svn commit: r105 - trunk/www/docs/OpenSourceBuild__README.html
gregboone at osgeo.org gregboone at osgeo.org
Mon Dec 4 14:23:29 EST 2006
Author: gregboone
Date: 2006-12-04 19:23:29+0000
New Revision: 105
FDO111: Update FDO Web Documentation (3.2.0)
Modified: trunk/www/docs/OpenSourceBuild__README.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/OpenSourceBuild__README.html?view=diff&rev=105&p1=trunk/www/docs/OpenSourceBuild__README.html&p2=trunk/www/docs/OpenSourceBuild__README.html&r1=104&r2=105
--- trunk/www/docs/OpenSourceBuild__README.html	(original)
+++ trunk/www/docs/OpenSourceBuild__README.html	2006-12-04 19:23:29+0000
@@ -321,63 +321,64 @@
         MySql:
             cd [FDO OpenSource]\Providers\GenericRdbms\Src\UnitTest
-				-  If you wish to run the MySql unit tests without specifying
-				   an initialization file, update the default initialization file
-				   "MySqlInit.txt" file with valid values for username, password and service
-				   for the service against which the unit tests should be executed and
-				   run "Dbg\UnitTestMySql.exe" with no additional parameters.
-				   NOTE: Do not drop MySqlInit.txt in subversion if you choose to modify it
-				-  If you wish to run the unit test and specify your own
-				   initialization file, create your the file with valid values for username,
-				   password and service and run the unit test by specifying the initialization file
-				   on the command line when executing the unit tests.
-				   e.g. Dbg\UnitTestMySql.exe initfiletest=MySqlInitEx.txt
-				   NOTE: The initialization file must contain values for service, username and password.
-				   e.g.: service=mysqlserver;username=root;password=xxxx;
+			If you wish to run the MySql unit tests without specifying
+			an initialization file, update the default initialization file
+			"MySqlInit.txt" file with valid values for username, password and service
+			for the service against which the unit tests should be executed and
+			run "Dbg\UnitTestMySql.exe" with no additional parameters.
+			NOTE: Do not drop MySqlInit.txt in subversion if you choose to modify it
+			If you wish to run the unit test and specify your own
+			initialization file, create your the file with valid values for username,
+			password and service and run the unit test by specifying the initialization file
+			on the command line when executing the unit tests.
+			e.g. Dbg\UnitTestMySql.exe initfiletest=MySqlInitEx.txt
+			NOTE: The initialization file must contain values for service, username and password.
+			e.g.: service=mysqlserver;username=root;password=xxxx;
         Odbc:
- 				-  If you wish to run the ODBC unit tests without specifying
-				   "OdbcInit.txt" file with valid values for username, password and service
-				   for the services against which the unit tests should be executed and
-				   run "Dbg\UnitTestOdbc.exe" with no additional parameters.
+ 			If you wish to run the ODBC unit tests without specifying
+			"OdbcInit.txt" file with valid values for username, password and service
+			for the services against which the unit tests should be executed and
+			run "Dbg\UnitTestOdbc.exe" with no additional parameters.
-				   NOTE: Do not drop OdbcInit.txt in subversion if you choose to modify it
+			NOTE: Do not drop OdbcInit.txt in subversion if you choose to modify it
-				   password and the service names. Run the unit test by specifying the
-				   initialization file on the command line when executing the unit tests.
-				   e.g. Dbg\UnitTestOdbc.exe initfiletest=OdbcInitEx.txt
-				   The initialization file must contain service, username and password for each server type
-				   DSN name can be specified using DSNOracle, DSNMySql, DSNSqlServer
-				   e.g.:
-                        serviceOracle=oraserver;usernameOracle=xxxx;passwordOracle=xxxx;DSNOracle=ORACLExxx;
-                        serviceMySql=mysqlserver;usernameMySql=root;passwordMySql=xxxx;DSNMySql=MySQLxxx;
-                        serviceSqlServer=sqlserver;usernameSqlServer=xxxx;passwordSqlServer=xxxx;DSNSqlServer=SqlServerxxx;
-                  NOTE: You can also run the unit tests separately for each ODBC subtype:
-                        MySql:       Dbg\UnitTestOdbc.exe OdbcMySqlTests
-                        Oracle:      Dbg\UnitTestOdbc.exe OdbcOracleTests
-                        SqlServer:   Dbg\UnitTestOdbc.exe OdbcSqlServerTests
-                        Access:      Dbg\UnitTestOdbc.exe OdbcAccessTests
-                        Excel:       Dbg\UnitTestOdbc.exe OdbcExcelTests
-                        Text:        Dbg\UnitTestOdbc.exe OdbcTextTests
+			password and the service names. Run the unit test by specifying the
+			initialization file on the command line when executing the unit tests.
+			e.g. Dbg\UnitTestOdbc.exe initfiletest=OdbcInitEx.txt
+			The initialization file must contain service, username and password for each server type
+			DSN name can be specified using DSNOracle, DSNMySql, DSNSqlServer
+			e.g.:
+            serviceOracle=oraserver;usernameOracle=xxxx;passwordOracle=xxxx;DSNOracle=ORACLExxx;
+            serviceMySql=mysqlserver;usernameMySql=root;passwordMySql=xxxx;DSNMySql=MySQLxxx;
+            serviceSqlServer=sqlserver;usernameSqlServer=xxxx;passwordSqlServer=xxxx;DSNSqlServer=SqlServerxxx;
+            NOTE: You can also run the unit tests separately for each ODBC subtype:
+            MySql:       Dbg\UnitTestOdbc.exe OdbcMySqlTests
+            Oracle:      Dbg\UnitTestOdbc.exe OdbcOracleTests
+            SqlServer:   Dbg\UnitTestOdbc.exe OdbcSqlServerTests
+            Access:      Dbg\UnitTestOdbc.exe OdbcAccessTests
+            Excel:       Dbg\UnitTestOdbc.exe OdbcExcelTests
+            Text:        Dbg\UnitTestOdbc.exe OdbcTextTests
 Linux Instructions
@@ -639,60 +640,60 @@
             cd [FDO OpenSource]/Providers/GenericRdbms/Src/UnitTest
-				   run ./UnitTestMySql with no additional parameters.
-				   e.g. ./UnitTestMySql initfiletest=MySqlInitEx.txt
+			run ./UnitTestMySql with no additional parameters.
+			e.g. ./UnitTestMySql initfiletest=MySqlInitEx.txt
         Odbc:
- 				-  you must have the DSN created before you will run the unit tests.
- 				-  DSN name can be specified using DSNOracle, DSNMySql, DSNSqlServer
-				   run ./UnitTestOdbc with no additional parameters.
-				   e.g. ./UnitTestOdbc initfiletest=OdbcInitEx.txt
-				   e.g.:
-                        serviceOracle=oraserver;usernameOracle=xxxx;passwordOracle=xxxx;DSNOracle=ORACLE;
-                        serviceMySql=mysqlserver;usernameMySql=root;passwordMySql=xxxx;DSNMySql=MySQL;
+ 			you must have the DSN created before you will run the unit tests.
-                        MySql:       ./UnitTestOdbc OdbcMySqlTests
-                        Oracle:      ./UnitTestOdbc OdbcOracleTests
+			run ./UnitTestOdbc with no additional parameters.
+			e.g. ./UnitTestOdbc initfiletest=OdbcInitEx.txt
+			e.g.:
+			serviceOracle=oraserver;usernameOracle=xxxx;passwordOracle=xxxx;DSNOracle=ORACLE;
+            serviceMySql=mysqlserver;usernameMySql=root;passwordMySql=xxxx;DSNMySql=MySQL;
+            MySql:   ./UnitTestOdbc OdbcMySqlTests
+            Oracle:  ./UnitTestOdbc OdbcOracleTests
 [end]
 </pre>
More information about the Fdo-commits mailing list
