svn commit: r107 - trunk/www/docs/OpenSourceBuild__README.html
    gregboone at osgeo.org
    Mon Dec  4 14:36:41 EST 2006
Author: gregboone
Date: 2006-12-04 19:36:41+0000
New Revision: 107
FDO111: Update FDO Web Documentation (3.2.0)
Modified: trunk/www/docs/OpenSourceBuild__README.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/OpenSourceBuild__README.html?view=diff&rev=107&p1=trunk/www/docs/OpenSourceBuild__README.html&p2=trunk/www/docs/OpenSourceBuild__README.html&r1=106&r2=107
--- trunk/www/docs/OpenSourceBuild__README.html	(original)
+++ trunk/www/docs/OpenSourceBuild__README.html	2006-12-04 19:36:41+0000
@@ -321,58 +321,58 @@
         MySql:
             cd [FDO OpenSource]\Providers\GenericRdbms\Src\UnitTest
-			If you wish to run the MySql unit tests without specifying
-			an initialization file, update the default initialization file
-			"MySqlInit.txt" file with valid values for username, password and service
-			for the service against which the unit tests should be executed and
-			run "Dbg\UnitTestMySql.exe" with no additional parameters.
-			NOTE: Do not drop MySqlInit.txt in subversion if you choose to modify it
-			If you wish to run the unit test and specify your own
-			initialization file, create your the file with valid values for username,
-			password and service and run the unit test by specifying the initialization file
-			on the command line when executing the unit tests.
-			e.g. Dbg\UnitTestMySql.exe initfiletest=MySqlInitEx.txt
-			NOTE: The initialization file must contain values for service, username and password.
-			e.g.: service=mysqlserver;username=root;password=xxxx;
+            If you wish to run the MySql unit tests without specifying
+            an initialization file, update the default initialization file
+            "MySqlInit.txt" file with valid values for username, password and service
+            for the service against which the unit tests should be executed and
+            run "Dbg\UnitTestMySql.exe" with no additional parameters.
+            NOTE: Do not drop MySqlInit.txt in subversion if you choose to modify it
+            If you wish to run the unit test and specify your own
+            initialization file, create your the file with valid values for username,
+            password and service and run the unit test by specifying the initialization file
+            on the command line when executing the unit tests.
+            e.g. Dbg\UnitTestMySql.exe initfiletest=MySqlInitEx.txt
+            NOTE: The initialization file must contain values for service, username and password.
+            e.g.: service=mysqlserver;username=root;password=xxxx;
         Odbc:
- 			If you wish to run the ODBC unit tests without specifying
-			"OdbcInit.txt" file with valid values for username, password and service
-			for the services against which the unit tests should be executed and
-			run "Dbg\UnitTestOdbc.exe" with no additional parameters.
+            If you wish to run the ODBC unit tests without specifying
+            "OdbcInit.txt" file with valid values for username, password and service
+            for the services against which the unit tests should be executed and
+            run "Dbg\UnitTestOdbc.exe" with no additional parameters.
-			NOTE: Do not drop OdbcInit.txt in subversion if you choose to modify it
+            NOTE: Do not drop OdbcInit.txt in subversion if you choose to modify it
-			password and the service names. Run the unit test by specifying the
-			initialization file on the command line when executing the unit tests.
+            password and the service names. Run the unit test by specifying the
+            initialization file on the command line when executing the unit tests.
-			e.g. Dbg\UnitTestOdbc.exe initfiletest=OdbcInitEx.txt
+            e.g. Dbg\UnitTestOdbc.exe initfiletest=OdbcInitEx.txt
-			The initialization file must contain service, username and password for each server type
-			DSN name can be specified using DSNOracle, DSNMySql, DSNSqlServer
-			e.g.:
+            The initialization file must contain service, username and password for each server type
+            DSN name can be specified using DSNOracle, DSNMySql, DSNSqlServer
+            e.g.:
             serviceOracle=oraserver;usernameOracle=xxxx;passwordOracle=xxxx;DSNOracle=ORACLExxx;
             serviceMySql=mysqlserver;usernameMySql=root;passwordMySql=xxxx;DSNMySql=MySQLxxx;
             serviceSqlServer=sqlserver;usernameSqlServer=xxxx;passwordSqlServer=xxxx;DSNSqlServer=SqlServerxxx;
             NOTE: You can also run the unit tests separately for each ODBC subtype:
             MySql:       Dbg\UnitTestOdbc.exe OdbcMySqlTests
             Oracle:      Dbg\UnitTestOdbc.exe OdbcOracleTests
             SqlServer:   Dbg\UnitTestOdbc.exe OdbcSqlServerTests
@@ -640,58 +640,58 @@
             cd [FDO OpenSource]/Providers/GenericRdbms/Src/UnitTest
-			run ./UnitTestMySql with no additional parameters.
-			e.g. ./UnitTestMySql initfiletest=MySqlInitEx.txt
+            run ./UnitTestMySql with no additional parameters.
+            e.g. ./UnitTestMySql initfiletest=MySqlInitEx.txt
         Odbc:
- 			you must have the DSN created before you will run the unit tests.
+            you must have the DSN created before you will run the unit tests.
-			run ./UnitTestOdbc with no additional parameters.
+            run ./UnitTestOdbc with no additional parameters.
-			e.g. ./UnitTestOdbc initfiletest=OdbcInitEx.txt
-			e.g.:
-			serviceOracle=oraserver;usernameOracle=xxxx;passwordOracle=xxxx;DSNOracle=ORACLE;
+            e.g. ./UnitTestOdbc initfiletest=OdbcInitEx.txt
+            e.g.:
+            serviceOracle=oraserver;usernameOracle=xxxx;passwordOracle=xxxx;DSNOracle=ORACLE;
             serviceMySql=mysqlserver;usernameMySql=root;passwordMySql=xxxx;DSNMySql=MySQL;
-			NOTE: You can also run the unit tests separately for each ODBC subtype:
+            NOTE: You can also run the unit tests separately for each ODBC subtype:
             MySql:   ./UnitTestOdbc OdbcMySqlTests
             Oracle:  ./UnitTestOdbc OdbcOracleTests
More information about the Fdo-commits
