svn commit: r97 - trunk/www/docs/SDF
gregboone at osgeo.org
Mon Dec 4 13:49:20 EST 2006
Author: gregboone
Date: 2006-12-04 18:49:20+0000
New Revision: 97
Added:
trunk/www/docs/SDF/_i_create_s_d_f_file_8h-source.html (contents, props changed)
trunk/www/docs/SDF/_i_create_s_d_f_file_8h.html (contents, props changed)
trunk/www/docs/SDF/_i_create_s_d_f_file_8h__incl.map (contents, props changed)
trunk/www/docs/SDF/_i_create_s_d_f_file_8h__incl.md5 (contents, props changed)
trunk/www/docs/SDF/_i_create_s_d_f_file_8h__incl.png (contents, props changed)
trunk/www/docs/SDF/_i_extended_select_8h-source.html (contents, props changed)
trunk/www/docs/SDF/_i_extended_select_8h.html (contents, props changed)
trunk/www/docs/SDF/_i_extended_select_8h__incl.map (contents, props changed)
trunk/www/docs/SDF/_i_extended_select_8h__incl.md5 (contents, props changed)
trunk/www/docs/SDF/_i_extended_select_8h__incl.png (contents, props changed)
trunk/www/docs/SDF/_i_scrollable_feature_reader_8h-source.html (contents, props changed)
trunk/www/docs/SDF/_i_scrollable_feature_reader_8h.html (contents, props changed)
trunk/www/docs/SDF/_i_scrollable_feature_reader_8h__dep__incl.map (contents, props changed)
trunk/www/docs/SDF/_i_scrollable_feature_reader_8h__dep__incl.md5 (contents, props changed)
trunk/www/docs/SDF/_i_scrollable_feature_reader_8h__dep__incl.png (contents, props changed)
trunk/www/docs/SDF/_i_scrollable_feature_reader_8h__incl.map (contents, props changed)
trunk/www/docs/SDF/_i_scrollable_feature_reader_8h__incl.md5 (contents, props changed)
trunk/www/docs/SDF/_i_scrollable_feature_reader_8h__incl.png (contents, props changed)
trunk/www/docs/SDF/_sdf_command_type_8h-source.html (contents, props changed)
trunk/www/docs/SDF/_sdf_command_type_8h.html (contents, props changed)
trunk/www/docs/SDF/_sdf_command_type_8h_4ac92492e0d58aeace1b0c0f96cefea3.html (contents, props changed)
trunk/www/docs/SDF/_sdf_command_type_8h_86597e57635d4329ec6b9d0a67f969d7.html (contents, props changed)
trunk/www/docs/SDF/_sdf_command_type_8h__incl.map (contents, props changed)
trunk/www/docs/SDF/_sdf_command_type_8h__incl.md5 (contents, props changed)
trunk/www/docs/SDF/_sdf_command_type_8h__incl.png (contents, props changed)
trunk/www/docs/SDF/_sdf_compare_handler_8h-source.html (contents, props changed)
trunk/www/docs/SDF/_sdf_compare_handler_8h.html (contents, props changed)
trunk/www/docs/SDF/_sdf_compare_handler_8h_9bfa9402971b67602a99fd99449c5d76.html (contents, props changed)
trunk/www/docs/SDF/_sdf_compare_handler_8h__dep__incl.map (contents, props changed)
trunk/www/docs/SDF/_sdf_compare_handler_8h__dep__incl.md5 (contents, props changed)
trunk/www/docs/SDF/_sdf_compare_handler_8h__dep__incl.png (contents, props changed)
trunk/www/docs/SDF/annotated.html (contents, props changed)
trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file-members.html (contents, props changed)
trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file.html (contents, props changed)
trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file_05550ca7007c3e389b7029c41baa1587.html (contents, props changed)
trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file_0b8020c31deb9acc05311fd11f260c7d.html (contents, props changed)
trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file_0bde059736005f052076c6735c8b2453.html (contents, props changed)
trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file_2937b06fdf37207301200042b40e8d71.html (contents, props changed)
trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file_4a2bb60374b5db4f9dca173de2845803.html (contents, props changed)
trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file_4d74d6f8e45e76d8c8606953ae4cb307.html (contents, props changed)
trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file_647ff5d7f47cf47422c32645074cce8d.html (contents, props changed)
trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file_86b4ac8510f46ad6629e42023f184cee.html (contents, props changed)
trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file_8b2fc8bbd39311d609c316fac75d765b.html (contents, props changed)
trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file_8bb4c31009cf0ab76fc094eadcf4ca91.html (contents, props changed)
trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file_b3e528dda87b952a83786b2d01343524.html (contents, props changed)
trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file_bda73a210df146335a62e933ebe19948.html (contents, props changed)
trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file_e92b777da3c498180dd72fe4629ee788.html (contents, props changed)
trunk/www/docs/SDF/class_sdf_compare_handler-members.html (contents, props changed)
trunk/www/docs/SDF/class_sdf_compare_handler.html (contents, props changed)
trunk/www/docs/SDF/class_sdf_compare_handler_25efcd708f7d73df47e3f592a4dc9df2.html (contents, props changed)
trunk/www/docs/SDF/class_sdf_compare_handler_3a1cda4006166f838c9c90dbbd16daf5.html (contents, props changed)
trunk/www/docs/SDF/class_sdf_compare_handler_3ade9dcf05112bb16590f695c022a474.html (contents, props changed)
trunk/www/docs/SDF/class_sdf_compare_handler_4b9fe2c6a37153efe808fbe7b9cfac39.html (contents, props changed)
trunk/www/docs/SDF/class_sdf_compare_handler_5da8124ec6d48c42207912cb1004168c.html (contents, props changed)
trunk/www/docs/SDF/class_sdf_compare_handler_c1e1a5c47894aa43ada963c4cb84b980.html (contents, props changed)
trunk/www/docs/SDF/class_sdf_compare_handler_d3a014c324bcbb6e2eccbf17ee9b43f3.html (contents, props changed)
trunk/www/docs/SDF/class_sdf_compare_handler_dd5c70a33541eb9eabc2d19021a768fd.html (contents, props changed)
trunk/www/docs/SDF/class_sdf_compare_handler_e99c60fe9321858c35f204003e06954c.html (contents, props changed)
trunk/www/docs/SDF/class_sdf_compare_handler_fb5771764ec97dd9888a0d243d01886b.html (contents, props changed)
trunk/www/docs/SDF/class_sdf_compare_handler_fba0af521a5201a71547bce66c36f583.html (contents, props changed)
trunk/www/docs/SDF/class_sdf_i_extended_select-members.html (contents, props changed)
trunk/www/docs/SDF/class_sdf_i_extended_select.html (contents, props changed)
trunk/www/docs/SDF/class_sdf_i_extended_select_56fb99cd7bef0a7528cf1dd408d32e16.html (contents, props changed)
trunk/www/docs/SDF/class_sdf_i_extended_select_69a9441cd4ada6b204a5b3ccfde49eab.html (contents, props changed)
trunk/www/docs/SDF/class_sdf_i_extended_select_7094d0597a2dec8f759b553af3c5aebd.html (contents, props changed)
trunk/www/docs/SDF/class_sdf_i_extended_select_8921a5db2a527690f4d5592daa014be8.html (contents, props changed)
trunk/www/docs/SDF/class_sdf_i_extended_select_a9e4db2cb4a126bfd03259073ef74719.html (contents, props changed)
trunk/www/docs/SDF/class_sdf_i_extended_select_d10d84246bb47e87adb334fd6d5e8836.html (contents, props changed)
trunk/www/docs/SDF/class_sdf_i_scrollable_feature_reader-members.html (contents, props changed)
trunk/www/docs/SDF/class_sdf_i_scrollable_feature_reader.html (contents, props changed)
trunk/www/docs/SDF/class_sdf_i_scrollable_feature_reader_0c8bd83991d3de13ea3914e50eea68cd.html (contents, props changed)
trunk/www/docs/SDF/class_sdf_i_scrollable_feature_reader_1f018e50f3f7fb295d1c0968bc66aad3.html (contents, props changed)
trunk/www/docs/SDF/class_sdf_i_scrollable_feature_reader_31612208adc6a6e34023b40ccbbe9ee9.html (contents, props changed)
trunk/www/docs/SDF/class_sdf_i_scrollable_feature_reader_3e1b34ea5d045715c41d232c261f9f37.html (contents, props changed)
trunk/www/docs/SDF/class_sdf_i_scrollable_feature_reader_5b3f6fe4b58576aef1f2b3e47bd32392.html (contents, props changed)
trunk/www/docs/SDF/class_sdf_i_scrollable_feature_reader_8de8b2476b8dc5051c7f17f734b4693c.html (contents, props changed)
trunk/www/docs/SDF/class_sdf_i_scrollable_feature_reader_d692f60e023be7168ac6cf22d781cacd.html (contents, props changed)
trunk/www/docs/SDF/classes.html (contents, props changed)
trunk/www/docs/SDF/custom.css (contents, props changed)
trunk/www/docs/SDF/define__pages_8h-source.html (contents, props changed)
trunk/www/docs/SDF/define__pages_8h.html (contents, props changed)
trunk/www/docs/SDF/doxygen.png (contents, props changed)
trunk/www/docs/SDF/files.html (contents, props changed)
trunk/www/docs/SDF/ftv2blank.png (contents, props changed)
trunk/www/docs/SDF/ftv2doc.png (contents, props changed)
trunk/www/docs/SDF/ftv2folderclosed.png (contents, props changed)
trunk/www/docs/SDF/ftv2folderopen.png (contents, props changed)
trunk/www/docs/SDF/ftv2lastnode.png (contents, props changed)
trunk/www/docs/SDF/ftv2link.png (contents, props changed)
trunk/www/docs/SDF/ftv2mlastnode.png (contents, props changed)
trunk/www/docs/SDF/ftv2mnode.png (contents, props changed)
trunk/www/docs/SDF/ftv2node.png (contents, props changed)
trunk/www/docs/SDF/ftv2plastnode.png (contents, props changed)
trunk/www/docs/SDF/ftv2pnode.png (contents, props changed)
trunk/www/docs/SDF/ftv2vertline.png (contents, props changed)
trunk/www/docs/SDF/functions.html (contents, props changed)
trunk/www/docs/SDF/functions_func.html (contents, props changed)
trunk/www/docs/SDF/globals.html (contents, props changed)
trunk/www/docs/SDF/globals_defs.html (contents, props changed)
trunk/www/docs/SDF/globals_enum.html (contents, props changed)
trunk/www/docs/SDF/globals_eval.html (contents, props changed)
trunk/www/docs/SDF/graph_legend.dot (contents, props changed)
trunk/www/docs/SDF/graph_legend.html (contents, props changed)
trunk/www/docs/SDF/graph_legend.png (contents, props changed)
trunk/www/docs/SDF/hierarchy.html (contents, props changed)
trunk/www/docs/SDF/index.hhc (contents, props changed)
trunk/www/docs/SDF/index.hhk (contents, props changed)
trunk/www/docs/SDF/index.hhp (contents, props changed)
trunk/www/docs/SDF/index.html (contents, props changed)
trunk/www/docs/SDF/inherit__graph__0.map (contents, props changed)
trunk/www/docs/SDF/inherit__graph__0.md5 (contents, props changed)
trunk/www/docs/SDF/inherit__graph__0.png (contents, props changed)
trunk/www/docs/SDF/inherit__graph__1.map (contents, props changed)
trunk/www/docs/SDF/inherit__graph__1.md5 (contents, props changed)
trunk/www/docs/SDF/inherit__graph__1.png (contents, props changed)
trunk/www/docs/SDF/inherit__graph__2.map (contents, props changed)
trunk/www/docs/SDF/inherit__graph__2.md5 (contents, props changed)
trunk/www/docs/SDF/inherit__graph__2.png (contents, props changed)
trunk/www/docs/SDF/inherit__graph__3.map (contents, props changed)
trunk/www/docs/SDF/inherit__graph__3.md5 (contents, props changed)
trunk/www/docs/SDF/inherit__graph__3.png (contents, props changed)
trunk/www/docs/SDF/inherits.html (contents, props changed)
trunk/www/docs/SDF/main.html (contents, props changed)
trunk/www/docs/SDF/tab_b.gif (contents, props changed)
trunk/www/docs/SDF/tab_l.gif (contents, props changed)
trunk/www/docs/SDF/tab_r.gif (contents, props changed)
trunk/www/docs/SDF/tabs.css (contents, props changed)
trunk/www/docs/SDF/tree.html (contents, props changed)
FDO111: Update FDO Web Documentation (3.2.0)
Added: trunk/www/docs/SDF/_i_create_s_d_f_file_8h-source.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/_i_create_s_d_f_file_8h-source.html?view=auto&rev=97
--- (empty file)
+++ trunk/www/docs/SDF/_i_create_s_d_f_file_8h-source.html 2006-12-04 18:49:20+0000
@@ -0,0 +1,222 @@
+<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN" "http://www.w3.org/TR/html4/loose.dtd">
+<html>
+ <head>
+ <meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
+ <title>OSGeo FDO Provider for SDF API Reference</title>
+ <link href="custom.css" rel="stylesheet" type="text/css">
+ <link href="tabs.css" rel="stylesheet" type="text/css">
+ </head>
+ <body bgcolor="#FFFFFF">
+ <table width="100%" border="0">
+ <tr>
+ <td><b>API Reference<b></td>
+ <td align="right"><b>OSGeo FDO Provider for SDF<b></td>
+ </tr>
+ </table>
+<!-- End of: header.html -->
+<!-- Generated by Doxygen 1.4.6-NO -->
+<div class="tabs">
+ <ul>
+ <li><a href="main.html"><span>Main Page</span></a></li>
+ <li><a href="classes.html"><span>Classes</span></a></li>
+ <li id="current"><a href="files.html"><span>Files</span></a></li>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ <li><a href="files.html"><span>File List</span></a></li>
+ <li><a href="globals.html"><span>File Members</span></a></li>
+ </ul></div>
+<h1>ICreateSDFFile.h</h1><a href="_i_create_s_d_f_file_8h.html">Go to the documentation of this file.</a><div class="fragment"><pre class="fragment"><a name="l00001"></a>00001 <span class="comment">// </span>
+<a name="l00002"></a>00002 <span class="comment">// Copyright (C) 2004-2006 Autodesk, Inc.</span>
+<a name="l00003"></a>00003 <span class="comment">// </span>
+<a name="l00004"></a>00004 <span class="comment">// This library is free software; you can redistribute it and/or</span>
+<a name="l00005"></a>00005 <span class="comment">// modify it under the terms of version 2.1 of the GNU Lesser</span>
+<a name="l00006"></a>00006 <span class="comment">// General Public License as published by the Free Software Foundation.</span>
+<a name="l00007"></a>00007 <span class="comment">// </span>
+<a name="l00008"></a>00008 <span class="comment">// This library is distributed in the hope that it will be useful,</span>
+<a name="l00009"></a>00009 <span class="comment">// but WITHOUT ANY WARRANTY; without even the implied warranty of</span>
+<a name="l00010"></a>00010 <span class="comment">// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU</span>
+<a name="l00011"></a>00011 <span class="comment">// Lesser General Public License for more details.</span>
+<a name="l00012"></a>00012 <span class="comment">// </span>
+<a name="l00013"></a>00013 <span class="comment">// You should have received a copy of the GNU Lesser General Public</span>
+<a name="l00014"></a>00014 <span class="comment">// License along with this library; if not, write to the Free Software</span>
+<a name="l00015"></a>00015 <span class="comment">// Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA</span>
+<a name="l00016"></a>00016 <span class="preprocessor">#ifndef ICREATESDFFILE_H</span>
+<a name="l00017"></a>00017 <span class="preprocessor"></span><span class="preprocessor">#define ICREATESDFFILE_H</span>
+<a name="l00018"></a>00018 <span class="preprocessor"></span>
+<a name="l00019"></a>00019 <span class="preprocessor">#include "FdoStd.h"</span>
+<a name="l00020"></a>00020 <span class="preprocessor">#include "Fdo/Commands/ICommand.h"</span>
+<a name="l00021"></a>00021
+<a name="l00022"></a>00022 <span class="comment"></span>
+<a name="l00023"></a>00023 <span class="comment">/// \brief</span>
+<a name="l00024"></a>00024 <span class="comment">/// This command creates a new SDF+ file with a specified location</span>
+<a name="l00025"></a>00025 <span class="comment">/// and file name and a given spatial coordinate system.</span>
+<a name="l00026"></a><a class="code" href="class_fdo_i_create_s_d_f_file.html">00026</a> <span class="comment"></span><span class="keyword">class </span><a class="code" href="class_fdo_i_create_s_d_f_file.html">FdoICreateSDFFile</a> : <span class="keyword">public</span> FdoICommand
+<a name="l00027"></a>00027 {
+<a name="l00028"></a>00028 <span class="keyword">public</span>:
+<a name="l00029"></a>00029 <span class="comment"></span>
+<a name="l00030"></a>00030 <span class="comment"> /// \brief</span>
+<a name="l00031"></a>00031 <span class="comment"> /// Sets the name of the SDF+ file being created.</span>
+<a name="l00032"></a>00032 <span class="comment"> /// The name must be a fully qualified absolute path.</span>
+<a name="l00033"></a>00033 <span class="comment"> /// </span>
+<a name="l00034"></a>00034 <span class="comment"> /// \param name </span>
+<a name="l00035"></a>00035 <span class="comment"> /// The fully qualified SDF+ file name.</span>
+<a name="l00036"></a>00036 <span class="comment"> /// </span>
+<a name="l00037"></a>00037 <span class="comment"> /// \return</span>
+<a name="l00038"></a>00038 <span class="comment"> /// Returns nothing.</span>
+<a name="l00039"></a>00039 <span class="comment"> /// </span>
+<a name="l00040"></a>00040 <span class="comment"></span> FDO_API <span class="keyword">virtual</span> <span class="keywordtype">void</span> <a class="code" href="class_fdo_i_create_s_d_f_file_e92b777da3c498180dd72fe4629ee788.html#e92b777da3c498180dd72fe4629ee788">SetFileName</a>(FdoString* name) = 0;
+<a name="l00041"></a>00041 <span class="comment"></span>
+<a name="l00042"></a>00042 <span class="comment"> /// \brief</span>
+<a name="l00043"></a>00043 <span class="comment"> /// Gets the name of the SDF+ file being created.</span>
+<a name="l00044"></a>00044 <span class="comment"> /// The name is a fully qualified absolute path.</span>
+<a name="l00045"></a>00045 <span class="comment"> /// </span>
+<a name="l00046"></a>00046 <span class="comment"> /// \return</span>
+<a name="l00047"></a>00047 <span class="comment"> /// Returns the name of the SDF+ file.</span>
+<a name="l00048"></a>00048 <span class="comment"> /// </span>
+<a name="l00049"></a>00049 <span class="comment"></span> FDO_API <span class="keyword">virtual</span> FdoString* <a class="code" href="class_fdo_i_create_s_d_f_file_0bde059736005f052076c6735c8b2453.html#0bde059736005f052076c6735c8b2453">GetFileName</a>() = 0;
+<a name="l00050"></a>00050 <span class="comment"></span>
+<a name="l00051"></a>00051 <span class="comment"> /// \brief</span>
+<a name="l00052"></a>00052 <span class="comment"> /// Sets the name of the spatial context as a string.</span>
+<a name="l00053"></a>00053 <span class="comment"> /// </span>
+<a name="l00054"></a>00054 <span class="comment"> /// \param name </span>
+<a name="l00055"></a>00055 <span class="comment"> /// Input the name of the spatial context.</span>
+<a name="l00056"></a>00056 <span class="comment"> /// </span>
+<a name="l00057"></a>00057 <span class="comment"> /// \return</span>
+<a name="l00058"></a>00058 <span class="comment"> /// Returns nothing.</span>
+<a name="l00059"></a>00059 <span class="comment"> /// </span>
+<a name="l00060"></a>00060 <span class="comment"></span> FDO_API <span class="keyword">virtual</span> <span class="keywordtype">void</span> <a class="code" href="class_fdo_i_create_s_d_f_file_bda73a210df146335a62e933ebe19948.html#bda73a210df146335a62e933ebe19948">SetSpatialContextName</a>(FdoString* name) = 0;
+<a name="l00061"></a>00061 <span class="comment"></span>
+<a name="l00062"></a>00062 <span class="comment"> /// \brief</span>
+<a name="l00063"></a>00063 <span class="comment"> /// Gets the name of the coordinate system of the spatial context.</span>
+<a name="l00064"></a>00064 <span class="comment"> /// If the result is a null or empty string, the coordinate system is</span>
+<a name="l00065"></a>00065 <span class="comment"> /// unknown to the spatial context.</span>
+<a name="l00066"></a>00066 <span class="comment"> /// </span>
+<a name="l00067"></a>00067 <span class="comment"> /// \return</span>
+<a name="l00068"></a>00068 <span class="comment"> /// Returns the coordinate system name of the spatial context.</span>
+<a name="l00069"></a>00069 <span class="comment"> /// </span>
+<a name="l00070"></a>00070 <span class="comment"></span> FDO_API <span class="keyword">virtual</span> FdoString* <a class="code" href="class_fdo_i_create_s_d_f_file_647ff5d7f47cf47422c32645074cce8d.html#647ff5d7f47cf47422c32645074cce8d">GetSpatialContextName</a>() = 0;
+<a name="l00071"></a>00071 <span class="comment"></span>
+<a name="l00072"></a>00072 <span class="comment"> /// \brief</span>
+<a name="l00073"></a>00073 <span class="comment"> /// Sets the description of the spatial context as a string.</span>
+<a name="l00074"></a>00074 <span class="comment"> /// </span>
+<a name="l00075"></a>00075 <span class="comment"> /// \param description </span>
+<a name="l00076"></a>00076 <span class="comment"> /// Input the description of the spatial context.</span>
+<a name="l00077"></a>00077 <span class="comment"> /// </span>
+<a name="l00078"></a>00078 <span class="comment"> /// \return</span>
+<a name="l00079"></a>00079 <span class="comment"> /// Returns nothing.</span>
+<a name="l00080"></a>00080 <span class="comment"> /// </span>
+<a name="l00081"></a>00081 <span class="comment"></span> FDO_API <span class="keyword">virtual</span> <span class="keywordtype">void</span> <a class="code" href="class_fdo_i_create_s_d_f_file_86b4ac8510f46ad6629e42023f184cee.html#86b4ac8510f46ad6629e42023f184cee">SetSpatialContextDescription</a>(FdoString* description) = 0;
+<a name="l00082"></a>00082 <span class="comment"></span>
+<a name="l00083"></a>00083 <span class="comment"> /// \brief</span>
+<a name="l00084"></a>00084 <span class="comment"> /// Gets the description of the spatial context.</span>
+<a name="l00085"></a>00085 <span class="comment"> /// </span>
+<a name="l00086"></a>00086 <span class="comment"> /// \return</span>
+<a name="l00087"></a>00087 <span class="comment"> /// Returns the description of the spatial context.</span>
+<a name="l00088"></a>00088 <span class="comment"> /// </span>
+<a name="l00089"></a>00089 <span class="comment"></span> FDO_API <span class="keyword">virtual</span> FdoString* <a class="code" href="class_fdo_i_create_s_d_f_file_4d74d6f8e45e76d8c8606953ae4cb307.html#4d74d6f8e45e76d8c8606953ae4cb307">GetSpatialContextDescription</a>() = 0;
+<a name="l00090"></a>00090 <span class="comment"></span>
+<a name="l00091"></a>00091 <span class="comment"> /// \brief</span>
+<a name="l00092"></a>00092 <span class="comment"> /// Sets the coordinate system of the context to create as a string in</span>
+<a name="l00093"></a>00093 <span class="comment"> /// OpenGIS SRS WKT format.</span>
+<a name="l00094"></a>00094 <span class="comment"> /// </span>
+<a name="l00095"></a>00095 <span class="comment"> /// \param wkt </span>
+<a name="l00096"></a>00096 <span class="comment"> /// Input the coordinate system.</span>
+<a name="l00097"></a>00097 <span class="comment"> /// </span>
+<a name="l00098"></a>00098 <span class="comment"> /// \return</span>
+<a name="l00099"></a>00099 <span class="comment"> /// Returns nothing.</span>
+<a name="l00100"></a>00100 <span class="comment"> /// </span>
+<a name="l00101"></a>00101 <span class="comment"></span> FDO_API <span class="keyword">virtual</span> <span class="keywordtype">void</span> <a class="code" href="class_fdo_i_create_s_d_f_file_8bb4c31009cf0ab76fc094eadcf4ca91.html#8bb4c31009cf0ab76fc094eadcf4ca91">SetCoordinateSystemWKT</a>(FdoString* wkt) = 0;
+<a name="l00102"></a>00102 <span class="comment"></span>
+<a name="l00103"></a>00103 <span class="comment"> /// \brief</span>
+<a name="l00104"></a>00104 <span class="comment"> /// Gets the name of the coordinate system in OpenGIS SRS WKT format of the spatial context.</span>
+<a name="l00105"></a>00105 <span class="comment"> /// If the result is an empty string, the coordinate system WKT description is</span>
+<a name="l00106"></a>00106 <span class="comment"> /// not available.</span>
+<a name="l00107"></a>00107 <span class="comment"> /// </span>
+<a name="l00108"></a>00108 <span class="comment"> /// \return</span>
+<a name="l00109"></a>00109 <span class="comment"> /// Returns the coordinate system description in WKT format of the spatial context.</span>
+<a name="l00110"></a>00110 <span class="comment"> /// </span>
+<a name="l00111"></a>00111 <span class="comment"></span> FDO_API <span class="keyword">virtual</span> FdoString* <a class="code" href="class_fdo_i_create_s_d_f_file_0b8020c31deb9acc05311fd11f260c7d.html#0b8020c31deb9acc05311fd11f260c7d">GetCoordinateSystemWKT</a>() = 0;
+<a name="l00112"></a>00112 <span class="comment"></span>
+<a name="l00113"></a>00113 <span class="comment"> /// \brief</span>
+<a name="l00114"></a>00114 <span class="comment"> /// Sets the tolerance value to use for X/Y ordinates. Tolerances are used</span>
+<a name="l00115"></a>00115 <span class="comment"> /// in some geometric tests, mostly for equality between coordinates. This</span>
+<a name="l00116"></a>00116 <span class="comment"> /// occurs frequently in spatial queries, especially with "on boundary" or "just</span>
+<a name="l00117"></a>00117 <span class="comment"> /// touching" conditions. It is also an objective amount that can be used</span>
+<a name="l00118"></a>00118 <span class="comment"> /// when formulating step distances for parametric curve interpolation.</span>
+<a name="l00119"></a>00119 <span class="comment"> /// </span>
+<a name="l00120"></a>00120 <span class="comment"> /// \param tolerance </span>
+<a name="l00121"></a>00121 <span class="comment"> /// Input the tolerance.</span>
+<a name="l00122"></a>00122 <span class="comment"> /// </span>
+<a name="l00123"></a>00123 <span class="comment"> /// \return</span>
+<a name="l00124"></a>00124 <span class="comment"> /// Returns nothing.</span>
+<a name="l00125"></a>00125 <span class="comment"> /// </span>
+<a name="l00126"></a>00126 <span class="comment"></span> FDO_API <span class="keyword">virtual</span> <span class="keywordtype">void</span> <a class="code" href="class_fdo_i_create_s_d_f_file_b3e528dda87b952a83786b2d01343524.html#b3e528dda87b952a83786b2d01343524">SetXYTolerance</a>(<span class="keywordtype">double</span> tolerance) = 0;
+<a name="l00127"></a>00127 <span class="comment"></span>
+<a name="l00128"></a>00128 <span class="comment"> /// \brief</span>
+<a name="l00129"></a>00129 <span class="comment"> /// Gets the tolerance value for X/Y ordinates of the spatial context.</span>
+<a name="l00130"></a>00130 <span class="comment"> /// Tolerances are used in some geometric tests,</span>
+<a name="l00131"></a>00131 <span class="comment"> /// mostly for equality between coordinates. This occurs frequently in spatial</span>
+<a name="l00132"></a>00132 <span class="comment"> /// queries, especially with "on boundary" or "just touching" conditions.</span>
+<a name="l00133"></a>00133 <span class="comment"> /// It is also an objective amount that can be used when formulating step</span>
+<a name="l00134"></a>00134 <span class="comment"> /// distances for parametric curve interpolation.</span>
+<a name="l00135"></a>00135 <span class="comment"> /// </span>
+<a name="l00136"></a>00136 <span class="comment"> /// \return</span>
+<a name="l00137"></a>00137 <span class="comment"> /// Returns the tolerance.</span>
+<a name="l00138"></a>00138 <span class="comment"> /// </span>
+<a name="l00139"></a>00139 <span class="comment"></span> FDO_API <span class="keyword">virtual</span> <span class="keywordtype">double</span> <a class="code" href="class_fdo_i_create_s_d_f_file_4a2bb60374b5db4f9dca173de2845803.html#4a2bb60374b5db4f9dca173de2845803">GetXYTolerance</a>() = 0;
+<a name="l00140"></a>00140 <span class="comment"></span>
+<a name="l00141"></a>00141 <span class="comment"> /// \brief</span>
+<a name="l00142"></a>00142 <span class="comment"> /// Sets the tolerance value to use for Z ordinates. Tolerances are used in</span>
+<a name="l00143"></a>00143 <span class="comment"> /// some geometric tests, mostly for equality between coordinates. This</span>
+<a name="l00144"></a>00144 <span class="comment"> /// occurs frequently in spatial queries, especially with "on boundary" or "just</span>
+<a name="l00145"></a>00145 <span class="comment"> /// touching" conditions. It is also an objective amount that can be used</span>
+<a name="l00146"></a>00146 <span class="comment"> /// when formulating step distances for parametric curve interpolation.</span>
+<a name="l00147"></a>00147 <span class="comment"> /// </span>
+<a name="l00148"></a>00148 <span class="comment"> /// \param tolerance </span>
+<a name="l00149"></a>00149 <span class="comment"> /// Input the tolerance.</span>
+<a name="l00150"></a>00150 <span class="comment"> /// </span>
+<a name="l00151"></a>00151 <span class="comment"> /// \return</span>
+<a name="l00152"></a>00152 <span class="comment"> /// Returns nothing.</span>
+<a name="l00153"></a>00153 <span class="comment"> /// </span>
+<a name="l00154"></a>00154 <span class="comment"></span> FDO_API <span class="keyword">virtual</span> <span class="keywordtype">void</span> <a class="code" href="class_fdo_i_create_s_d_f_file_2937b06fdf37207301200042b40e8d71.html#2937b06fdf37207301200042b40e8d71">SetZTolerance</a>(<span class="keywordtype">double</span> tolerance) = 0;
+<a name="l00155"></a>00155 <span class="comment"></span>
+<a name="l00156"></a>00156 <span class="comment"> /// \brief</span>
+<a name="l00157"></a>00157 <span class="comment"> /// Gets the tolerance value for Z ordinates of the spatial context.</span>
+<a name="l00158"></a>00158 <span class="comment"> /// Tolerances are used in some geometric tests,</span>
+<a name="l00159"></a>00159 <span class="comment"> /// mostly for equality between coordinates. This occurs a frequently in spatial</span>
+<a name="l00160"></a>00160 <span class="comment"> /// queries, especially with "on boundary" or "just touching" conditions.</span>
+<a name="l00161"></a>00161 <span class="comment"> /// It is also an objective amount that can be used when formulating step</span>
+<a name="l00162"></a>00162 <span class="comment"> /// distances for parametric curve interpolation.</span>
+<a name="l00163"></a>00163 <span class="comment"> /// </span>
+<a name="l00164"></a>00164 <span class="comment"> /// \return</span>
+<a name="l00165"></a>00165 <span class="comment"> /// Returns the tolerance.</span>
+<a name="l00166"></a>00166 <span class="comment"> /// </span>
+<a name="l00167"></a>00167 <span class="comment"></span> FDO_API <span class="keyword">virtual</span> <span class="keywordtype">double</span> <a class="code" href="class_fdo_i_create_s_d_f_file_8b2fc8bbd39311d609c316fac75d765b.html#8b2fc8bbd39311d609c316fac75d765b">GetZTolerance</a>() = 0;
+<a name="l00168"></a>00168 <span class="comment"></span>
+<a name="l00169"></a>00169 <span class="comment"> /// \brief</span>
+<a name="l00170"></a>00170 <span class="comment"> /// Executes the command. An exception is thrown if the file fails to be </span>
+<a name="l00171"></a>00171 <span class="comment"> /// created.</span>
+<a name="l00172"></a>00172 <span class="comment"> /// </span>
+<a name="l00173"></a>00173 <span class="comment"> /// \return</span>
+<a name="l00174"></a>00174 <span class="comment"> /// Returns nothing.</span>
+<a name="l00175"></a>00175 <span class="comment"> /// </span>
+<a name="l00176"></a>00176 <span class="comment"></span> FDO_API <span class="keyword">virtual</span> <span class="keywordtype">void</span> <a class="code" href="class_fdo_i_create_s_d_f_file_05550ca7007c3e389b7029c41baa1587.html#05550ca7007c3e389b7029c41baa1587">Execute</a>() = 0;
+<a name="l00177"></a>00177
+<a name="l00178"></a>00178 };
+<a name="l00179"></a>00179
+<a name="l00180"></a>00180
+<a name="l00181"></a>00181 <span class="preprocessor">#endif</span>
+<a name="l00182"></a>00182 <span class="preprocessor"></span>
+<a name="l00183"></a>00183
+</pre></div><!-- footer.html -->
+ <hr>
+ <tr>
+ <td align="right"><font size="-2"><a href="mailto:isd.docs at autodesk.com&subject=FDO%20Provider%20for%20SDF%20API%20documentation">Comments?</a></font></td>
+ <!-- The logo can go in another cell, when we get one -->
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SDF/_i_create_s_d_f_file_8h.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/_i_create_s_d_f_file_8h.html?view=auto&rev=97
--- (empty file)
+++ trunk/www/docs/SDF/_i_create_s_d_f_file_8h.html 2006-12-04 18:49:20+0000
@@ -0,0 +1,55 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<h1>ICreateSDFFile.h File Reference</h1>
+<p>
+<code>#include "FdoStd.h"</code><br>
+<code>#include "Fdo/Commands/ICommand.h"</code><br>
+<p>
+Include dependency graph for ICreateSDFFile.h:<p><center><img src="_i_create_s_d_f_file_8h__incl.png" border="0" usemap="#ICreateSDFFile.h_map" alt=""></center>
+<p>
+<a href="_i_create_s_d_f_file_8h-source.html">Go to the source code of this file.</a><table border="0" cellpadding="0" cellspacing="0">
+<tr><td></td></tr>
+<tr><td colspan="2"><br><h2>Classes</h2></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">class </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_i_create_s_d_f_file.html">FdoICreateSDFFile</a></td></tr>
+<tr><td class="mdescLeft"> </td><td class="mdescRight">This command creates a new SDF+ file with a specified location and file name and a given spatial coordinate system. <a href="class_fdo_i_create_s_d_f_file.html#_details">More...</a><br></td></tr>
+</table>
+<!-- footer.html -->
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SDF/_i_create_s_d_f_file_8h__incl.map
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/_i_create_s_d_f_file_8h__incl.map?view=auto&rev=97
--- (empty file)
+++ trunk/www/docs/SDF/_i_create_s_d_f_file_8h__incl.map 2006-12-04 18:49:20+0000
@@ -0,0 +1 @@
+base referer
Added: trunk/www/docs/SDF/_i_create_s_d_f_file_8h__incl.md5
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/_i_create_s_d_f_file_8h__incl.md5?view=auto&rev=97
--- (empty file)
+++ trunk/www/docs/SDF/_i_create_s_d_f_file_8h__incl.md5 2006-12-04 18:49:20+0000
@@ -0,0 +1 @@
+396f6285ab173e6a8c4be76a13e034da
\ No newline at end of file
Added: trunk/www/docs/SDF/_i_create_s_d_f_file_8h__incl.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/_i_create_s_d_f_file_8h__incl.png?view=auto&rev=97
Binary file. No diff available.
Added: trunk/www/docs/SDF/_i_extended_select_8h-source.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/_i_extended_select_8h-source.html?view=auto&rev=97
--- (empty file)
+++ trunk/www/docs/SDF/_i_extended_select_8h-source.html 2006-12-04 18:49:20+0000
@@ -0,0 +1,114 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<h1>IExtendedSelect.h</h1><a href="_i_extended_select_8h.html">Go to the documentation of this file.</a><div class="fragment"><pre class="fragment"><a name="l00001"></a>00001 <span class="comment">// </span>
+<a name="l00017"></a>00017 <span class="preprocessor">#ifndef _SdfIExtendedSelect_H_</span>
+<a name="l00018"></a>00018 <span class="preprocessor"></span><span class="preprocessor">#define _SdfIExtendedSelect_H_</span>
+<a name="l00019"></a>00019 <span class="preprocessor"></span>
+<a name="l00020"></a>00020 <span class="preprocessor">#include "FdoStd.h"</span>
+<a name="l00021"></a>00021 <span class="preprocessor">#include "Fdo.h"</span>
+<a name="l00022"></a>00022 <span class="preprocessor">#include "<a class="code" href="_i_scrollable_feature_reader_8h.html">SDF/IScrollableFeatureReader.h</a>"</span>
+<a name="l00023"></a>00023 <span class="preprocessor">#include "<a class="code" href="_sdf_compare_handler_8h.html">SDF/SdfCompareHandler.h</a>"</span>
+<a name="l00025"></a><a class="code" href="class_sdf_i_extended_select.html">00025</a> <span class="keyword">class </span><a class="code" href="class_sdf_i_extended_select.html">SdfIExtendedSelect</a> : <span class="keyword">public</span> FdoISelect
+<a name="l00026"></a>00026 {
+<a name="l00029"></a>00029 <span class="comment">// Expose the FdoISelect hidden functions</span>
+<a name="l00030"></a>00030 <span class="keyword">using</span> FdoISelect::GetOrderingOption;
+<a name="l00031"></a>00031 <span class="keyword">using</span> FdoISelect::SetOrderingOption;
+<a name="l00032"></a>00032 <span class="comment"></span>
+<a name="l00033"></a>00033 <span class="comment"> /// <summary>Set the ordering option of the selection. This is only used if the ordering collection is not empty.</summary></span>
+<a name="l00034"></a>00034 <span class="comment"> /// <param name="propertyName">Is the property name for which the ordering should be applied. This property should be in the ordering collection.</param> </span>
+<a name="l00035"></a>00035 <span class="comment"> /// <param name="option">Is the ordering option and should be set to one of FdoOrderingOption_Ascending or FdoOrderingOption_Descending.</span>
+<a name="l00036"></a>00036 <span class="comment"> /// FdoOrderingOption_Ascending is the default value.</param> </span>
+<a name="l00037"></a>00037 <span class="comment"> /// <returns>Returns nothing</returns> </span>
+<a name="l00038"></a>00038 <span class="comment"></span> <span class="keyword">virtual</span> <span class="keywordtype">void</span> <a class="code" href="class_sdf_i_extended_select_8921a5db2a527690f4d5592daa014be8.html#8921a5db2a527690f4d5592daa014be8">SetOrderingOption</a>( FdoString* propertyName, FdoOrderingOption option ) = 0;
+<a name="l00039"></a>00039 <span class="comment"></span>
+<a name="l00040"></a>00040 <span class="comment"> /// <summary>Gets the ordering option for a given property.</summary></span>
+<a name="l00041"></a>00041 <span class="comment"> /// <param name="propertyName">Is the property name for which the ordering should be applied. This property should be in the ordering collection.</param> </span>
+<a name="l00042"></a>00042 <span class="comment"> /// <returns>Returns the ordering option.</returns> </span>
+<a name="l00043"></a>00043 <span class="comment"></span> <span class="keyword">virtual</span> FdoOrderingOption <a class="code" href="class_sdf_i_extended_select_a9e4db2cb4a126bfd03259073ef74719.html#a9e4db2cb4a126bfd03259073ef74719">GetOrderingOption</a>( FdoString* propertyName ) = 0;
+<a name="l00044"></a>00044 <span class="comment"></span>
+<a name="l00045"></a>00045 <span class="comment"> /// <summary>This method clears the internal list of property/ordering option list and re-sets the ordering option for all </span>
+<a name="l00046"></a>00046 <span class="comment"> /// the ordering properties to the default FdoOrderingOption_Ascending or to the ordering option specified by the </span>
+<a name="l00047"></a>00047 <span class="comment"> /// FdoIBaseSelect interface.</summary></span>
+<a name="l00048"></a>00048 <span class="comment"> /// <returns>Returns nothing.</returns> </span>
+<a name="l00049"></a>00049 <span class="comment"></span> <span class="keyword">virtual</span> <span class="keywordtype">void</span> <a class="code" href="class_sdf_i_extended_select_56fb99cd7bef0a7528cf1dd408d32e16.html#56fb99cd7bef0a7528cf1dd408d32e16">ClearOrderingOptions</a>( ) = 0;
+<a name="l00051"></a>00051 <span class="comment"> /// <summary>Set the compare handler. This method is used to override the default sdf compare handler.</summary></span>
+<a name="l00052"></a>00052 <span class="comment"> /// <param name="handler">The compare handle that should be derived from the SdfCompareHandler class.</param> </span>
+<a name="l00053"></a>00053 <span class="comment"> /// <returns>Returns nothing</returns> </span>
+<a name="l00054"></a>00054 <span class="comment"></span> <span class="keyword">virtual</span> <span class="keywordtype">void</span> <a class="code" href="class_sdf_i_extended_select_69a9441cd4ada6b204a5b3ccfde49eab.html#69a9441cd4ada6b204a5b3ccfde49eab">SetCompareHandler</a>( <a class="code" href="class_sdf_compare_handler.html">SdfCompareHandler</a>* handler ) = 0;
+<a name="l00055"></a>00055 <span class="comment"></span>
+<a name="l00056"></a>00056 <span class="comment"> /// <summary> Executes the select command and returns a SdfIScrollableFeatureReader. </span>
+<a name="l00057"></a>00057 <span class="comment"> /// If ordering is enabled, then the returned reader is sorted according to </span>
+<a name="l00058"></a>00058 <span class="comment"> /// the ordering collection. This method perform sorting in memory and allocates an integer value for each row.</summary></span>
+<a name="l00059"></a>00059 <span class="comment"> /// <returns>Returns a SdfIScrollableFeatureReader object</returns> </span>
+<a name="l00060"></a>00060 <span class="comment"></span> <span class="keyword">virtual</span> <a class="code" href="class_sdf_i_scrollable_feature_reader.html">SdfIScrollableFeatureReader</a>* <a class="code" href="class_sdf_i_extended_select_7094d0597a2dec8f759b553af3c5aebd.html#7094d0597a2dec8f759b553af3c5aebd">ExecuteScrollable</a>() = 0;
+<a name="l00062"></a>00062 <span class="comment"> /// <summary> Executes the select command and returns a SdfIScrollableFeatureReader. This method creates a temporary SDF file </span>
+<a name="l00063"></a>00063 <span class="comment"> /// that contains the selected properties. If ordering is enabled, then the created temporary SDF file is sorted according to </span>
+<a name="l00064"></a>00064 <span class="comment"> /// the ordering collection. In this case the sorting is file based where the SQLite BTree is used. </span>
+<a name="l00065"></a>00065 <span class="comment"></span> <span class="comment">// The extendedProps and extendedDefaults can be used to extend the class definition of the selected data. </span><span class="comment"></span>
+<a name="l00066"></a>00066 <span class="comment"> /// Both collections have to be in-sync otherwise an exception will be thrown.</summary></span>
+<a name="l00067"></a>00067 <span class="comment"> /// <param name="sdfCacheFile">File path and name used to store the result of the query.</param> </span>
+<a name="l00068"></a>00068 <span class="comment"> /// <param name="extendedProps">A collection of data property definition that extends the class definition defined by the selected properties.</param> </span>
+<a name="l00069"></a>00069 <span class="comment"> /// <param name="extendedDefaults">A collection of property values used as defaults for extended properties defined by extendedProps parameter.</param> </span>
+<a name="l00070"></a>00070 <span class="comment"> /// <returns>Returns a SdfIScrollableFeatureReader object</returns> </span>
+<a name="l00071"></a>00071 <span class="comment"></span> <span class="keyword">virtual</span> <a class="code" href="class_sdf_i_scrollable_feature_reader.html">SdfIScrollableFeatureReader</a>* <a class="code" href="class_sdf_i_extended_select_7094d0597a2dec8f759b553af3c5aebd.html#7094d0597a2dec8f759b553af3c5aebd">ExecuteScrollable</a>( <span class="keyword">const</span> <span class="keywordtype">wchar_t</span>* sdfCacheFile, FdoDataPropertyDefinitionCollection* extendedProps, FdoPropertyValueCollection* extendedDefaults ) = 0;
+<a name="l00072"></a>00072 };
+<a name="l00074"></a>00074 <span class="preprocessor">#endif</span>
+<a name="l00075"></a>00075 <span class="preprocessor"></span>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SDF/_i_extended_select_8h.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/_i_extended_select_8h.html?view=auto&rev=97
--- (empty file)
+++ trunk/www/docs/SDF/_i_extended_select_8h.html 2006-12-04 18:49:20+0000
@@ -0,0 +1,60 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<h1>IExtendedSelect.h File Reference</h1>
+<p>
+<code>#include "Fdo.h"</code><br>
+<code>#include "<a class="el" href="_i_scrollable_feature_reader_8h-source.html">SDF/IScrollableFeatureReader.h</a>"</code><br>
+<code>#include "<a class="el" href="_sdf_compare_handler_8h-source.html">SDF/SdfCompareHandler.h</a>"</code><br>
+<p>
+Include dependency graph for IExtendedSelect.h:<p><center><img src="_i_extended_select_8h__incl.png" border="0" usemap="#IExtendedSelect.h_map" alt=""></center>
+<map name="IExtendedSelect.h_map">
+<area href="_i_scrollable_feature_reader_8h.html" shape="rect" coords="185,108,401,135" alt="">
+<area href="_sdf_compare_handler_8h.html" shape="rect" coords="201,159,385,185" alt="">
+</map>
+<p>
+<a href="_i_extended_select_8h-source.html">Go to the source code of this file.</a><table border="0" cellpadding="0" cellspacing="0">
+<tr><td></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">class </td><td class="memItemRight" valign="bottom"><a class="el" href="class_sdf_i_extended_select.html">SdfIExtendedSelect</a></td></tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SDF/_i_extended_select_8h__incl.map
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/_i_extended_select_8h__incl.map?view=auto&rev=97
--- (empty file)
+++ trunk/www/docs/SDF/_i_extended_select_8h__incl.map 2006-12-04 18:49:20+0000
@@ -0,0 +1,3 @@
+base referer
+rect $_i_scrollable_feature_reader_8h.html 185,108 401,135
+rect $_sdf_compare_handler_8h.html 201,159 385,185
Added: trunk/www/docs/SDF/_i_extended_select_8h__incl.md5
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/_i_extended_select_8h__incl.md5?view=auto&rev=97
--- (empty file)
+++ trunk/www/docs/SDF/_i_extended_select_8h__incl.md5 2006-12-04 18:49:20+0000
@@ -0,0 +1 @@
+e497b3cfbcd8e6b6c662c1468534efbd
Added: trunk/www/docs/SDF/_i_extended_select_8h__incl.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/_i_extended_select_8h__incl.png?view=auto&rev=97
Added: trunk/www/docs/SDF/_i_scrollable_feature_reader_8h-source.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/_i_scrollable_feature_reader_8h-source.html?view=auto&rev=97
--- (empty file)
+++ trunk/www/docs/SDF/_i_scrollable_feature_reader_8h-source.html 2006-12-04 18:49:20+0000
@@ -0,0 +1,106 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<h1>IScrollableFeatureReader.h</h1><a href="_i_scrollable_feature_reader_8h.html">Go to the documentation of this file.</a><div class="fragment"><pre class="fragment"><a name="l00001"></a>00001 <span class="comment">// </span>
+<a name="l00015"></a>00015 <span class="comment">// Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 US</span>
+<a name="l00017"></a>00017 <span class="preprocessor">#ifndef _SdfIScrollableFeatureReader_</span>
+<a name="l00018"></a>00018 <span class="preprocessor"></span><span class="preprocessor">#define _SdfIScrollableFeatureReader_</span>
+<a name="l00020"></a>00020 <span class="preprocessor">#include "Fdo.h"</span>
+<a name="l00022"></a><a class="code" href="class_sdf_i_scrollable_feature_reader.html">00022</a> <span class="keyword">class </span><a class="code" href="class_sdf_i_scrollable_feature_reader.html">SdfIScrollableFeatureReader</a> : <span class="keyword">public</span> FdoIFeatureReader
+<a name="l00023"></a>00023 {
+<a name="l00024"></a>00024 <span class="keyword">public</span>:
+<a name="l00025"></a>00025 <span class="comment"></span>
+<a name="l00026"></a>00026 <span class="comment"> /// <summary>Returns the number of records of the query result.</summary></span>
+<a name="l00027"></a>00027 <span class="comment"> /// <returns>Returns number of records.</returns> </span>
+<a name="l00028"></a>00028 <span class="comment"></span> <span class="keyword">virtual</span> <span class="keywordtype">int</span> <a class="code" href="class_sdf_i_scrollable_feature_reader_0c8bd83991d3de13ea3914e50eea68cd.html#0c8bd83991d3de13ea3914e50eea68cd">Count</a>() = 0;
+<a name="l00030"></a>00030 <span class="comment"> /// <summary>Position the reader at the first record of the query result. This method returns false if the query result is empty.</summary></span>
+<a name="l00031"></a>00031 <span class="comment"> /// <returns>Returns true if a record is found or false if the result is empty.</returns></span>
+<a name="l00032"></a>00032 <span class="comment"></span> <span class="keyword">virtual</span> <span class="keywordtype">bool</span> <a class="code" href="class_sdf_i_scrollable_feature_reader_5b3f6fe4b58576aef1f2b3e47bd32392.html#5b3f6fe4b58576aef1f2b3e47bd32392">ReadFirst</a>() = 0;
+<a name="l00033"></a>00033 <span class="comment"></span>
+<a name="l00034"></a>00034 <span class="comment"> /// <summary>Position the reader at the last record of the query result. This method returns false if the query result is empty.</summary></span>
+<a name="l00035"></a>00035 <span class="comment"> /// <returns>Returns true if a record is found or false if the result is empty.</returns></span>
+<a name="l00036"></a>00036 <span class="comment"></span> <span class="keyword">virtual</span> <span class="keywordtype">bool</span> <a class="code" href="class_sdf_i_scrollable_feature_reader_31612208adc6a6e34023b40ccbbe9ee9.html#31612208adc6a6e34023b40ccbbe9ee9">ReadLast</a>() = 0;
+<a name="l00037"></a>00037 <span class="comment"></span>
+<a name="l00038"></a>00038 <span class="comment"> /// <summary>Advances the reader to the previous item and returns true if there is</span>
+<a name="l00039"></a>00039 <span class="comment"> /// another object to read or false if reading is complete. The default</span>
+<a name="l00040"></a>00040 <span class="comment"> /// position of the reader is prior to the first item. Therefore you</span>
+<a name="l00041"></a>00041 <span class="comment"> /// must call ReadFirst or ReadLast to begin accessing any data.</summary></span>
+<a name="l00042"></a>00042 <span class="comment"> /// <returns>Returns true if a record is found or false otherwise.</returns></span>
+<a name="l00043"></a>00043 <span class="comment"></span> <span class="keyword">virtual</span> <span class="keywordtype">bool</span> <a class="code" href="class_sdf_i_scrollable_feature_reader_8de8b2476b8dc5051c7f17f734b4693c.html#8de8b2476b8dc5051c7f17f734b4693c">ReadPrevious</a>() = 0;
+<a name="l00045"></a>00045 <span class="comment"> /// <summary>provide the ad-hoc access to the query result. It positions the position of the reader at a given record </span>
+<a name="l00046"></a>00046 <span class="comment"> /// defined by the key. If the record is not found, then the reader position is unset and false value is returned. </span>
+<a name="l00047"></a>00047 <span class="comment"> /// Once the readers position becames unset, the caller needs to call ReadFirst, ReadLast or ReadAt to re-position </span>
+<a name="l00048"></a>00048 <span class="comment"> /// the reader at a valid location.</returns></span>
+<a name="l00049"></a>00049 <span class="comment"> /// <param name="key">The key that identifies a record.</param> </span>
+<a name="l00050"></a>00050 <span class="comment"> /// <returns>Returns true if a record is found or false otherwise.</returns></span>
+<a name="l00051"></a>00051 <span class="comment"></span> <span class="keyword">virtual</span> <span class="keywordtype">bool</span> <a class="code" href="class_sdf_i_scrollable_feature_reader_3e1b34ea5d045715c41d232c261f9f37.html#3e1b34ea5d045715c41d232c261f9f37">ReadAt</a>(FdoPropertyValueCollection* key) = 0;
+<a name="l00052"></a>00052 <span class="comment"></span>
+<a name="l00053"></a>00053 <span class="comment"> /// <summary>Provides an ad-hoc access to the query result. The recordindex is the one-based nth item in the query result. </span>
+<a name="l00054"></a>00054 <span class="comment"> /// If successful, this method will position the reader at the feature identified by the recordindex.</summary></span>
+<a name="l00055"></a>00055 <span class="comment"> /// <param name="recordindex">The index of the row.</param> </span>
+<a name="l00056"></a>00056 <span class="comment"> /// <returns>Returns true if a record is found or false otherwise.</returns></span>
+<a name="l00057"></a>00057 <span class="comment"></span> <span class="keyword">virtual</span> <span class="keywordtype">bool</span> <a class="code" href="class_sdf_i_scrollable_feature_reader_1f018e50f3f7fb295d1c0968bc66aad3.html#1f018e50f3f7fb295d1c0968bc66aad3">ReadAtIndex</a>( <span class="keywordtype">unsigned</span> <span class="keywordtype">int</span> recordindex ) = 0;
+<a name="l00058"></a>00058 <span class="comment"></span>
+<a name="l00059"></a>00059 <span class="comment"> /// <summary>Given a key of a feature, IndexOf will return the one based index or the record number of the feature within </span>
+<a name="l00060"></a>00060 <span class="comment"> /// the returned query result. If the record is not found, then zero is retuned. This is the mirror function of the GetAtIndex function. This method does not affect the reader position. </span>
+<a name="l00061"></a>00061 <span class="comment"> /// GetAtIndex need to be called to move the reader to the returned index.</summary></span>
+<a name="l00062"></a>00062 <span class="comment"> /// <param name="key">The key that identifies a record.</param> </span>
+<a name="l00063"></a>00063 <span class="comment"> /// <returns>Returns true if a record is found or false otherwise.</returns></span>
+<a name="l00064"></a>00064 <span class="comment"></span> <span class="keyword">virtual</span> <span class="keywordtype">unsigned</span> <span class="keywordtype">int</span> <a class="code" href="class_sdf_i_scrollable_feature_reader_d692f60e023be7168ac6cf22d781cacd.html#d692f60e023be7168ac6cf22d781cacd">IndexOf</a>(FdoPropertyValueCollection* key) = 0;
+<a name="l00065"></a>00065 };
+<a name="l00067"></a>00067 <span class="preprocessor">#endif</span>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SDF/_i_scrollable_feature_reader_8h.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/_i_scrollable_feature_reader_8h.html?view=auto&rev=97
--- (empty file)
+++ trunk/www/docs/SDF/_i_scrollable_feature_reader_8h.html 2006-12-04 18:49:20+0000
@@ -0,0 +1,59 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<h1>IScrollableFeatureReader.h File Reference</h1>
+<p>
+<p>
+Include dependency graph for IScrollableFeatureReader.h:<p><center><img src="_i_scrollable_feature_reader_8h__incl.png" border="0" usemap="#IScrollableFeatureReader.h_map" alt=""></center>
+<p>
+This graph shows which files directly or indirectly include this file:<p><center><img src="_i_scrollable_feature_reader_8h__dep__incl.png" border="0" usemap="#IScrollableFeatureReader.hdep_map" alt=""></center>
+<map name="IScrollableFeatureReader.hdep_map">
+<area href="_i_extended_select_8h.html" shape="rect" coords="242,7,372,33" alt="">
+</map>
+<p>
+<a href="_i_scrollable_feature_reader_8h-source.html">Go to the source code of this file.</a><table border="0" cellpadding="0" cellspacing="0">
+<tr><td></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">class </td><td class="memItemRight" valign="bottom"><a class="el" href="class_sdf_i_scrollable_feature_reader.html">SdfIScrollableFeatureReader</a></td></tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SDF/_i_scrollable_feature_reader_8h__dep__incl.map
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/_i_scrollable_feature_reader_8h__dep__incl.map?view=auto&rev=97
--- (empty file)
+++ trunk/www/docs/SDF/_i_scrollable_feature_reader_8h__dep__incl.map 2006-12-04 18:49:20+0000
@@ -0,0 +1,2 @@
+base referer
+rect $_i_extended_select_8h.html 242,7 372,33
Added: trunk/www/docs/SDF/_i_scrollable_feature_reader_8h__dep__incl.md5
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/_i_scrollable_feature_reader_8h__dep__incl.md5?view=auto&rev=97
--- (empty file)
+++ trunk/www/docs/SDF/_i_scrollable_feature_reader_8h__dep__incl.md5 2006-12-04 18:49:20+0000
@@ -0,0 +1 @@
+09d081cefef47d35b9772a8b7e1a2c57
Added: trunk/www/docs/SDF/_i_scrollable_feature_reader_8h__dep__incl.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/_i_scrollable_feature_reader_8h__dep__incl.png?view=auto&rev=97
Added: trunk/www/docs/SDF/_i_scrollable_feature_reader_8h__incl.map
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/_i_scrollable_feature_reader_8h__incl.map?view=auto&rev=97
--- (empty file)
+++ trunk/www/docs/SDF/_i_scrollable_feature_reader_8h__incl.map 2006-12-04 18:49:20+0000
@@ -0,0 +1 @@
+base referer
Added: trunk/www/docs/SDF/_i_scrollable_feature_reader_8h__incl.md5
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/_i_scrollable_feature_reader_8h__incl.md5?view=auto&rev=97
--- (empty file)
+++ trunk/www/docs/SDF/_i_scrollable_feature_reader_8h__incl.md5 2006-12-04 18:49:20+0000
@@ -0,0 +1 @@
+13adf1a9d41e67b2987a1af622a5ee47
Added: trunk/www/docs/SDF/_i_scrollable_feature_reader_8h__incl.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/_i_scrollable_feature_reader_8h__incl.png?view=auto&rev=97
Added: trunk/www/docs/SDF/_sdf_command_type_8h-source.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/_sdf_command_type_8h-source.html?view=auto&rev=97
--- (empty file)
+++ trunk/www/docs/SDF/_sdf_command_type_8h-source.html 2006-12-04 18:49:20+0000
@@ -0,0 +1,85 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<h1>SdfCommandType.h</h1><a href="_sdf_command_type_8h.html">Go to the documentation of this file.</a><div class="fragment"><pre class="fragment"><a name="l00001"></a>00001 <span class="comment">// </span>
+<a name="l00016"></a>00016 <span class="preprocessor">#ifndef SDFCOMMANDTYPE_H</span>
+<a name="l00017"></a>00017 <span class="preprocessor"></span><span class="preprocessor">#define SDFCOMMANDTYPE_H</span>
+<a name="l00019"></a>00019 <span class="preprocessor">#include "Fdo/Commands/CommandType.h"</span>
+<a name="l00021"></a>00021 <span class="comment">// This number is defined so our custom command would not clash with other</span>
+<a name="l00022"></a>00022 <span class="comment">// custom provider commands.</span>
+<a name="l00023"></a><a class="code" href="_sdf_command_type_8h_86597e57635d4329ec6b9d0a67f969d7.html#86597e57635d4329ec6b9d0a67f969d7">00023</a> <span class="preprocessor">#define SDF_FIRST_PROVIDER_COMMAND 911</span>
+<a name="l00024"></a>00024 <span class="preprocessor"></span>
+<a name="l00026"></a>00026 <span class="comment">/// \brief</span>
+<a name="l00027"></a>00027 <span class="comment">/// The SdfCommandType enumeration defines the list of SDF+ commands.</span>
+<a name="l00028"></a>00028 <span class="comment">/// <param name="SdfCommandType_CreateSDFFile"></span>
+<a name="l00029"></a>00029 <span class="comment">/// Represents the CreateSDFFile command.</span>
+<a name="l00030"></a>00030 <span class="comment">/// </param></span>
+<a name="l00031"></a>00031 <span class="comment"></span>
+<a name="l00032"></a><a class="code" href="_sdf_command_type_8h_4ac92492e0d58aeace1b0c0f96cefea3.html#4ac92492e0d58aeace1b0c0f96cefea3">00032</a> <span class="keyword">enum</span> <a class="code" href="_sdf_command_type_8h_4ac92492e0d58aeace1b0c0f96cefea3.html#4ac92492e0d58aeace1b0c0f96cefea3">SdfCommandType</a>{
+<a name="l00034"></a>00034 <span class="comment"> /// Represents the CreateSDFFile command.</span>
+<a name="l00035"></a>00035 <span class="comment"></span> <a class="code" href="_sdf_command_type_8h_4ac92492e0d58aeace1b0c0f96cefea3.html#4ac92492e0d58aeace1b0c0f96cefea348c2e525ef9f5e6ae1db0962a09cff37">SdfCommandType_CreateSDFFile</a> = FdoCommandType_FirstProviderCommand + <a class="code" href="_sdf_command_type_8h_86597e57635d4329ec6b9d0a67f969d7.html#86597e57635d4329ec6b9d0a67f969d7">SDF_FIRST_PROVIDER_COMMAND</a>,
+<a name="l00036"></a>00036 <a class="code" href="_sdf_command_type_8h_4ac92492e0d58aeace1b0c0f96cefea3.html#4ac92492e0d58aeace1b0c0f96cefea3cff985287cc5191960dc4a2258697243">SdfCommandType_ExtendedSelect</a>
+<a name="l00037"></a>00037 };
+<a name="l00044"></a>00044 <span class="preprocessor">#endif</span>
+<a name="l00045"></a>00045 <span class="preprocessor"></span>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SDF/_sdf_command_type_8h.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/_sdf_command_type_8h.html?view=auto&rev=97
--- (empty file)
+++ trunk/www/docs/SDF/_sdf_command_type_8h.html 2006-12-04 18:49:20+0000
@@ -0,0 +1,64 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<h1>SdfCommandType.h File Reference</h1>
+<p>
+<code>#include "Fdo/Commands/CommandType.h"</code><br>
+<p>
+Include dependency graph for SdfCommandType.h:<p><center><img src="_sdf_command_type_8h__incl.png" border="0" usemap="#SdfCommandType.h_map" alt=""></center>
+<p>
+<a href="_sdf_command_type_8h-source.html">Go to the source code of this file.</a><table border="0" cellpadding="0" cellspacing="0">
+<tr><td></td></tr>
+<tr><td colspan="2"><br><h2>Defines</h2></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">#define </td><td class="memItemRight" valign="bottom"><a class="el" href="_sdf_command_type_8h_86597e57635d4329ec6b9d0a67f969d7.html#86597e57635d4329ec6b9d0a67f969d7">SDF_FIRST_PROVIDER_COMMAND</a> 911</td></tr>
+<tr><td colspan="2"><br><h2>Enumerations</h2></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">enum </td><td class="memItemRight" valign="bottom"><a class="el" href="_sdf_command_type_8h_4ac92492e0d58aeace1b0c0f96cefea3.html#4ac92492e0d58aeace1b0c0f96cefea3">SdfCommandType</a> { <a class="el" href="_sdf_command_type_8h_4ac92492e0d58aeace1b0c0f96cefea3.html#4ac92492e0d58aeace1b0c0f96cefea348c2e525ef9f5e6ae1db0962a09cff37">SdfCommandType_CreateSDFFile</a> = FdoCommandType_FirstProviderCommand + 911,
+<a class="el" href="_sdf_command_type_8h_4ac92492e0d58aeace1b0c0f96cefea3.html#4ac92492e0d58aeace1b0c0f96cefea3cff985287cc5191960dc4a2258697243">SdfCommandType_ExtendedSelect</a>
+ }</td></tr>
+<tr><td class="mdescLeft"> </td><td class="mdescRight">The SdfCommandType enumeration defines the list of SDF+ commands. <dl compact><dt><b>Parameters:</b></dt><dd>
+ <table border="0" cellspacing="2" cellpadding="0">
+ <tr><td valign="top"></td><td valign="top"><em>SdfCommandType_CreateSDFFile</em> </td><td>Represents the CreateSDFFile command. </td></tr>
+ </table>
+</dl>
+. <a href="_sdf_command_type_8h_4ac92492e0d58aeace1b0c0f96cefea3.html#4ac92492e0d58aeace1b0c0f96cefea3">More...</a><br></td></tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SDF/_sdf_command_type_8h_4ac92492e0d58aeace1b0c0f96cefea3.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/_sdf_command_type_8h_4ac92492e0d58aeace1b0c0f96cefea3.html?view=auto&rev=97
--- (empty file)
+++ trunk/www/docs/SDF/_sdf_command_type_8h_4ac92492e0d58aeace1b0c0f96cefea3.html 2006-12-04 18:49:20+0000
@@ -0,0 +1,92 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ <li><a href="files.html"><span>Files</span></a></li>
+ </ul></div>
+<div class="nav">
+<a class="el" href="_sdf_command_type_8h.html">SdfCommandType.h</a></div>
+<table cellspacing="0" cellpadding="0" border="0">
+ <tr>
+ <td valign="top">
+ <div class="navtab">
+ <table>
+ <tr><td class="navtab"><a class="qindex" href="_sdf_command_type_8h_86597e57635d4329ec6b9d0a67f969d7.html#86597e57635d4329ec6b9d0a67f969d7">SDF_FIRST_PROVIDER_COMMAND</a></td></tr>
+ <tr><td class="navtab"><a class="qindexHL" href="_sdf_command_type_8h_4ac92492e0d58aeace1b0c0f96cefea3.html#4ac92492e0d58aeace1b0c0f96cefea3">SdfCommandType</a></td></tr>
+ <tr><td class="navtab"><a class="qindex" href="_sdf_command_type_8h_4ac92492e0d58aeace1b0c0f96cefea3.html#4ac92492e0d58aeace1b0c0f96cefea348c2e525ef9f5e6ae1db0962a09cff37">SdfCommandType_CreateSDFFile</a></td></tr>
+ <tr><td class="navtab"><a class="qindex" href="_sdf_command_type_8h_4ac92492e0d58aeace1b0c0f96cefea3.html#4ac92492e0d58aeace1b0c0f96cefea3cff985287cc5191960dc4a2258697243">SdfCommandType_ExtendedSelect</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="4ac92492e0d58aeace1b0c0f96cefea3"></a><!-- doxytag: member="SdfCommandType.h::SdfCommandType" ref="4ac92492e0d58aeace1b0c0f96cefea3" args="" --><p>
+<table class="mdTable" cellpadding="2" cellspacing="0">
+ <tr>
+ <td class="mdRow">
+ <table cellpadding="0" cellspacing="0" border="0">
+ <tr>
+ <td class="md" nowrap valign="top">enum <a class="el" href="_sdf_command_type_8h_4ac92492e0d58aeace1b0c0f96cefea3.html#4ac92492e0d58aeace1b0c0f96cefea3">SdfCommandType</a> </td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+<table cellspacing="5" cellpadding="0" border="0">
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+The SdfCommandType enumeration defines the list of SDF+ commands. <dl compact><dt><b>Parameters:</b></dt><dd>
+ </table>
+</dl>
+<p>
+<dl compact><dt><b>Enumerator: </b></dt><dd>
+<table border="0" cellspacing="2" cellpadding="0">
+<tr><td valign="top"><em><a class="anchor" name="4ac92492e0d58aeace1b0c0f96cefea348c2e525ef9f5e6ae1db0962a09cff37"></a><!-- doxytag: member="SdfCommandType_CreateSDFFile" ref="4ac92492e0d58aeace1b0c0f96cefea348c2e525ef9f5e6ae1db0962a09cff37" args="" -->SdfCommandType_CreateSDFFile</em> </td><td>
+Represents the CreateSDFFile command. </td></tr>
+<tr><td valign="top"><em><a class="anchor" name="4ac92492e0d58aeace1b0c0f96cefea3cff985287cc5191960dc4a2258697243"></a><!-- doxytag: member="SdfCommandType_ExtendedSelect" ref="4ac92492e0d58aeace1b0c0f96cefea3cff985287cc5191960dc4a2258697243" args="" -->SdfCommandType_ExtendedSelect</em> </td><td>
+</td></tr>
+</table>
+</dl>
+<p>
+Definition at line <a class="el" href="_sdf_command_type_8h-source.html#l00032">32</a> of file <a class="el" href="_sdf_command_type_8h-source.html">SdfCommandType.h</a>. </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SDF/_sdf_command_type_8h_86597e57635d4329ec6b9d0a67f969d7.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/_sdf_command_type_8h_86597e57635d4329ec6b9d0a67f969d7.html?view=auto&rev=97
--- (empty file)
+++ trunk/www/docs/SDF/_sdf_command_type_8h_86597e57635d4329ec6b9d0a67f969d7.html 2006-12-04 18:49:20+0000
@@ -0,0 +1,77 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="nav">
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="_sdf_command_type_8h_86597e57635d4329ec6b9d0a67f969d7.html#86597e57635d4329ec6b9d0a67f969d7">SDF_FIRST_PROVIDER_COMMAND</a></td></tr>
+ <tr><td class="navtab"><a class="qindex" href="_sdf_command_type_8h_4ac92492e0d58aeace1b0c0f96cefea3.html#4ac92492e0d58aeace1b0c0f96cefea3">SdfCommandType</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="86597e57635d4329ec6b9d0a67f969d7"></a><!-- doxytag: member="SdfCommandType.h::SDF_FIRST_PROVIDER_COMMAND" ref="86597e57635d4329ec6b9d0a67f969d7" args="" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">#define SDF_FIRST_PROVIDER_COMMAND 911 </td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+<p>
+Definition at line <a class="el" href="_sdf_command_type_8h-source.html#l00023">23</a> of file <a class="el" href="_sdf_command_type_8h-source.html">SdfCommandType.h</a>. </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SDF/_sdf_command_type_8h__incl.map
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/_sdf_command_type_8h__incl.map?view=auto&rev=97
--- (empty file)
+++ trunk/www/docs/SDF/_sdf_command_type_8h__incl.map 2006-12-04 18:49:20+0000
@@ -0,0 +1 @@
+base referer
Added: trunk/www/docs/SDF/_sdf_command_type_8h__incl.md5
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/_sdf_command_type_8h__incl.md5?view=auto&rev=97
--- (empty file)
+++ trunk/www/docs/SDF/_sdf_command_type_8h__incl.md5 2006-12-04 18:49:20+0000
@@ -0,0 +1 @@
+1970835c8d4cce69bb72e33ad3239dbf
Added: trunk/www/docs/SDF/_sdf_command_type_8h__incl.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/_sdf_command_type_8h__incl.png?view=auto&rev=97
Added: trunk/www/docs/SDF/_sdf_compare_handler_8h-source.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/_sdf_compare_handler_8h-source.html?view=auto&rev=97
--- (empty file)
+++ trunk/www/docs/SDF/_sdf_compare_handler_8h-source.html 2006-12-04 18:49:20+0000
@@ -0,0 +1,145 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<h1>SdfCompareHandler.h</h1><a href="_sdf_compare_handler_8h.html">Go to the documentation of this file.</a><div class="fragment"><pre class="fragment"><a name="l00001"></a>00001 <span class="comment">// </span>
+<a name="l00016"></a>00016 <span class="preprocessor">#ifndef SDFCOMPAREHANDLER_H</span>
+<a name="l00017"></a>00017 <span class="preprocessor"></span><span class="preprocessor">#define SDFCOMPAREHANDLER_H</span>
+<a name="l00019"></a>00019 <span class="preprocessor">#ifdef _WIN32</span>
+<a name="l00020"></a>00020 <span class="preprocessor"></span><span class="preprocessor"> #ifdef SDF_EXPORTS</span>
+<a name="l00021"></a>00021 <span class="preprocessor"></span><span class="preprocessor"> #define SDF_API __declspec(dllexport)</span>
+<a name="l00022"></a>00022 <span class="preprocessor"></span><span class="preprocessor"> #else</span>
+<a name="l00023"></a>00023 <span class="preprocessor"></span><span class="preprocessor"> #define SDF_API __declspec(dllimport)</span>
+<a name="l00024"></a>00024 <span class="preprocessor"></span><span class="preprocessor"> #endif</span>
+<a name="l00025"></a>00025 <span class="preprocessor"></span><span class="preprocessor">#else </span>
+<a name="l00026"></a><a class="code" href="_sdf_compare_handler_8h_9bfa9402971b67602a99fd99449c5d76.html#9bfa9402971b67602a99fd99449c5d76">00026</a> <span class="preprocessor"></span><span class="preprocessor">#define SDF_API</span>
+<a name="l00027"></a>00027 <span class="preprocessor"></span><span class="preprocessor">#endif</span>
+<a name="l00028"></a>00028 <span class="preprocessor"></span>
+<a name="l00029"></a><a class="code" href="class_sdf_compare_handler.html">00029</a> <span class="keyword">class </span><a class="code" href="class_sdf_compare_handler.html">SdfCompareHandler</a>: <span class="keyword">public</span> FdoIDisposable
+<a name="l00030"></a>00030 {
+<a name="l00031"></a>00031 <span class="keyword">private</span>:
+<a name="l00032"></a>00032 <a class="code" href="_sdf_compare_handler_8h_9bfa9402971b67602a99fd99449c5d76.html#9bfa9402971b67602a99fd99449c5d76">SDF_API</a> <a class="code" href="class_sdf_compare_handler.html">SdfCompareHandler</a>();
+<a name="l00034"></a>00034 <span class="keyword">protected</span>:
+<a name="l00035"></a>00035 <a class="code" href="_sdf_compare_handler_8h_9bfa9402971b67602a99fd99449c5d76.html#9bfa9402971b67602a99fd99449c5d76">SDF_API</a> <span class="keyword">virtual</span> <a class="code" href="class_sdf_compare_handler_c1e1a5c47894aa43ada963c4cb84b980.html#c1e1a5c47894aa43ada963c4cb84b980">~SdfCompareHandler</a>();
+<a name="l00037"></a>00037 <span class="comment">// dispose this object</span>
+<a name="l00038"></a><a class="code" href="class_sdf_compare_handler_d3a014c324bcbb6e2eccbf17ee9b43f3.html#d3a014c324bcbb6e2eccbf17ee9b43f3">00038</a> <a class="code" href="_sdf_compare_handler_8h_9bfa9402971b67602a99fd99449c5d76.html#9bfa9402971b67602a99fd99449c5d76">SDF_API</a> <span class="keyword">virtual</span> <span class="keywordtype">void</span> <a class="code" href="class_sdf_compare_handler_d3a014c324bcbb6e2eccbf17ee9b43f3.html#d3a014c324bcbb6e2eccbf17ee9b43f3">Dispose</a>() { <span class="keyword">delete</span> <span class="keyword">this</span>; }
+<a name="l00040"></a>00040 <span class="keyword">public</span>:<span class="comment"></span>
+<a name="l00041"></a>00041 <span class="comment"> /// <summary>The factory function that can be used to create new instance of this class.</summary></span>
+<a name="l00042"></a>00042 <span class="comment"> /// <returns>Returns a new instance of theSdfCompareHandler class.</returns> </span>
+<a name="l00043"></a>00043 <span class="comment"></span> <a class="code" href="_sdf_compare_handler_8h_9bfa9402971b67602a99fd99449c5d76.html#9bfa9402971b67602a99fd99449c5d76">SDF_API</a> <span class="keyword">static</span> <a class="code" href="class_sdf_compare_handler.html">SdfCompareHandler</a>* <a class="code" href="class_sdf_compare_handler_dd5c70a33541eb9eabc2d19021a768fd.html#dd5c70a33541eb9eabc2d19021a768fd">Create</a>();
+<a name="l00045"></a>00045 <span class="comment"> /// <summary>Compares double values.</summary></span>
+<a name="l00046"></a>00046 <span class="comment"> /// <param name="name">Is the property name.</param> </span>
+<a name="l00047"></a>00047 <span class="comment"> /// <param name="val1">Is the value of the first object.</param> </span>
+<a name="l00048"></a>00048 <span class="comment"> /// <param name="val1">Is the value of the second object.</param> </span>
+<a name="l00049"></a>00049 <span class="comment"> /// <returns>Returns a positive value if val1 is greater than val2, negative if val1 is smaller than val2 or zero if both val1 and val2 are equal.</returns> </span>
+<a name="l00050"></a>00050 <span class="comment"></span> <a class="code" href="_sdf_compare_handler_8h_9bfa9402971b67602a99fd99449c5d76.html#9bfa9402971b67602a99fd99449c5d76">SDF_API</a> <span class="keyword">virtual</span> <span class="keywordtype">int</span> <a class="code" href="class_sdf_compare_handler_4b9fe2c6a37153efe808fbe7b9cfac39.html#4b9fe2c6a37153efe808fbe7b9cfac39">Compare</a>( <span class="keyword">const</span> <span class="keywordtype">wchar_t</span>* name, <span class="keywordtype">double</span> val1, <span class="keywordtype">double</span> val2 );
+<a name="l00052"></a>00052 <span class="comment"> /// <summary>Compares float values.</summary></span>
+<a name="l00053"></a>00053 <span class="comment"> /// <param name="name">Is the property name.</param> </span>
+<a name="l00054"></a>00054 <span class="comment"> /// <param name="val1">Is the value of the first object.</param> </span>
+<a name="l00055"></a>00055 <span class="comment"> /// <param name="val1">Is the value of the second object.</param> </span>
+<a name="l00056"></a>00056 <span class="comment"> /// <returns>Returns a positive value if val1 is greater than val2, negative if val1 is smaller than val2 or zero if both val1 and val2 are equal.</returns> </span>
+<a name="l00057"></a>00057 <span class="comment"></span> <a class="code" href="_sdf_compare_handler_8h_9bfa9402971b67602a99fd99449c5d76.html#9bfa9402971b67602a99fd99449c5d76">SDF_API</a> <span class="keyword">virtual</span> <span class="keywordtype">int</span> <a class="code" href="class_sdf_compare_handler_4b9fe2c6a37153efe808fbe7b9cfac39.html#4b9fe2c6a37153efe808fbe7b9cfac39">Compare</a>( <span class="keyword">const</span> <span class="keywordtype">wchar_t</span>* name, <span class="keywordtype">float</span> val1, <span class="keywordtype">float</span> val2 );
+<a name="l00059"></a>00059 <span class="comment"> /// <summary>Compares int64 values.</summary></span>
+<a name="l00060"></a>00060 <span class="comment"> /// <param name="name">Is the property name.</param> </span>
+<a name="l00061"></a>00061 <span class="comment"> /// <param name="val1">Is the value of the first object.</param> </span>
+<a name="l00062"></a>00062 <span class="comment"> /// <param name="val1">Is the value of the second object.</param> </span>
+<a name="l00063"></a>00063 <span class="comment"> /// <returns>Returns a positive value if val1 is greater than val2, negative if val1 is smaller than val2 or zero if both val1 and val2 are equal.</returns> </span>
+<a name="l00064"></a>00064 <span class="comment"></span> <a class="code" href="_sdf_compare_handler_8h_9bfa9402971b67602a99fd99449c5d76.html#9bfa9402971b67602a99fd99449c5d76">SDF_API</a> <span class="keyword">virtual</span> <span class="keywordtype">int</span> <a class="code" href="class_sdf_compare_handler_4b9fe2c6a37153efe808fbe7b9cfac39.html#4b9fe2c6a37153efe808fbe7b9cfac39">Compare</a>( <span class="keyword">const</span> <span class="keywordtype">wchar_t</span>* name, FdoInt64 val1, FdoInt64 val2 );
+<a name="l00066"></a>00066 <span class="comment"> /// <summary>Compares int32 values.</summary></span>
+<a name="l00067"></a>00067 <span class="comment"> /// <param name="name">Is the property name.</param> </span>
+<a name="l00068"></a>00068 <span class="comment"> /// <param name="val1">Is the value of the first object.</param> </span>
+<a name="l00069"></a>00069 <span class="comment"> /// <param name="val1">Is the value of the second object.</param> </span>
+<a name="l00070"></a>00070 <span class="comment"> /// <returns>Returns a positive value if val1 is greater than val2, negative if val1 is smaller than val2 or zero if both val1 and val2 are equal.</returns> </span>
+<a name="l00071"></a>00071 <span class="comment"></span> <a class="code" href="_sdf_compare_handler_8h_9bfa9402971b67602a99fd99449c5d76.html#9bfa9402971b67602a99fd99449c5d76">SDF_API</a> <span class="keyword">virtual</span> <span class="keywordtype">int</span> <a class="code" href="class_sdf_compare_handler_4b9fe2c6a37153efe808fbe7b9cfac39.html#4b9fe2c6a37153efe808fbe7b9cfac39">Compare</a>( <span class="keyword">const</span> <span class="keywordtype">wchar_t</span>* name, FdoInt32 val1, FdoInt32 val2 );
+<a name="l00072"></a>00072 <span class="comment"></span>
+<a name="l00073"></a>00073 <span class="comment"> /// <summary>Compares int16 values.</summary></span>
+<a name="l00074"></a>00074 <span class="comment"> /// <param name="name">Is the property name.</param> </span>
+<a name="l00075"></a>00075 <span class="comment"> /// <param name="val1">Is the value of the first object.</param> </span>
+<a name="l00076"></a>00076 <span class="comment"> /// <param name="val1">Is the value of the second object.</param> </span>
+<a name="l00077"></a>00077 <span class="comment"> /// <returns>Returns a positive value if val1 is greater than val2, negative if val1 is smaller than val2 or zero if both val1 and val2 are equal.</returns> </span>
+<a name="l00078"></a>00078 <span class="comment"></span> <a class="code" href="_sdf_compare_handler_8h_9bfa9402971b67602a99fd99449c5d76.html#9bfa9402971b67602a99fd99449c5d76">SDF_API</a> <span class="keyword">virtual</span> <span class="keywordtype">int</span> <a class="code" href="class_sdf_compare_handler_4b9fe2c6a37153efe808fbe7b9cfac39.html#4b9fe2c6a37153efe808fbe7b9cfac39">Compare</a>( <span class="keyword">const</span> <span class="keywordtype">wchar_t</span>* name, FdoInt16 val1, FdoInt16 val2 );
+<a name="l00079"></a>00079 <span class="comment"></span>
+<a name="l00080"></a>00080 <span class="comment"> /// <summary>Compares string values.</summary></span>
+<a name="l00081"></a>00081 <span class="comment"> /// <param name="name">Is the property name.</param> </span>
+<a name="l00082"></a>00082 <span class="comment"> /// <param name="val1">Is the value of the first object.</param> </span>
+<a name="l00083"></a>00083 <span class="comment"> /// <param name="val1">Is the value of the second object.</param> </span>
+<a name="l00084"></a>00084 <span class="comment"> /// <returns>Returns a positive value if val1 is greater than val2, negative if val1 is smaller than val2 or zero if both val1 and val2 are equal.</returns> </span>
+<a name="l00085"></a>00085 <span class="comment"></span> <a class="code" href="_sdf_compare_handler_8h_9bfa9402971b67602a99fd99449c5d76.html#9bfa9402971b67602a99fd99449c5d76">SDF_API</a> <span class="keyword">virtual</span> <span class="keywordtype">int</span> <a class="code" href="class_sdf_compare_handler_4b9fe2c6a37153efe808fbe7b9cfac39.html#4b9fe2c6a37153efe808fbe7b9cfac39">Compare</a>( <span class="keyword">const</span> <span class="keywordtype">wchar_t</span>* name, <span class="keyword">const</span> <span class="keywordtype">wchar_t</span>* val1, <span class="keyword">const</span> <span class="keywordtype">wchar_t</span>* val2 );
+<a name="l00086"></a>00086 <span class="comment"></span>
+<a name="l00087"></a>00087 <span class="comment"> /// <summary>Compares date time values.</summary></span>
+<a name="l00088"></a>00088 <span class="comment"> /// <param name="name">Is the property name.</param> </span>
+<a name="l00089"></a>00089 <span class="comment"> /// <param name="val1">Is the value of the first object.</param> </span>
+<a name="l00090"></a>00090 <span class="comment"> /// <param name="val1">Is the value of the second object.</param> </span>
+<a name="l00091"></a>00091 <span class="comment"> /// <returns>Returns a positive value if val1 is greater than val2, negative if val1 is smaller than val2 or zero if both val1 and val2 are equal.</returns> </span>
+<a name="l00092"></a>00092 <span class="comment"></span> <a class="code" href="_sdf_compare_handler_8h_9bfa9402971b67602a99fd99449c5d76.html#9bfa9402971b67602a99fd99449c5d76">SDF_API</a> <span class="keyword">virtual</span> <span class="keywordtype">int</span> <a class="code" href="class_sdf_compare_handler_4b9fe2c6a37153efe808fbe7b9cfac39.html#4b9fe2c6a37153efe808fbe7b9cfac39">Compare</a>( <span class="keyword">const</span> <span class="keywordtype">wchar_t</span>* name, FdoDateTime val1, FdoDateTime val2 );
+<a name="l00093"></a>00093 <span class="comment"></span>
+<a name="l00094"></a>00094 <span class="comment"> /// <summary>Compares unsigned char values.</summary></span>
+<a name="l00095"></a>00095 <span class="comment"> /// <param name="name">Is the property name.</param> </span>
+<a name="l00096"></a>00096 <span class="comment"> /// <param name="val1">Is the value of the first object.</param> </span>
+<a name="l00097"></a>00097 <span class="comment"> /// <param name="val1">Is the value of the second object.</param> </span>
+<a name="l00098"></a>00098 <span class="comment"> /// <returns>Returns a positive value if val1 is greater than val2, negative if val1 is smaller than val2 or zero if both val1 and val2 are equal.</returns> </span>
+<a name="l00099"></a>00099 <span class="comment"></span> <a class="code" href="_sdf_compare_handler_8h_9bfa9402971b67602a99fd99449c5d76.html#9bfa9402971b67602a99fd99449c5d76">SDF_API</a> <span class="keyword">virtual</span> <span class="keywordtype">int</span> <a class="code" href="class_sdf_compare_handler_4b9fe2c6a37153efe808fbe7b9cfac39.html#4b9fe2c6a37153efe808fbe7b9cfac39">Compare</a>( <span class="keyword">const</span> <span class="keywordtype">wchar_t</span>* name, <span class="keywordtype">unsigned</span> <span class="keywordtype">char</span> val1, <span class="keywordtype">unsigned</span> <span class="keywordtype">char</span> val2 );
+<a name="l00100"></a>00100
+<a name="l00101"></a>00101 };
+<a name="l00102"></a>00102
+<a name="l00104"></a>00104 <span class="preprocessor">#endif</span>
+<a name="l00105"></a>00105 <span class="preprocessor"></span>
+ <hr>
+ <table width="100%" border="0">
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SDF/_sdf_compare_handler_8h.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/_sdf_compare_handler_8h.html?view=auto&rev=97
--- (empty file)
+++ trunk/www/docs/SDF/_sdf_compare_handler_8h.html 2006-12-04 18:49:20+0000
@@ -0,0 +1,58 @@
+<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN" "http://www.w3.org/TR/html4/loose.dtd">
+<html>
+ <head>
+ <meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
+ <title>OSGeo FDO Provider for SDF API Reference</title>
+ <link href="custom.css" rel="stylesheet" type="text/css">
+ <link href="tabs.css" rel="stylesheet" type="text/css">
+ </head>
+ <body bgcolor="#FFFFFF">
+ <tr>
+ <td><b>API Reference<b></td>
+ <td align="right"><b>OSGeo FDO Provider for SDF<b></td>
+ </tr>
+ </table>
+<!-- End of: header.html -->
+<!-- Generated by Doxygen 1.4.6-NO -->
+<div class="tabs">
+ <ul>
+ <li><a href="main.html"><span>Main Page</span></a></li>
+ <li><a href="classes.html"><span>Classes</span></a></li>
+ <li id="current"><a href="files.html"><span>Files</span></a></li>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ <li><a href="files.html"><span>File List</span></a></li>
+ <li><a href="globals.html"><span>File Members</span></a></li>
+ </ul></div>
+<h1>SdfCompareHandler.h File Reference</h1>
+<p>
+<p>
+This graph shows which files directly or indirectly include this file:<p><center><img src="_sdf_compare_handler_8h__dep__incl.png" border="0" usemap="#SdfCompareHandler.hdep_map" alt=""></center>
+<map name="SdfCompareHandler.hdep_map">
+<area href="_i_extended_select_8h.html" shape="rect" coords="210,7,340,33" alt="">
+</map>
+<p>
+<a href="_sdf_compare_handler_8h-source.html">Go to the source code of this file.</a><table border="0" cellpadding="0" cellspacing="0">
+<tr><td></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">class </td><td class="memItemRight" valign="bottom"><a class="el" href="class_sdf_compare_handler.html">SdfCompareHandler</a></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">#define </td><td class="memItemRight" valign="bottom"><a class="el" href="_sdf_compare_handler_8h_9bfa9402971b67602a99fd99449c5d76.html#9bfa9402971b67602a99fd99449c5d76">SDF_API</a></td></tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SDF/_sdf_compare_handler_8h_9bfa9402971b67602a99fd99449c5d76.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/_sdf_compare_handler_8h_9bfa9402971b67602a99fd99449c5d76.html?view=auto&rev=97
--- (empty file)
+++ trunk/www/docs/SDF/_sdf_compare_handler_8h_9bfa9402971b67602a99fd99449c5d76.html 2006-12-04 18:49:20+0000
@@ -0,0 +1,74 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="nav">
+<a class="el" href="_sdf_compare_handler_8h.html">SdfCompareHandler.h</a></div>
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="_sdf_compare_handler_8h_9bfa9402971b67602a99fd99449c5d76.html#9bfa9402971b67602a99fd99449c5d76">SDF_API</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="9bfa9402971b67602a99fd99449c5d76"></a><!-- doxytag: member="SdfCompareHandler.h::SDF_API" ref="9bfa9402971b67602a99fd99449c5d76" args="" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">#define SDF_API </td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+<p>
+Definition at line <a class="el" href="_sdf_compare_handler_8h-source.html#l00026">26</a> of file <a class="el" href="_sdf_compare_handler_8h-source.html">SdfCompareHandler.h</a>. </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SDF/_sdf_compare_handler_8h__dep__incl.map
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/_sdf_compare_handler_8h__dep__incl.map?view=auto&rev=97
--- (empty file)
+++ trunk/www/docs/SDF/_sdf_compare_handler_8h__dep__incl.map 2006-12-04 18:49:20+0000
@@ -0,0 +1,2 @@
+base referer
+rect $_i_extended_select_8h.html 210,7 340,33
Added: trunk/www/docs/SDF/_sdf_compare_handler_8h__dep__incl.md5
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/_sdf_compare_handler_8h__dep__incl.md5?view=auto&rev=97
--- (empty file)
+++ trunk/www/docs/SDF/_sdf_compare_handler_8h__dep__incl.md5 2006-12-04 18:49:20+0000
@@ -0,0 +1 @@
+ef90ed725a4944434236319bd0c74f1b
Added: trunk/www/docs/SDF/_sdf_compare_handler_8h__dep__incl.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/_sdf_compare_handler_8h__dep__incl.png?view=auto&rev=97
Added: trunk/www/docs/SDF/annotated.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/annotated.html?view=auto&rev=97
--- (empty file)
+++ trunk/www/docs/SDF/annotated.html 2006-12-04 18:49:20+0000
@@ -0,0 +1,47 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ <li id="current"><a href="classes.html"><span>Classes</span></a></li>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ <li><a href="classes.html"><span>Alphabetical List</span></a></li>
+ <li id="current"><a href="annotated.html"><span>Class List</span></a></li>
+ <li><a href="hierarchy.html"><span>Class Hierarchy</span></a></li>
+ <li><a href="functions.html"><span>Class Members</span></a></li>
+ </ul></div>
+<h1>FDO Provider for SDF Class List</h1>Here are the classes, structs, unions and interfaces with brief descriptions:<table>
+ <tr><td class="indexkey"><a class="el" href="class_fdo_i_create_s_d_f_file.html">FdoICreateSDFFile</a></td><td class="indexvalue">This command creates a new SDF+ file with a specified location and file name and a given spatial coordinate system </td></tr>
+ <tr><td class="indexkey"><a class="el" href="class_sdf_compare_handler.html">SdfCompareHandler</a></td><td class="indexvalue"></td></tr>
+ <tr><td class="indexkey"><a class="el" href="class_sdf_i_extended_select.html">SdfIExtendedSelect</a></td><td class="indexvalue"></td></tr>
+ <tr><td class="indexkey"><a class="el" href="class_sdf_i_scrollable_feature_reader.html">SdfIScrollableFeatureReader</a></td><td class="indexvalue"></td></tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file-members.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file-members.html?view=auto&rev=97
--- (empty file)
+++ trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file-members.html 2006-12-04 18:49:20+0000
@@ -0,0 +1,55 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ <li><a href="annotated.html"><span>Class List</span></a></li>
+ </ul></div>
+<h1>FdoICreateSDFFile Member List</h1>This is the complete list of members for <a class="el" href="class_fdo_i_create_s_d_f_file.html">FdoICreateSDFFile</a>, including all inherited members.<p><table>
+ <tr class="memlist"><td><a class="el" href="class_fdo_i_create_s_d_f_file_05550ca7007c3e389b7029c41baa1587.html#05550ca7007c3e389b7029c41baa1587">Execute</a>()=0</td><td><a class="el" href="class_fdo_i_create_s_d_f_file.html">FdoICreateSDFFile</a></td><td><code> [pure virtual]</code></td></tr>
+ <tr class="memlist"><td><a class="el" href="class_fdo_i_create_s_d_f_file_0b8020c31deb9acc05311fd11f260c7d.html#0b8020c31deb9acc05311fd11f260c7d">GetCoordinateSystemWKT</a>()=0</td><td><a class="el" href="class_fdo_i_create_s_d_f_file.html">FdoICreateSDFFile</a></td><td><code> [pure virtual]</code></td></tr>
+ <tr class="memlist"><td><a class="el" href="class_fdo_i_create_s_d_f_file_0bde059736005f052076c6735c8b2453.html#0bde059736005f052076c6735c8b2453">GetFileName</a>()=0</td><td><a class="el" href="class_fdo_i_create_s_d_f_file.html">FdoICreateSDFFile</a></td><td><code> [pure virtual]</code></td></tr>
+ <tr class="memlist"><td><a class="el" href="class_fdo_i_create_s_d_f_file_4d74d6f8e45e76d8c8606953ae4cb307.html#4d74d6f8e45e76d8c8606953ae4cb307">GetSpatialContextDescription</a>()=0</td><td><a class="el" href="class_fdo_i_create_s_d_f_file.html">FdoICreateSDFFile</a></td><td><code> [pure virtual]</code></td></tr>
+ <tr class="memlist"><td><a class="el" href="class_fdo_i_create_s_d_f_file_647ff5d7f47cf47422c32645074cce8d.html#647ff5d7f47cf47422c32645074cce8d">GetSpatialContextName</a>()=0</td><td><a class="el" href="class_fdo_i_create_s_d_f_file.html">FdoICreateSDFFile</a></td><td><code> [pure virtual]</code></td></tr>
+ <tr class="memlist"><td><a class="el" href="class_fdo_i_create_s_d_f_file_4a2bb60374b5db4f9dca173de2845803.html#4a2bb60374b5db4f9dca173de2845803">GetXYTolerance</a>()=0</td><td><a class="el" href="class_fdo_i_create_s_d_f_file.html">FdoICreateSDFFile</a></td><td><code> [pure virtual]</code></td></tr>
+ <tr class="memlist"><td><a class="el" href="class_fdo_i_create_s_d_f_file_8b2fc8bbd39311d609c316fac75d765b.html#8b2fc8bbd39311d609c316fac75d765b">GetZTolerance</a>()=0</td><td><a class="el" href="class_fdo_i_create_s_d_f_file.html">FdoICreateSDFFile</a></td><td><code> [pure virtual]</code></td></tr>
+ <tr class="memlist"><td><a class="el" href="class_fdo_i_create_s_d_f_file_8bb4c31009cf0ab76fc094eadcf4ca91.html#8bb4c31009cf0ab76fc094eadcf4ca91">SetCoordinateSystemWKT</a>(FdoString *wkt)=0</td><td><a class="el" href="class_fdo_i_create_s_d_f_file.html">FdoICreateSDFFile</a></td><td><code> [pure virtual]</code></td></tr>
+ <tr class="memlist"><td><a class="el" href="class_fdo_i_create_s_d_f_file_e92b777da3c498180dd72fe4629ee788.html#e92b777da3c498180dd72fe4629ee788">SetFileName</a>(FdoString *name)=0</td><td><a class="el" href="class_fdo_i_create_s_d_f_file.html">FdoICreateSDFFile</a></td><td><code> [pure virtual]</code></td></tr>
+ <tr class="memlist"><td><a class="el" href="class_fdo_i_create_s_d_f_file_86b4ac8510f46ad6629e42023f184cee.html#86b4ac8510f46ad6629e42023f184cee">SetSpatialContextDescription</a>(FdoString *description)=0</td><td><a class="el" href="class_fdo_i_create_s_d_f_file.html">FdoICreateSDFFile</a></td><td><code> [pure virtual]</code></td></tr>
+ <tr class="memlist"><td><a class="el" href="class_fdo_i_create_s_d_f_file_bda73a210df146335a62e933ebe19948.html#bda73a210df146335a62e933ebe19948">SetSpatialContextName</a>(FdoString *name)=0</td><td><a class="el" href="class_fdo_i_create_s_d_f_file.html">FdoICreateSDFFile</a></td><td><code> [pure virtual]</code></td></tr>
+ <tr class="memlist"><td><a class="el" href="class_fdo_i_create_s_d_f_file_b3e528dda87b952a83786b2d01343524.html#b3e528dda87b952a83786b2d01343524">SetXYTolerance</a>(double tolerance)=0</td><td><a class="el" href="class_fdo_i_create_s_d_f_file.html">FdoICreateSDFFile</a></td><td><code> [pure virtual]</code></td></tr>
+ <tr class="memlist"><td><a class="el" href="class_fdo_i_create_s_d_f_file_2937b06fdf37207301200042b40e8d71.html#2937b06fdf37207301200042b40e8d71">SetZTolerance</a>(double tolerance)=0</td><td><a class="el" href="class_fdo_i_create_s_d_f_file.html">FdoICreateSDFFile</a></td><td><code> [pure virtual]</code></td></tr>
+</table><!-- footer.html -->
+ <hr>
+ <tr>
+ <td align="right"><font size="-2"><a href="mailto:isd.docs at autodesk.com&subject=FDO%20Provider%20for%20SDF%20API%20documentation">Comments?</a></font></td>
+ <!-- The logo can go in another cell, when we get one -->
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file.html?view=auto&rev=97
--- (empty file)
+++ trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file.html 2006-12-04 18:49:20+0000
@@ -0,0 +1,93 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<h1>FdoICreateSDFFile Class Reference</h1><!-- doxytag: class="FdoICreateSDFFile" --><code>#include <<a class="el" href="_i_create_s_d_f_file_8h-source.html">ICreateSDFFile.h</a>></code>
+<p>
+<a href="class_fdo_i_create_s_d_f_file-members.html">List of all members.</a><hr><a name="_details"></a><h2>Detailed Description</h2>
+This command creates a new SDF+ file with a specified location and file name and a given spatial coordinate system.
+<p>
+<p>
+Definition at line <a class="el" href="_i_create_s_d_f_file_8h-source.html#l00026">26</a> of file <a class="el" href="_i_create_s_d_f_file_8h-source.html">ICreateSDFFile.h</a>.<table border="0" cellpadding="0" cellspacing="0">
+<tr><td></td></tr>
+<tr><td colspan="2"><br><h2>Public Member Functions</h2></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">virtual FDO_API void </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_i_create_s_d_f_file_05550ca7007c3e389b7029c41baa1587.html#05550ca7007c3e389b7029c41baa1587">Execute</a> ()=0</td></tr>
+<tr><td class="mdescLeft"> </td><td class="mdescRight">Executes the command. An exception is thrown if the file fails to be created. <a href="#05550ca7007c3e389b7029c41baa1587"></a><br></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">virtual FDO_API FdoString * </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_i_create_s_d_f_file_0b8020c31deb9acc05311fd11f260c7d.html#0b8020c31deb9acc05311fd11f260c7d">GetCoordinateSystemWKT</a> ()=0</td></tr>
+<tr><td class="mdescLeft"> </td><td class="mdescRight">Gets the name of the coordinate system in OpenGIS SRS WKT format of the spatial context. If the result is an empty string, the coordinate system WKT description is not available. <a href="#0b8020c31deb9acc05311fd11f260c7d"></a><br></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">virtual FDO_API FdoString * </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_i_create_s_d_f_file_0bde059736005f052076c6735c8b2453.html#0bde059736005f052076c6735c8b2453">GetFileName</a> ()=0</td></tr>
+<tr><td class="mdescLeft"> </td><td class="mdescRight">Gets the name of the SDF+ file being created. The name is a fully qualified absolute path. <a href="#0bde059736005f052076c6735c8b2453"></a><br></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">virtual FDO_API FdoString * </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_i_create_s_d_f_file_4d74d6f8e45e76d8c8606953ae4cb307.html#4d74d6f8e45e76d8c8606953ae4cb307">GetSpatialContextDescription</a> ()=0</td></tr>
+<tr><td class="mdescLeft"> </td><td class="mdescRight">Gets the description of the spatial context. <a href="#4d74d6f8e45e76d8c8606953ae4cb307"></a><br></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">virtual FDO_API FdoString * </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_i_create_s_d_f_file_647ff5d7f47cf47422c32645074cce8d.html#647ff5d7f47cf47422c32645074cce8d">GetSpatialContextName</a> ()=0</td></tr>
+<tr><td class="mdescLeft"> </td><td class="mdescRight">Gets the name of the coordinate system of the spatial context. If the result is a null or empty string, the coordinate system is unknown to the spatial context. <a href="#647ff5d7f47cf47422c32645074cce8d"></a><br></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">virtual FDO_API double </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_i_create_s_d_f_file_4a2bb60374b5db4f9dca173de2845803.html#4a2bb60374b5db4f9dca173de2845803">GetXYTolerance</a> ()=0</td></tr>
+<tr><td class="mdescLeft"> </td><td class="mdescRight">Gets the tolerance value for X/Y ordinates of the spatial context. Tolerances are used in some geometric tests, mostly for equality between coordinates. This occurs frequently in spatial queries, especially with "on boundary" or "just touching" conditions. It is also an objective amount that can be used when formulating step distances for parametric curve interpolation. <a href="#4a2bb60374b5db4f9dca173de2845803"></a><br></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">virtual FDO_API double </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_i_create_s_d_f_file_8b2fc8bbd39311d609c316fac75d765b.html#8b2fc8bbd39311d609c316fac75d765b">GetZTolerance</a> ()=0</td></tr>
+<tr><td class="mdescLeft"> </td><td class="mdescRight">Gets the tolerance value for Z ordinates of the spatial context. Tolerances are used in some geometric tests, mostly for equality between coordinates. This occurs a frequently in spatial queries, especially with "on boundary" or "just touching" conditions. It is also an objective amount that can be used when formulating step distances for parametric curve interpolation. <a href="#8b2fc8bbd39311d609c316fac75d765b"></a><br></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">virtual FDO_API void </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_i_create_s_d_f_file_8bb4c31009cf0ab76fc094eadcf4ca91.html#8bb4c31009cf0ab76fc094eadcf4ca91">SetCoordinateSystemWKT</a> (FdoString *wkt)=0</td></tr>
+<tr><td class="mdescLeft"> </td><td class="mdescRight">Sets the coordinate system of the context to create as a string in OpenGIS SRS WKT format. <a href="#8bb4c31009cf0ab76fc094eadcf4ca91"></a><br></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">virtual FDO_API void </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_i_create_s_d_f_file_e92b777da3c498180dd72fe4629ee788.html#e92b777da3c498180dd72fe4629ee788">SetFileName</a> (FdoString *name)=0</td></tr>
+<tr><td class="mdescLeft"> </td><td class="mdescRight">Sets the name of the SDF+ file being created. The name must be a fully qualified absolute path. <a href="#e92b777da3c498180dd72fe4629ee788"></a><br></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">virtual FDO_API void </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_i_create_s_d_f_file_86b4ac8510f46ad6629e42023f184cee.html#86b4ac8510f46ad6629e42023f184cee">SetSpatialContextDescription</a> (FdoString *description)=0</td></tr>
+<tr><td class="mdescLeft"> </td><td class="mdescRight">Sets the description of the spatial context as a string. <a href="#86b4ac8510f46ad6629e42023f184cee"></a><br></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">virtual FDO_API void </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_i_create_s_d_f_file_bda73a210df146335a62e933ebe19948.html#bda73a210df146335a62e933ebe19948">SetSpatialContextName</a> (FdoString *name)=0</td></tr>
+<tr><td class="mdescLeft"> </td><td class="mdescRight">Sets the name of the spatial context as a string. <a href="#bda73a210df146335a62e933ebe19948"></a><br></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">virtual FDO_API void </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_i_create_s_d_f_file_b3e528dda87b952a83786b2d01343524.html#b3e528dda87b952a83786b2d01343524">SetXYTolerance</a> (double tolerance)=0</td></tr>
+<tr><td class="mdescLeft"> </td><td class="mdescRight">Sets the tolerance value to use for X/Y ordinates. Tolerances are used in some geometric tests, mostly for equality between coordinates. This occurs frequently in spatial queries, especially with "on boundary" or "just touching" conditions. It is also an objective amount that can be used when formulating step distances for parametric curve interpolation. <a href="#b3e528dda87b952a83786b2d01343524"></a><br></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">virtual FDO_API void </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_i_create_s_d_f_file_2937b06fdf37207301200042b40e8d71.html#2937b06fdf37207301200042b40e8d71">SetZTolerance</a> (double tolerance)=0</td></tr>
+<tr><td class="mdescLeft"> </td><td class="mdescRight">Sets the tolerance value to use for Z ordinates. Tolerances are used in some geometric tests, mostly for equality between coordinates. This occurs frequently in spatial queries, especially with "on boundary" or "just touching" conditions. It is also an objective amount that can be used when formulating step distances for parametric curve interpolation. <a href="#2937b06fdf37207301200042b40e8d71"></a><br></td></tr>
+</table>
+<hr>The documentation for this class was generated from the following file:<ul>
+<li><a class="el" href="_i_create_s_d_f_file_8h-source.html">ICreateSDFFile.h</a></ul>
+<!-- footer.html -->
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file_05550ca7007c3e389b7029c41baa1587.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file_05550ca7007c3e389b7029c41baa1587.html?view=auto&rev=97
--- (empty file)
+++ trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file_05550ca7007c3e389b7029c41baa1587.html 2006-12-04 18:49:20+0000
@@ -0,0 +1,91 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="nav">
+<a class="el" href="class_fdo_i_create_s_d_f_file.html">FdoICreateSDFFile</a></div>
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="class_fdo_i_create_s_d_f_file_05550ca7007c3e389b7029c41baa1587.html#05550ca7007c3e389b7029c41baa1587">Execute</a></td></tr>
+ <tr><td class="navtab"><a class="qindex" href="class_fdo_i_create_s_d_f_file_0b8020c31deb9acc05311fd11f260c7d.html#0b8020c31deb9acc05311fd11f260c7d">GetCoordinateSystemWKT</a></td></tr>
+ <tr><td class="navtab"><a class="qindex" href="class_fdo_i_create_s_d_f_file_0bde059736005f052076c6735c8b2453.html#0bde059736005f052076c6735c8b2453">GetFileName</a></td></tr>
+ <tr><td class="navtab"><a class="qindex" href="class_fdo_i_create_s_d_f_file_4d74d6f8e45e76d8c8606953ae4cb307.html#4d74d6f8e45e76d8c8606953ae4cb307">GetSpatialContextDescription</a></td></tr>
+ <tr><td class="navtab"><a class="qindex" href="class_fdo_i_create_s_d_f_file_647ff5d7f47cf47422c32645074cce8d.html#647ff5d7f47cf47422c32645074cce8d">GetSpatialContextName</a></td></tr>
+ <tr><td class="navtab"><a class="qindex" href="class_fdo_i_create_s_d_f_file_4a2bb60374b5db4f9dca173de2845803.html#4a2bb60374b5db4f9dca173de2845803">GetXYTolerance</a></td></tr>
+ <tr><td class="navtab"><a class="qindex" href="class_fdo_i_create_s_d_f_file_8b2fc8bbd39311d609c316fac75d765b.html#8b2fc8bbd39311d609c316fac75d765b">GetZTolerance</a></td></tr>
+ <tr><td class="navtab"><a class="qindex" href="class_fdo_i_create_s_d_f_file_8bb4c31009cf0ab76fc094eadcf4ca91.html#8bb4c31009cf0ab76fc094eadcf4ca91">SetCoordinateSystemWKT</a></td></tr>
+ <tr><td class="navtab"><a class="qindex" href="class_fdo_i_create_s_d_f_file_e92b777da3c498180dd72fe4629ee788.html#e92b777da3c498180dd72fe4629ee788">SetFileName</a></td></tr>
+ <tr><td class="navtab"><a class="qindex" href="class_fdo_i_create_s_d_f_file_86b4ac8510f46ad6629e42023f184cee.html#86b4ac8510f46ad6629e42023f184cee">SetSpatialContextDescription</a></td></tr>
+ <tr><td class="navtab"><a class="qindex" href="class_fdo_i_create_s_d_f_file_bda73a210df146335a62e933ebe19948.html#bda73a210df146335a62e933ebe19948">SetSpatialContextName</a></td></tr>
+ <tr><td class="navtab"><a class="qindex" href="class_fdo_i_create_s_d_f_file_b3e528dda87b952a83786b2d01343524.html#b3e528dda87b952a83786b2d01343524">SetXYTolerance</a></td></tr>
+ <tr><td class="navtab"><a class="qindex" href="class_fdo_i_create_s_d_f_file_2937b06fdf37207301200042b40e8d71.html#2937b06fdf37207301200042b40e8d71">SetZTolerance</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="05550ca7007c3e389b7029c41baa1587"></a><!-- doxytag: member="FdoICreateSDFFile::Execute" ref="05550ca7007c3e389b7029c41baa1587" args="()=0" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">virtual FDO_API void FdoICreateSDFFile::Execute </td>
+ <td class="md" valign="top">( </td>
+ <td class="mdname1" valign="top" nowrap> </td>
+ <td class="md" valign="top"> ) </td>
+ <td class="md" nowrap><code> [pure virtual]</code></td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+Executes the command. An exception is thrown if the file fails to be created.
+<p>
+<dl compact><dt><b>Returns:</b></dt><dd>Returns nothing. </dd></dl>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file_0b8020c31deb9acc05311fd11f260c7d.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file_0b8020c31deb9acc05311fd11f260c7d.html?view=auto&rev=97
--- (empty file)
+++ trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file_0b8020c31deb9acc05311fd11f260c7d.html 2006-12-04 18:49:20+0000
@@ -0,0 +1,91 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="nav">
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindex" href="class_fdo_i_create_s_d_f_file_05550ca7007c3e389b7029c41baa1587.html#05550ca7007c3e389b7029c41baa1587">Execute</a></td></tr>
+ <tr><td class="navtab"><a class="qindexHL" href="class_fdo_i_create_s_d_f_file_0b8020c31deb9acc05311fd11f260c7d.html#0b8020c31deb9acc05311fd11f260c7d">GetCoordinateSystemWKT</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="0b8020c31deb9acc05311fd11f260c7d"></a><!-- doxytag: member="FdoICreateSDFFile::GetCoordinateSystemWKT" ref="0b8020c31deb9acc05311fd11f260c7d" args="()=0" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">virtual FDO_API FdoString* FdoICreateSDFFile::GetCoordinateSystemWKT </td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+Gets the name of the coordinate system in OpenGIS SRS WKT format of the spatial context. If the result is an empty string, the coordinate system WKT description is not available.
+<p>
+<dl compact><dt><b>Returns:</b></dt><dd>Returns the coordinate system description in WKT format of the spatial context. </dd></dl>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file_0bde059736005f052076c6735c8b2453.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file_0bde059736005f052076c6735c8b2453.html?view=auto&rev=97
--- (empty file)
+++ trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file_0bde059736005f052076c6735c8b2453.html 2006-12-04 18:49:20+0000
@@ -0,0 +1,91 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="nav">
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="class_fdo_i_create_s_d_f_file_0bde059736005f052076c6735c8b2453.html#0bde059736005f052076c6735c8b2453">GetFileName</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="0bde059736005f052076c6735c8b2453"></a><!-- doxytag: member="FdoICreateSDFFile::GetFileName" ref="0bde059736005f052076c6735c8b2453" args="()=0" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">virtual FDO_API FdoString* FdoICreateSDFFile::GetFileName </td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+Gets the name of the SDF+ file being created. The name is a fully qualified absolute path.
+<p>
+<dl compact><dt><b>Returns:</b></dt><dd>Returns the name of the SDF+ file. </dd></dl>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file_2937b06fdf37207301200042b40e8d71.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file_2937b06fdf37207301200042b40e8d71.html?view=auto&rev=97
--- (empty file)
+++ trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file_2937b06fdf37207301200042b40e8d71.html 2006-12-04 18:49:20+0000
@@ -0,0 +1,97 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="nav">
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="class_fdo_i_create_s_d_f_file_2937b06fdf37207301200042b40e8d71.html#2937b06fdf37207301200042b40e8d71">SetZTolerance</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="2937b06fdf37207301200042b40e8d71"></a><!-- doxytag: member="FdoICreateSDFFile::SetZTolerance" ref="2937b06fdf37207301200042b40e8d71" args="(double tolerance)=0" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">virtual FDO_API void FdoICreateSDFFile::SetZTolerance </td>
+ <td class="md" nowrap valign="top">double </td>
+ <td class="mdname1" valign="top" nowrap> <em>tolerance</em> </td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+Sets the tolerance value to use for Z ordinates. Tolerances are used in some geometric tests, mostly for equality between coordinates. This occurs frequently in spatial queries, especially with "on boundary" or "just touching" conditions. It is also an objective amount that can be used when formulating step distances for parametric curve interpolation.
+<p>
+<dl compact><dt><b>Parameters:</b></dt><dd>
+ <tr><td valign="top"></td><td valign="top"><em>tolerance</em> </td><td>Input the tolerance.</td></tr>
+ </table>
+</dl>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file_4a2bb60374b5db4f9dca173de2845803.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file_4a2bb60374b5db4f9dca173de2845803.html?view=auto&rev=97
--- (empty file)
+++ trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file_4a2bb60374b5db4f9dca173de2845803.html 2006-12-04 18:49:20+0000
@@ -0,0 +1,91 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="nav">
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="class_fdo_i_create_s_d_f_file_4a2bb60374b5db4f9dca173de2845803.html#4a2bb60374b5db4f9dca173de2845803">GetXYTolerance</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="4a2bb60374b5db4f9dca173de2845803"></a><!-- doxytag: member="FdoICreateSDFFile::GetXYTolerance" ref="4a2bb60374b5db4f9dca173de2845803" args="()=0" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">virtual FDO_API double FdoICreateSDFFile::GetXYTolerance </td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+Gets the tolerance value for X/Y ordinates of the spatial context. Tolerances are used in some geometric tests, mostly for equality between coordinates. This occurs frequently in spatial queries, especially with "on boundary" or "just touching" conditions. It is also an objective amount that can be used when formulating step distances for parametric curve interpolation.
+<p>
+<dl compact><dt><b>Returns:</b></dt><dd>Returns the tolerance. </dd></dl>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file_4d74d6f8e45e76d8c8606953ae4cb307.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file_4d74d6f8e45e76d8c8606953ae4cb307.html?view=auto&rev=97
--- (empty file)
+++ trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file_4d74d6f8e45e76d8c8606953ae4cb307.html 2006-12-04 18:49:20+0000
@@ -0,0 +1,91 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="nav">
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="class_fdo_i_create_s_d_f_file_4d74d6f8e45e76d8c8606953ae4cb307.html#4d74d6f8e45e76d8c8606953ae4cb307">GetSpatialContextDescription</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="4d74d6f8e45e76d8c8606953ae4cb307"></a><!-- doxytag: member="FdoICreateSDFFile::GetSpatialContextDescription" ref="4d74d6f8e45e76d8c8606953ae4cb307" args="()=0" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">virtual FDO_API FdoString* FdoICreateSDFFile::GetSpatialContextDescription </td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+Gets the description of the spatial context.
+<p>
+<dl compact><dt><b>Returns:</b></dt><dd>Returns the description of the spatial context. </dd></dl>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file_647ff5d7f47cf47422c32645074cce8d.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file_647ff5d7f47cf47422c32645074cce8d.html?view=auto&rev=97
--- (empty file)
+++ trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file_647ff5d7f47cf47422c32645074cce8d.html 2006-12-04 18:49:20+0000
@@ -0,0 +1,91 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="nav">
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="class_fdo_i_create_s_d_f_file_647ff5d7f47cf47422c32645074cce8d.html#647ff5d7f47cf47422c32645074cce8d">GetSpatialContextName</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="647ff5d7f47cf47422c32645074cce8d"></a><!-- doxytag: member="FdoICreateSDFFile::GetSpatialContextName" ref="647ff5d7f47cf47422c32645074cce8d" args="()=0" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">virtual FDO_API FdoString* FdoICreateSDFFile::GetSpatialContextName </td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+Gets the name of the coordinate system of the spatial context. If the result is a null or empty string, the coordinate system is unknown to the spatial context.
+<p>
+<dl compact><dt><b>Returns:</b></dt><dd>Returns the coordinate system name of the spatial context. </dd></dl>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file_86b4ac8510f46ad6629e42023f184cee.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file_86b4ac8510f46ad6629e42023f184cee.html?view=auto&rev=97
--- (empty file)
+++ trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file_86b4ac8510f46ad6629e42023f184cee.html 2006-12-04 18:49:20+0000
@@ -0,0 +1,97 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="nav">
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="class_fdo_i_create_s_d_f_file_86b4ac8510f46ad6629e42023f184cee.html#86b4ac8510f46ad6629e42023f184cee">SetSpatialContextDescription</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="86b4ac8510f46ad6629e42023f184cee"></a><!-- doxytag: member="FdoICreateSDFFile::SetSpatialContextDescription" ref="86b4ac8510f46ad6629e42023f184cee" args="(FdoString *description)=0" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">virtual FDO_API void FdoICreateSDFFile::SetSpatialContextDescription </td>
+ <td class="md" nowrap valign="top">FdoString * </td>
+ <td class="mdname1" valign="top" nowrap> <em>description</em> </td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+Sets the description of the spatial context as a string.
+<p>
+ <tr><td valign="top"></td><td valign="top"><em>description</em> </td><td>Input the description of the spatial context.</td></tr>
+ </table>
+</dl>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file_8b2fc8bbd39311d609c316fac75d765b.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file_8b2fc8bbd39311d609c316fac75d765b.html?view=auto&rev=97
--- (empty file)
+++ trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file_8b2fc8bbd39311d609c316fac75d765b.html 2006-12-04 18:49:20+0000
@@ -0,0 +1,91 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="nav">
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="class_fdo_i_create_s_d_f_file_8b2fc8bbd39311d609c316fac75d765b.html#8b2fc8bbd39311d609c316fac75d765b">GetZTolerance</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="8b2fc8bbd39311d609c316fac75d765b"></a><!-- doxytag: member="FdoICreateSDFFile::GetZTolerance" ref="8b2fc8bbd39311d609c316fac75d765b" args="()=0" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">virtual FDO_API double FdoICreateSDFFile::GetZTolerance </td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+Gets the tolerance value for Z ordinates of the spatial context. Tolerances are used in some geometric tests, mostly for equality between coordinates. This occurs a frequently in spatial queries, especially with "on boundary" or "just touching" conditions. It is also an objective amount that can be used when formulating step distances for parametric curve interpolation.
+<p>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file_8bb4c31009cf0ab76fc094eadcf4ca91.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file_8bb4c31009cf0ab76fc094eadcf4ca91.html?view=auto&rev=97
--- (empty file)
+++ trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file_8bb4c31009cf0ab76fc094eadcf4ca91.html 2006-12-04 18:49:20+0000
@@ -0,0 +1,97 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="nav">
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="class_fdo_i_create_s_d_f_file_8bb4c31009cf0ab76fc094eadcf4ca91.html#8bb4c31009cf0ab76fc094eadcf4ca91">SetCoordinateSystemWKT</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="8bb4c31009cf0ab76fc094eadcf4ca91"></a><!-- doxytag: member="FdoICreateSDFFile::SetCoordinateSystemWKT" ref="8bb4c31009cf0ab76fc094eadcf4ca91" args="(FdoString *wkt)=0" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">virtual FDO_API void FdoICreateSDFFile::SetCoordinateSystemWKT </td>
+ <td class="mdname1" valign="top" nowrap> <em>wkt</em> </td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+Sets the coordinate system of the context to create as a string in OpenGIS SRS WKT format.
+<p>
+ <tr><td valign="top"></td><td valign="top"><em>wkt</em> </td><td>Input the coordinate system.</td></tr>
+ </table>
+</dl>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file_b3e528dda87b952a83786b2d01343524.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file_b3e528dda87b952a83786b2d01343524.html?view=auto&rev=97
--- (empty file)
+++ trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file_b3e528dda87b952a83786b2d01343524.html 2006-12-04 18:49:20+0000
@@ -0,0 +1,97 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="nav">
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="class_fdo_i_create_s_d_f_file_b3e528dda87b952a83786b2d01343524.html#b3e528dda87b952a83786b2d01343524">SetXYTolerance</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="b3e528dda87b952a83786b2d01343524"></a><!-- doxytag: member="FdoICreateSDFFile::SetXYTolerance" ref="b3e528dda87b952a83786b2d01343524" args="(double tolerance)=0" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">virtual FDO_API void FdoICreateSDFFile::SetXYTolerance </td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+Sets the tolerance value to use for X/Y ordinates. Tolerances are used in some geometric tests, mostly for equality between coordinates. This occurs frequently in spatial queries, especially with "on boundary" or "just touching" conditions. It is also an objective amount that can be used when formulating step distances for parametric curve interpolation.
+<p>
+ <table border="0" cellspacing="2" cellpadding="0">
+ </table>
+</dl>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file_bda73a210df146335a62e933ebe19948.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file_bda73a210df146335a62e933ebe19948.html?view=auto&rev=97
--- (empty file)
+++ trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file_bda73a210df146335a62e933ebe19948.html 2006-12-04 18:49:20+0000
@@ -0,0 +1,97 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ <li><a href="files.html"><span>Files</span></a></li>
+ </ul></div>
+<div class="nav">
+<table cellspacing="0" cellpadding="0" border="0">
+ <tr>
+ <td valign="top">
+ <div class="navtab">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="class_fdo_i_create_s_d_f_file_bda73a210df146335a62e933ebe19948.html#bda73a210df146335a62e933ebe19948">SetSpatialContextName</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="bda73a210df146335a62e933ebe19948"></a><!-- doxytag: member="FdoICreateSDFFile::SetSpatialContextName" ref="bda73a210df146335a62e933ebe19948" args="(FdoString *name)=0" --><p>
+<table class="mdTable" cellpadding="2" cellspacing="0">
+ <tr>
+ <td class="mdRow">
+ <table cellpadding="0" cellspacing="0" border="0">
+ <tr>
+ <td class="md" nowrap valign="top">virtual FDO_API void FdoICreateSDFFile::SetSpatialContextName </td>
+ <td class="mdname1" valign="top" nowrap> <em>name</em> </td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+<table cellspacing="5" cellpadding="0" border="0">
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+Sets the name of the spatial context as a string.
+<p>
+ <tr><td valign="top"></td><td valign="top"><em>name</em> </td><td>Input the name of the spatial context.</td></tr>
+ </table>
+</dl>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file_e92b777da3c498180dd72fe4629ee788.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file_e92b777da3c498180dd72fe4629ee788.html?view=auto&rev=97
--- (empty file)
+++ trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file_e92b777da3c498180dd72fe4629ee788.html 2006-12-04 18:49:20+0000
@@ -0,0 +1,97 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="nav">
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="class_fdo_i_create_s_d_f_file_e92b777da3c498180dd72fe4629ee788.html#e92b777da3c498180dd72fe4629ee788">SetFileName</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="e92b777da3c498180dd72fe4629ee788"></a><!-- doxytag: member="FdoICreateSDFFile::SetFileName" ref="e92b777da3c498180dd72fe4629ee788" args="(FdoString *name)=0" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">virtual FDO_API void FdoICreateSDFFile::SetFileName </td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+Sets the name of the SDF+ file being created. The name must be a fully qualified absolute path.
+<p>
+ <tr><td valign="top"></td><td valign="top"><em>name</em> </td><td>The fully qualified SDF+ file name.</td></tr>
+ </table>
+</dl>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SDF/class_sdf_compare_handler-members.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/class_sdf_compare_handler-members.html?view=auto&rev=97
--- (empty file)
+++ trunk/www/docs/SDF/class_sdf_compare_handler-members.html 2006-12-04 18:49:20+0000
@@ -0,0 +1,53 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<h1>SdfCompareHandler Member List</h1>This is the complete list of members for <a class="el" href="class_sdf_compare_handler.html">SdfCompareHandler</a>, including all inherited members.<p><table>
+ <tr class="memlist"><td><a class="el" href="class_sdf_compare_handler_4b9fe2c6a37153efe808fbe7b9cfac39.html#4b9fe2c6a37153efe808fbe7b9cfac39">Compare</a>(const wchar_t *name, double val1, double val2)</td><td><a class="el" href="class_sdf_compare_handler.html">SdfCompareHandler</a></td><td><code> [virtual]</code></td></tr>
+ <tr class="memlist"><td><a class="el" href="class_sdf_compare_handler_e99c60fe9321858c35f204003e06954c.html#e99c60fe9321858c35f204003e06954c">Compare</a>(const wchar_t *name, float val1, float val2)</td><td><a class="el" href="class_sdf_compare_handler.html">SdfCompareHandler</a></td><td><code> [virtual]</code></td></tr>
+ <tr class="memlist"><td><a class="el" href="class_sdf_compare_handler_fba0af521a5201a71547bce66c36f583.html#fba0af521a5201a71547bce66c36f583">Compare</a>(const wchar_t *name, FdoInt64 val1, FdoInt64 val2)</td><td><a class="el" href="class_sdf_compare_handler.html">SdfCompareHandler</a></td><td><code> [virtual]</code></td></tr>
+ <tr class="memlist"><td><a class="el" href="class_sdf_compare_handler_3a1cda4006166f838c9c90dbbd16daf5.html#3a1cda4006166f838c9c90dbbd16daf5">Compare</a>(const wchar_t *name, FdoInt32 val1, FdoInt32 val2)</td><td><a class="el" href="class_sdf_compare_handler.html">SdfCompareHandler</a></td><td><code> [virtual]</code></td></tr>
+ <tr class="memlist"><td><a class="el" href="class_sdf_compare_handler_25efcd708f7d73df47e3f592a4dc9df2.html#25efcd708f7d73df47e3f592a4dc9df2">Compare</a>(const wchar_t *name, FdoInt16 val1, FdoInt16 val2)</td><td><a class="el" href="class_sdf_compare_handler.html">SdfCompareHandler</a></td><td><code> [virtual]</code></td></tr>
+ <tr class="memlist"><td><a class="el" href="class_sdf_compare_handler_3ade9dcf05112bb16590f695c022a474.html#3ade9dcf05112bb16590f695c022a474">Compare</a>(const wchar_t *name, const wchar_t *val1, const wchar_t *val2)</td><td><a class="el" href="class_sdf_compare_handler.html">SdfCompareHandler</a></td><td><code> [virtual]</code></td></tr>
+ <tr class="memlist"><td><a class="el" href="class_sdf_compare_handler_5da8124ec6d48c42207912cb1004168c.html#5da8124ec6d48c42207912cb1004168c">Compare</a>(const wchar_t *name, FdoDateTime val1, FdoDateTime val2)</td><td><a class="el" href="class_sdf_compare_handler.html">SdfCompareHandler</a></td><td><code> [virtual]</code></td></tr>
+ <tr class="memlist"><td><a class="el" href="class_sdf_compare_handler_fb5771764ec97dd9888a0d243d01886b.html#fb5771764ec97dd9888a0d243d01886b">Compare</a>(const wchar_t *name, unsigned char val1, unsigned char val2)</td><td><a class="el" href="class_sdf_compare_handler.html">SdfCompareHandler</a></td><td><code> [virtual]</code></td></tr>
+ <tr class="memlist"><td><a class="el" href="class_sdf_compare_handler_dd5c70a33541eb9eabc2d19021a768fd.html#dd5c70a33541eb9eabc2d19021a768fd">Create</a>()</td><td><a class="el" href="class_sdf_compare_handler.html">SdfCompareHandler</a></td><td><code> [static]</code></td></tr>
+ <tr class="memlist"><td><a class="el" href="class_sdf_compare_handler_d3a014c324bcbb6e2eccbf17ee9b43f3.html#d3a014c324bcbb6e2eccbf17ee9b43f3">Dispose</a>()</td><td><a class="el" href="class_sdf_compare_handler.html">SdfCompareHandler</a></td><td><code> [inline, protected, virtual]</code></td></tr>
+ <tr class="memlist"><td><a class="el" href="class_sdf_compare_handler_c1e1a5c47894aa43ada963c4cb84b980.html#c1e1a5c47894aa43ada963c4cb84b980">~SdfCompareHandler</a>()</td><td><a class="el" href="class_sdf_compare_handler.html">SdfCompareHandler</a></td><td><code> [protected, virtual]</code></td></tr>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SDF/class_sdf_compare_handler.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/class_sdf_compare_handler.html?view=auto&rev=97
--- (empty file)
+++ trunk/www/docs/SDF/class_sdf_compare_handler.html 2006-12-04 18:49:20+0000
@@ -0,0 +1,87 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<h1>SdfCompareHandler Class Reference</h1><!-- doxytag: class="SdfCompareHandler" --><code>#include <<a class="el" href="_sdf_compare_handler_8h-source.html">SdfCompareHandler.h</a>></code>
+<p>
+<a href="class_sdf_compare_handler-members.html">List of all members.</a><hr><a name="_details"></a><h2>Detailed Description</h2>
+<p>
+<p>
+Definition at line <a class="el" href="_sdf_compare_handler_8h-source.html#l00029">29</a> of file <a class="el" href="_sdf_compare_handler_8h-source.html">SdfCompareHandler.h</a>.<table border="0" cellpadding="0" cellspacing="0">
+<tr><td></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">virtual int </td><td class="memItemRight" valign="bottom"><a class="el" href="class_sdf_compare_handler_fb5771764ec97dd9888a0d243d01886b.html#fb5771764ec97dd9888a0d243d01886b">Compare</a> (const wchar_t *name, unsigned char val1, unsigned char val2)</td></tr>
+<tr><td class="mdescLeft"> </td><td class="mdescRight">Compares unsigned char values. <a href="#fb5771764ec97dd9888a0d243d01886b"></a><br></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">virtual int </td><td class="memItemRight" valign="bottom"><a class="el" href="class_sdf_compare_handler_5da8124ec6d48c42207912cb1004168c.html#5da8124ec6d48c42207912cb1004168c">Compare</a> (const wchar_t *name, FdoDateTime val1, FdoDateTime val2)</td></tr>
+<tr><td class="mdescLeft"> </td><td class="mdescRight">Compares date time values. <a href="#5da8124ec6d48c42207912cb1004168c"></a><br></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">virtual int </td><td class="memItemRight" valign="bottom"><a class="el" href="class_sdf_compare_handler_3ade9dcf05112bb16590f695c022a474.html#3ade9dcf05112bb16590f695c022a474">Compare</a> (const wchar_t *name, const wchar_t *val1, const wchar_t *val2)</td></tr>
+<tr><td class="mdescLeft"> </td><td class="mdescRight">Compares string values. <a href="#3ade9dcf05112bb16590f695c022a474"></a><br></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">virtual int </td><td class="memItemRight" valign="bottom"><a class="el" href="class_sdf_compare_handler_25efcd708f7d73df47e3f592a4dc9df2.html#25efcd708f7d73df47e3f592a4dc9df2">Compare</a> (const wchar_t *name, FdoInt16 val1, FdoInt16 val2)</td></tr>
+<tr><td class="mdescLeft"> </td><td class="mdescRight">Compares int16 values. <a href="#25efcd708f7d73df47e3f592a4dc9df2"></a><br></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">virtual int </td><td class="memItemRight" valign="bottom"><a class="el" href="class_sdf_compare_handler_3a1cda4006166f838c9c90dbbd16daf5.html#3a1cda4006166f838c9c90dbbd16daf5">Compare</a> (const wchar_t *name, FdoInt32 val1, FdoInt32 val2)</td></tr>
+<tr><td class="mdescLeft"> </td><td class="mdescRight">Compares int32 values. <a href="#3a1cda4006166f838c9c90dbbd16daf5"></a><br></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">virtual int </td><td class="memItemRight" valign="bottom"><a class="el" href="class_sdf_compare_handler_fba0af521a5201a71547bce66c36f583.html#fba0af521a5201a71547bce66c36f583">Compare</a> (const wchar_t *name, FdoInt64 val1, FdoInt64 val2)</td></tr>
+<tr><td class="mdescLeft"> </td><td class="mdescRight">Compares int64 values. <a href="#fba0af521a5201a71547bce66c36f583"></a><br></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">virtual int </td><td class="memItemRight" valign="bottom"><a class="el" href="class_sdf_compare_handler_e99c60fe9321858c35f204003e06954c.html#e99c60fe9321858c35f204003e06954c">Compare</a> (const wchar_t *name, float val1, float val2)</td></tr>
+<tr><td class="mdescLeft"> </td><td class="mdescRight">Compares float values. <a href="#e99c60fe9321858c35f204003e06954c"></a><br></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">virtual int </td><td class="memItemRight" valign="bottom"><a class="el" href="class_sdf_compare_handler_4b9fe2c6a37153efe808fbe7b9cfac39.html#4b9fe2c6a37153efe808fbe7b9cfac39">Compare</a> (const wchar_t *name, double val1, double val2)</td></tr>
+<tr><td class="mdescLeft"> </td><td class="mdescRight">Compares double values. <a href="#4b9fe2c6a37153efe808fbe7b9cfac39"></a><br></td></tr>
+<tr><td colspan="2"><br><h2>Static Public Member Functions</h2></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">static <a class="el" href="class_sdf_compare_handler.html">SdfCompareHandler</a> * </td><td class="memItemRight" valign="bottom"><a class="el" href="class_sdf_compare_handler_dd5c70a33541eb9eabc2d19021a768fd.html#dd5c70a33541eb9eabc2d19021a768fd">Create</a> ()</td></tr>
+<tr><td class="mdescLeft"> </td><td class="mdescRight">The factory function that can be used to create new instance of this class. <a href="#dd5c70a33541eb9eabc2d19021a768fd"></a><br></td></tr>
+<tr><td colspan="2"><br><h2>Protected Member Functions</h2></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">virtual void </td><td class="memItemRight" valign="bottom"><a class="el" href="class_sdf_compare_handler_d3a014c324bcbb6e2eccbf17ee9b43f3.html#d3a014c324bcbb6e2eccbf17ee9b43f3">Dispose</a> ()</td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">virtual </td><td class="memItemRight" valign="bottom"><a class="el" href="class_sdf_compare_handler_c1e1a5c47894aa43ada963c4cb84b980.html#c1e1a5c47894aa43ada963c4cb84b980">~SdfCompareHandler</a> ()</td></tr>
+</table>
+<li><a class="el" href="_sdf_compare_handler_8h-source.html">SdfCompareHandler.h</a></ul>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SDF/class_sdf_compare_handler_25efcd708f7d73df47e3f592a4dc9df2.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/class_sdf_compare_handler_25efcd708f7d73df47e3f592a4dc9df2.html?view=auto&rev=97
--- (empty file)
+++ trunk/www/docs/SDF/class_sdf_compare_handler_25efcd708f7d73df47e3f592a4dc9df2.html 2006-12-04 18:49:20+0000
@@ -0,0 +1,112 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="nav">
+<a class="el" href="class_sdf_compare_handler.html">SdfCompareHandler</a></div>
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindex" href="class_sdf_compare_handler_4b9fe2c6a37153efe808fbe7b9cfac39.html#4b9fe2c6a37153efe808fbe7b9cfac39">Compare</a></td></tr>
+ <tr><td class="navtab"><a class="qindex" href="class_sdf_compare_handler_e99c60fe9321858c35f204003e06954c.html#e99c60fe9321858c35f204003e06954c">Compare</a></td></tr>
+ <tr><td class="navtab"><a class="qindex" href="class_sdf_compare_handler_fba0af521a5201a71547bce66c36f583.html#fba0af521a5201a71547bce66c36f583">Compare</a></td></tr>
+ <tr><td class="navtab"><a class="qindex" href="class_sdf_compare_handler_3a1cda4006166f838c9c90dbbd16daf5.html#3a1cda4006166f838c9c90dbbd16daf5">Compare</a></td></tr>
+ <tr><td class="navtab"><a class="qindexHL" href="class_sdf_compare_handler_25efcd708f7d73df47e3f592a4dc9df2.html#25efcd708f7d73df47e3f592a4dc9df2">Compare</a></td></tr>
+ <tr><td class="navtab"><a class="qindex" href="class_sdf_compare_handler_3ade9dcf05112bb16590f695c022a474.html#3ade9dcf05112bb16590f695c022a474">Compare</a></td></tr>
+ <tr><td class="navtab"><a class="qindex" href="class_sdf_compare_handler_5da8124ec6d48c42207912cb1004168c.html#5da8124ec6d48c42207912cb1004168c">Compare</a></td></tr>
+ <tr><td class="navtab"><a class="qindex" href="class_sdf_compare_handler_fb5771764ec97dd9888a0d243d01886b.html#fb5771764ec97dd9888a0d243d01886b">Compare</a></td></tr>
+ <tr><td class="navtab"><a class="qindex" href="class_sdf_compare_handler_dd5c70a33541eb9eabc2d19021a768fd.html#dd5c70a33541eb9eabc2d19021a768fd">Create</a></td></tr>
+ <tr><td class="navtab"><a class="qindex" href="class_sdf_compare_handler_d3a014c324bcbb6e2eccbf17ee9b43f3.html#d3a014c324bcbb6e2eccbf17ee9b43f3">Dispose</a></td></tr>
+ <tr><td class="navtab"><a class="qindex" href="class_sdf_compare_handler_c1e1a5c47894aa43ada963c4cb84b980.html#c1e1a5c47894aa43ada963c4cb84b980">~SdfCompareHandler</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="25efcd708f7d73df47e3f592a4dc9df2"></a><!-- doxytag: member="SdfCompareHandler::Compare" ref="25efcd708f7d73df47e3f592a4dc9df2" args="(const wchar_t *name, FdoInt16 val1, FdoInt16 val2)" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">virtual int SdfCompareHandler::Compare </td>
+ <td class="md" nowrap valign="top">const wchar_t * </td>
+ <td class="mdname" nowrap> <em>name</em>, </td>
+ </tr>
+ <tr>
+ <td class="md" nowrap align="right"></td>
+ <td class="md"></td>
+ <td class="md" nowrap>FdoInt16 </td>
+ <td class="mdname" nowrap> <em>val1</em>, </td>
+ </tr>
+ <tr>
+ <td class="mdname" nowrap> <em>val2</em></td>
+ </tr>
+ <tr>
+ <td class="md">) </td>
+ <td class="md" colspan="2"><code> [virtual]</code></td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+Compares int16 values.
+<p>
+ <tr><td valign="top"></td><td valign="top"><em>name</em> </td><td>Is the property name.</td></tr>
+ <tr><td valign="top"></td><td valign="top"><em>val1</em> </td><td>Is the value of the first object.</td></tr>
+ <tr><td valign="top"></td><td valign="top"><em>val1</em> </td><td>Is the value of the second object.</td></tr>
+ </table>
+</dl>
+<dl compact><dt><b>Returns:</b></dt><dd>Returns a positive value if val1 is greater than val2, negative if val1 is smaller than val2 or zero if both val1 and val2 are equal.</dd></dl>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SDF/class_sdf_compare_handler_3a1cda4006166f838c9c90dbbd16daf5.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/class_sdf_compare_handler_3a1cda4006166f838c9c90dbbd16daf5.html?view=auto&rev=97
--- (empty file)
+++ trunk/www/docs/SDF/class_sdf_compare_handler_3a1cda4006166f838c9c90dbbd16daf5.html 2006-12-04 18:49:20+0000
@@ -0,0 +1,112 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="nav">
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="class_sdf_compare_handler_3a1cda4006166f838c9c90dbbd16daf5.html#3a1cda4006166f838c9c90dbbd16daf5">Compare</a></td></tr>
+ <tr><td class="navtab"><a class="qindex" href="class_sdf_compare_handler_25efcd708f7d73df47e3f592a4dc9df2.html#25efcd708f7d73df47e3f592a4dc9df2">Compare</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="3a1cda4006166f838c9c90dbbd16daf5"></a><!-- doxytag: member="SdfCompareHandler::Compare" ref="3a1cda4006166f838c9c90dbbd16daf5" args="(const wchar_t *name, FdoInt32 val1, FdoInt32 val2)" --><p>
+ <tr>
+ <tr>
+ </tr>
+ <tr>
+ <td class="md" nowrap>FdoInt32 </td>
+ </tr>
+ <tr>
+ </tr>
+ <tr>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+Compares int32 values.
+<p>
+ </table>
+</dl>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SDF/class_sdf_compare_handler_3ade9dcf05112bb16590f695c022a474.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/class_sdf_compare_handler_3ade9dcf05112bb16590f695c022a474.html?view=auto&rev=97
--- (empty file)
+++ trunk/www/docs/SDF/class_sdf_compare_handler_3ade9dcf05112bb16590f695c022a474.html 2006-12-04 18:49:20+0000
@@ -0,0 +1,112 @@
+<html>
+ <head>
+ </head>
+ <table width="100%" border="0">
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="nav">
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="class_sdf_compare_handler_3ade9dcf05112bb16590f695c022a474.html#3ade9dcf05112bb16590f695c022a474">Compare</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="3ade9dcf05112bb16590f695c022a474"></a><!-- doxytag: member="SdfCompareHandler::Compare" ref="3ade9dcf05112bb16590f695c022a474" args="(const wchar_t *name, const wchar_t *val1, const wchar_t *val2)" --><p>
+ <tr>
+ <tr>
+ </tr>
+ <tr>
+ <td class="md" nowrap>const wchar_t * </td>
+ </tr>
+ <tr>
+ </tr>
+ <tr>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+Compares string values.
+<p>
+ </table>
+</dl>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SDF/class_sdf_compare_handler_4b9fe2c6a37153efe808fbe7b9cfac39.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/class_sdf_compare_handler_4b9fe2c6a37153efe808fbe7b9cfac39.html?view=auto&rev=97
--- (empty file)
+++ trunk/www/docs/SDF/class_sdf_compare_handler_4b9fe2c6a37153efe808fbe7b9cfac39.html 2006-12-04 18:49:20+0000
@@ -0,0 +1,112 @@
+<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN" "http://www.w3.org/TR/html4/loose.dtd">
+<html>
+ <head>
+ <meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
+ <title>OSGeo FDO Provider for SDF API Reference</title>
+ <link href="custom.css" rel="stylesheet" type="text/css">
+ <link href="tabs.css" rel="stylesheet" type="text/css">
+ </head>
+ <body bgcolor="#FFFFFF">
+ <tr>
+ <td><b>API Reference<b></td>
+ <td align="right"><b>OSGeo FDO Provider for SDF<b></td>
+ </tr>
+ </table>
+<!-- End of: header.html -->
+<!-- Generated by Doxygen 1.4.6-NO -->
+<div class="tabs">
+ <ul>
+ <li><a href="main.html"><span>Main Page</span></a></li>
+ <li><a href="classes.html"><span>Classes</span></a></li>
+ </ul></div>
+<div class="nav">
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="class_sdf_compare_handler_4b9fe2c6a37153efe808fbe7b9cfac39.html#4b9fe2c6a37153efe808fbe7b9cfac39">Compare</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="4b9fe2c6a37153efe808fbe7b9cfac39"></a><!-- doxytag: member="SdfCompareHandler::Compare" ref="4b9fe2c6a37153efe808fbe7b9cfac39" args="(const wchar_t *name, double val1, double val2)" --><p>
+ <tr>
+ <tr>
+ </tr>
+ <tr>
+ <td class="md" nowrap>double </td>
+ </tr>
+ <tr>
+ </tr>
+ <tr>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+Compares double values.
+<p>
+ </table>
+</dl>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SDF/class_sdf_compare_handler_5da8124ec6d48c42207912cb1004168c.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/class_sdf_compare_handler_5da8124ec6d48c42207912cb1004168c.html?view=auto&rev=97
--- (empty file)
+++ trunk/www/docs/SDF/class_sdf_compare_handler_5da8124ec6d48c42207912cb1004168c.html 2006-12-04 18:49:20+0000
@@ -0,0 +1,112 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="nav">
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="class_sdf_compare_handler_5da8124ec6d48c42207912cb1004168c.html#5da8124ec6d48c42207912cb1004168c">Compare</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="5da8124ec6d48c42207912cb1004168c"></a><!-- doxytag: member="SdfCompareHandler::Compare" ref="5da8124ec6d48c42207912cb1004168c" args="(const wchar_t *name, FdoDateTime val1, FdoDateTime val2)" --><p>
+ <tr>
+ <tr>
+ </tr>
+ <tr>
+ <td class="md" nowrap>FdoDateTime </td>
+ </tr>
+ <tr>
+ </tr>
+ <tr>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+Compares date time values.
+<p>
+ </table>
+</dl>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SDF/class_sdf_compare_handler_c1e1a5c47894aa43ada963c4cb84b980.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/class_sdf_compare_handler_c1e1a5c47894aa43ada963c4cb84b980.html?view=auto&rev=97
--- (empty file)
+++ trunk/www/docs/SDF/class_sdf_compare_handler_c1e1a5c47894aa43ada963c4cb84b980.html 2006-12-04 18:49:20+0000
@@ -0,0 +1,86 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="nav">
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="class_sdf_compare_handler_c1e1a5c47894aa43ada963c4cb84b980.html#c1e1a5c47894aa43ada963c4cb84b980">~SdfCompareHandler</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="c1e1a5c47894aa43ada963c4cb84b980"></a><!-- doxytag: member="SdfCompareHandler::~SdfCompareHandler" ref="c1e1a5c47894aa43ada963c4cb84b980" args="()" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">virtual SdfCompareHandler::~SdfCompareHandler </td>
+ <td class="md" nowrap><code> [protected, virtual]</code></td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SDF/class_sdf_compare_handler_d3a014c324bcbb6e2eccbf17ee9b43f3.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/class_sdf_compare_handler_d3a014c324bcbb6e2eccbf17ee9b43f3.html?view=auto&rev=97
--- (empty file)
+++ trunk/www/docs/SDF/class_sdf_compare_handler_d3a014c324bcbb6e2eccbf17ee9b43f3.html 2006-12-04 18:49:20+0000
@@ -0,0 +1,88 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="nav">
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="class_sdf_compare_handler_d3a014c324bcbb6e2eccbf17ee9b43f3.html#d3a014c324bcbb6e2eccbf17ee9b43f3">Dispose</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="d3a014c324bcbb6e2eccbf17ee9b43f3"></a><!-- doxytag: member="SdfCompareHandler::Dispose" ref="d3a014c324bcbb6e2eccbf17ee9b43f3" args="()" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">virtual void SdfCompareHandler::Dispose </td>
+ <td class="md" nowrap><code> [inline, protected, virtual]</code></td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+<p>
+Definition at line <a class="el" href="_sdf_compare_handler_8h-source.html#l00038">38</a> of file <a class="el" href="_sdf_compare_handler_8h-source.html">SdfCompareHandler.h</a>. </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SDF/class_sdf_compare_handler_dd5c70a33541eb9eabc2d19021a768fd.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/class_sdf_compare_handler_dd5c70a33541eb9eabc2d19021a768fd.html?view=auto&rev=97
--- (empty file)
+++ trunk/www/docs/SDF/class_sdf_compare_handler_dd5c70a33541eb9eabc2d19021a768fd.html 2006-12-04 18:49:20+0000
@@ -0,0 +1,89 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="nav">
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="class_sdf_compare_handler_dd5c70a33541eb9eabc2d19021a768fd.html#dd5c70a33541eb9eabc2d19021a768fd">Create</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="dd5c70a33541eb9eabc2d19021a768fd"></a><!-- doxytag: member="SdfCompareHandler::Create" ref="dd5c70a33541eb9eabc2d19021a768fd" args="()" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">static <a class="el" href="class_sdf_compare_handler.html">SdfCompareHandler</a>* SdfCompareHandler::Create </td>
+ <td class="md" nowrap><code> [static]</code></td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+The factory function that can be used to create new instance of this class.
+<p>
+<dl compact><dt><b>Returns:</b></dt><dd>Returns a new instance of theSdfCompareHandler class.</dd></dl>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SDF/class_sdf_compare_handler_e99c60fe9321858c35f204003e06954c.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/class_sdf_compare_handler_e99c60fe9321858c35f204003e06954c.html?view=auto&rev=97
--- (empty file)
+++ trunk/www/docs/SDF/class_sdf_compare_handler_e99c60fe9321858c35f204003e06954c.html 2006-12-04 18:49:20+0000
@@ -0,0 +1,112 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="nav">
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="class_sdf_compare_handler_e99c60fe9321858c35f204003e06954c.html#e99c60fe9321858c35f204003e06954c">Compare</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="e99c60fe9321858c35f204003e06954c"></a><!-- doxytag: member="SdfCompareHandler::Compare" ref="e99c60fe9321858c35f204003e06954c" args="(const wchar_t *name, float val1, float val2)" --><p>
+ <tr>
+ <tr>
+ </tr>
+ <tr>
+ <td class="md" nowrap>float </td>
+ </tr>
+ <tr>
+ </tr>
+ <tr>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+Compares float values.
+<p>
+ </table>
+</dl>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SDF/class_sdf_compare_handler_fb5771764ec97dd9888a0d243d01886b.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/class_sdf_compare_handler_fb5771764ec97dd9888a0d243d01886b.html?view=auto&rev=97
--- (empty file)
+++ trunk/www/docs/SDF/class_sdf_compare_handler_fb5771764ec97dd9888a0d243d01886b.html 2006-12-04 18:49:20+0000
@@ -0,0 +1,112 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="nav">
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="class_sdf_compare_handler_fb5771764ec97dd9888a0d243d01886b.html#fb5771764ec97dd9888a0d243d01886b">Compare</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="fb5771764ec97dd9888a0d243d01886b"></a><!-- doxytag: member="SdfCompareHandler::Compare" ref="fb5771764ec97dd9888a0d243d01886b" args="(const wchar_t *name, unsigned char val1, unsigned char val2)" --><p>
+ <tr>
+ <tr>
+ </tr>
+ <tr>
+ <td class="md" nowrap>unsigned char </td>
+ </tr>
+ <tr>
+ </tr>
+ <tr>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+Compares unsigned char values.
+<p>
+ </table>
+</dl>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ <td align="right"><font size="-2"><a href="mailto:isd.docs at autodesk.com&subject=FDO%20Provider%20for%20SDF%20API%20documentation">Comments?</a></font></td>
+ <!-- The logo can go in another cell, when we get one -->
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SDF/class_sdf_compare_handler_fba0af521a5201a71547bce66c36f583.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/class_sdf_compare_handler_fba0af521a5201a71547bce66c36f583.html?view=auto&rev=97
--- (empty file)
+++ trunk/www/docs/SDF/class_sdf_compare_handler_fba0af521a5201a71547bce66c36f583.html 2006-12-04 18:49:20+0000
@@ -0,0 +1,112 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="nav">
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="class_sdf_compare_handler_fba0af521a5201a71547bce66c36f583.html#fba0af521a5201a71547bce66c36f583">Compare</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="fba0af521a5201a71547bce66c36f583"></a><!-- doxytag: member="SdfCompareHandler::Compare" ref="fba0af521a5201a71547bce66c36f583" args="(const wchar_t *name, FdoInt64 val1, FdoInt64 val2)" --><p>
+ <tr>
+ <tr>
+ </tr>
+ <tr>
+ <td class="md" nowrap>FdoInt64 </td>
+ </tr>
+ <tr>
+ </tr>
+ <tr>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+Compares int64 values.
+<p>
+ </table>
+</dl>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SDF/class_sdf_i_extended_select-members.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/class_sdf_i_extended_select-members.html?view=auto&rev=97
--- (empty file)
+++ trunk/www/docs/SDF/class_sdf_i_extended_select-members.html 2006-12-04 18:49:20+0000
@@ -0,0 +1,48 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ <li id="current"><a href="classes.html"><span>Classes</span></a></li>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ <li><a href="classes.html"><span>Alphabetical List</span></a></li>
+ <li><a href="annotated.html"><span>Class List</span></a></li>
+ <li><a href="hierarchy.html"><span>Class Hierarchy</span></a></li>
+ <li><a href="functions.html"><span>Class Members</span></a></li>
+ </ul></div>
+<h1>SdfIExtendedSelect Member List</h1>This is the complete list of members for <a class="el" href="class_sdf_i_extended_select.html">SdfIExtendedSelect</a>, including all inherited members.<p><table>
+ <tr class="memlist"><td><a class="el" href="class_sdf_i_extended_select_56fb99cd7bef0a7528cf1dd408d32e16.html#56fb99cd7bef0a7528cf1dd408d32e16">ClearOrderingOptions</a>()=0</td><td><a class="el" href="class_sdf_i_extended_select.html">SdfIExtendedSelect</a></td><td><code> [pure virtual]</code></td></tr>
+ <tr class="memlist"><td><a class="el" href="class_sdf_i_extended_select_7094d0597a2dec8f759b553af3c5aebd.html#7094d0597a2dec8f759b553af3c5aebd">ExecuteScrollable</a>()=0</td><td><a class="el" href="class_sdf_i_extended_select.html">SdfIExtendedSelect</a></td><td><code> [pure virtual]</code></td></tr>
+ <tr class="memlist"><td><a class="el" href="class_sdf_i_extended_select_d10d84246bb47e87adb334fd6d5e8836.html#d10d84246bb47e87adb334fd6d5e8836">ExecuteScrollable</a>(const wchar_t *sdfCacheFile, FdoDataPropertyDefinitionCollection *extendedProps, FdoPropertyValueCollection *extendedDefaults)=0</td><td><a class="el" href="class_sdf_i_extended_select.html">SdfIExtendedSelect</a></td><td><code> [pure virtual]</code></td></tr>
+ <tr class="memlist"><td><a class="el" href="class_sdf_i_extended_select_a9e4db2cb4a126bfd03259073ef74719.html#a9e4db2cb4a126bfd03259073ef74719">GetOrderingOption</a>(FdoString *propertyName)=0</td><td><a class="el" href="class_sdf_i_extended_select.html">SdfIExtendedSelect</a></td><td><code> [pure virtual]</code></td></tr>
+ <tr class="memlist"><td><a class="el" href="class_sdf_i_extended_select_69a9441cd4ada6b204a5b3ccfde49eab.html#69a9441cd4ada6b204a5b3ccfde49eab">SetCompareHandler</a>(SdfCompareHandler *handler)=0</td><td><a class="el" href="class_sdf_i_extended_select.html">SdfIExtendedSelect</a></td><td><code> [pure virtual]</code></td></tr>
+ <tr class="memlist"><td><a class="el" href="class_sdf_i_extended_select_8921a5db2a527690f4d5592daa014be8.html#8921a5db2a527690f4d5592daa014be8">SetOrderingOption</a>(FdoString *propertyName, FdoOrderingOption option)=0</td><td><a class="el" href="class_sdf_i_extended_select.html">SdfIExtendedSelect</a></td><td><code> [pure virtual]</code></td></tr>
+</table><!-- footer.html -->
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SDF/class_sdf_i_extended_select.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/class_sdf_i_extended_select.html?view=auto&rev=97
--- (empty file)
+++ trunk/www/docs/SDF/class_sdf_i_extended_select.html 2006-12-04 18:49:20+0000
@@ -0,0 +1,72 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<h1>SdfIExtendedSelect Class Reference</h1><!-- doxytag: class="SdfIExtendedSelect" --><code>#include <<a class="el" href="_i_extended_select_8h-source.html">IExtendedSelect.h</a>></code>
+<p>
+<a href="class_sdf_i_extended_select-members.html">List of all members.</a><hr><a name="_details"></a><h2>Detailed Description</h2>
+<p>
+<p>
+Definition at line <a class="el" href="_i_extended_select_8h-source.html#l00025">25</a> of file <a class="el" href="_i_extended_select_8h-source.html">IExtendedSelect.h</a>.<table border="0" cellpadding="0" cellspacing="0">
+<tr><td></td></tr>
+<tr><td colspan="2"><br><h2>Public Member Functions</h2></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">virtual void </td><td class="memItemRight" valign="bottom"><a class="el" href="class_sdf_i_extended_select_56fb99cd7bef0a7528cf1dd408d32e16.html#56fb99cd7bef0a7528cf1dd408d32e16">ClearOrderingOptions</a> ()=0</td></tr>
+<tr><td class="mdescLeft"> </td><td class="mdescRight">This method clears the internal list of property/ordering option list and re-sets the ordering option for all the ordering properties to the default FdoOrderingOption_Ascending or to the ordering option specified by the FdoIBaseSelect interface. <a href="#56fb99cd7bef0a7528cf1dd408d32e16"></a><br></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">virtual <a class="el" href="class_sdf_i_scrollable_feature_reader.html">SdfIScrollableFeatureReader</a> * </td><td class="memItemRight" valign="bottom"><a class="el" href="class_sdf_i_extended_select_d10d84246bb47e87adb334fd6d5e8836.html#d10d84246bb47e87adb334fd6d5e8836">ExecuteScrollable</a> (const wchar_t *sdfCacheFile, FdoDataPropertyDefinitionCollection *extendedProps, FdoPropertyValueCollection *extendedDefaults)=0</td></tr>
+<tr><td class="mdescLeft"> </td><td class="mdescRight">Executes the select command and returns a <a class="el" href="class_sdf_i_scrollable_feature_reader.html">SdfIScrollableFeatureReader</a>. This method creates a temporary SDF file that contains the selected properties. If ordering is enabled, then the created temporary SDF file is sorted according to the ordering collection. In this case the sorting is file based where the SQLite BTree is used. <a href="#d10d84246bb47e87adb334fd6d5e8836"></a><br></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">virtual <a class="el" href="class_sdf_i_scrollable_feature_reader.html">SdfIScrollableFeatureReader</a> * </td><td class="memItemRight" valign="bottom"><a class="el" href="class_sdf_i_extended_select_7094d0597a2dec8f759b553af3c5aebd.html#7094d0597a2dec8f759b553af3c5aebd">ExecuteScrollable</a> ()=0</td></tr>
+<tr><td class="mdescLeft"> </td><td class="mdescRight">Executes the select command and returns a <a class="el" href="class_sdf_i_scrollable_feature_reader.html">SdfIScrollableFeatureReader</a>. If ordering is enabled, then the returned reader is sorted according to the ordering collection. This method perform sorting in memory and allocates an integer value for each row. <a href="#7094d0597a2dec8f759b553af3c5aebd"></a><br></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">virtual FdoOrderingOption </td><td class="memItemRight" valign="bottom"><a class="el" href="class_sdf_i_extended_select_a9e4db2cb4a126bfd03259073ef74719.html#a9e4db2cb4a126bfd03259073ef74719">GetOrderingOption</a> (FdoString *propertyName)=0</td></tr>
+<tr><td class="mdescLeft"> </td><td class="mdescRight">Gets the ordering option for a given property. <a href="#a9e4db2cb4a126bfd03259073ef74719"></a><br></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">virtual void </td><td class="memItemRight" valign="bottom"><a class="el" href="class_sdf_i_extended_select_69a9441cd4ada6b204a5b3ccfde49eab.html#69a9441cd4ada6b204a5b3ccfde49eab">SetCompareHandler</a> (<a class="el" href="class_sdf_compare_handler.html">SdfCompareHandler</a> *handler)=0</td></tr>
+<tr><td class="mdescLeft"> </td><td class="mdescRight">Set the compare handler. This method is used to override the default sdf compare handler. <a href="#69a9441cd4ada6b204a5b3ccfde49eab"></a><br></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">virtual void </td><td class="memItemRight" valign="bottom"><a class="el" href="class_sdf_i_extended_select_8921a5db2a527690f4d5592daa014be8.html#8921a5db2a527690f4d5592daa014be8">SetOrderingOption</a> (FdoString *propertyName, FdoOrderingOption option)=0</td></tr>
+<tr><td class="mdescLeft"> </td><td class="mdescRight">Set the ordering option of the selection. This is only used if the ordering collection is not empty. <a href="#8921a5db2a527690f4d5592daa014be8"></a><br></td></tr>
+</table>
+<hr>The documentation for this class was generated from the following file:<ul>
+<li><a class="el" href="_i_extended_select_8h-source.html">IExtendedSelect.h</a></ul>
+<!-- footer.html -->
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SDF/class_sdf_i_extended_select_56fb99cd7bef0a7528cf1dd408d32e16.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/class_sdf_i_extended_select_56fb99cd7bef0a7528cf1dd408d32e16.html?view=auto&rev=97
--- (empty file)
+++ trunk/www/docs/SDF/class_sdf_i_extended_select_56fb99cd7bef0a7528cf1dd408d32e16.html 2006-12-04 18:49:20+0000
@@ -0,0 +1,84 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="nav">
+<a class="el" href="class_sdf_i_extended_select.html">SdfIExtendedSelect</a></div>
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="class_sdf_i_extended_select_56fb99cd7bef0a7528cf1dd408d32e16.html#56fb99cd7bef0a7528cf1dd408d32e16">ClearOrderingOptions</a></td></tr>
+ <tr><td class="navtab"><a class="qindex" href="class_sdf_i_extended_select_7094d0597a2dec8f759b553af3c5aebd.html#7094d0597a2dec8f759b553af3c5aebd">ExecuteScrollable</a></td></tr>
+ <tr><td class="navtab"><a class="qindex" href="class_sdf_i_extended_select_d10d84246bb47e87adb334fd6d5e8836.html#d10d84246bb47e87adb334fd6d5e8836">ExecuteScrollable</a></td></tr>
+ <tr><td class="navtab"><a class="qindex" href="class_sdf_i_extended_select_a9e4db2cb4a126bfd03259073ef74719.html#a9e4db2cb4a126bfd03259073ef74719">GetOrderingOption</a></td></tr>
+ <tr><td class="navtab"><a class="qindex" href="class_sdf_i_extended_select_69a9441cd4ada6b204a5b3ccfde49eab.html#69a9441cd4ada6b204a5b3ccfde49eab">SetCompareHandler</a></td></tr>
+ <tr><td class="navtab"><a class="qindex" href="class_sdf_i_extended_select_8921a5db2a527690f4d5592daa014be8.html#8921a5db2a527690f4d5592daa014be8">SetOrderingOption</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="56fb99cd7bef0a7528cf1dd408d32e16"></a><!-- doxytag: member="SdfIExtendedSelect::ClearOrderingOptions" ref="56fb99cd7bef0a7528cf1dd408d32e16" args="()=0" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">virtual void SdfIExtendedSelect::ClearOrderingOptions </td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+This method clears the internal list of property/ordering option list and re-sets the ordering option for all the ordering properties to the default FdoOrderingOption_Ascending or to the ordering option specified by the FdoIBaseSelect interface.
+<p>
+<dl compact><dt><b>Returns:</b></dt><dd>Returns nothing.</dd></dl>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SDF/class_sdf_i_extended_select_69a9441cd4ada6b204a5b3ccfde49eab.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/class_sdf_i_extended_select_69a9441cd4ada6b204a5b3ccfde49eab.html?view=auto&rev=97
--- (empty file)
+++ trunk/www/docs/SDF/class_sdf_i_extended_select_69a9441cd4ada6b204a5b3ccfde49eab.html 2006-12-04 18:49:20+0000
@@ -0,0 +1,90 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="nav">
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindex" href="class_sdf_i_extended_select_56fb99cd7bef0a7528cf1dd408d32e16.html#56fb99cd7bef0a7528cf1dd408d32e16">ClearOrderingOptions</a></td></tr>
+ <tr><td class="navtab"><a class="qindexHL" href="class_sdf_i_extended_select_69a9441cd4ada6b204a5b3ccfde49eab.html#69a9441cd4ada6b204a5b3ccfde49eab">SetCompareHandler</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="69a9441cd4ada6b204a5b3ccfde49eab"></a><!-- doxytag: member="SdfIExtendedSelect::SetCompareHandler" ref="69a9441cd4ada6b204a5b3ccfde49eab" args="(SdfCompareHandler *handler)=0" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">virtual void SdfIExtendedSelect::SetCompareHandler </td>
+ <td class="md" valign="top">( </td>
+ <td class="md" nowrap valign="top"><a class="el" href="class_sdf_compare_handler.html">SdfCompareHandler</a> * </td>
+ <td class="mdname1" valign="top" nowrap> <em>handler</em> </td>
+ <td class="md" valign="top"> ) </td>
+ <td class="md" nowrap><code> [pure virtual]</code></td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+Set the compare handler. This method is used to override the default sdf compare handler.
+<p>
+ <tr><td valign="top"></td><td valign="top"><em>handler</em> </td><td>The compare handle that should be derived from the <a class="el" href="class_sdf_compare_handler.html">SdfCompareHandler</a> class.</td></tr>
+ </table>
+</dl>
+<dl compact><dt><b>Returns:</b></dt><dd>Returns nothing</dd></dl>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SDF/class_sdf_i_extended_select_7094d0597a2dec8f759b553af3c5aebd.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/class_sdf_i_extended_select_7094d0597a2dec8f759b553af3c5aebd.html?view=auto&rev=97
--- (empty file)
+++ trunk/www/docs/SDF/class_sdf_i_extended_select_7094d0597a2dec8f759b553af3c5aebd.html 2006-12-04 18:49:20+0000
@@ -0,0 +1,84 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="nav">
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="class_sdf_i_extended_select_7094d0597a2dec8f759b553af3c5aebd.html#7094d0597a2dec8f759b553af3c5aebd">ExecuteScrollable</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="7094d0597a2dec8f759b553af3c5aebd"></a><!-- doxytag: member="SdfIExtendedSelect::ExecuteScrollable" ref="7094d0597a2dec8f759b553af3c5aebd" args="()=0" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">virtual <a class="el" href="class_sdf_i_scrollable_feature_reader.html">SdfIScrollableFeatureReader</a>* SdfIExtendedSelect::ExecuteScrollable </td>
+ <td class="mdname1" valign="top" nowrap> </td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+Executes the select command and returns a <a class="el" href="class_sdf_i_scrollable_feature_reader.html">SdfIScrollableFeatureReader</a>. If ordering is enabled, then the returned reader is sorted according to the ordering collection. This method perform sorting in memory and allocates an integer value for each row.
+<p>
+<dl compact><dt><b>Returns:</b></dt><dd>Returns a <a class="el" href="class_sdf_i_scrollable_feature_reader.html">SdfIScrollableFeatureReader</a> object</dd></dl>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SDF/class_sdf_i_extended_select_8921a5db2a527690f4d5592daa014be8.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/class_sdf_i_extended_select_8921a5db2a527690f4d5592daa014be8.html?view=auto&rev=97
--- (empty file)
+++ trunk/www/docs/SDF/class_sdf_i_extended_select_8921a5db2a527690f4d5592daa014be8.html 2006-12-04 18:49:20+0000
@@ -0,0 +1,100 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="nav">
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="class_sdf_i_extended_select_8921a5db2a527690f4d5592daa014be8.html#8921a5db2a527690f4d5592daa014be8">SetOrderingOption</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="8921a5db2a527690f4d5592daa014be8"></a><!-- doxytag: member="SdfIExtendedSelect::SetOrderingOption" ref="8921a5db2a527690f4d5592daa014be8" args="(FdoString *propertyName, FdoOrderingOption option)=0" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">virtual void SdfIExtendedSelect::SetOrderingOption </td>
+ <td class="mdname" nowrap> <em>propertyName</em>, </td>
+ </tr>
+ <tr>
+ <td class="md" nowrap>FdoOrderingOption </td>
+ <td class="mdname" nowrap> <em>option</em></td>
+ </tr>
+ <tr>
+ <td class="md" colspan="2"><code> [pure virtual]</code></td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+Set the ordering option of the selection. This is only used if the ordering collection is not empty.
+<p>
+<dl compact><dt><b>Parameters:</b></dt><dd>
+ <tr><td valign="top"></td><td valign="top"><em>propertyName</em> </td><td>Is the property name for which the ordering should be applied. This property should be in the ordering collection.</td></tr>
+ <tr><td valign="top"></td><td valign="top"><em>option</em> </td><td>Is the ordering option and should be set to one of FdoOrderingOption_Ascending or FdoOrderingOption_Descending. FdoOrderingOption_Ascending is the default value.</td></tr>
+ </table>
+</dl>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SDF/class_sdf_i_extended_select_a9e4db2cb4a126bfd03259073ef74719.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/class_sdf_i_extended_select_a9e4db2cb4a126bfd03259073ef74719.html?view=auto&rev=97
--- (empty file)
+++ trunk/www/docs/SDF/class_sdf_i_extended_select_a9e4db2cb4a126bfd03259073ef74719.html 2006-12-04 18:49:20+0000
@@ -0,0 +1,90 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="nav">
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="class_sdf_i_extended_select_a9e4db2cb4a126bfd03259073ef74719.html#a9e4db2cb4a126bfd03259073ef74719">GetOrderingOption</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="a9e4db2cb4a126bfd03259073ef74719"></a><!-- doxytag: member="SdfIExtendedSelect::GetOrderingOption" ref="a9e4db2cb4a126bfd03259073ef74719" args="(FdoString *propertyName)=0" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">virtual FdoOrderingOption SdfIExtendedSelect::GetOrderingOption </td>
+ <td class="mdname1" valign="top" nowrap> <em>propertyName</em> </td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+Gets the ordering option for a given property.
+<p>
+ </table>
+</dl>
+<dl compact><dt><b>Returns:</b></dt><dd>Returns the ordering option.</dd></dl>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SDF/class_sdf_i_extended_select_d10d84246bb47e87adb334fd6d5e8836.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/class_sdf_i_extended_select_d10d84246bb47e87adb334fd6d5e8836.html?view=auto&rev=97
--- (empty file)
+++ trunk/www/docs/SDF/class_sdf_i_extended_select_d10d84246bb47e87adb334fd6d5e8836.html 2006-12-04 18:49:20+0000
@@ -0,0 +1,107 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="nav">
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="class_sdf_i_extended_select_d10d84246bb47e87adb334fd6d5e8836.html#d10d84246bb47e87adb334fd6d5e8836">ExecuteScrollable</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="d10d84246bb47e87adb334fd6d5e8836"></a><!-- doxytag: member="SdfIExtendedSelect::ExecuteScrollable" ref="d10d84246bb47e87adb334fd6d5e8836" args="(const wchar_t *sdfCacheFile, FdoDataPropertyDefinitionCollection *extendedProps, FdoPropertyValueCollection *extendedDefaults)=0" --><p>
+ <tr>
+ <tr>
+ <td class="mdname" nowrap> <em>sdfCacheFile</em>, </td>
+ </tr>
+ <tr>
+ <td class="md" nowrap>FdoDataPropertyDefinitionCollection * </td>
+ <td class="mdname" nowrap> <em>extendedProps</em>, </td>
+ </tr>
+ <tr>
+ <td class="md" nowrap>FdoPropertyValueCollection * </td>
+ <td class="mdname" nowrap> <em>extendedDefaults</em></td>
+ </tr>
+ <tr>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+Executes the select command and returns a <a class="el" href="class_sdf_i_scrollable_feature_reader.html">SdfIScrollableFeatureReader</a>. This method creates a temporary SDF file that contains the selected properties. If ordering is enabled, then the created temporary SDF file is sorted according to the ordering collection. In this case the sorting is file based where the SQLite BTree is used.
+<p>
+Both collections have to be in-sync otherwise an exception will be thrown. <dl compact><dt><b>Parameters:</b></dt><dd>
+ <tr><td valign="top"></td><td valign="top"><em>sdfCacheFile</em> </td><td>File path and name used to store the result of the query.</td></tr>
+ <tr><td valign="top"></td><td valign="top"><em>extendedProps</em> </td><td>A collection of data property definition that extends the class definition defined by the selected properties.</td></tr>
+ <tr><td valign="top"></td><td valign="top"><em>extendedDefaults</em> </td><td>A collection of property values used as defaults for extended properties defined by extendedProps parameter.</td></tr>
+ </table>
+</dl>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SDF/class_sdf_i_scrollable_feature_reader-members.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/class_sdf_i_scrollable_feature_reader-members.html?view=auto&rev=97
--- (empty file)
+++ trunk/www/docs/SDF/class_sdf_i_scrollable_feature_reader-members.html 2006-12-04 18:49:20+0000
@@ -0,0 +1,49 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<h1>SdfIScrollableFeatureReader Member List</h1>This is the complete list of members for <a class="el" href="class_sdf_i_scrollable_feature_reader.html">SdfIScrollableFeatureReader</a>, including all inherited members.<p><table>
+ <tr class="memlist"><td><a class="el" href="class_sdf_i_scrollable_feature_reader_0c8bd83991d3de13ea3914e50eea68cd.html#0c8bd83991d3de13ea3914e50eea68cd">Count</a>()=0</td><td><a class="el" href="class_sdf_i_scrollable_feature_reader.html">SdfIScrollableFeatureReader</a></td><td><code> [pure virtual]</code></td></tr>
+ <tr class="memlist"><td><a class="el" href="class_sdf_i_scrollable_feature_reader_d692f60e023be7168ac6cf22d781cacd.html#d692f60e023be7168ac6cf22d781cacd">IndexOf</a>(FdoPropertyValueCollection *key)=0</td><td><a class="el" href="class_sdf_i_scrollable_feature_reader.html">SdfIScrollableFeatureReader</a></td><td><code> [pure virtual]</code></td></tr>
+ <tr class="memlist"><td><a class="el" href="class_sdf_i_scrollable_feature_reader_3e1b34ea5d045715c41d232c261f9f37.html#3e1b34ea5d045715c41d232c261f9f37">ReadAt</a>(FdoPropertyValueCollection *key)=0</td><td><a class="el" href="class_sdf_i_scrollable_feature_reader.html">SdfIScrollableFeatureReader</a></td><td><code> [pure virtual]</code></td></tr>
+ <tr class="memlist"><td><a class="el" href="class_sdf_i_scrollable_feature_reader_1f018e50f3f7fb295d1c0968bc66aad3.html#1f018e50f3f7fb295d1c0968bc66aad3">ReadAtIndex</a>(unsigned int recordindex)=0</td><td><a class="el" href="class_sdf_i_scrollable_feature_reader.html">SdfIScrollableFeatureReader</a></td><td><code> [pure virtual]</code></td></tr>
+ <tr class="memlist"><td><a class="el" href="class_sdf_i_scrollable_feature_reader_5b3f6fe4b58576aef1f2b3e47bd32392.html#5b3f6fe4b58576aef1f2b3e47bd32392">ReadFirst</a>()=0</td><td><a class="el" href="class_sdf_i_scrollable_feature_reader.html">SdfIScrollableFeatureReader</a></td><td><code> [pure virtual]</code></td></tr>
+ <tr class="memlist"><td><a class="el" href="class_sdf_i_scrollable_feature_reader_31612208adc6a6e34023b40ccbbe9ee9.html#31612208adc6a6e34023b40ccbbe9ee9">ReadLast</a>()=0</td><td><a class="el" href="class_sdf_i_scrollable_feature_reader.html">SdfIScrollableFeatureReader</a></td><td><code> [pure virtual]</code></td></tr>
+ <tr class="memlist"><td><a class="el" href="class_sdf_i_scrollable_feature_reader_8de8b2476b8dc5051c7f17f734b4693c.html#8de8b2476b8dc5051c7f17f734b4693c">ReadPrevious</a>()=0</td><td><a class="el" href="class_sdf_i_scrollable_feature_reader.html">SdfIScrollableFeatureReader</a></td><td><code> [pure virtual]</code></td></tr>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SDF/class_sdf_i_scrollable_feature_reader.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/class_sdf_i_scrollable_feature_reader.html?view=auto&rev=97
--- (empty file)
+++ trunk/www/docs/SDF/class_sdf_i_scrollable_feature_reader.html 2006-12-04 18:49:20+0000
@@ -0,0 +1,82 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<h1>SdfIScrollableFeatureReader Class Reference</h1><!-- doxytag: class="SdfIScrollableFeatureReader" --><code>#include <<a class="el" href="_i_scrollable_feature_reader_8h-source.html">IScrollableFeatureReader.h</a>></code>
+<p>
+<a href="class_sdf_i_scrollable_feature_reader-members.html">List of all members.</a><hr><a name="_details"></a><h2>Detailed Description</h2>
+<p>
+<p>
+Definition at line <a class="el" href="_i_scrollable_feature_reader_8h-source.html#l00022">22</a> of file <a class="el" href="_i_scrollable_feature_reader_8h-source.html">IScrollableFeatureReader.h</a>.<table border="0" cellpadding="0" cellspacing="0">
+<tr><td></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">virtual int </td><td class="memItemRight" valign="bottom"><a class="el" href="class_sdf_i_scrollable_feature_reader_0c8bd83991d3de13ea3914e50eea68cd.html#0c8bd83991d3de13ea3914e50eea68cd">Count</a> ()=0</td></tr>
+<tr><td class="mdescLeft"> </td><td class="mdescRight">Returns the number of records of the query result. <a href="#0c8bd83991d3de13ea3914e50eea68cd"></a><br></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">virtual unsigned int </td><td class="memItemRight" valign="bottom"><a class="el" href="class_sdf_i_scrollable_feature_reader_d692f60e023be7168ac6cf22d781cacd.html#d692f60e023be7168ac6cf22d781cacd">IndexOf</a> (FdoPropertyValueCollection *key)=0</td></tr>
+<tr><td class="mdescLeft"> </td><td class="mdescRight">Given a key of a feature, IndexOf will return the one based index or the record number of the feature within the returned query result. If the record is not found, then zero is retuned. This is the mirror function of the GetAtIndex function. This method does not affect the reader position. GetAtIndex need to be called to move the reader to the returned index. <a href="#d692f60e023be7168ac6cf22d781cacd"></a><br></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">virtual bool </td><td class="memItemRight" valign="bottom"><a class="el" href="class_sdf_i_scrollable_feature_reader_3e1b34ea5d045715c41d232c261f9f37.html#3e1b34ea5d045715c41d232c261f9f37">ReadAt</a> (FdoPropertyValueCollection *key)=0</td></tr>
+<tr><td class="mdescLeft"> </td><td class="mdescRight">provide the ad-hoc access to the query result. It positions the position of the reader at a given record defined by the key. If the record is not found, then the reader position is unset and false value is returned. Once the readers position becames unset, the caller needs to call ReadFirst, ReadLast or ReadAt to re-position the reader at a valid location.<p>
+ <tr><td valign="top"></td><td valign="top"><em>key</em> </td><td>The key that identifies a record.</td></tr>
+ </table>
+</dl>
+<dl compact><dt><b>Returns:</b></dt><dd>Returns true if a record is found or false otherwise.</dd></dl>
+ <a href="#3e1b34ea5d045715c41d232c261f9f37"></a><br></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">virtual bool </td><td class="memItemRight" valign="bottom"><a class="el" href="class_sdf_i_scrollable_feature_reader_1f018e50f3f7fb295d1c0968bc66aad3.html#1f018e50f3f7fb295d1c0968bc66aad3">ReadAtIndex</a> (unsigned int recordindex)=0</td></tr>
+<tr><td class="mdescLeft"> </td><td class="mdescRight">Provides an ad-hoc access to the query result. The recordindex is the one-based nth item in the query result. If successful, this method will position the reader at the feature identified by the recordindex. <a href="#1f018e50f3f7fb295d1c0968bc66aad3"></a><br></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">virtual bool </td><td class="memItemRight" valign="bottom"><a class="el" href="class_sdf_i_scrollable_feature_reader_5b3f6fe4b58576aef1f2b3e47bd32392.html#5b3f6fe4b58576aef1f2b3e47bd32392">ReadFirst</a> ()=0</td></tr>
+<tr><td class="mdescLeft"> </td><td class="mdescRight">Position the reader at the first record of the query result. This method returns false if the query result is empty. <a href="#5b3f6fe4b58576aef1f2b3e47bd32392"></a><br></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">virtual bool </td><td class="memItemRight" valign="bottom"><a class="el" href="class_sdf_i_scrollable_feature_reader_31612208adc6a6e34023b40ccbbe9ee9.html#31612208adc6a6e34023b40ccbbe9ee9">ReadLast</a> ()=0</td></tr>
+<tr><td class="mdescLeft"> </td><td class="mdescRight">Position the reader at the last record of the query result. This method returns false if the query result is empty. <a href="#31612208adc6a6e34023b40ccbbe9ee9"></a><br></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">virtual bool </td><td class="memItemRight" valign="bottom"><a class="el" href="class_sdf_i_scrollable_feature_reader_8de8b2476b8dc5051c7f17f734b4693c.html#8de8b2476b8dc5051c7f17f734b4693c">ReadPrevious</a> ()=0</td></tr>
+<tr><td class="mdescLeft"> </td><td class="mdescRight">Advances the reader to the previous item and returns true if there is another object to read or false if reading is complete. The default position of the reader is prior to the first item. Therefore you must call ReadFirst or ReadLast to begin accessing any data. <a href="#8de8b2476b8dc5051c7f17f734b4693c"></a><br></td></tr>
+</table>
+<li><a class="el" href="_i_scrollable_feature_reader_8h-source.html">IScrollableFeatureReader.h</a></ul>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SDF/class_sdf_i_scrollable_feature_reader_0c8bd83991d3de13ea3914e50eea68cd.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/class_sdf_i_scrollable_feature_reader_0c8bd83991d3de13ea3914e50eea68cd.html?view=auto&rev=97
--- (empty file)
+++ trunk/www/docs/SDF/class_sdf_i_scrollable_feature_reader_0c8bd83991d3de13ea3914e50eea68cd.html 2006-12-04 18:49:20+0000
@@ -0,0 +1,85 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ <li><a href="files.html"><span>Files</span></a></li>
+ </ul></div>
+<div class="nav">
+<a class="el" href="class_sdf_i_scrollable_feature_reader.html">SdfIScrollableFeatureReader</a></div>
+<table cellspacing="0" cellpadding="0" border="0">
+ <tr>
+ <td valign="top">
+ <div class="navtab">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="class_sdf_i_scrollable_feature_reader_0c8bd83991d3de13ea3914e50eea68cd.html#0c8bd83991d3de13ea3914e50eea68cd">Count</a></td></tr>
+ <tr><td class="navtab"><a class="qindex" href="class_sdf_i_scrollable_feature_reader_d692f60e023be7168ac6cf22d781cacd.html#d692f60e023be7168ac6cf22d781cacd">IndexOf</a></td></tr>
+ <tr><td class="navtab"><a class="qindex" href="class_sdf_i_scrollable_feature_reader_3e1b34ea5d045715c41d232c261f9f37.html#3e1b34ea5d045715c41d232c261f9f37">ReadAt</a></td></tr>
+ <tr><td class="navtab"><a class="qindex" href="class_sdf_i_scrollable_feature_reader_1f018e50f3f7fb295d1c0968bc66aad3.html#1f018e50f3f7fb295d1c0968bc66aad3">ReadAtIndex</a></td></tr>
+ <tr><td class="navtab"><a class="qindex" href="class_sdf_i_scrollable_feature_reader_5b3f6fe4b58576aef1f2b3e47bd32392.html#5b3f6fe4b58576aef1f2b3e47bd32392">ReadFirst</a></td></tr>
+ <tr><td class="navtab"><a class="qindex" href="class_sdf_i_scrollable_feature_reader_31612208adc6a6e34023b40ccbbe9ee9.html#31612208adc6a6e34023b40ccbbe9ee9">ReadLast</a></td></tr>
+ <tr><td class="navtab"><a class="qindex" href="class_sdf_i_scrollable_feature_reader_8de8b2476b8dc5051c7f17f734b4693c.html#8de8b2476b8dc5051c7f17f734b4693c">ReadPrevious</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="0c8bd83991d3de13ea3914e50eea68cd"></a><!-- doxytag: member="SdfIScrollableFeatureReader::Count" ref="0c8bd83991d3de13ea3914e50eea68cd" args="()=0" --><p>
+<table class="mdTable" cellpadding="2" cellspacing="0">
+ <tr>
+ <td class="mdRow">
+ <table cellpadding="0" cellspacing="0" border="0">
+ <tr>
+ <td class="md" nowrap valign="top">virtual int SdfIScrollableFeatureReader::Count </td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+<table cellspacing="5" cellpadding="0" border="0">
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+Returns the number of records of the query result.
+<p>
+<dl compact><dt><b>Returns:</b></dt><dd>Returns number of records.</dd></dl>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SDF/class_sdf_i_scrollable_feature_reader_1f018e50f3f7fb295d1c0968bc66aad3.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/class_sdf_i_scrollable_feature_reader_1f018e50f3f7fb295d1c0968bc66aad3.html?view=auto&rev=97
--- (empty file)
+++ trunk/www/docs/SDF/class_sdf_i_scrollable_feature_reader_1f018e50f3f7fb295d1c0968bc66aad3.html 2006-12-04 18:49:20+0000
@@ -0,0 +1,91 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="nav">
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindex" href="class_sdf_i_scrollable_feature_reader_0c8bd83991d3de13ea3914e50eea68cd.html#0c8bd83991d3de13ea3914e50eea68cd">Count</a></td></tr>
+ <tr><td class="navtab"><a class="qindexHL" href="class_sdf_i_scrollable_feature_reader_1f018e50f3f7fb295d1c0968bc66aad3.html#1f018e50f3f7fb295d1c0968bc66aad3">ReadAtIndex</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="1f018e50f3f7fb295d1c0968bc66aad3"></a><!-- doxytag: member="SdfIScrollableFeatureReader::ReadAtIndex" ref="1f018e50f3f7fb295d1c0968bc66aad3" args="(unsigned int recordindex)=0" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">virtual bool SdfIScrollableFeatureReader::ReadAtIndex </td>
+ <td class="md" nowrap valign="top">unsigned int </td>
+ <td class="mdname1" valign="top" nowrap> <em>recordindex</em> </td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+Provides an ad-hoc access to the query result. The recordindex is the one-based nth item in the query result. If successful, this method will position the reader at the feature identified by the recordindex.
+<p>
+ <table border="0" cellspacing="2" cellpadding="0">
+ <tr><td valign="top"></td><td valign="top"><em>recordindex</em> </td><td>The index of the row.</td></tr>
+ </table>
+</dl>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SDF/class_sdf_i_scrollable_feature_reader_31612208adc6a6e34023b40ccbbe9ee9.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/class_sdf_i_scrollable_feature_reader_31612208adc6a6e34023b40ccbbe9ee9.html?view=auto&rev=97
--- (empty file)
+++ trunk/www/docs/SDF/class_sdf_i_scrollable_feature_reader_31612208adc6a6e34023b40ccbbe9ee9.html 2006-12-04 18:49:20+0000
@@ -0,0 +1,85 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="nav">
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="class_sdf_i_scrollable_feature_reader_31612208adc6a6e34023b40ccbbe9ee9.html#31612208adc6a6e34023b40ccbbe9ee9">ReadLast</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="31612208adc6a6e34023b40ccbbe9ee9"></a><!-- doxytag: member="SdfIScrollableFeatureReader::ReadLast" ref="31612208adc6a6e34023b40ccbbe9ee9" args="()=0" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">virtual bool SdfIScrollableFeatureReader::ReadLast </td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+Position the reader at the last record of the query result. This method returns false if the query result is empty.
+<p>
+<dl compact><dt><b>Returns:</b></dt><dd>Returns true if a record is found or false if the result is empty.</dd></dl>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SDF/class_sdf_i_scrollable_feature_reader_3e1b34ea5d045715c41d232c261f9f37.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/class_sdf_i_scrollable_feature_reader_3e1b34ea5d045715c41d232c261f9f37.html?view=auto&rev=97
--- (empty file)
+++ trunk/www/docs/SDF/class_sdf_i_scrollable_feature_reader_3e1b34ea5d045715c41d232c261f9f37.html 2006-12-04 18:49:20+0000
@@ -0,0 +1,92 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="nav">
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="class_sdf_i_scrollable_feature_reader_3e1b34ea5d045715c41d232c261f9f37.html#3e1b34ea5d045715c41d232c261f9f37">ReadAt</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="3e1b34ea5d045715c41d232c261f9f37"></a><!-- doxytag: member="SdfIScrollableFeatureReader::ReadAt" ref="3e1b34ea5d045715c41d232c261f9f37" args="(FdoPropertyValueCollection *key)=0" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">virtual bool SdfIScrollableFeatureReader::ReadAt </td>
+ <td class="md" nowrap valign="top">FdoPropertyValueCollection * </td>
+ <td class="mdname1" valign="top" nowrap> <em>key</em> </td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+provide the ad-hoc access to the query result. It positions the position of the reader at a given record defined by the key. If the record is not found, then the reader position is unset and false value is returned. Once the readers position becames unset, the caller needs to call ReadFirst, ReadLast or ReadAt to re-position the reader at a valid location.<p>
+ </table>
+</dl>
+<p>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SDF/class_sdf_i_scrollable_feature_reader_5b3f6fe4b58576aef1f2b3e47bd32392.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/class_sdf_i_scrollable_feature_reader_5b3f6fe4b58576aef1f2b3e47bd32392.html?view=auto&rev=97
--- (empty file)
+++ trunk/www/docs/SDF/class_sdf_i_scrollable_feature_reader_5b3f6fe4b58576aef1f2b3e47bd32392.html 2006-12-04 18:49:20+0000
@@ -0,0 +1,85 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="nav">
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="class_sdf_i_scrollable_feature_reader_5b3f6fe4b58576aef1f2b3e47bd32392.html#5b3f6fe4b58576aef1f2b3e47bd32392">ReadFirst</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="5b3f6fe4b58576aef1f2b3e47bd32392"></a><!-- doxytag: member="SdfIScrollableFeatureReader::ReadFirst" ref="5b3f6fe4b58576aef1f2b3e47bd32392" args="()=0" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">virtual bool SdfIScrollableFeatureReader::ReadFirst </td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+Position the reader at the first record of the query result. This method returns false if the query result is empty.
+<p>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SDF/class_sdf_i_scrollable_feature_reader_8de8b2476b8dc5051c7f17f734b4693c.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/class_sdf_i_scrollable_feature_reader_8de8b2476b8dc5051c7f17f734b4693c.html?view=auto&rev=97
--- (empty file)
+++ trunk/www/docs/SDF/class_sdf_i_scrollable_feature_reader_8de8b2476b8dc5051c7f17f734b4693c.html 2006-12-04 18:49:20+0000
@@ -0,0 +1,85 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="nav">
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="class_sdf_i_scrollable_feature_reader_8de8b2476b8dc5051c7f17f734b4693c.html#8de8b2476b8dc5051c7f17f734b4693c">ReadPrevious</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="8de8b2476b8dc5051c7f17f734b4693c"></a><!-- doxytag: member="SdfIScrollableFeatureReader::ReadPrevious" ref="8de8b2476b8dc5051c7f17f734b4693c" args="()=0" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">virtual bool SdfIScrollableFeatureReader::ReadPrevious </td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+Advances the reader to the previous item and returns true if there is another object to read or false if reading is complete. The default position of the reader is prior to the first item. Therefore you must call ReadFirst or ReadLast to begin accessing any data.
+<p>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SDF/class_sdf_i_scrollable_feature_reader_d692f60e023be7168ac6cf22d781cacd.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/class_sdf_i_scrollable_feature_reader_d692f60e023be7168ac6cf22d781cacd.html?view=auto&rev=97
--- (empty file)
+++ trunk/www/docs/SDF/class_sdf_i_scrollable_feature_reader_d692f60e023be7168ac6cf22d781cacd.html 2006-12-04 18:49:20+0000
@@ -0,0 +1,91 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="nav">
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="class_sdf_i_scrollable_feature_reader_d692f60e023be7168ac6cf22d781cacd.html#d692f60e023be7168ac6cf22d781cacd">IndexOf</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="d692f60e023be7168ac6cf22d781cacd"></a><!-- doxytag: member="SdfIScrollableFeatureReader::IndexOf" ref="d692f60e023be7168ac6cf22d781cacd" args="(FdoPropertyValueCollection *key)=0" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">virtual unsigned int SdfIScrollableFeatureReader::IndexOf </td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+Given a key of a feature, IndexOf will return the one based index or the record number of the feature within the returned query result. If the record is not found, then zero is retuned. This is the mirror function of the GetAtIndex function. This method does not affect the reader position. GetAtIndex need to be called to move the reader to the returned index.
+<p>
+ </table>
+</dl>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SDF/classes.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/classes.html?view=auto&rev=97
--- (empty file)
+++ trunk/www/docs/SDF/classes.html 2006-12-04 18:49:20+0000
@@ -0,0 +1,46 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ <li id="current"><a href="classes.html"><span>Alphabetical List</span></a></li>
+ </ul></div>
+<h1>FDO Provider for SDF Class Index</h1><p><div class="qindex"><a class="qindex" href="#letter_F">F</a> | <a class="qindex" href="#letter_S">S</a></div><p>
+<table align="center" width="95%" border="0" cellspacing="0" cellpadding="0">
+<tr><td><a name="letter_F"></a><table border="0" cellspacing="0" cellpadding="0"><tr><td><div class="ah"> F </div></td></tr></table>
+</td><td><a name="letter_S"></a><table border="0" cellspacing="0" cellpadding="0"><tr><td><div class="ah"> S </div></td></tr></table>
+</td><td><a class="el" href="class_sdf_compare_handler.html">SdfCompareHandler</a> </td><td><a class="el" href="class_sdf_i_extended_select.html">SdfIExtendedSelect</a> </td><td><a class="el" href="class_sdf_i_scrollable_feature_reader.html">SdfIScrollableFeatureReader</a> </td></tr><tr><td><a class="el" href="class_fdo_i_create_s_d_f_file.html">FdoICreateSDFFile</a> </td></tr></table><p><div class="qindex"><a class="qindex" href="#letter_F">F</a> | <a class="qindex" href="#letter_S">S</a></div><p>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SDF/custom.css
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/custom.css?view=auto&rev=97
--- (empty file)
+++ trunk/www/docs/SDF/custom.css 2006-12-04 18:49:20+0000
@@ -0,0 +1,96 @@
+ at import url(doxygen.css);
+div.Syntax{
+ background-color:#FFFFD9;
+div.Example{
+ background-color:#E9E9E9;
+/* table cells on the main page (index.html) */
+div.mainpage td {
+ background-color: #FFFFCC;
+ border-right-color: #FF6633;
+ border-bottom-color: #FF6633;
+ border-left-color: #FFCC33;
+ border-top-color: #FFCC33;
+ text-align: center;
+/*** Used in external topics ***/
+p.indent_1 {
+ padding-left: 0.25in;
+p.indent_2 {
+ padding-left: 0.5in;
+p.indent_3 {
+ padding-left: 0.75in;
+table.RuledTable {
+ border-collapse: collapse;
+ table-layout: auto;
+ width: auto;
+ cellpadding: none;
+ cellspacing: none;
+table.RuledTable th {
+ background-color: #CCCCCC;
+ border-left-style: solid;
+ border-left-width: thin;
+ border-left-color: #000000;
+ border-right-style: solid;
+ border-right-width: thin;
+ border-right-color: #000000;
+ border-bottom-style: solid;
+ border-bottom-width: thin;
+ border-bottom-color: #000000;
+ border-top-style: solid;
+ border-top-width: thin;
+ border-top-color: #000000;
+ padding: 6px;
+ width: auto;
+table.RuledTable td {
+ padding-left: 6px;
+ padding-right: 6px;
+ padding-top: 4px;
+ padding-top: 4px;
+ width: auto;
+td.shaded{
+ background-color:#CCCCCC;
+/* Used in Geometry_FgfText.h */
+p.row_1 {
+ font-family: "Courier New", Courier, monospace;
+pre.row_2 {
+ background-color: #E7FFCE;
Added: trunk/www/docs/SDF/define__pages_8h-source.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/define__pages_8h-source.html?view=auto&rev=97
--- (empty file)
+++ trunk/www/docs/SDF/define__pages_8h-source.html 2006-12-04 18:49:20+0000
@@ -0,0 +1,77 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ <li id="current"><a href="files.html"><span>Files</span></a></li>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ <li><a href="files.html"><span>File List</span></a></li>
+ <li><a href="globals.html"><span>File Members</span></a></li>
+ </ul></div>
+<h1>define_pages.h</h1><a href="define__pages_8h.html">Go to the documentation of this file.</a><div class="fragment"><pre class="fragment"><a name="l00001"></a>00001 <span class="comment">/*! \mainpage Introduction</span>
+<a name="l00002"></a>00002 <span class="comment"><div class="mainpage"></span>
+<a name="l00003"></a>00003 <span class="comment"><!-- This is the index.html page that the user first sees. --></span>
+<a name="l00004"></a>00004 <span class="comment"></span>
+<a name="l00005"></a>00005 <span class="comment"><p>The Feature Data Objects (FDO) API provides access to data in a </span>
+<a name="l00006"></a>00006 <span class="comment">data store. A provider is a specific implementation of the FDO API </span>
+<a name="l00007"></a>00007 <span class="comment">that provides access to data in a particular data store. The FDO </span>
+<a name="l00008"></a>00008 <span class="comment">Provider for SDF provides FDO with access to an SDF-based data store.</span>
+<a name="l00009"></a>00009 <span class="comment"></span>
+<a name="l00010"></a>00010 <span class="comment"><p>The FDO Provider for SDF uses Autodesk's spatial database </span>
+<a name="l00011"></a>00011 <span class="comment">format, which is a file-based personal geodatabase that supports </span>
+<a name="l00012"></a>00012 <span class="comment">multiple features/attributes, spatial indexing, </span>
+<a name="l00013"></a>00013 <span class="comment">interoperability, file-locking, and high performance for </span>
+<a name="l00014"></a>00014 <span class="comment">large data sets.</span>
+<a name="l00015"></a>00015 <span class="comment"></p></span>
+<a name="l00016"></a>00016 <span class="comment"><p>The SDF file format has the following characteristics:</span>
+<a name="l00017"></a>00017 <span class="comment"></p></span>
+<a name="l00018"></a>00018 <span class="comment"></span>
+<a name="l00019"></a>00019 <span class="comment"><ul></span>
+<a name="l00020"></a>00020 <span class="comment"> <li> SDF files can be read on different platforms.</span>
+<a name="l00021"></a>00021 <span class="comment"> <li> The SDF file format has its own spatial indexing.</span>
+<a name="l00022"></a>00022 <span class="comment"> <li> SDF files can store geometric and non-geometric data with minimum </span>
+<a name="l00023"></a>00023 <span class="comment">overhead</span>
+<a name="l00024"></a>00024 <span class="comment"> <li>Although it does not support concurrency control (locking), </span>
+<a name="l00025"></a>00025 <span class="comment"> the SDF file format is a valid alternative to RDBMS.</span>
+<a name="l00026"></a>00026 <span class="comment"></ul></span>
+<a name="l00027"></a>00027 <span class="comment"><p></span>
+<a name="l00028"></a>00028 <span class="comment">For more information, see <i>The Essential FDO</i> (FET_TheEssentialFDO.pdf) </span>
+<a name="l00029"></a>00029 <span class="comment">and the <i>FDO Developer's Guide</i> (FDG_FDODevGuide.pdf).</span>
+<a name="l00030"></a>00030 <span class="comment"></p></span>
+<a name="l00031"></a>00031 <span class="comment"></span>
+<a name="l00032"></a>00032 <span class="comment"><br></span>
+<a name="l00033"></a>00033 <span class="comment"></div></span>
+<a name="l00034"></a>00034 <span class="comment">*/</span>
+<a name="l00035"></a>00035
+<a name="l00036"></a>00036
+<a name="l00037"></a>00037
+<a name="l00038"></a>00038
+</pre></div><!-- footer.html -->
+ <hr>
+ <table width="100%" border="0">
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SDF/define__pages_8h.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/define__pages_8h.html?view=auto&rev=97
--- (empty file)
+++ trunk/www/docs/SDF/define__pages_8h.html 2006-12-04 18:49:20+0000
@@ -0,0 +1,46 @@
+<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN" "http://www.w3.org/TR/html4/loose.dtd">
+<html>
+ <head>
+ <meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
+ <title>OSGeo FDO Provider for SDF API Reference</title>
+ <link href="custom.css" rel="stylesheet" type="text/css">
+ <link href="tabs.css" rel="stylesheet" type="text/css">
+ </head>
+ <body bgcolor="#FFFFFF">
+ <tr>
+ <td><b>API Reference<b></td>
+ <td align="right"><b>OSGeo FDO Provider for SDF<b></td>
+ </tr>
+ </table>
+<!-- End of: header.html -->
+<!-- Generated by Doxygen 1.4.6-NO -->
+<div class="tabs">
+ <ul>
+ <li><a href="main.html"><span>Main Page</span></a></li>
+ <li><a href="classes.html"><span>Classes</span></a></li>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<h1>define_pages.h File Reference</h1>
+<p>
+<p>
+<a href="define__pages_8h-source.html">Go to the source code of this file.</a><table border="0" cellpadding="0" cellspacing="0">
+<tr><td></td></tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SDF/doxygen.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/doxygen.png?view=auto&rev=97
Binary file. No diff available.
Added: trunk/www/docs/SDF/files.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/files.html?view=auto&rev=97
--- (empty file)
+++ trunk/www/docs/SDF/files.html 2006-12-04 18:49:20+0000
@@ -0,0 +1,47 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ <li id="current"><a href="files.html"><span>File List</span></a></li>
+ </ul></div>
+<h1>FDO Provider for SDF File List</h1>Here is a list of all files with brief descriptions:<table>
+ <tr><td class="indexkey"><a class="el" href="define__pages_8h.html">define_pages.h</a> <a href="define__pages_8h-source.html">[code]</a></td><td class="indexvalue"></td></tr>
+ <tr><td class="indexkey"><a class="el" href="_i_create_s_d_f_file_8h.html">ICreateSDFFile.h</a> <a href="_i_create_s_d_f_file_8h-source.html">[code]</a></td><td class="indexvalue"></td></tr>
+ <tr><td class="indexkey"><a class="el" href="_i_extended_select_8h.html">IExtendedSelect.h</a> <a href="_i_extended_select_8h-source.html">[code]</a></td><td class="indexvalue"></td></tr>
+ <tr><td class="indexkey"><a class="el" href="_i_scrollable_feature_reader_8h.html">IScrollableFeatureReader.h</a> <a href="_i_scrollable_feature_reader_8h-source.html">[code]</a></td><td class="indexvalue"></td></tr>
+ <tr><td class="indexkey"><a class="el" href="_sdf_command_type_8h.html">SdfCommandType.h</a> <a href="_sdf_command_type_8h-source.html">[code]</a></td><td class="indexvalue"></td></tr>
+ <tr><td class="indexkey"><a class="el" href="_sdf_compare_handler_8h.html">SdfCompareHandler.h</a> <a href="_sdf_compare_handler_8h-source.html">[code]</a></td><td class="indexvalue"></td></tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SDF/ftv2blank.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/ftv2blank.png?view=auto&rev=97
Added: trunk/www/docs/SDF/ftv2doc.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/ftv2doc.png?view=auto&rev=97
Added: trunk/www/docs/SDF/ftv2folderclosed.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/ftv2folderclosed.png?view=auto&rev=97
Added: trunk/www/docs/SDF/ftv2folderopen.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/ftv2folderopen.png?view=auto&rev=97
Added: trunk/www/docs/SDF/ftv2lastnode.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/ftv2lastnode.png?view=auto&rev=97
Added: trunk/www/docs/SDF/ftv2link.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/ftv2link.png?view=auto&rev=97
Added: trunk/www/docs/SDF/ftv2mlastnode.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/ftv2mlastnode.png?view=auto&rev=97
Added: trunk/www/docs/SDF/ftv2mnode.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/ftv2mnode.png?view=auto&rev=97
Added: trunk/www/docs/SDF/ftv2node.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/ftv2node.png?view=auto&rev=97
Added: trunk/www/docs/SDF/ftv2plastnode.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/ftv2plastnode.png?view=auto&rev=97
Added: trunk/www/docs/SDF/ftv2pnode.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/ftv2pnode.png?view=auto&rev=97
Added: trunk/www/docs/SDF/ftv2vertline.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/ftv2vertline.png?view=auto&rev=97
Added: trunk/www/docs/SDF/functions.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/functions.html?view=auto&rev=97
--- (empty file)
+++ trunk/www/docs/SDF/functions.html 2006-12-04 18:49:20+0000
@@ -0,0 +1,80 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ <li id="current"><a href="functions.html"><span>Class Members</span></a></li>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ <li id="current"><a href="functions.html"><span>All</span></a></li>
+ <li><a href="functions_func.html"><span>Functions</span></a></li>
+ </ul>
+</div>
+Here is a list of all class members with links to the classes they belong to:
+<p>
+<ul>
+<li>ClearOrderingOptions()
+: <a class="el" href="class_sdf_i_extended_select_56fb99cd7bef0a7528cf1dd408d32e16.html#56fb99cd7bef0a7528cf1dd408d32e16">SdfIExtendedSelect</a><li>Compare()
+: <a class="el" href="class_sdf_compare_handler_fb5771764ec97dd9888a0d243d01886b.html#fb5771764ec97dd9888a0d243d01886b">SdfCompareHandler</a><li>Count()
+: <a class="el" href="class_sdf_i_scrollable_feature_reader_0c8bd83991d3de13ea3914e50eea68cd.html#0c8bd83991d3de13ea3914e50eea68cd">SdfIScrollableFeatureReader</a><li>Create()
+: <a class="el" href="class_sdf_compare_handler_dd5c70a33541eb9eabc2d19021a768fd.html#dd5c70a33541eb9eabc2d19021a768fd">SdfCompareHandler</a><li>Dispose()
+: <a class="el" href="class_sdf_compare_handler_d3a014c324bcbb6e2eccbf17ee9b43f3.html#d3a014c324bcbb6e2eccbf17ee9b43f3">SdfCompareHandler</a><li>Execute()
+: <a class="el" href="class_fdo_i_create_s_d_f_file_05550ca7007c3e389b7029c41baa1587.html#05550ca7007c3e389b7029c41baa1587">FdoICreateSDFFile</a><li>ExecuteScrollable()
+: <a class="el" href="class_sdf_i_extended_select_d10d84246bb47e87adb334fd6d5e8836.html#d10d84246bb47e87adb334fd6d5e8836">SdfIExtendedSelect</a><li>GetCoordinateSystemWKT()
+: <a class="el" href="class_fdo_i_create_s_d_f_file_0b8020c31deb9acc05311fd11f260c7d.html#0b8020c31deb9acc05311fd11f260c7d">FdoICreateSDFFile</a><li>GetFileName()
+: <a class="el" href="class_fdo_i_create_s_d_f_file_0bde059736005f052076c6735c8b2453.html#0bde059736005f052076c6735c8b2453">FdoICreateSDFFile</a><li>GetOrderingOption()
+: <a class="el" href="class_sdf_i_extended_select_a9e4db2cb4a126bfd03259073ef74719.html#a9e4db2cb4a126bfd03259073ef74719">SdfIExtendedSelect</a><li>GetSpatialContextDescription()
+: <a class="el" href="class_fdo_i_create_s_d_f_file_4d74d6f8e45e76d8c8606953ae4cb307.html#4d74d6f8e45e76d8c8606953ae4cb307">FdoICreateSDFFile</a><li>GetSpatialContextName()
+: <a class="el" href="class_fdo_i_create_s_d_f_file_647ff5d7f47cf47422c32645074cce8d.html#647ff5d7f47cf47422c32645074cce8d">FdoICreateSDFFile</a><li>GetXYTolerance()
+: <a class="el" href="class_fdo_i_create_s_d_f_file_4a2bb60374b5db4f9dca173de2845803.html#4a2bb60374b5db4f9dca173de2845803">FdoICreateSDFFile</a><li>GetZTolerance()
+: <a class="el" href="class_fdo_i_create_s_d_f_file_8b2fc8bbd39311d609c316fac75d765b.html#8b2fc8bbd39311d609c316fac75d765b">FdoICreateSDFFile</a><li>IndexOf()
+: <a class="el" href="class_sdf_i_scrollable_feature_reader_d692f60e023be7168ac6cf22d781cacd.html#d692f60e023be7168ac6cf22d781cacd">SdfIScrollableFeatureReader</a><li>ReadAt()
+: <a class="el" href="class_sdf_i_scrollable_feature_reader_3e1b34ea5d045715c41d232c261f9f37.html#3e1b34ea5d045715c41d232c261f9f37">SdfIScrollableFeatureReader</a><li>ReadAtIndex()
+: <a class="el" href="class_sdf_i_scrollable_feature_reader_1f018e50f3f7fb295d1c0968bc66aad3.html#1f018e50f3f7fb295d1c0968bc66aad3">SdfIScrollableFeatureReader</a><li>ReadFirst()
+: <a class="el" href="class_sdf_i_scrollable_feature_reader_5b3f6fe4b58576aef1f2b3e47bd32392.html#5b3f6fe4b58576aef1f2b3e47bd32392">SdfIScrollableFeatureReader</a><li>ReadLast()
+: <a class="el" href="class_sdf_i_scrollable_feature_reader_31612208adc6a6e34023b40ccbbe9ee9.html#31612208adc6a6e34023b40ccbbe9ee9">SdfIScrollableFeatureReader</a><li>ReadPrevious()
+: <a class="el" href="class_sdf_i_scrollable_feature_reader_8de8b2476b8dc5051c7f17f734b4693c.html#8de8b2476b8dc5051c7f17f734b4693c">SdfIScrollableFeatureReader</a><li>SetCompareHandler()
+: <a class="el" href="class_sdf_i_extended_select_69a9441cd4ada6b204a5b3ccfde49eab.html#69a9441cd4ada6b204a5b3ccfde49eab">SdfIExtendedSelect</a><li>SetCoordinateSystemWKT()
+: <a class="el" href="class_fdo_i_create_s_d_f_file_8bb4c31009cf0ab76fc094eadcf4ca91.html#8bb4c31009cf0ab76fc094eadcf4ca91">FdoICreateSDFFile</a><li>SetFileName()
+: <a class="el" href="class_fdo_i_create_s_d_f_file_e92b777da3c498180dd72fe4629ee788.html#e92b777da3c498180dd72fe4629ee788">FdoICreateSDFFile</a><li>SetOrderingOption()
+: <a class="el" href="class_sdf_i_extended_select_8921a5db2a527690f4d5592daa014be8.html#8921a5db2a527690f4d5592daa014be8">SdfIExtendedSelect</a><li>SetSpatialContextDescription()
+: <a class="el" href="class_fdo_i_create_s_d_f_file_86b4ac8510f46ad6629e42023f184cee.html#86b4ac8510f46ad6629e42023f184cee">FdoICreateSDFFile</a><li>SetSpatialContextName()
+: <a class="el" href="class_fdo_i_create_s_d_f_file_bda73a210df146335a62e933ebe19948.html#bda73a210df146335a62e933ebe19948">FdoICreateSDFFile</a><li>SetXYTolerance()
+: <a class="el" href="class_fdo_i_create_s_d_f_file_b3e528dda87b952a83786b2d01343524.html#b3e528dda87b952a83786b2d01343524">FdoICreateSDFFile</a><li>SetZTolerance()
+: <a class="el" href="class_fdo_i_create_s_d_f_file_2937b06fdf37207301200042b40e8d71.html#2937b06fdf37207301200042b40e8d71">FdoICreateSDFFile</a><li>~SdfCompareHandler()
+: <a class="el" href="class_sdf_compare_handler_c1e1a5c47894aa43ada963c4cb84b980.html#c1e1a5c47894aa43ada963c4cb84b980">SdfCompareHandler</a></ul>
+ <hr>
+ <tr>
+ <td align="right"><font size="-2"><a href="mailto:isd.docs at autodesk.com&subject=FDO%20Provider%20for%20SDF%20API%20documentation">Comments?</a></font></td>
+ <!-- The logo can go in another cell, when we get one -->
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SDF/functions_func.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/functions_func.html?view=auto&rev=97
--- (empty file)
+++ trunk/www/docs/SDF/functions_func.html 2006-12-04 18:49:20+0000
@@ -0,0 +1,80 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ <li id="current"><a href="classes.html"><span>Classes</span></a></li>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ <li><a href="classes.html"><span>Alphabetical List</span></a></li>
+ <li><a href="annotated.html"><span>Class List</span></a></li>
+ <li><a href="hierarchy.html"><span>Class Hierarchy</span></a></li>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ <li><a href="functions.html"><span>All</span></a></li>
+ <li id="current"><a href="functions_func.html"><span>Functions</span></a></li>
+ </ul>
+</div>
+<p>
+<ul>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SDF/globals.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/globals.html?view=auto&rev=97
--- (empty file)
+++ trunk/www/docs/SDF/globals.html 2006-12-04 18:49:20+0000
@@ -0,0 +1,56 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ <li id="current"><a href="globals.html"><span>File Members</span></a></li>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ <li id="current"><a href="globals.html"><span>All</span></a></li>
+ <li><a href="globals_enum.html"><span>Enumerations</span></a></li>
+ <li><a href="globals_eval.html"><span>Enumerator</span></a></li>
+ <li><a href="globals_defs.html"><span>Defines</span></a></li>
+ </ul>
+</div>
+Here is a list of all file members with links to the files they belong to:
+<p>
+<ul>
+<li>SDF_API
+: <a class="el" href="_sdf_compare_handler_8h_9bfa9402971b67602a99fd99449c5d76.html#9bfa9402971b67602a99fd99449c5d76">SdfCompareHandler.h</a><li>SDF_FIRST_PROVIDER_COMMAND
+: <a class="el" href="_sdf_command_type_8h_86597e57635d4329ec6b9d0a67f969d7.html#86597e57635d4329ec6b9d0a67f969d7">SdfCommandType.h</a><li>SdfCommandType
+: <a class="el" href="_sdf_command_type_8h_4ac92492e0d58aeace1b0c0f96cefea3.html#4ac92492e0d58aeace1b0c0f96cefea3">SdfCommandType.h</a><li>SdfCommandType_CreateSDFFile
+: <a class="el" href="_sdf_command_type_8h_4ac92492e0d58aeace1b0c0f96cefea3.html#4ac92492e0d58aeace1b0c0f96cefea348c2e525ef9f5e6ae1db0962a09cff37">SdfCommandType.h</a><li>SdfCommandType_ExtendedSelect
+: <a class="el" href="_sdf_command_type_8h_4ac92492e0d58aeace1b0c0f96cefea3.html#4ac92492e0d58aeace1b0c0f96cefea3cff985287cc5191960dc4a2258697243">SdfCommandType.h</a></ul>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SDF/globals_defs.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/globals_defs.html?view=auto&rev=97
--- (empty file)
+++ trunk/www/docs/SDF/globals_defs.html 2006-12-04 18:49:20+0000
@@ -0,0 +1,53 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ <li><a href="globals.html"><span>All</span></a></li>
+ <li id="current"><a href="globals_defs.html"><span>Defines</span></a></li>
+ </ul>
+</div>
+<p>
+<ul>
+<li>SDF_API
+: <a class="el" href="_sdf_command_type_8h_86597e57635d4329ec6b9d0a67f969d7.html#86597e57635d4329ec6b9d0a67f969d7">SdfCommandType.h</a></ul>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SDF/globals_enum.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/globals_enum.html?view=auto&rev=97
--- (empty file)
+++ trunk/www/docs/SDF/globals_enum.html 2006-12-04 18:49:20+0000
@@ -0,0 +1,52 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ <li id="current"><a href="globals_enum.html"><span>Enumerations</span></a></li>
+ </ul>
+</div>
+<p>
+<ul>
+<li>SdfCommandType
+: <a class="el" href="_sdf_command_type_8h_4ac92492e0d58aeace1b0c0f96cefea3.html#4ac92492e0d58aeace1b0c0f96cefea3">SdfCommandType.h</a></ul>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SDF/globals_eval.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/globals_eval.html?view=auto&rev=97
--- (empty file)
+++ trunk/www/docs/SDF/globals_eval.html 2006-12-04 18:49:20+0000
@@ -0,0 +1,53 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ <li id="current"><a href="globals_eval.html"><span>Enumerator</span></a></li>
+ </ul>
+</div>
+<p>
+<ul>
+<li>SdfCommandType_CreateSDFFile
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SDF/graph_legend.dot
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/graph_legend.dot?view=auto&rev=97
--- (empty file)
+++ trunk/www/docs/SDF/graph_legend.dot 2006-12-04 18:49:20+0000
@@ -0,0 +1,22 @@
+digraph G
+ edge [fontname="Helvetica",fontsize=10,labelfontname="Helvetica",labelfontsize=10];
+ node [fontname="Helvetica",fontsize=10,shape=record];
+ Node9 [shape="box",label="Inherited",fontsize=10,height=0.2,width=0.4,fontname="Helvetica",color="black",style="filled" fontcolor="white"];
+ Node10 -> Node9 [dir=back,color="midnightblue",fontsize=10,style="solid",fontname="Helvetica"];
+ Node10 [shape="box",label="PublicBase",fontsize=10,height=0.2,width=0.4,fontname="Helvetica",color="black",URL="$classPublicBase.html"];
+ Node11 -> Node10 [dir=back,color="midnightblue",fontsize=10,style="solid",fontname="Helvetica"];
+ Node11 [shape="box",label="Truncated",fontsize=10,height=0.2,width=0.4,fontname="Helvetica",color="red",URL="$classTruncated.html"];
+ Node13 -> Node9 [dir=back,color="darkgreen",fontsize=10,style="solid",fontname="Helvetica"];
+ Node13 [shape="box",label="ProtectedBase",fontsize=10,height=0.2,width=0.4,fontname="Helvetica",color="black",URL="$classProtectedBase.html"];
+ Node14 -> Node9 [dir=back,color="firebrick4",fontsize=10,style="solid",fontname="Helvetica"];
+ Node14 [shape="box",label="PrivateBase",fontsize=10,height=0.2,width=0.4,fontname="Helvetica",color="black",URL="$classPrivateBase.html"];
+ Node15 -> Node9 [dir=back,color="midnightblue",fontsize=10,style="solid",fontname="Helvetica"];
+ Node15 [shape="box",label="Undocumented",fontsize=10,height=0.2,width=0.4,fontname="Helvetica",color="grey75"];
+ Node16 -> Node9 [dir=back,color="midnightblue",fontsize=10,style="solid",fontname="Helvetica"];
+ Node16 [shape="box",label="Templ< int >",fontsize=10,height=0.2,width=0.4,fontname="Helvetica",color="black",URL="$classTempl.html"];
+ Node17 -> Node16 [dir=back,color="orange",fontsize=10,style="dashed",label="< int >",fontname="Helvetica"];
+ Node17 [shape="box",label="Templ< T >",fontsize=10,height=0.2,width=0.4,fontname="Helvetica",color="black",URL="$classTempl.html"];
+ Node18 -> Node9 [dir=back,color="darkorchid3",fontsize=10,style="dashed",label="m_usedClass",fontname="Helvetica"];
+ Node18 [shape="box",label="Used",fontsize=10,height=0.2,width=0.4,fontname="Helvetica",color="black",URL="$classUsed.html"];
Added: trunk/www/docs/SDF/graph_legend.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/graph_legend.html?view=auto&rev=97
--- (empty file)
+++ trunk/www/docs/SDF/graph_legend.html 2006-12-04 18:49:20+0000
@@ -0,0 +1,96 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<h1>Graph Legend</h1>This page explains how to interpret the graphs that are generated by doxygen.<p>
+Consider the following example: <div class="fragment"><pre class="fragment"><span class="comment">/*! Invisible class because of truncation */</span>
+<span class="keyword">class </span>Invisible { };
+<span class="comment"></span>
+<span class="comment">/*! Truncated class, inheritance relation is hidden */</span>
+<span class="keyword">class </span>Truncated : <span class="keyword">public</span> Invisible { };
+<span class="comment">/* Class not documented with doxygen comments */</span>
+<span class="keyword">class </span>Undocumented { };
+<span class="comment">/*! Class that is inherited using public inheritance */</span>
+<span class="keyword">class </span>PublicBase : <span class="keyword">public</span> Truncated { };
+<span class="comment">/*! A template class */</span>
+<span class="keyword">template</span><<span class="keyword">class</span> T> <span class="keyword">class </span>Templ { };
+<span class="comment">/*! Class that is inherited using protected inheritance */</span>
+<span class="keyword">class </span>ProtectedBase { };
+<span class="comment">/*! Class that is inherited using private inheritance */</span>
+<span class="keyword">class </span>PrivateBase { };
+<span class="comment">/*! Class that is used by the Inherited class */</span>
+<span class="keyword">class </span>Used { };
+<span class="comment">/*! Super class that inherits a number of other classes */</span>
+<span class="keyword">class </span>Inherited : <span class="keyword">public</span> PublicBase,
+ <span class="keyword">protected</span> ProtectedBase,
+ <span class="keyword">private</span> PrivateBase,
+ <span class="keyword">public</span> Undocumented
+ <span class="keyword">public</span> Templ<int>
+ <span class="keyword">private</span>:
+ Used *m_usedClass;
+</pre></div> If the <code>MAX_DOT_GRAPH_HEIGHT</code> tag in the configuration file is set to 240 this will result in the following graph:<p>
+<center><div align="center">
+<img src="graph_legend.png" alt="graph_legend.png">
+</div>
+</center> <p>
+The boxes in the above graph have the following meaning: <ul>
+<li>
+A filled black box represents the struct or class for which the graph is generated. </li>
+<li>
+A box with a black border denotes a documented struct or class. </li>
+<li>
+A box with a grey border denotes an undocumented struct or class. </li>
+<li>
+A box with a red border denotes a documented struct or class forwhich not all inheritance/containment relations are shown. A graph is truncated if it does not fit within the specified boundaries. </li>
+</ul>
+The arrows have the following meaning: <ul>
+<li>
+A dark blue arrow is used to visualize a public inheritance relation between two classes. </li>
+<li>
+A dark green arrow is used for protected inheritance. </li>
+<li>
+A dark red arrow is used for private inheritance. </li>
+<li>
+A purple dashed arrow is used if a class is contained or used by another class. The arrow is labeled with the variable(s) through which the pointed class or struct is accessible. </li>
+<li>
+A yellow dashed arrow denotes a relation between a template instance and the template class it was instantiated from. The arrow is labeled with the template parameters of the instance. </li>
+</ul>
+<!-- footer.html -->
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SDF/graph_legend.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/graph_legend.png?view=auto&rev=97
Added: trunk/www/docs/SDF/hierarchy.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/hierarchy.html?view=auto&rev=97
--- (empty file)
+++ trunk/www/docs/SDF/hierarchy.html 2006-12-04 18:49:20+0000
@@ -0,0 +1,49 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ <li id="current"><a href="hierarchy.html"><span>Class Hierarchy</span></a></li>
+ <li><a href="functions.html"><span>Class Members</span></a></li>
+ </ul></div>
+<h1>FDO Provider for SDF Class Hierarchy</h1><a href="inherits.html">Go to the graphical class hierarchy</a>
+<p>
+This inheritance list is sorted roughly, but not completely, alphabetically:<ul>
+<li><a class="el" href="class_fdo_i_create_s_d_f_file.html">FdoICreateSDFFile</a>
+<li><a class="el" href="class_sdf_compare_handler.html">SdfCompareHandler</a>
+<li><a class="el" href="class_sdf_i_extended_select.html">SdfIExtendedSelect</a>
+<li><a class="el" href="class_sdf_i_scrollable_feature_reader.html">SdfIScrollableFeatureReader</a>
+</ul>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SDF/index.hhc
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/index.hhc?view=auto&rev=97
--- (empty file)
+++ trunk/www/docs/SDF/index.hhc 2006-12-04 18:49:20+0000
@@ -0,0 +1,34 @@
+<!DOCTYPE HTML PUBLIC "-//IETF//DTD HTML//EN">
+<HTML><HEAD></HEAD><BODY>
+<OBJECT type="text/site properties">
+<param name="FrameName" value="right">
+</OBJECT>
+<UL>
+<LI><OBJECT type="text/sitemap"><param name="Name" value="Introduction"><param name="Local" value="main.html"><param name="ImageNumber" value="11"></OBJECT>
+<LI><OBJECT type="text/sitemap"><param name="Name" value="File List"><param name="ImageNumber" value="1"></OBJECT>
+ <UL>
+ <LI><OBJECT type="text/sitemap"><param name="Name" value="define_pages.h"><param name="Local" value="define__pages_8h.html"><param name="ImageNumber" value="11"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Name" value="ICreateSDFFile.h"><param name="Local" value="_i_create_s_d_f_file_8h.html"><param name="ImageNumber" value="11"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Name" value="IExtendedSelect.h"><param name="Local" value="_i_extended_select_8h.html"><param name="ImageNumber" value="11"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Name" value="IScrollableFeatureReader.h"><param name="Local" value="_i_scrollable_feature_reader_8h.html"><param name="ImageNumber" value="11"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Name" value="SdfCommandType.h"><param name="Local" value="_sdf_command_type_8h.html"><param name="ImageNumber" value="11"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Name" value="SdfCompareHandler.h"><param name="Local" value="_sdf_compare_handler_8h.html"><param name="ImageNumber" value="11"></OBJECT>
+ </UL>
+<LI><OBJECT type="text/sitemap"><param name="Name" value="Class List"><param name="ImageNumber" value="1"></OBJECT>
+ <UL>
+ <LI><OBJECT type="text/sitemap"><param name="Name" value="FdoICreateSDFFile"><param name="Local" value="class_fdo_i_create_s_d_f_file.html"><param name="ImageNumber" value="11"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Name" value="SdfCompareHandler"><param name="Local" value="class_sdf_compare_handler.html"><param name="ImageNumber" value="11"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Name" value="SdfIExtendedSelect"><param name="Local" value="class_sdf_i_extended_select.html"><param name="ImageNumber" value="11"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Name" value="SdfIScrollableFeatureReader"><param name="Local" value="class_sdf_i_scrollable_feature_reader.html"><param name="ImageNumber" value="11"></OBJECT>
+ </UL>
+<LI><OBJECT type="text/sitemap"><param name="Name" value="Class Hierarchy"><param name="ImageNumber" value="1"></OBJECT>
+ <UL>
+ </UL>
+<LI><OBJECT type="text/sitemap"><param name="Name" value="Class Members"><param name="Local" value="functions.html"><param name="ImageNumber" value="11"></OBJECT>
+<LI><OBJECT type="text/sitemap"><param name="Name" value="File Members"><param name="Local" value="globals.html"><param name="ImageNumber" value="11"></OBJECT>
+<LI><OBJECT type="text/sitemap"><param name="Name" value="Graphical Class Hierarchy"><param name="Local" value="inherits.html"><param name="ImageNumber" value="11"></OBJECT>
+</UL>
Added: trunk/www/docs/SDF/index.hhk
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/index.hhk?view=auto&rev=97
--- (empty file)
+++ trunk/www/docs/SDF/index.hhk 2006-12-04 18:49:20+0000
@@ -0,0 +1,90 @@
+</OBJECT>
+<UL>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_sdf_i_extended_select_56fb99cd7bef0a7528cf1dd408d32e16.html#56fb99cd7bef0a7528cf1dd408d32e16"><param name="Name" value="ClearOrderingOptions"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_sdf_compare_handler_fb5771764ec97dd9888a0d243d01886b.html#fb5771764ec97dd9888a0d243d01886b"><param name="Name" value="Compare"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_sdf_i_scrollable_feature_reader_0c8bd83991d3de13ea3914e50eea68cd.html#0c8bd83991d3de13ea3914e50eea68cd"><param name="Name" value="Count"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_sdf_compare_handler_dd5c70a33541eb9eabc2d19021a768fd.html#dd5c70a33541eb9eabc2d19021a768fd"><param name="Name" value="Create"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_sdf_compare_handler_d3a014c324bcbb6e2eccbf17ee9b43f3.html#d3a014c324bcbb6e2eccbf17ee9b43f3"><param name="Name" value="Dispose"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_i_create_s_d_f_file_05550ca7007c3e389b7029c41baa1587.html#05550ca7007c3e389b7029c41baa1587"><param name="Name" value="Execute"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_sdf_i_extended_select_d10d84246bb47e87adb334fd6d5e8836.html#d10d84246bb47e87adb334fd6d5e8836"><param name="Name" value="ExecuteScrollable"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_i_create_s_d_f_file.html"><param name="Name" value="FdoICreateSDFFile"></OBJECT>
+ <UL>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_i_create_s_d_f_file.html#05550ca7007c3e389b7029c41baa1587"><param name="Name" value="Execute"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_i_create_s_d_f_file.html#0b8020c31deb9acc05311fd11f260c7d"><param name="Name" value="GetCoordinateSystemWKT"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_i_create_s_d_f_file.html#0bde059736005f052076c6735c8b2453"><param name="Name" value="GetFileName"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_i_create_s_d_f_file.html#4d74d6f8e45e76d8c8606953ae4cb307"><param name="Name" value="GetSpatialContextDescription"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_i_create_s_d_f_file.html#647ff5d7f47cf47422c32645074cce8d"><param name="Name" value="GetSpatialContextName"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_i_create_s_d_f_file.html#4a2bb60374b5db4f9dca173de2845803"><param name="Name" value="GetXYTolerance"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_i_create_s_d_f_file.html#8b2fc8bbd39311d609c316fac75d765b"><param name="Name" value="GetZTolerance"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_i_create_s_d_f_file.html#8bb4c31009cf0ab76fc094eadcf4ca91"><param name="Name" value="SetCoordinateSystemWKT"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_i_create_s_d_f_file.html#e92b777da3c498180dd72fe4629ee788"><param name="Name" value="SetFileName"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_i_create_s_d_f_file.html#86b4ac8510f46ad6629e42023f184cee"><param name="Name" value="SetSpatialContextDescription"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_i_create_s_d_f_file.html#bda73a210df146335a62e933ebe19948"><param name="Name" value="SetSpatialContextName"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_i_create_s_d_f_file.html#b3e528dda87b952a83786b2d01343524"><param name="Name" value="SetXYTolerance"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_i_create_s_d_f_file.html#2937b06fdf37207301200042b40e8d71"><param name="Name" value="SetZTolerance"></OBJECT>
+ </UL>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_i_create_s_d_f_file_0b8020c31deb9acc05311fd11f260c7d.html#0b8020c31deb9acc05311fd11f260c7d"><param name="Name" value="GetCoordinateSystemWKT"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_i_create_s_d_f_file_0bde059736005f052076c6735c8b2453.html#0bde059736005f052076c6735c8b2453"><param name="Name" value="GetFileName"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_sdf_i_extended_select_a9e4db2cb4a126bfd03259073ef74719.html#a9e4db2cb4a126bfd03259073ef74719"><param name="Name" value="GetOrderingOption"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_i_create_s_d_f_file_4d74d6f8e45e76d8c8606953ae4cb307.html#4d74d6f8e45e76d8c8606953ae4cb307"><param name="Name" value="GetSpatialContextDescription"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_i_create_s_d_f_file_647ff5d7f47cf47422c32645074cce8d.html#647ff5d7f47cf47422c32645074cce8d"><param name="Name" value="GetSpatialContextName"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_i_create_s_d_f_file_4a2bb60374b5db4f9dca173de2845803.html#4a2bb60374b5db4f9dca173de2845803"><param name="Name" value="GetXYTolerance"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_i_create_s_d_f_file_8b2fc8bbd39311d609c316fac75d765b.html#8b2fc8bbd39311d609c316fac75d765b"><param name="Name" value="GetZTolerance"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_sdf_i_scrollable_feature_reader_d692f60e023be7168ac6cf22d781cacd.html#d692f60e023be7168ac6cf22d781cacd"><param name="Name" value="IndexOf"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_sdf_i_scrollable_feature_reader_3e1b34ea5d045715c41d232c261f9f37.html#3e1b34ea5d045715c41d232c261f9f37"><param name="Name" value="ReadAt"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_sdf_i_scrollable_feature_reader_1f018e50f3f7fb295d1c0968bc66aad3.html#1f018e50f3f7fb295d1c0968bc66aad3"><param name="Name" value="ReadAtIndex"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_sdf_i_scrollable_feature_reader_5b3f6fe4b58576aef1f2b3e47bd32392.html#5b3f6fe4b58576aef1f2b3e47bd32392"><param name="Name" value="ReadFirst"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_sdf_i_scrollable_feature_reader_31612208adc6a6e34023b40ccbbe9ee9.html#31612208adc6a6e34023b40ccbbe9ee9"><param name="Name" value="ReadLast"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_sdf_i_scrollable_feature_reader_8de8b2476b8dc5051c7f17f734b4693c.html#8de8b2476b8dc5051c7f17f734b4693c"><param name="Name" value="ReadPrevious"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="_sdf_compare_handler_8h_9bfa9402971b67602a99fd99449c5d76.html#9bfa9402971b67602a99fd99449c5d76"><param name="Name" value="SDF_API"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="_sdf_command_type_8h_86597e57635d4329ec6b9d0a67f969d7.html#86597e57635d4329ec6b9d0a67f969d7"><param name="Name" value="SDF_FIRST_PROVIDER_COMMAND"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="_sdf_command_type_8h.html"><param name="Name" value="SdfCommandType.h"></OBJECT>
+ <UL>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="_sdf_command_type_8h.html#86597e57635d4329ec6b9d0a67f969d7"><param name="Name" value="SDF_FIRST_PROVIDER_COMMAND"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="_sdf_command_type_8h.html#4ac92492e0d58aeace1b0c0f96cefea3"><param name="Name" value="SdfCommandType"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="_sdf_command_type_8h.html#4ac92492e0d58aeace1b0c0f96cefea348c2e525ef9f5e6ae1db0962a09cff37"><param name="Name" value="SdfCommandType_CreateSDFFile"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="_sdf_command_type_8h.html#4ac92492e0d58aeace1b0c0f96cefea3cff985287cc5191960dc4a2258697243"><param name="Name" value="SdfCommandType_ExtendedSelect"></OBJECT>
+ </UL>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="_sdf_command_type_8h_4ac92492e0d58aeace1b0c0f96cefea3.html#4ac92492e0d58aeace1b0c0f96cefea3"><param name="Name" value="SdfCommandType"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="_sdf_command_type_8h_4ac92492e0d58aeace1b0c0f96cefea3.html#4ac92492e0d58aeace1b0c0f96cefea348c2e525ef9f5e6ae1db0962a09cff37"><param name="Name" value="SdfCommandType_CreateSDFFile"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="_sdf_command_type_8h_4ac92492e0d58aeace1b0c0f96cefea3.html#4ac92492e0d58aeace1b0c0f96cefea3cff985287cc5191960dc4a2258697243"><param name="Name" value="SdfCommandType_ExtendedSelect"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="_sdf_compare_handler_8h.html"><param name="Name" value="SdfCompareHandler.h"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_sdf_compare_handler.html"><param name="Name" value="SdfCompareHandler"></OBJECT>
+ <UL>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_sdf_compare_handler.html#fb5771764ec97dd9888a0d243d01886b"><param name="Name" value="Compare"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_sdf_compare_handler.html#dd5c70a33541eb9eabc2d19021a768fd"><param name="Name" value="Create"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_sdf_compare_handler.html#d3a014c324bcbb6e2eccbf17ee9b43f3"><param name="Name" value="Dispose"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_sdf_compare_handler.html#c1e1a5c47894aa43ada963c4cb84b980"><param name="Name" value="~SdfCompareHandler"></OBJECT>
+ </UL>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_sdf_i_extended_select.html"><param name="Name" value="SdfIExtendedSelect"></OBJECT>
+ <UL>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_sdf_i_extended_select.html#56fb99cd7bef0a7528cf1dd408d32e16"><param name="Name" value="ClearOrderingOptions"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_sdf_i_extended_select.html#d10d84246bb47e87adb334fd6d5e8836"><param name="Name" value="ExecuteScrollable"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_sdf_i_extended_select.html#a9e4db2cb4a126bfd03259073ef74719"><param name="Name" value="GetOrderingOption"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_sdf_i_extended_select.html#69a9441cd4ada6b204a5b3ccfde49eab"><param name="Name" value="SetCompareHandler"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_sdf_i_extended_select.html#8921a5db2a527690f4d5592daa014be8"><param name="Name" value="SetOrderingOption"></OBJECT>
+ </UL>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_sdf_i_scrollable_feature_reader.html"><param name="Name" value="SdfIScrollableFeatureReader"></OBJECT>
+ <UL>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_sdf_i_scrollable_feature_reader.html#0c8bd83991d3de13ea3914e50eea68cd"><param name="Name" value="Count"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_sdf_i_scrollable_feature_reader.html#d692f60e023be7168ac6cf22d781cacd"><param name="Name" value="IndexOf"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_sdf_i_scrollable_feature_reader.html#3e1b34ea5d045715c41d232c261f9f37"><param name="Name" value="ReadAt"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_sdf_i_scrollable_feature_reader.html#1f018e50f3f7fb295d1c0968bc66aad3"><param name="Name" value="ReadAtIndex"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_sdf_i_scrollable_feature_reader.html#5b3f6fe4b58576aef1f2b3e47bd32392"><param name="Name" value="ReadFirst"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_sdf_i_scrollable_feature_reader.html#31612208adc6a6e34023b40ccbbe9ee9"><param name="Name" value="ReadLast"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_sdf_i_scrollable_feature_reader.html#8de8b2476b8dc5051c7f17f734b4693c"><param name="Name" value="ReadPrevious"></OBJECT>
+ </UL>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_sdf_i_extended_select_69a9441cd4ada6b204a5b3ccfde49eab.html#69a9441cd4ada6b204a5b3ccfde49eab"><param name="Name" value="SetCompareHandler"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_i_create_s_d_f_file_8bb4c31009cf0ab76fc094eadcf4ca91.html#8bb4c31009cf0ab76fc094eadcf4ca91"><param name="Name" value="SetCoordinateSystemWKT"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_i_create_s_d_f_file_e92b777da3c498180dd72fe4629ee788.html#e92b777da3c498180dd72fe4629ee788"><param name="Name" value="SetFileName"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_sdf_i_extended_select_8921a5db2a527690f4d5592daa014be8.html#8921a5db2a527690f4d5592daa014be8"><param name="Name" value="SetOrderingOption"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_i_create_s_d_f_file_86b4ac8510f46ad6629e42023f184cee.html#86b4ac8510f46ad6629e42023f184cee"><param name="Name" value="SetSpatialContextDescription"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_i_create_s_d_f_file_bda73a210df146335a62e933ebe19948.html#bda73a210df146335a62e933ebe19948"><param name="Name" value="SetSpatialContextName"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_i_create_s_d_f_file_b3e528dda87b952a83786b2d01343524.html#b3e528dda87b952a83786b2d01343524"><param name="Name" value="SetXYTolerance"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_i_create_s_d_f_file_2937b06fdf37207301200042b40e8d71.html#2937b06fdf37207301200042b40e8d71"><param name="Name" value="SetZTolerance"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_sdf_compare_handler_c1e1a5c47894aa43ada963c4cb84b980.html#c1e1a5c47894aa43ada963c4cb84b980"><param name="Name" value="~SdfCompareHandler"></OBJECT>
+</UL>
Added: trunk/www/docs/SDF/index.hhp
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/index.hhp?view=auto&rev=97
--- (empty file)
+++ trunk/www/docs/SDF/index.hhp 2006-12-04 18:49:20+0000
@@ -0,0 +1,93 @@
+[OPTIONS]
+Compiled file=../../SDF_Provider_API.chm
+Compatibility=1.1
+Full-text search=Yes
+Contents file=index.hhc
+Default Window=main
+Default topic=main.html
+Index file=index.hhk
+Language=0x409 English (United States)
+Binary TOC=YES
+Title=FDO Provider for SDF
+[WINDOWS]
+main="FDO Provider for SDF","index.hhc","index.hhk","main.html","main.html",,,,,0x23520,,0x387e,,,,,,,,0
+[FILES]
+main.html
+files.html
+define__pages_8h-source.html
+_i_create_s_d_f_file_8h-source.html
+_i_extended_select_8h-source.html
+_i_scrollable_feature_reader_8h-source.html
+_sdf_command_type_8h-source.html
+_sdf_compare_handler_8h-source.html
+define__pages_8h.html
+_i_create_s_d_f_file_8h.html
+_i_extended_select_8h.html
+_i_scrollable_feature_reader_8h.html
+_sdf_command_type_8h.html
+_sdf_command_type_8h_86597e57635d4329ec6b9d0a67f969d7.html
+_sdf_command_type_8h_4ac92492e0d58aeace1b0c0f96cefea3.html
+_sdf_compare_handler_8h.html
+_sdf_compare_handler_8h_9bfa9402971b67602a99fd99449c5d76.html
+annotated.html
+classes.html
+hierarchy.html
+functions.html
+functions_func.html
+class_fdo_i_create_s_d_f_file.html
+class_fdo_i_create_s_d_f_file_05550ca7007c3e389b7029c41baa1587.html
+class_fdo_i_create_s_d_f_file_0b8020c31deb9acc05311fd11f260c7d.html
+class_fdo_i_create_s_d_f_file_0bde059736005f052076c6735c8b2453.html
+class_fdo_i_create_s_d_f_file_4d74d6f8e45e76d8c8606953ae4cb307.html
+class_fdo_i_create_s_d_f_file_647ff5d7f47cf47422c32645074cce8d.html
+class_fdo_i_create_s_d_f_file_4a2bb60374b5db4f9dca173de2845803.html
+class_fdo_i_create_s_d_f_file_8b2fc8bbd39311d609c316fac75d765b.html
+class_fdo_i_create_s_d_f_file_8bb4c31009cf0ab76fc094eadcf4ca91.html
+class_fdo_i_create_s_d_f_file_e92b777da3c498180dd72fe4629ee788.html
+class_fdo_i_create_s_d_f_file_86b4ac8510f46ad6629e42023f184cee.html
+class_fdo_i_create_s_d_f_file_bda73a210df146335a62e933ebe19948.html
+class_fdo_i_create_s_d_f_file_b3e528dda87b952a83786b2d01343524.html
+class_fdo_i_create_s_d_f_file_2937b06fdf37207301200042b40e8d71.html
+class_fdo_i_create_s_d_f_file-members.html
+class_sdf_compare_handler.html
+class_sdf_compare_handler_c1e1a5c47894aa43ada963c4cb84b980.html
+class_sdf_compare_handler_fb5771764ec97dd9888a0d243d01886b.html
+class_sdf_compare_handler_5da8124ec6d48c42207912cb1004168c.html
+class_sdf_compare_handler_3ade9dcf05112bb16590f695c022a474.html
+class_sdf_compare_handler_25efcd708f7d73df47e3f592a4dc9df2.html
+class_sdf_compare_handler_3a1cda4006166f838c9c90dbbd16daf5.html
+class_sdf_compare_handler_fba0af521a5201a71547bce66c36f583.html
+class_sdf_compare_handler_e99c60fe9321858c35f204003e06954c.html
+class_sdf_compare_handler_4b9fe2c6a37153efe808fbe7b9cfac39.html
+class_sdf_compare_handler_dd5c70a33541eb9eabc2d19021a768fd.html
+class_sdf_compare_handler_d3a014c324bcbb6e2eccbf17ee9b43f3.html
+class_sdf_compare_handler-members.html
+class_sdf_i_extended_select.html
+class_sdf_i_extended_select_56fb99cd7bef0a7528cf1dd408d32e16.html
+class_sdf_i_extended_select_d10d84246bb47e87adb334fd6d5e8836.html
+class_sdf_i_extended_select_7094d0597a2dec8f759b553af3c5aebd.html
+class_sdf_i_extended_select_a9e4db2cb4a126bfd03259073ef74719.html
+class_sdf_i_extended_select_69a9441cd4ada6b204a5b3ccfde49eab.html
+class_sdf_i_extended_select_8921a5db2a527690f4d5592daa014be8.html
+class_sdf_i_extended_select-members.html
+class_sdf_i_scrollable_feature_reader.html
+class_sdf_i_scrollable_feature_reader_0c8bd83991d3de13ea3914e50eea68cd.html
+class_sdf_i_scrollable_feature_reader_d692f60e023be7168ac6cf22d781cacd.html
+class_sdf_i_scrollable_feature_reader_3e1b34ea5d045715c41d232c261f9f37.html
+class_sdf_i_scrollable_feature_reader_1f018e50f3f7fb295d1c0968bc66aad3.html
+class_sdf_i_scrollable_feature_reader_5b3f6fe4b58576aef1f2b3e47bd32392.html
+class_sdf_i_scrollable_feature_reader_31612208adc6a6e34023b40ccbbe9ee9.html
+class_sdf_i_scrollable_feature_reader_8de8b2476b8dc5051c7f17f734b4693c.html
+class_sdf_i_scrollable_feature_reader-members.html
+globals.html
+globals_enum.html
+globals_eval.html
+globals_defs.html
+graph_legend.html
+inherits.html
+tabs.css
Added: trunk/www/docs/SDF/index.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/index.html?view=auto&rev=97
--- (empty file)
+++ trunk/www/docs/SDF/index.html 2006-12-04 18:49:20+0000
@@ -0,0 +1,8 @@
+<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
+<html><head><meta http-equiv="Content-Type" content="text/html;charset=iso-8859-1">
+<title>FDO Provider for SDF</title></head>
+<frameset cols="250,*">
+ <frame src="tree.html" name="treefrm">
+ <frame src="main.html" name="basefrm">
+</frameset>
+</html>
Added: trunk/www/docs/SDF/inherit__graph__0.map
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/inherit__graph__0.map?view=auto&rev=97
--- (empty file)
+++ trunk/www/docs/SDF/inherit__graph__0.map 2006-12-04 18:49:20+0000
@@ -0,0 +1,2 @@
+base referer
+rect $class_fdo_i_create_s_d_f_file.html 7,7 145,33
Added: trunk/www/docs/SDF/inherit__graph__0.md5
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/inherit__graph__0.md5?view=auto&rev=97
--- (empty file)
+++ trunk/www/docs/SDF/inherit__graph__0.md5 2006-12-04 18:49:20+0000
@@ -0,0 +1 @@
+b1661466bf076ac9f54d14627d06032d
\ No newline at end of file
Added: trunk/www/docs/SDF/inherit__graph__0.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/inherit__graph__0.png?view=auto&rev=97
Added: trunk/www/docs/SDF/inherit__graph__1.map
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/inherit__graph__1.map?view=auto&rev=97
--- (empty file)
+++ trunk/www/docs/SDF/inherit__graph__1.map 2006-12-04 18:49:20+0000
@@ -0,0 +1,2 @@
+base referer
+rect $class_sdf_compare_handler.html 7,7 151,33
Added: trunk/www/docs/SDF/inherit__graph__1.md5
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/inherit__graph__1.md5?view=auto&rev=97
--- (empty file)
+++ trunk/www/docs/SDF/inherit__graph__1.md5 2006-12-04 18:49:20+0000
@@ -0,0 +1 @@
+029bf9cda700dadbc0efdb3ba9e5d079
Added: trunk/www/docs/SDF/inherit__graph__1.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/inherit__graph__1.png?view=auto&rev=97
Added: trunk/www/docs/SDF/inherit__graph__2.map
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/inherit__graph__2.map?view=auto&rev=97
--- (empty file)
+++ trunk/www/docs/SDF/inherit__graph__2.map 2006-12-04 18:49:20+0000
@@ -0,0 +1,2 @@
+base referer
+rect $class_sdf_i_extended_select.html 8,7 147,33
Added: trunk/www/docs/SDF/inherit__graph__2.md5
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/inherit__graph__2.md5?view=auto&rev=97
--- (empty file)
+++ trunk/www/docs/SDF/inherit__graph__2.md5 2006-12-04 18:49:20+0000
@@ -0,0 +1 @@
+d88ffb3ec8f32a714182eadf656f907a
Added: trunk/www/docs/SDF/inherit__graph__2.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/inherit__graph__2.png?view=auto&rev=97
Added: trunk/www/docs/SDF/inherit__graph__3.map
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/inherit__graph__3.map?view=auto&rev=97
--- (empty file)
+++ trunk/www/docs/SDF/inherit__graph__3.map 2006-12-04 18:49:20+0000
@@ -0,0 +1,2 @@
+base referer
+rect $class_sdf_i_scrollable_feature_reader.html 7,7 201,33
Added: trunk/www/docs/SDF/inherit__graph__3.md5
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/inherit__graph__3.md5?view=auto&rev=97
--- (empty file)
+++ trunk/www/docs/SDF/inherit__graph__3.md5 2006-12-04 18:49:20+0000
@@ -0,0 +1 @@
+bddb4d26caf3c87c319b7b7a29a8903d
Added: trunk/www/docs/SDF/inherit__graph__3.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/inherit__graph__3.png?view=auto&rev=97
Added: trunk/www/docs/SDF/inherits.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/inherits.html?view=auto&rev=97
--- (empty file)
+++ trunk/www/docs/SDF/inherits.html 2006-12-04 18:49:20+0000
@@ -0,0 +1,61 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ <li><a href="files.html"><span>Files</span></a></li>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<h1>FDO Provider for SDF Graphical Class Hierarchy</h1><a href="hierarchy.html">Go to the textual class hierarchy</a>
+<p>
+<table border="0" cellspacing="10" cellpadding="0">
+<tr><td><img src="inherit__graph__0.png" border="0" alt="" usemap="#_fdo_i_create_s_d_f_file_map">
+<map name="_fdo_i_create_s_d_f_file_map">
+<area href="class_fdo_i_create_s_d_f_file.html" shape="rect" coords="7,7,145,33" alt="">
+</map></td></tr>
+<tr><td><img src="inherit__graph__1.png" border="0" alt="" usemap="#_sdf_compare_handler_map">
+<map name="_sdf_compare_handler_map">
+<area href="class_sdf_compare_handler.html" shape="rect" coords="7,7,151,33" alt="">
+</map></td></tr>
+<tr><td><img src="inherit__graph__2.png" border="0" alt="" usemap="#_sdf_i_extended_select_map">
+<map name="_sdf_i_extended_select_map">
+<area href="class_sdf_i_extended_select.html" shape="rect" coords="8,7,147,33" alt="">
+</map></td></tr>
+<tr><td><img src="inherit__graph__3.png" border="0" alt="" usemap="#_sdf_i_scrollable_feature_reader_map">
+<map name="_sdf_i_scrollable_feature_reader_map">
+<area href="class_sdf_i_scrollable_feature_reader.html" shape="rect" coords="7,7,201,33" alt="">
+</map></td></tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SDF/main.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/main.html?view=auto&rev=97
--- (empty file)
+++ trunk/www/docs/SDF/main.html 2006-12-04 18:49:20+0000
@@ -0,0 +1,55 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ <li id="current"><a href="main.html"><span>Main Page</span></a></li>
+ </ul></div>
+<h1>Introduction</h1>
+<p>
+<div class="mainpage"></div><p>
+<div class="mainpage">The Feature Data Objects (FDO) API provides access to data in a data store. A provider is a specific implementation of the FDO API that provides access to data in a particular data store. The FDO Provider for SDF provides FDO with access to an SDF-based data store.</div><p>
+<div class="mainpage">The FDO Provider for SDF uses Autodesk's spatial database format, which is a file-based personal geodatabase that supports multiple features/attributes, spatial indexing, interoperability, file-locking, and high performance for large data sets. </div><p>
+<div class="mainpage">The SDF file format has the following characteristics: </div><p>
+<div class="mainpage"><ul>
+<li>
+SDF files can be read on different platforms. </li>
+<li>
+The SDF file format has its own spatial indexing. </li>
+<li>
+SDF files can store geometric and non-geometric data with minimum overhead </li>
+<li>
+Although it does not support concurrency control (locking), the SDF file format is a valid alternative to RDBMS. </li>
+</ul>
+</div><p>
+<div class="mainpage"> For more information, see <em>The Essential FDO</em> (FET_TheEssentialFDO.pdf) and the <em>FDO Developer's Guide</em> (FDG_FDODevGuide.pdf). </div><p>
+<div class="mainpage"><br>
+ </div> <!-- footer.html -->
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SDF/tab_b.gif
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/tab_b.gif?view=auto&rev=97
Added: trunk/www/docs/SDF/tab_l.gif
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/tab_l.gif?view=auto&rev=97
Added: trunk/www/docs/SDF/tab_r.gif
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/tab_r.gif?view=auto&rev=97
Added: trunk/www/docs/SDF/tabs.css
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/tabs.css?view=auto&rev=97
--- (empty file)
+++ trunk/www/docs/SDF/tabs.css 2006-12-04 18:49:20+0000
@@ -0,0 +1,102 @@
+/* tabs styles, based on http://www.alistapart.com/articles/slidingdoors */
+DIV.tabs
+ float : left;
+ width : 100%;
+ background : url("tab_b.gif") repeat-x bottom;
+ margin-bottom : 4px;
+DIV.tabs UL
+ margin : 0px;
+ padding-left : 10px;
+ list-style : none;
+DIV.tabs LI, DIV.tabs FORM
+ display : inline;
+ margin : 0px;
+ padding : 0px;
+DIV.tabs FORM
+ float : right;
+DIV.tabs A
+ float : left;
+ background : url("tab_r.gif") no-repeat right top;
+ border-bottom : 1px solid #84B0C7;
+ font-size : x-small;
+ font-weight : bold;
+ text-decoration : none;
+DIV.tabs A:hover
+ background-position: 100% -150px;
+DIV.tabs A:link, DIV.tabs A:visited,
+DIV.tabs A:active, DIV.tabs A:hover
+ color: #1A419D;
+DIV.tabs SPAN
+ float : left;
+ display : block;
+ background : url("tab_l.gif") no-repeat left top;
+ padding : 5px 9px;
+ white-space : nowrap;
+DIV.tabs INPUT
+ float : right;
+ display : inline;
+ font-size : 1em;
+DIV.tabs TD
+/* Commented Backslash Hack hides rule from IE5-Mac \*/
+DIV.tabs SPAN {float : none;}
+/* End IE5-Mac hack */
+DIV.tabs A:hover SPAN
+ background-position: 0% -150px;
+DIV.tabs LI#current A
+ border-width : 0px;
+DIV.tabs LI#current SPAN
+ padding-bottom : 6px;
+DIV.nav
+ background : none;
+ border : none;
Added: trunk/www/docs/SDF/tree.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/tree.html?view=auto&rev=97
--- (empty file)
+++ trunk/www/docs/SDF/tree.html 2006-12-04 18:49:20+0000
@@ -0,0 +1,105 @@
+<html xmlns="http://www.w3.org/1999/xhtml" xml:lang="en" lang="en">
+ <head>
+ <meta http-equiv="Content-Type" content="text/xhtml;charset=iso-8859-1" />
+ <meta http-equiv="Content-Style-Type" content="text/css" />
+ <meta http-equiv="Content-Language" content="en" />
+ <link rel="stylesheet" href="custom.css">
+ <title>TreeView</title>
+ <style type="text/css">
+ .directory { font-size: 10pt; font-weight: bold; }
+ .directory h3 { margin: 0px; margin-top: 1em; font-size: 11pt; }
+ .directory p { margin: 0px; white-space: nowrap; }
+ .directory div { display: none; margin: 0px; }
+ .directory img { vertical-align: middle; }
+ </style>
+ <script type="text/javascript">
+ <!-- // Hide script from old browsers
+ function toggleFolder(id, imageNode)
+ var folder = document.getElementById(id);
+ var l = imageNode.src.length;
+ if (imageNode.src.substring(l-20,l)=="ftv2folderclosed.png" ||
+ imageNode.src.substring(l-18,l)=="ftv2folderopen.png")
+ imageNode = imageNode.previousSibling;
+ l = imageNode.src.length;
+ if (folder == null)
+ else if (folder.style.display == "block")
+ if (imageNode != null)
+ imageNode.nextSibling.src = "ftv2folderclosed.png";
+ if (imageNode.src.substring(l-13,l) == "ftv2mnode.png")
+ imageNode.src = "ftv2pnode.png";
+ else if (imageNode.src.substring(l-17,l) == "ftv2mlastnode.png")
+ imageNode.src = "ftv2plastnode.png";
+ folder.style.display = "none";
+ else
+ imageNode.nextSibling.src = "ftv2folderopen.png";
+ if (imageNode.src.substring(l-13,l) == "ftv2pnode.png")
+ imageNode.src = "ftv2mnode.png";
+ else if (imageNode.src.substring(l-17,l) == "ftv2plastnode.png")
+ imageNode.src = "ftv2mlastnode.png";
+ folder.style.display = "block";
+ // End script hiding -->
+ </script>
+ </head>
+ <body>
+ <div class="directory">
+ <h3>FDO Provider for SDF</h3>
+ <div style="display: block;">
+ <p><img src="ftv2node.png" alt="o" width=16 height=22 /><img src="ftv2doc.png" alt="*" width=24 height=22 /><a class="el" href="main.html" target="basefrm">Introduction</a></p>
+ <p><img src="ftv2pnode.png" alt="o" width=16 height=22 onclick="toggleFolder('folder1', this)"/><img src="ftv2folderclosed.png" alt="+" width=24 height=22 onclick="toggleFolder('folder1', this)"/><a class="el" href="files.html" target="basefrm">File List</a></p>
+ <div id="folder1">
+ <p><img src="ftv2vertline.png" alt="|" width=16 height=22 /><img src="ftv2node.png" alt="o" width=16 height=22 /><img src="ftv2doc.png" alt="*" width=24 height=22 /><a class="el" href="define__pages_8h.html" target="basefrm">define_pages.h</a></p>
+ <p><img src="ftv2vertline.png" alt="|" width=16 height=22 /><img src="ftv2node.png" alt="o" width=16 height=22 /><img src="ftv2doc.png" alt="*" width=24 height=22 /><a class="el" href="_i_create_s_d_f_file_8h.html" target="basefrm">ICreateSDFFile.h</a></p>
+ <p><img src="ftv2vertline.png" alt="|" width=16 height=22 /><img src="ftv2node.png" alt="o" width=16 height=22 /><img src="ftv2doc.png" alt="*" width=24 height=22 /><a class="el" href="_i_extended_select_8h.html" target="basefrm">IExtendedSelect.h</a></p>
+ <p><img src="ftv2vertline.png" alt="|" width=16 height=22 /><img src="ftv2node.png" alt="o" width=16 height=22 /><img src="ftv2doc.png" alt="*" width=24 height=22 /><a class="el" href="_i_scrollable_feature_reader_8h.html" target="basefrm">IScrollableFeatureReader.h</a></p>
+ <p><img src="ftv2vertline.png" alt="|" width=16 height=22 /><img src="ftv2node.png" alt="o" width=16 height=22 /><img src="ftv2doc.png" alt="*" width=24 height=22 /><a class="el" href="_sdf_command_type_8h.html" target="basefrm">SdfCommandType.h</a></p>
+ <p><img src="ftv2vertline.png" alt="|" width=16 height=22 /><img src="ftv2lastnode.png" alt="\" width=16 height=22 /><img src="ftv2doc.png" alt="*" width=24 height=22 /><a class="el" href="_sdf_compare_handler_8h.html" target="basefrm">SdfCompareHandler.h</a></p>
+ </div>
+ <p><img src="ftv2pnode.png" alt="o" width=16 height=22 onclick="toggleFolder('folder2', this)"/><img src="ftv2folderclosed.png" alt="+" width=24 height=22 onclick="toggleFolder('folder2', this)"/><a class="el" href="annotated.html" target="basefrm">Class List</a></p>
+ <div id="folder2">
+ <p><img src="ftv2vertline.png" alt="|" width=16 height=22 /><img src="ftv2node.png" alt="o" width=16 height=22 /><img src="ftv2doc.png" alt="*" width=24 height=22 /><a class="el" href="class_fdo_i_create_s_d_f_file.html" target="basefrm">FdoICreateSDFFile</a></p>
+ <p><img src="ftv2vertline.png" alt="|" width=16 height=22 /><img src="ftv2node.png" alt="o" width=16 height=22 /><img src="ftv2doc.png" alt="*" width=24 height=22 /><a class="el" href="class_sdf_compare_handler.html" target="basefrm">SdfCompareHandler</a></p>
+ <p><img src="ftv2vertline.png" alt="|" width=16 height=22 /><img src="ftv2node.png" alt="o" width=16 height=22 /><img src="ftv2doc.png" alt="*" width=24 height=22 /><a class="el" href="class_sdf_i_extended_select.html" target="basefrm">SdfIExtendedSelect</a></p>
+ <p><img src="ftv2vertline.png" alt="|" width=16 height=22 /><img src="ftv2lastnode.png" alt="\" width=16 height=22 /><img src="ftv2doc.png" alt="*" width=24 height=22 /><a class="el" href="class_sdf_i_scrollable_feature_reader.html" target="basefrm">SdfIScrollableFeatureReader</a></p>
+ </div>
+ <p><img src="ftv2pnode.png" alt="o" width=16 height=22 onclick="toggleFolder('folder3', this)"/><img src="ftv2folderclosed.png" alt="+" width=24 height=22 onclick="toggleFolder('folder3', this)"/><a class="el" href="hierarchy.html" target="basefrm">Class Hierarchy</a></p>
+ <div id="folder3">
+ </div>
+ <p><img src="ftv2node.png" alt="o" width=16 height=22 /><img src="ftv2doc.png" alt="*" width=24 height=22 /><a class="el" href="functions.html" target="basefrm">Class Members</a></p>
+ <p><img src="ftv2node.png" alt="o" width=16 height=22 /><img src="ftv2doc.png" alt="*" width=24 height=22 /><a class="el" href="globals.html" target="basefrm">File Members</a></p>
+ <p><img src="ftv2lastnode.png" alt="\" width=16 height=22 /><img src="ftv2doc.png" alt="*" width=24 height=22 /><a class="el" href="inherits.html" target="basefrm">Graphical Class Hierarchy</a></p>
+ </div>
+ </div>
+ </body>
+</html>
More information about the Fdo-commits
