize this element from its XML attributes</span>
+<a name="l00058"></a>00058 <span class="comment"></span> <span class="keyword">virtual</span> <span class="keywordtype">void</span> <a class="code" href="class_fdo_rdbms_ov_table_0e03dc3742dacf897c7f00dd19064882.html#0e03dc3742dacf897c7f00dd19064882">InitFromXml</a>(FdoXmlSaxContext* pContext, FdoXmlAttributeCollection* attrs);
+<a name="l00059"></a>00059 <span class="comment"></span>
+<a name="l00060"></a>00060 <span class="comment"> /// Sets the parent of this object. Not part of the API.</span>
+<a name="l00061"></a>00061 <span class="comment"></span> <span class="keywordtype">void</span> <a class="code" href="class_fdo_rdbms_ov_table_36b365e957e8aaadce79998310a89597.html#36b365e957e8aaadce79998310a89597">SetParent</a>(FdoPhysicalElementMapping* value);
+<a name="l00062"></a>00062 <span class="comment"></span>
+<a name="l00063"></a>00063 <span class="comment"> /// Common initializer for all constructors:</span>
+<a name="l00064"></a>00064 <span class="comment"></span> <span class="keywordtype">void</span> Init();
+<a name="l00066"></a>00066 <span class="comment">/// \endcond</span>
+<a name="l00067"></a>00067 <span class="comment"></span>
+<a name="l00068"></a>00068 <span class="keyword">protected</span>:
+<a name="l00069"></a>00069 <a class="code" href="class_fdo_odbc_ov_table_f59cdd955a259cd5b05f4acdc03b232c.html#f59cdd955a259cd5b05f4acdc03b232c">FdoOdbcOvTable</a>();
+<a name="l00070"></a>00070 <a class="code" href="class_fdo_odbc_ov_table_f59cdd955a259cd5b05f4acdc03b232c.html#f59cdd955a259cd5b05f4acdc03b232c">FdoOdbcOvTable</a>(FdoString *name);
+<a name="l00071"></a>00071 <span class="keyword">virtual</span> <a class="code" href="class_fdo_odbc_ov_table_faead8b2ea534e1e12ac8dda2efd087b.html#faead8b2ea534e1e12ac8dda2efd087b">~FdoOdbcOvTable</a>();
+<a name="l00072"></a>00072 <span class="keyword">virtual</span> <span class="keywordtype">void</span> <a class="code" href="class_fdo_odbc_ov_table_5f8ebb1fc58222ab31eea159fe718d96.html#5f8ebb1fc58222ab31eea159fe718d96">Dispose</a>();
+<a name="l00074"></a>00074 <span class="keyword">private</span>:
+<a name="l00075"></a>00075 };
+<a name="l00077"></a>00077 <span class="comment">/// \brief</span>
+<a name="l00078"></a>00078 <span class="comment">/// FdoOdbcOvTableP is a FdoPtr on FdoOdbcOvTable, provided for convenience.</span>
+<a name="l00079"></a><a class="code" href="_odbc_ov_table_8h_073b61edcaf447b7d0a9b9b17cea198b.html#073b61edcaf447b7d0a9b9b17cea198b">00079</a> <span class="comment"></span><span class="keyword">typedef</span> FdoPtr<FdoOdbcOvTable> <a class="code" href="_odbc_ov_table_8h_073b61edcaf447b7d0a9b9b17cea198b.html#073b61edcaf447b7d0a9b9b17cea198b">FdoOdbcOvTableP</a>;
+<a name="l00081"></a>00081 <span class="preprocessor">#endif</span>
+<a name="l00082"></a>00082 <span class="preprocessor"></span>
+</pre></div><!-- footer.html -->
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/ODBC/_odbc_ov_table_8h.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_odbc_ov_table_8h.html?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_odbc_ov_table_8h.html 2006-12-01 20:39:06+0000
@@ -0,0 +1,72 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<h1>OdbcOvTable.h File Reference</h1>
+<p>
+<code>#include <<a class="el" href="_rdbms_ov_table_8h-source.html">Rdbms/Override/RdbmsOvTable.h</a>></code><br>
+<p>
+Include dependency graph for OdbcOvTable.h:<p><center><img src="_odbc_ov_table_8h__incl.png" border="0" usemap="#OdbcOvTable.h_map" alt=""></center>
+<map name="OdbcOvTable.h_map">
+<area href="_rdbms_ov_table_8h.html" shape="rect" coords="171,57,397,84" alt="">
+<area href="_odbc_ov_8h.html" shape="rect" coords="171,108,397,135" alt="">
+<area href="_rdbms_ov_8h.html" shape="rect" coords="517,108,712,135" alt="">
+</map>
+<p>
+This graph shows which files directly or indirectly include this file:<p><center><img src="_odbc_ov_table_8h__dep__incl.png" border="0" usemap="#OdbcOvTable.hdep_map" alt=""></center>
+<map name="OdbcOvTable.hdep_map">
+<area href="_odbc_ov_class_definition_8h.html" shape="rect" coords="169,7,343,33" alt="">
+<area href="_odbc_ov_class_collection_8h.html" shape="rect" coords="391,7,567,33" alt="">
+<area href="_odbc_ov_physical_schema_mapping_8h.html" shape="rect" coords="616,7,848,33" alt="">
+</map>
+<p>
+<a href="_odbc_ov_table_8h-source.html">Go to the source code of this file.</a><table border="0" cellpadding="0" cellspacing="0">
+<tr><td></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">class </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_odbc_ov_table.html">FdoOdbcOvTable</a></td></tr>
+<tr><td class="mdescLeft"> </td><td class="mdescRight">Concrete class defining physical schema overrides for a table. <a href="class_fdo_odbc_ov_table.html#_details">More...</a><br></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">typedef FdoPtr< <a class="el" href="class_fdo_odbc_ov_table.html">FdoOdbcOvTable</a> > </td><td class="memItemRight" valign="bottom"><a class="el" href="_odbc_ov_table_8h_073b61edcaf447b7d0a9b9b17cea198b.html#073b61edcaf447b7d0a9b9b17cea198b">FdoOdbcOvTableP</a></td></tr>
+<tr><td class="mdescLeft"> </td><td class="mdescRight">FdoOdbcOvTableP is a FdoPtr on <a class="el" href="class_fdo_odbc_ov_table.html">FdoOdbcOvTable</a>, provided for convenience. <a href="#073b61edcaf447b7d0a9b9b17cea198b"></a><br></td></tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/ODBC/_odbc_ov_table_8h_073b61edcaf447b7d0a9b9b17cea198b.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_odbc_ov_table_8h_073b61edcaf447b7d0a9b9b17cea198b.html?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_odbc_ov_table_8h_073b61edcaf447b7d0a9b9b17cea198b.html 2006-12-01 20:39:06+0000
@@ -0,0 +1,76 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="nav">
+<a class="el" href="_odbc_ov_table_8h.html">OdbcOvTable.h</a></div>
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="_odbc_ov_table_8h_073b61edcaf447b7d0a9b9b17cea198b.html#073b61edcaf447b7d0a9b9b17cea198b">FdoOdbcOvTableP</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="073b61edcaf447b7d0a9b9b17cea198b"></a><!-- doxytag: member="OdbcOvTable.h::FdoOdbcOvTableP" ref="073b61edcaf447b7d0a9b9b17cea198b" args="" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">typedef FdoPtr<<a class="el" href="class_fdo_odbc_ov_table.html">FdoOdbcOvTable</a>> <a class="el" href="_odbc_ov_table_8h_073b61edcaf447b7d0a9b9b17cea198b.html#073b61edcaf447b7d0a9b9b17cea198b">FdoOdbcOvTableP</a> </td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+FdoOdbcOvTableP is a FdoPtr on <a class="el" href="class_fdo_odbc_ov_table.html">FdoOdbcOvTable</a>, provided for convenience.
+<p>
+<p>
+Definition at line <a class="el" href="_odbc_ov_table_8h-source.html#l00079">79</a> of file <a class="el" href="_odbc_ov_table_8h-source.html">OdbcOvTable.h</a>. </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/ODBC/_odbc_ov_table_8h__dep__incl.map
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_odbc_ov_table_8h__dep__incl.map?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_odbc_ov_table_8h__dep__incl.map 2006-12-01 20:39:06+0000
@@ -0,0 +1,4 @@
+base referer
+rect $_odbc_ov_class_definition_8h.html 169,7 343,33
+rect $_odbc_ov_class_collection_8h.html 391,7 567,33
+rect $_odbc_ov_physical_schema_mapping_8h.html 616,7 848,33
Added: trunk/www/docs/ODBC/_odbc_ov_table_8h__dep__incl.md5
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_odbc_ov_table_8h__dep__incl.md5?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_odbc_ov_table_8h__dep__incl.md5 2006-12-01 20:39:06+0000
@@ -0,0 +1 @@
+69616aea11854cfaebd28aa24a886961
\ No newline at end of file
Added: trunk/www/docs/ODBC/_odbc_ov_table_8h__dep__incl.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_odbc_ov_table_8h__dep__incl.png?view=auto&rev=94
Binary file. No diff available.
Added: trunk/www/docs/ODBC/_odbc_ov_table_8h__incl.map
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_odbc_ov_table_8h__incl.map?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_odbc_ov_table_8h__incl.map 2006-12-01 20:39:06+0000
@@ -0,0 +1,4 @@
+base referer
+rect $_rdbms_ov_table_8h.html 171,57 397,84
+rect $_odbc_ov_8h.html 171,108 397,135
+rect $_rdbms_ov_8h.html 517,108 712,135
Added: trunk/www/docs/ODBC/_odbc_ov_table_8h__incl.md5
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_odbc_ov_table_8h__incl.md5?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_odbc_ov_table_8h__incl.md5 2006-12-01 20:39:06+0000
@@ -0,0 +1 @@
+995a26c35ff474679f24dc5118e0a2ad
Added: trunk/www/docs/ODBC/_odbc_ov_table_8h__incl.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_odbc_ov_table_8h__incl.png?view=auto&rev=94
Added: trunk/www/docs/ODBC/_rdbms_ov_8h-source.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_8h-source.html?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_rdbms_ov_8h-source.html 2006-12-01 20:39:06+0000
@@ -0,0 +1,84 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<h1>RdbmsOv.h</h1><a href="_rdbms_ov_8h.html">Go to the documentation of this file.</a><div class="fragment"><pre class="fragment"><a name="l00001"></a>00001 <span class="comment">/*</span>
+<a name="l00002"></a>00002 <span class="comment"> //</span>
+<a name="l00003"></a>00003 <span class="comment">// Copyright (C) 2004-2006 Autodesk, Inc.</span>
+<a name="l00004"></a>00004 <span class="comment">// </span>
+<a name="l00005"></a>00005 <span class="comment">// This library is free software; you can redistribute it and/or</span>
+<a name="l00006"></a>00006 <span class="comment">// modify it under the terms of version 2.1 of the GNU Lesser</span>
+<a name="l00007"></a>00007 <span class="comment">// General Public License as published by the Free Software Foundation.</span>
+<a name="l00008"></a>00008 <span class="comment">// </span>
+<a name="l00009"></a>00009 <span class="comment">// This library is distributed in the hope that it will be useful,</span>
+<a name="l00010"></a>00010 <span class="comment">// but WITHOUT ANY WARRANTY; without even the implied warranty of</span>
+<a name="l00011"></a>00011 <span class="comment">// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU</span>
+<a name="l00012"></a>00012 <span class="comment">// Lesser General Public License for more details.</span>
+<a name="l00013"></a>00013 <span class="comment">// </span>
+<a name="l00014"></a>00014 <span class="comment">// You should have received a copy of the GNU Lesser General Public</span>
+<a name="l00015"></a>00015 <span class="comment">// License along with this library; if not, write to the Free Software</span>
+<a name="l00016"></a>00016 <span class="comment">// Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA</span>
+<a name="l00017"></a>00017 <span class="comment">//</span>
+<a name="l00018"></a>00018 <span class="comment"></span>
+<a name="l00019"></a>00019 <span class="comment"> *</span>
+<a name="l00020"></a>00020 <span class="comment"> */</span>
+<a name="l00022"></a>00022 <span class="preprocessor">#ifndef FDORDBMS_OV_H</span>
+<a name="l00023"></a>00023 <span class="preprocessor"></span><span class="preprocessor">#define FDORDBMS_OV_H</span>
+<a name="l00024"></a>00024 <span class="preprocessor"></span><span class="preprocessor">#ifdef _WIN32</span>
+<a name="l00025"></a>00025 <span class="preprocessor"></span><span class="preprocessor">#pragma once</span>
+<a name="l00026"></a>00026 <span class="preprocessor"></span><span class="preprocessor">#endif</span>
+<a name="l00027"></a>00027 <span class="preprocessor"></span>
+<a name="l00028"></a>00028 <span class="comment">// The following ifdef block is the standard way of creating macros which make exporting</span>
+<a name="l00029"></a>00029 <span class="comment">// from a DLL simpler. All files within this DLL are compiled with the FDORDBMS_OV_EXPORTS</span>
+<a name="l00030"></a>00030 <span class="comment">// symbol defined. The FDOORDBMS_OV_EXPORTS symbol should not be defined on any project</span>
+<a name="l00031"></a>00031 <span class="comment">// that uses this DLL. This way any other project whose source files include this file see</span>
+<a name="l00032"></a>00032 <span class="comment">// FDORDBMS_OV_API functions as being imported from a DLL, whereas this DLL sees symbols</span>
+<a name="l00033"></a>00033 <span class="comment">// defined with this macro as being exported.</span>
+<a name="l00034"></a>00034 <span class="preprocessor">#ifdef _WIN32</span>
+<a name="l00035"></a>00035 <span class="preprocessor"></span><span class="preprocessor">#ifdef FDORDBMS_OV_EXPORTS</span>
+<a name="l00036"></a>00036 <span class="preprocessor"></span><span class="preprocessor">#define FDORDBMS_OV_API __declspec(dllexport)</span>
+<a name="l00037"></a>00037 <span class="preprocessor"></span><span class="preprocessor">#else</span>
+<a name="l00038"></a>00038 <span class="preprocessor"></span><span class="preprocessor">#define FDORDBMS_OV_API __declspec(dllimport)</span>
+<a name="l00039"></a>00039 <span class="preprocessor"></span><span class="preprocessor">#endif</span>
+<a name="l00040"></a>00040 <span class="preprocessor"></span><span class="preprocessor">#else</span>
+<a name="l00041"></a><a class="code" href="_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html#9b6afd7f3f2f73a361844d7bff18436f">00041</a> <span class="preprocessor"></span><span class="preprocessor">#define FDORDBMS_OV_API</span>
+<a name="l00042"></a>00042 <span class="preprocessor"></span><span class="preprocessor">#endif</span>
+<a name="l00043"></a>00043 <span class="preprocessor"></span>
+<a name="l00044"></a>00044 <span class="preprocessor">#endif // FDORDBMS_OV_H</span>
+<a name="l00045"></a>00045 <span class="preprocessor"></span>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/ODBC/_rdbms_ov_8h.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_8h.html?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_rdbms_ov_8h.html 2006-12-01 20:39:06+0000
@@ -0,0 +1,70 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<h1>RdbmsOv.h File Reference</h1>
+<p>
+<p>
+This graph shows which files directly or indirectly include this file:<p><center><img src="_rdbms_ov_8h__dep__incl.png" border="0" usemap="#RdbmsOv.hdep_map" alt=""></center>
+<map name="RdbmsOv.hdep_map">
+<area href="_rdbms_ov_association_property_definition_8h.html" shape="rect" coords="148,7,418,33" alt="">
+<area href="_rdbms_ov_class_definition_8h.html" shape="rect" coords="1366,209,1547,236" alt="">
+<area href="_rdbms_ov_column_8h.html" shape="rect" coords="214,159,352,185" alt="">
+<area href="_rdbms_ov_data_property_definition_8h.html" shape="rect" coords="483,159,712,185" alt="">
+<area href="_rdbms_ov_geometric_column_8h.html" shape="rect" coords="182,260,384,287" alt="">
+<area href="_rdbms_ov_geometric_property_definition_8h.html" shape="rect" coords="467,311,728,337" alt="">
+<area href="_rdbms_ov_object_property_definition_8h.html" shape="rect" coords="1076,387,1316,413" alt="">
+<area href="_rdbms_ov_physical_schema_mapping_8h.html" shape="rect" coords="476,741,719,768" alt="">
+<area href="_rdbms_ov_property_definition_8h.html" shape="rect" coords="183,209,383,236" alt="">
+<area href="_rdbms_ov_property_mapping_class_8h.html" shape="rect" coords="790,463,1016,489" alt="">
+<area href="_rdbms_ov_property_mapping_concrete_8h.html" shape="rect" coords="779,513,1027,540" alt="">
+<area href="_rdbms_ov_property_mapping_definition_8h.html" shape="rect" coords="158,513,408,540" alt="">
+<area href="_rdbms_ov_property_mapping_relation_8h.html" shape="rect" coords="476,513,719,540" alt="">
+<area href="_rdbms_ov_property_mapping_single_8h.html" shape="rect" coords="482,412,714,439" alt="">
+<area href="_rdbms_ov_schema_auto_generation_8h.html" shape="rect" coords="166,767,400,793" alt="">
+<area href="_rdbms_ov_table_8h.html" shape="rect" coords="1134,564,1259,591" alt="">
+</map>
+<p>
+<a href="_rdbms_ov_8h-source.html">Go to the source code of this file.</a><table border="0" cellpadding="0" cellspacing="0">
+<tr><td></td></tr>
+<tr><td colspan="2"><br><h2>Defines</h2></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">#define </td><td class="memItemRight" valign="bottom"><a class="el" href="_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html#9b6afd7f3f2f73a361844d7bff18436f">FDORDBMS_OV_API</a></td></tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/ODBC/_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html 2006-12-01 20:39:06+0000
@@ -0,0 +1,74 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="nav">
+<a class="el" href="_rdbms_ov_8h.html">RdbmsOv.h</a></div>
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html#9b6afd7f3f2f73a361844d7bff18436f">FDORDBMS_OV_API</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="9b6afd7f3f2f73a361844d7bff18436f"></a><!-- doxytag: member="RdbmsOv.h::FDORDBMS_OV_API" ref="9b6afd7f3f2f73a361844d7bff18436f" args="" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">#define FDORDBMS_OV_API </td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+<p>
+Definition at line <a class="el" href="_rdbms_ov_8h-source.html#l00041">41</a> of file <a class="el" href="_rdbms_ov_8h-source.html">RdbmsOv.h</a>. </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/ODBC/_rdbms_ov_8h__dep__incl.map
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_8h__dep__incl.map?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_rdbms_ov_8h__dep__incl.map 2006-12-01 20:39:06+0000
@@ -0,0 +1,17 @@
+base referer
+rect $_rdbms_ov_association_property_definition_8h.html 148,7 418,33
+rect $_rdbms_ov_class_definition_8h.html 1366,209 1547,236
+rect $_rdbms_ov_column_8h.html 214,159 352,185
+rect $_rdbms_ov_data_property_definition_8h.html 483,159 712,185
+rect $_rdbms_ov_geometric_column_8h.html 182,260 384,287
+rect $_rdbms_ov_geometric_property_definition_8h.html 467,311 728,337
+rect $_rdbms_ov_object_property_definition_8h.html 1076,387 1316,413
+rect $_rdbms_ov_physical_schema_mapping_8h.html 476,741 719,768
+rect $_rdbms_ov_property_definition_8h.html 183,209 383,236
+rect $_rdbms_ov_property_mapping_class_8h.html 790,463 1016,489
+rect $_rdbms_ov_property_mapping_concrete_8h.html 779,513 1027,540
+rect $_rdbms_ov_property_mapping_definition_8h.html 158,513 408,540
+rect $_rdbms_ov_property_mapping_relation_8h.html 476,513 719,540
+rect $_rdbms_ov_property_mapping_single_8h.html 482,412 714,439
+rect $_rdbms_ov_schema_auto_generation_8h.html 166,767 400,793
+rect $_rdbms_ov_table_8h.html 1134,564 1259,591
Added: trunk/www/docs/ODBC/_rdbms_ov_8h__dep__incl.md5
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_8h__dep__incl.md5?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_rdbms_ov_8h__dep__incl.md5 2006-12-01 20:39:06+0000
@@ -0,0 +1 @@
+070c8a13d1b6819e48d5869dec072be4
Added: trunk/www/docs/ODBC/_rdbms_ov_8h__dep__incl.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_8h__dep__incl.png?view=auto&rev=94
Added: trunk/www/docs/ODBC/_rdbms_ov_association_property_definition_8h-source.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_association_property_definition_8h-source.html?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_rdbms_ov_association_property_definition_8h-source.html 2006-12-01 20:39:06+0000
@@ -0,0 +1,88 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<h1>RdbmsOvAssociationPropertyDefinition.h</h1><a href="_rdbms_ov_association_property_definition_8h.html">Go to the documentation of this file.</a><div class="fragment"><pre class="fragment"><a name="l00001"></a>00001 <span class="preprocessor">#ifndef FDO_RDBMSOVASSOCIATIONPROPERTYDEFINITION_H</span>
+<a name="l00002"></a>00002 <span class="preprocessor"></span><span class="preprocessor">#define FDO_RDBMSOVASSOCIATIONPROPERTYDEFINITION_H</span>
+<a name="l00003"></a>00003 <span class="preprocessor"></span><span class="comment">//</span>
+<a name="l00004"></a>00004 <span class="comment">//</span>
+<a name="l00005"></a>00005 <span class="comment">// Copyright (C) 2004-2006 Autodesk, Inc.</span>
+<a name="l00006"></a>00006 <span class="comment">// </span>
+<a name="l00007"></a>00007 <span class="comment">// This library is free software; you can redistribute it and/or</span>
+<a name="l00008"></a>00008 <span class="comment">// modify it under the terms of version 2.1 of the GNU Lesser</span>
+<a name="l00009"></a>00009 <span class="comment">// General Public License as published by the Free Software Foundation.</span>
+<a name="l00010"></a>00010 <span class="comment">// </span>
+<a name="l00011"></a>00011 <span class="comment">// This library is distributed in the hope that it will be useful,</span>
+<a name="l00012"></a>00012 <span class="comment">// but WITHOUT ANY WARRANTY; without even the implied warranty of</span>
+<a name="l00013"></a>00013 <span class="comment">// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU</span>
+<a name="l00014"></a>00014 <span class="comment">// Lesser General Public License for more details.</span>
+<a name="l00015"></a>00015 <span class="comment">// </span>
+<a name="l00016"></a>00016 <span class="comment">// You should have received a copy of the GNU Lesser General Public</span>
+<a name="l00017"></a>00017 <span class="comment">// License along with this library; if not, write to the Free Software</span>
+<a name="l00018"></a>00018 <span class="comment">// Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA</span>
+<a name="l00019"></a>00019 <span class="comment">//</span>
+<a name="l00020"></a>00020 <span class="comment"></span>
+<a name="l00021"></a>00021 <span class="comment">/// <library></span>
+<a name="l00022"></a>00022 <span class="comment">/// FdoRdbms.lib</span>
+<a name="l00023"></a>00023 <span class="comment">/// </library></span>
+<a name="l00025"></a>00025 <span class="preprocessor">#include <<a class="code" href="_rdbms_ov_8h.html">Rdbms/Override/RdbmsOv.h</a>></span>
+<a name="l00026"></a>00026 <span class="preprocessor">#include <<a class="code" href="_rdbms_ov_property_definition_collection_8h.html">Rdbms/Override/RdbmsOvPropertyDefinitionCollection.h</a>></span>
+<a name="l00027"></a>00027 <span class="comment"></span>
+<a name="l00028"></a>00028 <span class="comment">///<summary>Abstract class defining physical schema overrides for an association property</span>
+<a name="l00029"></a>00029 <span class="comment">///definition.</summary></span>
+<a name="l00030"></a><a class="code" href="class_fdo_rdbms_ov_association_property_definition.html">00030</a> <span class="comment"></span><span class="keyword">class </span><a class="code" href="class_fdo_rdbms_ov_association_property_definition.html">FdoRdbmsOvAssociationPropertyDefinition</a> : <span class="keyword">public</span> <span class="keyword">virtual</span> <a class="code" href="class_fdo_rdbms_ov_property_definition.html">FdoRdbmsOvPropertyDefinition</a>
+<a name="l00031"></a>00031 {
+<a name="l00032"></a>00032 <span class="keyword">public</span>:<span class="comment"></span>
+<a name="l00033"></a>00033 <span class="comment"> ///<summary>Gets a collection of Oracle property definitions</summary></span>
+<a name="l00034"></a>00034 <span class="comment"> /// <returns>Returns the collection of Oracle property definitions</returns></span>
+<a name="l00035"></a>00035 <span class="comment"></span> <a class="code" href="_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html#9b6afd7f3f2f73a361844d7bff18436f">FDORDBMS_OV_API</a> <a class="code" href="class_fdo_rdbms_ov_read_only_property_definition_collection.html">FdoRdbmsOvReadOnlyPropertyDefinitionCollection</a>* <a class="code" href="class_fdo_rdbms_ov_association_property_definition_387c25774cbaeae9a745a888e0c20e62.html#387c25774cbaeae9a745a888e0c20e62">GetProperties</a>();
+<a name="l00037"></a>00037 <span class="keyword">protected</span>:
+<a name="l00038"></a>00038 <a class="code" href="_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html#9b6afd7f3f2f73a361844d7bff18436f">FDORDBMS_OV_API</a> <a class="code" href="class_fdo_rdbms_ov_association_property_definition_f02db222ef7cf482901f3828f99d5d9d.html#f02db222ef7cf482901f3828f99d5d9d">FdoRdbmsOvAssociationPropertyDefinition</a>();
+<a name="l00039"></a>00039 <a class="code" href="_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html#9b6afd7f3f2f73a361844d7bff18436f">FDORDBMS_OV_API</a> <a class="code" href="class_fdo_rdbms_ov_association_property_definition_f02db222ef7cf482901f3828f99d5d9d.html#f02db222ef7cf482901f3828f99d5d9d">FdoRdbmsOvAssociationPropertyDefinition</a>(FdoString* name);
+<a name="l00040"></a>00040 <a class="code" href="_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html#9b6afd7f3f2f73a361844d7bff18436f">FDORDBMS_OV_API</a> <span class="keyword">virtual</span> <a class="code" href="class_fdo_rdbms_ov_association_property_definition_2825a113f289eceadbb57f51c963c6a7.html#2825a113f289eceadbb57f51c963c6a7">~FdoRdbmsOvAssociationPropertyDefinition</a>();
+<a name="l00042"></a>00042 <a class="code" href="_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html#9b6afd7f3f2f73a361844d7bff18436f">FDORDBMS_OV_API</a> <a class="code" href="class_fdo_rdbms_ov_property_definition_collection.html">FdoRdbmsOvPropertyDefinitionCollection</a>* <a class="code" href="class_fdo_rdbms_ov_association_property_definition_74dc114c67d46fbe5bccf6215dfc1b0a.html#74dc114c67d46fbe5bccf6215dfc1b0a">GetRdbmsProperties</a>();
+<a name="l00044"></a>00044 <span class="keyword">private</span>:
+<a name="l00045"></a>00045 <a class="code" href="_rdbms_ov_property_definition_collection_8h_8a7a02562b4dcd8bbbf507c92753c27c.html#8a7a02562b4dcd8bbbf507c92753c27c">FdoRdbmsOvPropertiesP</a> mProperties;
+<a name="l00046"></a>00046 };
+<a name="l00048"></a>00048 <span class="preprocessor">#endif</span>
+<a name="l00049"></a>00049 <span class="preprocessor"></span>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/ODBC/_rdbms_ov_association_property_definition_8h.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_association_property_definition_8h.html?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_rdbms_ov_association_property_definition_8h.html 2006-12-01 20:39:06+0000
@@ -0,0 +1,59 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<h1>RdbmsOvAssociationPropertyDefinition.h File Reference</h1>
+<p>
+<code>#include <<a class="el" href="_rdbms_ov_8h-source.html">Rdbms/Override/RdbmsOv.h</a>></code><br>
+<p>
+Include dependency graph for RdbmsOvAssociationPropertyDefinition.h:<p><center><img src="_rdbms_ov_association_property_definition_8h__incl.png" border="0" usemap="#RdbmsOvAssociationPropertyDefinition.h_map" alt=""></center>
+<map name="RdbmsOvAssociationPropertyDefinition.h_map">
+<area href="_rdbms_ov_8h.html" shape="rect" coords="408,7,603,34" alt="">
+<area href="_rdbms_ov_property_definition_collection_8h.html" shape="rect" coords="324,58,687,84" alt="">
+</map>
+<p>
+<a href="_rdbms_ov_association_property_definition_8h-source.html">Go to the source code of this file.</a><table border="0" cellpadding="0" cellspacing="0">
+<tr><td></td></tr>
+<tr><td colspan="2"><br><h2>Classes</h2></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">class </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_rdbms_ov_association_property_definition.html">FdoRdbmsOvAssociationPropertyDefinition</a></td></tr>
+<tr><td class="mdescLeft"> </td><td class="mdescRight">Abstract class defining physical schema overrides for an association property definition. <a href="class_fdo_rdbms_ov_association_property_definition.html#_details">More...</a><br></td></tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/ODBC/_rdbms_ov_association_property_definition_8h__incl.map
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_association_property_definition_8h__incl.map?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_rdbms_ov_association_property_definition_8h__incl.map 2006-12-01 20:39:06+0000
@@ -0,0 +1,3 @@
+base referer
+rect $_rdbms_ov_8h.html 408,7 603,34
+rect $_rdbms_ov_property_definition_collection_8h.html 324,58 687,84
Added: trunk/www/docs/ODBC/_rdbms_ov_association_property_definition_8h__incl.md5
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_association_property_definition_8h__incl.md5?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_rdbms_ov_association_property_definition_8h__incl.md5 2006-12-01 20:39:06+0000
@@ -0,0 +1 @@
+ffce42cb2c10629601e059800320ee6b
Added: trunk/www/docs/ODBC/_rdbms_ov_association_property_definition_8h__incl.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_association_property_definition_8h__incl.png?view=auto&rev=94
Added: trunk/www/docs/ODBC/_rdbms_ov_class_collection_8h-source.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_class_collection_8h-source.html?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_rdbms_ov_class_collection_8h-source.html 2006-12-01 20:39:06+0000
@@ -0,0 +1,122 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<h1>RdbmsOvClassCollection.h</h1><a href="_rdbms_ov_class_collection_8h.html">Go to the documentation of this file.</a><div class="fragment"><pre class="fragment"><a name="l00001"></a>00001 <span class="preprocessor">#ifndef FDO_RDBMSOVCLASSCOLLECTION_H</span>
+<a name="l00002"></a>00002 <span class="preprocessor"></span><span class="preprocessor">#define FDO_RDBMSOVCLASSCOLLECTION_H</span>
+<a name="l00003"></a>00003 <span class="preprocessor"></span><span class="comment">// </span>
+<a name="l00019"></a>00019 <span class="comment">// </span>
+<a name="l00025"></a>00025 <span class="preprocessor">#include <<a class="code" href="_rdbms_ov_class_definition_8h.html">Rdbms/Override/RdbmsOvClassDefinition.h</a>></span>
+<a name="l00026"></a>00026 <span class="preprocessor">#include <Fdo/Commands/Schema/PhysicalElementMappingCollection.h></span>
+<a name="l00028"></a>00028 <span class="comment">//DOM-IGNORE-BEGIN</span><span class="comment"></span>
+<a name="l00029"></a>00029 <span class="comment">///<summary>Concrete class defining physical schema overrides for a collection of class</span>
+<a name="l00030"></a>00030 <span class="comment">///definitions.</summary></span>
+<a name="l00031"></a><a class="code" href="class_fdo_rdbms_ov_class_collection.html">00031</a> <span class="comment"></span><span class="keyword">class </span><a class="code" href="class_fdo_rdbms_ov_class_collection.html">FdoRdbmsOvClassCollection</a> : <span class="keyword">public</span> FdoPhysicalElementMappingCollection<FdoRdbmsOvClassDefinition>
+<a name="l00032"></a>00032 {
+<a name="l00033"></a>00033 <span class="keyword">public</span>:<span class="comment"></span>
+<a name="l00034"></a>00034 <span class="comment"> ///<summary>Constructs a default instance of an FdoRdbmsOvClassCollection</summary></span>
+<a name="l00035"></a>00035 <span class="comment"> /// <returns>Returns FdoRdbmsOvClassCollection</returns> </span>
+<a name="l00036"></a>00036 <span class="comment"></span> <span class="keyword">static</span> <a class="code" href="class_fdo_rdbms_ov_class_collection.html">FdoRdbmsOvClassCollection</a>* <a class="code" href="class_fdo_rdbms_ov_class_collection_cc2c194d085a6b28d2b921746ef2dbd4.html#cc2c194d085a6b28d2b921746ef2dbd4">Create</a>();
+<a name="l00038"></a>00038 <span class="comment"> ///<summary>Constructs an instance of an FdoRdbmsOvClassCollection using the specified arguments</summary></span>
+<a name="l00039"></a>00039 <span class="comment"> /// <param name="parent">Input parent</param> </span>
+<a name="l00040"></a>00040 <span class="comment"> /// <returns>Returns FdoRdbmsOvClassCollection</returns> </span>
+<a name="l00041"></a>00041 <span class="comment"></span> <span class="keyword">static</span> <a class="code" href="class_fdo_rdbms_ov_class_collection.html">FdoRdbmsOvClassCollection</a>* <a class="code" href="class_fdo_rdbms_ov_class_collection_cc2c194d085a6b28d2b921746ef2dbd4.html#cc2c194d085a6b28d2b921746ef2dbd4">Create</a>(FdoPhysicalElementMapping* parent);
+<a name="l00043"></a>00043 <span class="keyword">protected</span>:
+<a name="l00044"></a>00044 <a class="code" href="class_fdo_rdbms_ov_class_collection_425cfaabd885fbcd5118512afee1cc3e.html#425cfaabd885fbcd5118512afee1cc3e">FdoRdbmsOvClassCollection</a>();
+<a name="l00045"></a>00045 <a class="code" href="class_fdo_rdbms_ov_class_collection_425cfaabd885fbcd5118512afee1cc3e.html#425cfaabd885fbcd5118512afee1cc3e">FdoRdbmsOvClassCollection</a>(FdoPhysicalElementMapping* parent);
+<a name="l00046"></a>00046 <span class="keyword">virtual</span> <a class="code" href="class_fdo_rdbms_ov_class_collection_33b7ad497be3d84ea74dafcd3d227cc8.html#33b7ad497be3d84ea74dafcd3d227cc8">~FdoRdbmsOvClassCollection</a>();
+<a name="l00047"></a>00047 <span class="keyword">virtual</span> <span class="keywordtype">void</span> <a class="code" href="class_fdo_rdbms_ov_class_collection_61efa167a392917361e7f552507cef6b.html#61efa167a392917361e7f552507cef6b">Dispose</a>();
+<a name="l00048"></a>00048 };
+<a name="l00049"></a>00049 <span class="comment"></span>
+<a name="l00050"></a>00050 <span class="comment">///<summary>FdoRdbmsOvClassesP is a FdoPtr on FdoRdbmsOvClassCollection, provided for convenience.</summary></span>
+<a name="l00051"></a><a class="code" href="_rdbms_ov_class_collection_8h_26ee985d3d48ae9904b2d8f4528b6b9c.html#26ee985d3d48ae9904b2d8f4528b6b9c">00051</a> <span class="comment"></span><span class="keyword">typedef</span> FdoPtr<FdoRdbmsOvClassCollection> <a class="code" href="_rdbms_ov_class_collection_8h_26ee985d3d48ae9904b2d8f4528b6b9c.html#26ee985d3d48ae9904b2d8f4528b6b9c">FdoRdbmsOvClassesP</a>;
+<a name="l00052"></a>00052 <span class="comment">//DOM-IGNORE-END</span>
+<a name="l00054"></a>00054 <span class="comment">///<summary>Collection of class overrides for an RDBMS-type provider.</span>
+<a name="l00055"></a>00055 <span class="comment">///Members cannot be added to or removed from this collection.</span>
+<a name="l00056"></a>00056 <span class="comment">///</summary></span>
+<a name="l00057"></a><a class="code" href="class_fdo_rdbms_ov_read_only_class_collection.html">00057</a> <span class="comment"></span><span class="keyword">class </span><a class="code" href="class_fdo_rdbms_ov_read_only_class_collection.html">FdoRdbmsOvReadOnlyClassCollection</a> : <span class="keyword">public</span> FdoReadOnlyNamedCollection<FdoRdbmsOvClassDefinition,FdoRdbmsOvClassCollection>
+<a name="l00058"></a>00058 {
+<a name="l00059"></a>00059 <span class="comment">//DOM-IGNORE-BEGIN</span>
+<a name="l00060"></a>00060 <span class="keyword">public</span>:<span class="comment"></span>
+<a name="l00061"></a>00061 <span class="comment"> ///<summary>Constructs a default of an FdoRdbmsReadOnlyOvClassCollection</summary></span>
+<a name="l00062"></a>00062 <span class="comment"> /// <returns>Returns FdoRdbmsOvReadOnlyClassCollection</returns> </span>
+<a name="l00063"></a>00063 <span class="comment"></span> <span class="keyword">static</span> <a class="code" href="class_fdo_rdbms_ov_read_only_class_collection.html">FdoRdbmsOvReadOnlyClassCollection</a>* <a class="code" href="class_fdo_rdbms_ov_read_only_class_collection_7b0936cb7438c96e8c6e9a60316ad577.html#7b0936cb7438c96e8c6e9a60316ad577">Create</a>();
+<a name="l00065"></a>00065 <span class="comment"> ///<summary>Constructs an instance of an FdoRdbmsOvReadOnlyClassCollection using the specified arguments</summary></span>
+<a name="l00066"></a>00066 <span class="comment"> /// <param name="parent">Input parent</param> </span>
+<a name="l00067"></a>00067 <span class="comment"> /// <returns>Returns FdoRdbmsOvReadOnlyClassCollection</returns> </span>
+<a name="l00068"></a>00068 <span class="comment"></span> <span class="keyword">static</span> <a class="code" href="class_fdo_rdbms_ov_read_only_class_collection.html">FdoRdbmsOvReadOnlyClassCollection</a>* <a class="code" href="class_fdo_rdbms_ov_read_only_class_collection_7b0936cb7438c96e8c6e9a60316ad577.html#7b0936cb7438c96e8c6e9a60316ad577">Create</a>(<a class="code" href="class_fdo_rdbms_ov_class_collection.html">FdoRdbmsOvClassCollection</a>* baseCollection);
+<a name="l00070"></a>00070 <span class="keyword">protected</span>:
+<a name="l00071"></a>00071 <a class="code" href="class_fdo_rdbms_ov_read_only_class_collection_9bc9718b6cfa52075840f833be5fd246.html#9bc9718b6cfa52075840f833be5fd246">FdoRdbmsOvReadOnlyClassCollection</a>();
+<a name="l00072"></a>00072 <a class="code" href="class_fdo_rdbms_ov_read_only_class_collection_9bc9718b6cfa52075840f833be5fd246.html#9bc9718b6cfa52075840f833be5fd246">FdoRdbmsOvReadOnlyClassCollection</a>(<a class="code" href="class_fdo_rdbms_ov_class_collection.html">FdoRdbmsOvClassCollection</a>* baseCollection);
+<a name="l00073"></a>00073 <span class="keyword">virtual</span> <a class="code" href="class_fdo_rdbms_ov_read_only_class_collection_08debf30e474b0e45b6c1c64ebc3d13e.html#08debf30e474b0e45b6c1c64ebc3d13e">~FdoRdbmsOvReadOnlyClassCollection</a>();
+<a name="l00074"></a>00074 <span class="keyword">virtual</span> <span class="keywordtype">void</span> <a class="code" href="class_fdo_rdbms_ov_read_only_class_collection_355f8ada79ff99509fa43a0de42c1ebb.html#355f8ada79ff99509fa43a0de42c1ebb">Dispose</a>();
+<a name="l00075"></a>00075 <span class="comment">//DOM-IGNORE-END</span>
+<a name="l00076"></a>00076 };
+<a name="l00077"></a>00077 <span class="comment"></span>
+<a name="l00078"></a>00078 <span class="comment">///<summary>FdoRdbmsOvReadOnlyClassesP is a FdoPtr on FdoRdbmsOvReadOnlyClassCollection, provided for convenience.</summary></span>
+<a name="l00079"></a><a class="code" href="_rdbms_ov_class_collection_8h_f361019b6db0e19fbf2265c24420ba09.html#f361019b6db0e19fbf2265c24420ba09">00079</a> <span class="comment"></span><span class="keyword">typedef</span> FdoPtr<FdoRdbmsOvReadOnlyClassCollection> <a class="code" href="_rdbms_ov_class_collection_8h_f361019b6db0e19fbf2265c24420ba09.html#f361019b6db0e19fbf2265c24420ba09">FdoRdbmsOvReadOnlyClassesP</a>;
+<a name="l00080"></a>00080
+<a name="l00082"></a>00082 <span class="preprocessor">#endif</span>
+<a name="l00083"></a>00083 <span class="preprocessor"></span>
+ <hr>
+ <table width="100%" border="0">
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/ODBC/_rdbms_ov_class_collection_8h.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_class_collection_8h.html?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_rdbms_ov_class_collection_8h.html 2006-12-01 20:39:06+0000
@@ -0,0 +1,74 @@
+<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN" "http://www.w3.org/TR/html4/loose.dtd">
+<html>
+ <head>
+ <meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
+ <title>OSGeo FDO Provider for ODBC API Reference</title>
+ <link href="custom.css" rel="stylesheet" type="text/css">
+ <link href="tabs.css" rel="stylesheet" type="text/css">
+ </head>
+ <body bgcolor="#FFFFFF">
+ <tr>
+ <td><b>API Reference<b></td>
+ <td align="right"><b>OSGeo FDO Provider for ODBC<b></td>
+ </tr>
+ </table>
+<!-- End of: header.html -->
+<!-- Generated by Doxygen 1.4.6-NO -->
+<div class="tabs">
+ <ul>
+ <li><a href="main.html"><span>Main Page</span></a></li>
+ <li><a href="classes.html"><span>Classes</span></a></li>
+ <li id="current"><a href="files.html"><span>Files</span></a></li>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ <li><a href="files.html"><span>File List</span></a></li>
+ <li><a href="globals.html"><span>File Members</span></a></li>
+ </ul></div>
+<h1>RdbmsOvClassCollection.h File Reference</h1>
+<p>
+<code>#include <<a class="el" href="_rdbms_ov_class_definition_8h-source.html">Rdbms/Override/RdbmsOvClassDefinition.h</a>></code><br>
+<p>
+Include dependency graph for RdbmsOvClassCollection.h:<p><center><img src="_rdbms_ov_class_collection_8h__incl.png" border="0" usemap="#RdbmsOvClassCollection.h_map" alt=""></center>
+<map name="RdbmsOvClassCollection.h_map">
+<area href="_rdbms_ov_class_definition_8h.html" shape="rect" coords="297,7,583,34" alt="">
+</map>
+<p>
+This graph shows which files directly or indirectly include this file:<p><center><img src="_rdbms_ov_class_collection_8h__dep__incl.png" border="0" usemap="#RdbmsOvClassCollection.hdep_map" alt=""></center>
+<map name="RdbmsOvClassCollection.hdep_map">
+<area href="_odbc_ov_class_collection_8h.html" shape="rect" coords="276,7,452,34" alt="">
+<area href="_rdbms_ov_physical_schema_mapping_8h.html" shape="rect" coords="243,58,485,84" alt="">
+<area href="_odbc_ov_physical_schema_mapping_8h.html" shape="rect" coords="536,32,768,59" alt="">
+</map>
+<p>
+<a href="_rdbms_ov_class_collection_8h-source.html">Go to the source code of this file.</a><table border="0" cellpadding="0" cellspacing="0">
+<tr><td></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">class </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_rdbms_ov_class_collection.html">FdoRdbmsOvClassCollection</a></td></tr>
+<tr><td class="mdescLeft"> </td><td class="mdescRight">Concrete class defining physical schema overrides for a collection of class definitions. <a href="class_fdo_rdbms_ov_class_collection.html#_details">More...</a><br></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">class </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_rdbms_ov_read_only_class_collection.html">FdoRdbmsOvReadOnlyClassCollection</a></td></tr>
+<tr><td class="mdescLeft"> </td><td class="mdescRight">Collection of class overrides for an RDBMS-type provider. Members cannot be added to or removed from this collection. /summary>. <a href="class_fdo_rdbms_ov_read_only_class_collection.html#_details">More...</a><br></td></tr>
+<tr><td colspan="2"><br><h2>Typedefs</h2></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">typedef FdoPtr< <a class="el" href="class_fdo_rdbms_ov_class_collection.html">FdoRdbmsOvClassCollection</a> > </td><td class="memItemRight" valign="bottom"><a class="el" href="_rdbms_ov_class_collection_8h_26ee985d3d48ae9904b2d8f4528b6b9c.html#26ee985d3d48ae9904b2d8f4528b6b9c">FdoRdbmsOvClassesP</a></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">typedef FdoPtr< <a class="el" href="class_fdo_rdbms_ov_read_only_class_collection.html">FdoRdbmsOvReadOnlyClassCollection</a> > </td><td class="memItemRight" valign="bottom"><a class="el" href="_rdbms_ov_class_collection_8h_f361019b6db0e19fbf2265c24420ba09.html#f361019b6db0e19fbf2265c24420ba09">FdoRdbmsOvReadOnlyClassesP</a></td></tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/ODBC/_rdbms_ov_class_collection_8h_26ee985d3d48ae9904b2d8f4528b6b9c.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_class_collection_8h_26ee985d3d48ae9904b2d8f4528b6b9c.html?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_rdbms_ov_class_collection_8h_26ee985d3d48ae9904b2d8f4528b6b9c.html 2006-12-01 20:39:06+0000
@@ -0,0 +1,75 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="nav">
+<a class="el" href="_rdbms_ov_class_collection_8h.html">RdbmsOvClassCollection.h</a></div>
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="_rdbms_ov_class_collection_8h_26ee985d3d48ae9904b2d8f4528b6b9c.html#26ee985d3d48ae9904b2d8f4528b6b9c">FdoRdbmsOvClassesP</a></td></tr>
+ <tr><td class="navtab"><a class="qindex" href="_rdbms_ov_class_collection_8h_f361019b6db0e19fbf2265c24420ba09.html#f361019b6db0e19fbf2265c24420ba09">FdoRdbmsOvReadOnlyClassesP</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="26ee985d3d48ae9904b2d8f4528b6b9c"></a><!-- doxytag: member="RdbmsOvClassCollection.h::FdoRdbmsOvClassesP" ref="26ee985d3d48ae9904b2d8f4528b6b9c" args="" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">typedef FdoPtr<<a class="el" href="class_fdo_rdbms_ov_class_collection.html">FdoRdbmsOvClassCollection</a>> <a class="el" href="_rdbms_ov_class_collection_8h_26ee985d3d48ae9904b2d8f4528b6b9c.html#26ee985d3d48ae9904b2d8f4528b6b9c">FdoRdbmsOvClassesP</a> </td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+<p>
+Definition at line <a class="el" href="_rdbms_ov_class_collection_8h-source.html#l00051">51</a> of file <a class="el" href="_rdbms_ov_class_collection_8h-source.html">RdbmsOvClassCollection.h</a>. </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/ODBC/_rdbms_ov_class_collection_8h__dep__incl.map
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_class_collection_8h__dep__incl.map?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_rdbms_ov_class_collection_8h__dep__incl.map 2006-12-01 20:39:06+0000
@@ -0,0 +1,4 @@
+base referer
+rect $_odbc_ov_class_collection_8h.html 276,7 452,34
+rect $_rdbms_ov_physical_schema_mapping_8h.html 243,58 485,84
+rect $_odbc_ov_physical_schema_mapping_8h.html 536,32 768,59
Added: trunk/www/docs/ODBC/_rdbms_ov_class_collection_8h__dep__incl.md5
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_class_collection_8h__dep__incl.md5?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_rdbms_ov_class_collection_8h__dep__incl.md5 2006-12-01 20:39:06+0000
@@ -0,0 +1 @@
+1259316ca44474d556a58413da3ede45
Added: trunk/www/docs/ODBC/_rdbms_ov_class_collection_8h__dep__incl.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_class_collection_8h__dep__incl.png?view=auto&rev=94
Added: trunk/www/docs/ODBC/_rdbms_ov_class_collection_8h__incl.map
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_class_collection_8h__incl.map?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_rdbms_ov_class_collection_8h__incl.map 2006-12-01 20:39:06+0000
@@ -0,0 +1,2 @@
+base referer
+rect $_rdbms_ov_class_definition_8h.html 297,7 583,34
Added: trunk/www/docs/ODBC/_rdbms_ov_class_collection_8h__incl.md5
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_class_collection_8h__incl.md5?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_rdbms_ov_class_collection_8h__incl.md5 2006-12-01 20:39:06+0000
@@ -0,0 +1 @@
+ef5df4aa28da68c22e91ebc0f86d1dec
Added: trunk/www/docs/ODBC/_rdbms_ov_class_collection_8h__incl.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_class_collection_8h__incl.png?view=auto&rev=94
Added: trunk/www/docs/ODBC/_rdbms_ov_class_collection_8h_f361019b6db0e19fbf2265c24420ba09.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_class_collection_8h_f361019b6db0e19fbf2265c24420ba09.html?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_rdbms_ov_class_collection_8h_f361019b6db0e19fbf2265c24420ba09.html 2006-12-01 20:39:06+0000
@@ -0,0 +1,75 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="nav">
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindex" href="_rdbms_ov_class_collection_8h_26ee985d3d48ae9904b2d8f4528b6b9c.html#26ee985d3d48ae9904b2d8f4528b6b9c">FdoRdbmsOvClassesP</a></td></tr>
+ <tr><td class="navtab"><a class="qindexHL" href="_rdbms_ov_class_collection_8h_f361019b6db0e19fbf2265c24420ba09.html#f361019b6db0e19fbf2265c24420ba09">FdoRdbmsOvReadOnlyClassesP</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="f361019b6db0e19fbf2265c24420ba09"></a><!-- doxytag: member="RdbmsOvClassCollection.h::FdoRdbmsOvReadOnlyClassesP" ref="f361019b6db0e19fbf2265c24420ba09" args="" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">typedef FdoPtr<<a class="el" href="class_fdo_rdbms_ov_read_only_class_collection.html">FdoRdbmsOvReadOnlyClassCollection</a>> <a class="el" href="_rdbms_ov_class_collection_8h_f361019b6db0e19fbf2265c24420ba09.html#f361019b6db0e19fbf2265c24420ba09">FdoRdbmsOvReadOnlyClassesP</a> </td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+<p>
+Definition at line <a class="el" href="_rdbms_ov_class_collection_8h-source.html#l00079">79</a> of file <a class="el" href="_rdbms_ov_class_collection_8h-source.html">RdbmsOvClassCollection.h</a>. </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/ODBC/_rdbms_ov_class_definition_8h-source.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_class_definition_8h-source.html?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_rdbms_ov_class_definition_8h-source.html 2006-12-01 20:39:06+0000
@@ -0,0 +1,261 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<h1>RdbmsOvClassDefinition.h</h1><a href="_rdbms_ov_class_definition_8h.html">Go to the documentation of this file.</a><div class="fragment"><pre class="fragment"><a name="l00001"></a>00001 <span class="preprocessor">#ifndef FDO_RDBMSOVCLASSDEFINITION_H</span>
+<a name="l00002"></a>00002 <span class="preprocessor"></span><span class="preprocessor">#define FDO_RDBMSOVCLASSDEFINITION_H</span>
+<a name="l00005"></a>00005 <span class="comment">//</span>
+<a name="l00006"></a>00006 <span class="comment">// Copyright (C) 2004-2006 Autodesk, Inc.</span>
+<a name="l00007"></a>00007 <span class="comment">// </span>
+<a name="l00008"></a>00008 <span class="comment">// This library is free software; you can redistribute it and/or</span>
+<a name="l00009"></a>00009 <span class="comment">// modify it under the terms of version 2.1 of the GNU Lesser</span>
+<a name="l00010"></a>00010 <span class="comment">// General Public License as published by the Free Software Foundation.</span>
+<a name="l00011"></a>00011 <span class="comment">// </span>
+<a name="l00012"></a>00012 <span class="comment">// This library is distributed in the hope that it will be useful,</span>
+<a name="l00013"></a>00013 <span class="comment">// but WITHOUT ANY WARRANTY; without even the implied warranty of</span>
+<a name="l00014"></a>00014 <span class="comment">// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU</span>
+<a name="l00015"></a>00015 <span class="comment">// Lesser General Public License for more details.</span>
+<a name="l00016"></a>00016 <span class="comment">// </span>
+<a name="l00017"></a>00017 <span class="comment">// You should have received a copy of the GNU Lesser General Public</span>
+<a name="l00018"></a>00018 <span class="comment">// License along with this library; if not, write to the Free Software</span>
+<a name="l00019"></a>00019 <span class="comment">// Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA</span>
+<a name="l00020"></a>00020 <span class="comment">//</span>
+<a name="l00021"></a>00021 <span class="comment"></span>
+<a name="l00022"></a>00022 <span class="comment">/// <library></span>
+<a name="l00023"></a>00023 <span class="comment">/// FdoRdbms.lib</span>
+<a name="l00024"></a>00024 <span class="comment">/// </library></span>
+<a name="l00025"></a>00025 <span class="comment"></span>
+<a name="l00026"></a>00026 <span class="preprocessor">#include <Fdo/Commands/Schema/PhysicalClassMapping.h></span>
+<a name="l00027"></a>00027 <span class="preprocessor">#include <Utilities/SchemaMgr/Overrides/TableMappingType.h></span>
+<a name="l00028"></a>00028 <span class="preprocessor">#include <<a class="code" href="_rdbms_ov_8h.html">Rdbms/Override/RdbmsOv.h</a>></span>
+<a name="l00029"></a>00029 <span class="preprocessor">#include <<a class="code" href="_rdbms_ov_property_definition_collection_8h.html">Rdbms/Override/RdbmsOvPropertyDefinitionCollection.h</a>></span>
+<a name="l00030"></a>00030 <span class="preprocessor">#include <<a class="code" href="_rdbms_ov_data_property_definition_8h.html">Rdbms/Override/RdbmsOvDataPropertyDefinition.h</a>></span>
+<a name="l00031"></a>00031 <span class="preprocessor">#include <<a class="code" href="_rdbms_ov_geometric_property_definition_8h.html">Rdbms/Override/RdbmsOvGeometricPropertyDefinition.h</a>></span>
+<a name="l00032"></a>00032 <span class="preprocessor">#include <<a class="code" href="_rdbms_ov_object_property_definition_8h.html">Rdbms/Override/RdbmsOvObjectPropertyDefinition.h</a>></span>
+<a name="l00033"></a>00033 <span class="preprocessor">#include <<a class="code" href="_rdbms_ov_table_8h.html">Rdbms/Override/RdbmsOvTable.h</a>></span>
+<a name="l00034"></a>00034 <span class="comment"></span>
+<a name="l00035"></a>00035 <span class="comment">///<summary>Abstract class defining physical schema overrides for a class definition.</summary></span>
+<a name="l00036"></a><a class="code" href="class_fdo_rdbms_ov_class_definition.html">00036</a> <span class="comment"></span><span class="keyword">class </span><a class="code" href="class_fdo_rdbms_ov_class_definition.html">FdoRdbmsOvClassDefinition</a>: <span class="keyword">public</span> FdoPhysicalClassMapping
+<a name="l00037"></a>00037 {
+<a name="l00039"></a>00039 <span class="keyword">public</span>:<span class="comment"></span>
+<a name="l00040"></a>00040 <span class="comment"> ///<summary>Gets the collection of property overrides for this class</span>
+<a name="l00041"></a>00041 <span class="comment"> ///override.</summary></span>
+<a name="l00042"></a>00042 <span class="comment"> /// <returns>Returns FdoRdbmsOvReadOnlyPropertyDefinitionCollection</returns></span>
+<a name="l00043"></a>00043 <span class="comment"></span> <a class="code" href="_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html#9b6afd7f3f2f73a361844d7bff18436f">FDORDBMS_OV_API</a> <a class="code" href="class_fdo_rdbms_ov_read_only_property_definition_collection.html">FdoRdbmsOvReadOnlyPropertyDefinitionCollection</a>* <a class="code" href="class_fdo_rdbms_ov_class_definition_14dd2ceb64c6717fce9e0c4b42453c38.html#14dd2ceb64c6717fce9e0c4b42453c38">GetProperties</a>();
+<a name="l00044"></a>00044 <span class="comment"></span>
+<a name="l00045"></a>00045 <span class="comment"> ///<summary>Gets the table overrides for this class override</summary></span>
+<a name="l00046"></a>00046 <span class="comment"> /// <returns>Returns FdoRdbmsOvTable</returns></span>
+<a name="l00047"></a>00047 <span class="comment"></span> <a class="code" href="_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html#9b6afd7f3f2f73a361844d7bff18436f">FDORDBMS_OV_API</a> <a class="code" href="class_fdo_rdbms_ov_table.html">FdoRdbmsOvTable</a>* <a class="code" href="class_fdo_rdbms_ov_class_definition_94c652ae4389ad6115f3ff0d3266e09d.html#94c652ae4389ad6115f3ff0d3266e09d">GetTable</a>();
+<a name="l00048"></a>00048 <span class="comment"></span>
+<a name="l00049"></a>00049 <span class="comment"> ///<summary>Gets the table mapping</summary></span>
+<a name="l00050"></a>00050 <span class="comment"> ///<returns>Returns FdoSmOvTableMappingType</returns></span>
+<a name="l00051"></a>00051 <span class="comment"></span> <a class="code" href="_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html#9b6afd7f3f2f73a361844d7bff18436f">FDORDBMS_OV_API</a> FdoSmOvTableMappingType <a class="code" href="class_fdo_rdbms_ov_class_definition_9a8be90a92df7487cec1224259e99833.html#9a8be90a92df7487cec1224259e99833">GetTableMapping</a>();
+<a name="l00052"></a>00052 <span class="comment"></span>
+<a name="l00053"></a>00053 <span class="comment"> ///<summary>Sets the table mapping</summary></span>
+<a name="l00054"></a>00054 <span class="comment"> /// <param name="mappingType">Input the mapping type</param></span>
+<a name="l00055"></a>00055 <span class="comment"> ///<returns>Returns nothing</returns></span>
+<a name="l00056"></a>00056 <span class="comment"></span> <a class="code" href="_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html#9b6afd7f3f2f73a361844d7bff18436f">FDORDBMS_OV_API</a> <span class="keywordtype">void</span> <a class="code" href="class_fdo_rdbms_ov_class_definition_1d3f4570f3a7eb4c89367dc8be9327e4.html#1d3f4570f3a7eb4c89367dc8be9327e4">SetTableMapping</a>(FdoSmOvTableMappingType mappingType);
+<a name="l00058"></a>00058 <span class="comment">//DOM-IGNORE-BEGIN</span>
+<a name="l00059"></a>00059 <a class="code" href="_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html#9b6afd7f3f2f73a361844d7bff18436f">FDORDBMS_OV_API</a> <span class="keywordtype">void</span> <a class="code" href="class_fdo_rdbms_ov_class_definition_b9305a7abd05993ed4122ed92518584a.html#b9305a7abd05993ed4122ed92518584a">SetParent</a>(FdoPhysicalElementMapping* value);
+<a name="l00061"></a>00061 <span class="comment">// XML Serialization functions.</span>
+<a name="l00063"></a>00063 <a class="code" href="_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html#9b6afd7f3f2f73a361844d7bff18436f">FDORDBMS_OV_API</a> <span class="keyword">virtual</span> <span class="keywordtype">void</span> <a class="code" href="class_fdo_rdbms_ov_class_definition_e3b45851d6a9559b5ec696ff011275a5.html#e3b45851d6a9559b5ec696ff011275a5">_writeXml</a>(FdoXmlWriter* xmlWriter, <span class="keyword">const</span> FdoXmlFlags* flags);
+<a name="l00065"></a>00065 <a class="code" href="_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html#9b6afd7f3f2f73a361844d7bff18436f">FDORDBMS_OV_API</a> <span class="keyword">virtual</span> <span class="keywordtype">void</span> <a class="code" href="class_fdo_rdbms_ov_class_definition_67aeba1b9893aba90139cb89f0e99d79.html#67aeba1b9893aba90139cb89f0e99d79">InitFromXml</a>(FdoXmlSaxContext* pContext, FdoXmlAttributeCollection* attrs);
+<a name="l00067"></a>00067 <span class="comment">// Serialize the XML attributes of this class:</span>
+<a name="l00068"></a>00068 <a class="code" href="_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html#9b6afd7f3f2f73a361844d7bff18436f">FDORDBMS_OV_API</a> <span class="keyword">virtual</span> <span class="keywordtype">void</span> <a class="code" href="class_fdo_rdbms_ov_class_definition_4ff68496a1501f813642d416cf239d48.html#4ff68496a1501f813642d416cf239d48">_writeXmlAttributes</a>(FdoXmlWriter* xmlWriter, <span class="keyword">const</span> FdoXmlFlags* flags);
+<a name="l00070"></a>00070 <a class="code" href="_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html#9b6afd7f3f2f73a361844d7bff18436f">FDORDBMS_OV_API</a> <span class="keyword">virtual</span> FdoXmlSaxHandler* <a class="code" href="class_fdo_rdbms_ov_class_definition_a25300e89cd1535e9b7b2f4605c0e413.html#a25300e89cd1535e9b7b2f4605c0e413">XmlStartElement</a>(
+<a name="l00071"></a>00071 FdoXmlSaxContext* context,
+<a name="l00072"></a>00072 FdoString* uri,
+<a name="l00073"></a>00073 FdoString* name,
+<a name="l00074"></a>00074 FdoString* qname,
+<a name="l00075"></a>00075 FdoXmlAttributeCollection* atts
+<a name="l00076"></a>00076 );
+<a name="l00078"></a>00078 <a class="code" href="_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html#9b6afd7f3f2f73a361844d7bff18436f">FDORDBMS_OV_API</a> <span class="keyword">virtual</span> FdoBoolean <a class="code" href="class_fdo_rdbms_ov_class_definition_f9ed063657db3faadeeee7514de9cd4c.html#f9ed063657db3faadeeee7514de9cd4c">XmlEndElement</a>(
+<a name="l00079"></a>00079 FdoXmlSaxContext* context,
+<a name="l00080"></a>00080 FdoString* uri,
+<a name="l00081"></a>00081 FdoString* name,
+<a name="l00082"></a>00082 FdoString* qname
+<a name="l00083"></a>00083 );
+<a name="l00084"></a>00084
+<a name="l00085"></a>00085 <span class="comment">//DOM-IGNORE-END</span>
+<a name="l00086"></a>00086
+<a name="l00087"></a>00087 <span class="keyword">protected</span>:
+<a name="l00088"></a>00088 <span class="comment">//<summary>Constructs a default instance of an FdoRdbmsOvClassDefinition.</summary></span>
+<a name="l00089"></a>00089 <a class="code" href="_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html#9b6afd7f3f2f73a361844d7bff18436f">FDORDBMS_OV_API</a> <a class="code" href="class_fdo_rdbms_ov_class_definition_e08591d4b92b0e41a9f5dfac8a71c48a.html#e08591d4b92b0e41a9f5dfac8a71c48a">FdoRdbmsOvClassDefinition</a>();
+<a name="l00090"></a>00090
+<a name="l00091"></a>00091 <span class="comment">//<summary>Constructs an instance of an FdoRdbmsOvClassDefinition using the specified arguments.</summary></span>
+<a name="l00092"></a>00092 <span class="comment">// <param name="name">Input the element name</param> </span>
+<a name="l00093"></a>00093 <a class="code" href="_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html#9b6afd7f3f2f73a361844d7bff18436f">FDORDBMS_OV_API</a> <a class="code" href="class_fdo_rdbms_ov_class_definition_e08591d4b92b0e41a9f5dfac8a71c48a.html#e08591d4b92b0e41a9f5dfac8a71c48a">FdoRdbmsOvClassDefinition</a>(FdoString *name);
+<a name="l00094"></a>00094
+<a name="l00095"></a>00095 <a class="code" href="_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html#9b6afd7f3f2f73a361844d7bff18436f">FDORDBMS_OV_API</a> <span class="keyword">virtual</span> <a class="code" href="class_fdo_rdbms_ov_class_definition_930aa466b8b22426b1091171d5875a39.html#930aa466b8b22426b1091171d5875a39">~FdoRdbmsOvClassDefinition</a>();
+<a name="l00096"></a>00096
+<a name="l00097"></a>00097 <span class="comment">//<summary>Gets the property overrides in writable form.</summary></span>
+<a name="l00098"></a>00098 <span class="comment">// <returns>Returns FdoRdbmsOvPropertyDefinitionCollection</returns></span>
+<a name="l00099"></a>00099 <a class="code" href="_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html#9b6afd7f3f2f73a361844d7bff18436f">FDORDBMS_OV_API</a> <a class="code" href="class_fdo_rdbms_ov_property_definition_collection.html">FdoRdbmsOvPropertyDefinitionCollection</a>* <a class="code" href="class_fdo_rdbms_ov_class_definition_98af5a6fe61d7e563bc26fe0cd4bd9e8.html#98af5a6fe61d7e563bc26fe0cd4bd9e8">GetRdbmsProperties</a>();
+<a name="l00100"></a>00100
+<a name="l00101"></a>00101 <span class="comment">//<summary>Sets the table override<summary></span>
+<a name="l00102"></a>00102 <span class="comment">// <param name="table">Input table override</param></span>
+<a name="l00103"></a>00103 <a class="code" href="_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html#9b6afd7f3f2f73a361844d7bff18436f">FDORDBMS_OV_API</a> <span class="keywordtype">void</span> <a class="code" href="class_fdo_rdbms_ov_class_definition_13055d78afb38b416bfa382b53b1d52c.html#13055d78afb38b416bfa382b53b1d52c">SetTable</a>(<a class="code" href="class_fdo_rdbms_ov_table.html">FdoRdbmsOvTable</a>* table);
+<a name="l00104"></a>00104
+<a name="l00105"></a>00105 <span class="comment">//<summary>Sets the table override from XML attributes</summary></span>
+<a name="l00106"></a>00106 <span class="comment">// <param name="context">Input context contain information about the current deserialization operation</param> </span>
+<a name="l00107"></a>00107 <span class="comment">// <param name="attrs">Input the XML attributes.</param> </span>
+<a name="l00108"></a><a class="code" href="class_fdo_rdbms_ov_class_definition_1f7f96e74f1fd02b5e674ffc00fafca1.html#1f7f96e74f1fd02b5e674ffc00fafca1">00108</a> <a class="code" href="_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html#9b6afd7f3f2f73a361844d7bff18436f">FDORDBMS_OV_API</a> <span class="keyword">virtual</span> <span class="keywordtype">void</span> <a class="code" href="class_fdo_rdbms_ov_class_definition_13055d78afb38b416bfa382b53b1d52c.html#13055d78afb38b416bfa382b53b1d52c">SetTable</a>(
+<a name="l00109"></a>00109 FdoXmlSaxContext* context,
+<a name="l00110"></a>00110 FdoXmlAttributeCollection* atts
+<a name="l00111"></a>00111 )
+<a name="l00112"></a>00112 {
+<a name="l00113"></a>00113 <span class="comment">//TODO: exception</span>
+<a name="l00114"></a>00114 }
+<a name="l00115"></a>00115
+<a name="l00116"></a>00116 <span class="comment">//<summary></span>
+<a name="l00117"></a>00117 <span class="comment">//Creates a data property override for this class override.</span>
+<a name="l00118"></a>00118 <span class="comment">//Must be overridden by all providers that support</span>
+<a name="l00119"></a>00119 <span class="comment">//data property overrides.</span>
+<a name="l00120"></a>00120 <span class="comment">//</summary></span>
+<a name="l00121"></a>00121 <span class="comment">// <param name="context">Input context contain information about the current deserialization operation</param> </span>
+<a name="l00122"></a>00122 <span class="comment">// <param name="propAttrs">Input the XML attributes for the property override.</param> </span>
+<a name="l00123"></a>00123 <span class="comment">// <param name="colAttrs">Input the XML attributes for the property's column override.</param> </span>
+<a name="l00124"></a>00124 <span class="comment">// <returns>Returns FdoRdbmsOvDataPropertyDefinition</returns></span>
+<a name="l00125"></a><a class="code" href="class_fdo_rdbms_ov_class_definition_e400bdb98dda4fd85ede3f356df30148.html#e400bdb98dda4fd85ede3f356df30148">00125</a> <a class="code" href="_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html#9b6afd7f3f2f73a361844d7bff18436f">FDORDBMS_OV_API</a> <span class="keyword">virtual</span> <a class="code" href="class_fdo_rdbms_ov_data_property_definition.html">FdoRdbmsOvDataPropertyDefinition</a>* <a class="code" href="class_fdo_rdbms_ov_class_definition_e400bdb98dda4fd85ede3f356df30148.html#e400bdb98dda4fd85ede3f356df30148">CreateDataProperty</a>(
+<a name="l00126"></a>00126 FdoXmlSaxContext* context,
+<a name="l00127"></a>00127 FdoXmlAttributeCollection* propAtts,
+<a name="l00128"></a>00128 FdoXmlAttributeCollection* colAtts
+<a name="l00129"></a>00129 )
+<a name="l00130"></a>00130 {
+<a name="l00131"></a>00131 <span class="comment">//TODO: exception</span>
+<a name="l00132"></a>00132 <span class="keywordflow">return</span> NULL;
+<a name="l00133"></a>00133 }
+<a name="l00134"></a>00134
+<a name="l00135"></a>00135 <span class="comment">//<summary></span>
+<a name="l00136"></a>00136 <span class="comment">//Creates a geometric property override for this class override.</span>
+<a name="l00137"></a>00137 <span class="comment">//Must be overridden by all providers that support</span>
+<a name="l00138"></a>00138 <span class="comment">//geometric property overrides.</span>
+<a name="l00139"></a>00139 <span class="comment">//</summary></span>
+<a name="l00140"></a>00140 <span class="comment">// <param name="context">Input context contain information about the current deserialization operation</param> </span>
+<a name="l00141"></a>00141 <span class="comment">// <param name="propAttrs">Input the XML attributes for the property override.</param> </span>
+<a name="l00142"></a>00142 <span class="comment">// <param name="colAttrs">Input the XML attributes for the property's column override.</param> </span>
+<a name="l00143"></a>00143 <span class="comment">// <returns>Returns FdoRdbmsOvDataPropertyDefinition</returns></span>
+<a name="l00144"></a><a class="code" href="class_fdo_rdbms_ov_class_definition_865da921ba083d63cb9c34c3e8bd5808.html#865da921ba083d63cb9c34c3e8bd5808">00144</a> <a class="code" href="_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html#9b6afd7f3f2f73a361844d7bff18436f">FDORDBMS_OV_API</a> <span class="keyword">virtual</span> <a class="code" href="class_fdo_rdbms_ov_geometric_property_definition.html">FdoRdbmsOvGeometricPropertyDefinition</a>* <a class="code" href="class_fdo_rdbms_ov_class_definition_865da921ba083d63cb9c34c3e8bd5808.html#865da921ba083d63cb9c34c3e8bd5808">CreateGeometricProperty</a>(
+<a name="l00145"></a>00145 FdoXmlSaxContext* context,
+<a name="l00146"></a>00146 FdoXmlAttributeCollection* propAtts,
+<a name="l00147"></a>00147 FdoXmlAttributeCollection* colAtts
+<a name="l00148"></a>00148 )
+<a name="l00149"></a>00149 {
+<a name="l00150"></a>00150 <span class="comment">//TODO: exception</span>
+<a name="l00151"></a>00151 <span class="keywordflow">return</span> NULL;
+<a name="l00152"></a>00152 }
+<a name="l00153"></a>00153
+<a name="l00154"></a>00154 <span class="comment">//<summary></span>
+<a name="l00155"></a>00155 <span class="comment">//Creates a object property override for this class override.</span>
+<a name="l00156"></a>00156 <span class="comment">//Must be overridden by all providers that support</span>
+<a name="l00157"></a>00157 <span class="comment">//object property overrides.</span>
+<a name="l00158"></a>00158 <span class="comment">//</summary></span>
+<a name="l00159"></a>00159 <span class="comment">// <param name="context">Input context contain information about the current deserialization operation</param> </span>
+<a name="l00160"></a>00160 <span class="comment">// <param name="propAttrs">Input the XML attributes for the property override.</param> </span>
+<a name="l00161"></a>00161 <span class="comment">// <param name="mappingAttrs">Input the XML attributes for the </span>
+<a name="l00162"></a>00162 <span class="comment">// object property table mapping override.</param> </span>
+<a name="l00163"></a>00163 <span class="comment">// <returns>Returns FdoRdbmsOvDataPropertyDefinition</returns></span>
+<a name="l00164"></a><a class="code" href="class_fdo_rdbms_ov_class_definition_1964e0fff0115e528f7aa328c19cc7fd.html#1964e0fff0115e528f7aa328c19cc7fd">00164</a> <a class="code" href="_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html#9b6afd7f3f2f73a361844d7bff18436f">FDORDBMS_OV_API</a> <span class="keyword">virtual</span> <a class="code" href="class_fdo_rdbms_ov_object_property_definition.html">FdoRdbmsOvObjectPropertyDefinition</a>* <a class="code" href="class_fdo_rdbms_ov_class_definition_1964e0fff0115e528f7aa328c19cc7fd.html#1964e0fff0115e528f7aa328c19cc7fd">CreateObjectProperty</a>(
+<a name="l00165"></a>00165 FdoXmlSaxContext* context,
+<a name="l00166"></a>00166 FdoXmlAttributeCollection* propAtts,
+<a name="l00167"></a>00167 FdoString* mappingType,
+<a name="l00168"></a>00168 FdoXmlAttributeCollection* mappingAtts
+<a name="l00169"></a>00169 )
+<a name="l00170"></a>00170 {
+<a name="l00171"></a>00171 <span class="comment">//TODO: exception</span>
+<a name="l00172"></a>00172 <span class="keywordflow">return</span> NULL;
+<a name="l00173"></a>00173 }
+<a name="l00174"></a>00174
+<a name="l00175"></a>00175 <span class="comment">//<summary> </span>
+<a name="l00176"></a>00176 <span class="comment">//Checks if the given property is already in this class overrides's</span>
+<a name="l00177"></a>00177 <span class="comment">//property list. If it is then an error is logged and a SAX handler</span>
+<a name="l00178"></a>00178 <span class="comment">//for skipping the rest of the property's XML elements is returned.</span><span class="comment"></span>
+<a name="l00179"></a>00179 <span class="comment"> ///summary></span>
+<a name="l00180"></a>00180 <span class="comment"></span> <span class="comment">// <param name="context">Input context contain information about the current deserialization operation</param> </span>
+<a name="l00181"></a>00181 <span class="comment">// <param name="pProp">Input the property to check</param> </span>
+<a name="l00182"></a>00182 <span class="comment">// <returns>Returns FdoXmlSaxHandler</returns></span>
+<a name="l00183"></a>00183 <a class="code" href="_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html#9b6afd7f3f2f73a361844d7bff18436f">FDORDBMS_OV_API</a> FdoXmlSaxHandler* <a class="code" href="class_fdo_rdbms_ov_class_definition_fab708882de4a26ffd667ebeffd6901a.html#fab708882de4a26ffd667ebeffd6901a">CheckDuplicateProperty</a>(
+<a name="l00184"></a>00184 FdoXmlSaxContext* context,
+<a name="l00185"></a>00185 <a class="code" href="class_fdo_rdbms_ov_property_definition.html">FdoRdbmsOvPropertyDefinition</a>* pProp
+<a name="l00186"></a>00186 );
+<a name="l00187"></a>00187
+<a name="l00188"></a>00188 <span class="comment">//<summary></span>
+<a name="l00189"></a>00189 <span class="comment">//Adds a property to this class definition.</span>
+<a name="l00190"></a>00190 <span class="comment">//<summary></span>
+<a name="l00191"></a>00191 <a class="code" href="_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html#9b6afd7f3f2f73a361844d7bff18436f">FDORDBMS_OV_API</a> <span class="keyword">virtual</span> <span class="keywordtype">void</span> <a class="code" href="class_fdo_rdbms_ov_class_definition_4600f7daf28d8e3301f768bcce460fd1.html#4600f7daf28d8e3301f768bcce460fd1">AddProperty</a>(
+<a name="l00192"></a>00192 <a class="code" href="class_fdo_rdbms_ov_property_definition.html">FdoRdbmsOvPropertyDefinition</a>* pProp
+<a name="l00193"></a>00193 ) = 0;
+<a name="l00194"></a>00194
+<a name="l00195"></a>00195 <span class="comment">//DOM-IGNORE-BEGIN</span>
+<a name="l00196"></a>00196 <span class="comment">// Initializes this class override.</span>
+<a name="l00197"></a>00197 <span class="keywordtype">void</span> <a class="code" href="class_fdo_rdbms_ov_class_definition_55ba186d10bdc2d88c18659edc0722c9.html#55ba186d10bdc2d88c18659edc0722c9">Init</a>();
+<a name="l00198"></a>00198 <span class="comment">//DOM-IGNORE-END</span>
+<a name="l00199"></a>00199
+<a name="l00200"></a>00200 <span class="keyword">private</span>:
+<a name="l00201"></a>00201 FdoSmOvTableMappingType mMappingType;
+<a name="l00202"></a>00202 <a class="code" href="_rdbms_ov_property_definition_collection_8h_8a7a02562b4dcd8bbbf507c92753c27c.html#8a7a02562b4dcd8bbbf507c92753c27c">FdoRdbmsOvPropertiesP</a> mProperties;
+<a name="l00203"></a>00203 <a class="code" href="_rdbms_ov_table_8h_612b061ebc8babde7d8d0ef0943742cb.html#612b061ebc8babde7d8d0ef0943742cb">FdoRdbmsOvTableP</a> mTable;
+<a name="l00204"></a>00204
+<a name="l00205"></a>00205 FdoXmlAttributesP mCurrAtts;
+<a name="l00206"></a>00206 <a class="code" href="class_fdo_rdbms_ov_property_definition.html">FdoRdbmsOvPropertyDefinition</a>* mCurrProp;
+<a name="l00207"></a>00207 <a class="code" href="_rdbms_ov_data_property_definition_8h_fb7f707266f7220c654ef63b0248531c.html#fb7f707266f7220c654ef63b0248531c">FdoRdbmsOvDataPropertyP</a> mCurrDataProp;
+<a name="l00208"></a>00208 <a class="code" href="_rdbms_ov_geometric_property_definition_8h_b9378490b3e08ad09a80d49a6a8aff7d.html#b9378490b3e08ad09a80d49a6a8aff7d">FdoRdbmsOvGeometricPropertyP</a> mCurrGeomProp;
+<a name="l00209"></a>00209 <a class="code" href="_rdbms_ov_object_property_definition_8h_82a4996cf07e521712d6b26ac2aa96de.html#82a4996cf07e521712d6b26ac2aa96de">FdoRdbmsOvObjectPropertyP</a> mCurrObjProp;
+<a name="l00210"></a>00210
+<a name="l00211"></a>00211 <span class="comment">// Lists the allowable sub-elements for class definition's XML element</span>
+<a name="l00212"></a>00212 FdoStringsP mElementSubElements;
+<a name="l00213"></a>00213 <span class="comment">// List of Object Property Mapping element.</span>
+<a name="l00214"></a>00214 FdoStringsP mOpSubElements;
+<a name="l00215"></a>00215 };
+<a name="l00216"></a>00216 <span class="comment"></span>
+<a name="l00217"></a>00217 <span class="comment">///<summary>FdoRdbmsOvClassP is a FdoPtr on FdoRdbmsOvClassDefinition, provided for convenience.</summary></span>
+<a name="l00218"></a><a class="code" href="_rdbms_ov_class_definition_8h_95c424bcc48087ac80719d81150c51c5.html#95c424bcc48087ac80719d81150c51c5">00218</a> <span class="comment"></span><span class="keyword">typedef</span> FdoPtr<FdoRdbmsOvClassDefinition> <a class="code" href="_rdbms_ov_class_definition_8h_95c424bcc48087ac80719d81150c51c5.html#95c424bcc48087ac80719d81150c51c5">FdoRdbmsOvClassP</a>;
+<a name="l00219"></a>00219
+<a name="l00220"></a>00220 <span class="preprocessor">#endif</span>
+<a name="l00221"></a>00221 <span class="preprocessor"></span>
+<a name="l00222"></a>00222
+</pre></div><!-- footer.html -->
+ <hr>
+ <tr>
+ <td align="right"><font size="-2"><a href="mailto:isd.docs at autodesk.com&subject=FDO%20Provider%20for%20ODBC%20API%20documentation">Comments?</a></font></td>
+ <!-- The logo can go in another cell, when we get one -->
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/ODBC/_rdbms_ov_class_definition_8h.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_class_definition_8h.html?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_rdbms_ov_class_definition_8h.html 2006-12-01 20:39:06+0000
@@ -0,0 +1,82 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<h1>RdbmsOvClassDefinition.h File Reference</h1>
+<p>
+<code>#include <Fdo/Commands/Schema/PhysicalClassMapping.h></code><br>
+<code>#include <Utilities/SchemaMgr/Overrides/TableMappingType.h></code><br>
+<code>#include <<a class="el" href="_rdbms_ov_property_definition_collection_8h-source.html">Rdbms/Override/RdbmsOvPropertyDefinitionCollection.h</a>></code><br>
+<code>#include <<a class="el" href="_rdbms_ov_data_property_definition_8h-source.html">Rdbms/Override/RdbmsOvDataPropertyDefinition.h</a>></code><br>
+<code>#include <<a class="el" href="_rdbms_ov_geometric_property_definition_8h-source.html">Rdbms/Override/RdbmsOvGeometricPropertyDefinition.h</a>></code><br>
+<code>#include <<a class="el" href="_rdbms_ov_object_property_definition_8h-source.html">Rdbms/Override/RdbmsOvObjectPropertyDefinition.h</a>></code><br>
+<code>#include <<a class="el" href="_rdbms_ov_table_8h-source.html">Rdbms/Override/RdbmsOvTable.h</a>></code><br>
+<p>
+Include dependency graph for RdbmsOvClassDefinition.h:<p><center><img src="_rdbms_ov_class_definition_8h__incl.png" border="0" usemap="#RdbmsOvClassDefinition.h_map" alt=""></center>
+<map name="RdbmsOvClassDefinition.h_map">
+<area href="_rdbms_ov_8h.html" shape="rect" coords="652,260,847,287" alt="">
+<area href="_rdbms_ov_property_definition_collection_8h.html" shape="rect" coords="240,159,603,186" alt="">
+<area href="_rdbms_ov_data_property_definition_8h.html" shape="rect" coords="256,210,587,236" alt="">
+<area href="_rdbms_ov_geometric_property_definition_8h.html" shape="rect" coords="239,260,604,287" alt="">
+<area href="_rdbms_ov_object_property_definition_8h.html" shape="rect" coords="251,311,592,338" alt="">
+<area href="_rdbms_ov_table_8h.html" shape="rect" coords="308,362,535,388" alt="">
+</map>
+<p>
+This graph shows which files directly or indirectly include this file:<p><center><img src="_rdbms_ov_class_definition_8h__dep__incl.png" border="0" usemap="#RdbmsOvClassDefinition.hdep_map" alt=""></center>
+<map name="RdbmsOvClassDefinition.hdep_map">
+<area href="_odbc_ov_class_definition_8h.html" shape="rect" coords="245,7,419,34" alt="">
+<area href="_rdbms_ov_class_collection_8h.html" shape="rect" coords="240,58,424,84" alt="">
+<area href="_odbc_ov_class_collection_8h.html" shape="rect" coords="508,7,684,34" alt="">
+<area href="_odbc_ov_physical_schema_mapping_8h.html" shape="rect" coords="768,32,1000,59" alt="">
+<area href="_rdbms_ov_physical_schema_mapping_8h.html" shape="rect" coords="475,58,717,84" alt="">
+</map>
+<p>
+<a href="_rdbms_ov_class_definition_8h-source.html">Go to the source code of this file.</a><table border="0" cellpadding="0" cellspacing="0">
+<tr><td></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">class </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_rdbms_ov_class_definition.html">FdoRdbmsOvClassDefinition</a></td></tr>
+<tr><td class="mdescLeft"> </td><td class="mdescRight">Abstract class defining physical schema overrides for a class definition. <a href="class_fdo_rdbms_ov_class_definition.html#_details">More...</a><br></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">typedef FdoPtr< <a class="el" href="class_fdo_rdbms_ov_class_definition.html">FdoRdbmsOvClassDefinition</a> > </td><td class="memItemRight" valign="bottom"><a class="el" href="_rdbms_ov_class_definition_8h_95c424bcc48087ac80719d81150c51c5.html#95c424bcc48087ac80719d81150c51c5">FdoRdbmsOvClassP</a></td></tr>
+</table>
+<!-- footer.html -->
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/ODBC/_rdbms_ov_class_definition_8h_95c424bcc48087ac80719d81150c51c5.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_class_definition_8h_95c424bcc48087ac80719d81150c51c5.html?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_rdbms_ov_class_definition_8h_95c424bcc48087ac80719d81150c51c5.html 2006-12-01 20:39:06+0000
@@ -0,0 +1,74 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ <li><a href="files.html"><span>Files</span></a></li>
+ </ul></div>
+<div class="nav">
+<a class="el" href="_rdbms_ov_class_definition_8h.html">RdbmsOvClassDefinition.h</a></div>
+<table cellspacing="0" cellpadding="0" border="0">
+ <tr>
+ <td valign="top">
+ <div class="navtab">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="_rdbms_ov_class_definition_8h_95c424bcc48087ac80719d81150c51c5.html#95c424bcc48087ac80719d81150c51c5">FdoRdbmsOvClassP</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="95c424bcc48087ac80719d81150c51c5"></a><!-- doxytag: member="RdbmsOvClassDefinition.h::FdoRdbmsOvClassP" ref="95c424bcc48087ac80719d81150c51c5" args="" --><p>
+<table class="mdTable" cellpadding="2" cellspacing="0">
+ <tr>
+ <td class="mdRow">
+ <table cellpadding="0" cellspacing="0" border="0">
+ <tr>
+ <td class="md" nowrap valign="top">typedef FdoPtr<<a class="el" href="class_fdo_rdbms_ov_class_definition.html">FdoRdbmsOvClassDefinition</a>> <a class="el" href="_rdbms_ov_class_definition_8h_95c424bcc48087ac80719d81150c51c5.html#95c424bcc48087ac80719d81150c51c5">FdoRdbmsOvClassP</a> </td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+<table cellspacing="5" cellpadding="0" border="0">
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+<p>
+Definition at line <a class="el" href="_rdbms_ov_class_definition_8h-source.html#l00218">218</a> of file <a class="el" href="_rdbms_ov_class_definition_8h-source.html">RdbmsOvClassDefinition.h</a>. </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/ODBC/_rdbms_ov_class_definition_8h__dep__incl.map
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_class_definition_8h__dep__incl.map?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_rdbms_ov_class_definition_8h__dep__incl.map 2006-12-01 20:39:06+0000
@@ -0,0 +1,6 @@
+base referer
+rect $_odbc_ov_class_definition_8h.html 245,7 419,34
+rect $_rdbms_ov_class_collection_8h.html 240,58 424,84
+rect $_odbc_ov_class_collection_8h.html 508,7 684,34
+rect $_odbc_ov_physical_schema_mapping_8h.html 768,32 1000,59
+rect $_rdbms_ov_physical_schema_mapping_8h.html 475,58 717,84
Added: trunk/www/docs/ODBC/_rdbms_ov_class_definition_8h__dep__incl.md5
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_class_definition_8h__dep__incl.md5?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_rdbms_ov_class_definition_8h__dep__incl.md5 2006-12-01 20:39:06+0000
@@ -0,0 +1 @@
+0af774233b09ba41f6f7fcb2976b8dfe
\ No newline at end of file
Added: trunk/www/docs/ODBC/_rdbms_ov_class_definition_8h__dep__incl.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_class_definition_8h__dep__incl.png?view=auto&rev=94
Binary file. No diff available.
Added: trunk/www/docs/ODBC/_rdbms_ov_class_definition_8h__incl.map
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_class_definition_8h__incl.map?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_rdbms_ov_class_definition_8h__incl.map 2006-12-01 20:39:06+0000
@@ -0,0 +1,7 @@
+base referer
+rect $_rdbms_ov_8h.html 652,260 847,287
+rect $_rdbms_ov_property_definition_collection_8h.html 240,159 603,186
+rect $_rdbms_ov_data_property_definition_8h.html 256,210 587,236
+rect $_rdbms_ov_geometric_property_definition_8h.html 239,260 604,287
+rect $_rdbms_ov_object_property_definition_8h.html 251,311 592,338
+rect $_rdbms_ov_table_8h.html 308,362 535,388
Added: trunk/www/docs/ODBC/_rdbms_ov_class_definition_8h__incl.md5
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_class_definition_8h__incl.md5?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_rdbms_ov_class_definition_8h__incl.md5 2006-12-01 20:39:06+0000
@@ -0,0 +1 @@
+00c2de9f8448db32d23360463e17fcc0
Added: trunk/www/docs/ODBC/_rdbms_ov_class_definition_8h__incl.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_class_definition_8h__incl.png?view=auto&rev=94
Added: trunk/www/docs/ODBC/_rdbms_ov_column_8h-source.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_column_8h-source.html?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_rdbms_ov_column_8h-source.html 2006-12-01 20:39:06+0000
@@ -0,0 +1,110 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<h1>RdbmsOvColumn.h</h1><a href="_rdbms_ov_column_8h.html">Go to the documentation of this file.</a><div class="fragment"><pre class="fragment"><a name="l00001"></a>00001 <span class="preprocessor">#ifndef FDO_RDBMSOVCOLUMN_H</span>
+<a name="l00002"></a>00002 <span class="preprocessor"></span><span class="preprocessor">#define FDO_RDBMSOVCOLUMN_H</span>
+<a name="l00003"></a>00003 <span class="preprocessor"></span><span class="comment">//</span>
+<a name="l00004"></a>00004 <span class="comment">//</span>
+<a name="l00005"></a>00005 <span class="comment">// Copyright (C) 2004-2006 Autodesk, Inc.</span>
+<a name="l00006"></a>00006 <span class="comment">// </span>
+<a name="l00007"></a>00007 <span class="comment">// This library is free software; you can redistribute it and/or</span>
+<a name="l00008"></a>00008 <span class="comment">// modify it under the terms of version 2.1 of the GNU Lesser</span>
+<a name="l00009"></a>00009 <span class="comment">// General Public License as published by the Free Software Foundation.</span>
+<a name="l00010"></a>00010 <span class="comment">// </span>
+<a name="l00011"></a>00011 <span class="comment">// This library is distributed in the hope that it will be useful,</span>
+<a name="l00012"></a>00012 <span class="comment">// but WITHOUT ANY WARRANTY; without even the implied warranty of</span>
+<a name="l00013"></a>00013 <span class="comment">// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU</span>
+<a name="l00014"></a>00014 <span class="comment">// Lesser General Public License for more details.</span>
+<a name="l00015"></a>00015 <span class="comment">// </span>
+<a name="l00016"></a>00016 <span class="comment">// You should have received a copy of the GNU Lesser General Public</span>
+<a name="l00017"></a>00017 <span class="comment">// License along with this library; if not, write to the Free Software</span>
+<a name="l00018"></a>00018 <span class="comment">// Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA</span>
+<a name="l00019"></a>00019 <span class="comment">//</span>
+<a name="l00020"></a>00020 <span class="comment"></span>
+<a name="l00021"></a>00021 <span class="comment">/// <library></span>
+<a name="l00022"></a>00022 <span class="comment">/// FdoRdbms.lib</span>
+<a name="l00023"></a>00023 <span class="comment">/// </library></span>
+<a name="l00024"></a>00024 <span class="comment"></span>
+<a name="l00025"></a>00025 <span class="preprocessor">#include <Fdo.h></span>
+<a name="l00026"></a>00026 <span class="preprocessor">#include <Fdo/Commands/Schema/PhysicalElementMapping.h></span>
+<a name="l00027"></a>00027 <span class="preprocessor">#include <<a class="code" href="_rdbms_ov_8h.html">Rdbms/Override/RdbmsOv.h</a>></span>
+<a name="l00028"></a>00028 <span class="comment"></span>
+<a name="l00029"></a>00029 <span class="comment">///<summary>Abstract class defining physical schema overrides for a column.</summary></span>
+<a name="l00030"></a><a class="code" href="class_fdo_rdbms_ov_column.html">00030</a> <span class="comment"></span><span class="keyword">class </span><a class="code" href="class_fdo_rdbms_ov_column.html">FdoRdbmsOvColumn</a> : <span class="keyword">public</span> FdoPhysicalElementMapping
+<a name="l00031"></a>00031 {
+<a name="l00032"></a>00032 <span class="keyword">public</span>:
+<a name="l00034"></a>00034 <span class="comment">//DOM-IGNORE-BEGIN</span>
+<a name="l00035"></a>00035 <span class="comment">// Sets the parent of this object. Not part of the API.</span>
+<a name="l00036"></a>00036 <a class="code" href="_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html#9b6afd7f3f2f73a361844d7bff18436f">FDORDBMS_OV_API</a> <span class="keywordtype">void</span> <a class="code" href="class_fdo_rdbms_ov_column_495202f59e8ec336cc6d5bc66384243f.html#495202f59e8ec336cc6d5bc66384243f">SetParent</a>(FdoPhysicalElementMapping* value);
+<a name="l00038"></a>00038 <span class="comment">// Serialize this override to XML.</span>
+<a name="l00039"></a>00039 <a class="code" href="_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html#9b6afd7f3f2f73a361844d7bff18436f">FDORDBMS_OV_API</a> <span class="keyword">virtual</span> <span class="keywordtype">void</span> <a class="code" href="class_fdo_rdbms_ov_column_799c09fe92f7297b6d9c6090513c0fed.html#799c09fe92f7297b6d9c6090513c0fed">_writeXml</a>(FdoXmlWriter* xmlWriter, <span class="keyword">const</span> FdoXmlFlags* flags);
+<a name="l00041"></a>00041 <span class="keyword">protected</span>:
+<a name="l00042"></a>00042 <a class="code" href="_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html#9b6afd7f3f2f73a361844d7bff18436f">FDORDBMS_OV_API</a> <a class="code" href="class_fdo_rdbms_ov_column_bde6620b08ab40c64ab8cff0c42087fa.html#bde6620b08ab40c64ab8cff0c42087fa">FdoRdbmsOvColumn</a>();
+<a name="l00043"></a>00043 <a class="code" href="_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html#9b6afd7f3f2f73a361844d7bff18436f">FDORDBMS_OV_API</a> <a class="code" href="class_fdo_rdbms_ov_column_bde6620b08ab40c64ab8cff0c42087fa.html#bde6620b08ab40c64ab8cff0c42087fa">FdoRdbmsOvColumn</a>(FdoString* name);
+<a name="l00044"></a>00044 <a class="code" href="_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html#9b6afd7f3f2f73a361844d7bff18436f">FDORDBMS_OV_API</a> <span class="keyword">virtual</span> <a class="code" href="class_fdo_rdbms_ov_column_f0fe1927d526a04b0f2443b40e6a467b.html#f0fe1927d526a04b0f2443b40e6a467b">~FdoRdbmsOvColumn</a>();
+<a name="l00047"></a>00047 <span class="comment">// Serialize provider-specific parts of this override to XML.</span>
+<a name="l00048"></a>00048 <a class="code" href="_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html#9b6afd7f3f2f73a361844d7bff18436f">FDORDBMS_OV_API</a> <span class="keyword">virtual</span> <span class="keywordtype">void</span> <a class="code" href="class_fdo_rdbms_ov_column_ca382d01afaa99a48748a1aa4a507ca5.html#ca382d01afaa99a48748a1aa4a507ca5">_writeXmlContents</a>(FdoXmlWriter* xmlWriter, <span class="keyword">const</span> FdoXmlFlags* flags);
+<a name="l00050"></a>00050 <span class="comment">// Initialize this element from its XML attributes</span>
+<a name="l00051"></a>00051 <a class="code" href="_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html#9b6afd7f3f2f73a361844d7bff18436f">FDORDBMS_OV_API</a> <span class="keyword">virtual</span> <span class="keywordtype">void</span> <a class="code" href="class_fdo_rdbms_ov_column_9d822ac4ab67ca84c513507701c83fdf.html#9d822ac4ab67ca84c513507701c83fdf">InitFromXml</a>(FdoXmlSaxContext* pContext, FdoXmlAttributeCollection* attrs);
+<a name="l00053"></a>00053 <a class="code" href="_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html#9b6afd7f3f2f73a361844d7bff18436f">FDORDBMS_OV_API</a> <span class="keyword">virtual</span> FdoXmlSaxHandler* <a class="code" href="class_fdo_rdbms_ov_column_ff4bd29c7e2627a70fb3b494cb316c0b.html#ff4bd29c7e2627a70fb3b494cb316c0b">XmlStartElement</a>(
+<a name="l00054"></a>00054 FdoXmlSaxContext* context,
+<a name="l00055"></a>00055 FdoString* uri,
+<a name="l00056"></a>00056 FdoString* name,
+<a name="l00057"></a>00057 FdoString* qname,
+<a name="l00058"></a>00058 FdoXmlAttributeCollection* atts
+<a name="l00059"></a>00059 );
+<a name="l00060"></a>00060 <span class="comment">//DOM-IGNORE-END</span>
+<a name="l00062"></a>00062 <span class="keyword">private</span>:
+<a name="l00063"></a>00063 };
+<a name="l00064"></a>00064 <span class="comment"></span>
+<a name="l00065"></a>00065 <span class="comment">///<summary>FdoRdbmsOvColumnP is a FdoPtr on FdoRdbmsOvColumn, provided for convenience.</summary></span>
+<a name="l00066"></a><a class="code" href="_rdbms_ov_column_8h_be8c4edc8774e74cb12d266f13e76f07.html#be8c4edc8774e74cb12d266f13e76f07">00066</a> <span class="comment"></span><span class="keyword">typedef</span> FdoPtr<FdoRdbmsOvColumn> <a class="code" href="_rdbms_ov_column_8h_be8c4edc8774e74cb12d266f13e76f07.html#be8c4edc8774e74cb12d266f13e76f07">FdoRdbmsOvColumnP</a>;
+<a name="l00069"></a>00069
+<a name="l00070"></a>00070 <span class="preprocessor">#endif</span>
+<a name="l00071"></a>00071 <span class="preprocessor"></span>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/ODBC/_rdbms_ov_column_8h.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_column_8h.html?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_rdbms_ov_column_8h.html 2006-12-01 20:39:06+0000
@@ -0,0 +1,73 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<h1>RdbmsOvColumn.h File Reference</h1>
+<p>
+<code>#include <Fdo.h></code><br>
+<code>#include <Fdo/Commands/Schema/PhysicalElementMapping.h></code><br>
+<code>#include <<a class="el" href="_rdbms_ov_8h-source.html">Rdbms/Override/RdbmsOv.h</a>></code><br>
+<p>
+Include dependency graph for RdbmsOvColumn.h:<p><center><img src="_rdbms_ov_column_8h__incl.png" border="0" usemap="#RdbmsOvColumn.h_map" alt=""></center>
+<map name="RdbmsOvColumn.h_map">
+<area href="_rdbms_ov_8h.html" shape="rect" coords="267,108,462,135" alt="">
+</map>
+<p>
+This graph shows which files directly or indirectly include this file:<p><center><img src="_rdbms_ov_column_8h__dep__incl.png" border="0" usemap="#RdbmsOvColumn.hdep_map" alt=""></center>
+<map name="RdbmsOvColumn.hdep_map">
+<area href="_odbc_ov_column_8h.html" shape="rect" coords="247,7,375,34" alt="">
+<area href="_rdbms_ov_data_property_definition_8h.html" shape="rect" coords="196,58,425,84" alt="">
+<area href="_odbc_ov_data_property_definition_8h.html" shape="rect" coords="473,7,692,34" alt="">
+<area href="_odbc_ov_class_definition_8h.html" shape="rect" coords="747,7,920,34" alt="">
+<area href="_rdbms_ov_class_definition_8h.html" shape="rect" coords="492,58,673,84" alt="">
+<area href="_rdbms_ov_class_collection_8h.html" shape="rect" coords="741,58,925,84" alt="">
+</map>
+<p>
+<a href="_rdbms_ov_column_8h-source.html">Go to the source code of this file.</a><table border="0" cellpadding="0" cellspacing="0">
+<tr><td></td></tr>
+<tr><td colspan="2"><br><h2>Classes</h2></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">class </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_rdbms_ov_column.html">FdoRdbmsOvColumn</a></td></tr>
+<tr><td class="mdescLeft"> </td><td class="mdescRight">Abstract class defining physical schema overrides for a column. <a href="class_fdo_rdbms_ov_column.html#_details">More...</a><br></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">typedef FdoPtr< <a class="el" href="class_fdo_rdbms_ov_column.html">FdoRdbmsOvColumn</a> > </td><td class="memItemRight" valign="bottom"><a class="el" href="_rdbms_ov_column_8h_be8c4edc8774e74cb12d266f13e76f07.html#be8c4edc8774e74cb12d266f13e76f07">FdoRdbmsOvColumnP</a></td></tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/ODBC/_rdbms_ov_column_8h__dep__incl.map
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_column_8h__dep__incl.map?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_rdbms_ov_column_8h__dep__incl.map 2006-12-01 20:39:06+0000
@@ -0,0 +1,7 @@
+base referer
+rect $_odbc_ov_column_8h.html 247,7 375,34
+rect $_rdbms_ov_data_property_definition_8h.html 196,58 425,84
+rect $_odbc_ov_data_property_definition_8h.html 473,7 692,34
+rect $_odbc_ov_class_definition_8h.html 747,7 920,34
+rect $_rdbms_ov_class_definition_8h.html 492,58 673,84
+rect $_rdbms_ov_class_collection_8h.html 741,58 925,84
Added: trunk/www/docs/ODBC/_rdbms_ov_column_8h__dep__incl.md5
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_column_8h__dep__incl.md5?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_rdbms_ov_column_8h__dep__incl.md5 2006-12-01 20:39:06+0000
@@ -0,0 +1 @@
+c753c974175bc1a2f520ebd209027337
Added: trunk/www/docs/ODBC/_rdbms_ov_column_8h__dep__incl.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_column_8h__dep__incl.png?view=auto&rev=94
Added: trunk/www/docs/ODBC/_rdbms_ov_column_8h__incl.map
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_column_8h__incl.map?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_rdbms_ov_column_8h__incl.map 2006-12-01 20:39:06+0000
@@ -0,0 +1,2 @@
+base referer
+rect $_rdbms_ov_8h.html 267,108 462,135
Added: trunk/www/docs/ODBC/_rdbms_ov_column_8h__incl.md5
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_column_8h__incl.md5?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_rdbms_ov_column_8h__incl.md5 2006-12-01 20:39:06+0000
@@ -0,0 +1 @@
+b3882743b73b6da5152b0601164e49e2
Added: trunk/www/docs/ODBC/_rdbms_ov_column_8h__incl.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_column_8h__incl.png?view=auto&rev=94
Added: trunk/www/docs/ODBC/_rdbms_ov_column_8h_be8c4edc8774e74cb12d266f13e76f07.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_column_8h_be8c4edc8774e74cb12d266f13e76f07.html?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_rdbms_ov_column_8h_be8c4edc8774e74cb12d266f13e76f07.html 2006-12-01 20:39:06+0000
@@ -0,0 +1,74 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="nav">
+<a class="el" href="_rdbms_ov_column_8h.html">RdbmsOvColumn.h</a></div>
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="_rdbms_ov_column_8h_be8c4edc8774e74cb12d266f13e76f07.html#be8c4edc8774e74cb12d266f13e76f07">FdoRdbmsOvColumnP</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="be8c4edc8774e74cb12d266f13e76f07"></a><!-- doxytag: member="RdbmsOvColumn.h::FdoRdbmsOvColumnP" ref="be8c4edc8774e74cb12d266f13e76f07" args="" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">typedef FdoPtr<<a class="el" href="class_fdo_rdbms_ov_column.html">FdoRdbmsOvColumn</a>> <a class="el" href="_rdbms_ov_column_8h_be8c4edc8774e74cb12d266f13e76f07.html#be8c4edc8774e74cb12d266f13e76f07">FdoRdbmsOvColumnP</a> </td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+<p>
+Definition at line <a class="el" href="_rdbms_ov_column_8h-source.html#l00066">66</a> of file <a class="el" href="_rdbms_ov_column_8h-source.html">RdbmsOvColumn.h</a>. </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <table width="100%" border="0">
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/ODBC/_rdbms_ov_data_property_definition_8h-source.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_data_property_definition_8h-source.html?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_rdbms_ov_data_property_definition_8h-source.html 2006-12-01 20:39:06+0000
@@ -0,0 +1,96 @@
+<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN" "http://www.w3.org/TR/html4/loose.dtd">
+<html>
+ <head>
+ <meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
+ <title>OSGeo FDO Provider for ODBC API Reference</title>
+ <link href="custom.css" rel="stylesheet" type="text/css">
+ <link href="tabs.css" rel="stylesheet" type="text/css">
+ </head>
+ <body bgcolor="#FFFFFF">
+ <tr>
+ <td><b>API Reference<b></td>
+ <td align="right"><b>OSGeo FDO Provider for ODBC<b></td>
+ </tr>
+ </table>
+<!-- End of: header.html -->
+<!-- Generated by Doxygen 1.4.6-NO -->
+<div class="tabs">
+ <ul>
+ <li><a href="main.html"><span>Main Page</span></a></li>
+ <li><a href="classes.html"><span>Classes</span></a></li>
+ <li id="current"><a href="files.html"><span>Files</span></a></li>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ <li><a href="files.html"><span>File List</span></a></li>
+ <li><a href="globals.html"><span>File Members</span></a></li>
+ </ul></div>
+<h1>RdbmsOvDataPropertyDefinition.h</h1><a href="_rdbms_ov_data_property_definition_8h.html">Go to the documentation of this file.</a><div class="fragment"><pre class="fragment"><a name="l00001"></a>00001 <span class="preprocessor">#ifndef FDO_RDBMSOVDATAPROPERTYDEFINITION_H</span>
+<a name="l00002"></a>00002 <span class="preprocessor"></span><span class="preprocessor">#define FDO_RDBMSOVDATAPROPERTYDEFINITION_H</span>
+<a name="l00025"></a>00025 <span class="preprocessor">#include <<a class="code" href="_rdbms_ov_8h.html">Rdbms/Override/RdbmsOv.h</a>></span>
+<a name="l00026"></a>00026 <span class="preprocessor">#include <<a class="code" href="_rdbms_ov_column_8h.html">Rdbms/Override/RdbmsOvColumn.h</a>></span>
+<a name="l00027"></a>00027 <span class="preprocessor">#include <<a class="code" href="_rdbms_ov_property_definition_8h.html">Rdbms/Override/RdbmsOvPropertyDefinition.h</a>></span>
+<a name="l00029"></a>00029 <span class="comment">///<summary>Abstract class defining physical schema overrides for a data property</span>
+<a name="l00030"></a>00030 <span class="comment">///definition.</summary></span>
+<a name="l00031"></a><a class="code" href="class_fdo_rdbms_ov_data_property_definition.html">00031</a> <span class="comment"></span><span class="keyword">class </span><a class="code" href="class_fdo_rdbms_ov_data_property_definition.html">FdoRdbmsOvDataPropertyDefinition</a> : <span class="keyword">public</span> <span class="keyword">virtual</span> <a class="code" href="class_fdo_rdbms_ov_property_definition.html">FdoRdbmsOvPropertyDefinition</a>
+<a name="l00032"></a>00032 {
+<a name="l00033"></a>00033 <span class="keyword">public</span>:<span class="comment"></span>
+<a name="l00034"></a>00034 <span class="comment"> ///<summary>Gets the column override</summary></span>
+<a name="l00035"></a>00035 <span class="comment"> /// <returns>Returns FdoRdbmsOvColumn</returns></span>
+<a name="l00036"></a>00036 <span class="comment"></span> <a class="code" href="_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html#9b6afd7f3f2f73a361844d7bff18436f">FDORDBMS_OV_API</a> <a class="code" href="class_fdo_rdbms_ov_column.html">FdoRdbmsOvColumn</a>* <a class="code" href="class_fdo_rdbms_ov_data_property_definition_afa52c3c68762992a3a4c884b539fc36.html#afa52c3c68762992a3a4c884b539fc36">GetColumn</a>();
+<a name="l00038"></a>00038 <span class="keyword">protected</span>:
+<a name="l00039"></a>00039 <a class="code" href="_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html#9b6afd7f3f2f73a361844d7bff18436f">FDORDBMS_OV_API</a> <a class="code" href="class_fdo_rdbms_ov_data_property_definition_956e7c893d7604567bee59fea598372e.html#956e7c893d7604567bee59fea598372e">FdoRdbmsOvDataPropertyDefinition</a>();
+<a name="l00040"></a>00040 <a class="code" href="_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html#9b6afd7f3f2f73a361844d7bff18436f">FDORDBMS_OV_API</a> <a class="code" href="class_fdo_rdbms_ov_data_property_definition_956e7c893d7604567bee59fea598372e.html#956e7c893d7604567bee59fea598372e">FdoRdbmsOvDataPropertyDefinition</a>(FdoString* name);
+<a name="l00041"></a>00041 <a class="code" href="_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html#9b6afd7f3f2f73a361844d7bff18436f">FDORDBMS_OV_API</a> <span class="keyword">virtual</span> <a class="code" href="class_fdo_rdbms_ov_data_property_definition_6c9bae4b23c707051c437d37fdaf5724.html#6c9bae4b23c707051c437d37fdaf5724">~FdoRdbmsOvDataPropertyDefinition</a>();
+<a name="l00043"></a>00043 <span class="comment">// Sets the column override.</span>
+<a name="l00044"></a>00044 <a class="code" href="_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html#9b6afd7f3f2f73a361844d7bff18436f">FDORDBMS_OV_API</a> <span class="keywordtype">void</span> <a class="code" href="class_fdo_rdbms_ov_data_property_definition_181918f49709e7f5eb3fc15f8ce54b6a.html#181918f49709e7f5eb3fc15f8ce54b6a">SetColumn</a>(<a class="code" href="class_fdo_rdbms_ov_column.html">FdoRdbmsOvColumn</a> *column);
+<a name="l00046"></a>00046 <span class="comment">// Serialize provider-specific parts of this override to XML.</span>
+<a name="l00047"></a>00047 <a class="code" href="_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html#9b6afd7f3f2f73a361844d7bff18436f">FDORDBMS_OV_API</a> <span class="keyword">virtual</span> <span class="keywordtype">void</span> <a class="code" href="class_fdo_rdbms_ov_data_property_definition_f28f70532d721f4d8a7ec630b7c4bc18.html#f28f70532d721f4d8a7ec630b7c4bc18">_writeXmlContents</a>(FdoXmlWriter* xmlWriter, <span class="keyword">const</span> FdoXmlFlags* flags);
+<a name="l00049"></a>00049 <span class="keyword">private</span>:
+<a name="l00050"></a>00050 <a class="code" href="_rdbms_ov_column_8h_be8c4edc8774e74cb12d266f13e76f07.html#be8c4edc8774e74cb12d266f13e76f07">FdoRdbmsOvColumnP</a> mColumn;
+<a name="l00051"></a>00051 };
+<a name="l00053"></a>00053 <span class="comment">///<summary>FdoRdbmsOvDataPropertyP is a FdoPtr on FdoRdbmsOvDataPropertyDefinition, provided for convenience.</summary></span>
+<a name="l00054"></a><a class="code" href="_rdbms_ov_data_property_definition_8h_fb7f707266f7220c654ef63b0248531c.html#fb7f707266f7220c654ef63b0248531c">00054</a> <span class="comment"></span><span class="keyword">typedef</span> FdoPtr<FdoRdbmsOvDataPropertyDefinition> <a class="code" href="_rdbms_ov_data_property_definition_8h_fb7f707266f7220c654ef63b0248531c.html#fb7f707266f7220c654ef63b0248531c">FdoRdbmsOvDataPropertyP</a>;
+<a name="l00056"></a>00056 <span class="preprocessor">#endif</span>
+<a name="l00057"></a>00057 <span class="preprocessor"></span>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/ODBC/_rdbms_ov_data_property_definition_8h.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_data_property_definition_8h.html?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_rdbms_ov_data_property_definition_8h.html 2006-12-01 20:39:06+0000
@@ -0,0 +1,73 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<h1>RdbmsOvDataPropertyDefinition.h File Reference</h1>
+<p>
+<code>#include <<a class="el" href="_rdbms_ov_column_8h-source.html">Rdbms/Override/RdbmsOvColumn.h</a>></code><br>
+<code>#include <<a class="el" href="_rdbms_ov_property_definition_8h-source.html">Rdbms/Override/RdbmsOvPropertyDefinition.h</a>></code><br>
+<p>
+Include dependency graph for RdbmsOvDataPropertyDefinition.h:<p><center><img src="_rdbms_ov_data_property_definition_8h__incl.png" border="0" usemap="#RdbmsOvDataPropertyDefinition.h_map" alt=""></center>
+<map name="RdbmsOvDataPropertyDefinition.h_map">
+<area href="_rdbms_ov_8h.html" shape="rect" coords="708,108,903,135" alt="">
+<area href="_rdbms_ov_column_8h.html" shape="rect" coords="315,57,557,84" alt="">
+<area href="_rdbms_ov_property_definition_8h.html" shape="rect" coords="285,159,587,185" alt="">
+</map>
+<p>
+This graph shows which files directly or indirectly include this file:<p><center><img src="_rdbms_ov_data_property_definition_8h__dep__incl.png" border="0" usemap="#RdbmsOvDataPropertyDefinition.hdep_map" alt=""></center>
+<map name="RdbmsOvDataPropertyDefinition.hdep_map">
+<area href="_odbc_ov_data_property_definition_8h.html" shape="rect" coords="284,7,503,34" alt="">
+<area href="_rdbms_ov_class_definition_8h.html" shape="rect" coords="303,58,484,84" alt="">
+<area href="_odbc_ov_class_definition_8h.html" shape="rect" coords="557,7,731,34" alt="">
+<area href="_rdbms_ov_class_collection_8h.html" shape="rect" coords="552,58,736,84" alt="">
+</map>
+<p>
+<a href="_rdbms_ov_data_property_definition_8h-source.html">Go to the source code of this file.</a><table border="0" cellpadding="0" cellspacing="0">
+<tr><td></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">class </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_rdbms_ov_data_property_definition.html">FdoRdbmsOvDataPropertyDefinition</a></td></tr>
+<tr><td class="mdescLeft"> </td><td class="mdescRight">Abstract class defining physical schema overrides for a data property definition. <a href="class_fdo_rdbms_ov_data_property_definition.html#_details">More...</a><br></td></tr>
+<tr><td colspan="2"><br><h2>Typedefs</h2></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">typedef FdoPtr< <a class="el" href="class_fdo_rdbms_ov_data_property_definition.html">FdoRdbmsOvDataPropertyDefinition</a> > </td><td class="memItemRight" valign="bottom"><a class="el" href="_rdbms_ov_data_property_definition_8h_fb7f707266f7220c654ef63b0248531c.html#fb7f707266f7220c654ef63b0248531c">FdoRdbmsOvDataPropertyP</a></td></tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/ODBC/_rdbms_ov_data_property_definition_8h__dep__incl.map
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_data_property_definition_8h__dep__incl.map?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_rdbms_ov_data_property_definition_8h__dep__incl.map 2006-12-01 20:39:06+0000
@@ -0,0 +1,5 @@
+base referer
+rect $_odbc_ov_data_property_definition_8h.html 284,7 503,34
+rect $_rdbms_ov_class_definition_8h.html 303,58 484,84
+rect $_odbc_ov_class_definition_8h.html 557,7 731,34
+rect $_rdbms_ov_class_collection_8h.html 552,58 736,84
Added: trunk/www/docs/ODBC/_rdbms_ov_data_property_definition_8h__dep__incl.md5
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_data_property_definition_8h__dep__incl.md5?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_rdbms_ov_data_property_definition_8h__dep__incl.md5 2006-12-01 20:39:06+0000
@@ -0,0 +1 @@
+24f2c52e496e3b6abb25648d3458961d
Added: trunk/www/docs/ODBC/_rdbms_ov_data_property_definition_8h__dep__incl.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_data_property_definition_8h__dep__incl.png?view=auto&rev=94
Added: trunk/www/docs/ODBC/_rdbms_ov_data_property_definition_8h__incl.map
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_data_property_definition_8h__incl.map?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_rdbms_ov_data_property_definition_8h__incl.map 2006-12-01 20:39:06+0000
@@ -0,0 +1,4 @@
+base referer
+rect $_rdbms_ov_8h.html 708,108 903,135
+rect $_rdbms_ov_column_8h.html 315,57 557,84
+rect $_rdbms_ov_property_definition_8h.html 285,159 587,185
Added: trunk/www/docs/ODBC/_rdbms_ov_data_property_definition_8h__incl.md5
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_data_property_definition_8h__incl.md5?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_rdbms_ov_data_property_definition_8h__incl.md5 2006-12-01 20:39:06+0000
@@ -0,0 +1 @@
+10e9258da9a0295fe3af5e69ab343f0d
Added: trunk/www/docs/ODBC/_rdbms_ov_data_property_definition_8h__incl.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_data_property_definition_8h__incl.png?view=auto&rev=94
Added: trunk/www/docs/ODBC/_rdbms_ov_data_property_definition_8h_fb7f707266f7220c654ef63b0248531c.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_data_property_definition_8h_fb7f707266f7220c654ef63b0248531c.html?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_rdbms_ov_data_property_definition_8h_fb7f707266f7220c654ef63b0248531c.html 2006-12-01 20:39:06+0000
@@ -0,0 +1,74 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="nav">
+<a class="el" href="_rdbms_ov_data_property_definition_8h.html">RdbmsOvDataPropertyDefinition.h</a></div>
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="_rdbms_ov_data_property_definition_8h_fb7f707266f7220c654ef63b0248531c.html#fb7f707266f7220c654ef63b0248531c">FdoRdbmsOvDataPropertyP</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="fb7f707266f7220c654ef63b0248531c"></a><!-- doxytag: member="RdbmsOvDataPropertyDefinition.h::FdoRdbmsOvDataPropertyP" ref="fb7f707266f7220c654ef63b0248531c" args="" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">typedef FdoPtr<<a class="el" href="class_fdo_rdbms_ov_data_property_definition.html">FdoRdbmsOvDataPropertyDefinition</a>> <a class="el" href="_rdbms_ov_data_property_definition_8h_fb7f707266f7220c654ef63b0248531c.html#fb7f707266f7220c654ef63b0248531c">FdoRdbmsOvDataPropertyP</a> </td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+<p>
+Definition at line <a class="el" href="_rdbms_ov_data_property_definition_8h-source.html#l00054">54</a> of file <a class="el" href="_rdbms_ov_data_property_definition_8h-source.html">RdbmsOvDataPropertyDefinition.h</a>. </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/ODBC/_rdbms_ov_geometric_column_8h-source.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_geometric_column_8h-source.html?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_rdbms_ov_geometric_column_8h-source.html 2006-12-01 20:39:06+0000
@@ -0,0 +1,106 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<h1>RdbmsOvGeometricColumn.h</h1><a href="_rdbms_ov_geometric_column_8h.html">Go to the documentation of this file.</a><div class="fragment"><pre class="fragment"><a name="l00001"></a>00001 <span class="preprocessor">#ifndef FDO_RDBMSOVGEOMETRICCOLUMN_H</span>
+<a name="l00002"></a>00002 <span class="preprocessor"></span><span class="preprocessor">#define FDO_RDBMSOVGEOMETRICCOLUMN_H</span>
+<a name="l00025"></a>00025 <span class="preprocessor">#include <Fdo/Commands/Schema/PhysicalElementMapping.h></span>
+<a name="l00026"></a>00026 <span class="preprocessor">#include <<a class="code" href="_rdbms_ov_8h.html">Rdbms/Override/RdbmsOv.h</a>></span>
+<a name="l00027"></a>00027 <span class="comment"></span>
+<a name="l00028"></a>00028 <span class="comment">///<summary>Abstract base class for defining physical schema overrides for a </span>
+<a name="l00029"></a>00029 <span class="comment">///geometric column.</span>
+<a name="l00030"></a>00030 <span class="comment">///</summary></span>
+<a name="l00031"></a><a class="code" href="class_fdo_rdbms_ov_geometric_column.html">00031</a> <span class="comment"></span><span class="keyword">class </span><a class="code" href="class_fdo_rdbms_ov_geometric_column.html">FdoRdbmsOvGeometricColumn</a> : <span class="keyword">public</span> FdoPhysicalElementMapping
+<a name="l00036"></a>00036 <span class="comment">// Sets the parent of this object. Not part of the API.</span>
+<a name="l00037"></a>00037 <a class="code" href="_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html#9b6afd7f3f2f73a361844d7bff18436f">FDORDBMS_OV_API</a> <span class="keywordtype">void</span> <a class="code" href="class_fdo_rdbms_ov_geometric_column_10322c8c00d86b3e8b70aa61b39918f3.html#10322c8c00d86b3e8b70aa61b39918f3">SetParent</a>(FdoPhysicalElementMapping* value);
+<a name="l00039"></a>00039 <span class="comment">// Serialize this property to XML. Not part of the API.</span>
+<a name="l00040"></a>00040 <a class="code" href="_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html#9b6afd7f3f2f73a361844d7bff18436f">FDORDBMS_OV_API</a> <span class="keyword">virtual</span> <span class="keywordtype">void</span> <a class="code" href="class_fdo_rdbms_ov_geometric_column_894893cf60f212d0e956464549d0840c.html#894893cf60f212d0e956464549d0840c">_writeXml</a>(FdoXmlWriter* xmlWriter, <span class="keyword">const</span> FdoXmlFlags* flags);
+<a name="l00042"></a>00042 <span class="comment">//DOM-IGNORE-END</span>
+<a name="l00044"></a>00044 <span class="keyword">protected</span>:
+<a name="l00045"></a>00045 <a class="code" href="_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html#9b6afd7f3f2f73a361844d7bff18436f">FDORDBMS_OV_API</a> <a class="code" href="class_fdo_rdbms_ov_geometric_column_aee998c9f9b97f772cb42b2ad6b90394.html#aee998c9f9b97f772cb42b2ad6b90394">FdoRdbmsOvGeometricColumn</a>();
+<a name="l00046"></a>00046 <a class="code" href="_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html#9b6afd7f3f2f73a361844d7bff18436f">FDORDBMS_OV_API</a> <a class="code" href="class_fdo_rdbms_ov_geometric_column_aee998c9f9b97f772cb42b2ad6b90394.html#aee998c9f9b97f772cb42b2ad6b90394">FdoRdbmsOvGeometricColumn</a>(FdoString* name);
+<a name="l00047"></a>00047 <a class="code" href="_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html#9b6afd7f3f2f73a361844d7bff18436f">FDORDBMS_OV_API</a> <span class="keyword">virtual</span> <a class="code" href="class_fdo_rdbms_ov_geometric_column_f905ae8553efaf4e8372635c5bfbc349.html#f905ae8553efaf4e8372635c5bfbc349">~FdoRdbmsOvGeometricColumn</a>();
+<a name="l00049"></a>00049 <span class="comment">// Serialize provider-specific parts of this override to XML</span>
+<a name="l00050"></a>00050 <a class="code" href="_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html#9b6afd7f3f2f73a361844d7bff18436f">FDORDBMS_OV_API</a> <span class="keyword">virtual</span> <span class="keywordtype">void</span> <a class="code" href="class_fdo_rdbms_ov_geometric_column_0b34b873e3a81534cefc3c5babc28579.html#0b34b873e3a81534cefc3c5babc28579">_writeXmlContents</a>(FdoXmlWriter* xmlWriter, <span class="keyword">const</span> FdoXmlFlags* flags);
+<a name="l00052"></a>00052 <a class="code" href="_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html#9b6afd7f3f2f73a361844d7bff18436f">FDORDBMS_OV_API</a> <span class="keyword">virtual</span> FdoXmlSaxHandler* <a class="code" href="class_fdo_rdbms_ov_geometric_column_2ce5767658a73331eb5830a67f7b9cc7.html#2ce5767658a73331eb5830a67f7b9cc7">XmlStartElement</a>(
+<a name="l00053"></a>00053 FdoXmlSaxContext* context,
+<a name="l00054"></a>00054 FdoString* uri,
+<a name="l00055"></a>00055 FdoString* name,
+<a name="l00056"></a>00056 FdoString* qname,
+<a name="l00057"></a>00057 FdoXmlAttributeCollection* atts
+<a name="l00058"></a>00058 );
+<a name="l00061"></a>00061 };
+<a name="l00062"></a>00062 <span class="comment"></span>
+<a name="l00063"></a>00063 <span class="comment">///<summary>FdoRdbmsOvGeometricColumnP is a FdoPtr on FdoRdbmsOvGeometricColumn, provided for convenience.</summary></span>
+<a name="l00064"></a><a class="code" href="_rdbms_ov_geometric_column_8h_6041d0e4455167520365a3628c75f7c1.html#6041d0e4455167520365a3628c75f7c1">00064</a> <span class="comment"></span><span class="keyword">typedef</span> FdoPtr<FdoRdbmsOvGeometricColumn> <a class="code" href="_rdbms_ov_geometric_column_8h_6041d0e4455167520365a3628c75f7c1.html#6041d0e4455167520365a3628c75f7c1">FdoRdbmsOvGeometricColumnP</a>;
+<a name="l00066"></a>00066 <span class="preprocessor">#endif</span>
+<a name="l00067"></a>00067 <span class="preprocessor"></span>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/ODBC/_rdbms_ov_geometric_column_8h.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_geometric_column_8h.html?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_rdbms_ov_geometric_column_8h.html 2006-12-01 20:39:06+0000
@@ -0,0 +1,69 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<h1>RdbmsOvGeometricColumn.h File Reference</h1>
+<p>
+<p>
+Include dependency graph for RdbmsOvGeometricColumn.h:<p><center><img src="_rdbms_ov_geometric_column_8h__incl.png" border="0" usemap="#RdbmsOvGeometricColumn.h_map" alt=""></center>
+<map name="RdbmsOvGeometricColumn.h_map">
+<area href="_rdbms_ov_8h.html" shape="rect" coords="328,58,523,84" alt="">
+</map>
+<p>
+This graph shows which files directly or indirectly include this file:<p><center><img src="_rdbms_ov_geometric_column_8h__dep__incl.png" border="0" usemap="#RdbmsOvGeometricColumn.hdep_map" alt=""></center>
+<map name="RdbmsOvGeometricColumn.hdep_map">
+<area href="_rdbms_ov_geometric_property_definition_8h.html" shape="rect" coords="259,32,520,59" alt="">
+<area href="_odbc_ov_geometric_property_definition_8h.html" shape="rect" coords="569,7,823,34" alt="">
+<area href="_rdbms_ov_class_definition_8h.html" shape="rect" coords="605,58,787,84" alt="">
+</map>
+<p>
+<a href="_rdbms_ov_geometric_column_8h-source.html">Go to the source code of this file.</a><table border="0" cellpadding="0" cellspacing="0">
+<tr><td></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">class </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_rdbms_ov_geometric_column.html">FdoRdbmsOvGeometricColumn</a></td></tr>
+<tr><td class="mdescLeft"> </td><td class="mdescRight">Abstract base class for defining physical schema overrides for a geometric column. /summary>. <a href="class_fdo_rdbms_ov_geometric_column.html#_details">More...</a><br></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">typedef FdoPtr< <a class="el" href="class_fdo_rdbms_ov_geometric_column.html">FdoRdbmsOvGeometricColumn</a> > </td><td class="memItemRight" valign="bottom"><a class="el" href="_rdbms_ov_geometric_column_8h_6041d0e4455167520365a3628c75f7c1.html#6041d0e4455167520365a3628c75f7c1">FdoRdbmsOvGeometricColumnP</a></td></tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/ODBC/_rdbms_ov_geometric_column_8h_6041d0e4455167520365a3628c75f7c1.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_geometric_column_8h_6041d0e4455167520365a3628c75f7c1.html?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_rdbms_ov_geometric_column_8h_6041d0e4455167520365a3628c75f7c1.html 2006-12-01 20:39:06+0000
@@ -0,0 +1,74 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="nav">
+<a class="el" href="_rdbms_ov_geometric_column_8h.html">RdbmsOvGeometricColumn.h</a></div>
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="_rdbms_ov_geometric_column_8h_6041d0e4455167520365a3628c75f7c1.html#6041d0e4455167520365a3628c75f7c1">FdoRdbmsOvGeometricColumnP</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="6041d0e4455167520365a3628c75f7c1"></a><!-- doxytag: member="RdbmsOvGeometricColumn.h::FdoRdbmsOvGeometricColumnP" ref="6041d0e4455167520365a3628c75f7c1" args="" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">typedef FdoPtr<<a class="el" href="class_fdo_rdbms_ov_geometric_column.html">FdoRdbmsOvGeometricColumn</a>> <a class="el" href="_rdbms_ov_geometric_column_8h_6041d0e4455167520365a3628c75f7c1.html#6041d0e4455167520365a3628c75f7c1">FdoRdbmsOvGeometricColumnP</a> </td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+<p>
+Definition at line <a class="el" href="_rdbms_ov_geometric_column_8h-source.html#l00064">64</a> of file <a class="el" href="_rdbms_ov_geometric_column_8h-source.html">RdbmsOvGeometricColumn.h</a>. </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/ODBC/_rdbms_ov_geometric_column_8h__dep__incl.map
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_geometric_column_8h__dep__incl.map?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_rdbms_ov_geometric_column_8h__dep__incl.map 2006-12-01 20:39:06+0000
@@ -0,0 +1,4 @@
+base referer
+rect $_rdbms_ov_geometric_property_definition_8h.html 259,32 520,59
+rect $_odbc_ov_geometric_property_definition_8h.html 569,7 823,34
+rect $_rdbms_ov_class_definition_8h.html 605,58 787,84
Added: trunk/www/docs/ODBC/_rdbms_ov_geometric_column_8h__dep__incl.md5
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_geometric_column_8h__dep__incl.md5?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_rdbms_ov_geometric_column_8h__dep__incl.md5 2006-12-01 20:39:06+0000
@@ -0,0 +1 @@
+bde4392b12fc70f3535deb0e23918ed9
Added: trunk/www/docs/ODBC/_rdbms_ov_geometric_column_8h__dep__incl.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_geometric_column_8h__dep__incl.png?view=auto&rev=94
Added: trunk/www/docs/ODBC/_rdbms_ov_geometric_column_8h__incl.map
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_geometric_column_8h__incl.map?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_rdbms_ov_geometric_column_8h__incl.map 2006-12-01 20:39:06+0000
@@ -0,0 +1,2 @@
+base referer
+rect $_rdbms_ov_8h.html 328,58 523,84
Added: trunk/www/docs/ODBC/_rdbms_ov_geometric_column_8h__incl.md5
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_geometric_column_8h__incl.md5?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_rdbms_ov_geometric_column_8h__incl.md5 2006-12-01 20:39:06+0000
@@ -0,0 +1 @@
+1ef36ac99b4e91e13a5e33cbfe457bb8
Added: trunk/www/docs/ODBC/_rdbms_ov_geometric_column_8h__incl.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_geometric_column_8h__incl.png?view=auto&rev=94
Added: trunk/www/docs/ODBC/_rdbms_ov_geometric_property_definition_8h-source.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_geometric_property_definition_8h-source.html?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_rdbms_ov_geometric_property_definition_8h-source.html 2006-12-01 20:39:06+0000
@@ -0,0 +1,165 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<h1>RdbmsOvGeometricPropertyDefinition.h</h1><a href="_rdbms_ov_geometric_property_definition_8h.html">Go to the documentation of this file.</a><div class="fragment"><pre class="fragment"><a name="l00001"></a>00001 <span class="preprocessor">#ifndef FDO_RDBMSOVGEOMETRICPROPERTYDEFINITION_H</span>
+<a name="l00002"></a>00002 <span class="preprocessor"></span><span class="preprocessor">#define FDO_RDBMSOVGEOMETRICPROPERTYDEFINITION_H</span>
+<a name="l00005"></a>00005 <span class="comment">//</span>
+<a name="l00006"></a>00006 <span class="comment">// Copyright (C) 2004-2006 Autodesk, Inc.</span>
+<a name="l00007"></a>00007 <span class="comment">// </span>
+<a name="l00008"></a>00008 <span class="comment">// This library is free software; you can redistribute it and/or</span>
+<a name="l00009"></a>00009 <span class="comment">// modify it under the terms of version 2.1 of the GNU Lesser</span>
+<a name="l00010"></a>00010 <span class="comment">// General Public License as published by the Free Software Foundation.</span>
+<a name="l00011"></a>00011 <span class="comment">// </span>
+<a name="l00012"></a>00012 <span class="comment">// This library is distributed in the hope that it will be useful,</span>
+<a name="l00013"></a>00013 <span class="comment">// but WITHOUT ANY WARRANTY; without even the implied warranty of</span>
+<a name="l00014"></a>00014 <span class="comment">// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU</span>
+<a name="l00015"></a>00015 <span class="comment">// Lesser General Public License for more details.</span>
+<a name="l00016"></a>00016 <span class="comment">// </span>
+<a name="l00017"></a>00017 <span class="comment">// You should have received a copy of the GNU Lesser General Public</span>
+<a name="l00018"></a>00018 <span class="comment">// License along with this library; if not, write to the Free Software</span>
+<a name="l00019"></a>00019 <span class="comment">// Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA</span>
+<a name="l00020"></a>00020 <span class="comment">//</span>
+<a name="l00021"></a>00021 <span class="comment"></span>
+<a name="l00022"></a>00022 <span class="comment">/// <library></span>
+<a name="l00023"></a>00023 <span class="comment">/// FdoRdbms.lib</span>
+<a name="l00024"></a>00024 <span class="comment">/// </library></span>
+<a name="l00025"></a>00025 <span class="comment"></span>
+<a name="l00028"></a>00028 <span class="preprocessor">#include <<a class="code" href="_rdbms_ov_geometric_column_8h.html">Rdbms/Override/RdbmsOvGeometricColumn.h</a>></span>
+<a name="l00029"></a>00029 <span class="preprocessor">#include <Utilities/SchemaMgr/Overrides/GeometricColumnType.h></span>
+<a name="l00030"></a>00030 <span class="preprocessor">#include <Utilities/SchemaMgr/Overrides/GeometricContentType.h></span>
+<a name="l00031"></a>00031 <span class="comment"></span>
+<a name="l00032"></a>00032 <span class="comment">///<summary>Abstract class defining physical schema overrides for a geometric property</span>
+<a name="l00033"></a>00033 <span class="comment">///definition.</summary></span>
+<a name="l00034"></a><a class="code" href="class_fdo_rdbms_ov_geometric_property_definition.html">00034</a> <span class="comment"></span><span class="keyword">class </span><a class="code" href="class_fdo_rdbms_ov_geometric_property_definition.html">FdoRdbmsOvGeometricPropertyDefinition</a> : <span class="keyword">virtual</span> <span class="keyword">public</span> <a class="code" href="class_fdo_rdbms_ov_property_definition.html">FdoRdbmsOvPropertyDefinition</a>
+<a name="l00035"></a>00035 {
+<a name="l00036"></a>00036 <span class="keyword">public</span>:<span class="comment"></span>
+<a name="l00037"></a>00037 <span class="comment"> ///<summary>Gets the column override</summary></span>
+<a name="l00038"></a>00038 <span class="comment"> /// <returns>Returns FdoRdbmsOvGeometricColumn</returns></span>
+<a name="l00039"></a>00039 <span class="comment"></span> <a class="code" href="_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html#9b6afd7f3f2f73a361844d7bff18436f">FDORDBMS_OV_API</a> <a class="code" href="class_fdo_rdbms_ov_geometric_column.html">FdoRdbmsOvGeometricColumn</a>* <a class="code" href="class_fdo_rdbms_ov_geometric_property_definition_56c93e984644b106b6b9982cdc36429f.html#56c93e984644b106b6b9982cdc36429f">GetColumn</a>();
+<a name="l00040"></a>00040 <span class="comment"></span>
+<a name="l00041"></a>00041 <span class="comment"> ///<summary>Gets the geometric column type</summary></span>
+<a name="l00042"></a>00042 <span class="comment"> ///<returns>Returns the default geometric column type</returns></span>
+<a name="l00043"></a>00043 <span class="comment"></span> <a class="code" href="_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html#9b6afd7f3f2f73a361844d7bff18436f">FDORDBMS_OV_API</a> FdoSmOvGeometricColumnType <a class="code" href="class_fdo_rdbms_ov_geometric_property_definition_c9c1de76e395eeecfa8bc0a46cb9a1d1.html#c9c1de76e395eeecfa8bc0a46cb9a1d1">GetGeometricColumnType</a>();
+<a name="l00044"></a>00044 <span class="comment"></span>
+<a name="l00045"></a>00045 <span class="comment"> ///<summary>Sets the geometric column type</summary></span>
+<a name="l00046"></a>00046 <span class="comment"> /// <param name="mappingType">Input the geometric column type</param></span>
+<a name="l00047"></a>00047 <span class="comment"> ///<returns>Returns nothing</returns></span>
+<a name="l00048"></a>00048 <span class="comment"></span> <a class="code" href="_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html#9b6afd7f3f2f73a361844d7bff18436f">FDORDBMS_OV_API</a> <span class="keywordtype">void</span> <a class="code" href="class_fdo_rdbms_ov_geometric_property_definition_ede8ec5d7f8dc2194be0c8472a8126ec.html#ede8ec5d7f8dc2194be0c8472a8126ec">SetGeometricColumnType</a>(FdoSmOvGeometricColumnType columnType);
+<a name="l00049"></a>00049 <span class="comment"></span>
+<a name="l00050"></a>00050 <span class="comment"> ///<summary>Gets the geometric content type</summary></span>
+<a name="l00051"></a>00051 <span class="comment"> ///<returns>Returns the geometric content type</returns></span>
+<a name="l00052"></a>00052 <span class="comment"></span> <a class="code" href="_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html#9b6afd7f3f2f73a361844d7bff18436f">FDORDBMS_OV_API</a> FdoSmOvGeometricContentType <a class="code" href="class_fdo_rdbms_ov_geometric_property_definition_77c26ccaadb05667df585711de57378f.html#77c26ccaadb05667df585711de57378f">GetGeometricContentType</a>();
+<a name="l00053"></a>00053 <span class="comment"></span>
+<a name="l00054"></a>00054 <span class="comment"> ///<summary>Sets the content type</summary></span>
+<a name="l00055"></a>00055 <span class="comment"> /// <param name="mappingType">Input the content type</param></span>
+<a name="l00056"></a>00056 <span class="comment"> ///<returns>Returns nothing</returns></span>
+<a name="l00057"></a>00057 <span class="comment"></span> <a class="code" href="_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html#9b6afd7f3f2f73a361844d7bff18436f">FDORDBMS_OV_API</a> <span class="keywordtype">void</span> <a class="code" href="class_fdo_rdbms_ov_geometric_property_definition_839d3e58dc3a1cc5bd2db3e0e9c4587d.html#839d3e58dc3a1cc5bd2db3e0e9c4587d">SetGeometricContentType</a>(FdoSmOvGeometricContentType contentType);
+<a name="l00058"></a>00058 <span class="comment"></span>
+<a name="l00059"></a>00059 <span class="comment"> ///<summary>Gets the ordinate column name for the X ordinate.</span>
+<a name="l00060"></a>00060 <span class="comment"> /// This only applies when GeometricContentType==FdoSmOvGeometricContentType_Ordinates.</span>
+<a name="l00061"></a>00061 <span class="comment"> /// Default value is "X".</span>
+<a name="l00062"></a>00062 <span class="comment"> ///</summary></span>
+<a name="l00063"></a>00063 <span class="comment"> ///<returns>Returns the ordinate column name for the X ordinate</returns></span>
+<a name="l00064"></a>00064 <span class="comment"></span> <a class="code" href="_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html#9b6afd7f3f2f73a361844d7bff18436f">FDORDBMS_OV_API</a> FdoString * <a class="code" href="class_fdo_rdbms_ov_geometric_property_definition_d1e5d00fb0c70ea8d50c1171e27add9f.html#d1e5d00fb0c70ea8d50c1171e27add9f">GetXColumnName</a>();
+<a name="l00065"></a>00065 <span class="comment"></span>
+<a name="l00066"></a>00066 <span class="comment"> ///<summary>Sets the ordinate column name for the X ordinate</summary></span>
+<a name="l00067"></a>00067 <span class="comment"> /// <param name="mappingType">Input the X ordinate column name</param></span>
+<a name="l00068"></a>00068 <span class="comment"> ///<returns>Returns nothing</returns></span>
+<a name="l00069"></a>00069 <span class="comment"></span> <a class="code" href="_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html#9b6afd7f3f2f73a361844d7bff18436f">FDORDBMS_OV_API</a> <span class="keywordtype">void</span> <a class="code" href="class_fdo_rdbms_ov_geometric_property_definition_0552d4c0287eb3f319ba6145e6e4e4b9.html#0552d4c0287eb3f319ba6145e6e4e4b9">SetXColumnName</a>(FdoString * columnName);
+<a name="l00070"></a>00070 <span class="comment"></span>
+<a name="l00071"></a>00071 <span class="comment"> ///<summary>Gets the ordinate column name for the Y ordinate.</span>
+<a name="l00072"></a>00072 <span class="comment"> /// This only applies when GeometricContentType==FdoSmOvGeometricContentType_Ordinates.</span>
+<a name="l00073"></a>00073 <span class="comment"> /// Default value is "Y".</span>
+<a name="l00074"></a>00074 <span class="comment"> ///</summary></span>
+<a name="l00075"></a>00075 <span class="comment"> ///<returns>Returns the ordinate column name for the Y ordinate</returns></span>
+<a name="l00076"></a>00076 <span class="comment"></span> <a class="code" href="_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html#9b6afd7f3f2f73a361844d7bff18436f">FDORDBMS_OV_API</a> FdoString * <a class="code" href="class_fdo_rdbms_ov_geometric_property_definition_93edf55b34051a41079774e2beae1c2b.html#93edf55b34051a41079774e2beae1c2b">GetYColumnName</a>();
+<a name="l00077"></a>00077 <span class="comment"></span>
+<a name="l00078"></a>00078 <span class="comment"> ///<summary>Sets the ordinate column name for the Y ordinate</summary></span>
+<a name="l00079"></a>00079 <span class="comment"> /// <param name="mappingType">Input the Y ordinate column name</param></span>
+<a name="l00080"></a>00080 <span class="comment"> ///<returns>Returns nothing</returns></span>
+<a name="l00081"></a>00081 <span class="comment"></span> <a class="code" href="_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html#9b6afd7f3f2f73a361844d7bff18436f">FDORDBMS_OV_API</a> <span class="keywordtype">void</span> <a class="code" href="class_fdo_rdbms_ov_geometric_property_definition_9738cb21bb8933cbc597542ae7d12f50.html#9738cb21bb8933cbc597542ae7d12f50">SetYColumnName</a>(FdoString * columnName);
+<a name="l00082"></a>00082 <span class="comment"></span>
+<a name="l00083"></a>00083 <span class="comment"> ///<summary>Gets the ordinate column name for the Z ordinate.</span>
+<a name="l00084"></a>00084 <span class="comment"> /// This only applies when GeometricContentType==FdoSmOvGeometricContentType_Ordinates</span>
+<a name="l00085"></a>00085 <span class="comment"> /// and the property definition's "HasElevation" attribute is "true".</span>
+<a name="l00086"></a>00086 <span class="comment"> /// Default value is "Z".</span>
+<a name="l00087"></a>00087 <span class="comment"> ///</summary></span>
+<a name="l00088"></a>00088 <span class="comment"> ///<returns>Returns the ordinate column name for the Z ordinate</returns></span>
+<a name="l00089"></a>00089 <span class="comment"></span> <a class="code" href="_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html#9b6afd7f3f2f73a361844d7bff18436f">FDORDBMS_OV_API</a> FdoString * <a class="code" href="class_fdo_rdbms_ov_geometric_property_definition_79b5f004b660853ab200775f23cb1bb8.html#79b5f004b660853ab200775f23cb1bb8">GetZColumnName</a>();
+<a name="l00090"></a>00090 <span class="comment"></span>
+<a name="l00091"></a>00091 <span class="comment"> ///<summary>Sets the ordinate column name for the Z ordinate</summary></span>
+<a name="l00092"></a>00092 <span class="comment"> /// <param name="mappingType">Input the Z ordinate column name</param></span>
+<a name="l00093"></a>00093 <span class="comment"> ///<returns>Returns nothing</returns></span>
+<a name="l00094"></a>00094 <span class="comment"></span> <a class="code" href="_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html#9b6afd7f3f2f73a361844d7bff18436f">FDORDBMS_OV_API</a> <span class="keywordtype">void</span> <a class="code" href="class_fdo_rdbms_ov_geometric_property_definition_4a942aa2e6b040ad0459d9bbf77316e5.html#4a942aa2e6b040ad0459d9bbf77316e5">SetZColumnName</a>(FdoString * columnName);
+<a name="l00095"></a>00095
+<a name="l00096"></a>00096 <span class="comment">//DOM-IGNORE-BEGIN</span>
+<a name="l00097"></a>00097 <a class="code" href="_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html#9b6afd7f3f2f73a361844d7bff18436f">FDORDBMS_OV_API</a> <span class="keyword">virtual</span> <span class="keywordtype">void</span> <a class="code" href="class_fdo_rdbms_ov_geometric_property_definition_c3f9df50411d16e812630411b53a6a68.html#c3f9df50411d16e812630411b53a6a68">InitFromXml</a>(FdoXmlSaxContext* pContext, FdoXmlAttributeCollection* attrs);
+<a name="l00098"></a>00098 <span class="comment">//DOM-IGNORE-END</span>
+<a name="l00099"></a>00099
+<a name="l00100"></a>00100
+<a name="l00101"></a>00101 <span class="keyword">protected</span>:
+<a name="l00102"></a>00102 <a class="code" href="_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html#9b6afd7f3f2f73a361844d7bff18436f">FDORDBMS_OV_API</a> <a class="code" href="class_fdo_rdbms_ov_geometric_property_definition_501f1bda658ff2fdd96013fa802fe716.html#501f1bda658ff2fdd96013fa802fe716">FdoRdbmsOvGeometricPropertyDefinition</a>();
+<a name="l00103"></a>00103 <a class="code" href="_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html#9b6afd7f3f2f73a361844d7bff18436f">FDORDBMS_OV_API</a> <a class="code" href="class_fdo_rdbms_ov_geometric_property_definition_501f1bda658ff2fdd96013fa802fe716.html#501f1bda658ff2fdd96013fa802fe716">FdoRdbmsOvGeometricPropertyDefinition</a>(FdoString* name);
+<a name="l00104"></a>00104 <a class="code" href="_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html#9b6afd7f3f2f73a361844d7bff18436f">FDORDBMS_OV_API</a> <span class="keyword">virtual</span> <a class="code" href="class_fdo_rdbms_ov_geometric_property_definition_977e611393a45777ce3d90519e8871db.html#977e611393a45777ce3d90519e8871db">~FdoRdbmsOvGeometricPropertyDefinition</a>();
+<a name="l00105"></a>00105
+<a name="l00106"></a>00106 <span class="comment">// Sets the column override</span>
+<a name="l00107"></a>00107 <a class="code" href="_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html#9b6afd7f3f2f73a361844d7bff18436f">FDORDBMS_OV_API</a> <span class="keywordtype">void</span> <a class="code" href="class_fdo_rdbms_ov_geometric_property_definition_8f68c8fb8c8a92c5e83b40e719dc6b37.html#8f68c8fb8c8a92c5e83b40e719dc6b37">SetColumn</a>(<a class="code" href="class_fdo_rdbms_ov_geometric_column.html">FdoRdbmsOvGeometricColumn</a>* geometricColumn);
+<a name="l00108"></a>00108
+<a name="l00109"></a>00109 <a class="code" href="_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html#9b6afd7f3f2f73a361844d7bff18436f">FDORDBMS_OV_API</a> <span class="keyword">virtual</span> <span class="keywordtype">void</span> <a class="code" href="class_fdo_rdbms_ov_geometric_property_definition_9039c8e9ceb849fd1edd847d2e39123e.html#9039c8e9ceb849fd1edd847d2e39123e">_writeXml</a>(FdoXmlWriter* xmlWriter, <span class="keyword">const</span> FdoXmlFlags* flags);
+<a name="l00110"></a>00110 <a class="code" href="_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html#9b6afd7f3f2f73a361844d7bff18436f">FDORDBMS_OV_API</a> <span class="keyword">virtual</span> <span class="keywordtype">void</span> <a class="code" href="class_fdo_rdbms_ov_geometric_property_definition_a032fcec7424bf16e302bc86734a425b.html#a032fcec7424bf16e302bc86734a425b">_writeXmlContents</a>(FdoXmlWriter* xmlWriter, <span class="keyword">const</span> FdoXmlFlags* flags);
+<a name="l00111"></a>00111
+<a name="l00112"></a>00112 <span class="keyword">private</span>:
+<a name="l00113"></a>00113 <a class="code" href="class_fdo_rdbms_ov_geometric_column.html">FdoRdbmsOvGeometricColumn</a>* mColumn;
+<a name="l00114"></a>00114 FdoSmOvGeometricColumnType mGeometricColumnType;
+<a name="l00115"></a>00115 FdoSmOvGeometricContentType mGeometricContentType;
+<a name="l00116"></a>00116 FdoStringP mXColumnName;
+<a name="l00117"></a>00117 FdoStringP mYColumnName;
+<a name="l00118"></a>00118 FdoStringP mZColumnName;
+<a name="l00119"></a>00119
+<a name="l00120"></a>00120 };
+<a name="l00121"></a>00121 <span class="comment"></span>
+<a name="l00122"></a>00122 <span class="comment">///<summary>FdoRdbmsOvGeometricPropertyP is a FdoPtr on FdoRdbmsOvGeometricPropertyDefinition, provided for convenience.</summary></span>
+<a name="l00123"></a><a class="code" href="_rdbms_ov_geometric_property_definition_8h_b9378490b3e08ad09a80d49a6a8aff7d.html#b9378490b3e08ad09a80d49a6a8aff7d">00123</a> <span class="comment"></span><span class="keyword">typedef</span> FdoPtr<FdoRdbmsOvGeometricPropertyDefinition> <a class="code" href="_rdbms_ov_geometric_property_definition_8h_b9378490b3e08ad09a80d49a6a8aff7d.html#b9378490b3e08ad09a80d49a6a8aff7d">FdoRdbmsOvGeometricPropertyP</a>;
+<a name="l00124"></a>00124
+<a name="l00125"></a>00125 <span class="preprocessor">#endif</span>
+<a name="l00126"></a>00126 <span class="preprocessor"></span>
+</pre></div><!-- footer.html -->
+ <hr>
+ <tr>
+ <td align="right"><font size="-2"><a href="mailto:isd.docs at autodesk.com&subject=FDO%20Provider%20for%20ODBC%20API%20documentation">Comments?</a></font></td>
+ <!-- The logo can go in another cell, when we get one -->
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/ODBC/_rdbms_ov_geometric_property_definition_8h.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_geometric_property_definition_8h.html?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_rdbms_ov_geometric_property_definition_8h.html 2006-12-01 20:39:06+0000
@@ -0,0 +1,75 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<h1>RdbmsOvGeometricPropertyDefinition.h File Reference</h1>
+<p>
+<code>#include <<a class="el" href="_rdbms_ov_geometric_column_8h-source.html">Rdbms/Override/RdbmsOvGeometricColumn.h</a>></code><br>
+<code>#include <Utilities/SchemaMgr/Overrides/GeometricColumnType.h></code><br>
+<code>#include <Utilities/SchemaMgr/Overrides/GeometricContentType.h></code><br>
+<p>
+Include dependency graph for RdbmsOvGeometricPropertyDefinition.h:<p><center><img src="_rdbms_ov_geometric_property_definition_8h__incl.png" border="0" usemap="#RdbmsOvGeometricPropertyDefinition.h_map" alt=""></center>
+<map name="RdbmsOvGeometricPropertyDefinition.h_map">
+<area href="_rdbms_ov_8h.html" shape="rect" coords="724,58,919,84" alt="">
+<area href="_rdbms_ov_property_definition_8h.html" shape="rect" coords="347,58,648,84" alt="">
+<area href="_rdbms_ov_geometric_column_8h.html" shape="rect" coords="345,108,649,135" alt="">
+</map>
+<p>
+This graph shows which files directly or indirectly include this file:<p><center><img src="_rdbms_ov_geometric_property_definition_8h__dep__incl.png" border="0" usemap="#RdbmsOvGeometricPropertyDefinition.hdep_map" alt=""></center>
+<map name="RdbmsOvGeometricPropertyDefinition.hdep_map">
+<area href="_odbc_ov_geometric_property_definition_8h.html" shape="rect" coords="319,7,572,34" alt="">
+<area href="_rdbms_ov_class_definition_8h.html" shape="rect" coords="355,58,536,84" alt="">
+<area href="_odbc_ov_class_definition_8h.html" shape="rect" coords="627,7,800,34" alt="">
+<area href="_rdbms_ov_class_collection_8h.html" shape="rect" coords="621,58,805,84" alt="">
+</map>
+<p>
+<a href="_rdbms_ov_geometric_property_definition_8h-source.html">Go to the source code of this file.</a><table border="0" cellpadding="0" cellspacing="0">
+<tr><td></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">class </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_rdbms_ov_geometric_property_definition.html">FdoRdbmsOvGeometricPropertyDefinition</a></td></tr>
+<tr><td class="mdescLeft"> </td><td class="mdescRight">Abstract class defining physical schema overrides for a geometric property definition. <a href="class_fdo_rdbms_ov_geometric_property_definition.html#_details">More...</a><br></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">typedef FdoPtr< <a class="el" href="class_fdo_rdbms_ov_geometric_property_definition.html">FdoRdbmsOvGeometricPropertyDefinition</a> > </td><td class="memItemRight" valign="bottom"><a class="el" href="_rdbms_ov_geometric_property_definition_8h_b9378490b3e08ad09a80d49a6a8aff7d.html#b9378490b3e08ad09a80d49a6a8aff7d">FdoRdbmsOvGeometricPropertyP</a></td></tr>
+</table>
+<!-- footer.html -->
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/ODBC/_rdbms_ov_geometric_property_definition_8h__dep__incl.map
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_geometric_property_definition_8h__dep__incl.map?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_rdbms_ov_geometric_property_definition_8h__dep__incl.map 2006-12-01 20:39:06+0000
@@ -0,0 +1,5 @@
+base referer
+rect $_odbc_ov_geometric_property_definition_8h.html 319,7 572,34
+rect $_rdbms_ov_class_definition_8h.html 355,58 536,84
+rect $_odbc_ov_class_definition_8h.html 627,7 800,34
+rect $_rdbms_ov_class_collection_8h.html 621,58 805,84
Added: trunk/www/docs/ODBC/_rdbms_ov_geometric_property_definition_8h__dep__incl.md5
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_geometric_property_definition_8h__dep__incl.md5?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_rdbms_ov_geometric_property_definition_8h__dep__incl.md5 2006-12-01 20:39:06+0000
@@ -0,0 +1 @@
+5d3c7f6cf644734bf4527b014fbe086e
\ No newline at end of file
Added: trunk/www/docs/ODBC/_rdbms_ov_geometric_property_definition_8h__dep__incl.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_geometric_property_definition_8h__dep__incl.png?view=auto&rev=94
Binary file. No diff available.
Added: trunk/www/docs/ODBC/_rdbms_ov_geometric_property_definition_8h__incl.map
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_geometric_property_definition_8h__incl.map?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_rdbms_ov_geometric_property_definition_8h__incl.map 2006-12-01 20:39:06+0000
@@ -0,0 +1,4 @@
+base referer
+rect $_rdbms_ov_8h.html 724,58 919,84
+rect $_rdbms_ov_property_definition_8h.html 347,58 648,84
+rect $_rdbms_ov_geometric_column_8h.html 345,108 649,135
Added: trunk/www/docs/ODBC/_rdbms_ov_geometric_property_definition_8h__incl.md5
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_geometric_property_definition_8h__incl.md5?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_rdbms_ov_geometric_property_definition_8h__incl.md5 2006-12-01 20:39:06+0000
@@ -0,0 +1 @@
+94580f3f6788af640099b43545d20da2
Added: trunk/www/docs/ODBC/_rdbms_ov_geometric_property_definition_8h__incl.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_geometric_property_definition_8h__incl.png?view=auto&rev=94
Added: trunk/www/docs/ODBC/_rdbms_ov_geometric_property_definition_8h_b9378490b3e08ad09a80d49a6a8aff7d.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_geometric_property_definition_8h_b9378490b3e08ad09a80d49a6a8aff7d.html?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_rdbms_ov_geometric_property_definition_8h_b9378490b3e08ad09a80d49a6a8aff7d.html 2006-12-01 20:39:06+0000
@@ -0,0 +1,74 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ <li><a href="files.html"><span>Files</span></a></li>
+ </ul></div>
+<div class="nav">
+<a class="el" href="_rdbms_ov_geometric_property_definition_8h.html">RdbmsOvGeometricPropertyDefinition.h</a></div>
+<table cellspacing="0" cellpadding="0" border="0">
+ <tr>
+ <td valign="top">
+ <div class="navtab">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="_rdbms_ov_geometric_property_definition_8h_b9378490b3e08ad09a80d49a6a8aff7d.html#b9378490b3e08ad09a80d49a6a8aff7d">FdoRdbmsOvGeometricPropertyP</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="b9378490b3e08ad09a80d49a6a8aff7d"></a><!-- doxytag: member="RdbmsOvGeometricPropertyDefinition.h::FdoRdbmsOvGeometricPropertyP" ref="b9378490b3e08ad09a80d49a6a8aff7d" args="" --><p>
+<table class="mdTable" cellpadding="2" cellspacing="0">
+ <tr>
+ <td class="mdRow">
+ <table cellpadding="0" cellspacing="0" border="0">
+ <tr>
+ <td class="md" nowrap valign="top">typedef FdoPtr<<a class="el" href="class_fdo_rdbms_ov_geometric_property_definition.html">FdoRdbmsOvGeometricPropertyDefinition</a>> <a class="el" href="_rdbms_ov_geometric_property_definition_8h_b9378490b3e08ad09a80d49a6a8aff7d.html#b9378490b3e08ad09a80d49a6a8aff7d">FdoRdbmsOvGeometricPropertyP</a> </td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+<table cellspacing="5" cellpadding="0" border="0">
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+<p>
+Definition at line <a class="el" href="_rdbms_ov_geometric_property_definition_8h-source.html#l00123">123</a> of file <a class="el" href="_rdbms_ov_geometric_property_definition_8h-source.html">RdbmsOvGeometricPropertyDefinition.h</a>. </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/ODBC/_rdbms_ov_object_property_definition_8h-source.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_object_property_definition_8h-source.html?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_rdbms_ov_object_property_definition_8h-source.html 2006-12-01 20:39:06+0000
@@ -0,0 +1,143 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<h1>RdbmsOvObjectPropertyDefinition.h</h1><a href="_rdbms_ov_object_property_definition_8h.html">Go to the documentation of this file.</a><div class="fragment"><pre class="fragment"><a name="l00001"></a>00001 <span class="preprocessor">#ifndef FDO_RDBMSOVOBJECTPROPERTYDEFINITION_H</span>
+<a name="l00002"></a>00002 <span class="preprocessor"></span><span class="preprocessor">#define FDO_RDBMSOVOBJECTPROPERTYDEFINITION_H</span>
+<a name="l00003"></a>00003 <span class="preprocessor"></span><span class="comment">//</span>
+<a name="l00004"></a>00004 <span class="comment">//</span>
+<a name="l00005"></a>00005 <span class="comment">// Copyright (C) 2004-2006 Autodesk, Inc.</span>
+<a name="l00006"></a>00006 <span class="comment">// </span>
+<a name="l00007"></a>00007 <span class="comment">// This library is free software; you can redistribute it and/or</span>
+<a name="l00008"></a>00008 <span class="comment">// modify it under the terms of version 2.1 of the GNU Lesser</span>
+<a name="l00009"></a>00009 <span class="comment">// General Public License as published by the Free Software Foundation.</span>
+<a name="l00010"></a>00010 <span class="comment">// </span>
+<a name="l00011"></a>00011 <span class="comment">// This library is distributed in the hope that it will be useful,</span>
+<a name="l00012"></a>00012 <span class="comment">// but WITHOUT ANY WARRANTY; without even the implied warranty of</span>
+<a name="l00013"></a>00013 <span class="comment">// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU</span>
+<a name="l00014"></a>00014 <span class="comment">// Lesser General Public License for more details.</span>
+<a name="l00015"></a>00015 <span class="comment">// </span>
+<a name="l00016"></a>00016 <span class="comment">// You should have received a copy of the GNU Lesser General Public</span>
+<a name="l00017"></a>00017 <span class="comment">// License along with this library; if not, write to the Free Software</span>
+<a name="l00018"></a>00018 <span class="comment">// Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA</span>
+<a name="l00019"></a>00019 <span class="comment">//</span>
+<a name="l00020"></a>00020 <span class="comment"></span>
+<a name="l00021"></a>00021 <span class="comment">/// <library></span>
+<a name="l00022"></a>00022 <span class="comment">/// FdoRdbms.lib</span>
+<a name="l00023"></a>00023 <span class="comment">/// </library></span>
+<a name="l00024"></a>00024 <span class="comment"></span>
+<a name="l00026"></a>00026 <span class="preprocessor">#include <<a class="code" href="_rdbms_ov_property_definition_8h.html">Rdbms/Override/RdbmsOvPropertyDefinition.h</a>></span>
+<a name="l00027"></a>00027 <span class="preprocessor">#include <<a class="code" href="_rdbms_ov_property_mapping_class_8h.html">Rdbms/Override/RdbmsOvPropertyMappingClass.h</a>></span>
+<a name="l00028"></a>00028 <span class="preprocessor">#include <<a class="code" href="_rdbms_ov_property_mapping_concrete_8h.html">Rdbms/Override/RdbmsOvPropertyMappingConcrete.h</a>></span>
+<a name="l00029"></a>00029 <span class="preprocessor">#include <<a class="code" href="_rdbms_ov_property_mapping_single_8h.html">Rdbms/Override/RdbmsOvPropertyMappingSingle.h</a>></span>
+<a name="l00030"></a>00030 <span class="comment"></span>
+<a name="l00031"></a>00031 <span class="comment">///<summary>Abstract class defining physical schema overrides for an object property</span>
+<a name="l00032"></a>00032 <span class="comment">///definition.</summary></span>
+<a name="l00033"></a><a class="code" href="class_fdo_rdbms_ov_object_property_definition.html">00033</a> <span class="comment"></span><span class="keyword">class </span><a class="code" href="class_fdo_rdbms_ov_object_property_definition.html">FdoRdbmsOvObjectPropertyDefinition</a> : <span class="keyword">virtual</span> <span class="keyword">public</span> <a class="code" href="class_fdo_rdbms_ov_property_definition.html">FdoRdbmsOvPropertyDefinition</a>
+<a name="l00034"></a>00034 {
+<a name="l00035"></a>00035 <span class="keyword">public</span>:<span class="comment"></span>
+<a name="l00036"></a>00036 <span class="comment"> ///<summary>Gets the object property mapping definition</summary></span>
+<a name="l00037"></a>00037 <span class="comment"> /// <returns>Returns FdoRdbmsOvPropertyMappingDefinition</returns></span>
+<a name="l00038"></a>00038 <span class="comment"></span> <a class="code" href="_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html#9b6afd7f3f2f73a361844d7bff18436f">FDORDBMS_OV_API</a> <a class="code" href="class_fdo_rdbms_ov_property_mapping_definition.html">FdoRdbmsOvPropertyMappingDefinition</a>* <a class="code" href="class_fdo_rdbms_ov_object_property_definition_f596496de1a0727160e669da1ad0bba0.html#f596496de1a0727160e669da1ad0bba0">GetMappingDefinition</a>();
+<a name="l00040"></a>00040 <span class="comment">//DOM-IGNORE-BEGIN</span>
+<a name="l00042"></a>00042 <span class="comment">// XML Serialization functions, not part of API.</span>
+<a name="l00044"></a>00044 <span class="comment">// Initialize this element from its XML attributes</span>
+<a name="l00045"></a>00045 <a class="code" href="_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html#9b6afd7f3f2f73a361844d7bff18436f">FDORDBMS_OV_API</a> <span class="keyword">virtual</span> <span class="keywordtype">void</span> <a class="code" href="class_fdo_rdbms_ov_object_property_definition_2643f55b32de68af05517e3679951f8c.html#2643f55b32de68af05517e3679951f8c">InitFromXml</a>(
+<a name="l00046"></a>00046 FdoXmlSaxContext* pContext,
+<a name="l00047"></a>00047 FdoXmlAttributeCollection* attrs,
+<a name="l00048"></a>00048 FdoString* mappingType,
+<a name="l00049"></a>00049 FdoXmlAttributeCollection* mappingAttrs
+<a name="l00050"></a>00050 );
+<a name="l00052"></a>00052 <span class="comment">// Create and optionally attach a Single table property mapping.</span>
+<a name="l00053"></a><a class="code" href="class_fdo_rdbms_ov_object_property_definition_55c9b086f2585c674b94e1f360a289d8.html#55c9b086f2585c674b94e1f360a289d8">00053</a> <a class="code" href="_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html#9b6afd7f3f2f73a361844d7bff18436f">FDORDBMS_OV_API</a> <span class="keyword">virtual</span> <a class="code" href="class_fdo_rdbms_ov_property_mapping_single.html">FdoRdbmsOvPropertyMappingSingle</a>* <a class="code" href="class_fdo_rdbms_ov_object_property_definition_55c9b086f2585c674b94e1f360a289d8.html#55c9b086f2585c674b94e1f360a289d8">CreateSingleMapping</a>(
+<a name="l00054"></a>00054 <span class="keywordtype">bool</span> attach <span class="comment">// if true then make the new mapping the property mapping for </span>
+<a name="l00055"></a>00055 <span class="comment">// this object property. Replaces any previous mapping </span>
+<a name="l00056"></a>00056 )
+<a name="l00057"></a>00057 {
+<a name="l00058"></a>00058 <span class="keywordflow">return</span> NULL;
+<a name="l00059"></a>00059 <span class="comment">//TODO: exception</span>
+<a name="l00060"></a>00060 }
+<a name="l00062"></a>00062 <span class="comment">// Create and optionally attach a Class table property mapping.</span>
+<a name="l00063"></a><a class="code" href="class_fdo_rdbms_ov_object_property_definition_97a69b3eadb6dfa059ba803654348101.html#97a69b3eadb6dfa059ba803654348101">00063</a> <a class="code" href="_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html#9b6afd7f3f2f73a361844d7bff18436f">FDORDBMS_OV_API</a> <span class="keyword">virtual</span> <a class="code" href="class_fdo_rdbms_ov_property_mapping_class.html">FdoRdbmsOvPropertyMappingClass</a>* <a class="code" href="class_fdo_rdbms_ov_object_property_definition_97a69b3eadb6dfa059ba803654348101.html#97a69b3eadb6dfa059ba803654348101">CreateClassMapping</a>(
+<a name="l00064"></a>00064 <span class="keywordtype">bool</span> attach <span class="comment">// if true then make the new mapping the property mapping for </span>
+<a name="l00065"></a>00065 <span class="comment">// this object property. Replaces any previous mapping </span>
+<a name="l00066"></a>00066 )
+<a name="l00067"></a>00067 {
+<a name="l00068"></a>00068 <span class="keywordflow">return</span> NULL;
+<a name="l00069"></a>00069 <span class="comment">//TODO: exception</span>
+<a name="l00070"></a>00070 }
+<a name="l00072"></a>00072 <span class="comment">// Create and optionally attach a Concrete table property mapping.</span>
+<a name="l00073"></a><a class="code" href="class_fdo_rdbms_ov_object_property_definition_1ab9fa891708a2986856f9f4aae7c8f4.html#1ab9fa891708a2986856f9f4aae7c8f4">00073</a> <a class="code" href="_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html#9b6afd7f3f2f73a361844d7bff18436f">FDORDBMS_OV_API</a> <span class="keyword">virtual</span> <a class="code" href="class_fdo_rdbms_ov_property_mapping_concrete.html">FdoRdbmsOvPropertyMappingConcrete</a>* <a class="code" href="class_fdo_rdbms_ov_object_property_definition_1ab9fa891708a2986856f9f4aae7c8f4.html#1ab9fa891708a2986856f9f4aae7c8f4">CreateConcreteMapping</a>(
+<a name="l00074"></a>00074 <span class="keywordtype">bool</span> attach <span class="comment">// if true then make the new mapping the property mapping for </span>
+<a name="l00075"></a>00075 <span class="comment">// this object property. Replaces any previous mapping </span>
+<a name="l00076"></a>00076 )
+<a name="l00077"></a>00077 {
+<a name="l00078"></a>00078 <span class="keywordflow">return</span> NULL;
+<a name="l00079"></a>00079 <span class="comment">//TODO: exception</span>
+<a name="l00080"></a>00080 }
+<a name="l00082"></a>00082 <span class="comment">//DOM-IGNORE-END</span>
+<a name="l00085"></a>00085 <span class="keyword">protected</span>:
+<a name="l00086"></a>00086 <a class="code" href="_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html#9b6afd7f3f2f73a361844d7bff18436f">FDORDBMS_OV_API</a> <a class="code" href="class_fdo_rdbms_ov_object_property_definition_ed9566f0edf068a505dc8960399b9336.html#ed9566f0edf068a505dc8960399b9336">FdoRdbmsOvObjectPropertyDefinition</a>();
+<a name="l00087"></a>00087 <a class="code" href="_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html#9b6afd7f3f2f73a361844d7bff18436f">FDORDBMS_OV_API</a> <a class="code" href="class_fdo_rdbms_ov_object_property_definition_ed9566f0edf068a505dc8960399b9336.html#ed9566f0edf068a505dc8960399b9336">FdoRdbmsOvObjectPropertyDefinition</a>(FdoString* name);
+<a name="l00088"></a>00088 <a class="code" href="_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html#9b6afd7f3f2f73a361844d7bff18436f">FDORDBMS_OV_API</a> <span class="keyword">virtual</span> <a class="code" href="class_fdo_rdbms_ov_object_property_definition_eba244316cb1d22359f6a9d05e794514.html#eba244316cb1d22359f6a9d05e794514">~FdoRdbmsOvObjectPropertyDefinition</a>();
+<a name="l00090"></a>00090 <span class="comment">// Sets the object property mapping</span>
+<a name="l00091"></a>00091 <a class="code" href="_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html#9b6afd7f3f2f73a361844d7bff18436f">FDORDBMS_OV_API</a> <span class="keywordtype">void</span> <a class="code" href="class_fdo_rdbms_ov_object_property_definition_03b019db58670b70b177331490de5db1.html#03b019db58670b70b177331490de5db1">SetMappingDefinition</a>(<a class="code" href="class_fdo_rdbms_ov_property_mapping_definition.html">FdoRdbmsOvPropertyMappingDefinition</a>* propertyMappingDefinition);
+<a name="l00093"></a>00093 <span class="comment">// Serialize provider-specific parts of this override to XML.</span>
+<a name="l00094"></a>00094 <a class="code" href="_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html#9b6afd7f3f2f73a361844d7bff18436f">FDORDBMS_OV_API</a> <span class="keyword">virtual</span> <span class="keywordtype">void</span> <a class="code" href="class_fdo_rdbms_ov_object_property_definition_83e55405dcaa9c75d31855e2e4cd9d85.html#83e55405dcaa9c75d31855e2e4cd9d85">_writeXmlContents</a>(FdoXmlWriter* xmlWriter, <span class="keyword">const</span> FdoXmlFlags* flags);
+<a name="l00096"></a>00096 <span class="keyword">private</span>:
+<a name="l00097"></a>00097 <a class="code" href="_rdbms_ov_property_mapping_definition_8h_c13fe6b320fc1f174d6079b9651cd759.html#c13fe6b320fc1f174d6079b9651cd759">FdoRdbmsOvPropertyMappingP</a> mPropertyMappingDefinition;
+<a name="l00098"></a>00098 };
+<a name="l00099"></a>00099 <span class="comment"></span>
+<a name="l00100"></a>00100 <span class="comment">///<summary>FdoRdbmsOvObjectPropertyP is a FdoPtr on FdoRdbmsOvObjectPropertyDefinition, provided for convenience.</summary></span>
+<a name="l00101"></a><a class="code" href="_rdbms_ov_object_property_definition_8h_82a4996cf07e521712d6b26ac2aa96de.html#82a4996cf07e521712d6b26ac2aa96de">00101</a> <span class="comment"></span><span class="keyword">typedef</span> FdoPtr<FdoRdbmsOvObjectPropertyDefinition> <a class="code" href="_rdbms_ov_object_property_definition_8h_82a4996cf07e521712d6b26ac2aa96de.html#82a4996cf07e521712d6b26ac2aa96de">FdoRdbmsOvObjectPropertyP</a>;
+<a name="l00103"></a>00103 <span class="preprocessor">#endif</span>
+<a name="l00104"></a>00104 <span class="preprocessor"></span>
+ <hr>
+ <table width="100%" border="0">
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/ODBC/_rdbms_ov_object_property_definition_8h.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_object_property_definition_8h.html?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_rdbms_ov_object_property_definition_8h.html 2006-12-01 20:39:06+0000
@@ -0,0 +1,78 @@
+<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN" "http://www.w3.org/TR/html4/loose.dtd">
+<html>
+ <head>
+ <meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
+ <title>OSGeo FDO Provider for ODBC API Reference</title>
+ <link href="custom.css" rel="stylesheet" type="text/css">
+ <link href="tabs.css" rel="stylesheet" type="text/css">
+ </head>
+ <body bgcolor="#FFFFFF">
+ <tr>
+ <td><b>API Reference<b></td>
+ <td align="right"><b>OSGeo FDO Provider for ODBC<b></td>
+ </tr>
+ </table>
+<!-- End of: header.html -->
+<!-- Generated by Doxygen 1.4.6-NO -->
+<div class="tabs">
+ <ul>
+ <li><a href="main.html"><span>Main Page</span></a></li>
+ <li><a href="classes.html"><span>Classes</span></a></li>
+ <li id="current"><a href="files.html"><span>Files</span></a></li>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ <li><a href="files.html"><span>File List</span></a></li>
+ <li><a href="globals.html"><span>File Members</span></a></li>
+ </ul></div>
+<h1>RdbmsOvObjectPropertyDefinition.h File Reference</h1>
+<p>
+<code>#include <<a class="el" href="_rdbms_ov_8h-source.html">Rdbms/Override/RdbmsOv.h</a>></code><br>
+<code>#include <<a class="el" href="_rdbms_ov_property_definition_8h-source.html">Rdbms/Override/RdbmsOvPropertyDefinition.h</a>></code><br>
+<code>#include <<a class="el" href="_rdbms_ov_property_mapping_class_8h-source.html">Rdbms/Override/RdbmsOvPropertyMappingClass.h</a>></code><br>
+<code>#include <<a class="el" href="_rdbms_ov_property_mapping_concrete_8h-source.html">Rdbms/Override/RdbmsOvPropertyMappingConcrete.h</a>></code><br>
+<code>#include <<a class="el" href="_rdbms_ov_property_mapping_single_8h-source.html">Rdbms/Override/RdbmsOvPropertyMappingSingle.h</a>></code><br>
+<p>
+Include dependency graph for RdbmsOvObjectPropertyDefinition.h:<p><center><img src="_rdbms_ov_object_property_definition_8h__incl.png" border="0" usemap="#RdbmsOvObjectPropertyDefinition.h_map" alt=""></center>
+<map name="RdbmsOvObjectPropertyDefinition.h_map">
+<area href="_rdbms_ov_8h.html" shape="rect" coords="695,108,889,135" alt="">
+<area href="_rdbms_ov_property_definition_8h.html" shape="rect" coords="320,58,621,84" alt="">
+<area href="_rdbms_ov_property_mapping_class_8h.html" shape="rect" coords="305,108,636,135" alt="">
+<area href="_rdbms_ov_property_mapping_concrete_8h.html" shape="rect" coords="295,159,647,186" alt="">
+<area href="_rdbms_ov_property_mapping_single_8h.html" shape="rect" coords="304,210,637,236" alt="">
+</map>
+<p>
+This graph shows which files directly or indirectly include this file:<p><center><img src="_rdbms_ov_object_property_definition_8h__dep__incl.png" border="0" usemap="#RdbmsOvObjectPropertyDefinition.hdep_map" alt=""></center>
+<map name="RdbmsOvObjectPropertyDefinition.hdep_map">
+<area href="_rdbms_ov_class_definition_8h.html" shape="rect" coords="296,32,477,59" alt="">
+<area href="_odbc_ov_class_definition_8h.html" shape="rect" coords="533,7,707,34" alt="">
+<area href="_rdbms_ov_class_collection_8h.html" shape="rect" coords="528,58,712,84" alt="">
+<area href="_odbc_ov_class_collection_8h.html" shape="rect" coords="796,7,972,34" alt="">
+<area href="_rdbms_ov_physical_schema_mapping_8h.html" shape="rect" coords="763,58,1005,84" alt="">
+</map>
+<p>
+<a href="_rdbms_ov_object_property_definition_8h-source.html">Go to the source code of this file.</a><table border="0" cellpadding="0" cellspacing="0">
+<tr><td></td></tr>
+<tr><td colspan="2"><br><h2>Classes</h2></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">class </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_rdbms_ov_object_property_definition.html">FdoRdbmsOvObjectPropertyDefinition</a></td></tr>
+<tr><td class="mdescLeft"> </td><td class="mdescRight">Abstract class defining physical schema overrides for an object property definition. <a href="class_fdo_rdbms_ov_object_property_definition.html#_details">More...</a><br></td></tr>
+<tr><td colspan="2"><br><h2>Typedefs</h2></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">typedef FdoPtr< <a class="el" href="class_fdo_rdbms_ov_object_property_definition.html">FdoRdbmsOvObjectPropertyDefinition</a> > </td><td class="memItemRight" valign="bottom"><a class="el" href="_rdbms_ov_object_property_definition_8h_82a4996cf07e521712d6b26ac2aa96de.html#82a4996cf07e521712d6b26ac2aa96de">FdoRdbmsOvObjectPropertyP</a></td></tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/ODBC/_rdbms_ov_object_property_definition_8h_82a4996cf07e521712d6b26ac2aa96de.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_object_property_definition_8h_82a4996cf07e521712d6b26ac2aa96de.html?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_rdbms_ov_object_property_definition_8h_82a4996cf07e521712d6b26ac2aa96de.html 2006-12-01 20:39:06+0000
@@ -0,0 +1,74 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="nav">
+<a class="el" href="_rdbms_ov_object_property_definition_8h.html">RdbmsOvObjectPropertyDefinition.h</a></div>
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="_rdbms_ov_object_property_definition_8h_82a4996cf07e521712d6b26ac2aa96de.html#82a4996cf07e521712d6b26ac2aa96de">FdoRdbmsOvObjectPropertyP</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="82a4996cf07e521712d6b26ac2aa96de"></a><!-- doxytag: member="RdbmsOvObjectPropertyDefinition.h::FdoRdbmsOvObjectPropertyP" ref="82a4996cf07e521712d6b26ac2aa96de" args="" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">typedef FdoPtr<<a class="el" href="class_fdo_rdbms_ov_object_property_definition.html">FdoRdbmsOvObjectPropertyDefinition</a>> <a class="el" href="_rdbms_ov_object_property_definition_8h_82a4996cf07e521712d6b26ac2aa96de.html#82a4996cf07e521712d6b26ac2aa96de">FdoRdbmsOvObjectPropertyP</a> </td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+<p>
+Definition at line <a class="el" href="_rdbms_ov_object_property_definition_8h-source.html#l00101">101</a> of file <a class="el" href="_rdbms_ov_object_property_definition_8h-source.html">RdbmsOvObjectPropertyDefinition.h</a>. </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/ODBC/_rdbms_ov_object_property_definition_8h__dep__incl.map
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_object_property_definition_8h__dep__incl.map?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_rdbms_ov_object_property_definition_8h__dep__incl.map 2006-12-01 20:39:06+0000
@@ -0,0 +1,6 @@
+base referer
+rect $_rdbms_ov_class_definition_8h.html 296,32 477,59
+rect $_odbc_ov_class_definition_8h.html 533,7 707,34
+rect $_rdbms_ov_class_collection_8h.html 528,58 712,84
+rect $_odbc_ov_class_collection_8h.html 796,7 972,34
+rect $_rdbms_ov_physical_schema_mapping_8h.html 763,58 1005,84
Added: trunk/www/docs/ODBC/_rdbms_ov_object_property_definition_8h__dep__incl.md5
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_object_property_definition_8h__dep__incl.md5?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_rdbms_ov_object_property_definition_8h__dep__incl.md5 2006-12-01 20:39:06+0000
@@ -0,0 +1 @@
+797e5ee82e5a4ca82f8a8d2459395165
Added: trunk/www/docs/ODBC/_rdbms_ov_object_property_definition_8h__dep__incl.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_object_property_definition_8h__dep__incl.png?view=auto&rev=94
Added: trunk/www/docs/ODBC/_rdbms_ov_object_property_definition_8h__incl.map
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_object_property_definition_8h__incl.map?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_rdbms_ov_object_property_definition_8h__incl.map 2006-12-01 20:39:06+0000
@@ -0,0 +1,6 @@
+base referer
+rect $_rdbms_ov_8h.html 695,108 889,135
+rect $_rdbms_ov_property_definition_8h.html 320,58 621,84
+rect $_rdbms_ov_property_mapping_class_8h.html 305,108 636,135
+rect $_rdbms_ov_property_mapping_concrete_8h.html 295,159 647,186
+rect $_rdbms_ov_property_mapping_single_8h.html 304,210 637,236
Added: trunk/www/docs/ODBC/_rdbms_ov_object_property_definition_8h__incl.md5
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_object_property_definition_8h__incl.md5?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_rdbms_ov_object_property_definition_8h__incl.md5 2006-12-01 20:39:06+0000
@@ -0,0 +1 @@
+e34a8e81a9f9dcf0f5afc59ff8da33c8
Added: trunk/www/docs/ODBC/_rdbms_ov_object_property_definition_8h__incl.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_object_property_definition_8h__incl.png?view=auto&rev=94
Added: trunk/www/docs/ODBC/_rdbms_ov_physical_schema_mapping_8h-source.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_physical_schema_mapping_8h-source.html?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_rdbms_ov_physical_schema_mapping_8h-source.html 2006-12-01 20:39:06+0000
@@ -0,0 +1,189 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<h1>RdbmsOvPhysicalSchemaMapping.h</h1><a href="_rdbms_ov_physical_schema_mapping_8h.html">Go to the documentation of this file.</a><div class="fragment"><pre class="fragment"><a name="l00001"></a>00001 <span class="preprocessor">#ifndef FDO_RDBMSOVPHYSICALSCHEMAMAPPING_H</span>
+<a name="l00002"></a>00002 <span class="preprocessor"></span><span class="preprocessor">#define FDO_RDBMSOVPHYSICALSCHEMAMAPPING_H</span>
+<a name="l00021"></a>00021 <span class="preprocessor">#include <Fdo/Commands/Schema/PhysicalSchemaMapping.h></span>
+<a name="l00022"></a>00022 <span class="preprocessor">#include <Utilities/SchemaMgr/Overrides/TableMappingType.h></span>
+<a name="l00023"></a>00023 <span class="preprocessor">#include <Utilities/SchemaMgr/Overrides/GeometricColumnType.h></span>
+<a name="l00024"></a>00024 <span class="preprocessor">#include <Utilities/SchemaMgr/Overrides/GeometricContentType.h></span>
+<a name="l00025"></a>00025 <span class="preprocessor">#include <<a class="code" href="_rdbms_ov_8h.html">Rdbms/Override/RdbmsOv.h</a>></span>
+<a name="l00026"></a>00026 <span class="preprocessor">#include <<a class="code" href="_rdbms_ov_class_collection_8h.html">Rdbms/Override/RdbmsOvClassCollection.h</a>></span>
+<a name="l00027"></a>00027 <span class="preprocessor">#include <<a class="code" href="_rdbms_ov_schema_auto_generation_8h.html">Rdbms/Override/RdbmsOvSchemaAutoGeneration.h</a>></span>
+<a name="l00028"></a>00028 <span class="comment"></span>
+<a name="l00029"></a>00029 <span class="comment">/// <library></span>
+<a name="l00030"></a>00030 <span class="comment">/// FdoRdbms.lib</span>
+<a name="l00031"></a>00031 <span class="comment">/// </library></span>
+<a name="l00032"></a>00032 <span class="comment"></span><span class="comment"></span>
+<a name="l00033"></a>00033 <span class="comment">///<summary>Abstract base class for RDBMS type provider schema </span>
+<a name="l00034"></a>00034 <span class="comment">///override sets.</summary></span>
+<a name="l00035"></a><a class="code" href="class_fdo_rdbms_ov_physical_schema_mapping.html">00035</a> <span class="comment"></span><span class="keyword">class </span><a class="code" href="class_fdo_rdbms_ov_physical_schema_mapping.html">FdoRdbmsOvPhysicalSchemaMapping</a> : <span class="keyword">public</span> FdoPhysicalSchemaMapping
+<a name="l00036"></a>00036 {
+<a name="l00038"></a>00038 <span class="keyword">public</span>:<span class="comment"></span>
+<a name="l00039"></a>00039 <span class="comment"> ///<summary>Gets the collection of class overrides for this schema </span>
+<a name="l00040"></a>00040 <span class="comment"> ///override set.</summary></span>
+<a name="l00041"></a>00041 <span class="comment"> /// <returns>Returns FdoRdbmsOvReadOnlyClassCollection</returns></span>
+<a name="l00042"></a>00042 <span class="comment"></span> <a class="code" href="_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html#9b6afd7f3f2f73a361844d7bff18436f">FDORDBMS_OV_API</a> <a class="code" href="class_fdo_rdbms_ov_read_only_class_collection.html">FdoRdbmsOvReadOnlyClassCollection</a>* <a class="code" href="class_fdo_rdbms_ov_physical_schema_mapping_645f9e612eb208b50977253407fb25ff.html#645f9e612eb208b50977253407fb25ff">GetClasses</a>();
+<a name="l00044"></a>00044 <span class="comment"> ///<summary>Gets the table mapping</summary></span>
+<a name="l00045"></a>00045 <span class="comment"> ///<returns>Returns the table mapping</returns></span>
+<a name="l00046"></a>00046 <span class="comment"></span> <a class="code" href="_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html#9b6afd7f3f2f73a361844d7bff18436f">FDORDBMS_OV_API</a> FdoSmOvTableMappingType <a class="code" href="class_fdo_rdbms_ov_physical_schema_mapping_11557baeabbdcc1a1fcc72dbf45d4552.html#11557baeabbdcc1a1fcc72dbf45d4552">GetTableMapping</a>();
+<a name="l00047"></a>00047 <span class="comment"></span>
+<a name="l00048"></a>00048 <span class="comment"> ///<summary>Sets the table mapping</summary></span>
+<a name="l00049"></a>00049 <span class="comment"> /// <param name="mappingType">Input the mapping type</param></span>
+<a name="l00050"></a>00050 <span class="comment"> ///<returns>Returns nothing</returns></span>
+<a name="l00051"></a>00051 <span class="comment"></span> <a class="code" href="_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html#9b6afd7f3f2f73a361844d7bff18436f">FDORDBMS_OV_API</a> <span class="keywordtype">void</span> <a class="code" href="class_fdo_rdbms_ov_physical_schema_mapping_06c7286190a76e961adfa3fda7e9859b.html#06c7286190a76e961adfa3fda7e9859b">SetTableMapping</a>(FdoSmOvTableMappingType mappingType);
+<a name="l00053"></a>00053 <span class="comment"> ///<summary>Gets the default geometric column type for newly-created geometric properties</summary></span>
+<a name="l00054"></a>00054 <span class="comment"> ///<returns>Returns the default geometric column type</returns></span>
+<a name="l00055"></a>00055 <span class="comment"></span> <a class="code" href="_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html#9b6afd7f3f2f73a361844d7bff18436f">FDORDBMS_OV_API</a> FdoSmOvGeometricColumnType <a class="code" href="class_fdo_rdbms_ov_physical_schema_mapping_653d1d44a2788211776eb485a5e559d1.html#653d1d44a2788211776eb485a5e559d1">GetGeometricColumnType</a>();
+<a name="l00056"></a>00056 <span class="comment"></span>
+<a name="l00057"></a>00057 <span class="comment"> ///<summary>Sets default geometric column type for newly-created geometric properties</summary></span>
+<a name="l00058"></a>00058 <span class="comment"> /// <param name="columnType">Input the default geometric column type</param></span>
+<a name="l00059"></a>00059 <span class="comment"> ///<returns>Returns nothing</returns></span>
+<a name="l00060"></a>00060 <span class="comment"></span> <a class="code" href="_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html#9b6afd7f3f2f73a361844d7bff18436f">FDORDBMS_OV_API</a> <span class="keywordtype">void</span> <a class="code" href="class_fdo_rdbms_ov_physical_schema_mapping_052d29b735fbe5300b6220ed14e5b69c.html#052d29b735fbe5300b6220ed14e5b69c">SetGeometricColumnType</a>(FdoSmOvGeometricColumnType columnType);
+<a name="l00061"></a>00061 <span class="comment"></span>
+<a name="l00062"></a>00062 <span class="comment"> ///<summary>Gets the default geometric content type for newly-created geometric properties</summary></span>
+<a name="l00063"></a>00063 <span class="comment"> ///<returns>Returns the default geometric content type</returns></span>
+<a name="l00064"></a>00064 <span class="comment"></span> <a class="code" href="_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html#9b6afd7f3f2f73a361844d7bff18436f">FDORDBMS_OV_API</a> FdoSmOvGeometricContentType <a class="code" href="class_fdo_rdbms_ov_physical_schema_mapping_4548da0330caee9645a487b476ccaca8.html#4548da0330caee9645a487b476ccaca8">GetGeometricContentType</a>();
+<a name="l00066"></a>00066 <span class="comment"> ///<summary>Sets default geometric content type for newly-created geometric properties</summary></span>
+<a name="l00067"></a>00067 <span class="comment"> /// <param name="contentType">Input the default geometric content type</param></span>
+<a name="l00069"></a>00069 <span class="comment"></span> <a class="code" href="_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html#9b6afd7f3f2f73a361844d7bff18436f">FDORDBMS_OV_API</a> <span class="keywordtype">void</span> <a class="code" href="class_fdo_rdbms_ov_physical_schema_mapping_d7d73849b4f9326288e88ba27c0fc45f.html#d7d73849b4f9326288e88ba27c0fc45f">SetGeometricContentType</a>(FdoSmOvGeometricContentType contentType);
+<a name="l00071"></a>00071 <span class="comment"> ///<summary>Gets the settings for AutoGenerating classes for this feature</span>
+<a name="l00072"></a>00072 <span class="comment"> ///schema from the physical schema of the connected datastore.</span>
+<a name="l00073"></a>00073 <span class="comment"> ///</summary></span>
+<a name="l00074"></a>00074 <span class="comment"> ///<returns>Returns FdoRdbmsOvSchemaAutoGeneration</returns></span>
+<a name="l00075"></a>00075 <span class="comment"></span> <a class="code" href="_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html#9b6afd7f3f2f73a361844d7bff18436f">FDORDBMS_OV_API</a> <a class="code" href="class_fdo_rdbms_ov_schema_auto_generation.html">FdoRdbmsOvSchemaAutoGeneration</a>* <a class="code" href="class_fdo_rdbms_ov_physical_schema_mapping_ec2811d5d0786b98114b418d82b73743.html#ec2811d5d0786b98114b418d82b73743">GetAutoGeneration</a>();
+<a name="l00077"></a>00077 <span class="comment"> ///<summary>Sets class autogeneration settings.</summary></span>
+<a name="l00078"></a>00078 <span class="comment"> /// <param name="autoGeneration"></span>
+<a name="l00079"></a>00079 <span class="comment"> /// Input the autogeneration settings. If NULL then no schema autogeneration</span>
+<a name="l00080"></a>00080 <span class="comment"> /// takes place.</span>
+<a name="l00081"></a>00081 <span class="comment"> /// </param></span>
+<a name="l00082"></a>00082 <span class="comment"> ///<returns>Returns nothing</returns></span>
+<a name="l00083"></a>00083 <span class="comment"></span> <a class="code" href="_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html#9b6afd7f3f2f73a361844d7bff18436f">FDORDBMS_OV_API</a> <span class="keywordtype">void</span> <a class="code" href="class_fdo_rdbms_ov_physical_schema_mapping_b0626ba328793b256547581795c7800c.html#b0626ba328793b256547581795c7800c">SetAutoGeneration</a>(<a class="code" href="class_fdo_rdbms_ov_schema_auto_generation.html">FdoRdbmsOvSchemaAutoGeneration</a>* autoGeneration);
+<a name="l00085"></a>00085 <span class="comment">//DOM-IGNORE-BEGIN</span>
+<a name="l00087"></a>00087 <a class="code" href="_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html#9b6afd7f3f2f73a361844d7bff18436f">FDORDBMS_OV_API</a> <span class="keywordtype">void</span> <a class="code" href="class_fdo_rdbms_ov_physical_schema_mapping_50943de96e62f86ca5d7a9446d907acd.html#50943de96e62f86ca5d7a9446d907acd">SetParent</a>(FdoPhysicalElementMapping* value);
+<a name="l00089"></a>00089 <a class="code" href="_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html#9b6afd7f3f2f73a361844d7bff18436f">FDORDBMS_OV_API</a> FdoXmlSaxHandler* <a class="code" href="class_fdo_rdbms_ov_physical_schema_mapping_1c5c4049eb5666870d94658cc6d81c35.html#1c5c4049eb5666870d94658cc6d81c35">XmlStartElement</a>(
+<a name="l00090"></a>00090 FdoXmlSaxContext* context,
+<a name="l00091"></a>00091 FdoString* uri,
+<a name="l00092"></a>00092 FdoString* name,
+<a name="l00093"></a>00093 FdoString* qname,
+<a name="l00094"></a>00094 FdoXmlAttributeCollection* atts
+<a name="l00095"></a>00095 );
+<a name="l00096"></a>00096 <span class="comment">//DOM-IGNORE-END</span>
+<a name="l00098"></a>00098 <span class="keyword">protected</span>:
+<a name="l00099"></a>00099 <a class="code" href="_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html#9b6afd7f3f2f73a361844d7bff18436f">FDORDBMS_OV_API</a> <a class="code" href="class_fdo_rdbms_ov_physical_schema_mapping_0709948feb750e1ab594e7e7128a3242.html#0709948feb750e1ab594e7e7128a3242">FdoRdbmsOvPhysicalSchemaMapping</a>();
+<a name="l00100"></a>00100 <a class="code" href="_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html#9b6afd7f3f2f73a361844d7bff18436f">FDORDBMS_OV_API</a> <a class="code" href="class_fdo_rdbms_ov_physical_schema_mapping_0709948feb750e1ab594e7e7128a3242.html#0709948feb750e1ab594e7e7128a3242">FdoRdbmsOvPhysicalSchemaMapping</a>(FdoString* name);
+<a name="l00101"></a>00101 <a class="code" href="_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html#9b6afd7f3f2f73a361844d7bff18436f">FDORDBMS_OV_API</a> <span class="keyword">virtual</span> <a class="code" href="class_fdo_rdbms_ov_physical_schema_mapping_d70b968a3c44bb2c0eff6beebf4bae17.html#d70b968a3c44bb2c0eff6beebf4bae17">~FdoRdbmsOvPhysicalSchemaMapping</a>();
+<a name="l00103"></a>00103 <span class="comment">// Initialize this element from its XML attributes</span>
+<a name="l00104"></a>00104 <a class="code" href="_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html#9b6afd7f3f2f73a361844d7bff18436f">FDORDBMS_OV_API</a> <span class="keyword">virtual</span> <span class="keywordtype">void</span> <a class="code" href="class_fdo_rdbms_ov_physical_schema_mapping_3346828609c0761c0f9a35ce1da88cab.html#3346828609c0761c0f9a35ce1da88cab">InitFromXml</a>(FdoXmlSaxContext* pContext, FdoXmlAttributeCollection* attrs);
+<a name="l00106"></a>00106 <span class="comment">// Serialize this property to XML.</span>
+<a name="l00107"></a>00107 <a class="code" href="_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html#9b6afd7f3f2f73a361844d7bff18436f">FDORDBMS_OV_API</a> <span class="keyword">virtual</span> <span class="keywordtype">void</span> <a class="code" href="class_fdo_rdbms_ov_physical_schema_mapping_17b84ebbae4f6b661f3d116e4b3b6311.html#17b84ebbae4f6b661f3d116e4b3b6311">_writeXml</a>(FdoXmlWriter* xmlWriter, <span class="keyword">const</span> FdoXmlFlags* flags);
+<a name="l00109"></a>00109 <span class="comment">// Write any provider-specific parts that become XML attributes.</span>
+<a name="l00110"></a>00110 <a class="code" href="_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html#9b6afd7f3f2f73a361844d7bff18436f">FDORDBMS_OV_API</a> <span class="keyword">virtual</span> <span class="keywordtype">void</span> <a class="code" href="class_fdo_rdbms_ov_physical_schema_mapping_0754e6d7807cd92a2b6cd1e3b3baa91d.html#0754e6d7807cd92a2b6cd1e3b3baa91d">_writeXmlAttributes</a>(FdoXmlWriter* xmlWriter, <span class="keyword">const</span> FdoXmlFlags* flags);
+<a name="l00112"></a>00112 <span class="comment">// Write any provider-specific parts that become XML elements.</span>
+<a name="l00113"></a>00113 <a class="code" href="_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html#9b6afd7f3f2f73a361844d7bff18436f">FDORDBMS_OV_API</a> <span class="keyword">virtual</span> <span class="keywordtype">void</span> <a class="code" href="class_fdo_rdbms_ov_physical_schema_mapping_4e67fff5dc13e27ade8d86c10078d450.html#4e67fff5dc13e27ade8d86c10078d450">_writeXmlElements</a>(FdoXmlWriter* xmlWriter, <span class="keyword">const</span> FdoXmlFlags* flags);
+<a name="l00115"></a>00115 <span class="comment">// Get a writable version of the class override collection.</span>
+<a name="l00116"></a>00116 <a class="code" href="_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html#9b6afd7f3f2f73a361844d7bff18436f">FDORDBMS_OV_API</a> <a class="code" href="class_fdo_rdbms_ov_class_collection.html">FdoRdbmsOvClassCollection</a>* <a class="code" href="class_fdo_rdbms_ov_physical_schema_mapping_58a9289ebd2279e26f4cbea8986b944c.html#58a9289ebd2279e26f4cbea8986b944c">GetRdbmsClasses</a>();
+<a name="l00118"></a>00118 <span class="comment">// Create a class override. Each provider that supports class overrides</span>
+<a name="l00119"></a>00119 <span class="comment">// must override this function.</span>
+<a name="l00120"></a><a class="code" href="class_fdo_rdbms_ov_physical_schema_mapping_c4bef3220580bf67d9a8cf5adc1b3a7b.html#c4bef3220580bf67d9a8cf5adc1b3a7b">00120</a> <a class="code" href="_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html#9b6afd7f3f2f73a361844d7bff18436f">FDORDBMS_OV_API</a> <span class="keyword">virtual</span> <a class="code" href="class_fdo_rdbms_ov_class_definition.html">FdoRdbmsOvClassDefinition</a>* <a class="code" href="class_fdo_rdbms_ov_physical_schema_mapping_c4bef3220580bf67d9a8cf5adc1b3a7b.html#c4bef3220580bf67d9a8cf5adc1b3a7b">CreateClass</a>(
+<a name="l00121"></a>00121 FdoXmlSaxContext* context,
+<a name="l00122"></a>00122 FdoXmlAttributeCollection* atts
+<a name="l00123"></a>00123 )
+<a name="l00124"></a>00124 {
+<a name="l00125"></a>00125 <span class="comment">// TODO: exception</span>
+<a name="l00126"></a>00126 <span class="keywordflow">return</span> NULL;
+<a name="l00127"></a>00127 }
+<a name="l00128"></a>00128
+<a name="l00129"></a>00129 <span class="comment">// Add a class override to this schema override set. Each provider that </span>
+<a name="l00130"></a>00130 <span class="comment">// supports class overrides must override this function.</span>
+<a name="l00131"></a><a class="code" href="class_fdo_rdbms_ov_physical_schema_mapping_4cc2d72e5cc5cc4ec3d542b175c93f9d.html#4cc2d72e5cc5cc4ec3d542b175c93f9d">00131</a> <a class="code" href="_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html#9b6afd7f3f2f73a361844d7bff18436f">FDORDBMS_OV_API</a> <span class="keyword">virtual</span> <span class="keywordtype">void</span> <a class="code" href="class_fdo_rdbms_ov_physical_schema_mapping_4cc2d72e5cc5cc4ec3d542b175c93f9d.html#4cc2d72e5cc5cc4ec3d542b175c93f9d">AddClass</a>(
+<a name="l00132"></a>00132 <a class="code" href="class_fdo_rdbms_ov_class_definition.html">FdoRdbmsOvClassDefinition</a>* pClass
+<a name="l00133"></a>00133 )
+<a name="l00134"></a>00134 {
+<a name="l00135"></a>00135 <span class="comment">// TODO: exception</span>
+<a name="l00136"></a>00136 }
+<a name="l00137"></a>00137
+<a name="l00138"></a>00138 <span class="keyword">private</span>:
+<a name="l00139"></a>00139 FdoSmOvTableMappingType mMappingType;
+<a name="l00140"></a>00140 FdoSmOvGeometricColumnType mDefaultGeometricColumnType;
+<a name="l00141"></a>00141 FdoSmOvGeometricContentType mDefaultGeometricContentType;
+<a name="l00142"></a>00142 <a class="code" href="_rdbms_ov_class_collection_8h_26ee985d3d48ae9904b2d8f4528b6b9c.html#26ee985d3d48ae9904b2d8f4528b6b9c">FdoRdbmsOvClassesP</a> mClasses;
+<a name="l00143"></a>00143 <a class="code" href="_rdbms_ov_schema_auto_generation_8h_499cf448778c4955e4e0f6776244c105.html#499cf448778c4955e4e0f6776244c105">FdoRdbmsOvSchemaAutoGenerationP</a> mAutoGeneration;
+<a name="l00144"></a>00144 };
+<a name="l00145"></a>00145 <span class="comment"></span>
+<a name="l00146"></a>00146 <span class="comment">///<summary>FdoRdbmsOvSchemaMappingP is a FdoPtr on FdoRdbmsOvPhysicalSchemaMapping, provided for convenience.</summary></span>
+<a name="l00147"></a><a class="code" href="_rdbms_ov_physical_schema_mapping_8h_02cd08b9000105a1137aa76047cbd783.html#02cd08b9000105a1137aa76047cbd783">00147</a> <span class="comment"></span><span class="keyword">typedef</span> FdoPtr<FdoRdbmsOvPhysicalSchemaMapping> <a class="code" href="_rdbms_ov_physical_schema_mapping_8h_02cd08b9000105a1137aa76047cbd783.html#02cd08b9000105a1137aa76047cbd783">FdoRdbmsOvSchemaMappingP</a>;
+<a name="l00148"></a>00148
+<a name="l00149"></a>00149 <span class="preprocessor">#endif</span>
+<a name="l00150"></a>00150 <span class="preprocessor"></span>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/ODBC/_rdbms_ov_physical_schema_mapping_8h.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_physical_schema_mapping_8h.html?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_rdbms_ov_physical_schema_mapping_8h.html 2006-12-01 20:39:06+0000
@@ -0,0 +1,74 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<h1>RdbmsOvPhysicalSchemaMapping.h File Reference</h1>
+<p>
+<code>#include <Fdo/Commands/Schema/PhysicalSchemaMapping.h></code><br>
+<code>#include <Utilities/SchemaMgr/Overrides/TableMappingType.h></code><br>
+<code>#include <<a class="el" href="_rdbms_ov_class_collection_8h-source.html">Rdbms/Override/RdbmsOvClassCollection.h</a>></code><br>
+<code>#include <<a class="el" href="_rdbms_ov_schema_auto_generation_8h-source.html">Rdbms/Override/RdbmsOvSchemaAutoGeneration.h</a>></code><br>
+<p>
+Include dependency graph for RdbmsOvPhysicalSchemaMapping.h:<p><center><img src="_rdbms_ov_physical_schema_mapping_8h__incl.png" border="0" usemap="#RdbmsOvPhysicalSchemaMapping.h_map" alt=""></center>
+<map name="RdbmsOvPhysicalSchemaMapping.h_map">
+<area href="_rdbms_ov_8h.html" shape="rect" coords="706,260,900,287" alt="">
+<area href="_rdbms_ov_class_collection_8h.html" shape="rect" coords="335,260,623,287" alt="">
+<area href="_rdbms_ov_schema_auto_generation_8h.html" shape="rect" coords="310,311,648,337" alt="">
+</map>
+<p>
+This graph shows which files directly or indirectly include this file:<p><center><img src="_rdbms_ov_physical_schema_mapping_8h__dep__incl.png" border="0" usemap="#RdbmsOvPhysicalSchemaMapping.hdep_map" alt=""></center>
+<map name="RdbmsOvPhysicalSchemaMapping.hdep_map">
+<area href="_odbc_ov_physical_schema_mapping_8h.html" shape="rect" coords="301,7,533,33" alt="">
+</map>
+<p>
+<a href="_rdbms_ov_physical_schema_mapping_8h-source.html">Go to the source code of this file.</a><table border="0" cellpadding="0" cellspacing="0">
+<tr><td></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">class </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_rdbms_ov_physical_schema_mapping.html">FdoRdbmsOvPhysicalSchemaMapping</a></td></tr>
+<tr><td class="mdescLeft"> </td><td class="mdescRight">Abstract base class for RDBMS type provider schema override sets. <a href="class_fdo_rdbms_ov_physical_schema_mapping.html#_details">More...</a><br></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">typedef FdoPtr< <a class="el" href="class_fdo_rdbms_ov_physical_schema_mapping.html">FdoRdbmsOvPhysicalSchemaMapping</a> > </td><td class="memItemRight" valign="bottom"><a class="el" href="_rdbms_ov_physical_schema_mapping_8h_02cd08b9000105a1137aa76047cbd783.html#02cd08b9000105a1137aa76047cbd783">FdoRdbmsOvSchemaMappingP</a></td></tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/ODBC/_rdbms_ov_physical_schema_mapping_8h_02cd08b9000105a1137aa76047cbd783.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_physical_schema_mapping_8h_02cd08b9000105a1137aa76047cbd783.html?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_rdbms_ov_physical_schema_mapping_8h_02cd08b9000105a1137aa76047cbd783.html 2006-12-01 20:39:06+0000
@@ -0,0 +1,74 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="nav">
+<a class="el" href="_rdbms_ov_physical_schema_mapping_8h.html">RdbmsOvPhysicalSchemaMapping.h</a></div>
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="_rdbms_ov_physical_schema_mapping_8h_02cd08b9000105a1137aa76047cbd783.html#02cd08b9000105a1137aa76047cbd783">FdoRdbmsOvSchemaMappingP</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="02cd08b9000105a1137aa76047cbd783"></a><!-- doxytag: member="RdbmsOvPhysicalSchemaMapping.h::FdoRdbmsOvSchemaMappingP" ref="02cd08b9000105a1137aa76047cbd783" args="" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">typedef FdoPtr<<a class="el" href="class_fdo_rdbms_ov_physical_schema_mapping.html">FdoRdbmsOvPhysicalSchemaMapping</a>> <a class="el" href="_rdbms_ov_physical_schema_mapping_8h_02cd08b9000105a1137aa76047cbd783.html#02cd08b9000105a1137aa76047cbd783">FdoRdbmsOvSchemaMappingP</a> </td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+<p>
+Definition at line <a class="el" href="_rdbms_ov_physical_schema_mapping_8h-source.html#l00147">147</a> of file <a class="el" href="_rdbms_ov_physical_schema_mapping_8h-source.html">RdbmsOvPhysicalSchemaMapping.h</a>. </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/ODBC/_rdbms_ov_physical_schema_mapping_8h__dep__incl.map
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_physical_schema_mapping_8h__dep__incl.map?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_rdbms_ov_physical_schema_mapping_8h__dep__incl.map 2006-12-01 20:39:06+0000
@@ -0,0 +1,2 @@
+base referer
+rect $_odbc_ov_physical_schema_mapping_8h.html 301,7 533,33
Added: trunk/www/docs/ODBC/_rdbms_ov_physical_schema_mapping_8h__dep__incl.md5
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_physical_schema_mapping_8h__dep__incl.md5?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_rdbms_ov_physical_schema_mapping_8h__dep__incl.md5 2006-12-01 20:39:06+0000
@@ -0,0 +1 @@
+8cc66ad93016134b7dd9e82e55690ef9
Added: trunk/www/docs/ODBC/_rdbms_ov_physical_schema_mapping_8h__dep__incl.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_physical_schema_mapping_8h__dep__incl.png?view=auto&rev=94
Added: trunk/www/docs/ODBC/_rdbms_ov_physical_schema_mapping_8h__incl.map
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_physical_schema_mapping_8h__incl.map?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_rdbms_ov_physical_schema_mapping_8h__incl.map 2006-12-01 20:39:06+0000
@@ -0,0 +1,4 @@
+base referer
+rect $_rdbms_ov_8h.html 706,260 900,287
+rect $_rdbms_ov_class_collection_8h.html 335,260 623,287
+rect $_rdbms_ov_schema_auto_generation_8h.html 310,311 648,337
Added: trunk/www/docs/ODBC/_rdbms_ov_physical_schema_mapping_8h__incl.md5
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_physical_schema_mapping_8h__incl.md5?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_rdbms_ov_physical_schema_mapping_8h__incl.md5 2006-12-01 20:39:06+0000
@@ -0,0 +1 @@
+f59b184c81828cb4474de56c87d830a8
Added: trunk/www/docs/ODBC/_rdbms_ov_physical_schema_mapping_8h__incl.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_physical_schema_mapping_8h__incl.png?view=auto&rev=94
Added: trunk/www/docs/ODBC/_rdbms_ov_property_definition_8h-source.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_property_definition_8h-source.html?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_rdbms_ov_property_definition_8h-source.html 2006-12-01 20:39:06+0000
@@ -0,0 +1,94 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<h1>RdbmsOvPropertyDefinition.h</h1><a href="_rdbms_ov_property_definition_8h.html">Go to the documentation of this file.</a><div class="fragment"><pre class="fragment"><a name="l00001"></a>00001 <span class="preprocessor">#ifndef FDO_RDBMSOVPROPERTYDEFINITION_H</span>
+<a name="l00002"></a>00002 <span class="preprocessor"></span><span class="preprocessor">#define FDO_RDBMSOVPROPERTYDEFINITION_H</span>
+<a name="l00025"></a>00025 <span class="preprocessor">#include <Fdo/Commands/Schema/PhysicalPropertyMapping.h></span>
+<a name="l00026"></a>00026 <span class="preprocessor">#include <<a class="code" href="_rdbms_ov_8h.html">Rdbms/Override/RdbmsOv.h</a>></span>
+<a name="l00027"></a>00027 <span class="comment"></span>
+<a name="l00028"></a>00028 <span class="comment">///<summary>Abstract class defining physical schema overrides for a property</span>
+<a name="l00029"></a>00029 <span class="comment">///definition.</summary></span>
+<a name="l00030"></a><a class="code" href="class_fdo_rdbms_ov_property_definition.html">00030</a> <span class="comment"></span><span class="keyword">class </span><a class="code" href="class_fdo_rdbms_ov_property_definition.html">FdoRdbmsOvPropertyDefinition</a> : <span class="keyword">public</span> FdoPhysicalPropertyMapping
+<a name="l00031"></a>00031 {
+<a name="l00032"></a>00032 <span class="keyword">public</span>:
+<a name="l00033"></a>00033 <span class="comment">//DOM-IGNORE-BEGIN</span>
+<a name="l00034"></a>00034 <span class="comment">// Serialize this property to XML. Not part of the API.</span>
+<a name="l00035"></a>00035 <a class="code" href="_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html#9b6afd7f3f2f73a361844d7bff18436f">FDORDBMS_OV_API</a> <span class="keyword">virtual</span> <span class="keywordtype">void</span> <a class="code" href="class_fdo_rdbms_ov_property_definition_cc9a4992e82b491746578b2373159765.html#cc9a4992e82b491746578b2373159765">_writeXml</a>(FdoXmlWriter* xmlWriter, <span class="keyword">const</span> FdoXmlFlags* flags);
+<a name="l00037"></a>00037 <span class="comment">// Makes SetParent function public</span>
+<a name="l00038"></a>00038 <a class="code" href="_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html#9b6afd7f3f2f73a361844d7bff18436f">FDORDBMS_OV_API</a> <span class="keywordtype">void</span> <a class="code" href="class_fdo_rdbms_ov_property_definition_bd6d7567bee9cc782c1cbba4389cda93.html#bd6d7567bee9cc782c1cbba4389cda93">SetParent</a>(FdoPhysicalElementMapping* value);
+<a name="l00040"></a>00040 <span class="comment">//DOM-IGNORE-END</span>
+<a name="l00042"></a>00042 <span class="keyword">protected</span>:
+<a name="l00043"></a>00043 <a class="code" href="_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html#9b6afd7f3f2f73a361844d7bff18436f">FDORDBMS_OV_API</a> <a class="code" href="class_fdo_rdbms_ov_property_definition_823cd2ad36c41c015df90b31ae19750f.html#823cd2ad36c41c015df90b31ae19750f">FdoRdbmsOvPropertyDefinition</a>();
+<a name="l00044"></a>00044 <a class="code" href="_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html#9b6afd7f3f2f73a361844d7bff18436f">FDORDBMS_OV_API</a> <a class="code" href="class_fdo_rdbms_ov_property_definition_823cd2ad36c41c015df90b31ae19750f.html#823cd2ad36c41c015df90b31ae19750f">FdoRdbmsOvPropertyDefinition</a>(FdoString *name);
+<a name="l00045"></a>00045 <a class="code" href="_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html#9b6afd7f3f2f73a361844d7bff18436f">FDORDBMS_OV_API</a> <span class="keyword">virtual</span> <a class="code" href="class_fdo_rdbms_ov_property_definition_86f4ba556a337a842a3cc733a2224da9.html#86f4ba556a337a842a3cc733a2224da9">~FdoRdbmsOvPropertyDefinition</a>();
+<a name="l00047"></a>00047 <span class="comment">// Serialize this property to XML. </span>
+<a name="l00048"></a>00048 <a class="code" href="_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html#9b6afd7f3f2f73a361844d7bff18436f">FDORDBMS_OV_API</a> <span class="keyword">virtual</span> <span class="keywordtype">void</span> <a class="code" href="class_fdo_rdbms_ov_property_definition_a394465c946ccaa44822e0ca5c5ef7a6.html#a394465c946ccaa44822e0ca5c5ef7a6">_writeXmlContents</a>(FdoXmlWriter* xmlWriter, <span class="keyword">const</span> FdoXmlFlags* flags);
+<a name="l00049"></a>00049 };
+<a name="l00050"></a>00050 <span class="comment"></span>
+<a name="l00051"></a>00051 <span class="comment">///<summary>FdoRdbmsOvPropertyP is a FdoPtr on FdoRdbmsOvPropertyDefinition, provided for convenience.</summary></span>
+<a name="l00052"></a><a class="code" href="_rdbms_ov_property_definition_8h_24fedbc49697b547f171502e79aa9797.html#24fedbc49697b547f171502e79aa9797">00052</a> <span class="comment"></span><span class="keyword">typedef</span> FdoPtr<FdoRdbmsOvPropertyDefinition> <a class="code" href="_rdbms_ov_property_definition_8h_24fedbc49697b547f171502e79aa9797.html#24fedbc49697b547f171502e79aa9797">FdoRdbmsOvPropertyP</a>;
+<a name="l00054"></a>00054 <span class="preprocessor">#endif</span>
+<a name="l00055"></a>00055 <span class="preprocessor"></span>
+</pre></div><!-- footer.html -->
+ <hr>
+ <tr>
+ <td align="right"><font size="-2"><a href="mailto:isd.docs at autodesk.com&subject=FDO%20Provider%20for%20ODBC%20API%20documentation">Comments?</a></font></td>
+ <!-- The logo can go in another cell, when we get one -->
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/ODBC/_rdbms_ov_property_definition_8h.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_property_definition_8h.html?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_rdbms_ov_property_definition_8h.html 2006-12-01 20:39:06+0000
@@ -0,0 +1,76 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<h1>RdbmsOvPropertyDefinition.h File Reference</h1>
+<p>
+<code>#include <Fdo/Commands/Schema/PhysicalPropertyMapping.h></code><br>
+<p>
+Include dependency graph for RdbmsOvPropertyDefinition.h:<p><center><img src="_rdbms_ov_property_definition_8h__incl.png" border="0" usemap="#RdbmsOvPropertyDefinition.h_map" alt=""></center>
+<map name="RdbmsOvPropertyDefinition.h_map">
+<area href="_rdbms_ov_8h.html" shape="rect" coords="330,58,524,84" alt="">
+</map>
+<p>
+This graph shows which files directly or indirectly include this file:<p><center><img src="_rdbms_ov_property_definition_8h__dep__incl.png" border="0" usemap="#RdbmsOvPropertyDefinition.hdep_map" alt=""></center>
+<map name="RdbmsOvPropertyDefinition.hdep_map">
+<area href="_odbc_ov_property_definition_8h.html" shape="rect" coords="295,7,484,34" alt="">
+<area href="_rdbms_ov_data_property_definition_8h.html" shape="rect" coords="275,58,504,84" alt="">
+<area href="_rdbms_ov_geometric_property_definition_8h.html" shape="rect" coords="259,108,520,135" alt="">
+<area href="_rdbms_ov_object_property_definition_8h.html" shape="rect" coords="269,210,509,236" alt="">
+<area href="_rdbms_ov_property_definition_collection_8h.html" shape="rect" coords="260,159,519,186" alt="">
+<area href="_odbc_ov_data_property_definition_8h.html" shape="rect" coords="595,7,813,34" alt="">
+<area href="_odbc_ov_geometric_property_definition_8h.html" shape="rect" coords="577,58,831,84" alt="">
+<area href="_odbc_ov_property_definition_collection_8h.html" shape="rect" coords="580,108,828,135" alt="">
+<area href="_rdbms_ov_class_definition_8h.html" shape="rect" coords="613,159,795,186" alt="">
+<area href="_rdbms_ov_association_property_definition_8h.html" shape="rect" coords="569,210,839,236" alt="">
+</map>
+<p>
+<a href="_rdbms_ov_property_definition_8h-source.html">Go to the source code of this file.</a><table border="0" cellpadding="0" cellspacing="0">
+<tr><td></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">class </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_rdbms_ov_property_definition.html">FdoRdbmsOvPropertyDefinition</a></td></tr>
+<tr><td class="mdescLeft"> </td><td class="mdescRight">Abstract class defining physical schema overrides for a property definition. <a href="class_fdo_rdbms_ov_property_definition.html#_details">More...</a><br></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">typedef FdoPtr< <a class="el" href="class_fdo_rdbms_ov_property_definition.html">FdoRdbmsOvPropertyDefinition</a> > </td><td class="memItemRight" valign="bottom"><a class="el" href="_rdbms_ov_property_definition_8h_24fedbc49697b547f171502e79aa9797.html#24fedbc49697b547f171502e79aa9797">FdoRdbmsOvPropertyP</a></td></tr>
+</table>
+<!-- footer.html -->
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/ODBC/_rdbms_ov_property_definition_8h_24fedbc49697b547f171502e79aa9797.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_property_definition_8h_24fedbc49697b547f171502e79aa9797.html?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_rdbms_ov_property_definition_8h_24fedbc49697b547f171502e79aa9797.html 2006-12-01 20:39:06+0000
@@ -0,0 +1,74 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ <li><a href="files.html"><span>Files</span></a></li>
+ </ul></div>
+<div class="nav">
+<a class="el" href="_rdbms_ov_property_definition_8h.html">RdbmsOvPropertyDefinition.h</a></div>
+<table cellspacing="0" cellpadding="0" border="0">
+ <tr>
+ <td valign="top">
+ <div class="navtab">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="_rdbms_ov_property_definition_8h_24fedbc49697b547f171502e79aa9797.html#24fedbc49697b547f171502e79aa9797">FdoRdbmsOvPropertyP</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="24fedbc49697b547f171502e79aa9797"></a><!-- doxytag: member="RdbmsOvPropertyDefinition.h::FdoRdbmsOvPropertyP" ref="24fedbc49697b547f171502e79aa9797" args="" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">typedef FdoPtr<<a class="el" href="class_fdo_rdbms_ov_property_definition.html">FdoRdbmsOvPropertyDefinition</a>> <a class="el" href="_rdbms_ov_property_definition_8h_24fedbc49697b547f171502e79aa9797.html#24fedbc49697b547f171502e79aa9797">FdoRdbmsOvPropertyP</a> </td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+<p>
+Definition at line <a class="el" href="_rdbms_ov_property_definition_8h-source.html#l00052">52</a> of file <a class="el" href="_rdbms_ov_property_definition_8h-source.html">RdbmsOvPropertyDefinition.h</a>. </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/ODBC/_rdbms_ov_property_definition_8h__dep__incl.map
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_property_definition_8h__dep__incl.map?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_rdbms_ov_property_definition_8h__dep__incl.map 2006-12-01 20:39:06+0000
@@ -0,0 +1,11 @@
+base referer
+rect $_odbc_ov_property_definition_8h.html 295,7 484,34
+rect $_rdbms_ov_data_property_definition_8h.html 275,58 504,84
+rect $_rdbms_ov_geometric_property_definition_8h.html 259,108 520,135
+rect $_rdbms_ov_object_property_definition_8h.html 269,210 509,236
+rect $_rdbms_ov_property_definition_collection_8h.html 260,159 519,186
+rect $_odbc_ov_data_property_definition_8h.html 595,7 813,34
+rect $_odbc_ov_geometric_property_definition_8h.html 577,58 831,84
+rect $_odbc_ov_property_definition_collection_8h.html 580,108 828,135
+rect $_rdbms_ov_class_definition_8h.html 613,159 795,186
+rect $_rdbms_ov_association_property_definition_8h.html 569,210 839,236
Added: trunk/www/docs/ODBC/_rdbms_ov_property_definition_8h__dep__incl.md5
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_property_definition_8h__dep__incl.md5?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_rdbms_ov_property_definition_8h__dep__incl.md5 2006-12-01 20:39:06+0000
@@ -0,0 +1 @@
+469b2f8cd00081c7d1317e487c8cb8fa
\ No newline at end of file
Added: trunk/www/docs/ODBC/_rdbms_ov_property_definition_8h__dep__incl.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_property_definition_8h__dep__incl.png?view=auto&rev=94
Binary file. No diff available.
Added: trunk/www/docs/ODBC/_rdbms_ov_property_definition_8h__incl.map
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_property_definition_8h__incl.map?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_rdbms_ov_property_definition_8h__incl.map 2006-12-01 20:39:06+0000
@@ -0,0 +1,2 @@
+base referer
+rect $_rdbms_ov_8h.html 330,58 524,84
Added: trunk/www/docs/ODBC/_rdbms_ov_property_definition_8h__incl.md5
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_property_definition_8h__incl.md5?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_rdbms_ov_property_definition_8h__incl.md5 2006-12-01 20:39:06+0000
@@ -0,0 +1 @@
+b607acd0180bb519b6d8b85447f4a664
Added: trunk/www/docs/ODBC/_rdbms_ov_property_definition_8h__incl.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_property_definition_8h__incl.png?view=auto&rev=94
Added: trunk/www/docs/ODBC/_rdbms_ov_property_definition_collection_8h-source.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_property_definition_collection_8h-source.html?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_rdbms_ov_property_definition_collection_8h-source.html 2006-12-01 20:39:06+0000
@@ -0,0 +1,122 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<h1>RdbmsOvPropertyDefinitionCollection.h</h1><a href="_rdbms_ov_property_definition_collection_8h.html">Go to the documentation of this file.</a><div class="fragment"><pre class="fragment"><a name="l00001"></a>00001 <span class="preprocessor">#ifndef FDO_RDBMSOVPROPERTYDEFINITIONCOLLECTION_H</span>
+<a name="l00002"></a>00002 <span class="preprocessor"></span><span class="preprocessor">#define FDO_RDBMSOVPROPERTYDEFINITIONCOLLECTION_H</span>
+<a name="l00003"></a>00003 <span class="preprocessor"></span><span class="comment">// </span>
+<a name="l00004"></a>00004 <span class="comment">//</span>
+<a name="l00005"></a>00005 <span class="comment">// Copyright (C) 2004-2006 Autodesk, Inc.</span>
+<a name="l00006"></a>00006 <span class="comment">// </span>
+<a name="l00007"></a>00007 <span class="comment">// This library is free software; you can redistribute it and/or</span>
+<a name="l00008"></a>00008 <span class="comment">// modify it under the terms of version 2.1 of the GNU Lesser</span>
+<a name="l00009"></a>00009 <span class="comment">// General Public License as published by the Free Software Foundation.</span>
+<a name="l00010"></a>00010 <span class="comment">// </span>
+<a name="l00011"></a>00011 <span class="comment">// This library is distributed in the hope that it will be useful,</span>
+<a name="l00012"></a>00012 <span class="comment">// but WITHOUT ANY WARRANTY; without even the implied warranty of</span>
+<a name="l00013"></a>00013 <span class="comment">// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU</span>
+<a name="l00014"></a>00014 <span class="comment">// Lesser General Public License for more details.</span>
+<a name="l00015"></a>00015 <span class="comment">// </span>
+<a name="l00016"></a>00016 <span class="comment">// You should have received a copy of the GNU Lesser General Public</span>
+<a name="l00017"></a>00017 <span class="comment">// License along with this library; if not, write to the Free Software</span>
+<a name="l00018"></a>00018 <span class="comment">// Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA</span>
+<a name="l00019"></a>00019 <span class="comment">// </span>
+<a name="l00020"></a>00020 <span class="comment"></span>
+<a name="l00021"></a>00021 <span class="comment">/// <library></span>
+<a name="l00022"></a>00022 <span class="comment">/// FdoRdbms.lib</span>
+<a name="l00023"></a>00023 <span class="comment">/// </library></span>
+<a name="l00024"></a>00024 <span class="comment"></span>
+<a name="l00025"></a>00025 <span class="preprocessor">#include <Fdo/Commands/Schema/PhysicalElementMappingCollection.h></span>
+<a name="l00026"></a>00026 <span class="preprocessor">#include <<a class="code" href="_rdbms_ov_property_definition_8h.html">Rdbms/Override/RdbmsOvPropertyDefinition.h</a>></span>
+<a name="l00028"></a>00028 <span class="comment">//DOM-IGNORE-BEGIN</span><span class="comment"></span>
+<a name="l00029"></a>00029 <span class="comment">///<summary>Concrete class defining physical schema overrides for a collection of property</span>
+<a name="l00030"></a>00030 <span class="comment">///definitions.</summary></span>
+<a name="l00031"></a><a class="code" href="class_fdo_rdbms_ov_property_definition_collection.html">00031</a> <span class="comment"></span><span class="keyword">class </span><a class="code" href="class_fdo_rdbms_ov_property_definition_collection.html">FdoRdbmsOvPropertyDefinitionCollection</a> : <span class="keyword">public</span> FdoPhysicalElementMappingCollection<FdoRdbmsOvPropertyDefinition>
+<a name="l00032"></a>00032 {
+<a name="l00033"></a>00033 <span class="keyword">public</span>:<span class="comment"></span>
+<a name="l00034"></a>00034 <span class="comment"> ///<summary>Constructs a default instance of an FdoRdbmsOvPropertyDefinitionCollection</summary></span>
+<a name="l00035"></a>00035 <span class="comment"> /// <returns>Returns FdoRdbmsOvPropertyDefinitionCollection</returns> </span>
+<a name="l00036"></a>00036 <span class="comment"></span> <span class="keyword">static</span> <a class="code" href="class_fdo_rdbms_ov_property_definition_collection.html">FdoRdbmsOvPropertyDefinitionCollection</a>* <a class="code" href="class_fdo_rdbms_ov_property_definition_collection_83e134c7680f3ac1852b9a8df6425f20.html#83e134c7680f3ac1852b9a8df6425f20">Create</a>();
+<a name="l00037"></a>00037 <span class="comment"></span>
+<a name="l00038"></a>00038 <span class="comment"> ///<summary>Constructs an instance of an FdoRdbmsOvPropertyDefinitionCollection using the specified arguments</summary></span>
+<a name="l00039"></a>00039 <span class="comment"> /// <param name="parent">Input parent</param> </span>
+<a name="l00040"></a>00040 <span class="comment"> /// <returns>Returns FdoRdbmsOvPropertyDefinitionCollection</returns> </span>
+<a name="l00041"></a>00041 <span class="comment"></span> <span class="keyword">static</span> <a class="code" href="class_fdo_rdbms_ov_property_definition_collection.html">FdoRdbmsOvPropertyDefinitionCollection</a>* <a class="code" href="class_fdo_rdbms_ov_property_definition_collection_83e134c7680f3ac1852b9a8df6425f20.html#83e134c7680f3ac1852b9a8df6425f20">Create</a>(FdoPhysicalElementMapping* parent);
+<a name="l00043"></a>00043 <span class="keyword">protected</span>:
+<a name="l00044"></a>00044 <a class="code" href="class_fdo_rdbms_ov_property_definition_collection_c1b7fccc469533409689a1606683fde0.html#c1b7fccc469533409689a1606683fde0">FdoRdbmsOvPropertyDefinitionCollection</a>();
+<a name="l00045"></a>00045 <a class="code" href="class_fdo_rdbms_ov_property_definition_collection_c1b7fccc469533409689a1606683fde0.html#c1b7fccc469533409689a1606683fde0">FdoRdbmsOvPropertyDefinitionCollection</a>(FdoPhysicalElementMapping* parent);
+<a name="l00046"></a>00046 <span class="keyword">virtual</span> <a class="code" href="class_fdo_rdbms_ov_property_definition_collection_ffbf059f678c27fd89119c764b1ef421.html#ffbf059f678c27fd89119c764b1ef421">~FdoRdbmsOvPropertyDefinitionCollection</a>();
+<a name="l00047"></a>00047 <span class="keyword">virtual</span> <span class="keywordtype">void</span> <a class="code" href="class_fdo_rdbms_ov_property_definition_collection_dd8070b745a257212667fe17c0b197f0.html#dd8070b745a257212667fe17c0b197f0">Dispose</a>();
+<a name="l00048"></a>00048 };
+<a name="l00049"></a>00049 <span class="comment"></span>
+<a name="l00050"></a>00050 <span class="comment">///<summary>FdoRdbmsOvPropertiesP is a FdoPtr on FdoRdbmsOvPropertyDefinitionCollection, provided for convenience.</summary></span>
+<a name="l00051"></a><a class="code" href="_rdbms_ov_property_definition_collection_8h_8a7a02562b4dcd8bbbf507c92753c27c.html#8a7a02562b4dcd8bbbf507c92753c27c">00051</a> <span class="comment"></span><span class="keyword">typedef</span> FdoPtr<FdoRdbmsOvPropertyDefinitionCollection> <a class="code" href="_rdbms_ov_property_definition_collection_8h_8a7a02562b4dcd8bbbf507c92753c27c.html#8a7a02562b4dcd8bbbf507c92753c27c">FdoRdbmsOvPropertiesP</a>;
+<a name="l00052"></a>00052 <span class="comment">//DOM-IGNORE-END</span>
+<a name="l00053"></a>00053 <span class="comment"></span>
+<a name="l00054"></a>00054 <span class="comment">///<summary>Collection of property overrides for an RDBMS-type provider.</span>
+<a name="l00055"></a>00055 <span class="comment">///Members cannot be added to or removed from this collection.</span>
+<a name="l00056"></a>00056 <span class="comment">///</summary></span>
+<a name="l00057"></a><a class="code" href="class_fdo_rdbms_ov_read_only_property_definition_collection.html">00057</a> <span class="comment"></span><span class="keyword">class </span><a class="code" href="class_fdo_rdbms_ov_read_only_property_definition_collection.html">FdoRdbmsOvReadOnlyPropertyDefinitionCollection</a> : <span class="keyword">public</span> FdoReadOnlyNamedCollection<FdoRdbmsOvPropertyDefinition,FdoRdbmsOvPropertyDefinitionCollection>
+<a name="l00058"></a>00058 {
+<a name="l00059"></a>00059 <span class="comment">//DOM-IGNORE-BEGIN</span>
+<a name="l00060"></a>00060 <span class="keyword">public</span>:<span class="comment"></span>
+<a name="l00061"></a>00061 <span class="comment"> ///<summary>Constructs a default of an FdoRdbmsReadOnlyOvPropertyDefinitionCollection</summary></span>
+<a name="l00062"></a>00062 <span class="comment"> /// <returns>Returns FdoRdbmsOvReadOnlyPropertyDefinitionCollection</returns> </span>
+<a name="l00063"></a>00063 <span class="comment"></span> <span class="keyword">static</span> <a class="code" href="class_fdo_rdbms_ov_read_only_property_definition_collection.html">FdoRdbmsOvReadOnlyPropertyDefinitionCollection</a>* <a class="code" href="class_fdo_rdbms_ov_read_only_property_definition_collection_4a95a07128e96e901e0eef4a30ce0f83.html#4a95a07128e96e901e0eef4a30ce0f83">Create</a>();
+<a name="l00065"></a>00065 <span class="comment"> ///<summary>Constructs an instance of an FdoRdbmsReadOnlyOvPropertyDefinitionCollection using the specified arguments</summary></span>
+<a name="l00066"></a>00066 <span class="comment"> /// <param name="parent">Input parent</param> </span>
+<a name="l00067"></a>00067 <span class="comment"> /// <returns>Returns FdoRdbmsOvReadOnlyPropertyDefinitionCollection</returns> </span>
+<a name="l00068"></a>00068 <span class="comment"></span> <span class="keyword">static</span> <a class="code" href="class_fdo_rdbms_ov_read_only_property_definition_collection.html">FdoRdbmsOvReadOnlyPropertyDefinitionCollection</a>* <a class="code" href="class_fdo_rdbms_ov_read_only_property_definition_collection_4a95a07128e96e901e0eef4a30ce0f83.html#4a95a07128e96e901e0eef4a30ce0f83">Create</a>(<a class="code" href="class_fdo_rdbms_ov_property_definition_collection.html">FdoRdbmsOvPropertyDefinitionCollection</a>* baseCollection);
+<a name="l00070"></a>00070 <span class="keyword">protected</span>:
+<a name="l00071"></a>00071 <a class="code" href="class_fdo_rdbms_ov_read_only_property_definition_collection_855bf7fdd382ba6cb4300990f34539fe.html#855bf7fdd382ba6cb4300990f34539fe">FdoRdbmsOvReadOnlyPropertyDefinitionCollection</a>();
+<a name="l00072"></a>00072 <a class="code" href="class_fdo_rdbms_ov_read_only_property_definition_collection_855bf7fdd382ba6cb4300990f34539fe.html#855bf7fdd382ba6cb4300990f34539fe">FdoRdbmsOvReadOnlyPropertyDefinitionCollection</a>(<a class="code" href="class_fdo_rdbms_ov_property_definition_collection.html">FdoRdbmsOvPropertyDefinitionCollection</a>* baseCollection);
+<a name="l00073"></a>00073 <span class="keyword">virtual</span> <a class="code" href="class_fdo_rdbms_ov_read_only_property_definition_collection_8a2c64bd01420a039115c009cbf81caf.html#8a2c64bd01420a039115c009cbf81caf">~FdoRdbmsOvReadOnlyPropertyDefinitionCollection</a>();
+<a name="l00074"></a>00074 <span class="keyword">virtual</span> <span class="keywordtype">void</span> <a class="code" href="class_fdo_rdbms_ov_read_only_property_definition_collection_9a8ccc6c0b95faf0ae058bd72c055f32.html#9a8ccc6c0b95faf0ae058bd72c055f32">Dispose</a>();
+<a name="l00075"></a>00075 <span class="comment">//DOM-IGNORE-END</span>
+<a name="l00076"></a>00076 };
+<a name="l00077"></a>00077 <span class="comment"></span>
+<a name="l00078"></a>00078 <span class="comment">///<summary>FdoRdbmsOvReadOnlyPropertiesP is a FdoPtr on FdoRdbmsOvReadOnlyPropertyDefinitionCollection, provided for convenience.</summary></span>
+<a name="l00079"></a><a class="code" href="_rdbms_ov_property_definition_collection_8h_28f0f2c56e33f94a7d96751ec866475a.html#28f0f2c56e33f94a7d96751ec866475a">00079</a> <span class="comment"></span><span class="keyword">typedef</span> FdoPtr<FdoRdbmsOvReadOnlyPropertyDefinitionCollection> <a class="code" href="_rdbms_ov_property_definition_collection_8h_28f0f2c56e33f94a7d96751ec866475a.html#28f0f2c56e33f94a7d96751ec866475a">FdoRdbmsOvReadOnlyPropertiesP</a>;
+<a name="l00082"></a>00082 <span class="preprocessor">#endif</span>
+<a name="l00083"></a>00083 <span class="preprocessor"></span>
+ <hr>
+ <table width="100%" border="0">
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/ODBC/_rdbms_ov_property_definition_collection_8h.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_property_definition_collection_8h.html?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_rdbms_ov_property_definition_collection_8h.html 2006-12-01 20:39:06+0000
@@ -0,0 +1,76 @@
+<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN" "http://www.w3.org/TR/html4/loose.dtd">
+<html>
+ <head>
+ <meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
+ <title>OSGeo FDO Provider for ODBC API Reference</title>
+ <link href="custom.css" rel="stylesheet" type="text/css">
+ <link href="tabs.css" rel="stylesheet" type="text/css">
+ </head>
+ <body bgcolor="#FFFFFF">
+ <tr>
+ <td><b>API Reference<b></td>
+ <td align="right"><b>OSGeo FDO Provider for ODBC<b></td>
+ </tr>
+ </table>
+<!-- End of: header.html -->
+<!-- Generated by Doxygen 1.4.6-NO -->
+<div class="tabs">
+ <ul>
+ <li><a href="main.html"><span>Main Page</span></a></li>
+ <li><a href="classes.html"><span>Classes</span></a></li>
+ <li id="current"><a href="files.html"><span>Files</span></a></li>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ <li><a href="files.html"><span>File List</span></a></li>
+ <li><a href="globals.html"><span>File Members</span></a></li>
+ </ul></div>
+<h1>RdbmsOvPropertyDefinitionCollection.h File Reference</h1>
+<p>
+<code>#include <Fdo/Commands/Schema/PhysicalElementMappingCollection.h></code><br>
+<code>#include <<a class="el" href="_rdbms_ov_property_definition_8h-source.html">Rdbms/Override/RdbmsOvPropertyDefinition.h</a>></code><br>
+<p>
+Include dependency graph for RdbmsOvPropertyDefinitionCollection.h:<p><center><img src="_rdbms_ov_property_definition_collection_8h__incl.png" border="0" usemap="#RdbmsOvPropertyDefinitionCollection.h_map" alt=""></center>
+<map name="RdbmsOvPropertyDefinitionCollection.h_map">
+<area href="_rdbms_ov_property_definition_8h.html" shape="rect" coords="364,58,665,84" alt="">
+</map>
+<p>
+This graph shows which files directly or indirectly include this file:<p><center><img src="_rdbms_ov_property_definition_collection_8h__dep__incl.png" border="0" usemap="#RdbmsOvPropertyDefinitionCollection.hdep_map" alt=""></center>
+<map name="RdbmsOvPropertyDefinitionCollection.hdep_map">
+<area href="_odbc_ov_property_definition_collection_8h.html" shape="rect" coords="327,7,575,33" alt="">
+<area href="_rdbms_ov_association_property_definition_8h.html" shape="rect" coords="316,57,586,84" alt="">
+<area href="_rdbms_ov_class_definition_8h.html" shape="rect" coords="360,108,542,135" alt="">
+<area href="_odbc_ov_class_definition_8h.html" shape="rect" coords="640,32,814,59" alt="">
+<area href="_rdbms_ov_class_collection_8h.html" shape="rect" coords="635,108,819,135" alt="">
+</map>
+<p>
+<a href="_rdbms_ov_property_definition_collection_8h-source.html">Go to the source code of this file.</a><table border="0" cellpadding="0" cellspacing="0">
+<tr><td></td></tr>
+<tr><td colspan="2"><br><h2>Classes</h2></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">class </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_rdbms_ov_property_definition_collection.html">FdoRdbmsOvPropertyDefinitionCollection</a></td></tr>
+<tr><td class="mdescLeft"> </td><td class="mdescRight">Concrete class defining physical schema overrides for a collection of property definitions. <a href="class_fdo_rdbms_ov_property_definition_collection.html#_details">More...</a><br></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">class </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_rdbms_ov_read_only_property_definition_collection.html">FdoRdbmsOvReadOnlyPropertyDefinitionCollection</a></td></tr>
+<tr><td class="mdescLeft"> </td><td class="mdescRight">Collection of property overrides for an RDBMS-type provider. Members cannot be added to or removed from this collection. /summary>. <a href="class_fdo_rdbms_ov_read_only_property_definition_collection.html#_details">More...</a><br></td></tr>
+<tr><td colspan="2"><br><h2>Typedefs</h2></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">typedef FdoPtr< <a class="el" href="class_fdo_rdbms_ov_property_definition_collection.html">FdoRdbmsOvPropertyDefinitionCollection</a> > </td><td class="memItemRight" valign="bottom"><a class="el" href="_rdbms_ov_property_definition_collection_8h_8a7a02562b4dcd8bbbf507c92753c27c.html#8a7a02562b4dcd8bbbf507c92753c27c">FdoRdbmsOvPropertiesP</a></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">typedef FdoPtr< <a class="el" href="class_fdo_rdbms_ov_read_only_property_definition_collection.html">FdoRdbmsOvReadOnlyPropertyDefinitionCollection</a> > </td><td class="memItemRight" valign="bottom"><a class="el" href="_rdbms_ov_property_definition_collection_8h_28f0f2c56e33f94a7d96751ec866475a.html#28f0f2c56e33f94a7d96751ec866475a">FdoRdbmsOvReadOnlyPropertiesP</a></td></tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/ODBC/_rdbms_ov_property_definition_collection_8h_28f0f2c56e33f94a7d96751ec866475a.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_property_definition_collection_8h_28f0f2c56e33f94a7d96751ec866475a.html?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_rdbms_ov_property_definition_collection_8h_28f0f2c56e33f94a7d96751ec866475a.html 2006-12-01 20:39:06+0000
@@ -0,0 +1,75 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="nav">
+<a class="el" href="_rdbms_ov_property_definition_collection_8h.html">RdbmsOvPropertyDefinitionCollection.h</a></div>
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindex" href="_rdbms_ov_property_definition_collection_8h_8a7a02562b4dcd8bbbf507c92753c27c.html#8a7a02562b4dcd8bbbf507c92753c27c">FdoRdbmsOvPropertiesP</a></td></tr>
+ <tr><td class="navtab"><a class="qindexHL" href="_rdbms_ov_property_definition_collection_8h_28f0f2c56e33f94a7d96751ec866475a.html#28f0f2c56e33f94a7d96751ec866475a">FdoRdbmsOvReadOnlyPropertiesP</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="28f0f2c56e33f94a7d96751ec866475a"></a><!-- doxytag: member="RdbmsOvPropertyDefinitionCollection.h::FdoRdbmsOvReadOnlyPropertiesP" ref="28f0f2c56e33f94a7d96751ec866475a" args="" --><p>
+<table class="mdTable" cellpadding="2" cellspacing="0">
+ <tr>
+ <td class="mdRow">
+ <table cellpadding="0" cellspacing="0" border="0">
+ <tr>
+ <td class="md" nowrap valign="top">typedef FdoPtr<<a class="el" href="class_fdo_rdbms_ov_read_only_property_definition_collection.html">FdoRdbmsOvReadOnlyPropertyDefinitionCollection</a>> <a class="el" href="_rdbms_ov_property_definition_collection_8h_28f0f2c56e33f94a7d96751ec866475a.html#28f0f2c56e33f94a7d96751ec866475a">FdoRdbmsOvReadOnlyPropertiesP</a> </td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+<table cellspacing="5" cellpadding="0" border="0">
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+<p>
+Definition at line <a class="el" href="_rdbms_ov_property_definition_collection_8h-source.html#l00079">79</a> of file <a class="el" href="_rdbms_ov_property_definition_collection_8h-source.html">RdbmsOvPropertyDefinitionCollection.h</a>. </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/ODBC/_rdbms_ov_property_definition_collection_8h_8a7a02562b4dcd8bbbf507c92753c27c.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_property_definition_collection_8h_8a7a02562b4dcd8bbbf507c92753c27c.html?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_rdbms_ov_property_definition_collection_8h_8a7a02562b4dcd8bbbf507c92753c27c.html 2006-12-01 20:39:06+0000
@@ -0,0 +1,75 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="nav">
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="_rdbms_ov_property_definition_collection_8h_8a7a02562b4dcd8bbbf507c92753c27c.html#8a7a02562b4dcd8bbbf507c92753c27c">FdoRdbmsOvPropertiesP</a></td></tr>
+ <tr><td class="navtab"><a class="qindex" href="_rdbms_ov_property_definition_collection_8h_28f0f2c56e33f94a7d96751ec866475a.html#28f0f2c56e33f94a7d96751ec866475a">FdoRdbmsOvReadOnlyPropertiesP</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="8a7a02562b4dcd8bbbf507c92753c27c"></a><!-- doxytag: member="RdbmsOvPropertyDefinitionCollection.h::FdoRdbmsOvPropertiesP" ref="8a7a02562b4dcd8bbbf507c92753c27c" args="" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">typedef FdoPtr<<a class="el" href="class_fdo_rdbms_ov_property_definition_collection.html">FdoRdbmsOvPropertyDefinitionCollection</a>> <a class="el" href="_rdbms_ov_property_definition_collection_8h_8a7a02562b4dcd8bbbf507c92753c27c.html#8a7a02562b4dcd8bbbf507c92753c27c">FdoRdbmsOvPropertiesP</a> </td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+<p>
+Definition at line <a class="el" href="_rdbms_ov_property_definition_collection_8h-source.html#l00051">51</a> of file <a class="el" href="_rdbms_ov_property_definition_collection_8h-source.html">RdbmsOvPropertyDefinitionCollection.h</a>. </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/ODBC/_rdbms_ov_property_definition_collection_8h__dep__incl.map
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_property_definition_collection_8h__dep__incl.map?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_rdbms_ov_property_definition_collection_8h__dep__incl.map 2006-12-01 20:39:06+0000
@@ -0,0 +1,6 @@
+base referer
+rect $_odbc_ov_property_definition_collection_8h.html 327,7 575,33
+rect $_rdbms_ov_association_property_definition_8h.html 316,57 586,84
+rect $_rdbms_ov_class_definition_8h.html 360,108 542,135
+rect $_odbc_ov_class_definition_8h.html 640,32 814,59
+rect $_rdbms_ov_class_collection_8h.html 635,108 819,135
Added: trunk/www/docs/ODBC/_rdbms_ov_property_definition_collection_8h__dep__incl.md5
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_property_definition_collection_8h__dep__incl.md5?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_rdbms_ov_property_definition_collection_8h__dep__incl.md5 2006-12-01 20:39:06+0000
@@ -0,0 +1 @@
+6f9b612b63ecaaa1ab8bb5802894c215
Added: trunk/www/docs/ODBC/_rdbms_ov_property_definition_collection_8h__dep__incl.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_property_definition_collection_8h__dep__incl.png?view=auto&rev=94
Added: trunk/www/docs/ODBC/_rdbms_ov_property_definition_collection_8h__incl.map
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_property_definition_collection_8h__incl.map?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_rdbms_ov_property_definition_collection_8h__incl.map 2006-12-01 20:39:06+0000
@@ -0,0 +1,2 @@
+base referer
+rect $_rdbms_ov_property_definition_8h.html 364,58 665,84
Added: trunk/www/docs/ODBC/_rdbms_ov_property_definition_collection_8h__incl.md5
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_property_definition_collection_8h__incl.md5?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_rdbms_ov_property_definition_collection_8h__incl.md5 2006-12-01 20:39:06+0000
@@ -0,0 +1 @@
+eef82be276a8d945ba59006dd686f325
Added: trunk/www/docs/ODBC/_rdbms_ov_property_definition_collection_8h__incl.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_property_definition_collection_8h__incl.png?view=auto&rev=94
Added: trunk/www/docs/ODBC/_rdbms_ov_property_mapping_class_8h-source.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_property_mapping_class_8h-source.html?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_rdbms_ov_property_mapping_class_8h-source.html 2006-12-01 20:39:06+0000
@@ -0,0 +1,101 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<h1>RdbmsOvPropertyMappingClass.h</h1><a href="_rdbms_ov_property_mapping_class_8h.html">Go to the documentation of this file.</a><div class="fragment"><pre class="fragment"><a name="l00001"></a>00001 <span class="preprocessor">#ifndef FDO_RDBMSOVPROPERTYMAPPINGRCLASS_H</span>
+<a name="l00002"></a>00002 <span class="preprocessor"></span><span class="preprocessor">#define FDO_RDBMSOVPROPERTYMAPPINGRCLASS_H</span>
+<a name="l00003"></a>00003 <span class="preprocessor"></span><span class="comment">//</span>
+<a name="l00019"></a>00019 <span class="comment">//</span>
+<a name="l00025"></a>00025 <span class="preprocessor">#include <<a class="code" href="_rdbms_ov_8h.html">Rdbms/Override/RdbmsOv.h</a>></span>
+<a name="l00026"></a>00026 <span class="preprocessor">#include <<a class="code" href="_rdbms_ov_property_mapping_relation_8h.html">Rdbms/Override/RdbmsOvPropertyMappingRelation.h</a>></span>
+<a name="l00029"></a>00029 <span class="comment"></span>
+<a name="l00030"></a>00030 <span class="comment">///<summary>Abstract class defining the physical schema overrides for the Class</span>
+<a name="l00031"></a>00031 <span class="comment">///type object property mapping.</summary></span>
+<a name="l00032"></a><a class="code" href="class_fdo_rdbms_ov_property_mapping_class.html">00032</a> <span class="comment"></span><span class="keyword">class </span><a class="code" href="class_fdo_rdbms_ov_property_mapping_class.html">FdoRdbmsOvPropertyMappingClass</a> : <span class="keyword">public</span> <span class="keyword">virtual</span> <a class="code" href="class_fdo_rdbms_ov_property_mapping_relation.html">FdoRdbmsOvPropertyMappingRelation</a>
+<a name="l00033"></a>00033 {
+<a name="l00034"></a>00034 <span class="keyword">public</span>:
+<a name="l00035"></a>00035 <span class="comment">// Serialize this property to XML. Not part of the API.</span>
+<a name="l00036"></a>00036 <a class="code" href="_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html#9b6afd7f3f2f73a361844d7bff18436f">FDORDBMS_OV_API</a> <span class="keyword">virtual</span> <span class="keywordtype">void</span> <a class="code" href="class_fdo_rdbms_ov_property_mapping_class_2810b377bdf9fe163c79025830050031.html#2810b377bdf9fe163c79025830050031">_writeXml</a>(FdoXmlWriter* xmlWriter, <span class="keyword">const</span> FdoXmlFlags* flags);
+<a name="l00038"></a>00038 <span class="comment">// Initialize this element from its XML attributes</span>
+<a name="l00039"></a>00039 <a class="code" href="_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html#9b6afd7f3f2f73a361844d7bff18436f">FDORDBMS_OV_API</a> <span class="keyword">virtual</span> <span class="keywordtype">void</span> <a class="code" href="class_fdo_rdbms_ov_property_mapping_class_be09a24c031113087f0f394e68edd78e.html#be09a24c031113087f0f394e68edd78e">InitFromXml</a>(FdoXmlSaxContext* pContext, FdoXmlAttributeCollection* attrs);
+<a name="l00041"></a>00041 <span class="keyword">protected</span>:
+<a name="l00042"></a>00042 <a class="code" href="_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html#9b6afd7f3f2f73a361844d7bff18436f">FDORDBMS_OV_API</a> <a class="code" href="class_fdo_rdbms_ov_property_mapping_class_c0ef144c3f8043866b707e2f23eef679.html#c0ef144c3f8043866b707e2f23eef679">FdoRdbmsOvPropertyMappingClass</a>();
+<a name="l00043"></a>00043 <a class="code" href="_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html#9b6afd7f3f2f73a361844d7bff18436f">FDORDBMS_OV_API</a> <span class="keyword">virtual</span> <a class="code" href="class_fdo_rdbms_ov_property_mapping_class_6c0ceb2307027764dc492ee5a8ac015c.html#6c0ceb2307027764dc492ee5a8ac015c">~FdoRdbmsOvPropertyMappingClass</a>();
+<a name="l00045"></a>00045 <span class="comment">// Handle sub-elements when deserializing from XML.</span>
+<a name="l00046"></a>00046 <a class="code" href="_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html#9b6afd7f3f2f73a361844d7bff18436f">FDORDBMS_OV_API</a> <span class="keyword">virtual</span> FdoXmlSaxHandler* <a class="code" href="class_fdo_rdbms_ov_property_mapping_class_11df41f413f9fddc8c8c38ee5c9f57f1.html#11df41f413f9fddc8c8c38ee5c9f57f1">XmlStartElement</a>(
+<a name="l00047"></a>00047 FdoXmlSaxContext* context,
+<a name="l00048"></a>00048 FdoString* uri,
+<a name="l00049"></a>00049 FdoString* name,
+<a name="l00050"></a>00050 FdoString* qname,
+<a name="l00051"></a>00051 FdoXmlAttributeCollection* atts
+<a name="l00052"></a>00052 );
+<a name="l00054"></a>00054 };
+<a name="l00055"></a>00055 <span class="comment"></span>
+<a name="l00056"></a>00056 <span class="comment">///<summary>FdoRdbmsOvPropertyMappingClassP is a FdoPtr on FdoRdbmsOvPropertyMappingClass, provided for convenience.</summary></span>
+<a name="l00057"></a><a class="code" href="_rdbms_ov_property_mapping_class_8h_87b56c23456a68ff05d9b74e4dd72dc2.html#87b56c23456a68ff05d9b74e4dd72dc2">00057</a> <span class="comment"></span><span class="keyword">typedef</span> FdoPtr<FdoRdbmsOvPropertyMappingClass> <a class="code" href="_rdbms_ov_property_mapping_class_8h_87b56c23456a68ff05d9b74e4dd72dc2.html#87b56c23456a68ff05d9b74e4dd72dc2">FdoRdbmsOvPropertyMappingClassP</a>;
+<a name="l00059"></a>00059 <span class="comment">//DOM-IGNORE-END</span>
+<a name="l00061"></a>00061 <span class="preprocessor">#endif</span>
+<a name="l00062"></a>00062 <span class="preprocessor"></span>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/ODBC/_rdbms_ov_property_mapping_class_8h.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_property_mapping_class_8h.html?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_rdbms_ov_property_mapping_class_8h.html 2006-12-01 20:39:06+0000
@@ -0,0 +1,71 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<h1>RdbmsOvPropertyMappingClass.h File Reference</h1>
+<p>
+<code>#include <<a class="el" href="_rdbms_ov_8h-source.html">Rdbms/Override/RdbmsOv.h</a>></code><br>
+<code>#include <<a class="el" href="_rdbms_ov_property_mapping_relation_8h-source.html">Rdbms/Override/RdbmsOvPropertyMappingRelation.h</a>></code><br>
+<p>
+Include dependency graph for RdbmsOvPropertyMappingClass.h:<p><center><img src="_rdbms_ov_property_mapping_class_8h__incl.png" border="0" usemap="#RdbmsOvPropertyMappingClass.h_map" alt=""></center>
+<map name="RdbmsOvPropertyMappingClass.h_map">
+<area href="_rdbms_ov_8h.html" shape="rect" coords="679,32,873,59" alt="">
+<area href="_rdbms_ov_property_mapping_relation_8h.html" shape="rect" coords="284,58,631,84" alt="">
+</map>
+<p>
+This graph shows which files directly or indirectly include this file:<p><center><img src="_rdbms_ov_property_mapping_class_8h__dep__incl.png" border="0" usemap="#RdbmsOvPropertyMappingClass.hdep_map" alt=""></center>
+<map name="RdbmsOvPropertyMappingClass.hdep_map">
+<area href="_rdbms_ov_object_property_definition_8h.html" shape="rect" coords="284,32,524,59" alt="">
+<area href="_rdbms_ov_class_definition_8h.html" shape="rect" coords="573,32,755,59" alt="">
+<area href="_odbc_ov_class_definition_8h.html" shape="rect" coords="811,7,984,34" alt="">
+<area href="_rdbms_ov_class_collection_8h.html" shape="rect" coords="805,58,989,84" alt="">
+</map>
+<p>
+<a href="_rdbms_ov_property_mapping_class_8h-source.html">Go to the source code of this file.</a><table border="0" cellpadding="0" cellspacing="0">
+<tr><td></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">class </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_rdbms_ov_property_mapping_class.html">FdoRdbmsOvPropertyMappingClass</a></td></tr>
+<tr><td class="mdescLeft"> </td><td class="mdescRight">Abstract class defining the physical schema overrides for the Class type object property mapping. <a href="class_fdo_rdbms_ov_property_mapping_class.html#_details">More...</a><br></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">typedef FdoPtr< <a class="el" href="class_fdo_rdbms_ov_property_mapping_class.html">FdoRdbmsOvPropertyMappingClass</a> > </td><td class="memItemRight" valign="bottom"><a class="el" href="_rdbms_ov_property_mapping_class_8h_87b56c23456a68ff05d9b74e4dd72dc2.html#87b56c23456a68ff05d9b74e4dd72dc2">FdoRdbmsOvPropertyMappingClassP</a></td></tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/ODBC/_rdbms_ov_property_mapping_class_8h_87b56c23456a68ff05d9b74e4dd72dc2.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_property_mapping_class_8h_87b56c23456a68ff05d9b74e4dd72dc2.html?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_rdbms_ov_property_mapping_class_8h_87b56c23456a68ff05d9b74e4dd72dc2.html 2006-12-01 20:39:06+0000
@@ -0,0 +1,74 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="nav">
+<a class="el" href="_rdbms_ov_property_mapping_class_8h.html">RdbmsOvPropertyMappingClass.h</a></div>
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="_rdbms_ov_property_mapping_class_8h_87b56c23456a68ff05d9b74e4dd72dc2.html#87b56c23456a68ff05d9b74e4dd72dc2">FdoRdbmsOvPropertyMappingClassP</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="87b56c23456a68ff05d9b74e4dd72dc2"></a><!-- doxytag: member="RdbmsOvPropertyMappingClass.h::FdoRdbmsOvPropertyMappingClassP" ref="87b56c23456a68ff05d9b74e4dd72dc2" args="" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">typedef FdoPtr<<a class="el" href="class_fdo_rdbms_ov_property_mapping_class.html">FdoRdbmsOvPropertyMappingClass</a>> <a class="el" href="_rdbms_ov_property_mapping_class_8h_87b56c23456a68ff05d9b74e4dd72dc2.html#87b56c23456a68ff05d9b74e4dd72dc2">FdoRdbmsOvPropertyMappingClassP</a> </td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+<p>
+Definition at line <a class="el" href="_rdbms_ov_property_mapping_class_8h-source.html#l00057">57</a> of file <a class="el" href="_rdbms_ov_property_mapping_class_8h-source.html">RdbmsOvPropertyMappingClass.h</a>. </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/ODBC/_rdbms_ov_property_mapping_class_8h__dep__incl.map
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_property_mapping_class_8h__dep__incl.map?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_rdbms_ov_property_mapping_class_8h__dep__incl.map 2006-12-01 20:39:06+0000
@@ -0,0 +1,5 @@
+base referer
+rect $_rdbms_ov_object_property_definition_8h.html 284,32 524,59
+rect $_rdbms_ov_class_definition_8h.html 573,32 755,59
+rect $_odbc_ov_class_definition_8h.html 811,7 984,34
+rect $_rdbms_ov_class_collection_8h.html 805,58 989,84
Added: trunk/www/docs/ODBC/_rdbms_ov_property_mapping_class_8h__dep__incl.md5
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_property_mapping_class_8h__dep__incl.md5?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_rdbms_ov_property_mapping_class_8h__dep__incl.md5 2006-12-01 20:39:06+0000
@@ -0,0 +1 @@
+a75848e60e9c6f9575377c7ef617e523
Added: trunk/www/docs/ODBC/_rdbms_ov_property_mapping_class_8h__dep__incl.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_property_mapping_class_8h__dep__incl.png?view=auto&rev=94
Added: trunk/www/docs/ODBC/_rdbms_ov_property_mapping_class_8h__incl.map
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_property_mapping_class_8h__incl.map?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_rdbms_ov_property_mapping_class_8h__incl.map 2006-12-01 20:39:06+0000
@@ -0,0 +1,3 @@
+base referer
+rect $_rdbms_ov_8h.html 679,32 873,59
+rect $_rdbms_ov_property_mapping_relation_8h.html 284,58 631,84
Added: trunk/www/docs/ODBC/_rdbms_ov_property_mapping_class_8h__incl.md5
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_property_mapping_class_8h__incl.md5?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_rdbms_ov_property_mapping_class_8h__incl.md5 2006-12-01 20:39:06+0000
@@ -0,0 +1 @@
+4d7ac70e620d06999f2fe45fbf59cb70
Added: trunk/www/docs/ODBC/_rdbms_ov_property_mapping_class_8h__incl.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_property_mapping_class_8h__incl.png?view=auto&rev=94
Added: trunk/www/docs/ODBC/_rdbms_ov_property_mapping_concrete_8h-source.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_property_mapping_concrete_8h-source.html?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_rdbms_ov_property_mapping_concrete_8h-source.html 2006-12-01 20:39:06+0000
@@ -0,0 +1,112 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<h1>RdbmsOvPropertyMappingConcrete.h</h1><a href="_rdbms_ov_property_mapping_concrete_8h.html">Go to the documentation of this file.</a><div class="fragment"><pre class="fragment"><a name="l00001"></a>00001 <span class="preprocessor">#ifndef FDO_RDBMSOVPROPERTYMAPPINGRCONCRETE_H</span>
+<a name="l00002"></a>00002 <span class="preprocessor"></span><span class="preprocessor">#define FDO_RDBMSOVPROPERTYMAPPINGRCONCRETE_H</span>
+<a name="l00028"></a>00028 <span class="comment">///<summary></span>
+<a name="l00029"></a>00029 <span class="comment">///Abstract class defining the physical schema overrides for the Concrete </span>
+<a name="l00030"></a>00030 <span class="comment">///type object property mapping. Under the Concrete mapping type, each object </span>
+<a name="l00031"></a>00031 <span class="comment">///property is kept in its own table.</span>
+<a name="l00032"></a>00032 <span class="comment">///</summary></span>
+<a name="l00033"></a><a class="code" href="class_fdo_rdbms_ov_property_mapping_concrete.html">00033</a> <span class="comment"></span><span class="keyword">class </span><a class="code" href="class_fdo_rdbms_ov_property_mapping_concrete.html">FdoRdbmsOvPropertyMappingConcrete</a> : <span class="keyword">public</span> <span class="keyword">virtual</span> <a class="code" href="class_fdo_rdbms_ov_property_mapping_relation.html">FdoRdbmsOvPropertyMappingRelation</a>
+<a name="l00034"></a>00034 {
+<a name="l00036"></a>00036 <span class="keyword">public</span>:
+<a name="l00037"></a>00037 <span class="comment">//DOM-IGNORE-BEGIN</span>
+<a name="l00039"></a>00039 <span class="comment">// XML Serialization functions, not part of the API.</span>
+<a name="l00041"></a>00041 <span class="comment">// Serialize this property to XML.</span>
+<a name="l00042"></a>00042 <a class="code" href="_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html#9b6afd7f3f2f73a361844d7bff18436f">FDORDBMS_OV_API</a> <span class="keyword">virtual</span> <span class="keywordtype">void</span> <a class="code" href="class_fdo_rdbms_ov_property_mapping_concrete_644c838b9f4e37a19527c10a6d0011e6.html#644c838b9f4e37a19527c10a6d0011e6">_writeXml</a>(FdoXmlWriter* xmlWriter, <span class="keyword">const</span> FdoXmlFlags* flags);
+<a name="l00044"></a>00044 <span class="comment">// Initialize this element from its XML attributes</span>
+<a name="l00045"></a>00045 <a class="code" href="_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html#9b6afd7f3f2f73a361844d7bff18436f">FDORDBMS_OV_API</a> <span class="keyword">virtual</span> <span class="keywordtype">void</span> <a class="code" href="class_fdo_rdbms_ov_property_mapping_concrete_e60c778281acc929d697bd460fcf8586.html#e60c778281acc929d697bd460fcf8586">InitFromXml</a>(FdoXmlSaxContext* pContext, FdoXmlAttributeCollection* attrs);
+<a name="l00047"></a>00047 <span class="comment">//DOM-IGNORE-END</span>
+<a name="l00049"></a>00049 <span class="keyword">protected</span>:
+<a name="l00050"></a>00050 <a class="code" href="_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html#9b6afd7f3f2f73a361844d7bff18436f">FDORDBMS_OV_API</a> <a class="code" href="class_fdo_rdbms_ov_property_mapping_concrete_48435a417f70333a2842a6ce86a8549b.html#48435a417f70333a2842a6ce86a8549b">FdoRdbmsOvPropertyMappingConcrete</a>();
+<a name="l00051"></a>00051 <a class="code" href="_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html#9b6afd7f3f2f73a361844d7bff18436f">FDORDBMS_OV_API</a> <span class="keyword">virtual</span> <a class="code" href="class_fdo_rdbms_ov_property_mapping_concrete_2acece23c9aa45246c2bbbee429b125d.html#2acece23c9aa45246c2bbbee429b125d">~FdoRdbmsOvPropertyMappingConcrete</a>();
+<a name="l00053"></a>00053 <span class="comment">// Handle sub-elements when deserializing from XML.</span>
+<a name="l00054"></a>00054 <a class="code" href="_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html#9b6afd7f3f2f73a361844d7bff18436f">FDORDBMS_OV_API</a> <span class="keyword">virtual</span> FdoXmlSaxHandler* <a class="code" href="class_fdo_rdbms_ov_property_mapping_concrete_cda5ea045747502d5eecf8e128d9e7c1.html#cda5ea045747502d5eecf8e128d9e7c1">XmlStartElement</a>(
+<a name="l00055"></a>00055 FdoXmlSaxContext* context,
+<a name="l00056"></a>00056 FdoString* uri,
+<a name="l00057"></a>00057 FdoString* name,
+<a name="l00058"></a>00058 FdoString* qname,
+<a name="l00059"></a>00059 FdoXmlAttributeCollection* atts
+<a name="l00060"></a>00060 );
+<a name="l00062"></a>00062 <span class="keyword">private</span>:
+<a name="l00063"></a>00063 };
+<a name="l00064"></a>00064 <span class="comment"></span>
+<a name="l00065"></a>00065 <span class="comment">///<summary></span>
+<a name="l00066"></a>00066 <span class="comment">///FdoRdbmsOvPropertyMappingConcreteP is a FdoPtr on </span>
+<a name="l00067"></a>00067 <span class="comment">///FdoRdbmsOvPropertyMappingConcrete, provided for convenience.</span>
+<a name="l00068"></a>00068 <span class="comment">///</summary></span>
+<a name="l00069"></a><a class="code" href="_rdbms_ov_property_mapping_concrete_8h_5dd5fae46254c872392b8b0aa0552f92.html#5dd5fae46254c872392b8b0aa0552f92">00069</a> <span class="comment"></span><span class="keyword">typedef</span> FdoPtr<FdoRdbmsOvPropertyMappingConcrete> <a class="code" href="_rdbms_ov_property_mapping_concrete_8h_5dd5fae46254c872392b8b0aa0552f92.html#5dd5fae46254c872392b8b0aa0552f92">FdoRdbmsOvPropertyMappingConcreteP</a>;
+<a name="l00071"></a>00071 <span class="preprocessor">#endif</span>
+<a name="l00072"></a>00072 <span class="preprocessor"></span>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/ODBC/_rdbms_ov_property_mapping_concrete_8h.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_property_mapping_concrete_8h.html?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_rdbms_ov_property_mapping_concrete_8h.html 2006-12-01 20:39:06+0000
@@ -0,0 +1,71 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<h1>RdbmsOvPropertyMappingConcrete.h File Reference</h1>
+<p>
+<p>
+Include dependency graph for RdbmsOvPropertyMappingConcrete.h:<p><center><img src="_rdbms_ov_property_mapping_concrete_8h__incl.png" border="0" usemap="#RdbmsOvPropertyMappingConcrete.h_map" alt=""></center>
+<map name="RdbmsOvPropertyMappingConcrete.h_map">
+<area href="_rdbms_ov_8h.html" shape="rect" coords="700,32,895,59" alt="">
+<area href="_rdbms_ov_property_mapping_relation_8h.html" shape="rect" coords="305,58,652,84" alt="">
+</map>
+<p>
+This graph shows which files directly or indirectly include this file:<p><center><img src="_rdbms_ov_property_mapping_concrete_8h__dep__incl.png" border="0" usemap="#RdbmsOvPropertyMappingConcrete.hdep_map" alt=""></center>
+<map name="RdbmsOvPropertyMappingConcrete.hdep_map">
+<area href="_rdbms_ov_object_property_definition_8h.html" shape="rect" coords="306,32,546,59" alt="">
+<area href="_rdbms_ov_class_definition_8h.html" shape="rect" coords="595,32,776,59" alt="">
+<area href="_odbc_ov_class_definition_8h.html" shape="rect" coords="832,7,1006,34" alt="">
+<area href="_rdbms_ov_class_collection_8h.html" shape="rect" coords="827,58,1011,84" alt="">
+</map>
+<p>
+<a href="_rdbms_ov_property_mapping_concrete_8h-source.html">Go to the source code of this file.</a><table border="0" cellpadding="0" cellspacing="0">
+<tr><td></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">class </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_rdbms_ov_property_mapping_concrete.html">FdoRdbmsOvPropertyMappingConcrete</a></td></tr>
+<tr><td class="mdescLeft"> </td><td class="mdescRight">Abstract class defining the physical schema overrides for the Concrete type object property mapping. Under the Concrete mapping type, each object property is kept in its own table. /summary>. <a href="class_fdo_rdbms_ov_property_mapping_concrete.html#_details">More...</a><br></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">typedef FdoPtr< <a class="el" href="class_fdo_rdbms_ov_property_mapping_concrete.html">FdoRdbmsOvPropertyMappingConcrete</a> > </td><td class="memItemRight" valign="bottom"><a class="el" href="_rdbms_ov_property_mapping_concrete_8h_5dd5fae46254c872392b8b0aa0552f92.html#5dd5fae46254c872392b8b0aa0552f92">FdoRdbmsOvPropertyMappingConcreteP</a></td></tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/ODBC/_rdbms_ov_property_mapping_concrete_8h_5dd5fae46254c872392b8b0aa0552f92.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_property_mapping_concrete_8h_5dd5fae46254c872392b8b0aa0552f92.html?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_rdbms_ov_property_mapping_concrete_8h_5dd5fae46254c872392b8b0aa0552f92.html 2006-12-01 20:39:06+0000
@@ -0,0 +1,74 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="nav">
+<a class="el" href="_rdbms_ov_property_mapping_concrete_8h.html">RdbmsOvPropertyMappingConcrete.h</a></div>
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="_rdbms_ov_property_mapping_concrete_8h_5dd5fae46254c872392b8b0aa0552f92.html#5dd5fae46254c872392b8b0aa0552f92">FdoRdbmsOvPropertyMappingConcreteP</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="5dd5fae46254c872392b8b0aa0552f92"></a><!-- doxytag: member="RdbmsOvPropertyMappingConcrete.h::FdoRdbmsOvPropertyMappingConcreteP" ref="5dd5fae46254c872392b8b0aa0552f92" args="" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">typedef FdoPtr<<a class="el" href="class_fdo_rdbms_ov_property_mapping_concrete.html">FdoRdbmsOvPropertyMappingConcrete</a>> <a class="el" href="_rdbms_ov_property_mapping_concrete_8h_5dd5fae46254c872392b8b0aa0552f92.html#5dd5fae46254c872392b8b0aa0552f92">FdoRdbmsOvPropertyMappingConcreteP</a> </td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+<p>
+Definition at line <a class="el" href="_rdbms_ov_property_mapping_concrete_8h-source.html#l00069">69</a> of file <a class="el" href="_rdbms_ov_property_mapping_concrete_8h-source.html">RdbmsOvPropertyMappingConcrete.h</a>. </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/ODBC/_rdbms_ov_property_mapping_concrete_8h__dep__incl.map
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_property_mapping_concrete_8h__dep__incl.map?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_rdbms_ov_property_mapping_concrete_8h__dep__incl.map 2006-12-01 20:39:06+0000
@@ -0,0 +1,5 @@
+base referer
+rect $_rdbms_ov_object_property_definition_8h.html 306,32 546,59
+rect $_rdbms_ov_class_definition_8h.html 595,32 776,59
+rect $_odbc_ov_class_definition_8h.html 832,7 1006,34
+rect $_rdbms_ov_class_collection_8h.html 827,58 1011,84
Added: trunk/www/docs/ODBC/_rdbms_ov_property_mapping_concrete_8h__dep__incl.md5
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_property_mapping_concrete_8h__dep__incl.md5?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_rdbms_ov_property_mapping_concrete_8h__dep__incl.md5 2006-12-01 20:39:06+0000
@@ -0,0 +1 @@
+33a8a3fbdc00eb75b8e4587d960f042a
Added: trunk/www/docs/ODBC/_rdbms_ov_property_mapping_concrete_8h__dep__incl.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_property_mapping_concrete_8h__dep__incl.png?view=auto&rev=94
Added: trunk/www/docs/ODBC/_rdbms_ov_property_mapping_concrete_8h__incl.map
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_property_mapping_concrete_8h__incl.map?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_rdbms_ov_property_mapping_concrete_8h__incl.map 2006-12-01 20:39:06+0000
@@ -0,0 +1,3 @@
+base referer
+rect $_rdbms_ov_8h.html 700,32 895,59
+rect $_rdbms_ov_property_mapping_relation_8h.html 305,58 652,84
Added: trunk/www/docs/ODBC/_rdbms_ov_property_mapping_concrete_8h__incl.md5
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_property_mapping_concrete_8h__incl.md5?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_rdbms_ov_property_mapping_concrete_8h__incl.md5 2006-12-01 20:39:06+0000
@@ -0,0 +1 @@
+cd626ab5f6ccb085230ce90d6b073e01
Added: trunk/www/docs/ODBC/_rdbms_ov_property_mapping_concrete_8h__incl.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_property_mapping_concrete_8h__incl.png?view=auto&rev=94
Added: trunk/www/docs/ODBC/_rdbms_ov_property_mapping_definition_8h-source.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_property_mapping_definition_8h-source.html?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_rdbms_ov_property_mapping_definition_8h-source.html 2006-12-01 20:39:06+0000
@@ -0,0 +1,104 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<h1>RdbmsOvPropertyMappingDefinition.h</h1><a href="_rdbms_ov_property_mapping_definition_8h.html">Go to the documentation of this file.</a><div class="fragment"><pre class="fragment"><a name="l00001"></a>00001 <span class="preprocessor">#ifndef FDO_RDBMSOVPROPERTYMAPPINGDEFINITION_H</span>
+<a name="l00002"></a>00002 <span class="preprocessor"></span><span class="preprocessor">#define FDO_RDBMSOVPROPERTYMAPPINGDEFINITION_H</span>
+<a name="l00025"></a>00025 <span class="preprocessor">#include <FdoCommon.h></span>
+<a name="l00026"></a>00026 <span class="preprocessor">#include <Fdo/Xml/Flags.h></span>
+<a name="l00027"></a>00027 <span class="preprocessor">#include <Fdo/Commands/Schema/PhysicalElementMapping.h></span>
+<a name="l00028"></a>00028 <span class="preprocessor">#include <<a class="code" href="_rdbms_ov_8h.html">Rdbms/Override/RdbmsOv.h</a>></span>
+<a name="l00030"></a>00030 <span class="comment">///<summary></span>
+<a name="l00031"></a>00031 <span class="comment">///Abstract class defining the physical schema overrides for object </span>
+<a name="l00032"></a>00032 <span class="comment">///property table mappings.</span>
+<a name="l00033"></a>00033 <span class="comment">///</summary></span>
+<a name="l00034"></a><a class="code" href="class_fdo_rdbms_ov_property_mapping_definition.html">00034</a> <span class="comment"></span><span class="keyword">class </span><a class="code" href="class_fdo_rdbms_ov_property_mapping_definition.html">FdoRdbmsOvPropertyMappingDefinition</a> : <span class="keyword">public</span> FdoPhysicalElementMapping
+<a name="l00035"></a>00035 {
+<a name="l00038"></a>00038 <span class="comment">//DOM-IGNORE-BEGIN</span>
+<a name="l00040"></a>00040 <span class="comment">// The following functions are for internal use and are not part of the API.</span>
+<a name="l00042"></a>00042 <span class="comment">// Sets the parent of this object.</span>
+<a name="l00043"></a>00043 <a class="code" href="_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html#9b6afd7f3f2f73a361844d7bff18436f">FDORDBMS_OV_API</a> <span class="keywordtype">void</span> <a class="code" href="class_fdo_rdbms_ov_property_mapping_definition_618997b863b2a1ea642f2f0864830af9.html#618997b863b2a1ea642f2f0864830af9">SetParent</a>(FdoPhysicalElementMapping* value);
+<a name="l00045"></a>00045 <span class="comment">// Initialize this element from its XML attributes</span>
+<a name="l00046"></a>00046 <a class="code" href="_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html#9b6afd7f3f2f73a361844d7bff18436f">FDORDBMS_OV_API</a> <span class="keyword">virtual</span> <span class="keywordtype">void</span> <a class="code" href="class_fdo_rdbms_ov_property_mapping_definition_641cc7da4e8e0696744a5ca8dbf70cb0.html#641cc7da4e8e0696744a5ca8dbf70cb0">InitFromXml</a>(FdoXmlSaxContext* pContext, FdoXmlAttributeCollection* attrs);
+<a name="l00048"></a>00048 <span class="comment">// Serialize this property to XML.</span>
+<a name="l00049"></a>00049 <a class="code" href="_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html#9b6afd7f3f2f73a361844d7bff18436f">FDORDBMS_OV_API</a> <span class="keyword">virtual</span> <span class="keywordtype">void</span> <a class="code" href="class_fdo_rdbms_ov_property_mapping_definition_03db45b676deef2a9e820e534e4ed02d.html#03db45b676deef2a9e820e534e4ed02d">_writeXml</a>(FdoXmlWriter* xmlWriter, <span class="keyword">const</span> FdoXmlFlags* flags);
+<a name="l00051"></a>00051 <span class="comment">//DOM-IGNORE-END</span>
+<a name="l00053"></a>00053 <span class="keyword">protected</span>:
+<a name="l00054"></a>00054 <a class="code" href="_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html#9b6afd7f3f2f73a361844d7bff18436f">FDORDBMS_OV_API</a> <a class="code" href="class_fdo_rdbms_ov_property_mapping_definition_3ae359b6b7e658824cf186b2d3c9ad3f.html#3ae359b6b7e658824cf186b2d3c9ad3f">FdoRdbmsOvPropertyMappingDefinition</a>();
+<a name="l00055"></a>00055 <a class="code" href="_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html#9b6afd7f3f2f73a361844d7bff18436f">FDORDBMS_OV_API</a> <span class="keyword">virtual</span> <a class="code" href="class_fdo_rdbms_ov_property_mapping_definition_b100a514d000b4ebb6a95be24740b0ad.html#b100a514d000b4ebb6a95be24740b0ad">~FdoRdbmsOvPropertyMappingDefinition</a>();
+<a name="l00056"></a>00056 };
+<a name="l00057"></a>00057 <span class="comment"></span>
+<a name="l00058"></a>00058 <span class="comment">///<summary></span>
+<a name="l00059"></a>00059 <span class="comment">///FdoRdbmsOvPropertyMappingP is a FdoPtr on FdoRdbmsOvPropertyMappingDefinition,</span>
+<a name="l00060"></a>00060 <span class="comment">///provided for convenience.</span>
+<a name="l00061"></a>00061 <span class="comment">///</summary></span>
+<a name="l00062"></a><a class="code" href="_rdbms_ov_property_mapping_definition_8h_c13fe6b320fc1f174d6079b9651cd759.html#c13fe6b320fc1f174d6079b9651cd759">00062</a> <span class="comment"></span><span class="keyword">typedef</span> FdoPtr<FdoRdbmsOvPropertyMappingDefinition> <a class="code" href="_rdbms_ov_property_mapping_definition_8h_c13fe6b320fc1f174d6079b9651cd759.html#c13fe6b320fc1f174d6079b9651cd759">FdoRdbmsOvPropertyMappingP</a>;
+<a name="l00064"></a>00064 <span class="preprocessor">#endif</span>
+<a name="l00065"></a>00065 <span class="preprocessor"></span>
+</pre></div><!-- footer.html -->
+ <hr>
+ <tr>
+ <td align="right"><font size="-2"><a href="mailto:isd.docs at autodesk.com&subject=FDO%20Provider%20for%20ODBC%20API%20documentation">Comments?</a></font></td>
+ <!-- The logo can go in another cell, when we get one -->
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/ODBC/_rdbms_ov_property_mapping_definition_8h.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_property_mapping_definition_8h.html?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_rdbms_ov_property_mapping_definition_8h.html 2006-12-01 20:39:06+0000
@@ -0,0 +1,70 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<h1>RdbmsOvPropertyMappingDefinition.h File Reference</h1>
+<p>
+<code>#include <FdoCommon.h></code><br>
+<code>#include <Fdo/Xml/Flags.h></code><br>
+<code>#include <Fdo/Commands/Schema/PhysicalElementMapping.h></code><br>
+<p>
+Include dependency graph for RdbmsOvPropertyMappingDefinition.h:<p><center><img src="_rdbms_ov_property_mapping_definition_8h__incl.png" border="0" usemap="#RdbmsOvPropertyMappingDefinition.h_map" alt=""></center>
+<map name="RdbmsOvPropertyMappingDefinition.h_map">
+<area href="_rdbms_ov_8h.html" shape="rect" coords="379,159,574,185" alt="">
+</map>
+<p>
+This graph shows which files directly or indirectly include this file:<p><center><img src="_rdbms_ov_property_mapping_definition_8h__dep__incl.png" border="0" usemap="#RdbmsOvPropertyMappingDefinition.hdep_map" alt=""></center>
+<map name="RdbmsOvPropertyMappingDefinition.hdep_map">
+<area href="_rdbms_ov_property_mapping_relation_8h.html" shape="rect" coords="309,7,552,34" alt="">
+<area href="_rdbms_ov_property_mapping_single_8h.html" shape="rect" coords="315,58,547,84" alt="">
+</map>
+<p>
+<a href="_rdbms_ov_property_mapping_definition_8h-source.html">Go to the source code of this file.</a><table border="0" cellpadding="0" cellspacing="0">
+<tr><td></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">class </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_rdbms_ov_property_mapping_definition.html">FdoRdbmsOvPropertyMappingDefinition</a></td></tr>
+<tr><td class="mdescLeft"> </td><td class="mdescRight">Abstract class defining the physical schema overrides for object property table mappings. /summary>. <a href="class_fdo_rdbms_ov_property_mapping_definition.html#_details">More...</a><br></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">typedef FdoPtr< <a class="el" href="class_fdo_rdbms_ov_property_mapping_definition.html">FdoRdbmsOvPropertyMappingDefinition</a> > </td><td class="memItemRight" valign="bottom"><a class="el" href="_rdbms_ov_property_mapping_definition_8h_c13fe6b320fc1f174d6079b9651cd759.html#c13fe6b320fc1f174d6079b9651cd759">FdoRdbmsOvPropertyMappingP</a></td></tr>
+</table>
+<!-- footer.html -->
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/ODBC/_rdbms_ov_property_mapping_definition_8h__dep__incl.map
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_property_mapping_definition_8h__dep__incl.map?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_rdbms_ov_property_mapping_definition_8h__dep__incl.map 2006-12-01 20:39:06+0000
@@ -0,0 +1,3 @@
+base referer
+rect $_rdbms_ov_property_mapping_relation_8h.html 309,7 552,34
+rect $_rdbms_ov_property_mapping_single_8h.html 315,58 547,84
Added: trunk/www/docs/ODBC/_rdbms_ov_property_mapping_definition_8h__dep__incl.md5
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_property_mapping_definition_8h__dep__incl.md5?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_rdbms_ov_property_mapping_definition_8h__dep__incl.md5 2006-12-01 20:39:06+0000
@@ -0,0 +1 @@
+b39fb0821b8908c7b29897144b53d509
\ No newline at end of file
Added: trunk/www/docs/ODBC/_rdbms_ov_property_mapping_definition_8h__dep__incl.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_property_mapping_definition_8h__dep__incl.png?view=auto&rev=94
Binary file. No diff available.
Added: trunk/www/docs/ODBC/_rdbms_ov_property_mapping_definition_8h__incl.map
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_property_mapping_definition_8h__incl.map?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_rdbms_ov_property_mapping_definition_8h__incl.map 2006-12-01 20:39:06+0000
@@ -0,0 +1,2 @@
+base referer
+rect $_rdbms_ov_8h.html 379,159 574,185
Added: trunk/www/docs/ODBC/_rdbms_ov_property_mapping_definition_8h__incl.md5
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_property_mapping_definition_8h__incl.md5?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_rdbms_ov_property_mapping_definition_8h__incl.md5 2006-12-01 20:39:06+0000
@@ -0,0 +1 @@
+fd85a371c76423812351340f3af3bf8e
Added: trunk/www/docs/ODBC/_rdbms_ov_property_mapping_definition_8h__incl.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_property_mapping_definition_8h__incl.png?view=auto&rev=94
Added: trunk/www/docs/ODBC/_rdbms_ov_property_mapping_definition_8h_c13fe6b320fc1f174d6079b9651cd759.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_property_mapping_definition_8h_c13fe6b320fc1f174d6079b9651cd759.html?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_rdbms_ov_property_mapping_definition_8h_c13fe6b320fc1f174d6079b9651cd759.html 2006-12-01 20:39:06+0000
@@ -0,0 +1,74 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ <li><a href="files.html"><span>Files</span></a></li>
+ </ul></div>
+<div class="nav">
+<a class="el" href="_rdbms_ov_property_mapping_definition_8h.html">RdbmsOvPropertyMappingDefinition.h</a></div>
+<table cellspacing="0" cellpadding="0" border="0">
+ <tr>
+ <td valign="top">
+ <div class="navtab">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="_rdbms_ov_property_mapping_definition_8h_c13fe6b320fc1f174d6079b9651cd759.html#c13fe6b320fc1f174d6079b9651cd759">FdoRdbmsOvPropertyMappingP</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="c13fe6b320fc1f174d6079b9651cd759"></a><!-- doxytag: member="RdbmsOvPropertyMappingDefinition.h::FdoRdbmsOvPropertyMappingP" ref="c13fe6b320fc1f174d6079b9651cd759" args="" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">typedef FdoPtr<<a class="el" href="class_fdo_rdbms_ov_property_mapping_definition.html">FdoRdbmsOvPropertyMappingDefinition</a>> <a class="el" href="_rdbms_ov_property_mapping_definition_8h_c13fe6b320fc1f174d6079b9651cd759.html#c13fe6b320fc1f174d6079b9651cd759">FdoRdbmsOvPropertyMappingP</a> </td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+<p>
+Definition at line <a class="el" href="_rdbms_ov_property_mapping_definition_8h-source.html#l00062">62</a> of file <a class="el" href="_rdbms_ov_property_mapping_definition_8h-source.html">RdbmsOvPropertyMappingDefinition.h</a>. </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/ODBC/_rdbms_ov_property_mapping_relation_8h-source.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_property_mapping_relation_8h-source.html?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_rdbms_ov_property_mapping_relation_8h-source.html 2006-12-01 20:39:06+0000
@@ -0,0 +1,136 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<h1>RdbmsOvPropertyMappingRelation.h</h1><a href="_rdbms_ov_property_mapping_relation_8h.html">Go to the documentation of this file.</a><div class="fragment"><pre class="fragment"><a name="l00001"></a>00001 <span class="preprocessor">#ifndef FDO_RDBMSOVPROPERTYMAPPINGRELATION_H</span>
+<a name="l00002"></a>00002 <span class="preprocessor"></span><span class="preprocessor">#define FDO_RDBMSOVPROPERTYMAPPINGRELATION_H</span>
+<a name="l00004"></a>00004 <span class="comment">//</span>
+<a name="l00005"></a>00005 <span class="comment">// Copyright (C) 2004-2006 Autodesk, Inc.</span>
+<a name="l00006"></a>00006 <span class="comment">// </span>
+<a name="l00007"></a>00007 <span class="comment">// This library is free software; you can redistribute it and/or</span>
+<a name="l00008"></a>00008 <span class="comment">// modify it under the terms of version 2.1 of the GNU Lesser</span>
+<a name="l00009"></a>00009 <span class="comment">// General Public License as published by the Free Software Foundation.</span>
+<a name="l00010"></a>00010 <span class="comment">// </span>
+<a name="l00011"></a>00011 <span class="comment">// This library is distributed in the hope that it will be useful,</span>
+<a name="l00012"></a>00012 <span class="comment">// but WITHOUT ANY WARRANTY; without even the implied warranty of</span>
+<a name="l00013"></a>00013 <span class="comment">// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU</span>
+<a name="l00014"></a>00014 <span class="comment">// Lesser General Public License for more details.</span>
+<a name="l00015"></a>00015 <span class="comment">// </span>
+<a name="l00016"></a>00016 <span class="comment">// You should have received a copy of the GNU Lesser General Public</span>
+<a name="l00017"></a>00017 <span class="comment">// License along with this library; if not, write to the Free Software</span>
+<a name="l00018"></a>00018 <span class="comment">// Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA</span>
+<a name="l00020"></a>00020 <span class="comment"></span>
+<a name="l00021"></a>00021 <span class="comment">/// <library></span>
+<a name="l00022"></a>00022 <span class="comment">/// FdoRdbms.lib</span>
+<a name="l00023"></a>00023 <span class="comment">/// </library></span>
+<a name="l00024"></a>00024 <span class="comment"></span>
+<a name="l00026"></a>00026 <span class="preprocessor">#include <<a class="code" href="_rdbms_ov_8h.html">Rdbms/Override/RdbmsOv.h</a>></span>
+<a name="l00027"></a>00027 <span class="preprocessor">#include <<a class="code" href="_rdbms_ov_property_mapping_definition_8h.html">Rdbms/Override/RdbmsOvPropertyMappingDefinition.h</a>></span>
+<a name="l00029"></a>00029 <span class="keyword">class </span><a class="code" href="class_fdo_rdbms_ov_class_definition.html">FdoRdbmsOvClassDefinition</a>;
+<a name="l00030"></a>00030 <span class="comment"></span>
+<a name="l00031"></a>00031 <span class="comment">///<summary></span>
+<a name="l00032"></a>00032 <span class="comment">///Abstract class defining the physical schema overrides for relation type </span>
+<a name="l00033"></a>00033 <span class="comment">///object property table mappings.</span>
+<a name="l00034"></a>00034 <span class="comment">///</summary></span>
+<a name="l00035"></a><a class="code" href="class_fdo_rdbms_ov_property_mapping_relation.html">00035</a> <span class="comment"></span><span class="keyword">class </span><a class="code" href="class_fdo_rdbms_ov_property_mapping_relation.html">FdoRdbmsOvPropertyMappingRelation</a> : <span class="keyword">public</span> <span class="keyword">virtual</span> <a class="code" href="class_fdo_rdbms_ov_property_mapping_definition.html">FdoRdbmsOvPropertyMappingDefinition</a>
+<a name="l00036"></a>00036 {
+<a name="l00038"></a>00038 <span class="keyword">public</span>:
+<a name="l00039"></a>00039 <span class="comment"></span>
+<a name="l00040"></a>00040 <span class="comment"> ///<summary>Gets the internal class</summary></span>
+<a name="l00041"></a>00041 <span class="comment"> /// <returns>Returns the internal class</returns></span>
+<a name="l00042"></a>00042 <span class="comment"></span> <a class="code" href="_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html#9b6afd7f3f2f73a361844d7bff18436f">FDORDBMS_OV_API</a> <a class="code" href="class_fdo_rdbms_ov_class_definition.html">FdoRdbmsOvClassDefinition</a>* <a class="code" href="class_fdo_rdbms_ov_property_mapping_relation_8ff17d9dc1c74beefcfdeb5c166dd40d.html#8ff17d9dc1c74beefcfdeb5c166dd40d">GetInternalClass</a>();
+<a name="l00044"></a>00044 <span class="comment">//DOM-IGNORE-BEGIN</span>
+<a name="l00046"></a>00046 <span class="comment">// Serialize this property to XML. Not part of the API.</span>
+<a name="l00047"></a>00047 <a class="code" href="_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html#9b6afd7f3f2f73a361844d7bff18436f">FDORDBMS_OV_API</a> <span class="keyword">virtual</span> <span class="keywordtype">void</span> <a class="code" href="class_fdo_rdbms_ov_property_mapping_relation_5e75bb8248eeb703d6d8c47493247ff6.html#5e75bb8248eeb703d6d8c47493247ff6">_writeXml</a>(FdoXmlWriter* xmlWriter, <span class="keyword">const</span> FdoXmlFlags* flags);
+<a name="l00049"></a>00049 <span class="comment">// Creates and optionally attaches an internal class override object.</span>
+<a name="l00050"></a><a class="code" href="class_fdo_rdbms_ov_property_mapping_relation_9ec78dd558383c1fbd77f0f611222932.html#9ec78dd558383c1fbd77f0f611222932">00050</a> <a class="code" href="_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html#9b6afd7f3f2f73a361844d7bff18436f">FDORDBMS_OV_API</a> <span class="keyword">virtual</span> <a class="code" href="class_fdo_rdbms_ov_class_definition.html">FdoRdbmsOvClassDefinition</a>* <a class="code" href="class_fdo_rdbms_ov_property_mapping_relation_9ec78dd558383c1fbd77f0f611222932.html#9ec78dd558383c1fbd77f0f611222932">CreateInternalClass</a>(
+<a name="l00051"></a>00051 <span class="keywordtype">bool</span> attach <span class="comment">// if true then make the new class the internal class for </span>
+<a name="l00052"></a>00052 <span class="comment">// this property mapping. Replaces any previous internal class </span>
+<a name="l00053"></a>00053 )
+<a name="l00054"></a>00054 {
+<a name="l00055"></a>00055 <span class="comment">// TODO: throw exception.</span>
+<a name="l00056"></a>00056 <span class="keywordflow">return</span> NULL;
+<a name="l00057"></a>00057 }
+<a name="l00058"></a>00058 <span class="comment">//DOM-IGNORE-END</span>
+<a name="l00060"></a>00060 <span class="keyword">protected</span>:
+<a name="l00061"></a>00061 <a class="code" href="_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html#9b6afd7f3f2f73a361844d7bff18436f">FDORDBMS_OV_API</a> <a class="code" href="class_fdo_rdbms_ov_property_mapping_relation_1d0a1c240408b951d053f580cc4e10f8.html#1d0a1c240408b951d053f580cc4e10f8">FdoRdbmsOvPropertyMappingRelation</a>();
+<a name="l00062"></a>00062 <a class="code" href="_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html#9b6afd7f3f2f73a361844d7bff18436f">FDORDBMS_OV_API</a> <span class="keyword">virtual</span> <a class="code" href="class_fdo_rdbms_ov_property_mapping_relation_0356f294429f9f0a4f0e980c0309e239.html#0356f294429f9f0a4f0e980c0309e239">~FdoRdbmsOvPropertyMappingRelation</a>();
+<a name="l00063"></a>00063 <span class="comment"></span>
+<a name="l00064"></a>00064 <span class="comment"> ///<summary>Sets the internal class</summary></span>
+<a name="l00065"></a>00065 <span class="comment"> /// <returns>Returns nothing</returns></span>
+<a name="l00066"></a>00066 <span class="comment"></span> <a class="code" href="_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html#9b6afd7f3f2f73a361844d7bff18436f">FDORDBMS_OV_API</a> <span class="keywordtype">void</span> <a class="code" href="class_fdo_rdbms_ov_property_mapping_relation_3bcb1a60ae2ab9b8868a022b32624e0d.html#3bcb1a60ae2ab9b8868a022b32624e0d">SetInternalClass</a>(<a class="code" href="class_fdo_rdbms_ov_class_definition.html">FdoRdbmsOvClassDefinition</a>* classDefinition);
+<a name="l00068"></a>00068 <span class="comment">// Handle start of sub-elements when deserializing from XML.</span>
+<a name="l00069"></a>00069 <a class="code" href="_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html#9b6afd7f3f2f73a361844d7bff18436f">FDORDBMS_OV_API</a> <span class="keyword">virtual</span> FdoXmlSaxHandler* <a class="code" href="class_fdo_rdbms_ov_property_mapping_relation_4c64aa5b06cd639b6f599ea0a3776589.html#4c64aa5b06cd639b6f599ea0a3776589">XmlStartElement</a>(
+<a name="l00070"></a>00070 FdoXmlSaxContext* context,
+<a name="l00071"></a>00071 FdoString* uri,
+<a name="l00072"></a>00072 FdoString* name,
+<a name="l00073"></a>00073 FdoString* qname,
+<a name="l00074"></a>00074 FdoXmlAttributeCollection* atts
+<a name="l00075"></a>00075 );
+<a name="l00076"></a>00076
+<a name="l00077"></a>00077 <span class="comment">// Handle end of sub-elements when deserializing from XML.</span>
+<a name="l00078"></a>00078 <a class="code" href="_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html#9b6afd7f3f2f73a361844d7bff18436f">FDORDBMS_OV_API</a> <span class="keyword">virtual</span> FdoBoolean <a class="code" href="class_fdo_rdbms_ov_property_mapping_relation_e8a263e8c6dc2b9351f6e7f0101c88e5.html#e8a263e8c6dc2b9351f6e7f0101c88e5">XmlEndElement</a>(
+<a name="l00079"></a>00079 FdoXmlSaxContext* context,
+<a name="l00080"></a>00080 FdoString* uri,
+<a name="l00081"></a>00081 FdoString* name,
+<a name="l00082"></a>00082 FdoString* qname
+<a name="l00083"></a>00083 );
+<a name="l00084"></a>00084
+<a name="l00085"></a>00085
+<a name="l00086"></a>00086 <span class="keyword">private</span>:
+<a name="l00087"></a>00087 FdoPtr<FdoRdbmsOvClassDefinition> mClassDefinition;
+<a name="l00088"></a>00088 };
+<a name="l00089"></a>00089 <span class="comment"></span>
+<a name="l00090"></a>00090 <span class="comment">///<summary></span>
+<a name="l00091"></a>00091 <span class="comment">///FdoRdbmsOvPropertyMappingRelationP is a FdoPtr on </span>
+<a name="l00092"></a>00092 <span class="comment">///FdoRdbmsOvPropertyMappingRelation, provided for convenience.</span>
+<a name="l00093"></a>00093 <span class="comment">///</summary></span>
+<a name="l00094"></a><a class="code" href="_rdbms_ov_property_mapping_relation_8h_b3f57932c53a39a0aa8aa9928ff972eb.html#b3f57932c53a39a0aa8aa9928ff972eb">00094</a> <span class="comment"></span><span class="keyword">typedef</span> FdoPtr<FdoRdbmsOvPropertyMappingRelation> <a class="code" href="_rdbms_ov_property_mapping_relation_8h_b3f57932c53a39a0aa8aa9928ff972eb.html#b3f57932c53a39a0aa8aa9928ff972eb">FdoRdbmsOvPropertyMappingRelationP</a>;
+<a name="l00095"></a>00095
+<a name="l00096"></a>00096 <span class="preprocessor">#endif</span>
+<a name="l00097"></a>00097 <span class="preprocessor"></span>
+ <hr>
+ <table width="100%" border="0">
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/ODBC/_rdbms_ov_property_mapping_relation_8h.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_property_mapping_relation_8h.html?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_rdbms_ov_property_mapping_relation_8h.html 2006-12-01 20:39:06+0000
@@ -0,0 +1,69 @@
+<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN" "http://www.w3.org/TR/html4/loose.dtd">
+<html>
+ <head>
+ <meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
+ <title>OSGeo FDO Provider for ODBC API Reference</title>
+ <link href="custom.css" rel="stylesheet" type="text/css">
+ <link href="tabs.css" rel="stylesheet" type="text/css">
+ </head>
+ <body bgcolor="#FFFFFF">
+ <tr>
+ <td><b>API Reference<b></td>
+ <td align="right"><b>OSGeo FDO Provider for ODBC<b></td>
+ </tr>
+ </table>
+<!-- End of: header.html -->
+<!-- Generated by Doxygen 1.4.6-NO -->
+<div class="tabs">
+ <ul>
+ <li><a href="main.html"><span>Main Page</span></a></li>
+ <li><a href="classes.html"><span>Classes</span></a></li>
+ <li id="current"><a href="files.html"><span>Files</span></a></li>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ <li><a href="files.html"><span>File List</span></a></li>
+ <li><a href="globals.html"><span>File Members</span></a></li>
+ </ul></div>
+<h1>RdbmsOvPropertyMappingRelation.h File Reference</h1>
+<p>
+<code>#include <<a class="el" href="_rdbms_ov_property_mapping_definition_8h-source.html">Rdbms/Override/RdbmsOvPropertyMappingDefinition.h</a>></code><br>
+<p>
+Include dependency graph for RdbmsOvPropertyMappingRelation.h:<p><center><img src="_rdbms_ov_property_mapping_relation_8h__incl.png" border="0" usemap="#RdbmsOvPropertyMappingRelation.h_map" alt=""></center>
+<map name="RdbmsOvPropertyMappingRelation.h_map">
+<area href="_rdbms_ov_8h.html" shape="rect" coords="703,32,897,59" alt="">
+<area href="_rdbms_ov_property_mapping_definition_8h.html" shape="rect" coords="300,58,655,84" alt="">
+</map>
+<p>
+This graph shows which files directly or indirectly include this file:<p><center><img src="_rdbms_ov_property_mapping_relation_8h__dep__incl.png" border="0" usemap="#RdbmsOvPropertyMappingRelation.hdep_map" alt=""></center>
+<map name="RdbmsOvPropertyMappingRelation.hdep_map">
+<area href="_rdbms_ov_property_mapping_class_8h.html" shape="rect" coords="312,7,539,34" alt="">
+<area href="_rdbms_ov_property_mapping_concrete_8h.html" shape="rect" coords="301,58,549,84" alt="">
+<area href="_rdbms_ov_object_property_definition_8h.html" shape="rect" coords="599,32,839,59" alt="">
+</map>
+<p>
+<a href="_rdbms_ov_property_mapping_relation_8h-source.html">Go to the source code of this file.</a><table border="0" cellpadding="0" cellspacing="0">
+<tr><td></td></tr>
+<tr><td colspan="2"><br><h2>Classes</h2></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">class </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_rdbms_ov_property_mapping_relation.html">FdoRdbmsOvPropertyMappingRelation</a></td></tr>
+<tr><td colspan="2"><br><h2>Typedefs</h2></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">typedef FdoPtr< <a class="el" href="class_fdo_rdbms_ov_property_mapping_relation.html">FdoRdbmsOvPropertyMappingRelation</a> > </td><td class="memItemRight" valign="bottom"><a class="el" href="_rdbms_ov_property_mapping_relation_8h_b3f57932c53a39a0aa8aa9928ff972eb.html#b3f57932c53a39a0aa8aa9928ff972eb">FdoRdbmsOvPropertyMappingRelationP</a></td></tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/ODBC/_rdbms_ov_property_mapping_relation_8h__dep__incl.map
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_property_mapping_relation_8h__dep__incl.map?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_rdbms_ov_property_mapping_relation_8h__dep__incl.map 2006-12-01 20:39:06+0000
@@ -0,0 +1,4 @@
+base referer
+rect $_rdbms_ov_property_mapping_class_8h.html 312,7 539,34
+rect $_rdbms_ov_property_mapping_concrete_8h.html 301,58 549,84
+rect $_rdbms_ov_object_property_definition_8h.html 599,32 839,59
Added: trunk/www/docs/ODBC/_rdbms_ov_property_mapping_relation_8h__dep__incl.md5
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_property_mapping_relation_8h__dep__incl.md5?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_rdbms_ov_property_mapping_relation_8h__dep__incl.md5 2006-12-01 20:39:06+0000
@@ -0,0 +1 @@
+c880e6be8b8ae1e8f374309d02724570
Added: trunk/www/docs/ODBC/_rdbms_ov_property_mapping_relation_8h__dep__incl.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_property_mapping_relation_8h__dep__incl.png?view=auto&rev=94
Added: trunk/www/docs/ODBC/_rdbms_ov_property_mapping_relation_8h__incl.map
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_property_mapping_relation_8h__incl.map?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_rdbms_ov_property_mapping_relation_8h__incl.map 2006-12-01 20:39:06+0000
@@ -0,0 +1,3 @@
+base referer
+rect $_rdbms_ov_8h.html 703,32 897,59
+rect $_rdbms_ov_property_mapping_definition_8h.html 300,58 655,84
Added: trunk/www/docs/ODBC/_rdbms_ov_property_mapping_relation_8h__incl.md5
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_property_mapping_relation_8h__incl.md5?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_rdbms_ov_property_mapping_relation_8h__incl.md5 2006-12-01 20:39:06+0000
@@ -0,0 +1 @@
+548c9cea27a9e65b29eb0e4583c590c3
Added: trunk/www/docs/ODBC/_rdbms_ov_property_mapping_relation_8h__incl.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_property_mapping_relation_8h__incl.png?view=auto&rev=94
Added: trunk/www/docs/ODBC/_rdbms_ov_property_mapping_relation_8h_b3f57932c53a39a0aa8aa9928ff972eb.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_property_mapping_relation_8h_b3f57932c53a39a0aa8aa9928ff972eb.html?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_rdbms_ov_property_mapping_relation_8h_b3f57932c53a39a0aa8aa9928ff972eb.html 2006-12-01 20:39:06+0000
@@ -0,0 +1,74 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="nav">
+<a class="el" href="_rdbms_ov_property_mapping_relation_8h.html">RdbmsOvPropertyMappingRelation.h</a></div>
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="_rdbms_ov_property_mapping_relation_8h_b3f57932c53a39a0aa8aa9928ff972eb.html#b3f57932c53a39a0aa8aa9928ff972eb">FdoRdbmsOvPropertyMappingRelationP</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="b3f57932c53a39a0aa8aa9928ff972eb"></a><!-- doxytag: member="RdbmsOvPropertyMappingRelation.h::FdoRdbmsOvPropertyMappingRelationP" ref="b3f57932c53a39a0aa8aa9928ff972eb" args="" --><p>
+<table class="mdTable" cellpadding="2" cellspacing="0">
+ <tr>
+ <td class="mdRow">
+ <table cellpadding="0" cellspacing="0" border="0">
+ <tr>
+ <td class="md" nowrap valign="top">typedef FdoPtr<<a class="el" href="class_fdo_rdbms_ov_property_mapping_relation.html">FdoRdbmsOvPropertyMappingRelation</a>> <a class="el" href="_rdbms_ov_property_mapping_relation_8h_b3f57932c53a39a0aa8aa9928ff972eb.html#b3f57932c53a39a0aa8aa9928ff972eb">FdoRdbmsOvPropertyMappingRelationP</a> </td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+<table cellspacing="5" cellpadding="0" border="0">
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+<p>
+Definition at line <a class="el" href="_rdbms_ov_property_mapping_relation_8h-source.html#l00094">94</a> of file <a class="el" href="_rdbms_ov_property_mapping_relation_8h-source.html">RdbmsOvPropertyMappingRelation.h</a>. </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/ODBC/_rdbms_ov_property_mapping_single_8h-source.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_property_mapping_single_8h-source.html?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_rdbms_ov_property_mapping_single_8h-source.html 2006-12-01 20:39:06+0000
@@ -0,0 +1,123 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<h1>RdbmsOvPropertyMappingSingle.h</h1><a href="_rdbms_ov_property_mapping_single_8h.html">Go to the documentation of this file.</a><div class="fragment"><pre class="fragment"><a name="l00001"></a>00001 <span class="preprocessor">#ifndef FDO_RDBMSOVPROPERTYMAPPINGSINGLE_H</span>
+<a name="l00002"></a>00002 <span class="preprocessor"></span><span class="preprocessor">#define FDO_RDBMSOVPROPERTYMAPPINGSINGLE_H</span>
+<a name="l00031"></a>00031 <span class="comment">///Abstract class defining the physical schema overrides for the Single </span>
+<a name="l00032"></a>00032 <span class="comment">///type object property mapping. Under the Single mapping type, the object </span>
+<a name="l00033"></a>00033 <span class="comment">///property is kept in the same table as its containing class.</span>
+<a name="l00035"></a><a class="code" href="class_fdo_rdbms_ov_property_mapping_single.html">00035</a> <span class="comment"></span><span class="keyword">class </span><a class="code" href="class_fdo_rdbms_ov_property_mapping_single.html">FdoRdbmsOvPropertyMappingSingle</a> : <span class="keyword">public</span> <span class="keyword">virtual</span> <a class="code" href="class_fdo_rdbms_ov_property_mapping_definition.html">FdoRdbmsOvPropertyMappingDefinition</a>
+<a name="l00037"></a>00037 <span class="keyword">public</span>:<span class="comment"></span>
+<a name="l00038"></a>00038 <span class="comment"> ///<summary></span>
+<a name="l00039"></a>00039 <span class="comment"> ///Gets the prefix which is prepended to the name of each column</span>
+<a name="l00040"></a>00040 <span class="comment"> ///</summary></span>
+<a name="l00041"></a>00041 <span class="comment"> /// <returns>Returns the prefix</returns></span>
+<a name="l00042"></a>00042 <span class="comment"></span> <a class="code" href="_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html#9b6afd7f3f2f73a361844d7bff18436f">FDORDBMS_OV_API</a> FdoString* <a class="code" href="class_fdo_rdbms_ov_property_mapping_single_39313f76df020263766b8c10479ad257.html#39313f76df020263766b8c10479ad257">GetPrefix</a>();
+<a name="l00043"></a>00043 <span class="comment"></span>
+<a name="l00044"></a>00044 <span class="comment"> ///<summary>Sets the prefix</summary></span>
+<a name="l00045"></a>00045 <span class="comment"> /// <returns>Returns nothing</returns></span>
+<a name="l00046"></a>00046 <span class="comment"></span> <a class="code" href="_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html#9b6afd7f3f2f73a361844d7bff18436f">FDORDBMS_OV_API</a> <span class="keywordtype">void</span> <a class="code" href="class_fdo_rdbms_ov_property_mapping_single_1a5d483c26b31cabd3871a10be45a90c.html#1a5d483c26b31cabd3871a10be45a90c">SetPrefix</a>(FdoString* prefix);
+<a name="l00048"></a>00048 <span class="comment">//DOM-IGNORE-BEGIN</span>
+<a name="l00050"></a>00050 <span class="comment">// XML Serialization functions, not part of the API.</span>
+<a name="l00052"></a>00052 <span class="comment">// Serialize this property to XML.</span>
+<a name="l00053"></a>00053 <a class="code" href="_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html#9b6afd7f3f2f73a361844d7bff18436f">FDORDBMS_OV_API</a> <span class="keyword">virtual</span> <span class="keywordtype">void</span> <a class="code" href="class_fdo_rdbms_ov_property_mapping_single_8e0e30c1088348915153f06684c83ca1.html#8e0e30c1088348915153f06684c83ca1">_writeXml</a>(FdoXmlWriter* xmlWriter, <span class="keyword">const</span> FdoXmlFlags* flags);
+<a name="l00055"></a>00055 <span class="comment">// Initialize this element from its XML attributes</span>
+<a name="l00056"></a>00056 <a class="code" href="_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html#9b6afd7f3f2f73a361844d7bff18436f">FDORDBMS_OV_API</a> <span class="keyword">virtual</span> <span class="keywordtype">void</span> <a class="code" href="class_fdo_rdbms_ov_property_mapping_single_b17c06ea2effe39282f1deddac722526.html#b17c06ea2effe39282f1deddac722526">InitFromXml</a>(FdoXmlSaxContext* pContext, FdoXmlAttributeCollection* attrs);
+<a name="l00061"></a>00061 <a class="code" href="_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html#9b6afd7f3f2f73a361844d7bff18436f">FDORDBMS_OV_API</a> <a class="code" href="class_fdo_rdbms_ov_property_mapping_single_7be8a29544577d9bfaa883ca263ddad7.html#7be8a29544577d9bfaa883ca263ddad7">FdoRdbmsOvPropertyMappingSingle</a>();
+<a name="l00062"></a>00062 <a class="code" href="_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html#9b6afd7f3f2f73a361844d7bff18436f">FDORDBMS_OV_API</a> <span class="keyword">virtual</span> <a class="code" href="class_fdo_rdbms_ov_property_mapping_single_7bb0d36e5fc78a8d91adb1ea79f77c1e.html#7bb0d36e5fc78a8d91adb1ea79f77c1e">~FdoRdbmsOvPropertyMappingSingle</a>();
+<a name="l00064"></a>00064 <span class="comment">// Handle sub-elements when deserializing from XML.</span>
+<a name="l00065"></a>00065 <a class="code" href="_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html#9b6afd7f3f2f73a361844d7bff18436f">FDORDBMS_OV_API</a> <span class="keyword">virtual</span> FdoXmlSaxHandler* <a class="code" href="class_fdo_rdbms_ov_property_mapping_single_4432ebee838b92bc50276c016b50734f.html#4432ebee838b92bc50276c016b50734f">XmlStartElement</a>(
+<a name="l00066"></a>00066 FdoXmlSaxContext* context,
+<a name="l00067"></a>00067 FdoString* uri,
+<a name="l00068"></a>00068 FdoString* name,
+<a name="l00069"></a>00069 FdoString* qname,
+<a name="l00070"></a>00070 FdoXmlAttributeCollection* atts
+<a name="l00071"></a>00071 );
+<a name="l00073"></a>00073 <span class="keyword">private</span>:
+<a name="l00074"></a>00074 FdoStringP mPrefix;
+<a name="l00075"></a>00075 };
+<a name="l00076"></a>00076 <span class="comment"></span>
+<a name="l00077"></a>00077 <span class="comment">///<summary></span>
+<a name="l00078"></a>00078 <span class="comment">///FdoRdbmsOvPropertyMappingSingleP is a FdoPtr on </span>
+<a name="l00079"></a>00079 <span class="comment">///FdoRdbmsOvPropertyMappingSingle, provided for convenience.</span>
+<a name="l00080"></a>00080 <span class="comment">///</summary></span>
+<a name="l00081"></a><a class="code" href="_rdbms_ov_property_mapping_single_8h_d486b981d11220f25c37a429705aea57.html#d486b981d11220f25c37a429705aea57">00081</a> <span class="comment"></span><span class="keyword">typedef</span> FdoPtr<FdoRdbmsOvPropertyMappingSingle> <a class="code" href="_rdbms_ov_property_mapping_single_8h_d486b981d11220f25c37a429705aea57.html#d486b981d11220f25c37a429705aea57">FdoRdbmsOvPropertyMappingSingleP</a>;
+<a name="l00083"></a>00083 <span class="preprocessor">#endif</span>
+<a name="l00084"></a>00084 <span class="preprocessor"></span>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/ODBC/_rdbms_ov_property_mapping_single_8h.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_property_mapping_single_8h.html?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_rdbms_ov_property_mapping_single_8h.html 2006-12-01 20:39:06+0000
@@ -0,0 +1,72 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<h1>RdbmsOvPropertyMappingSingle.h File Reference</h1>
+<p>
+<p>
+Include dependency graph for RdbmsOvPropertyMappingSingle.h:<p><center><img src="_rdbms_ov_property_mapping_single_8h__incl.png" border="0" usemap="#RdbmsOvPropertyMappingSingle.h_map" alt=""></center>
+<map name="RdbmsOvPropertyMappingSingle.h_map">
+<area href="_rdbms_ov_8h.html" shape="rect" coords="763,57,958,84" alt="">
+<area href="_rdbms_ov_property_mapping_definition_8h.html" shape="rect" coords="290,108,644,135" alt="">
+</map>
+<p>
+This graph shows which files directly or indirectly include this file:<p><center><img src="_rdbms_ov_property_mapping_single_8h__dep__incl.png" border="0" usemap="#RdbmsOvPropertyMappingSingle.hdep_map" alt=""></center>
+<map name="RdbmsOvPropertyMappingSingle.hdep_map">
+<area href="_rdbms_ov_object_property_definition_8h.html" shape="rect" coords="290,32,530,59" alt="">
+<area href="_rdbms_ov_class_definition_8h.html" shape="rect" coords="579,32,760,59" alt="">
+<area href="_odbc_ov_class_definition_8h.html" shape="rect" coords="816,7,990,34" alt="">
+<area href="_rdbms_ov_class_collection_8h.html" shape="rect" coords="811,58,995,84" alt="">
+</map>
+<p>
+<a href="_rdbms_ov_property_mapping_single_8h-source.html">Go to the source code of this file.</a><table border="0" cellpadding="0" cellspacing="0">
+<tr><td></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">class </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_rdbms_ov_property_mapping_single.html">FdoRdbmsOvPropertyMappingSingle</a></td></tr>
+<tr><td class="mdescLeft"> </td><td class="mdescRight">Abstract class defining the physical schema overrides for the Single type object property mapping. Under the Single mapping type, the object property is kept in the same table as its containing class. /summary>. <a href="class_fdo_rdbms_ov_property_mapping_single.html#_details">More...</a><br></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">typedef FdoPtr< <a class="el" href="class_fdo_rdbms_ov_property_mapping_single.html">FdoRdbmsOvPropertyMappingSingle</a> > </td><td class="memItemRight" valign="bottom"><a class="el" href="_rdbms_ov_property_mapping_single_8h_d486b981d11220f25c37a429705aea57.html#d486b981d11220f25c37a429705aea57">FdoRdbmsOvPropertyMappingSingleP</a></td></tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/ODBC/_rdbms_ov_property_mapping_single_8h__dep__incl.map
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_property_mapping_single_8h__dep__incl.map?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_rdbms_ov_property_mapping_single_8h__dep__incl.map 2006-12-01 20:39:06+0000
@@ -0,0 +1,5 @@
+base referer
+rect $_rdbms_ov_object_property_definition_8h.html 290,32 530,59
+rect $_rdbms_ov_class_definition_8h.html 579,32 760,59
+rect $_odbc_ov_class_definition_8h.html 816,7 990,34
+rect $_rdbms_ov_class_collection_8h.html 811,58 995,84
Added: trunk/www/docs/ODBC/_rdbms_ov_property_mapping_single_8h__dep__incl.md5
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_property_mapping_single_8h__dep__incl.md5?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_rdbms_ov_property_mapping_single_8h__dep__incl.md5 2006-12-01 20:39:06+0000
@@ -0,0 +1 @@
+347338a8c4c4e3c0b6c5f9d1405d770f
Added: trunk/www/docs/ODBC/_rdbms_ov_property_mapping_single_8h__dep__incl.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_property_mapping_single_8h__dep__incl.png?view=auto&rev=94
Added: trunk/www/docs/ODBC/_rdbms_ov_property_mapping_single_8h__incl.map
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_property_mapping_single_8h__incl.map?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_rdbms_ov_property_mapping_single_8h__incl.map 2006-12-01 20:39:06+0000
@@ -0,0 +1,3 @@
+base referer
+rect $_rdbms_ov_8h.html 763,57 958,84
+rect $_rdbms_ov_property_mapping_definition_8h.html 290,108 644,135
Added: trunk/www/docs/ODBC/_rdbms_ov_property_mapping_single_8h__incl.md5
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_property_mapping_single_8h__incl.md5?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_rdbms_ov_property_mapping_single_8h__incl.md5 2006-12-01 20:39:06+0000
@@ -0,0 +1 @@
+5c471dba444908c0f3999e2a52c1f003
Added: trunk/www/docs/ODBC/_rdbms_ov_property_mapping_single_8h__incl.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_property_mapping_single_8h__incl.png?view=auto&rev=94
Added: trunk/www/docs/ODBC/_rdbms_ov_property_mapping_single_8h_d486b981d11220f25c37a429705aea57.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_property_mapping_single_8h_d486b981d11220f25c37a429705aea57.html?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_rdbms_ov_property_mapping_single_8h_d486b981d11220f25c37a429705aea57.html 2006-12-01 20:39:06+0000
@@ -0,0 +1,74 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="nav">
+<a class="el" href="_rdbms_ov_property_mapping_single_8h.html">RdbmsOvPropertyMappingSingle.h</a></div>
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="_rdbms_ov_property_mapping_single_8h_d486b981d11220f25c37a429705aea57.html#d486b981d11220f25c37a429705aea57">FdoRdbmsOvPropertyMappingSingleP</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="d486b981d11220f25c37a429705aea57"></a><!-- doxytag: member="RdbmsOvPropertyMappingSingle.h::FdoRdbmsOvPropertyMappingSingleP" ref="d486b981d11220f25c37a429705aea57" args="" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">typedef FdoPtr<<a class="el" href="class_fdo_rdbms_ov_property_mapping_single.html">FdoRdbmsOvPropertyMappingSingle</a>> <a class="el" href="_rdbms_ov_property_mapping_single_8h_d486b981d11220f25c37a429705aea57.html#d486b981d11220f25c37a429705aea57">FdoRdbmsOvPropertyMappingSingleP</a> </td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+<p>
+Definition at line <a class="el" href="_rdbms_ov_property_mapping_single_8h-source.html#l00081">81</a> of file <a class="el" href="_rdbms_ov_property_mapping_single_8h-source.html">RdbmsOvPropertyMappingSingle.h</a>. </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/ODBC/_rdbms_ov_schema_auto_generation_8h-source.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_schema_auto_generation_8h-source.html?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_rdbms_ov_schema_auto_generation_8h-source.html 2006-12-01 20:39:06+0000
@@ -0,0 +1,188 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<h1>RdbmsOvSchemaAutoGeneration.h</h1><a href="_rdbms_ov_schema_auto_generation_8h.html">Go to the documentation of this file.</a><div class="fragment"><pre class="fragment"><a name="l00001"></a>00001 <span class="preprocessor">#ifndef FDO_RDBMSOVSCHEMAAUTOGENERATION_H</span>
+<a name="l00002"></a>00002 <span class="preprocessor"></span><span class="preprocessor">#define FDO_RDBMSOVSCHEMAAUTOGENERATION_H</span>
+<a name="l00003"></a>00003 <span class="preprocessor"></span><span class="comment">//</span>
+<a name="l00019"></a>00019 <span class="comment">//</span>
+<a name="l00021"></a>00021 <span class="preprocessor">#include <Fdo/Commands/Schema/PhysicalElementMapping.h></span>
+<a name="l00022"></a>00022 <span class="preprocessor">#include <Fdo/Xml/NameCollectionHandler.h></span>
+<a name="l00023"></a>00023 <span class="preprocessor">#include <<a class="code" href="_rdbms_ov_8h.html">Rdbms/Override/RdbmsOv.h</a>></span>
+<a name="l00025"></a>00025 <span class="comment">/// <library></span>
+<a name="l00026"></a>00026 <span class="comment">/// FdoRdbms.lib</span>
+<a name="l00027"></a>00027 <span class="comment">/// </library></span>
+<a name="l00028"></a>00028 <span class="comment"></span><span class="comment"></span>
+<a name="l00029"></a>00029 <span class="comment">///<summary></span>
+<a name="l00030"></a>00030 <span class="comment">///This class provides directives for reverse-engineering FDO</span>
+<a name="l00031"></a>00031 <span class="comment">///Feature Schema elements from the physical schema of the currently </span>
+<a name="l00032"></a>00032 <span class="comment">///connected datastore.</span>
+<a name="l00034"></a><a class="code" href="class_fdo_rdbms_ov_schema_auto_generation.html">00034</a> <span class="comment"></span><span class="keyword">class </span><a class="code" href="class_fdo_rdbms_ov_schema_auto_generation.html">FdoRdbmsOvSchemaAutoGeneration</a>: <span class="keyword">public</span> FdoPhysicalElementMapping
+<a name="l00038"></a>00038 <span class="comment"> ///<summary>Creates a set of schema autogeneration settings.</span>
+<a name="l00039"></a>00039 <span class="comment"> ///</summary></span>
+<a name="l00040"></a>00040 <span class="comment"> ///<returns>Returns FdoRdbmsOvSchemaAutoGeneration</returns></span>
+<a name="l00041"></a>00041 <span class="comment"></span> <a class="code" href="_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html#9b6afd7f3f2f73a361844d7bff18436f">FDORDBMS_OV_API</a> <span class="keyword">static</span> <a class="code" href="class_fdo_rdbms_ov_schema_auto_generation.html">FdoRdbmsOvSchemaAutoGeneration</a>* <a class="code" href="class_fdo_rdbms_ov_schema_auto_generation_1d8bc2acd02130612b4604abaf46b081.html#1d8bc2acd02130612b4604abaf46b081">Create</a>();
+<a name="l00043"></a>00043 <span class="comment"> ///<summary>Gets the table prefix for autogenerating class definitions.</span>
+<a name="l00044"></a>00044 <span class="comment"> ///When set, an FDO Class Definition is automatically generated for</span>
+<a name="l00045"></a>00045 <span class="comment"> ///each table whose name begins with this prefix. Any table already </span>
+<a name="l00046"></a>00046 <span class="comment"> ///referenced by a class definition is skipped. Each generated class is </span>
+<a name="l00047"></a>00047 <span class="comment"> ///added to the Feature Schema for this Schema Mapping Set.</span>
+<a name="l00048"></a>00048 <span class="comment"> ///</summary></span>
+<a name="l00049"></a>00049 <span class="comment"> ///<returns>Returns the class autogeneration table name prefix</returns></span>
+<a name="l00050"></a>00050 <span class="comment"></span> <a class="code" href="_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html#9b6afd7f3f2f73a361844d7bff18436f">FDORDBMS_OV_API</a> FdoString* <a class="code" href="class_fdo_rdbms_ov_schema_auto_generation_b4a99aa44de049ec3363cb355ef0f05b.html#b4a99aa44de049ec3363cb355ef0f05b">GetGenTablePrefix</a>();
+<a name="l00051"></a>00051 <span class="comment"></span>
+<a name="l00052"></a>00052 <span class="comment"> ///<summary></span>
+<a name="l00053"></a>00053 <span class="comment"> ///Sets the table prefix for autogenerating class definitions.</span>
+<a name="l00054"></a>00054 <span class="comment"> ///</summary></span>
+<a name="l00055"></a>00055 <span class="comment"> /// <param name="tablePrefix"></span>
+<a name="l00056"></a>00056 <span class="comment"> /// Input the table prefix. If L"" then no </span>
+<a name="l00057"></a>00057 <span class="comment"> /// classes will be generated by table prefix.</span>
+<a name="l00058"></a>00058 <span class="comment"> /// </param></span>
+<a name="l00059"></a>00059 <span class="comment"> ///<returns>Returns nothing</returns></span>
+<a name="l00060"></a>00060 <span class="comment"></span> <a class="code" href="_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html#9b6afd7f3f2f73a361844d7bff18436f">FDORDBMS_OV_API</a> <span class="keywordtype">void</span> <a class="code" href="class_fdo_rdbms_ov_schema_auto_generation_95910d04bc6fcf61cd88e4247c25e8b9.html#95910d04bc6fcf61cd88e4247c25e8b9">SetGenTablePrefix</a>(FdoString* tablePrefix);
+<a name="l00061"></a>00061 <span class="comment"></span>
+<a name="l00062"></a>00062 <span class="comment"> ///<summary>Gets the table prefix removal setting. This setting affects</span>
+<a name="l00063"></a>00063 <span class="comment"> ///how classes, generated from tables matching the table prefix, are named:</span>
+<a name="l00064"></a>00064 <span class="comment"> /// * when true, the class name is the table name with prefix removed. </span>
+<a name="l00065"></a>00065 <span class="comment"> /// true is the default setting.</span>
+<a name="l00066"></a>00066 <span class="comment"> /// * when false, the class name is the table name. </span>
+<a name="l00067"></a>00067 <span class="comment"> ///</summary></span>
+<a name="l00068"></a>00068 <span class="comment"> ///<returns>Returns FdoBoolean.</returns></span>
+<a name="l00069"></a>00069 <span class="comment"></span> <a class="code" href="_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html#9b6afd7f3f2f73a361844d7bff18436f">FDORDBMS_OV_API</a> FdoBoolean <a class="code" href="class_fdo_rdbms_ov_schema_auto_generation_fce5f95403f431707747d2bf0248ebd5.html#fce5f95403f431707747d2bf0248ebd5">GetRemoveTablePrefix</a>();
+<a name="l00070"></a>00070 <span class="comment"></span>
+<a name="l00071"></a>00071 <span class="comment"> ///<summary>Sets the "remove table prefix" setting.</summary></span>
+<a name="l00072"></a>00072 <span class="comment"> /// <param name="removeTablePrefix"></span>
+<a name="l00073"></a>00073 <span class="comment"> /// Input the "remove table prefix" setting.</span>
+<a name="l00074"></a>00074 <span class="comment"></span> <span class="comment">// </param></span><span class="comment"></span>
+<a name="l00075"></a>00075 <span class="comment"> ///<returns>Returns nothing</returns></span>
+<a name="l00076"></a>00076 <span class="comment"></span> <a class="code" href="_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html#9b6afd7f3f2f73a361844d7bff18436f">FDORDBMS_OV_API</a> <span class="keywordtype">void</span> <a class="code" href="class_fdo_rdbms_ov_schema_auto_generation_5366adde2b202582dc29ada8b0776b51.html#5366adde2b202582dc29ada8b0776b51">SetRemoveTablePrefix</a>(FdoBoolean removeTablePrefix);
+<a name="l00077"></a>00077 <span class="comment"></span>
+<a name="l00078"></a>00078 <span class="comment"> ///<summary>Gets the list of tables or views for which class definitions </span>
+<a name="l00079"></a>00079 <span class="comment"> ///will be autogenerated. Once retrieved, the caller can populate this </span>
+<a name="l00080"></a>00080 <span class="comment"> ///list.</span>
+<a name="l00081"></a>00081 <span class="comment"> ///When set, an FDO Class Definition is automatically generated for</span>
+<a name="l00082"></a>00082 <span class="comment"> ///each table in this list. Any table already </span>
+<a name="l00083"></a>00083 <span class="comment"> ///referenced by a class definition is skipped. Each generated class is </span>
+<a name="l00084"></a>00084 <span class="comment"> ///added to the Feature Schema for this Schema Mapping Set.</span>
+<a name="l00085"></a>00085 <span class="comment"> ///</span>
+<a name="l00086"></a>00086 <span class="comment"> ///Note: the only way to autogenerate a class definition from a view</span>
+<a name="l00087"></a>00087 <span class="comment"> ///is to add the view name to this list. There is one caveat in that</span>
+<a name="l00088"></a>00088 <span class="comment"> ///the generated class will not have identity properties. </span>
+<a name="l00089"></a>00089 <span class="comment"> ///</summary></span>
+<a name="l00090"></a>00090 <span class="comment"> ///<returns>Returns FdoStringCollection</returns></span>
+<a name="l00091"></a>00091 <span class="comment"></span> <a class="code" href="_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html#9b6afd7f3f2f73a361844d7bff18436f">FDORDBMS_OV_API</a> FdoStringCollection* <a class="code" href="class_fdo_rdbms_ov_schema_auto_generation_10607168b4dc6988da728924b9bf3a85.html#10607168b4dc6988da728924b9bf3a85">GetGenTableList</a>();
+<a name="l00092"></a>00092 <span class="comment"></span>
+<a name="l00093"></a>00093 <span class="comment"> ///<summary>Gets the maximum number of rows to sample when table data</span>
+<a name="l00094"></a>00094 <span class="comment"> ///must be examined to determine schema information. The situations </span>
+<a name="l00095"></a>00095 <span class="comment"> ///where this must be done depend on the provider. For example, </span>
+<a name="l00096"></a>00096 <span class="comment"> ///when a geometric property is generated from a geometric column, the </span>
+<a name="l00097"></a>00097 <span class="comment"> ///geomety types might be determined by examining some of the geometry</span>
+<a name="l00098"></a>00098 <span class="comment"> ///values in the column.</span>
+<a name="l00099"></a>00099 <span class="comment"> ///</span>
+<a name="l00100"></a>00100 <span class="comment"> ///MaxSampleRows can be any positive integer or one of the following:</span>
+<a name="l00101"></a>00101 <span class="comment"> /// * 0: all rows in the table are sampled. (Not recommended for</span>
+<a name="l00102"></a>00102 <span class="comment"> /// large datastores).</span>
+<a name="l00103"></a>00103 <span class="comment"> /// * -1: no rows are sampled.</span>
+<a name="l00104"></a>00104 <span class="comment"> ///</span>
+<a name="l00105"></a>00105 <span class="comment"> ///</summary></span>
+<a name="l00106"></a>00106 <span class="comment"> ///<returns>Returns FdoBoolean.</returns></span>
+<a name="l00107"></a>00107 <span class="comment"></span> <a class="code" href="_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html#9b6afd7f3f2f73a361844d7bff18436f">FDORDBMS_OV_API</a> FdoInt32 <a class="code" href="class_fdo_rdbms_ov_schema_auto_generation_1d003bbe339a1b983e450a9d3fe7f165.html#1d003bbe339a1b983e450a9d3fe7f165">GetMaxSampleRows</a>();
+<a name="l00108"></a>00108 <span class="comment"></span>
+<a name="l00109"></a>00109 <span class="comment"> ///<summary>Sets the maximum number of rows to sample when </span>
+<a name="l00110"></a>00110 <span class="comment"> ///determining schema from table data. Higher values give a more</span>
+<a name="l00111"></a>00111 <span class="comment"> ///accurate result but lower values provide better performance.</summary></span>
+<a name="l00112"></a>00112 <span class="comment"> /// <param name="maxRows">Input the maximum number of rows to sample.</param></span>
+<a name="l00113"></a>00113 <span class="comment"> ///<returns>Returns nothing</returns></span>
+<a name="l00114"></a>00114 <span class="comment"></span> <a class="code" href="_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html#9b6afd7f3f2f73a361844d7bff18436f">FDORDBMS_OV_API</a> <span class="keywordtype">void</span> <a class="code" href="class_fdo_rdbms_ov_schema_auto_generation_172f90d8d0c7c0ce3a046186a70fa4b3.html#172f90d8d0c7c0ce3a046186a70fa4b3">SetMaxSampleRows</a>(FdoInt32 maxRows);
+<a name="l00115"></a>00115
+<a name="l00116"></a>00116 <span class="comment">//DOM-IGNORE-BEGIN</span>
+<a name="l00117"></a>00117 <span class="comment">// Initialize this element from its XML attributes</span>
+<a name="l00118"></a>00118 <span class="keyword">virtual</span> <span class="keywordtype">void</span> <a class="code" href="class_fdo_rdbms_ov_schema_auto_generation_a08327e0743427ccb6233ce25c0354e2.html#a08327e0743427ccb6233ce25c0354e2">InitFromXml</a>(FdoXmlSaxContext* pContext, FdoXmlAttributeCollection* attrs);
+<a name="l00119"></a>00119
+<a name="l00120"></a>00120 <span class="comment">// Serialize this property to XML.</span>
+<a name="l00121"></a>00121 <span class="keyword">virtual</span> <span class="keywordtype">void</span> <a class="code" href="class_fdo_rdbms_ov_schema_auto_generation_ddf56629e27d25b1f5e5457c807a1c5c.html#ddf56629e27d25b1f5e5457c807a1c5c">_writeXml</a>(FdoXmlWriter* xmlWriter, <span class="keyword">const</span> FdoXmlFlags* flags);
+<a name="l00122"></a>00122 <span class="comment">//DOM-IGNORE-END</span>
+<a name="l00123"></a>00123
+<a name="l00124"></a>00124 <span class="keyword">protected</span>:
+<a name="l00125"></a>00125 <a class="code" href="class_fdo_rdbms_ov_schema_auto_generation_4ca740f68b29d8d40e9a817145d6dcff.html#4ca740f68b29d8d40e9a817145d6dcff">FdoRdbmsOvSchemaAutoGeneration</a>();
+<a name="l00126"></a>00126 <span class="keyword">virtual</span> <a class="code" href="class_fdo_rdbms_ov_schema_auto_generation_894de2f28577f3309b384e23f269b4f3.html#894de2f28577f3309b384e23f269b4f3">~FdoRdbmsOvSchemaAutoGeneration</a>();
+<a name="l00127"></a>00127 <span class="keyword">virtual</span> <span class="keywordtype">void</span> <a class="code" href="class_fdo_rdbms_ov_schema_auto_generation_bcccc6acca278bb74ecf48f848643763.html#bcccc6acca278bb74ecf48f848643763">Dispose</a>();
+<a name="l00128"></a>00128
+<a name="l00129"></a>00129 <span class="comment">// Handle the table list.</span>
+<a name="l00130"></a>00130 FdoXmlSaxHandler* <a class="code" href="class_fdo_rdbms_ov_schema_auto_generation_4286f512b8811f479e47daa867b5ad20.html#4286f512b8811f479e47daa867b5ad20">XmlStartElement</a>(
+<a name="l00131"></a>00131 FdoXmlSaxContext* context,
+<a name="l00132"></a>00132 FdoString* uri,
+<a name="l00133"></a>00133 FdoString* name,
+<a name="l00134"></a>00134 FdoString* qname,
+<a name="l00135"></a>00135 FdoXmlAttributeCollection* atts
+<a name="l00136"></a>00136 );
+<a name="l00137"></a>00137 <span class="keyword">private</span>:
+<a name="l00138"></a>00138 FdoStringP mGenTablePrefix;
+<a name="l00139"></a>00139 FdoBoolean mRemoveTablePrefix;
+<a name="l00140"></a>00140 FdoInt32 mMaxSampleRows;
+<a name="l00141"></a>00141
+<a name="l00142"></a>00142 FdoXmlNameCollectionHandlerP mTableListSerializer;
+<a name="l00143"></a>00143 };
+<a name="l00144"></a>00144 <span class="comment"></span>
+<a name="l00145"></a>00145 <span class="comment">///<summary>FdoRdbmsOvSchemaAutoGenerationP is a FdoPtr on FdoRdbmsOvSchemaAutoGeneration, provided for convenience.</summary></span>
+<a name="l00146"></a><a class="code" href="_rdbms_ov_schema_auto_generation_8h_499cf448778c4955e4e0f6776244c105.html#499cf448778c4955e4e0f6776244c105">00146</a> <span class="comment"></span><span class="keyword">typedef</span> FdoPtr<FdoRdbmsOvSchemaAutoGeneration> <a class="code" href="_rdbms_ov_schema_auto_generation_8h_499cf448778c4955e4e0f6776244c105.html#499cf448778c4955e4e0f6776244c105">FdoRdbmsOvSchemaAutoGenerationP</a>;
+<a name="l00147"></a>00147
+<a name="l00148"></a>00148 <span class="preprocessor">#endif</span>
+<a name="l00149"></a>00149 <span class="preprocessor"></span>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/ODBC/_rdbms_ov_schema_auto_generation_8h.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_schema_auto_generation_8h.html?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_rdbms_ov_schema_auto_generation_8h.html 2006-12-01 20:39:06+0000
@@ -0,0 +1,69 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<h1>RdbmsOvSchemaAutoGeneration.h File Reference</h1>
+<p>
+<code>#include <Fdo/Xml/NameCollectionHandler.h></code><br>
+<code>#include <<a class="el" href="_rdbms_ov_8h-source.html">Rdbms/Override/RdbmsOv.h</a>></code><br>
+<p>
+Include dependency graph for RdbmsOvSchemaAutoGeneration.h:<p><center><img src="_rdbms_ov_schema_auto_generation_8h__incl.png" border="0" usemap="#RdbmsOvSchemaAutoGeneration.h_map" alt=""></center>
+<map name="RdbmsOvSchemaAutoGeneration.h_map">
+<area href="_rdbms_ov_8h.html" shape="rect" coords="363,108,558,135" alt="">
+</map>
+<p>
+This graph shows which files directly or indirectly include this file:<p><center><img src="_rdbms_ov_schema_auto_generation_8h__dep__incl.png" border="0" usemap="#RdbmsOvSchemaAutoGeneration.hdep_map" alt=""></center>
+<map name="RdbmsOvSchemaAutoGeneration.hdep_map">
+<area href="_rdbms_ov_physical_schema_mapping_8h.html" shape="rect" coords="294,7,536,33" alt="">
+<area href="_odbc_ov_physical_schema_mapping_8h.html" shape="rect" coords="587,7,819,33" alt="">
+</map>
+<p>
+<a href="_rdbms_ov_schema_auto_generation_8h-source.html">Go to the source code of this file.</a><table border="0" cellpadding="0" cellspacing="0">
+<tr><td></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">class </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_rdbms_ov_schema_auto_generation.html">FdoRdbmsOvSchemaAutoGeneration</a></td></tr>
+<tr><td class="mdescLeft"> </td><td class="mdescRight">This class provides directives for reverse-engineering FDO Feature Schema elements from the physical schema of the currently connected datastore. /summary>. <a href="class_fdo_rdbms_ov_schema_auto_generation.html#_details">More...</a><br></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">typedef FdoPtr< <a class="el" href="class_fdo_rdbms_ov_schema_auto_generation.html">FdoRdbmsOvSchemaAutoGeneration</a> > </td><td class="memItemRight" valign="bottom"><a class="el" href="_rdbms_ov_schema_auto_generation_8h_499cf448778c4955e4e0f6776244c105.html#499cf448778c4955e4e0f6776244c105">FdoRdbmsOvSchemaAutoGenerationP</a></td></tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/ODBC/_rdbms_ov_schema_auto_generation_8h_499cf448778c4955e4e0f6776244c105.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_schema_auto_generation_8h_499cf448778c4955e4e0f6776244c105.html?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_rdbms_ov_schema_auto_generation_8h_499cf448778c4955e4e0f6776244c105.html 2006-12-01 20:39:06+0000
@@ -0,0 +1,74 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="nav">
+<a class="el" href="_rdbms_ov_schema_auto_generation_8h.html">RdbmsOvSchemaAutoGeneration.h</a></div>
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="_rdbms_ov_schema_auto_generation_8h_499cf448778c4955e4e0f6776244c105.html#499cf448778c4955e4e0f6776244c105">FdoRdbmsOvSchemaAutoGenerationP</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="499cf448778c4955e4e0f6776244c105"></a><!-- doxytag: member="RdbmsOvSchemaAutoGeneration.h::FdoRdbmsOvSchemaAutoGenerationP" ref="499cf448778c4955e4e0f6776244c105" args="" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">typedef FdoPtr<<a class="el" href="class_fdo_rdbms_ov_schema_auto_generation.html">FdoRdbmsOvSchemaAutoGeneration</a>> <a class="el" href="_rdbms_ov_schema_auto_generation_8h_499cf448778c4955e4e0f6776244c105.html#499cf448778c4955e4e0f6776244c105">FdoRdbmsOvSchemaAutoGenerationP</a> </td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+<p>
+Definition at line <a class="el" href="_rdbms_ov_schema_auto_generation_8h-source.html#l00146">146</a> of file <a class="el" href="_rdbms_ov_schema_auto_generation_8h-source.html">RdbmsOvSchemaAutoGeneration.h</a>. </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ <td align="right"><font size="-2"><a href="mailto:isd.docs at autodesk.com&subject=FDO%20Provider%20for%20ODBC%20API%20documentation">Comments?</a></font></td>
+ <!-- The logo can go in another cell, when we get one -->
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/ODBC/_rdbms_ov_schema_auto_generation_8h__dep__incl.map
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_schema_auto_generation_8h__dep__incl.map?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_rdbms_ov_schema_auto_generation_8h__dep__incl.map 2006-12-01 20:39:06+0000
@@ -0,0 +1,3 @@
+base referer
+rect $_rdbms_ov_physical_schema_mapping_8h.html 294,7 536,33
+rect $_odbc_ov_physical_schema_mapping_8h.html 587,7 819,33
Added: trunk/www/docs/ODBC/_rdbms_ov_schema_auto_generation_8h__dep__incl.md5
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_schema_auto_generation_8h__dep__incl.md5?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_rdbms_ov_schema_auto_generation_8h__dep__incl.md5 2006-12-01 20:39:06+0000
@@ -0,0 +1 @@
+c87559e4c4ddb30a3ffb1425c6bdfc23
Added: trunk/www/docs/ODBC/_rdbms_ov_schema_auto_generation_8h__dep__incl.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_schema_auto_generation_8h__dep__incl.png?view=auto&rev=94
Added: trunk/www/docs/ODBC/_rdbms_ov_schema_auto_generation_8h__incl.map
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_schema_auto_generation_8h__incl.map?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_rdbms_ov_schema_auto_generation_8h__incl.map 2006-12-01 20:39:06+0000
@@ -0,0 +1,2 @@
+base referer
+rect $_rdbms_ov_8h.html 363,108 558,135
Added: trunk/www/docs/ODBC/_rdbms_ov_schema_auto_generation_8h__incl.md5
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_schema_auto_generation_8h__incl.md5?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_rdbms_ov_schema_auto_generation_8h__incl.md5 2006-12-01 20:39:06+0000
@@ -0,0 +1 @@
+7c1a47fedb29028389f3cbc135db0ad4
Added: trunk/www/docs/ODBC/_rdbms_ov_schema_auto_generation_8h__incl.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_schema_auto_generation_8h__incl.png?view=auto&rev=94
Added: trunk/www/docs/ODBC/_rdbms_ov_table_8h-source.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/ODBC/_rdbms_ov_table_8h-source.html?view=auto&rev=94
--- (empty file)
+++ trunk/www/docs/ODBC/_rdbms_ov_table_8h-source.html 2006-12-01 20:39:06+0000
@@ -0,0 +1,117 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<h1>RdbmsOvTable.h</h1><a href="_rdbms_ov_table_8h.html">Go to the documentation of this file.</a><div class="fragment"><pre class="fragment"><a name="l00001"></a>00001 <span class="preprocessor">#ifndef FDO_RDBMSOVTABLE_H</span>
+<a name="l00002"></a>00002 <span class="preprocessor"></span><span class="preprocessor">#define FDO_RDBMSOVTABLE_H</span>
+<a name="l00025"></a>00025 <span class="preprocessor">#include <FdoCommon.h></span>
+<a name="l00026"></a>00026 <span class="preprocessor">#include <Fdo/Commands/Schema/PhysicalElementMapping.h></span>
+<a name="l00027"></a>00027 <span class="preprocessor">#include <<a class="code" href="_rdbms_ov_8h.html">Rdbms/Override/RdbmsOv.h</a>></span>
+<a name="l00029"></a>00029 <span class="comment">///<summary>Abstract class defining physical schema overrides for a table.</summary></span>
+<a name="l00030"></a><a class="code" href="class_fdo_rdbms_ov_table.html">00030</a> <span class="comment"></span><span class="keyword">class </span><a class="code" href="class_fdo_rdbms_ov_table.html">FdoRdbmsOvTable</a> : <span class="keyword">public</span> FdoPhysicalElementMapping
+<a name="l00031"></a>00031 {
+<a name="l00032"></a>00032 <span class="keyword">public</span>:<span class="comment"></span>
+<a name="l00033"></a>00033 <span class="comment"> ///<summary>Gets the primary key nane</summary></span>
+<a name="l00034"></a>00034 <span class="comment"> ///<returns>Returns the primary key name</returns></span>
+<a name="l00035"></a>00035 <span class="comment"></span> <a class="code" href="_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html#9b6afd7f3f2f73a361844d7bff18436f">FDORDBMS_OV_API</a> FdoString *<a class="code" href="class_fdo_rdbms_ov_table_7c5c89a5bc08fe0c439bdc416bd39b7b.html#7c5c89a5bc08fe0c439bdc416bd39b7b">GetPKeyName</a>();
+<a name="l00036"></a>00036 <span class="comment"></span>
+<a name="l00037"></a>00037 <span class="comment"> ///<summary>Sets the primary key name</summary></span>
+<a name="l00038"></a>00038 <span class="comment"> /// <param name="pKeyName">Input the primary key name</param></span>
+<a name="l00039"></a>00039 <span class="comment"> ///<returns>Returns nothing</returns></span>
+<a name="l00040"></a>00040 <span class="comment"></span> <a class="code" href="_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html#9b6afd7f3f2f73a361844d7bff18436f">FDORDBMS_OV_API</a> <span class="keywordtype">void</span> <a class="code" href="class_fdo_rdbms_ov_table_851524a620c0f7bd5668ea19d56dd718.html#851524a620c0f7bd5668ea19d56dd718">SetPKeyName</a>(FdoString *pKeyName);
+<a name="l00042"></a>00042 <span class="comment">//DOM-IGNORE-BEGIN</span>
+<a name="l00043"></a>00043 <span class="comment">// Makes SetParent function public.</span>
+<a name="l00044"></a>00044 <a class="code" href="_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html#9b6afd7f3f2f73a361844d7bff18436f">FDORDBMS_OV_API</a> <span class="keywordtype">void</span> <a class="code" href="class_fdo_rdbms_ov_table_36b365e957e8aaadce79998310a89597.html#36b365e957e8aaadce79998310a89597">SetParent</a>(FdoPhysicalElementMapping* value);
+<a name="l00046"></a>00046 <span class="comment">// Serialize this property to XML.</span>
+<a name="l00047"></a>00047 <a class="code" href="_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html#9b6afd7f3f2f73a361844d7bff18436f">FDORDBMS_OV_API</a> <span class="keyword">virtual</span> <span class="keywordtype">void</span> <a class="code" href="class_fdo_rdbms_ov_table_22cd99f83948f56058e375600c0690d5.html#22cd99f83948f56058e375600c0690d5">_writeXml</a>(FdoXmlWriter* xmlWriter, <span class="keyword">const</span> FdoXmlFlags* flags);
+<a name="l00048"></a>00048 <span class="comment">//DOM-IGNORE-END</span>
+<a name="l00050"></a>00050 <span class="keyword">protected</span>:
+<a name="l00051"></a>00051 <a class="code" href="_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html#9b6afd7f3f2f73a361844d7bff18436f">FDORDBMS_OV_API</a> <a class="code" href="class_fdo_rdbms_ov_table_2b3477c363a06d4c499e1a10691bea50.html#2b3477c363a06d4c499e1a10691bea50">FdoRdbmsOvTable</a>();
+<a name="l00052"></a>00052 <a class="code" href="_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html#9b6afd7f3f2f73a361844d7bff18436f">FDORDBMS_OV_API</a> <a class="code" href="class_fdo_rdbms_ov_table_2b3477c363a06d4c499e1a10691bea50.html#2b3477c363a06d4c499e1a10691bea50">FdoRdbmsOvTable</a>(FdoString* name);
+<a name="l00053"></a>00053 <a class="code" href="_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html#9b6afd7f3f2f73a361844d7bff18436f">FDORDBMS_OV_API</a> <span class="keyword">virtual</span> <a class="code" href="class_fdo_rdbms_ov_table_e678441f64a8c2efbaa724fefe79b302.html#e678441f64a8c2efbaa724fefe79b302">~FdoRdbmsOvTable</a>();
+<a name="l00056"></a>00056 <a class="code" href="_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html#9b6afd7f3f2f73a361844d7bff18436f">FDORDBMS_OV_API</a> <span class="keyword">virtual</span> <span class="keywordtype">void</span> <a class="code" href="class_fdo_rdbms_ov_table_0e03dc3742dacf897c7f00dd19064882.html#0e03dc3742dacf897c7f00dd19064882">InitFromXml</a>(FdoXmlSaxContext* pContext, FdoXmlAttributeCollection* attrs);
+<a name="l00058"></a>00058 <a class="code" href="_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html#9b6afd7f3f2f73a361844d7bff18436f">FDORDBMS_OV_API</a> <span class="keyword">virtual</span> FdoXmlSaxHandler* <a class="code" href="class_fdo_rdbms_ov_table_b002904d6ee0bd1c82ccb2da78277d60.html#b002904d6ee0bd1c82ccb2da78277d60">XmlStartElement</a>(
+<a name="l00059"></a>00059 FdoXmlSaxContext* context,
+<a name="l00060"></a>00060 FdoString* uri,
+<a name="l00061"></a>00061 FdoString* name,
+<a name="l00062"></a>00062 FdoString* qname,
+<a name="l00063"></a>00063 FdoXmlAttributeCollection* atts
+<a name="l00064"></a>00064 );
+<a name="l00066"></a>00066 <span class="comment">// Write provider-specific parts to XML.</span>
+<a name="l00067"></a>00067 <a class="code" href="_rdbms_ov_8h_9b6afd7f3f2f73a361844d7bff18436f.html#9b6afd7f3f2f73a361844d7bff18436f">FDORDBMS_OV_API</a> <span class="keyword">virtual</span> <span class="keywordtype">void</span> <a class="code" href="class_fdo_rdbms_ov_table_209299ef102d4b5ee2b92763be873289.html#209299ef102d4b5ee2b92763be873289">_writeXmlContents</a>(FdoXmlWriter* xmlWriter, <span class="keyword">const</span> FdoXmlFlags* flags);
+<a name="l00069"></a>00069 <span class="keyword">private</span>:
+<a name="l00070"></a>00070 FdoStringP mPKeyName;
+<a name="l00072"></a>00072 };
+<a name="l00073"></a>00073 <span class="comment"></span>
+<a name="l00074"></a>00074 <span class="comment">///<summary>FdoRdbmsOvTableP is a FdoPtr on FdoRdbmsOvTable, provided for convenience.</summary>
