svn commit: r30 - trunk/www/docs
donaldcameron at osgeo.org
Fri Jul 14 15:48:41 EDT 2006
Author: donaldcameron
Date: 2006-07-14 19:48:41+0000
New Revision: 30
Added:
trunk/www/docs/BuildFDOOpenSource.pdf (contents, props changed)
trunk/www/docs/OpenSourceBuild__README.html
FDO2
July 2006 website release
Added: trunk/www/docs/BuildFDOOpenSource.pdf
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/BuildFDOOpenSource.pdf?view=auto&rev=30
Binary file. No diff available.
Added: trunk/www/docs/OpenSourceBuild__README.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/OpenSourceBuild__README.html?view=auto&rev=30
--- (empty file)
+++ trunk/www/docs/OpenSourceBuild__README.html 2006-07-14 19:48:41+0000
@@ -0,0 +1,509 @@
+<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
+<html xmlns="http://www.w3.org/1999/xhtml">
+<head>
+ <meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1" />
+ <link href="styles/projectcontent.css" rel="stylesheet" type="text/css">
+ <title>FDO Open Source - Build README</title>
+</head>
+<body>
+<pre>
+Feature Data Objects (FDO) OpenSource README
+This ReadMe contains important information required to build FDO open source.
+Ensure you read through this document before building.
+Contents:
+Windows Instructions
+ - Windows Notes
+ - Windows Build Instructions
+Linux Instructions
+ - Linux Notes
+ - Linux Build Instructions
+I. Windows Notes:
+ In preparation for building the Windows Open Source FDO Binaries
+ 1. Ensure that the Windows Environment Variables are set as follows:
+ SET FDO=<FDO OpenSource>\Fdo
+ SET FDOUTILITIES=<FDO OpenSource>\Utilities
+ SET FDOTHIRDPARTY=<FDO OpenSource>\ThirdParty
+ SET XALANROOT=%FDOTHIRDPARTY%\apache\xml-xalan\c
+ SET XERCESCROOT=%FDOTHIRDPARTY%\apache\xml-xerces\c
+ SET NLSDIR=%XALANROOT%\Src\xalanc\NLS
+ 2. In order to build The FDO Thirdparty OpenSSL components, be sure to
+ install ActiveState Perl, available from:
+ http://www.activestate.com/ActivePerl
+ 3. In order to build all FDO Windows components, ensure that the Microsoft
+ MsBuild tool that is used by the the FDO build process is included in
+ the Windows system PATH.
+ set PATH=%PATH%;C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727
+ 4. In order to build the ArcSDE Provider, you will need to have the
+ ArcSDE 9.1 Client SDK installed and the following environment variable
+ set that points to the installation location:
+ set SDEHOME=<ArcSDE developer components path>
+ Note that ArcSDE is licensed software and must be obtained from an ESRI vendor.
+ 5. In order to build the MySQL Provider, you will need to download
+ and install the MySQL 5.0 Windows client and developer components from:
+ http://dev.mysql.com/downloads/mysql/5.0.html
+ Following the installation, set the following FDO Windows environment variable:
+ set FDOMYSQL=<MySQL developer components path>
+ e.g. set FDOMYSQL=c:\Program Files\MySQL\MySQL Server 5.0
+ 6. OPTIONAL: The FDO build includes several generated .cpp files that were
+ generated from source .y files by the Bision and Sed utilities. These
+ files are fairly static therefore they are not automatically regenerated
+ as a part of the standard FDO build process. If changes are made
+ to the .y files they will need to be recompiled into their respective
+ .cpp and .h files.
+ In order to rebuild these files download and install the GNU
+ Win32 Bison (version 1.875) and Sed (version 4.1.4) self-extracting utilities.
+ "Bison"
+ Bison is a general-purpose parser generator that converts a grammar
+ description for an LALR context-free grammar into a C program to parse
+ that grammar.
+ Home Page:
+ http://gnuwin32.sourceforge.net/packages/bison.htm
+ Download Location:
+ http://prdownloads.sourceforge.net/gnuwin32/bison-1.875-1.exe?download
+ "Sed"
+ Sed (streams editor) isn't really a true text editor or text processor.
+ Instead, it is used to filter text, i.e., it takes text input and performs
+ some operation (or set of operations) on it and outputs the modified text.
+ Sed is typically used for extracting part of a file using pattern matching
+ or substituting multiple occurrences of a string within a file.
+ Home Page:
+ http://gnuwin32.sourceforge.net/packages/sed.htm
+ http://prdownloads.sourceforge.net/gnuwin32/sed-4.1.4.exe?download
+ FDO has been tested using Bison 1.875 and Sed 4.1.4 and will not work with
+ other versions of these binaries. The Bison and Sed executable files MUST be
+ included in the Windows PATH in order to be used by the FDO build process.
+ e.g. set PATH=%PATH%;C:\Program Files\GnuWin32\bin
+ The optional FDO build script that will need to be executed to rebuild the
+ generated cpp source files is:
+ build_parse.bat
+ 7. OPTIONAL: The FDO build process allows it's documentation to be regenerated.
+ If this is required, install the OpenSource Doxygen documentation generation
+ software. Doxygen is a documentation system for C++, C, Java, Objective-C,
+ Python, IDL (Corba and Microsoft flavors) and to some extent PHP, C#, and D.
+ To install Doxygen, refer to: http://www.stack.nl/~dimitri/doxygen/
+ The FDO Doxygen documentation generation process will also use the "dot" tool
+ from graphviz 1.5 to generate more advanced diagrams and graphs. Graphviz is an
+ "open-sourced", cross-platform graph drawing toolkit from AT&T and Lucent
+ Bell Labs.
+ To install graphviz, refer to: http://www.research.att.com/sw/tools/graphviz/
+ The FDO Doxygen documentation generation process also uses the Microsoft
+ HTML Help Workshop. Microsoft HTML Help is the standard help system for the
+ Windows platform. Authors can use HTML Help to create online help for a
+ software application or to create content for a multimedia title or Web site.
+ To install the Microsoft HTML Help Workshop, refer to:
+ http://msdn.microsoft.com/library/default.asp?url=/library/en-us/htmlhelp/html/hwMicrosoftHTMLHelpDownloads.asp
+ Ensure that the tools are in the build environment's PATH.
+ Doxygen -- e.g. C:\Program Files\doxygen\bin
+ Dot -- e.g. C:\Program Files\ATT\Graphviz\bin
+ e.g.
+ set PATH=%PATH%;C:\Program Files\doxygen\bin
+ set PATH=%PATH%;C:\Program Files\ATT\Graphviz\bin
+II. Windows Build Instructions:
+ 1. Extract the FDO OpenSource files using either gunzip/tar or Winzip.
+ Use gunzip and tar utilities as follows:
+ gunzip fdo-3.2.0_G007.tar.gz
+ tar -xvf fdo-3.2.0_G007.tar
+ gunzip fdoshp-3.2.0_G007.tar.gz
+ tar -xvf fdoshp-3.2.0_G007.tar
+ gunzip fdosdf-3.2.0_G007.tar.gz
+ tar -xvf fdosdf-3.2.0_G007.tar
+ gunzip fdowms-3.2.0_G007.tar.gz
+ tar -xvf fdowms-3.2.0_G007.tar
+ gunzip fdowfs-3.2.0_G007.tar.gz
+ tar -xvf fdowfs-3.2.0_G007.tar
+ gunzip fdoarcsde-3.2.0_G007.tar.gz
+ tar -xvf fdoarcsde-3.2.0_G007.tar
+ gunzip fdordbms-3.2.0_G007.tar.gz
+ tar -xvf fdordbms-3.2.0_G007.tar
+ - or -
+ Use Windows Winzip utility as follows:
+ WINZIP32.EXE fdo-3.2.0_G007.tar.gz
+ WINZIP32.EXE fdoshp-3.2.0_G007.tar.gz
+ WINZIP32.EXE fdosdf-3.2.0_G007.tar.gz
+ WINZIP32.EXE fdowms-3.2.0_G007.tar.gz
+ WINZIP32.EXE fdowfs-3.2.0_G007.tar.gz
+ WINZIP32.EXE fdoarcsde-3.2.0_G007.tar.gz
+ WINZIP32.EXE fdordbms-3.2.0_G007.tar.gz
+ 2. Use the build_thirdparty.bat file to build the FDO Thirdparty binaries. The following
+ is a general guideline on how to use the build_thirdparty.bat build script.
+ build_thirdparty.bat [-h] [-o=OutFolder] [-c=BuildType] [-a=Action] [-w=WithModule]
+ Help: -h[elp]
+ OutFolder: -o[utpath]=destination folder for binaries
+ BuildType: -c[onfig]=release(default), debug
+ Action: -a[ction]=build(default), buildinstall, install, clean
+ WithModule: -w[ith]=all(default), fdo, providers, sdf, wfs, wms
+ e.g.
+ **** Display help for build.bat
+ build_thirdparty -h
+ **** Build all Thirdparty components
+ build_thirdparty
+ **** Build all Thirdparty components and install output files to C:\Fdo
+ build -o=C:\Fdo -a=buildinstall
+ **** Build all Thirdparty components and install files to C:\Fdo
+ build_thirdparty -o=C:\Fdo -a=buildinstall -d=build
+ **** Build Thirdparty components for FDO libraries
+ build_thirdparty -w=fdo
+ **** Build Thirdparty components for all FDO Providers
+ build_thirdparty -w=providers
+ **** Build Thirdparty components for for SDF Provider
+ build_thirdparty -w=sdf
+ **** Build Thirdparty components for for WMS Provider
+ build_thirdparty -w=wms
+ 3. Use the build.bat file to build the FDO binaries. The following
+ is a general guideline on how to use the build.bat build script.
+ build.bat [-h] [-o=OutFolder] [-c=BuildType] [-a=Action] [-w=WithModule] [-d=BuildDocs]
+ Help: -h[elp]
+ OutFolder: -o[utpath]=destination folder for binaries '
+ WithModule: -w[ith]=all(default), fdo, providers, shp, sdf, wfs, wms, arcsde, odbc, mysql
+ BuildDocs: -d[ocs]=skip(default), build
+ e.g.
+ build -h
+ **** Build all components excluding documentation
+ build
+ **** Build all components and install output files to C:\Fdo
+ **** Build all components and documentation and install files to C:\Fdo
+ build -o=C:\Fdo -a=buildinstall -d=build
+ **** Build only FDO libraries
+ build -w=fdo
+ **** Build all FDO Providers
+ build -w=providers
+ **** Build FDO Shape Provider
+ build -w=shp
+ **** Build FDO SDF Provider
+ build -w=sdf
+ **** Build documentation and install files to C:\Fdo
+ build -o=C:\Fdo -d=build -a=install
+ 4. In order to run the SHP, SDF, and ArcSDE Provider Unit Tests
+ SDF:
+ cd <FDO OpenSource Location>\Providers\SDF\Src\UnitTest
+ ..\..\bin\win32\Debug\UnitTest
+ SHP:
+ cd <FDO OpenSource Location>\Providers\SHP\Src\UnitTest
+ ArcSDE:
+ Please refer to <FDO OpenSource Location>\Providers\ArcSDE\UnitTest_README.txt
+ for details on how to create test users and test data, and which command-line arguments
+ to pass to the ArcSDE Provider UnitTest executable in order to point to your
+ test server and data.
+ cd <FDO OpenSource Location>\Providers\ArcSDE\Src\UnitTest
+ ..\..\bin\win32\Debug\UnitTest <mandatory command-line arguments>
+Linux Instructions
+I. Linux Notes:
+ In preparation for building the Linux Open Source FDO Binaries
+ 1. Before building FDO and thirdparty libraries, the /usr/local
+ directory must be set as writeable by the user, otherwise the user
+ will have to log in and build FDO as the ROOT user. This requirement
+ is due to the fact that the FDO Libraries will be built and installed
+ in /usr/local/fdo-3.2.0/lib
+ 2. Ensure that the following FDO Environment Variables are set as follows:
+ FDO = <FDO OpenSource>/Fdo
+ FDOUTILITIES = <FDO OpenSource>/Providers/Utilities
+ FDOTHIRDPARTY = <FDO OpenSource>/ThirdParty
+ 3. In order to build the ArcSDE Provider, you will need to have the
+ ArcSDE 9.1 Client SDK installed and the following environment variable set that
+ points to the installation location:
+ SDEHOME=<ArcSDE developer components path>
+ 4. In order to build the MySQL Provider, you will need to download and extract
+ the MySQL client and MySQL 5.0 devloper components from MySQL. These
+ components are located at:
+ For example, for Red Hat Enterprise Linux 3 RPM (x86)
+ Client: MySQL-client-standard-5.0.22-0.rhel3.i386.rpm
+ Headers and Libraries: MySQL-devel-standard-5.0.22-0.rhel3.i386.rpm
+ NOTE: Choosing the RPM install of the MySQL components is *strongly*
+ recommended. However, if a non-RPM installation of MySQL is chosen,
+ following the installation, set the following FDO environment variable:
+ FDOMYSQL=<MySQL developer components path>
+ 5. In order to build the ODBC Provider, you will need to either
+ a) download and install the Linux ODBC driver Manager, specifically
+ the unixODBC-CORE and unixODBC-devel packages relased by www.unixodbc.org
+ Home Page:
+ http://www.unixodbc.org/
+ http://sourceforge.net/project/showfiles.php?group_id=1544
+ Download Files:
+ unixODBC-CORE - unixODBC-2.2.11-1.i386.rpm
+ unixODBC-devel - unixODBC-devel-2.2.11-1.i386.rpm
+ Such an installation will install the unixODBC driver manager libraries
+ and header files in
+ usr/lib and usr/include
+ The FDO ODBC provider build will automatically locate thee files in this liocation.
+ b) install an unixODBC driver such as the EasySofy Oracle ODBC driver. This installation
+ will include the driver libraries as well as the unixODBC manager libraries.
+ If such an installation occurs the manager libraries and headers will not be
+ installed under /usr/lib or usr/include but will be installed in a custom location
+ as specified by the driver RPM package. If this is the case, you will need to set
+ the following FDO environment variable to point to the location of the unixODBC
+ components:
+ FDOODBC=<unixODBC developer components path>
+ 6. NOTE: To run the unit test, you must set LD_LIBRARY_PATH as follows:
+ export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/usr/local/fdo-3.2.0/lib:$FDOTHIRDPARTY/linux/cppunit/lib
+ export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:$SDEHOME/lib:$FDOTHIRDPARTY/ESRI/ArcSDEClient91/Linux/lib
+ 7. NOTE: Several known problems exist if auto-mounted drives are used as locations
+ for the FDO Linux builds. It is recommended that users not use auto-mounted drives
+ when building FDO.
+ 8. NOTE: The FDO expression scripts (.y) are not automatially recompiled as a part of the
+ FDO build process. In order to recompile the .y files into their .cpp and .h
+ counterparts, execute the build_parse.sh script.
+II. Linux Build Instructions:
+ 1. Extract the FDO OpenSource files using gunzip/tar.
+ 2. cd <FDO OpenSource Location>
+ 3. Use the build_thirdparty.sh script to build the FDO Thirdparty binaries. The following
+ build_thirdparty.sh [--h] [--a Action] [--m ConfigMakefiles]
+ Help: --h[elp]
+ Action: --a[ction] buildinstall(default), build, install, uninstall, clean
+ ConfigMakefiles: --m[akefile] configure(default), noconfigure
+ e.g.
+ **** Display help for build_thirdparty.sh
+ build_thirdparty --h
+ **** Build and install all Thirdparty components
+ build_thirdparty
+ 4. Use the build_linux.sh script to build and install the FDO OpenSource libraries.
+ The following is a general guideline on how to use build_linux.sh
+ build_linux.sh [--h] [-c BuildType] [--a Action] [--w WithModule] [--m ConfigMakefiles]
+ Help: --h[elp]
+ BuildType: --c[onfig] release(default), debug
+ Action: --a[ction] buildinstall(default), buildonly, installonly, configure
+ WithModule: --w[ith] fdocore(default), fdo, thirdparty, providers, shp, sdf, wfs, wms, arcsde, rdbms
+ e.g.
+ build_linux.sh --h
+ **** ReBuild and Install all components without running configure
+ build_linux.sh
+ **** Configure and ReBuild all components
+ build_linux.sh --a buildonly --a configure
+ **** Configure, ReBuild and Install all components
+ build_linux.sh --a buildinstall --a configure
+ **** ReBuild all components
+ **** Install all components
+ build_linux.sh --a installonly
+ **** ReBuild FDO library
+ build_linux.sh --a buildonly -w fdo
+ **** ReBuild all FDO Providers
+ build_linux.sh --a buildonly --w providers
+ **** ReBuild FDO Shape Provider
+ build_linux.sh --a buildonly --w shp
+ **** ReBuild FDO SDF Provider
+ build_linux.sh --a buildonly --w sdf
+ NOTE: build_linux.sh is a simple helper script that assists developers to build the FDO
+ components. These scripts supplement stand support of configure and make. We have
+ many components in the FDO architecture and building them all was getting somewhat
+ tedious using straight calls to configure and make. We also found that some
+ developers were not interested in building all components or were only interested
+ in building a subset of the components.
+ The implementation of the above build_linux.sh script in essence calls
+ aclocal
+ libtoolize --force
+ automake --add-missing --copy
+ autoconf
+ ./configure
+ make
+ make install
+ for the fdocore components as well as the set of FDO providers that are
+ currently supported on the OSGeo site.
+ 5. In order to run the SHP, SDF and ArcSDE Provider Unit Tests:
+ SDF:
+ cd <FDO OpenSource>/Providers/SDF/Src/UnitTest
+ ./UnitTest
+ SHP:
+ cd <FDO OpenSource>/Providers/SHP/Src/UnitTest
+ ./UnitTest
+ ArcSDE:
+ Please refer to <FDO OpenSource>\Providers\ArcSDE\UnitTest_README.txt
+ command-line arguments to pass to the ArcSDE Provider UnitTest
+ executable in order to point to your test server and data.
+ cd <FDO OpenSource>\Providers\ArcSDE\Src\UnitTest
+<end>
+</pre>
+</body>
+</html>
More information about the Fdo-commits
